[PATCH v2 0/3] *** Introduce get_boot_device() for K3 platform ***
It is handy to have some u-boot environment variables set based on the current booting device. Provide a way to obtain the boot device for non SPLs by factoring out spl_boot_device() into an own function get_boot_device().
v2: - Relocate bootindex to OCRAM, drop misleading comments and remove not needed changes - Make get_boot_device() read bootindex out of OCRAM - Add user for get_boot_device(), patch 3
v1: https://lists.denx.de/pipermail/u-boot/2024-February/546770.html
Wadim Egorov (3): arm: mach-k3: am625: copy bootindex to OCRAM for main domain SPL arm: mach-k3: am625: Provide a way to obtain boot device for non SPLs board: phycore-am62x: Extend for better environment handling
arch/arm/mach-k3/Makefile | 1 + arch/arm/mach-k3/am625_init.c | 103 ++---------------- arch/arm/mach-k3/am62x/Makefile | 2 + arch/arm/mach-k3/am62x/boot.c | 103 ++++++++++++++++++ arch/arm/mach-k3/include/mach/am62_hardware.h | 1 + arch/arm/mach-k3/include/mach/hardware.h | 1 + board/phytec/phycore_am62x/phycore-am62x.c | 64 +++++++++++ configs/phycore_am62x_a53_defconfig | 1 + 8 files changed, 182 insertions(+), 94 deletions(-) create mode 100644 arch/arm/mach-k3/am62x/Makefile create mode 100644 arch/arm/mach-k3/am62x/boot.c
Relocate booindex to OCRAM region after it gets opened by TIFS so the main domain bootloaders can have access to this data.
Signed-off-by: Wadim Egorov w.egorov@phytec.de --- v2: - Relocate bootindex to OCRAM, drop misleading comments and remove not needed changes --- arch/arm/mach-k3/am625_init.c | 8 ++++++++ arch/arm/mach-k3/include/mach/am62_hardware.h | 1 + 2 files changed, 9 insertions(+)
diff --git a/arch/arm/mach-k3/am625_init.c b/arch/arm/mach-k3/am625_init.c index 6c96e881146..c9c97b6ce19 100644 --- a/arch/arm/mach-k3/am625_init.c +++ b/arch/arm/mach-k3/am625_init.c @@ -175,6 +175,14 @@ void board_init_f(ulong dummy) k3_sysfw_loader(true, NULL, NULL); }
+ /* + * Relocate boot information to OCRAM (after TIFS has opend this + * region for us) so the next bootloader stages can keep access to + * primary vs backup bootmodes. + */ + if (IS_ENABLED(CONFIG_CPU_V7R)) + writel(bootindex, K3_BOOT_PARAM_TABLE_INDEX_OCRAM); + /* * Force probe of clk_k3 driver here to ensure basic default clock * configuration is always done. diff --git a/arch/arm/mach-k3/include/mach/am62_hardware.h b/arch/arm/mach-k3/include/mach/am62_hardware.h index 54380f36e16..30c2f11062c 100644 --- a/arch/arm/mach-k3/include/mach/am62_hardware.h +++ b/arch/arm/mach-k3/include/mach/am62_hardware.h @@ -76,6 +76,7 @@ #define CTRLMMR_MCU_RST_CTRL (MCU_CTRL_MMR0_BASE + 0x18170)
#define ROM_EXTENDED_BOOT_DATA_INFO 0x43c3f1e0 +#define K3_BOOT_PARAM_TABLE_INDEX_OCRAM 0x7000F290
#define TI_SRAM_SCRATCH_BOARD_EEPROM_START 0x43c30000
Introduce get_boot_device() to obtain the booting device. Make it also available for non SPL builds so u-boot can also know the device it is booting from.
Signed-off-by: Wadim Egorov w.egorov@phytec.de --- v2: - Make get_boot_device() read bootindex out of OCRAM --- arch/arm/mach-k3/Makefile | 1 + arch/arm/mach-k3/am625_init.c | 95 +-------------------- arch/arm/mach-k3/am62x/Makefile | 2 + arch/arm/mach-k3/am62x/boot.c | 103 +++++++++++++++++++++++ arch/arm/mach-k3/include/mach/hardware.h | 1 + 5 files changed, 108 insertions(+), 94 deletions(-) create mode 100644 arch/arm/mach-k3/am62x/Makefile create mode 100644 arch/arm/mach-k3/am62x/boot.c
diff --git a/arch/arm/mach-k3/Makefile b/arch/arm/mach-k3/Makefile index 42161376469..61ec4ea13cf 100644 --- a/arch/arm/mach-k3/Makefile +++ b/arch/arm/mach-k3/Makefile @@ -22,3 +22,4 @@ obj-$(CONFIG_SOC_K3_AM625) += am625_init.o obj-$(CONFIG_SOC_K3_AM62A7) += am62a7_init.o endif obj-y += common.o security.o +obj-$(CONFIG_SOC_K3_AM625) += am62x/ diff --git a/arch/arm/mach-k3/am625_init.c b/arch/arm/mach-k3/am625_init.c index c9c97b6ce19..56078099f09 100644 --- a/arch/arm/mach-k3/am625_init.c +++ b/arch/arm/mach-k3/am625_init.c @@ -243,100 +243,7 @@ u32 spl_mmc_boot_mode(struct mmc *mmc, const u32 boot_device) } }
-static u32 __get_backup_bootmedia(u32 devstat) -{ - u32 bkup_bootmode = (devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_MASK) >> - MAIN_DEVSTAT_BACKUP_BOOTMODE_SHIFT; - u32 bkup_bootmode_cfg = - (devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_MASK) >> - MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_SHIFT; - - switch (bkup_bootmode) { - case BACKUP_BOOT_DEVICE_UART: - return BOOT_DEVICE_UART; - - case BACKUP_BOOT_DEVICE_USB: - return BOOT_DEVICE_USB; - - case BACKUP_BOOT_DEVICE_ETHERNET: - return BOOT_DEVICE_ETHERNET; - - case BACKUP_BOOT_DEVICE_MMC: - if (bkup_bootmode_cfg) - return BOOT_DEVICE_MMC2; - return BOOT_DEVICE_MMC1; - - case BACKUP_BOOT_DEVICE_SPI: - return BOOT_DEVICE_SPI; - - case BACKUP_BOOT_DEVICE_I2C: - return BOOT_DEVICE_I2C; - - case BACKUP_BOOT_DEVICE_DFU: - if (bkup_bootmode_cfg & MAIN_DEVSTAT_BACKUP_USB_MODE_MASK) - return BOOT_DEVICE_USB; - return BOOT_DEVICE_DFU; - }; - - return BOOT_DEVICE_RAM; -} - -static u32 __get_primary_bootmedia(u32 devstat) -{ - u32 bootmode = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_MASK) >> - MAIN_DEVSTAT_PRIMARY_BOOTMODE_SHIFT; - u32 bootmode_cfg = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_MASK) >> - MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_SHIFT; - - switch (bootmode) { - case BOOT_DEVICE_OSPI: - fallthrough; - case BOOT_DEVICE_QSPI: - fallthrough; - case BOOT_DEVICE_XSPI: - fallthrough; - case BOOT_DEVICE_SPI: - return BOOT_DEVICE_SPI; - - case BOOT_DEVICE_ETHERNET_RGMII: - fallthrough; - case BOOT_DEVICE_ETHERNET_RMII: - return BOOT_DEVICE_ETHERNET; - - case BOOT_DEVICE_EMMC: - return BOOT_DEVICE_MMC1; - - case BOOT_DEVICE_MMC: - if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_MMC_PORT_MASK) >> - MAIN_DEVSTAT_PRIMARY_MMC_PORT_SHIFT) - return BOOT_DEVICE_MMC2; - return BOOT_DEVICE_MMC1; - - case BOOT_DEVICE_DFU: - if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_USB_MODE_MASK) >> - MAIN_DEVSTAT_PRIMARY_USB_MODE_SHIFT) - return BOOT_DEVICE_USB; - return BOOT_DEVICE_DFU; - - case BOOT_DEVICE_NOBOOT: - return BOOT_DEVICE_RAM; - } - - return bootmode; -} - u32 spl_boot_device(void) { - u32 devstat = readl(CTRLMMR_MAIN_DEVSTAT); - u32 bootmedia; - - if (bootindex == K3_PRIMARY_BOOTMODE) - bootmedia = __get_primary_bootmedia(devstat); - else - bootmedia = __get_backup_bootmedia(devstat); - - debug("am625_init: %s: devstat = 0x%x bootmedia = 0x%x bootindex = %d\n", - __func__, devstat, bootmedia, bootindex); - - return bootmedia; + return get_boot_device(); } diff --git a/arch/arm/mach-k3/am62x/Makefile b/arch/arm/mach-k3/am62x/Makefile new file mode 100644 index 00000000000..acf09c3426c --- /dev/null +++ b/arch/arm/mach-k3/am62x/Makefile @@ -0,0 +1,2 @@ +# SPDX-License-Identifier: GPL-2.0+ +obj-y += boot.o diff --git a/arch/arm/mach-k3/am62x/boot.c b/arch/arm/mach-k3/am62x/boot.c new file mode 100644 index 00000000000..132b42f7edb --- /dev/null +++ b/arch/arm/mach-k3/am62x/boot.c @@ -0,0 +1,103 @@ +// SPDX-License-Identifier: GPL-2.0+ +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <asm/arch/am62_spl.h> + +static u32 __get_backup_bootmedia(u32 devstat) +{ + u32 bkup_bootmode = (devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_MASK) >> + MAIN_DEVSTAT_BACKUP_BOOTMODE_SHIFT; + u32 bkup_bootmode_cfg = + (devstat & MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_MASK) >> + MAIN_DEVSTAT_BACKUP_BOOTMODE_CFG_SHIFT; + + switch (bkup_bootmode) { + case BACKUP_BOOT_DEVICE_UART: + return BOOT_DEVICE_UART; + + case BACKUP_BOOT_DEVICE_USB: + return BOOT_DEVICE_USB; + + case BACKUP_BOOT_DEVICE_ETHERNET: + return BOOT_DEVICE_ETHERNET; + + case BACKUP_BOOT_DEVICE_MMC: + if (bkup_bootmode_cfg) + return BOOT_DEVICE_MMC2; + return BOOT_DEVICE_MMC1; + + case BACKUP_BOOT_DEVICE_SPI: + return BOOT_DEVICE_SPI; + + case BACKUP_BOOT_DEVICE_I2C: + return BOOT_DEVICE_I2C; + + case BACKUP_BOOT_DEVICE_DFU: + if (bkup_bootmode_cfg & MAIN_DEVSTAT_BACKUP_USB_MODE_MASK) + return BOOT_DEVICE_USB; + return BOOT_DEVICE_DFU; + }; + + return BOOT_DEVICE_RAM; +} + +static u32 __get_primary_bootmedia(u32 devstat) +{ + u32 bootmode = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_MASK) >> + MAIN_DEVSTAT_PRIMARY_BOOTMODE_SHIFT; + u32 bootmode_cfg = (devstat & MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_MASK) >> + MAIN_DEVSTAT_PRIMARY_BOOTMODE_CFG_SHIFT; + + switch (bootmode) { + case BOOT_DEVICE_OSPI: + fallthrough; + case BOOT_DEVICE_QSPI: + fallthrough; + case BOOT_DEVICE_XSPI: + fallthrough; + case BOOT_DEVICE_SPI: + return BOOT_DEVICE_SPI; + + case BOOT_DEVICE_ETHERNET_RGMII: + fallthrough; + case BOOT_DEVICE_ETHERNET_RMII: + return BOOT_DEVICE_ETHERNET; + + case BOOT_DEVICE_EMMC: + return BOOT_DEVICE_MMC1; + + case BOOT_DEVICE_MMC: + if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_MMC_PORT_MASK) >> + MAIN_DEVSTAT_PRIMARY_MMC_PORT_SHIFT) + return BOOT_DEVICE_MMC2; + return BOOT_DEVICE_MMC1; + + case BOOT_DEVICE_DFU: + if ((bootmode_cfg & MAIN_DEVSTAT_PRIMARY_USB_MODE_MASK) >> + MAIN_DEVSTAT_PRIMARY_USB_MODE_SHIFT) + return BOOT_DEVICE_USB; + return BOOT_DEVICE_DFU; + + case BOOT_DEVICE_NOBOOT: + return BOOT_DEVICE_RAM; + } + + return bootmode; +} + +u32 get_boot_device(void) +{ + u32 devstat = readl(CTRLMMR_MAIN_DEVSTAT); + u32 bootmode = *(u32 *)(K3_BOOT_PARAM_TABLE_INDEX_OCRAM); + u32 bootmedia; + + if (bootmode == K3_PRIMARY_BOOTMODE) + bootmedia = __get_primary_bootmedia(devstat); + else + bootmedia = __get_backup_bootmedia(devstat); + + debug("%s: devstat = 0x%x bootmedia = 0x%x bootmode = %d\n", + __func__, devstat, bootmedia, bootmode); + + return bootmedia; +} diff --git a/arch/arm/mach-k3/include/mach/hardware.h b/arch/arm/mach-k3/include/mach/hardware.h index 52ef82e70b0..81a8c612f3c 100644 --- a/arch/arm/mach-k3/include/mach/hardware.h +++ b/arch/arm/mach-k3/include/mach/hardware.h @@ -96,4 +96,5 @@ struct rom_extended_boot_data { u32 num_components; };
+u32 get_boot_device(void); #endif /* _ASM_ARCH_HARDWARE_H_ */
Select environment location based on the device we boot from. Also, introduce a "boot" variable that represents the current boot device and can be used by scripts.
Signed-off-by: Wadim Egorov w.egorov@phytec.de --- board/phytec/phycore_am62x/phycore-am62x.c | 64 ++++++++++++++++++++++ configs/phycore_am62x_a53_defconfig | 1 + 2 files changed, 65 insertions(+)
diff --git a/board/phytec/phycore_am62x/phycore-am62x.c b/board/phytec/phycore_am62x/phycore-am62x.c index 91a24018c40..618b4c370d1 100644 --- a/board/phytec/phycore_am62x/phycore-am62x.c +++ b/board/phytec/phycore_am62x/phycore-am62x.c @@ -57,3 +57,67 @@ void spl_board_init(void) MCU_CTRL_DEVICE_CLKOUT_32K_CTRL); } #endif + +#if IS_ENABLED(CONFIG_ENV_IS_IN_FAT) || IS_ENABLED(CONFIG_ENV_IS_IN_MMC) +int mmc_get_env_dev(void) +{ + u32 boot_device = get_boot_device(); + + switch (boot_device) { + case BOOT_DEVICE_MMC1: + return 0; + case BOOT_DEVICE_MMC2: + return 1; + }; + + return CONFIG_SYS_MMC_ENV_DEV; +} +#endif + +enum env_location env_get_location(enum env_operation op, int prio) +{ + u32 boot_device = get_boot_device(); + + if (prio) + return ENVL_UNKNOWN; + + switch (boot_device) { + case BOOT_DEVICE_MMC1: + case BOOT_DEVICE_MMC2: + if (CONFIG_IS_ENABLED(ENV_IS_IN_FAT)) + return ENVL_FAT; + if (CONFIG_IS_ENABLED(ENV_IS_IN_MMC)) + return ENVL_MMC; + case BOOT_DEVICE_SPI: + if (CONFIG_IS_ENABLED(ENV_IS_IN_SPI_FLASH)) + return ENVL_SPI_FLASH; + default: + return ENVL_NOWHERE; + }; +} + +#if IS_ENABLED(CONFIG_BOARD_LATE_INIT) +int board_late_init(void) +{ + u32 boot_device = get_boot_device(); + + switch (boot_device) { + case BOOT_DEVICE_MMC1: + env_set_ulong("mmcdev", 0); + env_set("boot", "mmc"); + break; + case BOOT_DEVICE_MMC2: + env_set_ulong("mmcdev", 1); + env_set("boot", "mmc"); + break; + case BOOT_DEVICE_SPI: + env_set("boot", "spi"); + break; + case BOOT_DEVICE_ETHERNET: + env_set("boot", "net"); + break; + }; + + return 0; +} +#endif diff --git a/configs/phycore_am62x_a53_defconfig b/configs/phycore_am62x_a53_defconfig index ef6d08591a2..8e6f1786d81 100644 --- a/configs/phycore_am62x_a53_defconfig +++ b/configs/phycore_am62x_a53_defconfig @@ -34,6 +34,7 @@ CONFIG_BOOTSTD_FULL=y CONFIG_SYS_BOOTM_LEN=0x800000 CONFIG_BOOTCOMMAND="run mmcboot; bootflow scan -lb" CONFIG_DEFAULT_FDT_FILE="oftree" +CONFIG_BOARD_LATE_INIT=y CONFIG_SPL_MAX_SIZE=0x58000 CONFIG_SPL_HAS_BSS_LINKER_SECTION=y CONFIG_SPL_BSS_START_ADDR=0x80c80000
Applied to u-boot/master now (but I seem to have missed this in b4 ty), thanks.
Wadim Egorov
