[PATCH v2] mtd: spi: nor: force mtd name to "nor%d"
Force the mtd name of spi-nor to "nor" + the driver sequence number: "nor0", "nor1"...
This patch is coherent with existing "nand" and "spi-nand" mtd device names.
I keep the existing "nor" name to don't disturb the existing users of mtd functions. The mtd name 'nor' was configured previously by the function drivers/mtd/spi/sf_mtd.c:spi_flash_mtd_register() = "nor%d" + spi_flash_mtd_number()
The 'nor' name is also coherent with get_mtd_info() and the macro MTD_DEV_TYPE(): MTD_DEV_TYPE_NOR is associated with "nor" name.
This generic name can be use to identify the mtd spi-nor device without knowing the real device name or the DT path of the device, used with API get_mtd_device_nm().
And also avoid issue when the same NOR device is present 2 times, for example on STM32MP15F-EV1:
STM32MP> mtd list SF: Detected mx66l51235l with page size 256 Bytes, erase size 64 KiB, \ total 64 MiB
List of MTD devices: * nand0 - type: NAND flash - block size: 0x40000 bytes - min I/O: 0x1000 bytes - OOB size: 224 bytes - OOB available: 118 bytes - ECC strength: 8 bits - ECC step size: 512 bytes - bitflip threshold: 6 bits - 0x000000000000-0x000040000000 : "nand0" * mx66l51235l - device: mx66l51235l@0 - parent: spi@58003000 - driver: jedec_spi_nor - path: /soc/spi@58003000/mx66l51235l@0 - type: NOR flash - block size: 0x10000 bytes - min I/O: 0x1 bytes - 0x000000000000-0x000004000000 : "mx66l51235l" * mx66l51235l - device: mx66l51235l@1 - parent: spi@58003000 - driver: jedec_spi_nor - path: /soc/spi@58003000/mx66l51235l@1 - type: NOR flash - block size: 0x10000 bytes - min I/O: 0x1 bytes - 0x000000000000-0x000004000000 : "mx66l51235l"
The same mtd name "mx66l51235l" identify the 2 instance mx66l51235l@0 and mx66l51235l@1.
This patch solves a ST32CubeProgrammer / stm32prog command issue with nor0 target on STM32MP157C-EV1 board.
Fixes: b7f060565e31 ("mtd: spi-nor: allow registering multiple MTDs when DM is enabled") Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com --- For other device, the mtd name are hardcoded in each MTD driver:
drivers/mtd/nand/spi/core.c:1169: sprintf(mtd->name, "spi-nand%d", spi_nand_idx++); drivers/mtd/nand/raw/nand.c:59: sprintf(dev_name[devnum], "nand%d", devnum);
The existing user with "nor..."
arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c:625: mtd = get_mtd_device_nm(mtd_id); board/emulation/common/qemu_mtdparts.c:63: mtd = get_mtd_device_nm("nor0"); board/emulation/common/qemu_mtdparts.c:70: mtd = get_mtd_device_nm("nor1"); board/emulation/common/qemu_dfu.c:61: mtd = get_mtd_device_nm("nor0"); board/st/common/stm32mp_dfu.c:132: mtd = get_mtd_device_nm("nor0"); drivers/dfu/dfu_mtd.c:259: mtd = get_mtd_device_nm(devstr); => see "dfu mtd" support in doc/usage/dfu.rst
Changes in v2: - update commit message, change invalid patman tag "Series-Cc"
drivers/mtd/spi/spi-nor-core.c | 8 +++++--- include/linux/mtd/spi-nor.h | 1 + 2 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index d5d905fa5a..3eb7dcfddb 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3715,8 +3715,10 @@ int spi_nor_scan(struct spi_nor *nor) if (ret) return ret;
- if (!mtd->name) - mtd->name = info->name; + if (!mtd->name) { + sprintf(nor->mtd_name, "nor%d", dev_seq(nor->dev)); + mtd->name = nor->mtd_name; + } mtd->dev = nor->dev; mtd->priv = nor; mtd->type = MTD_NORFLASH; @@ -3821,7 +3823,7 @@ int spi_nor_scan(struct spi_nor *nor)
nor->rdsr_dummy = params.rdsr_dummy; nor->rdsr_addr_nbytes = params.rdsr_addr_nbytes; - nor->name = mtd->name; + nor->name = info->name; nor->size = mtd->size; nor->erase_size = mtd->erasesize; nor->sector_size = mtd->erasesize; diff --git a/include/linux/mtd/spi-nor.h b/include/linux/mtd/spi-nor.h index 7ddc4ba2bf..8c3d5032e3 100644 --- a/include/linux/mtd/spi-nor.h +++ b/include/linux/mtd/spi-nor.h @@ -561,6 +561,7 @@ struct spi_nor { int (*ready)(struct spi_nor *nor);
void *priv; + char mtd_name[10]; /* Compatibility for spi_flash, remove once sf layer is merged with mtd */ const char *name; u32 size;
Patrick Delaunay
