[U-Boot] [PATCH] Blackfin: bfin_spi: fix build error when DEBUG is defined
4 Oct
2011
4 Oct
'11
2:51 a.m.
The new debug() changes pointed out debug code that rotted a little.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/spi/bfin_spi.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/drivers/spi/bfin_spi.c b/drivers/spi/bfin_spi.c index 213e792..e080bec 100644 --- a/drivers/spi/bfin_spi.c +++ b/drivers/spi/bfin_spi.c @@ -197,7 +197,7 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs, spi_set_speed(&bss->slave, max_hz);
debug("%s: bus:%i cs:%i mmr:%x ctl:%x baud:%i flg:%i\n", __func__, - bus, cs, mmr_base, bss->ctl, baud, bss->flg); + bus, cs, mmr_base, bss->ctl, bss->baud, bss->flg);
return &bss->slave; }
1.7.6.1
4965
Mike Frysinger
