[U-Boot] [PATCH 2/3] 85xx: Fix the wrong CSIZE mask bit
The CSIZE is L1CFG0[56-63] in the e500 and e500mc core, so we should mask 0xff, not 0x1ff.
Signed-off-by: Dave Liu daveliu@freescale.com --- cpu/mpc85xx/start.S | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpu/mpc85xx/start.S b/cpu/mpc85xx/start.S index 80f9677..cfa53c0 100644 --- a/cpu/mpc85xx/start.S +++ b/cpu/mpc85xx/start.S @@ -244,7 +244,7 @@ switch_as: lis r3,CONFIG_SYS_INIT_RAM_ADDR@h ori r3,r3,CONFIG_SYS_INIT_RAM_ADDR@l mfspr r2, L1CFG0 - andi. r2, r2, 0x1ff + andi. r2, r2, 0xff /* cache size * 1024 / (2 * L1 line size) */ slwi r2, r2, (10 - 1 - L1_CACHE_SHIFT) mtctr r2 @@ -1004,7 +1004,7 @@ unlock_ram_in_cache: lis r3,(CONFIG_SYS_INIT_RAM_ADDR & ~(CONFIG_SYS_CACHELINE_SIZE-1))@h ori r3,r3,(CONFIG_SYS_INIT_RAM_ADDR & ~(CONFIG_SYS_CACHELINE_SIZE-1))@l mfspr r4,L1CFG0 - andi. r4,r4,0x1ff + andi. r4,r4,0xff slwi r4,r4,(10 - 1 - L1_CACHE_SHIFT) mtctr r4 1: dcbi r0,r3
was code breaking or just fixing it up to match the docs?
- k
not break the system, because the bit[55] is reserved zero for e500/e500mc. so just fixied it to match the e500/e500mc docs.
Ok. I'd prefer we just expand the field to 0x3ff to match the EREF spec since the upper bits are reserved we'll always read them as 0 so no harm. And we dont have to change the code again in the future if we expand into those upper bits.
- k
If match the EREF, it should be 0x7ff. and it also cause our customers confuse why not use the mask in e500UM. Anyway, it is easy to change them to 0x7ff for me.
Dave Liu
Kumar Gala
Liu Dave
