[U-Boot] [PATCH v9 14/14] sf: Rename sf_ops.c to spi_flash.c
Since all spi_flash core operations are moved into sf_ops.c then it's better to renamed as spi_flash.c
Reviewed-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Jagan Teki jteki@openedev.com --- Changes for v9: - Renamed spi-flash.c to spi_flash.c
drivers/mtd/spi/Makefile | 2 +- drivers/mtd/spi/sf_ops.c | 1114 ------------------------------------------ drivers/mtd/spi/spi_flash.c | 1115 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 1116 insertions(+), 1115 deletions(-) delete mode 100644 drivers/mtd/spi/sf_ops.c create mode 100644 drivers/mtd/spi/spi_flash.c
diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index a24f761..c665836 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -12,7 +12,7 @@ obj-$(CONFIG_SPL_SPI_LOAD) += spi_spl_load.o obj-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o endif
-obj-$(CONFIG_SPI_FLASH) += sf_probe.o sf_ops.o sf_params.o sf.o +obj-$(CONFIG_SPI_FLASH) += sf_probe.o spi_flash.o sf_params.o sf.o obj-$(CONFIG_SPI_FLASH_DATAFLASH) += sf_dataflash.o obj-$(CONFIG_SPI_FLASH_MTD) += sf_mtd.o obj-$(CONFIG_SPI_FLASH_SANDBOX) += sandbox.o diff --git a/drivers/mtd/spi/sf_ops.c b/drivers/mtd/spi/sf_ops.c deleted file mode 100644 index c065858..0000000 --- a/drivers/mtd/spi/sf_ops.c +++ /dev/null @@ -1,1114 +0,0 @@ -/* - * SPI flash operations - * - * Copyright (C) 2008 Atmel Corporation - * Copyright (C) 2010 Reinhard Meyer, EMK Elektronik - * Copyright (C) 2013 Jagannadha Sutradharudu Teki, Xilinx Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <errno.h> -#include <malloc.h> -#include <mapmem.h> -#include <spi.h> -#include <spi_flash.h> -#include <linux/log2.h> - -#include "sf_internal.h" - -DECLARE_GLOBAL_DATA_PTR; - -static void spi_flash_addr(u32 addr, u8 *cmd) -{ - /* cmd[0] is actual command */ - cmd[1] = addr >> 16; - cmd[2] = addr >> 8; - cmd[3] = addr >> 0; -} - -/* Read commands array */ -static u8 spi_read_cmds_array[] = { - CMD_READ_ARRAY_SLOW, - CMD_READ_ARRAY_FAST, - CMD_READ_DUAL_OUTPUT_FAST, - CMD_READ_DUAL_IO_FAST, - CMD_READ_QUAD_OUTPUT_FAST, - CMD_READ_QUAD_IO_FAST, -}; - -static int read_sr(struct spi_flash *flash, u8 *rs) -{ - int ret; - u8 cmd; - - cmd = CMD_READ_STATUS; - ret = spi_flash_read_common(flash, &cmd, 1, rs, 1); - if (ret < 0) { - debug("SF: fail to read status register\n"); - return ret; - } - - return 0; -} - -static int read_fsr(struct spi_flash *flash, u8 *fsr) -{ - int ret; - const u8 cmd = CMD_FLAG_STATUS; - - ret = spi_flash_read_common(flash, &cmd, 1, fsr, 1); - if (ret < 0) { - debug("SF: fail to read flag status register\n"); - return ret; - } - - return 0; -} - -static int write_sr(struct spi_flash *flash, u8 ws) -{ - u8 cmd; - int ret; - - cmd = CMD_WRITE_STATUS; - ret = spi_flash_write_common(flash, &cmd, 1, &ws, 1); - if (ret < 0) { - debug("SF: fail to write status register\n"); - return ret; - } - - return 0; -} - -#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) -static int read_cr(struct spi_flash *flash, u8 *rc) -{ - int ret; - u8 cmd; - - cmd = CMD_READ_CONFIG; - ret = spi_flash_read_common(flash, &cmd, 1, rc, 1); - if (ret < 0) { - debug("SF: fail to read config register\n"); - return ret; - } - - return 0; -} - -static int write_cr(struct spi_flash *flash, u8 wc) -{ - u8 data[2]; - u8 cmd; - int ret; - - ret = read_sr(flash, &data[0]); - if (ret < 0) - return ret; - - cmd = CMD_WRITE_STATUS; - data[1] = wc; - ret = spi_flash_write_common(flash, &cmd, 1, &data, 2); - if (ret) { - debug("SF: fail to write config register\n"); - return ret; - } - - return 0; -} -#endif - -#ifdef CONFIG_SPI_FLASH_BAR -static int spi_flash_write_bar(struct spi_flash *flash, u32 offset) -{ - u8 cmd, bank_sel; - int ret; - - bank_sel = offset / (SPI_FLASH_16MB_BOUN << flash->shift); - if (bank_sel == flash->bank_curr) - goto bar_end; - - cmd = flash->bank_write_cmd; - ret = spi_flash_write_common(flash, &cmd, 1, &bank_sel, 1); - if (ret < 0) { - debug("SF: fail to write bank register\n"); - return ret; - } - -bar_end: - flash->bank_curr = bank_sel; - return flash->bank_curr; -} - -static int spi_flash_read_bar(struct spi_flash *flash, u8 idcode0) -{ - u8 curr_bank = 0; - int ret; - - if (flash->size <= SPI_FLASH_16MB_BOUN) - goto bank_end; - - switch (idcode0) { - case SPI_FLASH_CFI_MFR_SPANSION: - flash->bank_read_cmd = CMD_BANKADDR_BRRD; - flash->bank_write_cmd = CMD_BANKADDR_BRWR; - break; - default: - flash->bank_read_cmd = CMD_EXTNADDR_RDEAR; - flash->bank_write_cmd = CMD_EXTNADDR_WREAR; - } - - ret = spi_flash_read_common(flash, &flash->bank_read_cmd, 1, - &curr_bank, 1); - if (ret) { - debug("SF: fail to read bank addr register\n"); - return ret; - } - -bank_end: - flash->bank_curr = curr_bank; - return 0; -} -#endif - -#ifdef CONFIG_SF_DUAL_FLASH -static void spi_flash_dual(struct spi_flash *flash, u32 *addr) -{ - switch (flash->dual_flash) { - case SF_DUAL_STACKED_FLASH: - if (*addr >= (flash->size >> 1)) { - *addr -= flash->size >> 1; - flash->spi->flags |= SPI_XFER_U_PAGE; - } else { - flash->spi->flags &= ~SPI_XFER_U_PAGE; - } - break; - case SF_DUAL_PARALLEL_FLASH: - *addr >>= flash->shift; - break; - default: - debug("SF: Unsupported dual_flash=%d\n", flash->dual_flash); - break; - } -} -#endif - -static int spi_flash_sr_ready(struct spi_flash *flash) -{ - u8 sr; - int ret; - - ret = read_sr(flash, &sr); - if (ret < 0) - return ret; - - return !(sr & STATUS_WIP); -} - -static int spi_flash_fsr_ready(struct spi_flash *flash) -{ - u8 fsr; - int ret; - - ret = read_fsr(flash, &fsr); - if (ret < 0) - return ret; - - return fsr & STATUS_PEC; -} - -static int spi_flash_ready(struct spi_flash *flash) -{ - int sr, fsr; - - sr = spi_flash_sr_ready(flash); - if (sr < 0) - return sr; - - fsr = 1; - if (flash->flags & SNOR_F_USE_FSR) { - fsr = spi_flash_fsr_ready(flash); - if (fsr < 0) - return fsr; - } - - return sr && fsr; -} - -static int spi_flash_cmd_wait_ready(struct spi_flash *flash, - unsigned long timeout) -{ - int timebase, ret; - - timebase = get_timer(0); - - while (get_timer(timebase) < timeout) { - ret = spi_flash_ready(flash); - if (ret < 0) - return ret; - if (ret) - return 0; - } - - printf("SF: Timeout!\n"); - - return -ETIMEDOUT; -} - -int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, - size_t cmd_len, const void *buf, size_t buf_len) -{ - struct spi_slave *spi = flash->spi; - unsigned long timeout = SPI_FLASH_PROG_TIMEOUT; - int ret; - - if (buf == NULL) - timeout = SPI_FLASH_PAGE_ERASE_TIMEOUT; - - ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: unable to claim SPI bus\n"); - return ret; - } - - ret = spi_flash_cmd_write_enable(flash); - if (ret < 0) { - debug("SF: enabling write failed\n"); - return ret; - } - - ret = spi_flash_cmd_write(spi, cmd, cmd_len, buf, buf_len); - if (ret < 0) { - debug("SF: write cmd failed\n"); - return ret; - } - - ret = spi_flash_cmd_wait_ready(flash, timeout); - if (ret < 0) { - debug("SF: write %s timed out\n", - timeout == SPI_FLASH_PROG_TIMEOUT ? - "program" : "page erase"); - return ret; - } - - spi_release_bus(spi); - - return ret; -} - -int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) -{ - u32 erase_size, erase_addr; - u8 cmd[SPI_FLASH_CMD_LEN]; - int ret = -1; - - erase_size = flash->erase_size; - if (offset % erase_size || len % erase_size) { - debug("SF: Erase offset/length not multiple of erase size\n"); - return -1; - } - - if (flash->flash_is_locked) { - if (flash->flash_is_locked(flash, offset, len) > 0) { - printf("offset 0x%x is protected and cannot be erased\n", - offset); - return -EINVAL; - } - } - - cmd[0] = flash->erase_cmd; - while (len) { - erase_addr = offset; - -#ifdef CONFIG_SF_DUAL_FLASH - if (flash->dual_flash > SF_SINGLE_FLASH) - spi_flash_dual(flash, &erase_addr); -#endif -#ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_write_bar(flash, erase_addr); - if (ret < 0) - return ret; -#endif - spi_flash_addr(erase_addr, cmd); - - debug("SF: erase %2x %2x %2x %2x (%x)\n", cmd[0], cmd[1], - cmd[2], cmd[3], erase_addr); - - ret = spi_flash_write_common(flash, cmd, sizeof(cmd), NULL, 0); - if (ret < 0) { - debug("SF: erase failed\n"); - break; - } - - offset += erase_size; - len -= erase_size; - } - - return ret; -} - -int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, - size_t len, const void *buf) -{ - unsigned long byte_addr, page_size; - u32 write_addr; - size_t chunk_len, actual; - u8 cmd[SPI_FLASH_CMD_LEN]; - int ret = -1; - - page_size = flash->page_size; - - if (flash->flash_is_locked) { - if (flash->flash_is_locked(flash, offset, len) > 0) { - printf("offset 0x%x is protected and cannot be written\n", - offset); - return -EINVAL; - } - } - - cmd[0] = flash->write_cmd; - for (actual = 0; actual < len; actual += chunk_len) { - write_addr = offset; - -#ifdef CONFIG_SF_DUAL_FLASH - if (flash->dual_flash > SF_SINGLE_FLASH) - spi_flash_dual(flash, &write_addr); -#endif -#ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_write_bar(flash, write_addr); - if (ret < 0) - return ret; -#endif - byte_addr = offset % page_size; - chunk_len = min(len - actual, (size_t)(page_size - byte_addr)); - - if (flash->spi->max_write_size) - chunk_len = min(chunk_len, - (size_t)flash->spi->max_write_size); - - spi_flash_addr(write_addr, cmd); - - debug("SF: 0x%p => cmd = { 0x%02x 0x%02x%02x%02x } chunk_len = %zu\n", - buf + actual, cmd[0], cmd[1], cmd[2], cmd[3], chunk_len); - - ret = spi_flash_write_common(flash, cmd, sizeof(cmd), - buf + actual, chunk_len); - if (ret < 0) { - debug("SF: write failed\n"); - break; - } - - offset += chunk_len; - } - - return ret; -} - -int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, - size_t cmd_len, void *data, size_t data_len) -{ - struct spi_slave *spi = flash->spi; - int ret; - - ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: unable to claim SPI bus\n"); - return ret; - } - - ret = spi_flash_cmd_read(spi, cmd, cmd_len, data, data_len); - if (ret < 0) { - debug("SF: read cmd failed\n"); - return ret; - } - - spi_release_bus(spi); - - return ret; -} - -void __weak spi_flash_copy_mmap(void *data, void *offset, size_t len) -{ - memcpy(data, offset, len); -} - -int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, - size_t len, void *data) -{ - u8 *cmd, cmdsz; - u32 remain_len, read_len, read_addr; - int bank_sel = 0; - int ret = -1; - - /* Handle memory-mapped SPI */ - if (flash->memory_map) { - ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: unable to claim SPI bus\n"); - return ret; - } - spi_xfer(flash->spi, 0, NULL, NULL, SPI_XFER_MMAP); - spi_flash_copy_mmap(data, flash->memory_map + offset, len); - spi_xfer(flash->spi, 0, NULL, NULL, SPI_XFER_MMAP_END); - spi_release_bus(flash->spi); - return 0; - } - - cmdsz = SPI_FLASH_CMD_LEN + flash->dummy_byte; - cmd = calloc(1, cmdsz); - if (!cmd) { - debug("SF: Failed to allocate cmd\n"); - return -ENOMEM; - } - - cmd[0] = flash->read_cmd; - while (len) { - read_addr = offset; - -#ifdef CONFIG_SF_DUAL_FLASH - if (flash->dual_flash > SF_SINGLE_FLASH) - spi_flash_dual(flash, &read_addr); -#endif -#ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_write_bar(flash, read_addr); - if (ret < 0) - return ret; - bank_sel = flash->bank_curr; -#endif - remain_len = ((SPI_FLASH_16MB_BOUN << flash->shift) * - (bank_sel + 1)) - offset; - if (len < remain_len) - read_len = len; - else - read_len = remain_len; - - spi_flash_addr(read_addr, cmd); - - ret = spi_flash_read_common(flash, cmd, cmdsz, data, read_len); - if (ret < 0) { - debug("SF: read failed\n"); - break; - } - - offset += read_len; - len -= read_len; - data += read_len; - } - - free(cmd); - return ret; -} - -#ifdef CONFIG_SPI_FLASH_SST -static int sst_byte_write(struct spi_flash *flash, u32 offset, const void *buf) -{ - int ret; - u8 cmd[4] = { - CMD_SST_BP, - offset >> 16, - offset >> 8, - offset, - }; - - debug("BP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", - spi_w8r8(flash->spi, CMD_READ_STATUS), buf, cmd[0], offset); - - ret = spi_flash_cmd_write_enable(flash); - if (ret) - return ret; - - ret = spi_flash_cmd_write(flash->spi, cmd, sizeof(cmd), buf, 1); - if (ret) - return ret; - - return spi_flash_cmd_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); -} - -int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, - const void *buf) -{ - size_t actual, cmd_len; - int ret; - u8 cmd[4]; - - ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: Unable to claim SPI bus\n"); - return ret; - } - - /* If the data is not word aligned, write out leading single byte */ - actual = offset % 2; - if (actual) { - ret = sst_byte_write(flash, offset, buf); - if (ret) - goto done; - } - offset += actual; - - ret = spi_flash_cmd_write_enable(flash); - if (ret) - goto done; - - cmd_len = 4; - cmd[0] = CMD_SST_AAI_WP; - cmd[1] = offset >> 16; - cmd[2] = offset >> 8; - cmd[3] = offset; - - for (; actual < len - 1; actual += 2) { - debug("WP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", - spi_w8r8(flash->spi, CMD_READ_STATUS), buf + actual, - cmd[0], offset); - - ret = spi_flash_cmd_write(flash->spi, cmd, cmd_len, - buf + actual, 2); - if (ret) { - debug("SF: sst word program failed\n"); - break; - } - - ret = spi_flash_cmd_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); - if (ret) - break; - - cmd_len = 1; - offset += 2; - } - - if (!ret) - ret = spi_flash_cmd_write_disable(flash); - - /* If there is a single trailing byte, write it out */ - if (!ret && actual != len) - ret = sst_byte_write(flash, offset, buf + actual); - - done: - debug("SF: sst: program %s %zu bytes @ 0x%zx\n", - ret ? "failure" : "success", len, offset - actual); - - spi_release_bus(flash->spi); - return ret; -} - -int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, - const void *buf) -{ - size_t actual; - int ret; - - ret = spi_claim_bus(flash->spi); - if (ret) { - debug("SF: Unable to claim SPI bus\n"); - return ret; - } - - for (actual = 0; actual < len; actual++) { - ret = sst_byte_write(flash, offset, buf + actual); - if (ret) { - debug("SF: sst byte program failed\n"); - break; - } - offset++; - } - - if (!ret) - ret = spi_flash_cmd_write_disable(flash); - - debug("SF: sst: program %s %zu bytes @ 0x%zx\n", - ret ? "failure" : "success", len, offset - actual); - - spi_release_bus(flash->spi); - return ret; -} -#endif - -#if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) -static void stm_get_locked_range(struct spi_flash *flash, u8 sr, loff_t *ofs, - u32 *len) -{ - u8 mask = SR_BP2 | SR_BP1 | SR_BP0; - int shift = ffs(mask) - 1; - int pow; - - if (!(sr & mask)) { - /* No protection */ - *ofs = 0; - *len = 0; - } else { - pow = ((sr & mask) ^ mask) >> shift; - *len = flash->size >> pow; - *ofs = flash->size - *len; - } -} - -/* - * Return 1 if the entire region is locked, 0 otherwise - */ -static int stm_is_locked_sr(struct spi_flash *flash, u32 ofs, u32 len, - u8 sr) -{ - loff_t lock_offs; - u32 lock_len; - - stm_get_locked_range(flash, sr, &lock_offs, &lock_len); - - return (ofs + len <= lock_offs + lock_len) && (ofs >= lock_offs); -} - -/* - * Check if a region of the flash is (completely) locked. See stm_lock() for - * more info. - * - * Returns 1 if entire region is locked, 0 if any portion is unlocked, and - * negative on errors. - */ -int stm_is_locked(struct spi_flash *flash, u32 ofs, size_t len) -{ - int status; - u8 sr; - - status = read_sr(flash, &sr); - if (status < 0) - return status; - - return stm_is_locked_sr(flash, ofs, len, sr); -} - -/* - * Lock a region of the flash. Compatible with ST Micro and similar flash. - * Supports only the block protection bits BP{0,1,2} in the status register - * (SR). Does not support these features found in newer SR bitfields: - * - TB: top/bottom protect - only handle TB=0 (top protect) - * - SEC: sector/block protect - only handle SEC=0 (block protect) - * - CMP: complement protect - only support CMP=0 (range is not complemented) - * - * Sample table portion for 8MB flash (Winbond w25q64fw): - * - * SEC | TB | BP2 | BP1 | BP0 | Prot Length | Protected Portion - * -------------------------------------------------------------------------- - * X | X | 0 | 0 | 0 | NONE | NONE - * 0 | 0 | 0 | 0 | 1 | 128 KB | Upper 1/64 - * 0 | 0 | 0 | 1 | 0 | 256 KB | Upper 1/32 - * 0 | 0 | 0 | 1 | 1 | 512 KB | Upper 1/16 - * 0 | 0 | 1 | 0 | 0 | 1 MB | Upper 1/8 - * 0 | 0 | 1 | 0 | 1 | 2 MB | Upper 1/4 - * 0 | 0 | 1 | 1 | 0 | 4 MB | Upper 1/2 - * X | X | 1 | 1 | 1 | 8 MB | ALL - * - * Returns negative on errors, 0 on success. - */ -int stm_lock(struct spi_flash *flash, u32 ofs, size_t len) -{ - u8 status_old, status_new; - u8 mask = SR_BP2 | SR_BP1 | SR_BP0; - u8 shift = ffs(mask) - 1, pow, val; - int ret; - - ret = read_sr(flash, &status_old); - if (ret < 0) - return ret; - - /* SPI NOR always locks to the end */ - if (ofs + len != flash->size) { - /* Does combined region extend to end? */ - if (!stm_is_locked_sr(flash, ofs + len, flash->size - ofs - len, - status_old)) - return -EINVAL; - len = flash->size - ofs; - } - - /* - * Need smallest pow such that: - * - * 1 / (2^pow) <= (len / size) - * - * so (assuming power-of-2 size) we do: - * - * pow = ceil(log2(size / len)) = log2(size) - floor(log2(len)) - */ - pow = ilog2(flash->size) - ilog2(len); - val = mask - (pow << shift); - if (val & ~mask) - return -EINVAL; - - /* Don't "lock" with no region! */ - if (!(val & mask)) - return -EINVAL; - - status_new = (status_old & ~mask) | val; - - /* Only modify protection if it will not unlock other areas */ - if ((status_new & mask) <= (status_old & mask)) - return -EINVAL; - - write_sr(flash, status_new); - - return 0; -} - -/* - * Unlock a region of the flash. See stm_lock() for more info - * - * Returns negative on errors, 0 on success. - */ -int stm_unlock(struct spi_flash *flash, u32 ofs, size_t len) -{ - uint8_t status_old, status_new; - u8 mask = SR_BP2 | SR_BP1 | SR_BP0; - u8 shift = ffs(mask) - 1, pow, val; - int ret; - - ret = read_sr(flash, &status_old); - if (ret < 0) - return ret; - - /* Cannot unlock; would unlock larger region than requested */ - if (stm_is_locked_sr(flash, status_old, ofs - flash->erase_size, - flash->erase_size)) - return -EINVAL; - /* - * Need largest pow such that: - * - * 1 / (2^pow) >= (len / size) - * - * so (assuming power-of-2 size) we do: - * - * pow = floor(log2(size / len)) = log2(size) - ceil(log2(len)) - */ - pow = ilog2(flash->size) - order_base_2(flash->size - (ofs + len)); - if (ofs + len == flash->size) { - val = 0; /* fully unlocked */ - } else { - val = mask - (pow << shift); - /* Some power-of-two sizes are not supported */ - if (val & ~mask) - return -EINVAL; - } - - status_new = (status_old & ~mask) | val; - - /* Only modify protection if it will not lock other areas */ - if ((status_new & mask) >= (status_old & mask)) - return -EINVAL; - - write_sr(flash, status_new); - - return 0; -} -#endif - - -#ifdef CONFIG_SPI_FLASH_MACRONIX -static int spi_flash_set_qeb_mxic(struct spi_flash *flash) -{ - u8 qeb_status; - int ret; - - ret = read_sr(flash, &qeb_status); - if (ret < 0) - return ret; - - if (qeb_status & STATUS_QEB_MXIC) { - debug("SF: mxic: QEB is already set\n"); - } else { - ret = write_sr(flash, STATUS_QEB_MXIC); - if (ret < 0) - return ret; - } - - return ret; -} -#endif - -#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) -static int spi_flash_set_qeb_winspan(struct spi_flash *flash) -{ - u8 qeb_status; - int ret; - - ret = read_cr(flash, &qeb_status); - if (ret < 0) - return ret; - - if (qeb_status & STATUS_QEB_WINSPAN) { - debug("SF: winspan: QEB is already set\n"); - } else { - ret = write_cr(flash, STATUS_QEB_WINSPAN); - if (ret < 0) - return ret; - } - - return ret; -} -#endif - -static int spi_flash_set_qeb(struct spi_flash *flash, u8 idcode0) -{ - switch (idcode0) { -#ifdef CONFIG_SPI_FLASH_MACRONIX - case SPI_FLASH_CFI_MFR_MACRONIX: - return spi_flash_set_qeb_mxic(flash); -#endif -#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) - case SPI_FLASH_CFI_MFR_SPANSION: - case SPI_FLASH_CFI_MFR_WINBOND: - return spi_flash_set_qeb_winspan(flash); -#endif -#ifdef CONFIG_SPI_FLASH_STMICRO - case SPI_FLASH_CFI_MFR_STMICRO: - debug("SF: QEB is volatile for %02x flash\n", idcode0); - return 0; -#endif - default: - printf("SF: Need set QEB func for %02x flash\n", idcode0); - return -1; - } -} - -#if CONFIG_IS_ENABLED(OF_CONTROL) -int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) -{ - fdt_addr_t addr; - fdt_size_t size; - int node; - - /* If there is no node, do nothing */ - node = fdtdec_next_compatible(blob, 0, COMPAT_GENERIC_SPI_FLASH); - if (node < 0) - return 0; - - addr = fdtdec_get_addr_size(blob, node, "memory-map", &size); - if (addr == FDT_ADDR_T_NONE) { - debug("%s: Cannot decode address\n", __func__); - return 0; - } - - if (flash->size != size) { - debug("%s: Memory map must cover entire device\n", __func__); - return -1; - } - flash->memory_map = map_sysmem(addr, size); - - return 0; -} -#endif /* CONFIG_IS_ENABLED(OF_CONTROL) */ - -int spi_flash_scan(struct spi_flash *flash) -{ - struct spi_slave *spi = flash->spi; - const struct spi_flash_params *params; - u16 jedec, ext_jedec; - u8 idcode[5]; - u8 cmd; - int ret; - - /* Read the ID codes */ - ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode)); - if (ret) { - printf("SF: Failed to get idcodes\n"); - return -EINVAL; - } - -#ifdef DEBUG - printf("SF: Got idcodes\n"); - print_buffer(0, idcode, 1, sizeof(idcode), 0); -#endif - - jedec = idcode[1] << 8 | idcode[2]; - ext_jedec = idcode[3] << 8 | idcode[4]; - - /* Validate params from spi_flash_params table */ - params = spi_flash_params_table; - for (; params->name != NULL; params++) { - if ((params->jedec >> 16) == idcode[0]) { - if ((params->jedec & 0xFFFF) == jedec) { - if (params->ext_jedec == 0) - break; - else if (params->ext_jedec == ext_jedec) - break; - } - } - } - - if (!params->name) { - printf("SF: Unsupported flash IDs: "); - printf("manuf %02x, jedec %04x, ext_jedec %04x\n", - idcode[0], jedec, ext_jedec); - return -EPROTONOSUPPORT; - } - - /* Flash powers up read-only, so clear BP# bits */ - if (idcode[0] == SPI_FLASH_CFI_MFR_ATMEL || - idcode[0] == SPI_FLASH_CFI_MFR_MACRONIX || - idcode[0] == SPI_FLASH_CFI_MFR_SST) - write_sr(flash, 0); - - /* Assign spi data */ - flash->name = params->name; - flash->memory_map = spi->memory_map; - flash->dual_flash = flash->spi->option; - - /* Assign spi flash flags */ - if (params->flags & SST_WR) - flash->flags |= SNOR_F_SST_WR; - - /* Assign spi_flash ops */ -#ifndef CONFIG_DM_SPI_FLASH - flash->write = spi_flash_cmd_write_ops; -#if defined(CONFIG_SPI_FLASH_SST) - if (flash->flags & SNOR_F_SST_WR) { - if (flash->spi->op_mode_tx & SPI_OPM_TX_BP) - flash->write = sst_write_bp; - else - flash->write = sst_write_wp; - } -#endif - flash->erase = spi_flash_cmd_erase_ops; - flash->read = spi_flash_cmd_read_ops; -#endif - - /* lock hooks are flash specific - assign them based on idcode0 */ - switch (idcode[0]) { -#if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) - case SPI_FLASH_CFI_MFR_STMICRO: - case SPI_FLASH_CFI_MFR_SST: - flash->flash_lock = stm_lock; - flash->flash_unlock = stm_unlock; - flash->flash_is_locked = stm_is_locked; -#endif - break; - default: - debug("SF: Lock ops not supported for %02x flash\n", idcode[0]); - } - - /* Compute the flash size */ - flash->shift = (flash->dual_flash & SF_DUAL_PARALLEL_FLASH) ? 1 : 0; - /* - * The Spansion S25FL032P and S25FL064P have 256b pages, yet use the - * 0x4d00 Extended JEDEC code. The rest of the Spansion flashes with - * the 0x4d00 Extended JEDEC code have 512b pages. All of the others - * have 256b pages. - */ - if (ext_jedec == 0x4d00) { - if ((jedec == 0x0215) || (jedec == 0x216)) - flash->page_size = 256; - else - flash->page_size = 512; - } else { - flash->page_size = 256; - } - flash->page_size <<= flash->shift; - flash->sector_size = params->sector_size << flash->shift; - flash->size = flash->sector_size * params->nr_sectors << flash->shift; -#ifdef CONFIG_SF_DUAL_FLASH - if (flash->dual_flash & SF_DUAL_STACKED_FLASH) - flash->size <<= 1; -#endif - - /* Compute erase sector and command */ - if (params->flags & SECT_4K) { - flash->erase_cmd = CMD_ERASE_4K; - flash->erase_size = 4096 << flash->shift; - } else if (params->flags & SECT_32K) { - flash->erase_cmd = CMD_ERASE_32K; - flash->erase_size = 32768 << flash->shift; - } else { - flash->erase_cmd = CMD_ERASE_64K; - flash->erase_size = flash->sector_size; - } - - /* Now erase size becomes valid sector size */ - flash->sector_size = flash->erase_size; - - /* Look for the fastest read cmd */ - cmd = fls(params->e_rd_cmd & flash->spi->op_mode_rx); - if (cmd) { - cmd = spi_read_cmds_array[cmd - 1]; - flash->read_cmd = cmd; - } else { - /* Go for default supported read cmd */ - flash->read_cmd = CMD_READ_ARRAY_FAST; - } - - /* Not require to look for fastest only two write cmds yet */ - if (params->flags & WR_QPP && flash->spi->op_mode_tx & SPI_OPM_TX_QPP) - flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; - else - /* Go for default supported write cmd */ - flash->write_cmd = CMD_PAGE_PROGRAM; - - /* Set the quad enable bit - only for quad commands */ - if ((flash->read_cmd == CMD_READ_QUAD_OUTPUT_FAST) || - (flash->read_cmd == CMD_READ_QUAD_IO_FAST) || - (flash->write_cmd == CMD_QUAD_PAGE_PROGRAM)) { - ret = spi_flash_set_qeb(flash, idcode[0]); - if (ret) { - debug("SF: Fail to set QEB for %02x\n", idcode[0]); - return -EINVAL; - } - } - - /* Read dummy_byte: dummy byte is determined based on the - * dummy cycles of a particular command. - * Fast commands - dummy_byte = dummy_cycles/8 - * I/O commands- dummy_byte = (dummy_cycles * no.of lines)/8 - * For I/O commands except cmd[0] everything goes on no.of lines - * based on particular command but incase of fast commands except - * data all go on single line irrespective of command. - */ - switch (flash->read_cmd) { - case CMD_READ_QUAD_IO_FAST: - flash->dummy_byte = 2; - break; - case CMD_READ_ARRAY_SLOW: - flash->dummy_byte = 0; - break; - default: - flash->dummy_byte = 1; - } - -#ifdef CONFIG_SPI_FLASH_STMICRO - if (params->flags & E_FSR) - flash->flags |= SNOR_F_USE_FSR; -#endif - - /* Configure the BAR - discover bank cmds and read current bank */ -#ifdef CONFIG_SPI_FLASH_BAR - ret = spi_flash_read_bar(flash, idcode[0]); - if (ret < 0) - return ret; -#endif - -#if CONFIG_IS_ENABLED(OF_CONTROL) - ret = spi_flash_decode_fdt(gd->fdt_blob, flash); - if (ret) { - debug("SF: FDT decode error\n"); - return -EINVAL; - } -#endif - -#ifndef CONFIG_SPL_BUILD - printf("SF: Detected %s with page size ", flash->name); - print_size(flash->page_size, ", erase size "); - print_size(flash->erase_size, ", total "); - print_size(flash->size, ""); - if (flash->memory_map) - printf(", mapped at %p", flash->memory_map); - puts("\n"); -#endif - -#ifndef CONFIG_SPI_FLASH_BAR - if (((flash->dual_flash == SF_SINGLE_FLASH) && - (flash->size > SPI_FLASH_16MB_BOUN)) || - ((flash->dual_flash > SF_SINGLE_FLASH) && - (flash->size > SPI_FLASH_16MB_BOUN << 1))) { - puts("SF: Warning - Only lower 16MiB accessible,"); - puts(" Full access #define CONFIG_SPI_FLASH_BAR\n"); - } -#endif - - return ret; -} diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c new file mode 100644 index 0000000..7ffa136 --- /dev/null +++ b/drivers/mtd/spi/spi_flash.c @@ -0,0 +1,1115 @@ +/* + * SPI Flash Core + * + * Copyright (C) 2015 Jagan Teki jteki@openedev.com + * Copyright (C) 2013 Jagannadha Sutradharudu Teki, Xilinx Inc. + * Copyright (C) 2010 Reinhard Meyer, EMK Elektronik + * Copyright (C) 2008 Atmel Corporation + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <malloc.h> +#include <mapmem.h> +#include <spi.h> +#include <spi_flash.h> +#include <linux/log2.h> + +#include "sf_internal.h" + +DECLARE_GLOBAL_DATA_PTR; + +static void spi_flash_addr(u32 addr, u8 *cmd) +{ + /* cmd[0] is actual command */ + cmd[1] = addr >> 16; + cmd[2] = addr >> 8; + cmd[3] = addr >> 0; +} + +/* Read commands array */ +static u8 spi_read_cmds_array[] = { + CMD_READ_ARRAY_SLOW, + CMD_READ_ARRAY_FAST, + CMD_READ_DUAL_OUTPUT_FAST, + CMD_READ_DUAL_IO_FAST, + CMD_READ_QUAD_OUTPUT_FAST, + CMD_READ_QUAD_IO_FAST, +}; + +static int read_sr(struct spi_flash *flash, u8 *rs) +{ + int ret; + u8 cmd; + + cmd = CMD_READ_STATUS; + ret = spi_flash_read_common(flash, &cmd, 1, rs, 1); + if (ret < 0) { + debug("SF: fail to read status register\n"); + return ret; + } + + return 0; +} + +static int read_fsr(struct spi_flash *flash, u8 *fsr) +{ + int ret; + const u8 cmd = CMD_FLAG_STATUS; + + ret = spi_flash_read_common(flash, &cmd, 1, fsr, 1); + if (ret < 0) { + debug("SF: fail to read flag status register\n"); + return ret; + } + + return 0; +} + +static int write_sr(struct spi_flash *flash, u8 ws) +{ + u8 cmd; + int ret; + + cmd = CMD_WRITE_STATUS; + ret = spi_flash_write_common(flash, &cmd, 1, &ws, 1); + if (ret < 0) { + debug("SF: fail to write status register\n"); + return ret; + } + + return 0; +} + +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) +static int read_cr(struct spi_flash *flash, u8 *rc) +{ + int ret; + u8 cmd; + + cmd = CMD_READ_CONFIG; + ret = spi_flash_read_common(flash, &cmd, 1, rc, 1); + if (ret < 0) { + debug("SF: fail to read config register\n"); + return ret; + } + + return 0; +} + +static int write_cr(struct spi_flash *flash, u8 wc) +{ + u8 data[2]; + u8 cmd; + int ret; + + ret = read_sr(flash, &data[0]); + if (ret < 0) + return ret; + + cmd = CMD_WRITE_STATUS; + data[1] = wc; + ret = spi_flash_write_common(flash, &cmd, 1, &data, 2); + if (ret) { + debug("SF: fail to write config register\n"); + return ret; + } + + return 0; +} +#endif + +#ifdef CONFIG_SPI_FLASH_BAR +static int spi_flash_write_bar(struct spi_flash *flash, u32 offset) +{ + u8 cmd, bank_sel; + int ret; + + bank_sel = offset / (SPI_FLASH_16MB_BOUN << flash->shift); + if (bank_sel == flash->bank_curr) + goto bar_end; + + cmd = flash->bank_write_cmd; + ret = spi_flash_write_common(flash, &cmd, 1, &bank_sel, 1); + if (ret < 0) { + debug("SF: fail to write bank register\n"); + return ret; + } + +bar_end: + flash->bank_curr = bank_sel; + return flash->bank_curr; +} + +static int spi_flash_read_bar(struct spi_flash *flash, u8 idcode0) +{ + u8 curr_bank = 0; + int ret; + + if (flash->size <= SPI_FLASH_16MB_BOUN) + goto bank_end; + + switch (idcode0) { + case SPI_FLASH_CFI_MFR_SPANSION: + flash->bank_read_cmd = CMD_BANKADDR_BRRD; + flash->bank_write_cmd = CMD_BANKADDR_BRWR; + break; + default: + flash->bank_read_cmd = CMD_EXTNADDR_RDEAR; + flash->bank_write_cmd = CMD_EXTNADDR_WREAR; + } + + ret = spi_flash_read_common(flash, &flash->bank_read_cmd, 1, + &curr_bank, 1); + if (ret) { + debug("SF: fail to read bank addr register\n"); + return ret; + } + +bank_end: + flash->bank_curr = curr_bank; + return 0; +} +#endif + +#ifdef CONFIG_SF_DUAL_FLASH +static void spi_flash_dual(struct spi_flash *flash, u32 *addr) +{ + switch (flash->dual_flash) { + case SF_DUAL_STACKED_FLASH: + if (*addr >= (flash->size >> 1)) { + *addr -= flash->size >> 1; + flash->spi->flags |= SPI_XFER_U_PAGE; + } else { + flash->spi->flags &= ~SPI_XFER_U_PAGE; + } + break; + case SF_DUAL_PARALLEL_FLASH: + *addr >>= flash->shift; + break; + default: + debug("SF: Unsupported dual_flash=%d\n", flash->dual_flash); + break; + } +} +#endif + +static int spi_flash_sr_ready(struct spi_flash *flash) +{ + u8 sr; + int ret; + + ret = read_sr(flash, &sr); + if (ret < 0) + return ret; + + return !(sr & STATUS_WIP); +} + +static int spi_flash_fsr_ready(struct spi_flash *flash) +{ + u8 fsr; + int ret; + + ret = read_fsr(flash, &fsr); + if (ret < 0) + return ret; + + return fsr & STATUS_PEC; +} + +static int spi_flash_ready(struct spi_flash *flash) +{ + int sr, fsr; + + sr = spi_flash_sr_ready(flash); + if (sr < 0) + return sr; + + fsr = 1; + if (flash->flags & SNOR_F_USE_FSR) { + fsr = spi_flash_fsr_ready(flash); + if (fsr < 0) + return fsr; + } + + return sr && fsr; +} + +static int spi_flash_cmd_wait_ready(struct spi_flash *flash, + unsigned long timeout) +{ + int timebase, ret; + + timebase = get_timer(0); + + while (get_timer(timebase) < timeout) { + ret = spi_flash_ready(flash); + if (ret < 0) + return ret; + if (ret) + return 0; + } + + printf("SF: Timeout!\n"); + + return -ETIMEDOUT; +} + +int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, + size_t cmd_len, const void *buf, size_t buf_len) +{ + struct spi_slave *spi = flash->spi; + unsigned long timeout = SPI_FLASH_PROG_TIMEOUT; + int ret; + + if (buf == NULL) + timeout = SPI_FLASH_PAGE_ERASE_TIMEOUT; + + ret = spi_claim_bus(flash->spi); + if (ret) { + debug("SF: unable to claim SPI bus\n"); + return ret; + } + + ret = spi_flash_cmd_write_enable(flash); + if (ret < 0) { + debug("SF: enabling write failed\n"); + return ret; + } + + ret = spi_flash_cmd_write(spi, cmd, cmd_len, buf, buf_len); + if (ret < 0) { + debug("SF: write cmd failed\n"); + return ret; + } + + ret = spi_flash_cmd_wait_ready(flash, timeout); + if (ret < 0) { + debug("SF: write %s timed out\n", + timeout == SPI_FLASH_PROG_TIMEOUT ? + "program" : "page erase"); + return ret; + } + + spi_release_bus(spi); + + return ret; +} + +int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) +{ + u32 erase_size, erase_addr; + u8 cmd[SPI_FLASH_CMD_LEN]; + int ret = -1; + + erase_size = flash->erase_size; + if (offset % erase_size || len % erase_size) { + debug("SF: Erase offset/length not multiple of erase size\n"); + return -1; + } + + if (flash->flash_is_locked) { + if (flash->flash_is_locked(flash, offset, len) > 0) { + printf("offset 0x%x is protected and cannot be erased\n", + offset); + return -EINVAL; + } + } + + cmd[0] = flash->erase_cmd; + while (len) { + erase_addr = offset; + +#ifdef CONFIG_SF_DUAL_FLASH + if (flash->dual_flash > SF_SINGLE_FLASH) + spi_flash_dual(flash, &erase_addr); +#endif +#ifdef CONFIG_SPI_FLASH_BAR + ret = spi_flash_write_bar(flash, erase_addr); + if (ret < 0) + return ret; +#endif + spi_flash_addr(erase_addr, cmd); + + debug("SF: erase %2x %2x %2x %2x (%x)\n", cmd[0], cmd[1], + cmd[2], cmd[3], erase_addr); + + ret = spi_flash_write_common(flash, cmd, sizeof(cmd), NULL, 0); + if (ret < 0) { + debug("SF: erase failed\n"); + break; + } + + offset += erase_size; + len -= erase_size; + } + + return ret; +} + +int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, + size_t len, const void *buf) +{ + unsigned long byte_addr, page_size; + u32 write_addr; + size_t chunk_len, actual; + u8 cmd[SPI_FLASH_CMD_LEN]; + int ret = -1; + + page_size = flash->page_size; + + if (flash->flash_is_locked) { + if (flash->flash_is_locked(flash, offset, len) > 0) { + printf("offset 0x%x is protected and cannot be written\n", + offset); + return -EINVAL; + } + } + + cmd[0] = flash->write_cmd; + for (actual = 0; actual < len; actual += chunk_len) { + write_addr = offset; + +#ifdef CONFIG_SF_DUAL_FLASH + if (flash->dual_flash > SF_SINGLE_FLASH) + spi_flash_dual(flash, &write_addr); +#endif +#ifdef CONFIG_SPI_FLASH_BAR + ret = spi_flash_write_bar(flash, write_addr); + if (ret < 0) + return ret; +#endif + byte_addr = offset % page_size; + chunk_len = min(len - actual, (size_t)(page_size - byte_addr)); + + if (flash->spi->max_write_size) + chunk_len = min(chunk_len, + (size_t)flash->spi->max_write_size); + + spi_flash_addr(write_addr, cmd); + + debug("SF: 0x%p => cmd = { 0x%02x 0x%02x%02x%02x } chunk_len = %zu\n", + buf + actual, cmd[0], cmd[1], cmd[2], cmd[3], chunk_len); + + ret = spi_flash_write_common(flash, cmd, sizeof(cmd), + buf + actual, chunk_len); + if (ret < 0) { + debug("SF: write failed\n"); + break; + } + + offset += chunk_len; + } + + return ret; +} + +int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, + size_t cmd_len, void *data, size_t data_len) +{ + struct spi_slave *spi = flash->spi; + int ret; + + ret = spi_claim_bus(flash->spi); + if (ret) { + debug("SF: unable to claim SPI bus\n"); + return ret; + } + + ret = spi_flash_cmd_read(spi, cmd, cmd_len, data, data_len); + if (ret < 0) { + debug("SF: read cmd failed\n"); + return ret; + } + + spi_release_bus(spi); + + return ret; +} + +void __weak spi_flash_copy_mmap(void *data, void *offset, size_t len) +{ + memcpy(data, offset, len); +} + +int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, + size_t len, void *data) +{ + u8 *cmd, cmdsz; + u32 remain_len, read_len, read_addr; + int bank_sel = 0; + int ret = -1; + + /* Handle memory-mapped SPI */ + if (flash->memory_map) { + ret = spi_claim_bus(flash->spi); + if (ret) { + debug("SF: unable to claim SPI bus\n"); + return ret; + } + spi_xfer(flash->spi, 0, NULL, NULL, SPI_XFER_MMAP); + spi_flash_copy_mmap(data, flash->memory_map + offset, len); + spi_xfer(flash->spi, 0, NULL, NULL, SPI_XFER_MMAP_END); + spi_release_bus(flash->spi); + return 0; + } + + cmdsz = SPI_FLASH_CMD_LEN + flash->dummy_byte; + cmd = calloc(1, cmdsz); + if (!cmd) { + debug("SF: Failed to allocate cmd\n"); + return -ENOMEM; + } + + cmd[0] = flash->read_cmd; + while (len) { + read_addr = offset; + +#ifdef CONFIG_SF_DUAL_FLASH + if (flash->dual_flash > SF_SINGLE_FLASH) + spi_flash_dual(flash, &read_addr); +#endif +#ifdef CONFIG_SPI_FLASH_BAR + ret = spi_flash_write_bar(flash, read_addr); + if (ret < 0) + return ret; + bank_sel = flash->bank_curr; +#endif + remain_len = ((SPI_FLASH_16MB_BOUN << flash->shift) * + (bank_sel + 1)) - offset; + if (len < remain_len) + read_len = len; + else + read_len = remain_len; + + spi_flash_addr(read_addr, cmd); + + ret = spi_flash_read_common(flash, cmd, cmdsz, data, read_len); + if (ret < 0) { + debug("SF: read failed\n"); + break; + } + + offset += read_len; + len -= read_len; + data += read_len; + } + + free(cmd); + return ret; +} + +#ifdef CONFIG_SPI_FLASH_SST +static int sst_byte_write(struct spi_flash *flash, u32 offset, const void *buf) +{ + int ret; + u8 cmd[4] = { + CMD_SST_BP, + offset >> 16, + offset >> 8, + offset, + }; + + debug("BP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", + spi_w8r8(flash->spi, CMD_READ_STATUS), buf, cmd[0], offset); + + ret = spi_flash_cmd_write_enable(flash); + if (ret) + return ret; + + ret = spi_flash_cmd_write(flash->spi, cmd, sizeof(cmd), buf, 1); + if (ret) + return ret; + + return spi_flash_cmd_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); +} + +int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, + const void *buf) +{ + size_t actual, cmd_len; + int ret; + u8 cmd[4]; + + ret = spi_claim_bus(flash->spi); + if (ret) { + debug("SF: Unable to claim SPI bus\n"); + return ret; + } + + /* If the data is not word aligned, write out leading single byte */ + actual = offset % 2; + if (actual) { + ret = sst_byte_write(flash, offset, buf); + if (ret) + goto done; + } + offset += actual; + + ret = spi_flash_cmd_write_enable(flash); + if (ret) + goto done; + + cmd_len = 4; + cmd[0] = CMD_SST_AAI_WP; + cmd[1] = offset >> 16; + cmd[2] = offset >> 8; + cmd[3] = offset; + + for (; actual < len - 1; actual += 2) { + debug("WP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", + spi_w8r8(flash->spi, CMD_READ_STATUS), buf + actual, + cmd[0], offset); + + ret = spi_flash_cmd_write(flash->spi, cmd, cmd_len, + buf + actual, 2); + if (ret) { + debug("SF: sst word program failed\n"); + break; + } + + ret = spi_flash_cmd_wait_ready(flash, SPI_FLASH_PROG_TIMEOUT); + if (ret) + break; + + cmd_len = 1; + offset += 2; + } + + if (!ret) + ret = spi_flash_cmd_write_disable(flash); + + /* If there is a single trailing byte, write it out */ + if (!ret && actual != len) + ret = sst_byte_write(flash, offset, buf + actual); + + done: + debug("SF: sst: program %s %zu bytes @ 0x%zx\n", + ret ? "failure" : "success", len, offset - actual); + + spi_release_bus(flash->spi); + return ret; +} + +int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, + const void *buf) +{ + size_t actual; + int ret; + + ret = spi_claim_bus(flash->spi); + if (ret) { + debug("SF: Unable to claim SPI bus\n"); + return ret; + } + + for (actual = 0; actual < len; actual++) { + ret = sst_byte_write(flash, offset, buf + actual); + if (ret) { + debug("SF: sst byte program failed\n"); + break; + } + offset++; + } + + if (!ret) + ret = spi_flash_cmd_write_disable(flash); + + debug("SF: sst: program %s %zu bytes @ 0x%zx\n", + ret ? "failure" : "success", len, offset - actual); + + spi_release_bus(flash->spi); + return ret; +} +#endif + +#if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) +static void stm_get_locked_range(struct spi_flash *flash, u8 sr, loff_t *ofs, + u32 *len) +{ + u8 mask = SR_BP2 | SR_BP1 | SR_BP0; + int shift = ffs(mask) - 1; + int pow; + + if (!(sr & mask)) { + /* No protection */ + *ofs = 0; + *len = 0; + } else { + pow = ((sr & mask) ^ mask) >> shift; + *len = flash->size >> pow; + *ofs = flash->size - *len; + } +} + +/* + * Return 1 if the entire region is locked, 0 otherwise + */ +static int stm_is_locked_sr(struct spi_flash *flash, u32 ofs, u32 len, + u8 sr) +{ + loff_t lock_offs; + u32 lock_len; + + stm_get_locked_range(flash, sr, &lock_offs, &lock_len); + + return (ofs + len <= lock_offs + lock_len) && (ofs >= lock_offs); +} + +/* + * Check if a region of the flash is (completely) locked. See stm_lock() for + * more info. + * + * Returns 1 if entire region is locked, 0 if any portion is unlocked, and + * negative on errors. + */ +int stm_is_locked(struct spi_flash *flash, u32 ofs, size_t len) +{ + int status; + u8 sr; + + status = read_sr(flash, &sr); + if (status < 0) + return status; + + return stm_is_locked_sr(flash, ofs, len, sr); +} + +/* + * Lock a region of the flash. Compatible with ST Micro and similar flash. + * Supports only the block protection bits BP{0,1,2} in the status register + * (SR). Does not support these features found in newer SR bitfields: + * - TB: top/bottom protect - only handle TB=0 (top protect) + * - SEC: sector/block protect - only handle SEC=0 (block protect) + * - CMP: complement protect - only support CMP=0 (range is not complemented) + * + * Sample table portion for 8MB flash (Winbond w25q64fw): + * + * SEC | TB | BP2 | BP1 | BP0 | Prot Length | Protected Portion + * -------------------------------------------------------------------------- + * X | X | 0 | 0 | 0 | NONE | NONE + * 0 | 0 | 0 | 0 | 1 | 128 KB | Upper 1/64 + * 0 | 0 | 0 | 1 | 0 | 256 KB | Upper 1/32 + * 0 | 0 | 0 | 1 | 1 | 512 KB | Upper 1/16 + * 0 | 0 | 1 | 0 | 0 | 1 MB | Upper 1/8 + * 0 | 0 | 1 | 0 | 1 | 2 MB | Upper 1/4 + * 0 | 0 | 1 | 1 | 0 | 4 MB | Upper 1/2 + * X | X | 1 | 1 | 1 | 8 MB | ALL + * + * Returns negative on errors, 0 on success. + */ +int stm_lock(struct spi_flash *flash, u32 ofs, size_t len) +{ + u8 status_old, status_new; + u8 mask = SR_BP2 | SR_BP1 | SR_BP0; + u8 shift = ffs(mask) - 1, pow, val; + int ret; + + ret = read_sr(flash, &status_old); + if (ret < 0) + return ret; + + /* SPI NOR always locks to the end */ + if (ofs + len != flash->size) { + /* Does combined region extend to end? */ + if (!stm_is_locked_sr(flash, ofs + len, flash->size - ofs - len, + status_old)) + return -EINVAL; + len = flash->size - ofs; + } + + /* + * Need smallest pow such that: + * + * 1 / (2^pow) <= (len / size) + * + * so (assuming power-of-2 size) we do: + * + * pow = ceil(log2(size / len)) = log2(size) - floor(log2(len)) + */ + pow = ilog2(flash->size) - ilog2(len); + val = mask - (pow << shift); + if (val & ~mask) + return -EINVAL; + + /* Don't "lock" with no region! */ + if (!(val & mask)) + return -EINVAL; + + status_new = (status_old & ~mask) | val; + + /* Only modify protection if it will not unlock other areas */ + if ((status_new & mask) <= (status_old & mask)) + return -EINVAL; + + write_sr(flash, status_new); + + return 0; +} + +/* + * Unlock a region of the flash. See stm_lock() for more info + * + * Returns negative on errors, 0 on success. + */ +int stm_unlock(struct spi_flash *flash, u32 ofs, size_t len) +{ + uint8_t status_old, status_new; + u8 mask = SR_BP2 | SR_BP1 | SR_BP0; + u8 shift = ffs(mask) - 1, pow, val; + int ret; + + ret = read_sr(flash, &status_old); + if (ret < 0) + return ret; + + /* Cannot unlock; would unlock larger region than requested */ + if (stm_is_locked_sr(flash, status_old, ofs - flash->erase_size, + flash->erase_size)) + return -EINVAL; + /* + * Need largest pow such that: + * + * 1 / (2^pow) >= (len / size) + * + * so (assuming power-of-2 size) we do: + * + * pow = floor(log2(size / len)) = log2(size) - ceil(log2(len)) + */ + pow = ilog2(flash->size) - order_base_2(flash->size - (ofs + len)); + if (ofs + len == flash->size) { + val = 0; /* fully unlocked */ + } else { + val = mask - (pow << shift); + /* Some power-of-two sizes are not supported */ + if (val & ~mask) + return -EINVAL; + } + + status_new = (status_old & ~mask) | val; + + /* Only modify protection if it will not lock other areas */ + if ((status_new & mask) >= (status_old & mask)) + return -EINVAL; + + write_sr(flash, status_new); + + return 0; +} +#endif + + +#ifdef CONFIG_SPI_FLASH_MACRONIX +static int spi_flash_set_qeb_mxic(struct spi_flash *flash) +{ + u8 qeb_status; + int ret; + + ret = read_sr(flash, &qeb_status); + if (ret < 0) + return ret; + + if (qeb_status & STATUS_QEB_MXIC) { + debug("SF: mxic: QEB is already set\n"); + } else { + ret = write_sr(flash, STATUS_QEB_MXIC); + if (ret < 0) + return ret; + } + + return ret; +} +#endif + +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) +static int spi_flash_set_qeb_winspan(struct spi_flash *flash) +{ + u8 qeb_status; + int ret; + + ret = read_cr(flash, &qeb_status); + if (ret < 0) + return ret; + + if (qeb_status & STATUS_QEB_WINSPAN) { + debug("SF: winspan: QEB is already set\n"); + } else { + ret = write_cr(flash, STATUS_QEB_WINSPAN); + if (ret < 0) + return ret; + } + + return ret; +} +#endif + +static int spi_flash_set_qeb(struct spi_flash *flash, u8 idcode0) +{ + switch (idcode0) { +#ifdef CONFIG_SPI_FLASH_MACRONIX + case SPI_FLASH_CFI_MFR_MACRONIX: + return spi_flash_set_qeb_mxic(flash); +#endif +#if defined(CONFIG_SPI_FLASH_SPANSION) || defined(CONFIG_SPI_FLASH_WINBOND) + case SPI_FLASH_CFI_MFR_SPANSION: + case SPI_FLASH_CFI_MFR_WINBOND: + return spi_flash_set_qeb_winspan(flash); +#endif +#ifdef CONFIG_SPI_FLASH_STMICRO + case SPI_FLASH_CFI_MFR_STMICRO: + debug("SF: QEB is volatile for %02x flash\n", idcode0); + return 0; +#endif + default: + printf("SF: Need set QEB func for %02x flash\n", idcode0); + return -1; + } +} + +#if CONFIG_IS_ENABLED(OF_CONTROL) +int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) +{ + fdt_addr_t addr; + fdt_size_t size; + int node; + + /* If there is no node, do nothing */ + node = fdtdec_next_compatible(blob, 0, COMPAT_GENERIC_SPI_FLASH); + if (node < 0) + return 0; + + addr = fdtdec_get_addr_size(blob, node, "memory-map", &size); + if (addr == FDT_ADDR_T_NONE) { + debug("%s: Cannot decode address\n", __func__); + return 0; + } + + if (flash->size != size) { + debug("%s: Memory map must cover entire device\n", __func__); + return -1; + } + flash->memory_map = map_sysmem(addr, size); + + return 0; +} +#endif /* CONFIG_IS_ENABLED(OF_CONTROL) */ + +int spi_flash_scan(struct spi_flash *flash) +{ + struct spi_slave *spi = flash->spi; + const struct spi_flash_params *params; + u16 jedec, ext_jedec; + u8 idcode[5]; + u8 cmd; + int ret; + + /* Read the ID codes */ + ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode)); + if (ret) { + printf("SF: Failed to get idcodes\n"); + return -EINVAL; + } + +#ifdef DEBUG + printf("SF: Got idcodes\n"); + print_buffer(0, idcode, 1, sizeof(idcode), 0); +#endif + + jedec = idcode[1] << 8 | idcode[2]; + ext_jedec = idcode[3] << 8 | idcode[4]; + + /* Validate params from spi_flash_params table */ + params = spi_flash_params_table; + for (; params->name != NULL; params++) { + if ((params->jedec >> 16) == idcode[0]) { + if ((params->jedec & 0xFFFF) == jedec) { + if (params->ext_jedec == 0) + break; + else if (params->ext_jedec == ext_jedec) + break; + } + } + } + + if (!params->name) { + printf("SF: Unsupported flash IDs: "); + printf("manuf %02x, jedec %04x, ext_jedec %04x\n", + idcode[0], jedec, ext_jedec); + return -EPROTONOSUPPORT; + } + + /* Flash powers up read-only, so clear BP# bits */ + if (idcode[0] == SPI_FLASH_CFI_MFR_ATMEL || + idcode[0] == SPI_FLASH_CFI_MFR_MACRONIX || + idcode[0] == SPI_FLASH_CFI_MFR_SST) + write_sr(flash, 0); + + /* Assign spi data */ + flash->name = params->name; + flash->memory_map = spi->memory_map; + flash->dual_flash = flash->spi->option; + + /* Assign spi flash flags */ + if (params->flags & SST_WR) + flash->flags |= SNOR_F_SST_WR; + + /* Assign spi_flash ops */ +#ifndef CONFIG_DM_SPI_FLASH + flash->write = spi_flash_cmd_write_ops; +#if defined(CONFIG_SPI_FLASH_SST) + if (flash->flags & SNOR_F_SST_WR) { + if (flash->spi->op_mode_tx & SPI_OPM_TX_BP) + flash->write = sst_write_bp; + else + flash->write = sst_write_wp; + } +#endif + flash->erase = spi_flash_cmd_erase_ops; + flash->read = spi_flash_cmd_read_ops; +#endif + + /* lock hooks are flash specific - assign them based on idcode0 */ + switch (idcode[0]) { +#if defined(CONFIG_SPI_FLASH_STMICRO) || defined(CONFIG_SPI_FLASH_SST) + case SPI_FLASH_CFI_MFR_STMICRO: + case SPI_FLASH_CFI_MFR_SST: + flash->flash_lock = stm_lock; + flash->flash_unlock = stm_unlock; + flash->flash_is_locked = stm_is_locked; +#endif + break; + default: + debug("SF: Lock ops not supported for %02x flash\n", idcode[0]); + } + + /* Compute the flash size */ + flash->shift = (flash->dual_flash & SF_DUAL_PARALLEL_FLASH) ? 1 : 0; + /* + * The Spansion S25FL032P and S25FL064P have 256b pages, yet use the + * 0x4d00 Extended JEDEC code. The rest of the Spansion flashes with + * the 0x4d00 Extended JEDEC code have 512b pages. All of the others + * have 256b pages. + */ + if (ext_jedec == 0x4d00) { + if ((jedec == 0x0215) || (jedec == 0x216)) + flash->page_size = 256; + else + flash->page_size = 512; + } else { + flash->page_size = 256; + } + flash->page_size <<= flash->shift; + flash->sector_size = params->sector_size << flash->shift; + flash->size = flash->sector_size * params->nr_sectors << flash->shift; +#ifdef CONFIG_SF_DUAL_FLASH + if (flash->dual_flash & SF_DUAL_STACKED_FLASH) + flash->size <<= 1; +#endif + + /* Compute erase sector and command */ + if (params->flags & SECT_4K) { + flash->erase_cmd = CMD_ERASE_4K; + flash->erase_size = 4096 << flash->shift; + } else if (params->flags & SECT_32K) { + flash->erase_cmd = CMD_ERASE_32K; + flash->erase_size = 32768 << flash->shift; + } else { + flash->erase_cmd = CMD_ERASE_64K; + flash->erase_size = flash->sector_size; + } + + /* Now erase size becomes valid sector size */ + flash->sector_size = flash->erase_size; + + /* Look for the fastest read cmd */ + cmd = fls(params->e_rd_cmd & flash->spi->op_mode_rx); + if (cmd) { + cmd = spi_read_cmds_array[cmd - 1]; + flash->read_cmd = cmd; + } else { + /* Go for default supported read cmd */ + flash->read_cmd = CMD_READ_ARRAY_FAST; + } + + /* Not require to look for fastest only two write cmds yet */ + if (params->flags & WR_QPP && flash->spi->op_mode_tx & SPI_OPM_TX_QPP) + flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; + else + /* Go for default supported write cmd */ + flash->write_cmd = CMD_PAGE_PROGRAM; + + /* Set the quad enable bit - only for quad commands */ + if ((flash->read_cmd == CMD_READ_QUAD_OUTPUT_FAST) || + (flash->read_cmd == CMD_READ_QUAD_IO_FAST) || + (flash->write_cmd == CMD_QUAD_PAGE_PROGRAM)) { + ret = spi_flash_set_qeb(flash, idcode[0]); + if (ret) { + debug("SF: Fail to set QEB for %02x\n", idcode[0]); + return -EINVAL; + } + } + + /* Read dummy_byte: dummy byte is determined based on the + * dummy cycles of a particular command. + * Fast commands - dummy_byte = dummy_cycles/8 + * I/O commands- dummy_byte = (dummy_cycles * no.of lines)/8 + * For I/O commands except cmd[0] everything goes on no.of lines + * based on particular command but incase of fast commands except + * data all go on single line irrespective of command. + */ + switch (flash->read_cmd) { + case CMD_READ_QUAD_IO_FAST: + flash->dummy_byte = 2; + break; + case CMD_READ_ARRAY_SLOW: + flash->dummy_byte = 0; + break; + default: + flash->dummy_byte = 1; + } + +#ifdef CONFIG_SPI_FLASH_STMICRO + if (params->flags & E_FSR) + flash->flags |= SNOR_F_USE_FSR; +#endif + + /* Configure the BAR - discover bank cmds and read current bank */ +#ifdef CONFIG_SPI_FLASH_BAR + ret = spi_flash_read_bar(flash, idcode[0]); + if (ret < 0) + return ret; +#endif + +#if CONFIG_IS_ENABLED(OF_CONTROL) + ret = spi_flash_decode_fdt(gd->fdt_blob, flash); + if (ret) { + debug("SF: FDT decode error\n"); + return -EINVAL; + } +#endif + +#ifndef CONFIG_SPL_BUILD + printf("SF: Detected %s with page size ", flash->name); + print_size(flash->page_size, ", erase size "); + print_size(flash->erase_size, ", total "); + print_size(flash->size, ""); + if (flash->memory_map) + printf(", mapped at %p", flash->memory_map); + puts("\n"); +#endif + +#ifndef CONFIG_SPI_FLASH_BAR + if (((flash->dual_flash == SF_SINGLE_FLASH) && + (flash->size > SPI_FLASH_16MB_BOUN)) || + ((flash->dual_flash > SF_SINGLE_FLASH) && + (flash->size > SPI_FLASH_16MB_BOUN << 1))) { + puts("SF: Warning - Only lower 16MiB accessible,"); + puts(" Full access #define CONFIG_SPI_FLASH_BAR\n"); + } +#endif + + return ret; +}
Jagan Teki
