[U-Boot] [PATCH 1/4] 4xx: Add fdt support for VOM405 boards
Signed-off-by: Matthias Fuchs mf@esd.eu --- include/configs/VOM405.h | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index ec6f205..43404fc 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -87,6 +87,8 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_EEPROM
+#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP
#undef CONFIG_WATCHDOG /* watchdog disabled */
From: Matthias Fuchs matthias.fuchs@esd-electronics.com
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- board/esd/vom405/u-boot.lds | 12 ------------ 1 files changed, 0 insertions(+), 12 deletions(-)
diff --git a/board/esd/vom405/u-boot.lds b/board/esd/vom405/u-boot.lds index 21547ac..5d07e44 100644 --- a/board/esd/vom405/u-boot.lds +++ b/board/esd/vom405/u-boot.lds @@ -61,18 +61,6 @@ SECTIONS /* the sector layout of our flash chips! XXX FIXME XXX */
cpu/ppc4xx/start.o (.text) - cpu/ppc4xx/traps.o (.text) - cpu/ppc4xx/interrupts.o (.text) - cpu/ppc4xx/4xx_uart.o (.text) - cpu/ppc4xx/cpu_init.o (.text) - cpu/ppc4xx/speed.o (.text) - common/dlmalloc.o (.text) - lib_generic/crc32.o (.text) - lib_ppc/extable.o (.text) - lib_generic/zlib.o (.text) - -/* . = env_offset;*/ -/* common/environment.o(.text)*/
*(.text) *(.fixup)
This patch removed the obsolete initdram() function from VOM405 platform file.
Some minor cleanup.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- board/esd/vom405/vom405.c | 25 ------------------------- 1 files changed, 0 insertions(+), 25 deletions(-)
diff --git a/board/esd/vom405/vom405.c b/board/esd/vom405/vom405.c index af8efcf..1b1479f 100644 --- a/board/esd/vom405/vom405.c +++ b/board/esd/vom405/vom405.c @@ -37,7 +37,6 @@ const unsigned char fpgadata[] = }; int filesize = sizeof(fpgadata);
- int board_early_init_f (void) { /* @@ -76,9 +75,6 @@ int board_early_init_f (void) return 0; }
- -/* ------------------------------------------------------------------------- */ - int misc_init_r (void) { /* adjust flash start and offset */ @@ -88,11 +84,9 @@ int misc_init_r (void) return (0); }
- /* * Check Board Identity: */ - int checkboard (void) { char str[64]; @@ -127,25 +121,6 @@ int checkboard (void) return 0; }
-/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - -#if 0 - printf("\nmb0cf=%x\n", val); /* test-only */ - printf("strap=%x\n", mfdcr(strap)); /* test-only */ -#endif - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - -/* ------------------------------------------------------------------------- */ - void reset_phy(void) { #ifdef CONFIG_LXT971_NO_SLEEP
- remove PCI code - add command line editing - minor cleanup
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- include/configs/VOM405.h | 52 ++++++++-------------------------------------- 1 files changed, 9 insertions(+), 43 deletions(-)
diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index 43404fc..f235890 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -24,7 +24,6 @@ /* * board/config.h - configuration options, board specific */ - #ifndef __CONFIG_H #define __CONFIG_H
@@ -32,7 +31,6 @@ * High Level Configuration Options * (easy to change) */ - #define CONFIG_405EP 1 /* This is a PPC405 CPU */ #define CONFIG_4xx 1 /* ...member of PPC4xx family */ #define CONFIG_VOM405 1 /* ...on a VOM405 board */ @@ -71,7 +69,6 @@ #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME
- /* * Command line configuration. */ @@ -79,7 +76,6 @@
#define CONFIG_CMD_DHCP #define CONFIG_CMD_BSP -#define CONFIG_CMD_PCI #define CONFIG_CMD_IRQ #define CONFIG_CMD_ELF #define CONFIG_CMD_I2C @@ -138,44 +134,20 @@
#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */
+#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */
#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
#define CFG_RX_ETH_BUFFER 16 /* use 16 rx buffer on 405 emac */
-/*----------------------------------------------------------------------- - * PCI stuff - *----------------------------------------------------------------------- - */ -#define PCI_HOST_ADAPTER 0 /* configure as pci adapter */ -#define PCI_HOST_FORCE 1 /* configure as pci host */ -#define PCI_HOST_AUTO 2 /* detected via arbiter enable */ - -#define CONFIG_PCI /* include pci support */ -#define CONFIG_PCI_HOST PCI_HOST_HOST /* select pci host function */ -#undef CONFIG_PCI_PNP /* do pci plug-and-play */ - /* resource configuration */ - -#undef CONFIG_PCI_SCAN_SHOW /* print pci devices @ startup */ - -#define CFG_PCI_SUBSYS_VENDORID 0x12FE /* PCI Vendor ID: esd gmbh */ -#define CFG_PCI_SUBSYS_DEVICEID 0x0405 /* PCI Device ID: CPCI-405 */ -#define CFG_PCI_CLASSCODE 0x0b20 /* PCI Class Code: Processor/PPC*/ -#define CFG_PCI_PTM1LA 0x00000000 /* point to sdram */ -#define CFG_PCI_PTM1MS 0xfc000001 /* 64MB, enable hard-wired to 1 */ -#define CFG_PCI_PTM1PCI 0x00000000 /* Host: use this pci address */ -#define CFG_PCI_PTM2LA 0xffc00000 /* point to flash */ -#define CFG_PCI_PTM2MS 0xffc00001 /* 4MB, enable */ -#define CFG_PCI_PTM2PCI 0x04000000 /* Host: use this pci address */ - /* * For booting Linux, the board info and command line data * have to be in the first 8 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ -/*----------------------------------------------------------------------- +/* * FLASH organization */ #define FLASH_BASE0_PRELIM 0xFFC00000 /* FLASH bank #0 */ @@ -199,12 +171,7 @@
#define CFG_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
-#if 0 /* test-only */ -#define CFG_JFFS2_FIRST_BANK 0 /* use for JFFS2 */ -#define CFG_JFFS2_NUM_BANKS 1 /* ! second bank contains U-Boot */ -#endif - -/*----------------------------------------------------------------------- +/* * Start addresses for the final memory configuration * (Set up by the startup code) * Please note that CFG_SDRAM_BASE _must_ start at 0 @@ -221,7 +188,7 @@ # undef CFG_RAMBOOT #endif
-/*----------------------------------------------------------------------- +/* * Environment Variable setup */ #define CFG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ @@ -232,7 +199,7 @@ #define CFG_NVRAM_BASE_ADDR 0xF0000500 /* NVRAM base address */ #define CFG_NVRAM_SIZE 242 /* NVRAM size */
-/*----------------------------------------------------------------------- +/* * I2C EEPROM (CAT24WC16) for environment */ #define CONFIG_HARD_I2C /* I2c with hardware support */ @@ -249,10 +216,9 @@ #define CFG_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */ #define CFG_EEPROM_PAGE_WRITE_ENABLE
-/*----------------------------------------------------------------------- +/* * External Bus Controller (EBC) Setup */ - #define CAN_BA 0xF0000000 /* CAN Base Address */
/* Memory Bank 0 (Flash Bank 0, NOR-FLASH) initialization */ @@ -263,7 +229,7 @@ #define CFG_EBC_PB2AP 0x010053C0 /* BWT=2,WBN=1,WBF=1,TH=1,RE=1,SOR=1,BEM=1 */ #define CFG_EBC_PB2CR 0xF0018000 /* BAS=0xF00,BS=1MB,BU=R/W,BW=8bit */
-/*----------------------------------------------------------------------- +/* * FPGA stuff */ #define CFG_FPGA_XC95XL 1 /* using Xilinx XC95XL CPLD */ @@ -276,7 +242,7 @@ #define CFG_FPGA_INIT 0x00010000 /* unused (ppc input) */ #define CFG_FPGA_DONE 0x00008000 /* JTAG TDI->TDO pin (ppc input) */
-/*----------------------------------------------------------------------- +/* * Definitions for initial stack pointer and data area (in data cache) */ /* use on chip memory ( OCM ) for temperary stack until sdram is tested */ @@ -292,7 +258,7 @@ #define CFG_GBL_DATA_OFFSET (CFG_INIT_RAM_END - CFG_GBL_DATA_SIZE) #define CFG_INIT_SP_OFFSET CFG_GBL_DATA_OFFSET
-/*----------------------------------------------------------------------- +/* * Definitions for GPIO setup (PPC405EP specific) * * GPIO0[0] - External Bus Controller BLAST output
On Tuesday 02 September 2008, matthias.fuchs@esd-electronics.com wrote:
All [1...4] applied to u-boot-ppc4xx. Thanks.
Best regards, Stefan
Stefan Roese
