[U-Boot] [PATCH] openrd: Once again shrink binary size
With some recent changes to relevant drivers here the openrd board (openrd_client in this case) does not fit within its size constraint. We can however drop the slightly extended baudrate table and then the duplication of mtdparts/mtdids in the default environment. These defaults are set in the environment by the 'mtdparts' command and otherwise referenced throughout the code.
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/mv-common.h | 8 -------- include/configs/openrd.h | 4 +--- 2 files changed, 1 insertion(+), 11 deletions(-)
diff --git a/include/configs/mv-common.h b/include/configs/mv-common.h index 79d61c599e54..8ae521f7e986 100644 --- a/include/configs/mv-common.h +++ b/include/configs/mv-common.h @@ -38,14 +38,6 @@ #define CONFIG_SYS_NS16550_COM1 MV_UART_CONSOLE_BASE #endif
-/* - * Serial Port configuration - * The following definitions let you select what serial you want to use - * for your console driver. - */ - -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ - 115200,230400, 460800, 921600 } /* auto boot */ #define CONFIG_PREBOOT
diff --git a/include/configs/openrd.h b/include/configs/openrd.h index 2b21003b8b75..17611bc56873 100644 --- a/include/configs/openrd.h +++ b/include/configs/openrd.h @@ -60,9 +60,7 @@ CONFIG_MTDPARTS_DEFAULT " rw ubi.mtd=2,2048\0" \ "x_bootcmd_kernel=nand read 0x6400000 0x100000 0x300000\0" \ "x_bootcmd_usb=usb start\0" \ - "x_bootargs_root=root=ubi0:rootfs rootfstype=ubifs\0" \ - "mtdids="CONFIG_MTDIDS_DEFAULT"\0" \ - "mtdparts="CONFIG_MTDPARTS_DEFAULT"\0" + "x_bootargs_root=root=ubi0:rootfs rootfstype=ubifs\0"
/* * Ethernet Driver configuration
We could probably shrink things further by disabling jffs2 and only supporting ubifs. Similarly having support for both fat and ext4 is taking up much of the image although it may be less desirable to pick only one of these since either of those file systems could be on removable media.
Ah, so, did you also see my email marking the platforms as orphaned? If so, please feel free to pick them up and trim the config down :) Thanks!
Yep I did. I'm happy to put some effort into trimming them down but I don't have any genuine openrd hardware to test on (I do have some custom kirkwood based boards).
I can do some basic things (like disabling jffs2) but I'd be hesitant to do more involved things like converting to devicetree without actual hardware to test on. Hopefully we can find someone with access to the real thing.
Chris Packham
