[U-Boot] [PATCH] usb: Do not compile USB_STORAGE with !BLK && !DM_USB
The USB storage driver does not compile when CONFIG_BLK is set, but DM_USB is not set, as we're missing the DM device links for CONFIG_BLK enabled code paths.
So far it looks like nobody fell into this trap, because no board enabled CONFIG_BLK and CONFIG_USB_STORAGE while not enabling CONFIG_DM_USB, but we should still reflect that dependency properly in Kconfig so that implicit enabling of CONFIG_USB_STORAGE works.
Signed-off-by: Alexander Graf agraf@suse.de --- drivers/usb/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/usb/Kconfig b/drivers/usb/Kconfig index 4fbe172e05..297dda1511 100644 --- a/drivers/usb/Kconfig +++ b/drivers/usb/Kconfig @@ -65,6 +65,7 @@ comment "USB peripherals"
config USB_STORAGE bool "USB Mass Storage support" + depends on DM_USB || !BLK ---help--- Say Y here if you want to connect USB mass storage devices to your board's USB port.
Can we fix it such that it'd compile ? :)
- depends on DM_USB || !BLK ---help--- Say Y here if you want to connect USB mass storage devices to your board's USB port.
I'm not sure. It feels awkward to allow code to use DM enabled block functions, but not DM enabled USB functionality. I can definitely see why the code tripped over :).
Wasn't Simon planning to rip out non-DM enabled devices soon'ish anyways?
Alex
I dunno. Which devices have this problem ?
The ones I've seen (enable DISTRO_DEFAULTS, enable USB, enable CONFIG_BLK, don't enable DM_USB and don't enable USB_STORAGE today) are mostly i.MX6 and OMAP/AM[3-5]xxx based.
Alex
Alexander Graf
