[U-Boot] [PATCH] powerpc/85xx: don't touch MAS7 on e500v1 when relocating CCSR
The CCSR relocation code in start.S writes to MAS7 on all e500 parts, but that register does not exist on e500v1.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/cpu/mpc85xx/start.S | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/start.S b/arch/powerpc/cpu/mpc85xx/start.S index 4d37d6e..d0872cf 100644 --- a/arch/powerpc/cpu/mpc85xx/start.S +++ b/arch/powerpc/cpu/mpc85xx/start.S @@ -434,13 +434,15 @@ create_ccsr_new_tlb: ori r2, r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR, (MAS2_I|MAS2_G))@l lis r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_PHYS_LOW, 0, (MAS3_SW|MAS3_SR))@h ori r3, r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_PHYS_LOW, 0, (MAS3_SW|MAS3_SR))@l +#ifdef CONFIG_ENABLE_36BIT_PHYS lis r7, CONFIG_SYS_CCSRBAR_PHYS_HIGH@h ori r7, r7, CONFIG_SYS_CCSRBAR_PHYS_HIGH@l + mtspr MAS7, r7 +#endif mtspr MAS0, r0 mtspr MAS1, r1 mtspr MAS2, r2 mtspr MAS3, r3 - mtspr MAS7, r7 isync msync tlbwe @@ -456,12 +458,14 @@ create_ccsr_old_tlb: ori r2, r2, FSL_BOOKE_MAS2(CONFIG_SYS_CCSRBAR + 0x1000, (MAS2_I|MAS2_G))@l lis r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_DEFAULT, 0, (MAS3_SW|MAS3_SR))@h ori r3, r3, FSL_BOOKE_MAS3(CONFIG_SYS_CCSRBAR_DEFAULT, 0, (MAS3_SW|MAS3_SR))@l +#ifdef CONFIG_ENABLE_36BIT_PHYS li r7, 0 /* The default CCSR address is always a 32-bit number */ + mtspr MAS7, r7 +#endif mtspr MAS0, r0 /* MAS1 is the same as above */ mtspr MAS2, r2 mtspr MAS3, r3 - mtspr MAS7, r7 isync msync tlbwe
Timur Tabi
