[U-Boot] [PATCH 0/2] spl: Support loading a FIT from SPI
This series makes sure that raw read of fit is dma aligned and supports loading a fit from SPI.
Verified on DRA7-evm.
Lokesh Vutla (2): spl: Make sure destination address is dma aligned when loading fit spl: Support loading a FIT from SPI
common/spl/spl_fit.c | 11 +++++++---- drivers/mtd/spi/spi_spl_load.c | 32 +++++++++++++++++++++++++++++--- 2 files changed, 36 insertions(+), 7 deletions(-)
Peripherals like spi etc. uses DMA for transfers. So, when loading the fit image the destination address should be dma aligned.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- - Assuming u-boot.bin load addr will always be dma aligned.
common/spl/spl_fit.c | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/common/spl/spl_fit.c b/common/spl/spl_fit.c index 4c9fe7b..20396b9 100644 --- a/common/spl/spl_fit.c +++ b/common/spl/spl_fit.c @@ -91,7 +91,7 @@ int spl_load_simple_fit(struct spl_load_info *info, ulong sector, void *fit) void *load_ptr; int fdt_offset, fdt_len; int data_offset, data_size; - int base_offset; + int base_offset, align_len; int src_sector; void *dst;
@@ -117,7 +117,9 @@ int spl_load_simple_fit(struct spl_load_info *info, ulong sector, void *fit) * In fact the FIT has its own load address, but we assume it cannot * be before CONFIG_SYS_TEXT_BASE. */ - fit = (void *)(CONFIG_SYS_TEXT_BASE - size - info->bl_len); + align_len = ARCH_DMA_MINALIGN - 1; + fit = (void *)((CONFIG_SYS_TEXT_BASE - size - info->bl_len - + align_len) & ~align_len); sectors = (size + info->bl_len - 1) / info->bl_len; count = info->read(info, sector, sectors, fit); debug("fit read sector %lx, sectors=%d, dst=%p, count=%lu\n", @@ -173,8 +175,9 @@ int spl_load_simple_fit(struct spl_load_info *info, ulong sector, void *fit) /* * Read the device tree and place it after the image. There may be * some extra data before it since we can only read entire blocks. + * And also align the destination address to ARCH_DMA_MINALIGN. */ - dst = load_ptr + data_size; + dst = (void *)((load + data_size + align_len) & ~align_len); fdt_offset += base_offset; count = info->read(info, sector + fdt_offset / info->bl_len, sectors, dst); @@ -188,7 +191,7 @@ int spl_load_simple_fit(struct spl_load_info *info, ulong sector, void *fit) * After this we will have the U-Boot image and its device tree ready * for us to start. */ - memcpy(dst, dst + fdt_offset % info->bl_len, fdt_len); + memcpy(load_ptr + data_size, dst + fdt_offset % info->bl_len, fdt_len);
return 0; }
After the v5 of my FS support for FIT[1], this patch is no more necessary. Patch 2 is alone sufficient.
[1] http://patchwork.ozlabs.org/patch/618403/
Thanks and regards, Lokesh
- int base_offset;
- int base_offset, align_len; int src_sector; void *dst;
- align_len = ARCH_DMA_MINALIGN - 1;
- fit = (void *)((CONFIG_SYS_TEXT_BASE - size - info->bl_len -
sectors = (size + info->bl_len - 1) / info->bl_len; count = info->read(info, sector, sectors, fit); debug("fit read sector %lx, sectors=%d, dst=%p, count=%lu\n",align_len) & ~align_len);
*/* And also align the destination address to ARCH_DMA_MINALIGN.
- dst = (void *)((load + data_size + align_len) & ~align_len); fdt_offset += base_offset; count = info->read(info, sector + fdt_offset / info->bl_len, sectors, dst);
Thanks. Note that if you register with patchwork you should be able to manage the state of your own patches as well. Thanks!
Sure, Ill register with patchwork.
Detect a FIT when loading from SPI and handle it using the new FIT SPL support.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- drivers/mtd/spi/spi_spl_load.c | 32 +++++++++++++++++++++++++++++--- 1 file changed, 29 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/spi/spi_spl_load.c b/drivers/mtd/spi/spi_spl_load.c index ca56fe9..a255188 100644 --- a/drivers/mtd/spi/spi_spl_load.c +++ b/drivers/mtd/spi/spi_spl_load.c @@ -44,6 +44,18 @@ static int spi_load_image_os(struct spi_flash *flash, } #endif
+static ulong spl_spi_fit_read(struct spl_load_info *load, ulong sector, + ulong count, void *buf) +{ + struct spi_flash *flash = load->dev; + ulong ret; + + ret = spi_flash_read(flash, sector, count, buf); + if (!ret) + return count; + else + return 0; +} /* * The main entry for SPI booting. It's necessary that SDRAM is already * configured and available since this code loads the main U-Boot image @@ -81,9 +93,23 @@ int spl_spi_load_image(void) if (err) return err;
- spl_parse_image_header(header); - err = spi_flash_read(flash, CONFIG_SYS_SPI_U_BOOT_OFFS, - spl_image.size, (void *)spl_image.load_addr); + if (IS_ENABLED(CONFIG_SPL_LOAD_FIT)) { + struct spl_load_info load; + + debug("Found FIT\n"); + load.dev = flash; + load.priv = NULL; + load.bl_len = 1; + load.read = spl_spi_fit_read; + err = spl_load_simple_fit(&load, + CONFIG_SYS_SPI_U_BOOT_OFFS, + header); + } else { + spl_parse_image_header(header); + err = spi_flash_read(flash, CONFIG_SYS_SPI_U_BOOT_OFFS, + spl_image.size, + (void *)spl_image.load_addr); + } }
return err;
Lokesh Vutla
