[U-Boot] [PATCH][RFC v2] add pci 64 bit prefechable mem support
u-boot did not program the upper 32 bits of prefetchable base and limit in pci bridge config space. I think it's needed when 64 bit address space is used. Changes for v1: - use lowest bit of prefechable base(or limit) to determine whether the bridge support 64 bit prefechable address space.
Signed-off-by: David Feng fenghua@phytium.com.cn --- drivers/pci/pci_auto.c | 38 ++++++++++++++++++++++++++++++++++++-- 1 file changed, 36 insertions(+), 2 deletions(-)
diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index 86ba6b5..14652be 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -197,9 +197,12 @@ void pciauto_prescan_setup_bridge(struct pci_controller *hose, struct pci_region *pci_mem = hose->pci_mem; struct pci_region *pci_prefetch = hose->pci_prefetch; struct pci_region *pci_io = hose->pci_io; - u16 cmdstat; + u16 cmdstat, prefechable_64;
pci_hose_read_config_word(hose, dev, PCI_COMMAND, &cmdstat); + pci_hose_read_config_word(hose, dev, PCI_PREF_MEMORY_BASE, + &prefechable_64); + prefechable_64 &= 0x1;
/* Configure bus number registers */ pci_hose_write_config_byte(hose, dev, PCI_PRIMARY_BUS, @@ -226,12 +229,26 @@ void pciauto_prescan_setup_bridge(struct pci_controller *hose, /* Set up memory and I/O filter limits, assume 32-bit I/O space */ pci_hose_write_config_word(hose, dev, PCI_PREF_MEMORY_BASE, (pci_prefetch->bus_lower & 0xfff00000) >> 16); + if (prefechable_64) +#ifdef CONFIG_SYS_PCI_64BIT + pci_hose_write_config_dword(hose, dev, + PCI_PREF_BASE_UPPER32, + pci_prefetch->bus_lower >> 32); +#else + pci_hose_write_config_dword(hose, dev, + PCI_PREF_BASE_UPPER32, + 0x0); +#endif
cmdstat |= PCI_COMMAND_MEMORY; } else { /* We don't support prefetchable memory for now, so disable */ pci_hose_write_config_word(hose, dev, PCI_PREF_MEMORY_BASE, 0x1000); pci_hose_write_config_word(hose, dev, PCI_PREF_MEMORY_LIMIT, 0x0); + if (prefechable_64) { + pci_hose_write_config_word(hose, dev, PCI_PREF_BASE_UPPER32, 0x0); + pci_hose_write_config_word(hose, dev, PCI_PREF_LIMIT_UPPER32, 0x0); + } }
if (pci_io) { @@ -271,11 +288,28 @@ void pciauto_postscan_setup_bridge(struct pci_controller *hose, }
if (pci_prefetch) { + u16 prefechable_64; + + pci_hose_read_config_word(hose, dev, + PCI_PREF_MEMORY_LIMIT, + &prefechable_64); + prefechable_64 &= 0x1; + /* Round memory allocator to 1MB boundary */ pciauto_region_align(pci_prefetch, 0x100000);
pci_hose_write_config_word(hose, dev, PCI_PREF_MEMORY_LIMIT, - (pci_prefetch->bus_lower - 1) >> 16); + (pci_prefetch->bus_lower - 1) >> 16); + if (prefechable_64) +#ifdef CONFIG_SYS_PCI_64BIT + pci_hose_write_config_dword(hose, dev, + PCI_PREF_LIMIT_UPPER32, + (pci_prefetch->bus_lower - 1) >> 32); +#else + pci_hose_write_config_dword(hose, dev, + PCI_PREF_LIMIT_UPPER32, + 0x0); +#endif }
if (pci_io) {
Dear fenghua@phytium.com.cn,
In message 1392282108-56485-1-git-send-email-fenghua@phytium.com.cn you wrote:
You write "I think it's needed" - is it or not?
Do you have a specific test case that fails without your patch, and works with it?
-----Original Messages----- From: "Wolfgang Denk" wd@denx.de Sent Time: 2014-02-14 00:30:24 (Friday) To: fenghua@phytium.com.cn Cc: u-boot@lists.denx.de, trini@ti.com, albert.u.boot@aribaud.net Subject: Re: [PATCH][RFC v2] add pci 64 bit prefechable mem support
Wolfgang Denk.
There's no test case now (maybe a few days later I could make a test). "PCI-to-PCI Bridge Architecture Specification" require that the upper 32 bit of prefetchable space must be initialized by configuration software. But usually the default value is zero already. A board using 64 bit pci prefetchable memory space and a pci device with 64 bit prefetchable space are needed. I think u-boot did not encounter this situation before.
Best Regards, David
Wolfgang Denk.
There's two things happening here.
1) You are adding support to explicitly program the upper32 prefetch limit/base to zero (in the 64-bit prefetch memory <4GB case) which is a completely theoretical fix. I can more or less confirm that this doesn't cause a problem in practice for prefetch memory <4GB. When I wrote the original code in-kernel, I had noticed this on the 21154 bridges and others when I was trying out WIP prefetch support (which I never finished to upstream because we let the kernel subsystem fix up prefetch later). If we look at the history of the prefetch support added to the U-Boot version of pci_auto.c it's also proven on real h/w that this is only a theoretical fix. To be fair, it is best to be safe, but as Wolfgang points out it appears you are fixing something that's not practically broken
2) 64-bit prefetch support for prefetch memory >4GB. It's up to the maintainers, but given that this is untested code, I don't see a good reason to merge it. I have reviewed it and the implementation looks correct to me per spec. However, I believe that you should resubmit this patch along with support for a platform that actually makes use of it as you describe above. At that time, it would be appropriate to fix the possible latent bug (for a not-yet-known p2p bridge that doesn't default upper32 limit/base to 0) in the <4GB case just as part of handling the
4GB case.
-Matt
FengHua
fenghuaï¼ phytium.com.cn
Matt Porter
