[U-Boot] [PATCH] ARM: uniphier: use BIT() macro for DDR PHY header
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/include/mach/ddrphy-regs.h | 91 ++++++++++++----------- 1 file changed, 46 insertions(+), 45 deletions(-)
diff --git a/arch/arm/mach-uniphier/include/mach/ddrphy-regs.h b/arch/arm/mach-uniphier/include/mach/ddrphy-regs.h index 0c3b508..03aedc2 100644 --- a/arch/arm/mach-uniphier/include/mach/ddrphy-regs.h +++ b/arch/arm/mach-uniphier/include/mach/ddrphy-regs.h @@ -9,6 +9,7 @@ #ifndef ARCH_DDRPHY_REGS_H #define ARCH_DDRPHY_REGS_H
+#include <linux/bitops.h> #include <linux/compiler.h>
#ifndef __ASSEMBLY__ @@ -79,52 +80,52 @@ struct ddrphy {
#endif /* __ASSEMBLY__ */
-#define PIR_INIT (1 << 0) /* Initialization Trigger */ -#define PIR_ZCAL (1 << 1) /* Impedance Calibration */ -#define PIR_PLLINIT (1 << 4) /* PLL Initialization */ -#define PIR_DCAL (1 << 5) /* DDL Calibration */ -#define PIR_PHYRST (1 << 6) /* PHY Reset */ -#define PIR_DRAMRST (1 << 7) /* DRAM Reset */ -#define PIR_DRAMINIT (1 << 8) /* DRAM Initialization */ -#define PIR_WL (1 << 9) /* Write Leveling */ -#define PIR_QSGATE (1 << 10) /* Read DQS Gate Training */ -#define PIR_WLADJ (1 << 11) /* Write Leveling Adjust */ -#define PIR_RDDSKW (1 << 12) /* Read Data Bit Deskew */ -#define PIR_WRDSKW (1 << 13) /* Write Data Bit Deskew */ -#define PIR_RDEYE (1 << 14) /* Read Data Eye Training */ -#define PIR_WREYE (1 << 15) /* Write Data Eye Training */ -#define PIR_LOCKBYP (1 << 28) /* PLL Lock Bypass */ -#define PIR_DCALBYP (1 << 29) /* DDL Calibration Bypass */ -#define PIR_ZCALBYP (1 << 30) /* Impedance Calib Bypass */ -#define PIR_INITBYP (1 << 31) /* Initialization Bypass */ - -#define PGSR0_IDONE (1 << 0) /* Initialization Done */ -#define PGSR0_PLDONE (1 << 1) /* PLL Lock Done */ -#define PGSR0_DCDONE (1 << 2) /* DDL Calibration Done */ -#define PGSR0_ZCDONE (1 << 3) /* Impedance Calibration Done */ -#define PGSR0_DIDONE (1 << 4) /* DRAM Initialization Done */ -#define PGSR0_WLDONE (1 << 5) /* Write Leveling Done */ -#define PGSR0_QSGDONE (1 << 6) /* DQS Gate Training Done */ -#define PGSR0_WLADONE (1 << 7) /* Write Leveling Adjust Done */ -#define PGSR0_RDDONE (1 << 8) /* Read Bit Deskew Done */ -#define PGSR0_WDDONE (1 << 9) /* Write Bit Deskew Done */ -#define PGSR0_REDONE (1 << 10) /* Read Eye Training Done */ -#define PGSR0_WEDONE (1 << 11) /* Write Eye Training Done */ -#define PGSR0_IERR (1 << 16) /* Initialization Error */ -#define PGSR0_PLERR (1 << 17) /* PLL Lock Error */ -#define PGSR0_DCERR (1 << 18) /* DDL Calibration Error */ -#define PGSR0_ZCERR (1 << 19) /* Impedance Calib Error */ -#define PGSR0_DIERR (1 << 20) /* DRAM Initialization Error */ -#define PGSR0_WLERR (1 << 21) /* Write Leveling Error */ -#define PGSR0_QSGERR (1 << 22) /* DQS Gate Training Error */ -#define PGSR0_WLAERR (1 << 23) /* Write Leveling Adj Error */ -#define PGSR0_RDERR (1 << 24) /* Read Bit Deskew Error */ -#define PGSR0_WDERR (1 << 25) /* Write Bit Deskew Error */ -#define PGSR0_REERR (1 << 26) /* Read Eye Training Error */ -#define PGSR0_WEERR (1 << 27) /* Write Eye Training Error */ +#define PIR_INIT BIT(0) /* Initialization Trigger */ +#define PIR_ZCAL BIT(1) /* Impedance Calibration */ +#define PIR_PLLINIT BIT(4) /* PLL Initialization */ +#define PIR_DCAL BIT(5) /* DDL Calibration */ +#define PIR_PHYRST BIT(6) /* PHY Reset */ +#define PIR_DRAMRST BIT(7) /* DRAM Reset */ +#define PIR_DRAMINIT BIT(8) /* DRAM Initialization */ +#define PIR_WL BIT(9) /* Write Leveling */ +#define PIR_QSGATE BIT(10) /* Read DQS Gate Training */ +#define PIR_WLADJ BIT(11) /* Write Leveling Adjust */ +#define PIR_RDDSKW BIT(12) /* Read Data Bit Deskew */ +#define PIR_WRDSKW BIT(13) /* Write Data Bit Deskew */ +#define PIR_RDEYE BIT(14) /* Read Data Eye Training */ +#define PIR_WREYE BIT(15) /* Write Data Eye Training */ +#define PIR_LOCKBYP BIT(28) /* PLL Lock Bypass */ +#define PIR_DCALBYP BIT(29) /* DDL Calibration Bypass */ +#define PIR_ZCALBYP BIT(30) /* Impedance Calib Bypass */ +#define PIR_INITBYP BIT(31) /* Initialization Bypass */ + +#define PGSR0_IDONE BIT(0) /* Initialization Done */ +#define PGSR0_PLDONE BIT(1) /* PLL Lock Done */ +#define PGSR0_DCDONE BIT(2) /* DDL Calibration Done */ +#define PGSR0_ZCDONE BIT(3) /* Impedance Calibration Done */ +#define PGSR0_DIDONE BIT(4) /* DRAM Initialization Done */ +#define PGSR0_WLDONE BIT(5) /* Write Leveling Done */ +#define PGSR0_QSGDONE BIT(6) /* DQS Gate Training Done */ +#define PGSR0_WLADONE BIT(7) /* Write Leveling Adjust Done */ +#define PGSR0_RDDONE BIT(8) /* Read Bit Deskew Done */ +#define PGSR0_WDDONE BIT(9) /* Write Bit Deskew Done */ +#define PGSR0_REDONE BIT(10) /* Read Eye Training Done */ +#define PGSR0_WEDONE BIT(11) /* Write Eye Training Done */ +#define PGSR0_IERR BIT(16) /* Initialization Error */ +#define PGSR0_PLERR BIT(17) /* PLL Lock Error */ +#define PGSR0_DCERR BIT(18) /* DDL Calibration Error */ +#define PGSR0_ZCERR BIT(19) /* Impedance Calib Error */ +#define PGSR0_DIERR BIT(20) /* DRAM Initialization Error */ +#define PGSR0_WLERR BIT(21) /* Write Leveling Error */ +#define PGSR0_QSGERR BIT(22) /* DQS Gate Training Error */ +#define PGSR0_WLAERR BIT(23) /* Write Leveling Adj Error */ +#define PGSR0_RDERR BIT(24) /* Read Bit Deskew Error */ +#define PGSR0_WDERR BIT(25) /* Write Bit Deskew Error */ +#define PGSR0_REERR BIT(26) /* Read Eye Training Error */ +#define PGSR0_WEERR BIT(27) /* Write Eye Training Error */ #define PGSR0_DTERR_SHIFT 28 /* Data Training Error Status*/ #define PGSR0_DTERR (7 << (PGSR0_DTERR_SHIFT)) -#define PGSR0_APLOCK (1 << 31) /* AC PLL Lock */ +#define PGSR0_APLOCK BIT(31) /* AC PLL Lock */
#define DXCCR_DQSRES_OPEN (0 << 5) #define DXCCR_DQSRES_688_OHM (1 << 5) @@ -146,7 +147,7 @@ struct ddrphy {
#define DTCR_DTRANK_SHIFT 4 /* Data Training Rank */ #define DTCR_DTRANK_MASK (0x3 << (DTCR_DTRANK_SHIFT)) -#define DTCR_DTMPR (1 << 6) /* Data Training using MPR */ +#define DTCR_DTMPR BIT(6) /* Data Training using MPR */ #define DTCR_RANKEN_SHIFT 24 /* Rank Enable */ #define DTCR_RANKEN_MASK (0xf << (DTCR_RANKEN_SHIFT))
2015-12-16 10:44 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
applied to u-boot-uniphier/master.
Masahiro Yamada
