[PATCH 1/2] driver: watchdog: reset watchdog in designware_wdt_stop() function
In uboot command line environment, watchdog is not able to be stopped with below commands: SOCFPGA_STRATIX10 # wdt dev watchdog@ffd00200 SOCFPGA_STRATIX10 # wdt stop Refer to watchdog driver in linux kernel, it is also need to reset watchdog after disable it so that the disable action takes effect.
Signed-off-by: Meng Li Meng.Li@windriver.com --- drivers/watchdog/designware_wdt.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/drivers/watchdog/designware_wdt.c b/drivers/watchdog/designware_wdt.c index 12f09a7a39..63e89d38c4 100644 --- a/drivers/watchdog/designware_wdt.c +++ b/drivers/watchdog/designware_wdt.c @@ -92,10 +92,27 @@ static int designware_wdt_reset(struct udevice *dev) static int designware_wdt_stop(struct udevice *dev) { struct designware_wdt_priv *priv = dev_get_priv(dev); + __maybe_unused int ret;
designware_wdt_reset(dev); writel(0, priv->base + DW_WDT_CR);
+#if CONFIG_IS_ENABLED(DM_RESET) + struct reset_ctl_bulk resets; + + ret = reset_get_bulk(dev, &resets); + if (ret) + return ret; + + ret = reset_assert_bulk(&resets); + if (ret) + return ret; + + ret = reset_deassert_bulk(&resets); + if (ret) + return ret; +#endif + return 0; }
In latest u-boot code, watchdog feature is implemented, so enable wdt command by default.
Signed-off-by: Meng Li Meng.Li@windriver.com --- configs/socfpga_stratix10_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index 02d4ac0dae..0256afe511 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_WDT=y CONFIG_MTDIDS_DEFAULT="nor0=ff705000.spi.0" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y
- __maybe_unused int ret;
You add "ret" here as "__maybe_unused" and ...
- struct reset_ctl_bulk resets;
... here this struct. Please add both above as __maybe_unsed. I assume that checkpatch and other tools will complain about variable declarations in the code path.
BTW: It should be possible to change the above #if CONFIG_ to this
if (CONFIG_IS_ENABLED(DM_RESET)) {
Then you can put both variable declarations in here:
if (CONFIG_IS_ENABLED(DM_RESET)) { struct reset_ctl_bulk resets; int ret;
Please check if this works and resubmit.
Thanks, Stefan
- ret = reset_get_bulk(dev, &resets);
- if (ret)
return ret;
- ret = reset_assert_bulk(&resets);
- if (ret)
return ret;
- ret = reset_deassert_bulk(&resets);
- if (ret)
return ret;
- return 0; }
Stefan Roese
