[U-Boot] [PATCH v2 1/2] odroid: Update README with USB host usage
Add information wrt using the USB host interface for loading kernel over ethernet and/or usb mass storage.
Signed-off-by: Suriyan Ramasami suriyan.r@gmail.com ---
Changes in v2: - Make updates to be of use from a user's perspective Series-changes: 1 - Add USB host notes for the Odroid
doc/README.odroid | 169 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 169 insertions(+)
diff --git a/doc/README.odroid b/doc/README.odroid index 528bb95..25b962b 100644 --- a/doc/README.odroid +++ b/doc/README.odroid @@ -141,3 +141,172 @@ And the boot sequence is: - boot_fit - if "Image.itb" exists - boot_zimg - if "zImage" exists - boot_uimg - if "uImage" exists + +11. USB host support +==================== + +The ethernet can be accessed after starting the USB subsystem in U-Boot. +The adapter does not come with a preconfigured MAC address, and hence it needs +to be set before starting USB. +setenv usbethaddr 02:DE:AD:BE:EF:FF + +Note that in this example a locally managed MAC address is chosen. Care should +be taken to make these MAC addresses unique within the same subnet. + +Start the USB subsystem: +Odroid # setenv usbethaddr 02:DE:AD:BE:EF:FF +Odroid # usb start +(Re)start USB... +USB0: USB EHCI 1.00 +scanning bus 0 for devices... 4 USB Device(s) found + scanning usb for storage devices... 1 Storage Device(s) found + scanning usb for ethernet devices... 1 Ethernet Device(s) found +Odroid # + +Automatic IP assignment: +------------------------ +If the ethernet is connected to a DHCP server (router maybe with DHCP enabled), +then the below will automatically assign an ip address through DHCP. +setenv autoload no +dhcp + +Odroid # setenv autoload no +Odroid # dhcp +Waiting for Ethernet connection... done. +BOOTP broadcast 1 +DHCP client bound to address 192.168.1.10 (524 ms) +Odroid # + +Note that this automatically sets the many IP address related variables in +U-Boot that is obtained from the DHCP server. + +Odroid # printenv ipaddr netmask gatewayip dnsip +ipaddr=192.168.1.10 +netmask=255.255.255.0 +gatewayip=192.168.1.1 +dnsip=192.168.1.1 + +Ping example: +The ping command can be used a test to check connectivity. In this example, +192.168.1.27 is a pingable server in the network. +Odroid # ping 192.168.1.27 +Waiting for Ethernet connection... done. +Using sms0 device +host 192.168.1.27 is alive +Odroid # + +Static IP assignment: +--------------------- +In the case where there are no DHCP servers in the network, or you want to +set the IP address statically, it can be done by: +Odroid # setenv ipaddr 192.168.1.10 +Odroid # ping 192.168.1.27 +Waiting for Ethernet connection... done. +Using sms0 device +host 192.168.1.27 is alive + +TFTP booting: +------------- +Say there exists a tftp server in the network with address 192.168.1.27 and +it serves a kernel image (zImage.3.17) and a DTB blob (exynos4412-odroidu3.dtb) +that needs to be loaded and booted. It can be accomplished as below: +(Assumes that you have setenv usbethaddr, and have not set autoload to no) + +Odroid # setenv serverip 192.168.1.27 +Odroid # tftpboot 0x40080000 zImage.3.17 +Waiting for Ethernet connection... done. +Using sms0 device +TFTP from server 192.168.1.27; our IP address is 192.168.1.10 +Filename 'zImage.3.17'. +Load address: 0x40080000 +Loading: ################################################################# + ################################################################# + ################################################################# + ####################### + 52.7 KiB/s +done +Bytes transferred = 3194200 (30bd58 hex) +Odroid # tftpboot 0x42000000 exynos4412-odroidu3.dtb +Waiting for Ethernet connection... done. +Using sms0 device +TFTP from server 192.168.1.27; our IP address is 192.168.1.10 +Filename 'exynos4412-odroidu3.dtb'. +Load address: 0x42000000 +Loading: #### + 40 KiB/s +done +Bytes transferred = 46935 (b757 hex) +Odroid # printenv bootargs +bootargs=Please use defined boot +Odroid # setenv bootargs console=ttySAC1,115200n8 root=/dev/mmcblk0p2 rootwait +Odroid # bootz 40080000 - 42000000 +Kernel image @ 0x40080000 [ 0x000000 - 0x30bd58 ] +## Flattened Device Tree blob at 42000000 + Booting using the fdt blob at 0x42000000 + Loading Device Tree to 4fff1000, end 4ffff756 ... OK + +Starting kernel ... + +[ 0.000000] Booting Linux on physical CPU 0xa00 +... etc ... + +In the above example you can substitute 'dhcp' for 'tftpboot' as well. + +USB Storage booting: +-------------------- +Similarly we can use the USB storage to load the kernel image/initrd/fdt etc +and boot. For this example, there is a USB drive plugged in. It has a FAT +1st partition and an EXT 2nd partition. Using the generic FS (ls/load) makes +it even easier to work with FAT/EXT file systems. +For this example the second EXT partition is used for booting and as rootfs. +The boot files - kernel and the dtb are present in the /boot directory of the +second partition. + +Odroid # usb start +(Re)start USB... +USB0: USB EHCI 1.00 +scanning bus 0 for devices... 4 USB Device(s) found + scanning usb for storage devices... 1 Storage Device(s) found + scanning usb for ethernet devices... +Error: sms0 address not set. <----- Note the error as usbethaddr +Warning: failed to set MAC address <----- is not set. +1 Ethernet Device(s) found +Odroid # usb part 0 + +Partition Map for USB device 0 -- Partition Type: DOS + +Part Start Sector Num Sectors UUID Type + 1 3072 263168 000c4046-01 06 + 2 266240 13457408 000c4046-02 83 + +Odroid # ls usb 0:2 /boot +<DIR> 4096 . +<DIR> 4096 .. + 353 boot.scr + 281 boot.txt + 101420 config-3.8.13.23 + 2127254 initrd.img-3.8.13.23 + 2194825 uInitrd + 2194825 uInitrd-3.8.13.23 + 2453112 zImage + 101448 config-3.8.13.26 + 2127670 uInitrd-3.8.13.26 + 2127606 initrd.img-3.8.13.26 + 3194200 zImage.3.17 <--- Kernel + 46935 exynos4412-odroidu3.dtb <--- DTB +Odroid # load usb 0:2 40080000 /boot/zImage.3.17 +3194200 bytes read in 471 ms (6.5 MiB/s) +Odroid # load usb 0:2 42000000 /boot/exynos4412-odroidu3.dtb +46935 bytes read in 233 ms (196.3 KiB/s) +Odroid # setenv bootargs console=ttySAC1,115200n8 root=/dev/sda2 rootwait +Odroid # bootz 40080000 - 42000000 +Kernel image @ 0x40080000 [ 0x000000 - 0x30bd58 ] +## Flattened Device Tree blob at 42000000 + Booting using the fdt blob at 0x42000000 + Loading Device Tree to 4fff1000, end 4ffff756 ... OK + +Starting kernel ... + +[ 0.000000] Booting Linux on physical CPU 0xa00 + +Please refer to README.usb for additional information.
The USB host code was missing gpio_request() calls before using the gpio functions, causing errors to be printed out.
As a side note calls to max77686_set_buck_mode(OPMODE_OFF/OPMODE_ON) have been removed, as they did not have any effect. This is as per Przemyslaw: I looked into the documentation and there is a "ENB8" pin in PMIC package. This pin allows steering BUCK8 ON/OFF by the hardware. If ENB8 is set to low then you can do on/off. If high, then you cannot change its state by I2C write, which seems to be the case with the Odroids.
Signed-off-by: Suriyan Ramasami suriyan.r@gmail.com Acked-by: Przemyslaw Marczak p.marczak@samsung.com ---
Changes in v2: - Add comment why max77686_set_buck_mode() has been removed Series-changes: 1 - Added gpio_request() call in board_gpio_init()
board/samsung/odroid/odroid.c | 13 +++++++++++-- 1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/board/samsung/odroid/odroid.c b/board/samsung/odroid/odroid.c index f7396ab..a2c008e 100644 --- a/board/samsung/odroid/odroid.c +++ b/board/samsung/odroid/odroid.c @@ -382,6 +382,17 @@ static void board_gpio_init(void) gpio_set_pull(EXYNOS4X12_GPIO_X31, S5P_GPIO_PULL_UP); gpio_set_drv(EXYNOS4X12_GPIO_X31, S5P_GPIO_DRV_4X); gpio_direction_input(EXYNOS4X12_GPIO_X31); + +#ifdef CONFIG_CMD_USB + /* USB3503A Reference frequency */ + gpio_request(EXYNOS4X12_GPIO_X30, "USB3503A RefFreq"); + + /* USB3503A Connect */ + gpio_request(EXYNOS4X12_GPIO_X34, "USB3503A Connect"); + + /* USB3503A Reset */ + gpio_request(EXYNOS4X12_GPIO_X35, "USB3503A Reset"); +#endif }
static int pmic_init_max77686(void) @@ -489,10 +500,8 @@ int board_usb_init(int index, enum usb_init_type init)
p_pmic = pmic_get("MAX77686_PMIC"); if (p_pmic && !pmic_probe(p_pmic)) { - max77686_set_buck_mode(p_pmic, 8, OPMODE_OFF); max77686_set_buck_voltage(p_pmic, 8, 750000); max77686_set_buck_voltage(p_pmic, 8, 3300000); - max77686_set_buck_mode(p_pmic, 8, OPMODE_ON); }
#endif
Tested on top of u-boot-samsung head (6a23c6533c880d557e786df81fa21b62168db6d9), with this patch ethernet support work on my Odroid X2 (emmc boot). Free free to add, Tested-by: Sjoerd Simons sjoerd.simons@collabora.co.uk
Changes in v2:
Series-changes: 1
- /* USB3503A Reference frequency */
- gpio_request(EXYNOS4X12_GPIO_X30, "USB3503A RefFreq");
- /* USB3503A Connect */
- gpio_request(EXYNOS4X12_GPIO_X34, "USB3503A Connect");
- /* USB3503A Reset */
- gpio_request(EXYNOS4X12_GPIO_X35, "USB3503A Reset");
+#endif }
max77686_set_buck_voltage(p_pmic, 8, 750000); max77686_set_buck_voltage(p_pmic, 8, 3300000);max77686_set_buck_mode(p_pmic, 8, OPMODE_OFF);
}max77686_set_buck_mode(p_pmic, 8, OPMODE_ON);
#endif
As a side note calls to max77686_set_buck_mode(OPMODE_OFF/OPMODE_ON) have been removed, as they did not have any effect. This is as per Przemyslaw: I looked into the documentation and there is a "ENB8" pin in PMIC package. This pin allows steering BUCK8 ON/OFF by the vhardware. If ENB8 is set to low then you can do on/off. If high, then you cannot change its state by I2C write, which seems to be the case with the Odroids.
Changes in v2:
Series-changes: 1
applied to u-boot-samsung.
Thanks, Minkyu Kang.
Hello Suriyan,
Changes in v2:
Series-changes: 1
+Odroid #
52.7 KiB/s
40 KiB/s
- Booting using the fdt blob at 0x42000000
- Loading Device Tree to 4fff1000, end 4ffff756 ... OK
- 1 3072 263168 000c4046-01 06
- 2 266240 13457408 000c4046-02 83
353 boot.scr
281 boot.txt
2194825 uInitrd
2453112 zImage
This is a very complete instruction. Thank you for a great job!
Changes in v2:
Series-changes: 1
Minkyu Kang
Przemyslaw Marczak
Sjoerd Simons
Suriyan Ramasami
