[PATCH 1/1] test: fix pylint warnings in test_env.py
* assert does not need parentheses * add module docstring * fix misspelled constant True * limit lines to 100 characters
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- test/py/tests/test_env.py | 20 ++++++++++++-------- 1 file changed, 12 insertions(+), 8 deletions(-)
diff --git a/test/py/tests/test_env.py b/test/py/tests/test_env.py index 9bed2f48d7..39fad4194b 100644 --- a/test/py/tests/test_env.py +++ b/test/py/tests/test_env.py @@ -2,11 +2,13 @@ # Copyright (c) 2015 Stephen Warren # Copyright (c) 2015-2016, NVIDIA CORPORATION. All rights reserved.
-# Test operation of shell commands relating to environment variables. +""" +Test operation of shell commands relating to environment variables. +"""
import os import os.path -from subprocess import call, check_call, CalledProcessError +from subprocess import call, CalledProcessError
import pytest import u_boot_utils @@ -191,7 +193,7 @@ def test_env_printenv_non_existent(state_test_env): c = state_test_env.u_boot_console with c.disable_check('error_notification'): response = c.run_command('printenv %s' % var) - assert(response == '## Error: "%s" not defined' % var) + assert response == '## Error: "%s" not defined' % var
@pytest.mark.buildconfigspec('cmd_echo') def test_env_unset_non_existent(state_test_env): @@ -256,7 +258,7 @@ def test_env_import_checksum_no_size(state_test_env):
with c.disable_check('error_notification'): response = c.run_command('env import -c %s -' % addr) - assert(response == '## Error: external checksum format must pass size') + assert response == '## Error: external checksum format must pass size'
@pytest.mark.buildconfigspec('cmd_importenv') def test_env_import_whitelist_checksum_no_size(state_test_env): @@ -269,7 +271,7 @@ def test_env_import_whitelist_checksum_no_size(state_test_env):
with c.disable_check('error_notification'): response = c.run_command('env import -c %s - foo1 foo2 foo4' % addr) - assert(response == '## Error: external checksum format must pass size') + assert response == '## Error: external checksum format must pass size'
@pytest.mark.buildconfigspec('cmd_exportenv') @pytest.mark.buildconfigspec('cmd_importenv') @@ -358,12 +360,14 @@ def test_env_info(state_test_env): assert '= true' in l or '= false' in l nb_line += 1 else: - assert true + assert True assert nb_line == 3
response = c.run_command('env info -p -d') - assert 'Default environment is used' in response or "Environment was loaded from persistent storage" in response - assert 'Environment can be persisted' in response or "Environment cannot be persisted" in response + assert 'Default environment is used' in response or \ + "Environment was loaded from persistent storage" in response + assert 'Environment can be persisted' in response or \ + "Environment cannot be persisted" in response
response = c.run_command('env info -p -d -q') assert response == ""
On Fri, Nov 26, 2021 at 11:30:27PM +0100, Heinrich Schuchardt wrote:
- assert does not need parentheses
- add module docstring
- fix misspelled constant True
- limit lines to 100 characters
