[U-Boot] [PATCH 4/8] Convert CONFIG_BOOTCOUNT_ENV to Kconfig
This converts the following to Kconfig: CONFIG_BOOTCOUNT_ENV
Signed-off-by: Alex Kiernan alex.kiernan@gmail.com ---
README | 11 ----------- configs/draco_defconfig | 1 + configs/etamin_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rut_defconfig | 1 + configs/thuban_defconfig | 1 + drivers/bootcount/Kconfig | 12 ++++++++++++ include/configs/siemens-am33x-common.h | 2 -- scripts/config_whitelist.txt | 1 - 10 files changed, 18 insertions(+), 14 deletions(-)
diff --git a/README b/README index f51f670..0581b58 100644 --- a/README +++ b/README @@ -714,17 +714,6 @@ The following options need to be configured: RAM and NFS.
- Bootcount: - CONFIG_BOOTCOUNT_ENV - If no softreset save registers are found on the hardware - "bootcount" is stored in the environment. To prevent a - saveenv on all reboots, the environment variable - "upgrade_available" is used. If "upgrade_available" is - 0, "bootcount" is always 0, if "upgrade_available" is - 1 "bootcount" is incremented in the environment. - So the Userspace Applikation must set the "upgrade_available" - and "bootcount" variable to 0, if a boot was successfully. - -- Pre-Boot Commands: CONFIG_PREBOOT
When this option is #defined, the existence of the diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 693d91c..0416daa 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -52,6 +52,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index e7a3d22..7d639ea 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -52,6 +52,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 6063259..90783b4 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -55,6 +55,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index ce6981e..c0947e9 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -52,6 +52,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index b31eb97..685b4c8 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -56,6 +56,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 4a3c0cd..f5d1077 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -52,6 +52,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/drivers/bootcount/Kconfig b/drivers/bootcount/Kconfig index e905295..40a0755 100644 --- a/drivers/bootcount/Kconfig +++ b/drivers/bootcount/Kconfig @@ -28,6 +28,18 @@ config BOOTCOUNT_AM33XX This requires the RTC clocks, etc, to be enabled prior to use and not all boards with this IP block on it will have the RTC in use.
+config BOOTCOUNT_ENV + bool "Boot counter in environment" + help + If no softreset save registers are found on the hardware + "bootcount" is stored in the environment. To prevent a + saveenv on all reboots, the environment variable + "upgrade_available" is used. If "upgrade_available" is + 0, "bootcount" is always 0, if "upgrade_available" is + 1 "bootcount" is incremented in the environment. + So the Userspace Application must set the "upgrade_available" + and "bootcount" variable to 0, if a boot was successfully. + endchoice
config SYS_BOOTCOUNT_SINGLEWORD diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index eb4b1f6..a7b427f 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -500,6 +500,4 @@ #define CONFIG_RESET_TO_RETRY #define CONFIG_BOOT_RETRY_TIME 60
-#define CONFIG_BOOTCOUNT_ENV - #endif /* ! __CONFIG_SIEMENS_AM33X_COMMON_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 46d9d5c..0fd4ad6 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -148,7 +148,6 @@ CONFIG_BOOGER CONFIG_BOOM CONFIG_BOOTBLOCK CONFIG_BOOTCOUNT_ALEN -CONFIG_BOOTCOUNT_ENV CONFIG_BOOTCOUNT_I2C CONFIG_BOOTCOUNT_LIMIT CONFIG_BOOTCOUNT_RAM
On Sun, 11 Feb 2018 12:06:49 +0000 Alex Kiernan alex.kiernan@gmail.com wrote:
- Bootcount:
hardware
a
is
"upgrade_available"
diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 693d91c..0416daa 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -52,6 +52,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/etamin_defconfig b/configs/etamin_defconfig index e7a3d22..7d639ea 100644 --- a/configs/etamin_defconfig +++ b/configs/etamin_defconfig @@ -52,6 +52,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 6063259..90783b4 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -55,6 +55,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index ce6981e..c0947e9 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -52,6 +52,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index b31eb97..685b4c8 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -56,6 +56,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 4a3c0cd..f5d1077 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -52,6 +52,7 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_ENV_IS_IN_NAND=y CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_BOOTCOUNT_ENV=y CONFIG_DFU_NAND=y CONFIG_MMC_OMAP_HS=y CONFIG_NAND=y diff --git a/drivers/bootcount/Kconfig b/drivers/bootcount/Kconfig index e905295..40a0755 100644 --- a/drivers/bootcount/Kconfig +++ b/drivers/bootcount/Kconfig @@ -28,6 +28,18 @@ config BOOTCOUNT_AM33XX This requires the RTC clocks, etc, to be enabled prior to use and not all boards with this IP block on it will have the RTC in use. +config BOOTCOUNT_ENV
- bool "Boot counter in environment"
- help
"upgrade_available"
endchoice
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Hi Alex,
- Bootcount:
hardware
a
is
"upgrade_available"
^^^^^^^^^^^ - This line shall be keep. The "- Bootcount:" Above shall be deleted instead.
CONFIG_PREBOOT
Lukasz Majewski
On Tue, Feb 13, 2018 at 9:30 AM, Lukasz Majewski lukma@denx.de wrote:
Hi Alex,
- Bootcount:
hardware
a
is
"upgrade_available"
Ooh, good spot!
Alex Kiernan
Lukasz Majewski
