[PATCH] arm: dts; am625_beagleplay: Switch to OF_UPSTREAM
Enable OF_UPSTREAM for AM625-beagleplay board. Remove DT files that are now available in dts/upstream. Update the appended files based on version of latest OF_UPSTREAM sync point (v6.10-rc1).
Signed-off-by: Nishanth Menon nm@ti.com ---
Based off u-boot next 15d0dcc0ec1f Merge tag 'u-boot-imx-next-20240603' of https://gitlab.denx.de/u-boot/custodians/u-boot-imx into next
bootph properties are in sync, so nothing much to do there.
arch/arm/dts/Makefile | 1 - arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 4 +- arch/arm/dts/k3-am625-beagleplay.dts | 932 ------------------- configs/am62x_beagleplay_a53_defconfig | 3 +- 4 files changed, 4 insertions(+), 936 deletions(-) delete mode 100644 arch/arm/dts/k3-am625-beagleplay.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index cd7fcb3a3e6d..8461c70ff093 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1207,7 +1207,6 @@ dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-r5-evm.dtb \
dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-sk.dtb \ k3-am625-r5-sk.dtb \ - k3-am625-beagleplay.dtb \ k3-am625-r5-beagleplay.dtb \ k3-am625-verdin-r5.dtb \ k3-am625-r5-phycore-som-2gb.dtb diff --git a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi index 9ac4a825f841..dd5b335ed2ee 100644 --- a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi @@ -66,9 +66,9 @@ #ifdef CONFIG_TARGET_AM625_A53_BEAGLEPLAY
#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" -#define SPL_AM625_BEAGLEPLAY_DTB "spl/dts/k3-am625-beagleplay.dtb" +#define SPL_AM625_BEAGLEPLAY_DTB "spl/dts/ti/k3-am625-beagleplay.dtb" #define UBOOT_NODTB "u-boot-nodtb.bin" -#define AM625_BEAGLEPLAY_DTB "arch/arm/dts/k3-am625-beagleplay.dtb" +#define AM625_BEAGLEPLAY_DTB "dts/upstream/src/arm64/ti/k3-am625-beagleplay.dtb"
&binman { ti-dm { diff --git a/arch/arm/dts/k3-am625-beagleplay.dts b/arch/arm/dts/k3-am625-beagleplay.dts deleted file mode 100644 index 8ab838f1697c..000000000000 --- a/arch/arm/dts/k3-am625-beagleplay.dts +++ /dev/null @@ -1,932 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * https://beagleplay.org/ - * - * Copyright (C) 2022-2024 Texas Instruments Incorporated - https://www.ti.com/ - * Copyright (C) 2022-2024 Robert Nelson, BeagleBoard.org Foundation - */ - -/dts-v1/; - -#include <dt-bindings/leds/common.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include "k3-am625.dtsi" - -/ { - compatible = "beagle,am625-beagleplay", "ti,am625"; - model = "BeagleBoard.org BeaglePlay"; - - aliases { - ethernet0 = &cpsw_port1; - ethernet1 = &cpsw_port2; - gpio0 = &main_gpio0; - gpio1 = &main_gpio1; - gpio2 = &mcu_gpio0; - i2c0 = &main_i2c0; - i2c1 = &main_i2c1; - i2c2 = &main_i2c2; - i2c3 = &main_i2c3; - i2c4 = &wkup_i2c0; - i2c5 = &mcu_i2c0; - mmc0 = &sdhci0; - mmc1 = &sdhci1; - mmc2 = &sdhci2; - rtc0 = &rtc; - serial0 = &main_uart5; - serial1 = &main_uart6; - serial2 = &main_uart0; - usb0 = &usb0; - usb1 = &usb1; - }; - - chosen { - stdout-path = "serial2:115200n8"; - }; - - memory@80000000 { - bootph-pre-ram; - device_type = "memory"; - /* 2G RAM */ - reg = <0x00000000 0x80000000 0x00000000 0x80000000>; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - ramoops: ramoops@9ca00000 { - compatible = "ramoops"; - reg = <0x00 0x9ca00000 0x00 0x00100000>; - record-size = <0x8000>; - console-size = <0x8000>; - ftrace-size = <0x00>; - pmsg-size = <0x8000>; - }; - - secure_tfa_ddr: tfa@9e780000 { - reg = <0x00 0x9e780000 0x00 0x80000>; - no-map; - }; - - secure_ddr: optee@9e800000 { - reg = <0x00 0x9e800000 0x00 0x01800000>; - no-map; - }; - - wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 { - compatible = "shared-dma-pool"; - reg = <0x00 0x9db00000 0x00 0xc00000>; - no-map; - }; - }; - - vsys_5v0: regulator-1 { - bootph-all; - compatible = "regulator-fixed"; - regulator-name = "vsys_5v0"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - vdd_3v3: regulator-2 { - /* output of TLV62595DMQR-U12 */ - bootph-all; - compatible = "regulator-fixed"; - regulator-name = "vdd_3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vsys_5v0>; - regulator-always-on; - regulator-boot-on; - }; - - wlan_en: regulator-3 { - /* OUTPUT of SN74AVC2T244DQMR */ - compatible = "regulator-fixed"; - regulator-name = "wlan_en"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - enable-active-high; - regulator-always-on; - vin-supply = <&vdd_3v3>; - gpio = <&main_gpio0 38 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_en_pins_default>; - }; - - vdd_3v3_sd: regulator-4 { - /* output of TPS22918DBVR-U21 */ - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&vdd_3v3_sd_pins_default>; - - compatible = "regulator-fixed"; - regulator-name = "vdd_3v3_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - enable-active-high; - regulator-always-on; - vin-supply = <&vdd_3v3>; - gpio = <&main_gpio1 19 GPIO_ACTIVE_HIGH>; - }; - - vdd_sd_dv: regulator-5 { - bootph-all; - compatible = "regulator-gpio"; - regulator-name = "sd_hs200_switch"; - pinctrl-names = "default"; - pinctrl-0 = <&vdd_sd_dv_pins_default>; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - vin-supply = <&ldo1_reg>; - gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>; - states = <1800000 0x0>, - <3300000 0x1>; - }; - - leds { - bootph-all; - compatible = "gpio-leds"; - - led-0 { - bootph-all; - gpios = <&main_gpio0 3 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - function = LED_FUNCTION_HEARTBEAT; - default-state = "off"; - }; - - led-1 { - bootph-all; - gpios = <&main_gpio0 4 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "disk-activity"; - function = LED_FUNCTION_DISK_ACTIVITY; - default-state = "keep"; - }; - - led-2 { - bootph-all; - gpios = <&main_gpio0 5 GPIO_ACTIVE_HIGH>; - function = LED_FUNCTION_CPU; - }; - - led-3 { - bootph-all; - gpios = <&main_gpio0 6 GPIO_ACTIVE_HIGH>; - function = LED_FUNCTION_LAN; - }; - - led-4 { - bootph-all; - gpios = <&main_gpio0 9 GPIO_ACTIVE_HIGH>; - function = LED_FUNCTION_WLAN; - }; - }; - - gpio_keys: gpio-keys { - compatible = "gpio-keys"; - autorepeat; - pinctrl-names = "default"; - pinctrl-0 = <&usr_button_pins_default>; - - usr: button-usr { - label = "User Key"; - linux,code = <BTN_0>; - gpios = <&main_gpio0 18 GPIO_ACTIVE_LOW>; - }; - - }; - - hdmi0: connector-hdmi { - compatible = "hdmi-connector"; - label = "hdmi"; - type = "a"; - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&it66121_out>; - }; - }; - }; - - sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "it66121 HDMI"; - simple-audio-card,format = "i2s"; - simple-audio-card,bitclock-master = <&hdmi_dailink_master>; - simple-audio-card,frame-master = <&hdmi_dailink_master>; - - hdmi_dailink_master: simple-audio-card,cpu { - sound-dai = <&mcasp1>; - system-clock-direction-out; - }; - - simple-audio-card,codec { - sound-dai = <&it66121>; - }; - }; - -}; - -&main_pmx0 { - gpio0_pins_default: gpio0-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x0004, PIN_INPUT, 7) /* (G25) OSPI0_LBCLKO.GPIO0_1 */ - AM62X_IOPAD(0x0008, PIN_INPUT, 7) /* (J24) OSPI0_DQS.GPIO0_2 */ - AM62X_IOPAD(0x000c, PIN_INPUT, 7) /* (E25) OSPI0_D0.GPIO0_3 */ - AM62X_IOPAD(0x0010, PIN_INPUT, 7) /* (G24) OSPI0_D1.GPIO0_4 */ - AM62X_IOPAD(0x0014, PIN_INPUT, 7) /* (F25) OSPI0_D2.GPIO0_5 */ - AM62X_IOPAD(0x0018, PIN_INPUT, 7) /* (F24) OSPI0_D3.GPIO0_6 */ - AM62X_IOPAD(0x0024, PIN_INPUT, 7) /* (H25) OSPI0_D6.GPIO0_9 */ - AM62X_IOPAD(0x0028, PIN_INPUT, 7) /* (J22) OSPI0_D7.GPIO0_10 */ - AM62X_IOPAD(0x002c, PIN_INPUT, 7) /* (F23) OSPI0_CSn0.GPIO0_11 */ - AM62X_IOPAD(0x0030, PIN_INPUT, 7) /* (G21) OSPI0_CSn1.GPIO0_12 */ - AM62X_IOPAD(0x0034, PIN_INPUT, 7) /* (H21) OSPI0_CSn2.GPIO0_13 */ - AM62X_IOPAD(0x0038, PIN_INPUT, 7) /* (E24) OSPI0_CSn3.GPIO0_14 */ - AM62X_IOPAD(0x00a4, PIN_INPUT, 7) /* (M22) GPMC0_DIR.GPIO0_40 */ - AM62X_IOPAD(0x00ac, PIN_INPUT, 7) /* (L21) GPMC0_CSn1.GPIO0_42 */ - >; - }; - - vdd_sd_dv_pins_default: vdd-sd-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x0244, PIN_OUTPUT, 7) /* (C17) MMC1_SDWP.GPIO1_49 */ - >; - }; - - usr_button_pins_default: usr-button-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0048, PIN_INPUT, 7) /* (N25) GPMC0_AD3.GPIO0_18 */ - >; - }; - - grove_pins_default: grove-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */ - AM62X_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */ - >; - }; - - local_i2c_pins_default: local-i2c-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */ - AM62X_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */ - >; - }; - - i2c2_1v8_pins_default: i2c2-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x00b0, PIN_INPUT_PULLUP, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */ - AM62X_IOPAD(0x00b4, PIN_INPUT_PULLUP, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */ - >; - }; - - mdio0_pins_default: mdio0-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0160, PIN_OUTPUT, 0) /* (AD24) MDIO0_MDC */ - AM62X_IOPAD(0x015c, PIN_INPUT, 0) /* (AB22) MDIO0_MDIO */ - AM62X_IOPAD(0x003c, PIN_INPUT, 7) /* (M25) GPMC0_AD0.GPIO0_15 */ - AM62X_IOPAD(0x018c, PIN_INPUT, 7) /* (AC21) RGMII2_RD2.GPIO1_5 */ - >; - }; - - rgmii1_pins_default: rgmii1-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x014c, PIN_INPUT, 0) /* (AB17) RGMII1_RD0 */ - AM62X_IOPAD(0x0150, PIN_INPUT, 0) /* (AC17) RGMII1_RD1 */ - AM62X_IOPAD(0x0154, PIN_INPUT, 0) /* (AB16) RGMII1_RD2 */ - AM62X_IOPAD(0x0158, PIN_INPUT, 0) /* (AA15) RGMII1_RD3 */ - AM62X_IOPAD(0x0148, PIN_INPUT, 0) /* (AD17) RGMII1_RXC */ - AM62X_IOPAD(0x0144, PIN_INPUT, 0) /* (AE17) RGMII1_RX_CTL */ - AM62X_IOPAD(0x0134, PIN_OUTPUT, 0) /* (AE20) RGMII1_TD0 */ - AM62X_IOPAD(0x0138, PIN_OUTPUT, 0) /* (AD20) RGMII1_TD1 */ - AM62X_IOPAD(0x013c, PIN_OUTPUT, 0) /* (AE18) RGMII1_TD2 */ - AM62X_IOPAD(0x0140, PIN_OUTPUT, 0) /* (AD18) RGMII1_TD3 */ - AM62X_IOPAD(0x0130, PIN_OUTPUT, 0) /* (AE19) RGMII1_TXC */ - AM62X_IOPAD(0x012c, PIN_OUTPUT, 0) /* (AD19) RGMII1_TX_CTL */ - >; - }; - - emmc_pins_default: emmc-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x0220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */ - AM62X_IOPAD(0x0218, PIN_INPUT, 0) /* (AB1) MMC0_CLK */ - AM62X_IOPAD(0x0214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */ - AM62X_IOPAD(0x0210, PIN_INPUT, 0) /* (AA1) MMC0_DAT1 */ - AM62X_IOPAD(0x020c, PIN_INPUT, 0) /* (AA3) MMC0_DAT2 */ - AM62X_IOPAD(0x0208, PIN_INPUT, 0) /* (Y4) MMC0_DAT3 */ - AM62X_IOPAD(0x0204, PIN_INPUT, 0) /* (AB2) MMC0_DAT4 */ - AM62X_IOPAD(0x0200, PIN_INPUT, 0) /* (AC1) MMC0_DAT5 */ - AM62X_IOPAD(0x01fc, PIN_INPUT, 0) /* (AD2) MMC0_DAT6 */ - AM62X_IOPAD(0x01f8, PIN_INPUT, 0) /* (AC2) MMC0_DAT7 */ - >; - }; - - vdd_3v3_sd_pins_default: vdd-3v3-sd-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x01c4, PIN_INPUT, 7) /* (B14) SPI0_D1_GPIO1_19 */ - >; - }; - - sd_pins_default: sd-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x023c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ - AM62X_IOPAD(0x0234, PIN_INPUT, 0) /* (B22) MMC1_CLK */ - AM62X_IOPAD(0x0230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */ - AM62X_IOPAD(0x022c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */ - AM62X_IOPAD(0x0228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */ - AM62X_IOPAD(0x0224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */ - AM62X_IOPAD(0x0240, PIN_INPUT, 7) /* (D17) MMC1_SDCD.GPIO1_48 */ - >; - }; - - wifi_pins_default: wifi-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0120, PIN_INPUT, 0) /* (C24) MMC2_CMD */ - AM62X_IOPAD(0x0118, PIN_INPUT, 0) /* (D25) MMC2_CLK */ - AM62X_IOPAD(0x0114, PIN_INPUT, 0) /* (B24) MMC2_DAT0 */ - AM62X_IOPAD(0x0110, PIN_INPUT, 0) /* (C25) MMC2_DAT1 */ - AM62X_IOPAD(0x010c, PIN_INPUT, 0) /* (E23) MMC2_DAT2 */ - AM62X_IOPAD(0x0108, PIN_INPUT, 0) /* (D24) MMC2_DAT3 */ - AM62X_IOPAD(0x0124, PIN_INPUT, 0) /* (A23) MMC2_SDCD */ - AM62X_IOPAD(0x11c, PIN_INPUT, 0) /* (#N/A) MMC2_CLKB */ - >; - }; - - wifi_en_pins_default: wifi-en-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x009c, PIN_OUTPUT, 7) /* (V25) GPMC0_WAIT1.GPIO0_38 */ - >; - }; - - wifi_wlirq_pins_default: wifi-wlirq-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x00a8, PIN_INPUT, 7) /* (M21) GPMC0_CSn0.GPIO0_41 */ - >; - }; - - spe_pins_default: spe-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0168, PIN_INPUT, 1) /* (AE21) RGMII2_TXC.RMII2_CRS_DV */ - AM62X_IOPAD(0x0180, PIN_INPUT, 1) /* (AD23) RGMII2_RXC.RMII2_REF_CLK */ - AM62X_IOPAD(0x0184, PIN_INPUT, 1) /* (AE23) RGMII2_RD0.RMII2_RXD0 */ - AM62X_IOPAD(0x0188, PIN_INPUT, 1) /* (AB20) RGMII2_RD1.RMII2_RXD1 */ - AM62X_IOPAD(0x017c, PIN_INPUT, 1) /* (AD22) RGMII2_RX_CTL.RMII2_RX_ER */ - AM62X_IOPAD(0x016c, PIN_INPUT, 1) /* (Y18) RGMII2_TD0.RMII2_TXD0 */ - AM62X_IOPAD(0x0170, PIN_INPUT, 1) /* (AA18) RGMII2_TD1.RMII2_TXD1 */ - AM62X_IOPAD(0x0164, PIN_INPUT, 1) /* (AA19) RGMII2_TX_CTL.RMII2_TX_EN */ - AM62X_IOPAD(0x0190, PIN_INPUT, 7) /* (AE22) RGMII2_RD3.GPIO1_6 */ - AM62X_IOPAD(0x01f0, PIN_OUTPUT, 5) /* (A18) EXT_REFCLK1.CLKOUT0 */ - >; - }; - - mikrobus_i2c_pins_default: mikrobus-i2c-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x01d0, PIN_INPUT_PULLUP, 2) /* (A15) UART0_CTSn.I2C3_SCL */ - AM62X_IOPAD(0x01d4, PIN_INPUT_PULLUP, 2) /* (B15) UART0_RTSn.I2C3_SDA */ - >; - }; - - mikrobus_uart_pins_default: mikrobus-uart-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x01d8, PIN_INPUT, 1) /* (C15) MCAN0_TX.UART5_RXD */ - AM62X_IOPAD(0x01dc, PIN_OUTPUT, 1) /* (E15) MCAN0_RX.UART5_TXD */ - >; - }; - - mikrobus_spi_pins_default: mikrobus-spi-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x01b0, PIN_INPUT, 1) /* (A20) MCASP0_ACLKR.SPI2_CLK */ - AM62X_IOPAD(0x01ac, PIN_INPUT, 1) /* (E19) MCASP0_AFSR.SPI2_CS0 */ - AM62X_IOPAD(0x0194, PIN_INPUT, 1) /* (B19) MCASP0_AXR3.SPI2_D0 */ - AM62X_IOPAD(0x0198, PIN_INPUT, 1) /* (A19) MCASP0_AXR2.SPI2_D1 */ - >; - }; - - mikrobus_gpio_pins_default: mikrobus-gpio-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x019c, PIN_INPUT, 7) /* (B18) MCASP0_AXR1.GPIO1_9 */ - AM62X_IOPAD(0x01a0, PIN_INPUT, 7) /* (E18) MCASP0_AXR0.GPIO1_10 */ - AM62X_IOPAD(0x01a8, PIN_INPUT, 7) /* (D20) MCASP0_AFSX.GPIO1_12 */ - >; - }; - - main_uart0_pins_default: main-uart0-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x01c8, PIN_INPUT, 0) /* (D14) UART0_RXD */ - AM62X_IOPAD(0x01cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */ - >; - }; - - wifi_debug_uart_pins_default: wifi-debug-uart-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x001c, PIN_INPUT, 3) /* (J23) OSPI0_D4.UART6_RXD */ - AM62X_IOPAD(0x0020, PIN_OUTPUT, 3) /* (J25) OSPI0_D5.UART6_TXD */ - >; - }; - - usb1_pins_default: usb1-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0258, PIN_INPUT, 0) /* (F18) USB1_DRVVBUS */ - >; - }; - - pmic_irq_pins_default: pmic-irq-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x01f4, PIN_INPUT_PULLUP, 0) /* (D16) EXTINTn */ - >; - }; - - hdmi_gpio_pins_default: hdmi-gpio-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0094, PIN_INPUT_PULLUP | PIN_DEBOUNCE_CONF6, 7) /* (N20) GPMC0_BE1n.GPIO0_36 */ - AM62X_IOPAD(0x0054, PIN_OUTPUT_PULLUP, 7) /* (P21) GPMC0_AD6.GPIO0_21 */ - >; - }; - - mcasp_hdmi_pins_default: mcasp-hdmi-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0090, PIN_INPUT, 2) /* (M24) GPMC0_BE0n_CLE.MCASP1_ACLKX */ - AM62X_IOPAD(0x0098, PIN_INPUT, 2) /* (U23) GPMC0_WAIT0.MCASP1_AFSX */ - AM62X_IOPAD(0x008c, PIN_OUTPUT, 2) /* (L25) GPMC0_WEn.MCASP1_AXR0 */ - AM62X_IOPAD(0x0088, PIN_INPUT, 2) /* (L24) GPMC0_OEn_REn.MCASP1_AXR1 */ - AM62X_IOPAD(0x0084, PIN_INPUT, 2) /* (L23) GPMC0_ADVn_ALE.MCASP1_AXR2 */ - AM62X_IOPAD(0x007c, PIN_INPUT, 2) /* (P25) GPMC0_CLK.MCASP1_AXR3 */ - >; - }; - - dss0_pins_default: dss0-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AC25) VOUT0_VSYNC */ - AM62X_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */ - AM62X_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC24) VOUT0_PCLK */ - AM62X_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (Y20) VOUT0_DE */ - AM62X_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */ - AM62X_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (V24) VOUT0_DATA1 */ - AM62X_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA2 */ - AM62X_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA3 */ - AM62X_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (Y25) VOUT0_DATA4 */ - AM62X_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (Y24) VOUT0_DATA5 */ - AM62X_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA6 */ - AM62X_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA7 */ - AM62X_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA8 */ - AM62X_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA9 */ - AM62X_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (V20) VOUT0_DATA10 */ - AM62X_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA11 */ - AM62X_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA12 */ - AM62X_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA13 */ - AM62X_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA14 */ - AM62X_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AA21) VOUT0_DATA15 */ - AM62X_IOPAD(0x005c, PIN_OUTPUT, 1) /* (R24) GPMC0_AD8.VOUT0_DATA16 */ - AM62X_IOPAD(0x0060, PIN_OUTPUT, 1) /* (R25) GPMC0_AD9.VOUT0_DATA17 */ - AM62X_IOPAD(0x0064, PIN_OUTPUT, 1) /* (T25) GPMC0_AD10.VOUT0_DATA18 */ - AM62X_IOPAD(0x0068, PIN_OUTPUT, 1) /* (R21) GPMC0_AD11.VOUT0_DATA19 */ - AM62X_IOPAD(0x006c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */ - AM62X_IOPAD(0x0070, PIN_OUTPUT, 1) /* (T24) GPMC0_AD13.VOUT0_DATA21 */ - AM62X_IOPAD(0x0074, PIN_OUTPUT, 1) /* (U25) GPMC0_AD14.VOUT0_DATA22 */ - AM62X_IOPAD(0x0078, PIN_OUTPUT, 1) /* (U24) GPMC0_AD15.VOUT0_DATA23 */ - >; - }; -}; - -&mcu_pmx0 { - i2c_qwiic_pins_default: i2c-qwiic-default-pins { - pinctrl-single,pins = < - AM62X_MCU_IOPAD(0x0044, PIN_INPUT, 0) /* (A8) MCU_I2C0_SCL */ - AM62X_MCU_IOPAD(0x0048, PIN_INPUT, 0) /* (D10) MCU_I2C0_SDA */ - >; - }; - - gbe_pmx_obsclk: gbe-pmx-obsclk-default-pins { - pinctrl-single,pins = < - AM62X_MCU_IOPAD(0x0004, PIN_OUTPUT, 1) /* (B8) MCU_SPI0_CS1.MCU_OBSCLK0 */ - >; - }; - - i2c_csi_pins_default: i2c-csi-default-pins { - pinctrl-single,pins = < - AM62X_MCU_IOPAD(0x004c, PIN_INPUT_PULLUP, 0) /* (B9) WKUP_I2C0_SCL */ - AM62X_MCU_IOPAD(0x0050, PIN_INPUT_PULLUP, 0) /* (A9) WKUP_I2C0_SDA */ - >; - }; - - wifi_32k_clk: mcu-clk-out-default-pins { - pinctrl-single,pins = < - AM62X_MCU_IOPAD(0x0084, PIN_OUTPUT, 0) /* (A12) WKUP_CLKOUT0 */ - >; - }; -}; - -&a53_opp_table { - /* Requires VDD_CORE to be at 0.85V */ - opp-1400000000 { - opp-hz = /bits/ 64 <1400000000>; - opp-supported-hw = <0x01 0x0004>; - }; -}; - -&wkup_i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c_csi_pins_default>; - clock-frequency = <400000>; - /* Enable with overlay for camera sensor */ -}; - -&mcu_i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c_qwiic_pins_default>; - clock-frequency = <100000>; - status = "okay"; -}; - -&usbss0 { - bootph-all; - ti,vbus-divider; - status = "okay"; -}; - -&usb0 { - bootph-all; - dr_mode = "peripheral"; -}; - -&usbss1 { - ti,vbus-divider; - status = "okay"; -}; - -&usb1 { - dr_mode = "host"; - pinctrl-names = "default"; - pinctrl-0 = <&usb1_pins_default>; -}; - -&cpsw3g { - pinctrl-names = "default"; - pinctrl-0 = <&rgmii1_pins_default>, <&spe_pins_default>, - <&gbe_pmx_obsclk>; - assigned-clocks = <&k3_clks 157 70>, <&k3_clks 157 20>; - assigned-clock-parents = <&k3_clks 157 72>, <&k3_clks 157 22>; -}; - -&cpsw_port1 { - phy-mode = "rgmii-rxid"; - phy-handle = <&cpsw3g_phy0>; -}; - -&cpsw_port2 { - phy-mode = "rmii"; - phy-handle = <&cpsw3g_phy1>; -}; - -&cpsw3g_mdio { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mdio0_pins_default>; - - cpsw3g_phy0: ethernet-phy@0 { - reg = <0>; - reset-gpios = <&main_gpio0 15 GPIO_ACTIVE_LOW>; - reset-assert-us = <10000>; - reset-deassert-us = <50000>; - }; - - cpsw3g_phy1: ethernet-phy@1 { - reg = <1>; - reset-gpios = <&main_gpio1 5 GPIO_ACTIVE_LOW>; - reset-assert-us = <25>; - reset-deassert-us = <60000>; /* T2 */ - }; -}; - -&main_gpio0 { - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&gpio0_pins_default>; - gpio-line-names = "BL_EN_3V3", "SPE_PO_EN", "RTC_INT", /* 0-2 */ - "USR0", "USR1", "USR2", "USR3", "", "", "USR4", /* 3-9 */ - "EEPROM_WP", /* 10 */ - "CSI2_CAMERA_GPIO1", "CSI2_CAMERA_GPIO2", /* 11-12 */ - "CC1352P7_BOOT", "CC1352P7_RSTN", "GBE_RSTN", "", "", /* 13-17 */ - "USR_BUTTON", "", "", "", "", "", "", "", "", /* 18-26 */ - "", "", "", "", "", "", "", "", "", "HDMI_INT", /* 27-36 */ - "", "VDD_WLAN_EN", "", "", "WL_IRQ", "GBE_INTN",/* 37-42 */ - "", "", "", "", "", "", "", "", "", "", "", "", /* 43-54 */ - "", "", "", "", "", "", "", "", "", "", "", "", /* 55-66 */ - "", "", "", "", "", "", "", "", "", "", "", "", /* 67-78 */ - "", "", "", "", "", "", /* 79-84 */ - "BITBANG_MDIO_DATA", "BITBANG_MDIO_CLK", /* 85-86 */ - "", "", "", "", ""; /* 87-91 */ -}; - -&main_gpio1 { - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&mikrobus_gpio_pins_default>; - gpio-line-names = "", "", "", "", "", /* 0-4 */ - "SPE_RSTN", "SPE_INTN", "MIKROBUS_GPIO1_7", /* 5-7 */ - "MIKROBUS_GPIO1_8", "MIKROBUS_GPIO1_9", /* 8-9 */ - "MIKROBUS_GPIO1_10", "MIKROBUS_GPIO1_11", /* 10-11 */ - "MIKROBUS_GPIO1_12", "MIKROBUS_W1_GPIO0", /* 12-13 */ - "MIKROBUS_GPIO1_14", /* 14 */ - "", "", "", "", "VDD_3V3_SD", "", "", /* 15-21 */ - "MIKROBUS_GPIO1_22", "MIKROBUS_GPIO1_23", /* 22-23 */ - "MIKROBUS_GPIO1_24", "MIKROBUS_GPIO1_25", /* 24-25 */ - "", "", "", "", "", "", "", "", "", "", "", "", /* 26-37 */ - "", "", "", "", "", "", "", "", "", "", /* 38-47 */ - "SD_CD", "SD_VOLT_SEL", "", ""; /* 48-51 */ -}; - -&main_i2c0 { - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&local_i2c_pins_default>; - clock-frequency = <400000>; - status = "okay"; - - eeprom@50 { - compatible = "atmel,24c32"; - reg = <0x50>; - }; - - rtc: rtc@68 { - compatible = "ti,bq32000"; - reg = <0x68>; - interrupt-parent = <&main_gpio0>; - interrupts = <2 IRQ_TYPE_EDGE_FALLING>; - }; - - tps65219: pmic@30 { - bootph-all; - compatible = "ti,tps65219"; - reg = <0x30>; - buck1-supply = <&vsys_5v0>; - buck2-supply = <&vsys_5v0>; - buck3-supply = <&vsys_5v0>; - ldo1-supply = <&vdd_3v3>; - ldo2-supply = <&buck2_reg>; - ldo3-supply = <&vdd_3v3>; - ldo4-supply = <&vdd_3v3>; - - pinctrl-names = "default"; - pinctrl-0 = <&pmic_irq_pins_default>; - interrupt-parent = <&gic500>; - interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - #interrupt-cells = <1>; - - system-power-controller; - ti,power-button; - - regulators { - buck1_reg: buck1 { - regulator-name = "VDD_CORE"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <850000>; - regulator-boot-on; - regulator-always-on; - }; - - buck2_reg: buck2 { - regulator-name = "VDD_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - buck3_reg: buck3 { - regulator-name = "VDD_1V2"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1_reg: ldo1 { - /* - * Regulator is left as is unused, vdd_sd - * is controlled via GPIO with bypass config - * as per the NVM configuration - */ - regulator-name = "VDD_SD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-allow-bypass; - regulator-boot-on; - regulator-always-on; - }; - - ldo2_reg: ldo2 { - regulator-name = "VDDA_0V85"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <850000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo3_reg: ldo3 { - regulator-name = "VDDA_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4_reg: ldo4 { - regulator-name = "VDD_2V5"; - regulator-min-microvolt = <2500000>; - regulator-max-microvolt = <2500000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; -}; - -&main_i2c1 { - pinctrl-names = "default"; - pinctrl-0 = <&grove_pins_default>; - clock-frequency = <100000>; - status = "okay"; -}; - -&main_i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_1v8_pins_default>; - clock-frequency = <100000>; - status = "okay"; - - it66121: bridge-hdmi@4c { - compatible = "ite,it66121"; - reg = <0x4c>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_gpio_pins_default>; - vcn33-supply = <&vdd_3v3>; - vcn18-supply = <&buck2_reg>; - vrf12-supply = <&buck3_reg>; - reset-gpios = <&main_gpio0 21 GPIO_ACTIVE_LOW>; - interrupt-parent = <&main_gpio0>; - interrupts = <36 IRQ_TYPE_EDGE_FALLING>; - #sound-dai-cells = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - it66121_in: endpoint { - bus-width = <24>; - remote-endpoint = <&dpi1_out>; - }; - }; - - port@1 { - reg = <1>; - - it66121_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; - }; - }; - }; -}; - -&main_i2c3 { - pinctrl-names = "default"; - pinctrl-0 = <&mikrobus_i2c_pins_default>; - clock-frequency = <400000>; - status = "okay"; -}; - -&main_spi2 { - pinctrl-names = "default"; - pinctrl-0 = <&mikrobus_spi_pins_default>; - status = "okay"; -}; - -&sdhci0 { - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_pins_default>; - disable-wp; - status = "okay"; -}; - -&sdhci1 { - /* SD/MMC */ - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&sd_pins_default>; - - vmmc-supply = <&vdd_3v3_sd>; - vqmmc-supply = <&vdd_sd_dv>; - disable-wp; - cd-gpios = <&main_gpio1 48 GPIO_ACTIVE_LOW>; - cd-debounce-delay-ms = <100>; - ti,fails-without-test-cd; - status = "okay"; -}; - -&sdhci2 { - vmmc-supply = <&wlan_en>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_pins_default>, <&wifi_32k_clk>; - non-removable; - ti,fails-without-test-cd; - cap-power-off-card; - keep-power-in-suspend; - assigned-clocks = <&k3_clks 157 158>; - assigned-clock-parents = <&k3_clks 157 160>; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - wlcore: wlcore@2 { - compatible = "ti,wl1807"; - reg = <2>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_wlirq_pins_default>; - interrupt-parent = <&main_gpio0>; - interrupts = <41 IRQ_TYPE_EDGE_FALLING>; - }; -}; - -&main_uart0 { - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&main_uart0_pins_default>; - status = "okay"; -}; - -&main_uart1 { - /* Main UART1 is used by TIFS firmware */ - status = "reserved"; -}; - -&main_uart5 { - pinctrl-names = "default"; - pinctrl-0 = <&mikrobus_uart_pins_default>; - status = "okay"; -}; - -&main_uart6 { - pinctrl-names = "default"; - pinctrl-0 = <&wifi_debug_uart_pins_default>; - status = "okay"; - - mcu { - compatible = "ti,cc1352p7"; - reset-gpios = <&main_gpio0 72 GPIO_ACTIVE_LOW>; - vdds-supply = <&vdd_3v3>; - }; -}; - -&dss { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&dss0_pins_default>; -}; - -&dss_ports { - /* VP2: DPI Output */ - port@1 { - reg = <1>; - - dpi1_out: endpoint { - remote-endpoint = <&it66121_in>; - }; - }; -}; - -&mcasp1 { - status = "okay"; - #sound-dai-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&mcasp_hdmi_pins_default>; - auxclk-fs-ratio = <2177>; - op-mode = <0>; /* MCASP_IIS_MODE */ - tdm-slots = <2>; - serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ - 1 0 0 0 - 0 0 0 0 - 0 0 0 0 - 0 0 0 0 - >; - tx-num-evt = <32>; - rx-num-evt = <32>; -}; diff --git a/configs/am62x_beagleplay_a53_defconfig b/configs/am62x_beagleplay_a53_defconfig index ec62670d55d6..455dd86b2fc3 100644 --- a/configs/am62x_beagleplay_a53_defconfig +++ b/configs/am62x_beagleplay_a53_defconfig @@ -10,7 +10,7 @@ CONFIG_TARGET_AM625_A53_BEAGLEPLAY=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80b80000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="k3-am625-beagleplay" +CONFIG_DEFAULT_DEVICE_TREE="ti/k3-am625-beagleplay" CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y @@ -58,6 +58,7 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y
base-commit: 15d0dcc0ec1f424199dff2a3cbe037bc3a7d8749
Doing a bit more cleanup since I got a few mins to do it.. will resubmit this patch as part of a series.
Nishanth Menon
