[U-Boot] [PATCH] [fdt] Fix constness of the fdt void pointer in fdt_getprop_u32_default
The function fdt_getprop_u32_default doesn't modify the fdt, so it can use a const void * for its fdt argument.
Signed-off-by: Gabe Black gabeblack@chromium.org --- common/fdt_support.c | 4 ++-- include/fdt_support.h | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/common/fdt_support.c b/common/fdt_support.c index bdda64d..bd3a014 100644 --- a/common/fdt_support.c +++ b/common/fdt_support.c @@ -49,8 +49,8 @@ DECLARE_GLOBAL_DATA_PTR; * Convenience function to find a node and return it's property or a * default value if it doesn't exist. */ -u32 fdt_getprop_u32_default(void *fdt, const char *path, const char *prop, - const u32 dflt) +u32 fdt_getprop_u32_default(const void *fdt, const char *path, + const char *prop, const u32 dflt) { const u32 *val; int off; diff --git a/include/fdt_support.h b/include/fdt_support.h index c7b4605..cef3c65 100644 --- a/include/fdt_support.h +++ b/include/fdt_support.h @@ -28,8 +28,8 @@
#include <fdt.h>
-u32 fdt_getprop_u32_default(void *fdt, const char *path, const char *prop, - const u32 dflt); +u32 fdt_getprop_u32_default(const void *fdt, const char *path, + const char *prop, const u32 dflt); int fdt_chosen(void *fdt, int force); int fdt_initrd(void *fdt, ulong initrd_start, ulong initrd_end, int force); void do_fixup_by_path(void *fdt, const char *path, const char *prop,
+fdt maintainer
- Convenience function to find a node and return it's property or a
- default value if it doesn't exist.
const u32 dflt)
#include <fdt.h>
const u32 dflt);
Bump.
On Tue, Nov 8, 2011 at 5:47 AM, Mike Frysinger vapier@gentoo.org wrote:
+fdt maintainer
use
*prop,
const u32 dflt)
#include <fdt.h>
*prop,
const u32 dflt);
Signed-off-by: Gabe Blackgabeblack@chromium.org
Applied and requested a bugfix pull.
Thanks, gvb
Gabe Black
Gabe Black
Jerry Van Baren
Mike Frysinger
