[U-Boot] [PATCH] drivers: net: cpsw: Fix reading of mac address for am43 SoCs
cpsw driver tries to get macid for am43xx SoCs using the compatible ti,am4372. But not all variants of am43x uses this complatible like epos evm uses ti,am438x. So use a generic compatible ti,am43 to get macid for all am43 based platforms.
Tested-by: Aparna Balasubramanian aparnab@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- drivers/net/cpsw-common.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/cpsw-common.c b/drivers/net/cpsw-common.c index e828e85d8b..607eb4563c 100644 --- a/drivers/net/cpsw-common.c +++ b/drivers/net/cpsw-common.c @@ -110,7 +110,7 @@ int ti_cm_get_macid(struct udevice *dev, int slave, u8 *mac_addr) if (of_device_is_compatible(dev, "ti,dm816-emac")) return cpsw_am33xx_cm_get_macid(dev, 0x30, slave, mac_addr);
- if (of_machine_is_compatible("ti,am4372")) + if (of_machine_is_compatible("ti,am43")) return cpsw_am33xx_cm_get_macid(dev, 0x630, slave, mac_addr);
if (of_machine_is_compatible("ti,dra7"))
+ Joe
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Tested-by: Aparna Balasubramanian aparnab@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Joe Hershberger joe.hershberger@ni.com Reviewed-by: Tom Rini trini@konsulko.com
Joe Hershberger
Lokesh Vutla
