[U-Boot] [PATCH] imx: mx6q: add aipstz init for off platform periph
Init peripheral access control register of AIPSTZ OPACRx:
Buffer Writes(BW): 0 -> not bufferable, Supervisor Protect(SP): 0 -> not require supervisor privilege level for accesses. Write Protect(WP): 0 -> allows write accesses. Trusted Protect(TP): 0 -> allows unstrusted master
Signed-off-by: Jason Liu jason.hui@linaro.org Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/armv7/mx6/soc.c | 29 +++++++++++++++++++++++------ arch/arm/include/asm/arch-mx6/imx-regs.h | 11 +++++++++++ 2 files changed, 34 insertions(+), 6 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index bd59cf5..bec53cd 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -40,18 +40,35 @@ u32 get_cpu_rev(void) #ifdef CONFIG_ARCH_CPU_INIT void init_aips(void) { - u32 reg = AIPS1_BASE_ADDR; + struct aipstz_regs *aips1, *aips2; + + aips1 = (struct aipstz_regs *)AIPS1_BASE_ADDR; + aips2 = (struct aipstz_regs *)AIPS2_BASE_ADDR;
/* * Set all MPROTx to be non-bufferable, trusted for R/W, * not forced to user-mode. */ - writel(0x77777777, reg + 0x00); - writel(0x77777777, reg + 0x04); + writel(0x77777777, &aips1->mprot0); + writel(0x77777777, &aips1->mprot1); + writel(0x77777777, &aips2->mprot0); + writel(0x77777777, &aips2->mprot1);
- reg = AIPS2_BASE_ADDR; - writel(0x77777777, reg + 0x00); - writel(0x77777777, reg + 0x04); + /* + * Set all OPACRx to be non-bufferable, not require + * supervisor privilege level for access,allow for + * write access and untrusted master access. + */ + writel(0x00000000, &aips1->opacr0); + writel(0x00000000, &aips1->opacr1); + writel(0x00000000, &aips1->opacr2); + writel(0x00000000, &aips1->opacr3); + writel(0x00000000, &aips1->opacr4); + writel(0x00000000, &aips2->opacr0); + writel(0x00000000, &aips2->opacr1); + writel(0x00000000, &aips2->opacr2); + writel(0x00000000, &aips2->opacr3); + writel(0x00000000, &aips2->opacr4); }
int arch_cpu_init(void) diff --git a/arch/arm/include/asm/arch-mx6/imx-regs.h b/arch/arm/include/asm/arch-mx6/imx-regs.h index 5fe9748..7650cb9 100644 --- a/arch/arm/include/asm/arch-mx6/imx-regs.h +++ b/arch/arm/include/asm/arch-mx6/imx-regs.h @@ -232,5 +232,16 @@ struct fuse_bank4_regs { u32 rsvd3[0x13]; };
+struct aipstz_regs { + u32 mprot0; + u32 mprot1; + u32 rsvd[0xe]; + u32 opacr0; + u32 opacr1; + u32 opacr2; + u32 opacr3; + u32 opacr4; +}; + #endif /* __ASSEMBLER__*/ #endif /* __ASM_ARCH_MX6_IMX_REGS_H__ */
Applied to u-boot-imx, thanks.
Best regards, Stefano Babic
Jason Liu
Stefano Babic
