[U-Boot] [PATCH] NAND: davinci: choose correct 1-bit h/w ECC reg
In nand_davinci_readecc(), select the correct NANDF<n>ECC register based on CONFIG_SYS_NAND_CS rather than hardcoding the choice of NANDF1ECC. This allows 1-bit hardware ECC to work with chip select other than CS2.
Note this now matches the usage in nand_davinci_enable_hwecc(), which already had the correct handling, and allows refactoring to a single function encapsulating the register read.
Without this fix, writing NAND pages to a chip not wired to CS2 would result in in the ECC calculation always returning FFFFFF for each 512-byte segment, and reading back a correctly written page (one with ECC intact) would always fail. With this fix, the ECC is written and verified correctly. --- drivers/mtd/nand/davinci_nand.c | 26 +++++++++++++------------- 1 files changed, 13 insertions(+), 13 deletions(-)
diff --git a/drivers/mtd/nand/davinci_nand.c b/drivers/mtd/nand/davinci_nand.c index d41579c..e8506dd 100644 --- a/drivers/mtd/nand/davinci_nand.c +++ b/drivers/mtd/nand/davinci_nand.c @@ -176,12 +176,22 @@ static void nand_davinci_hwcontrol(struct mtd_info *mtd, int cmd,
#ifdef CONFIG_SYS_NAND_HW_ECC
+static u_int32_t nand_davinci_readecc(struct mtd_info *mtd) +{ + u_int32_t ecc = 0; + + ecc = __raw_readl(&(davinci_emif_regs->nandfecc[ + CONFIG_SYS_NAND_CS - 2])); + + return ecc; +} + static void nand_davinci_enable_hwecc(struct mtd_info *mtd, int mode) { u_int32_t val;
- (void)__raw_readl(&(davinci_emif_regs->nandfecc[ - CONFIG_SYS_NAND_CS - 2])); + /* reading the ECC result register resets the ECC calculation */ + nand_davinci_readecc(mtd);
val = __raw_readl(&davinci_emif_regs->nandfcr); val |= DAVINCI_NANDFCR_NAND_ENABLE(CONFIG_SYS_NAND_CS); @@ -189,22 +199,12 @@ static void nand_davinci_enable_hwecc(struct mtd_info *mtd, int mode) __raw_writel(val, &davinci_emif_regs->nandfcr); }
-static u_int32_t nand_davinci_readecc(struct mtd_info *mtd, u_int32_t region) -{ - u_int32_t ecc = 0; - - ecc = __raw_readl(&(davinci_emif_regs->nandfecc[region - 1])); - - return ecc; -} - static int nand_davinci_calculate_ecc(struct mtd_info *mtd, const u_char *dat, u_char *ecc_code) { u_int32_t tmp; - const int region = 1;
- tmp = nand_davinci_readecc(mtd, region); + tmp = nand_davinci_readecc(mtd);
/* Squeeze 4 bytes ECC into 3 bytes by removing RESERVED bits * and shifting. RESERVED bits are 31 to 28 and 15 to 12. */
Signed-off-by: Laurence Withers lwithers@guralp.com --- Changes for v2: Add Signed-off-by to commit message. --- drivers/mtd/nand/davinci_nand.c | 26 +++++++++++++------------- 1 files changed, 13 insertions(+), 13 deletions(-)
Does anybody have any comments on this bugfix? If not, can it be accepted?
Many thanks, and bye for now,
Applied to u-boot-nand-flash
-Scott
Hello.
You need to sign off your patch. Add this line to the changelog:
WBR, Sergei
Thanks, I have reposted v2. Please ignore the posting with the unaltered subject line; I only realised after sending that I had forgotten it.
Bye for now,
Laurence Withers
Scott Wood
Sergei Shtylyov
