[PATCH] board: gateworks: venice: rename eeprom_init
rename eeprom_init to avoid build failure when using CMD_EEPROM.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/venice/eeprom.c | 2 +- board/gateworks/venice/eeprom.h | 2 +- board/gateworks/venice/spl.c | 2 +- board/gateworks/venice/venice.c | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/board/gateworks/venice/eeprom.c b/board/gateworks/venice/eeprom.c index ac52cc0a9ec9..6aea60ad05c7 100644 --- a/board/gateworks/venice/eeprom.c +++ b/board/gateworks/venice/eeprom.c @@ -299,7 +299,7 @@ static int eeprom_info(bool verbose) return 0; }
-int eeprom_init(int quiet) +int venice_eeprom_init(int quiet) { char rev_pcb; int rev_bom; diff --git a/board/gateworks/venice/eeprom.h b/board/gateworks/venice/eeprom.h index 8ea7318d7dfc..bb7a5fa9ad1f 100644 --- a/board/gateworks/venice/eeprom.h +++ b/board/gateworks/venice/eeprom.h @@ -24,7 +24,7 @@ struct venice_board_info { u8 chksum[2]; /* 0x4E */ };
-int eeprom_init(int quiet); +int venice_eeprom_init(int quiet); const char *eeprom_get_model(void); const char *eeprom_get_baseboard_model(void); const char *eeprom_get_dtb_name(int level, char *buf, int len); diff --git a/board/gateworks/venice/spl.c b/board/gateworks/venice/spl.c index ae460296cb99..14241e5e2fb6 100644 --- a/board/gateworks/venice/spl.c +++ b/board/gateworks/venice/spl.c @@ -280,7 +280,7 @@ void board_init_f(ulong dummy) break; mdelay(1); } - dram_sz = eeprom_init(0); + dram_sz = venice_eeprom_init(0);
/* PMIC */ power_init_board(); diff --git a/board/gateworks/venice/venice.c b/board/gateworks/venice/venice.c index 32b25ffd3edf..d94f6b8a577d 100644 --- a/board/gateworks/venice/venice.c +++ b/board/gateworks/venice/venice.c @@ -111,7 +111,7 @@ int board_phy_config(struct phy_device *phydev)
int board_init(void) { - eeprom_init(1); + venice_eeprom_init(1);
if (IS_ENABLED(CONFIG_FEC_MXC)) setup_fec();
rename eeprom_init to avoid build failure when using CMD_EEPROM. Signed-off-by: Tim Harvey tharvey@gateworks.com
Best regards, Stefano Babic
sbabic@denx.de
Tim Harvey
