[U-Boot] [PATCH] drivers/usb: Move conditional compilation to Makefile
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- drivers/usb/Makefile | 19 +++++++++++++------ drivers/usb/isp116x-hcd.c | 4 ---- drivers/usb/sl811_usb.c | 3 --- drivers/usb/usb_ohci.c | 4 ---- drivers/usb/usbdcore_ep0.c | 4 ---- drivers/usb/usbdcore_mpc8xx.c | 4 ---- drivers/usb/usbdcore_omap1510.c | 4 ---- 7 files changed, 13 insertions(+), 29 deletions(-)
diff --git a/drivers/usb/Makefile b/drivers/usb/Makefile index c67a490..856f51a 100644 --- a/drivers/usb/Makefile +++ b/drivers/usb/Makefile @@ -25,15 +25,22 @@ include $(TOPDIR)/config.mk
LIB := $(obj)libusb.a
+# core +COBJS-y += usbdcore.o +COBJS-$(CONFIG_USB_OHCI_NEW) += usb_ohci.o + +# host +COBJS-$(CONFIG_USB_ISP116X_HCD) += isp116x-hcd.o COBJS-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o +COBJS-$(CONFIG_USB_SL811HS) += sl811_usb.o
-COBJS-y += isp116x-hcd.o -COBJS-y += sl811_usb.o -COBJS-y += usb_ohci.o -COBJS-y += usbdcore.o +# device +ifdef CONFIG_USB_DEVICE COBJS-y += usbdcore_ep0.o -COBJS-y += usbdcore_mpc8xx.o -COBJS-y += usbdcore_omap1510.o +COBJS-$(CONFIG_OMAP1510) += usbdcore_omap1510.o +COBJS-$(CONFIG_OMAP1610) += usbdcore_omap1510.o +COBJS-$(CONFIG_MPC885_FAMILY) += usbdcore_mpc8xx.o +endif
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/usb/isp116x-hcd.c b/drivers/usb/isp116x-hcd.c index cc46dfe..348e404 100644 --- a/drivers/usb/isp116x-hcd.c +++ b/drivers/usb/isp116x-hcd.c @@ -56,8 +56,6 @@ */
#include <common.h> - -#ifdef CONFIG_USB_ISP116X_HCD #include <asm/io.h> #include <usb.h> #include <malloc.h> @@ -1441,5 +1439,3 @@ int usb_lowlevel_stop(void)
return 0; } - -#endif /* CONFIG_USB_ISP116X_HCD */ diff --git a/drivers/usb/sl811_usb.c b/drivers/usb/sl811_usb.c index 48f1ee9..a03e469 100644 --- a/drivers/usb/sl811_usb.c +++ b/drivers/usb/sl811_usb.c @@ -36,7 +36,6 @@ */
#include <common.h> -#ifdef CONFIG_USB_SL811HS #include <mpc8xx.h> #include <usb.h> #include "sl811.h" @@ -733,5 +732,3 @@ static int sl811_rh_submit_urb(struct usb_device *usb_dev, unsigned long pipe,
return status == 0 ? len : status; } - -#endif /* CONFIG_USB_SL811HS */ diff --git a/drivers/usb/usb_ohci.c b/drivers/usb/usb_ohci.c index e03371c..d68fdcf 100644 --- a/drivers/usb/usb_ohci.c +++ b/drivers/usb/usb_ohci.c @@ -46,9 +46,6 @@ */
#include <common.h> - -#ifdef CONFIG_USB_OHCI_NEW - #include <asm/byteorder.h>
#if defined(CONFIG_PCI_OHCI) @@ -2016,4 +2013,3 @@ int usb_lowlevel_stop(void) ohci_inited = 0; return 0; } -#endif /* CONFIG_USB_OHCI_NEW */ diff --git a/drivers/usb/usbdcore_ep0.c b/drivers/usb/usbdcore_ep0.c index cf3f382..f6e017d 100644 --- a/drivers/usb/usbdcore_ep0.c +++ b/drivers/usb/usbdcore_ep0.c @@ -51,8 +51,6 @@ */
#include <common.h> - -#if defined(CONFIG_USB_DEVICE) #include "usbdcore.h"
#if 0 @@ -597,5 +595,3 @@ int ep0_recv_setup (struct urb *urb) } return -1; } - -#endif diff --git a/drivers/usb/usbdcore_mpc8xx.c b/drivers/usb/usbdcore_mpc8xx.c index 53bde0d..0e311ad 100644 --- a/drivers/usb/usbdcore_mpc8xx.c +++ b/drivers/usb/usbdcore_mpc8xx.c @@ -58,8 +58,6 @@ */ #include <common.h> #include <config.h> - -#if defined(CONFIG_MPC885_FAMILY) && defined(CONFIG_USB_DEVICE) #include <commproc.h> #include "usbdcore.h" #include "usbdcore_mpc8xx.h" @@ -1398,5 +1396,3 @@ static u32 mpc8xx_udc_alloc (u32 data_size, u32 alignment)
return retaddr; } - -#endif /* CONFIG_MPC885_FAMILY && CONFIG_USB_DEVICE) */ diff --git a/drivers/usb/usbdcore_omap1510.c b/drivers/usb/usbdcore_omap1510.c index 4e3239f..cb9dc44 100644 --- a/drivers/usb/usbdcore_omap1510.c +++ b/drivers/usb/usbdcore_omap1510.c @@ -27,9 +27,6 @@ */
#include <common.h> - -#if ((defined(CONFIG_OMAP1510) || defined(CONFIG_OMAP1610)) && defined(CONFIG_USB_DEVICE)) - #include <asm/io.h> #ifdef CONFIG_OMAP_SX1 #include <i2c.h> @@ -1566,4 +1563,3 @@ void udc_unset_nak (int epid) { /* TODO: implement this functionality in omap1510 */ } -#endif
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- drivers/bios_emulator/Makefile | 3 ++- drivers/bios_emulator/atibios.c | 5 ----- drivers/bios_emulator/besys.c | 4 ---- drivers/bios_emulator/bios.c | 4 ---- drivers/bios_emulator/biosemu.c | 4 ---- drivers/bios_emulator/x86emu/debug.c | 5 ----- drivers/bios_emulator/x86emu/decode.c | 5 ----- drivers/bios_emulator/x86emu/ops.c | 5 ----- drivers/bios_emulator/x86emu/ops2.c | 5 ----- drivers/bios_emulator/x86emu/prim_ops.c | 5 ----- drivers/bios_emulator/x86emu/sys.c | 5 ----- 11 files changed, 2 insertions(+), 48 deletions(-)
diff --git a/drivers/bios_emulator/Makefile b/drivers/bios_emulator/Makefile index 90c64da..c73da97 100644 --- a/drivers/bios_emulator/Makefile +++ b/drivers/bios_emulator/Makefile @@ -6,7 +6,7 @@ X86DIR = x86emu
$(shell mkdir -p $(obj)$(X86DIR))
-COBJS = atibios.o biosemu.o besys.o bios.o \ +COBJS-$(CONFIG_BIOSEMU) = atibios.o biosemu.o besys.o bios.o \ $(X86DIR)/decode.o \ $(X86DIR)/ops2.o \ $(X86DIR)/ops.o \ @@ -14,6 +14,7 @@ COBJS = atibios.o biosemu.o besys.o bios.o \ $(X86DIR)/sys.o \ $(X86DIR)/debug.o
+COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS))
diff --git a/drivers/bios_emulator/atibios.c b/drivers/bios_emulator/atibios.c index 5779f99..d950b18 100644 --- a/drivers/bios_emulator/atibios.c +++ b/drivers/bios_emulator/atibios.c @@ -46,9 +46,6 @@ * BIOS in u-boot. ****************************************************************************/ #include <common.h> - -#ifdef CONFIG_BIOSEMU - #include "biosemui.h" #include <malloc.h>
@@ -336,5 +333,3 @@ int BootVideoCardBIOS(pci_dev_t pcidev, BE_VGAInfo ** pVGAInfo, int cleanUp) *pVGAInfo = VGAInfo; return true; } - -#endif diff --git a/drivers/bios_emulator/besys.c b/drivers/bios_emulator/besys.c index cb1b0c1..cbc5062 100644 --- a/drivers/bios_emulator/besys.c +++ b/drivers/bios_emulator/besys.c @@ -48,9 +48,6 @@ ****************************************************************************/
#include <common.h> - -#if defined(CONFIG_BIOSEMU) - #include "biosemui.h"
/*------------------------- Global Variables ------------------------------*/ @@ -721,4 +718,3 @@ void X86API BE_outl(X86EMU_pioAddr port, u32 val) #endif LOG_outpd(port, val); } -#endif diff --git a/drivers/bios_emulator/bios.c b/drivers/bios_emulator/bios.c index d41511c..edda276 100644 --- a/drivers/bios_emulator/bios.c +++ b/drivers/bios_emulator/bios.c @@ -42,9 +42,6 @@ ****************************************************************************/
/*----------------------------- Implementation ----------------------------*/ @@ -323,4 +320,3 @@ void _BE_bios_init(u32 * intrTab) bios_intr_tab[0x6D] = int10; X86EMU_setupIntrFuncs(bios_intr_tab); } -#endif diff --git a/drivers/bios_emulator/biosemu.c b/drivers/bios_emulator/biosemu.c index decdb79..d0c6521 100644 --- a/drivers/bios_emulator/biosemu.c +++ b/drivers/bios_emulator/biosemu.c @@ -47,9 +47,6 @@
#include <malloc.h> #include <common.h> - -#if defined(CONFIG_BIOSEMU) - #include "biosemui.h"
BE_sysEnv _BE_env = {{0}}; @@ -372,4 +369,3 @@ int X86API BE_int86x(int intno, RMREGS * in, RMREGS * out, RMSREGS * sregs) sregs->gs = M.x86.R_GS; return out->x.ax; } -#endif diff --git a/drivers/bios_emulator/x86emu/debug.c b/drivers/bios_emulator/x86emu/debug.c index 29fe3f1..241acf3 100644 --- a/drivers/bios_emulator/x86emu/debug.c +++ b/drivers/bios_emulator/x86emu/debug.c @@ -39,9 +39,6 @@
#include <stdarg.h> #include <common.h> - -#if defined(CONFIG_BIOSEMU) - #include "x86emu/x86emui.h"
/*----------------------------- Implementation ----------------------------*/ @@ -463,5 +460,3 @@ void x86emu_dump_xregs(void) printk("NC "); printk("\n"); } - -#endif diff --git a/drivers/bios_emulator/x86emu/decode.c b/drivers/bios_emulator/x86emu/decode.c index 7a9a1dd..a782b81 100644 --- a/drivers/bios_emulator/x86emu/decode.c +++ b/drivers/bios_emulator/x86emu/decode.c @@ -37,9 +37,6 @@ * ****************************************************************************/ #include <common.h> - -#if defined(CONFIG_BIOSEMU) - #include "x86emu/x86emui.h"
/*----------------------------- Implementation ----------------------------*/ @@ -1145,5 +1142,3 @@ unsigned decode_rmXX_address(int mod, int rm) return decode_rm01_address(rm); return decode_rm10_address(rm); } - -#endif diff --git a/drivers/bios_emulator/x86emu/ops.c b/drivers/bios_emulator/x86emu/ops.c index 10f2757..d63c99f 100644 --- a/drivers/bios_emulator/x86emu/ops.c +++ b/drivers/bios_emulator/x86emu/ops.c @@ -76,9 +76,6 @@ ****************************************************************************/
/*----------------------------- Implementation ----------------------------*/ @@ -5434,5 +5431,3 @@ void (*x86emu_optab[256])(u8) __attribute__ ((section(GOT2_TYPE))) = /* 0xfe */ x86emuOp_opcFE_byte_RM, /* 0xff */ x86emuOp_opcFF_word_RM, }; - -#endif diff --git a/drivers/bios_emulator/x86emu/ops2.c b/drivers/bios_emulator/x86emu/ops2.c index d90d366..51e20e1 100644 --- a/drivers/bios_emulator/x86emu/ops2.c +++ b/drivers/bios_emulator/x86emu/ops2.c @@ -45,9 +45,6 @@ ****************************************************************************/
/*----------------------------- Implementation ----------------------------*/ @@ -1772,5 +1769,3 @@ void (*x86emu_optab2[256])(u8) __attribute__((section(GOT2_TYPE))) = /* 0xfe */ x86emuOp2_illegal_op, /* 0xff */ x86emuOp2_illegal_op, }; - -#endif diff --git a/drivers/bios_emulator/x86emu/prim_ops.c b/drivers/bios_emulator/x86emu/prim_ops.c index 2a254a4..7553087 100644 --- a/drivers/bios_emulator/x86emu/prim_ops.c +++ b/drivers/bios_emulator/x86emu/prim_ops.c @@ -100,9 +100,6 @@ #include <common.h>
#define PRIM_OPS_NO_REDEFINE_ASM - -#if defined(CONFIG_BIOSEMU) - #include "x86emu/x86emui.h"
/*------------------------- Global Variables ------------------------------*/ @@ -2448,5 +2445,3 @@ DB( if (CHECK_SP_ACCESS()) M.x86.R_SP += 4; return res; } - -#endif diff --git a/drivers/bios_emulator/x86emu/sys.c b/drivers/bios_emulator/x86emu/sys.c index dd44ff1..21f9730 100644 --- a/drivers/bios_emulator/x86emu/sys.c +++ b/drivers/bios_emulator/x86emu/sys.c @@ -40,9 +40,6 @@ ****************************************************************************/
/*------------------------- Global Variables ------------------------------*/ @@ -324,5 +321,3 @@ void X86EMU_prepareForInt(int num) M.x86.R_IP = mem_access_word(num * 4); M.x86.intr = 0; } - -#endif
Dear Jean-Christophe PLAGNIOL-VILLARD,
In message 1226094382-19338-2-git-send-email-plagnioj@jcrosoft.com you wrote:
Applied, thanks.
