[U-Boot] Please pull u-boot-mpc85xx.git
git://www.denx.de/git/u-boot-mpc85xx.git master
This pull request supercedes the previous one, and contains the fixup patches from Peter Tyser for 5200 board support
Dave Liu (1): 85xx: Fix the boot window issue
Haiying Wang (1): Set IVPR to kenrel entry point in second core boot page
Kumar Gala (3): 85xx: Add support to populate addr map based on TLB settings ppc: Use addrmap in virt_to_phys and map_physmem. NAND FSL elbc: Use virt_to_phys to determine which bank is in use
Paul Gortmaker (3): sbc8548: don't enable the 3rd and 4th eTSEC sbc8548: enable command line editing by default. sbc8548: use proper PHY address
Peter Tyser (7): pci/fsl_pci_init: Enable inbound PCI config cycles Add support for PCA953x I2C gpio devices XPedite5370 board support 85xx: Enable inbound PCI config cycles for X-ES boards XPedite5200 board support XPedite5200 board support cleanup 85xx: Enable inbound PCI config cycles for X-ES boards cleanup
Trent Piepho (5): mpc8[56]xx: Put localbus clock in device tree mpc8xxx: LCRR[CLKDIV] is sometimes five bits mpc8568: Double local bus clock divider mpc86xx: Double local bus clock divider mpc8[56]xx: Put localbus clock in sysinfo and gd
MAINTAINERS | 4 + MAKEALL | 2 + Makefile | 8 + README | 9 + board/freescale/mpc8540ads/mpc8540ads.c | 2 +- board/freescale/mpc8541cds/mpc8541cds.c | 2 +- board/freescale/mpc8548cds/mpc8548cds.c | 2 +- board/freescale/mpc8555cds/mpc8555cds.c | 2 +- board/freescale/mpc8560ads/mpc8560ads.c | 2 +- board/freescale/mpc8568mds/mpc8568mds.c | 2 +- board/mpc8540eval/mpc8540eval.c | 2 +- board/pm854/pm854.c | 2 +- board/pm856/pm856.c | 2 +- board/sbc8548/sbc8548.c | 2 +- board/socrates/socrates.c | 2 +- board/tqc/tqm85xx/tqm85xx.c | 2 +- board/xes/common/Makefile | 57 +++ board/xes/common/actl_nand.c | 65 ++++ board/xes/common/fsl_8572_clk.c | 51 +++ board/xes/common/fsl_85xx_ddr.c | 93 +++++ board/xes/common/fsl_85xx_pci.c | 379 ++++++++++++++++++++ board/xes/xpedite5200/Makefile | 55 +++ board/xes/xpedite5200/config.mk | 34 ++ board/xes/xpedite5200/ddr.c | 91 +++++ board/xes/xpedite5200/law.c | 51 +++ board/xes/xpedite5200/tlb.c | 85 +++++ board/xes/xpedite5200/u-boot.lds | 145 ++++++++ board/xes/xpedite5200/xpedite5200.c | 125 +++++++ board/xes/xpedite5370/Makefile | 45 +++ board/xes/xpedite5370/config.mk | 35 ++ board/xes/xpedite5370/ddr.c | 270 ++++++++++++++ board/xes/xpedite5370/law.c | 54 +++ board/xes/xpedite5370/tlb.c | 94 +++++ board/xes/xpedite5370/u-boot.lds | 145 ++++++++ board/xes/xpedite5370/xpedite5370.c | 128 +++++++ cpu/mpc85xx/cpu.c | 31 +-- cpu/mpc85xx/fdt.c | 8 +- cpu/mpc85xx/release.S | 1 + cpu/mpc85xx/speed.c | 27 ++ cpu/mpc85xx/start.S | 16 +- cpu/mpc85xx/tlb.c | 34 ++ cpu/mpc86xx/cpu.c | 21 +- cpu/mpc86xx/fdt.c | 9 + cpu/mpc86xx/speed.c | 19 + drivers/gpio/Makefile | 47 +++ drivers/gpio/pca953x.c | 227 ++++++++++++ drivers/mtd/nand/fsl_elbc_nand.c | 6 +- drivers/pci/fsl_pci_init.c | 29 ++ include/asm-ppc/fsl_lbc.h | 5 +- include/asm-ppc/global_data.h | 3 + include/asm-ppc/io.h | 12 + include/asm-ppc/mmu.h | 3 + include/configs/XPEDITE5200.h | 546 ++++++++++++++++++++++++++++ include/configs/XPEDITE5370.h | 589 +++++++++++++++++++++++++++++++ include/configs/sbc8548.h | 20 +- include/e500.h | 1 + include/mpc86xx.h | 1 + include/pca953x.h | 39 ++ lib_ppc/board.c | 8 + 59 files changed, 3668 insertions(+), 83 deletions(-) create mode 100644 board/xes/common/Makefile create mode 100644 board/xes/common/actl_nand.c create mode 100644 board/xes/common/fsl_8572_clk.c create mode 100644 board/xes/common/fsl_85xx_ddr.c create mode 100644 board/xes/common/fsl_85xx_pci.c create mode 100644 board/xes/xpedite5200/Makefile create mode 100644 board/xes/xpedite5200/config.mk create mode 100644 board/xes/xpedite5200/ddr.c create mode 100644 board/xes/xpedite5200/law.c create mode 100644 board/xes/xpedite5200/tlb.c create mode 100644 board/xes/xpedite5200/u-boot.lds create mode 100644 board/xes/xpedite5200/xpedite5200.c create mode 100644 board/xes/xpedite5370/Makefile create mode 100644 board/xes/xpedite5370/config.mk create mode 100644 board/xes/xpedite5370/ddr.c create mode 100644 board/xes/xpedite5370/law.c create mode 100644 board/xes/xpedite5370/tlb.c create mode 100644 board/xes/xpedite5370/u-boot.lds create mode 100644 board/xes/xpedite5370/xpedite5370.c create mode 100644 drivers/gpio/Makefile create mode 100644 drivers/gpio/pca953x.c create mode 100644 include/configs/XPEDITE5200.h create mode 100644 include/configs/XPEDITE5370.h create mode 100644 include/pca953x.h
Andy Fleming
