[U-Boot] [PATCH] omap3/am33xx: mux: fix several checkpatch issues
Fix the following checkpatch issues:
CHECK: No space is necessary after a cast #39: FILE: arch/arm/include/asm/arch-am33xx/mux.h:39: +#define PAD_CTRL_BASE 0x800 +#define OFFSET(x) (unsigned int) (&((struct pad_signals *) \
CHECK: Avoid CamelCase: <CONTROL_PADCONF_JTAG_nTRST> #284: FILE: arch/arm/include/asm/arch-omap3/mux.h:284: +#define CONTROL_PADCONF_JTAG_nTRST 0x0A1C
ERROR: space required after that ',' (ctx:VxV) #446: FILE: arch/arm/include/asm/arch-omap3/mux.h:446: +#define MUX_VAL(OFFSET,VALUE)\ ^ Cc: Raphael Assenat raph@8d.com Cc: Ilya Yanok yanok@emcraft.com Cc: Vaibhav Hiremath hvaibhav@ti.com Cc: Peter Barada peter.barada@logicpd.com Cc: Grazvydas Ignotas notasas@gmail.com Cc: Stefan Roese sr@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Nagendra T S nagendra@mistralsolutions.com Cc: Nishanth Menon nm@ti.com Cc: Tom Rini trini@ti.com Signed-off-by: Igor Grinberg grinberg@compulab.co.il --- Build tested with ./MAKEALL -s omap3 ./MAKEALL -s am33xx Only tricorder and tricorder_flash (which is the same board, but different configurations, I think) have failed with unrelated errors: ld: u-boot-spl section `.data' will not fit in region `.sram' ld: region `.sram' overflowed by 484 bytes
arch/arm/include/asm/arch-am33xx/mux.h | 2 +- arch/arm/include/asm/arch-omap3/mux.h | 4 ++-- board/8dtech/eco5pk/eco5pk.h | 2 +- board/compulab/cm_t35/cm_t35.c | 2 +- board/htkw/mcx/mcx.h | 2 +- board/logicpd/am3517evm/am3517evm.h | 2 +- board/logicpd/omap3som/omap3logic.c | 2 +- board/pandora/pandora.h | 2 +- board/technexion/tao3530/tao3530.h | 2 +- board/technexion/twister/twister.h | 2 +- board/teejet/mt_ventoux/mt_ventoux.h | 2 +- board/ti/am3517crane/am3517crane.h | 2 +- board/ti/evm/evm.h | 2 +- board/ti/sdp3430/sdp.h | 2 +- 14 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/arch/arm/include/asm/arch-am33xx/mux.h b/arch/arm/include/asm/arch-am33xx/mux.h index 3249437..d8bf872 100644 --- a/arch/arm/include/asm/arch-am33xx/mux.h +++ b/arch/arm/include/asm/arch-am33xx/mux.h @@ -36,7 +36,7 @@ struct module_pin_mux {
/* Pad control register offset */ #define PAD_CTRL_BASE 0x800 -#define OFFSET(x) (unsigned int) (&((struct pad_signals *) \ +#define OFFSET(x) (unsigned int) (&((struct pad_signals *)\ (PAD_CTRL_BASE))->x)
/* diff --git a/arch/arm/include/asm/arch-omap3/mux.h b/arch/arm/include/asm/arch-omap3/mux.h index 2f83206..eba4a5c 100644 --- a/arch/arm/include/asm/arch-omap3/mux.h +++ b/arch/arm/include/asm/arch-omap3/mux.h @@ -281,7 +281,7 @@ #define CONTROL_PADCONF_SYS_OFF_MODE 0x0A18 #define CONTROL_PADCONF_SYS_CLKOUT1 0x0A1A #define CONTROL_PADCONF_SYS_CLKOUT2 0x01E2 -#define CONTROL_PADCONF_JTAG_nTRST 0x0A1C +#define CONTROL_PADCONF_JTAG_NTRST 0x0A1C #define CONTROL_PADCONF_JTAG_TCK 0x0A1E #define CONTROL_PADCONF_JTAG_TMS 0x0A20 #define CONTROL_PADCONF_JTAG_TDI 0x0A22 @@ -443,7 +443,7 @@ #define OMAP34XX_CTRL_WKUP_CTRL (OMAP34XX_CTRL_BASE + 0x0A5C) #define OMAP34XX_CTRL_WKUP_CTRL_GPIO_IO_PWRDNZ (1<<6)
-#define MUX_VAL(OFFSET,VALUE)\ +#define MUX_VAL(OFFSET, VALUE)\ writew((VALUE), OMAP34XX_CTRL_BASE + (OFFSET));
#define CP(x) (CONTROL_PADCONF_##x) diff --git a/board/8dtech/eco5pk/eco5pk.h b/board/8dtech/eco5pk/eco5pk.h index a794764..acf2b80 100644 --- a/board/8dtech/eco5pk/eco5pk.h +++ b/board/8dtech/eco5pk/eco5pk.h @@ -332,7 +332,7 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) \ /* JTAG */\ - MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_NTRST), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) \ diff --git a/board/compulab/cm_t35/cm_t35.c b/board/compulab/cm_t35/cm_t35.c index 7f6d12e..9c73264 100644 --- a/board/compulab/cm_t35/cm_t35.c +++ b/board/compulab/cm_t35/cm_t35.c @@ -281,7 +281,7 @@ static void cm_t3x_set_common_muxconf(void) MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)); /*OFF_MODE*/ MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)); /*CLKOUT1*/ MUX_VAL(CP(SYS_CLKOUT2), (IDIS | PTU | DIS | M4)); /*green LED*/ - MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)); /*JTAG_nTRST*/ + MUX_VAL(CP(JTAG_NTRST), (IEN | PTD | DIS | M0)); /*JTAG_NTRST*/ MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)); /*JTAG_TCK*/ MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)); /*JTAG_TMS*/ MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)); /*JTAG_TDI*/ diff --git a/board/htkw/mcx/mcx.h b/board/htkw/mcx/mcx.h index 17c122c..d6c5df2 100644 --- a/board/htkw/mcx/mcx.h +++ b/board/htkw/mcx/mcx.h @@ -339,7 +339,7 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M4))\ MUX_VAL(CP(SYS_CLKOUT2), (IDIS | PTU | DIS | M4))\ /* JTAG */\ - MUX_VAL(CP(JTAG_nTRST), (IEN | PTU | EN | M4)) \ + MUX_VAL(CP(JTAG_NTRST), (IEN | PTU | EN | M4)) \ MUX_VAL(CP(JTAG_TCK), (IEN | PTU | EN | M4)) \ MUX_VAL(CP(JTAG_TMS), (IEN | PTU | EN | M4)) \ MUX_VAL(CP(JTAG_TDI), (IEN | PTU | EN | M4)) \ diff --git a/board/logicpd/am3517evm/am3517evm.h b/board/logicpd/am3517evm/am3517evm.h index d407d66..a6a55ee 100644 --- a/board/logicpd/am3517evm/am3517evm.h +++ b/board/logicpd/am3517evm/am3517evm.h @@ -333,7 +333,7 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) \ /* JTAG */\ - MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_NTRST), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) \ diff --git a/board/logicpd/omap3som/omap3logic.c b/board/logicpd/omap3som/omap3logic.c index 075fe94..1fd9f2c 100644 --- a/board/logicpd/omap3som/omap3logic.c +++ b/board/logicpd/omap3som/omap3logic.c @@ -230,6 +230,6 @@ void set_muxconf_regs(void) MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)); MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)); MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)); - MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)); + MUX_VAL(CP(JTAG_NTRST), (IEN | PTD | DIS | M0)); MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)); } diff --git a/board/pandora/pandora.h b/board/pandora/pandora.h index cbf4186..268b929 100644 --- a/board/pandora/pandora.h +++ b/board/pandora/pandora.h @@ -310,7 +310,7 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(SYS_BOOT6), (IEN | PTD | DIS | M4)) /*GPIO_8*/\ MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) /*SYS_OFF_MODE*/\ /*JTAG*/\ - MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) /*JTAG_nTRST*/\ + MUX_VAL(CP(JTAG_NTRST), (IEN | PTD | DIS | M0)) /*JTAG_NTRST*/\ MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) /*JTAG_TCK*/\ MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) /*JTAG_TMS*/\ MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) /*JTAG_TDI*/\ diff --git a/board/technexion/tao3530/tao3530.h b/board/technexion/tao3530/tao3530.h index daff109..4a94399 100644 --- a/board/technexion/tao3530/tao3530.h +++ b/board/technexion/tao3530/tao3530.h @@ -275,7 +275,7 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) \ - MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_NTRST), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) \ diff --git a/board/technexion/twister/twister.h b/board/technexion/twister/twister.h index 62fbfdf..e286bd4 100644 --- a/board/technexion/twister/twister.h +++ b/board/technexion/twister/twister.h @@ -337,7 +337,7 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) \ /* JTAG */\ - MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_NTRST), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) \ diff --git a/board/teejet/mt_ventoux/mt_ventoux.h b/board/teejet/mt_ventoux/mt_ventoux.h index aba71a8..bc85ad4 100644 --- a/board/teejet/mt_ventoux/mt_ventoux.h +++ b/board/teejet/mt_ventoux/mt_ventoux.h @@ -339,7 +339,7 @@ const omap3_sysinfo sysinfo = { /* gpio_10 */\ MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) \ /* JTAG */\ - MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) \ + MUX_VAL(CP(JTAG_NTRST), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) \ MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) \ diff --git a/board/ti/am3517crane/am3517crane.h b/board/ti/am3517crane/am3517crane.h index e131c8f..6289ca7 100644 --- a/board/ti/am3517crane/am3517crane.h +++ b/board/ti/am3517crane/am3517crane.h @@ -284,7 +284,7 @@ const omap3_sysinfo sysinfo = { MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M4))/*GPIO_10 TP*/\ MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0))\ /*JTAG*/\ - MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_NTRST), (IEN | PTD | DIS | M0))\ MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0))\ MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0))\ MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0))\ diff --git a/board/ti/evm/evm.h b/board/ti/evm/evm.h index f50193d..91e9b88 100644 --- a/board/ti/evm/evm.h +++ b/board/ti/evm/evm.h @@ -300,7 +300,7 @@ static void reset_net_chip(void); MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) /*SYS_OFF_MODE*/\ MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0)) /*SYS_CLKOUT1*/\ MUX_VAL(CP(SYS_CLKOUT2), (IEN | PTU | EN | M0)) /*SYS_CLKOUT2*/\ - MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0)) /*JTAG_nTRST*/\ + MUX_VAL(CP(JTAG_NTRST), (IEN | PTD | DIS | M0)) /*JTAG_NTRST*/\ MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0)) /*JTAG_TCK*/\ MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0)) /*JTAG_TMS*/\ MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0)) /*JTAG_TDI*/\ diff --git a/board/ti/sdp3430/sdp.h b/board/ti/sdp3430/sdp.h index 2acb302..0e63189 100644 --- a/board/ti/sdp3430/sdp.h +++ b/board/ti/sdp3430/sdp.h @@ -265,7 +265,7 @@ MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0))\ MUX_VAL(CP(SYS_CLKOUT1), (IEN | PTD | DIS | M0))\ MUX_VAL(CP(SYS_CLKOUT2), (OFF_IN_PD | IEN | PTU | EN | M4))/*GPIO_186*/\ - MUX_VAL(CP(JTAG_nTRST), (IEN | PTD | DIS | M0))\ + MUX_VAL(CP(JTAG_NTRST), (IEN | PTD | DIS | M0))\ MUX_VAL(CP(JTAG_TCK), (IEN | PTD | DIS | M0))\ MUX_VAL(CP(JTAG_TMS), (IEN | PTD | DIS | M0))\ MUX_VAL(CP(JTAG_TDI), (IEN | PTD | DIS | M0))\
Looks good, so:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
ERROR: space required after that ',' (ctx:VxV) #446: FILE: arch/arm/include/asm/arch-omap3/mux.h:446: +#define MUX_VAL(OFFSET,VALUE)\ ^ Cc: Raphael Assenat raph@8d.com Cc: Ilya Yanok yanok@emcraft.com Cc: Vaibhav Hiremath hvaibhav@ti.com Cc: Peter Barada peter.barada@logicpd.com Cc: Grazvydas Ignotas notasas@gmail.com Cc: Stefan Roese sr@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Nagendra T S nagendra@mistralsolutions.com Cc: Nishanth Menon nm@ti.com Cc: Tom Rini trini@ti.com Signed-off-by: Igor Grinberg grinberg@compulab.co.il Acked-by: Stefan Roese sr@denx.de
Applied to u-boot-ti/master, thanks!
Igor Grinberg
Stefan Roese
