[PATCH v2 0/3] arch: arm: mach-k3: j7200 document and emmc update
This patch set create the documentation for J7200.
Also corrects emmc raw offset as per current allocated size, along with adding support for UDA FS boot.
Changelog: Change from v1: https://lore.kernel.org/all/20230503052821.1257467-1-u-kumar1@ti.com/
1) Added board specific documentation as per review comments 2) No change in emmc offset, only version and commit message updated 3) Added support for UDA FS booting
Udit Kumar (3): doc: board: ti: add documenation for j7200 configs: j7200: correct mmc offset arch: arm: mach-k3: j721e: add support for UDA FS booting
arch/arm/mach-k3/j721e_init.c | 2 +- configs/j7200_evm_a72_defconfig | 2 +- configs/j7200_evm_r5_defconfig | 2 +- configs/j7200_hs_evm_a72_defconfig | 2 +- configs/j7200_hs_evm_r5_defconfig | 2 +- doc/board/ti/j7200_evm.rst | 332 +++++++++++++++++++++++++++++ doc/board/ti/k3.rst | 1 + 7 files changed, 338 insertions(+), 5 deletions(-) create mode 100644 doc/board/ti/j7200_evm.rst
This patch adds documentation for j7200.
TRM link https://www.ti.com/lit/pdf/spruiu1
Signed-off-by: Udit Kumar u-kumar1@ti.com --- doc/board/ti/j7200_evm.rst | 332 +++++++++++++++++++++++++++++++++++++ doc/board/ti/k3.rst | 1 + 2 files changed, 333 insertions(+) create mode 100644 doc/board/ti/j7200_evm.rst
diff --git a/doc/board/ti/j7200_evm.rst b/doc/board/ti/j7200_evm.rst new file mode 100644 index 0000000000..0d3a526516 --- /dev/null +++ b/doc/board/ti/j7200_evm.rst @@ -0,0 +1,332 @@ +.. SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +.. sectionauthor:: Udit Kumar u-kumar1@ti.com + +J7200 Platforms +=============== + +Introduction: +------------- +The J7200 family of SoCs are part of K3 Multicore SoC architecture platform +targeting automotive applications. They are designed as a low power, high +performance and highly integrated device architecture, adding significant +enhancement on processing power, graphics capability, video and imaging +processing, virtualization and coherent memory support. + +The device is partitioned into three functional domains, each containing +specific processing cores and peripherals: + +1. Wake-up (WKUP) domain: + * Device Management and Security Controller (DMSC) + +2. Microcontroller (MCU) domain: + * Dual Core ARM Cortex-R5F processor + +3. MAIN domain: + * Dual core 64-bit ARM Cortex-A72 + +More info can be found in TRM: https://www.ti.com/lit/pdf/spruiu1 + +Boot Flow: +---------- +Below is the pictorial representation of boot flow: + +.. code-block:: text + + +------------------------------------------------------------------------+-----------------------+ + | DMSC | MCU R5 | A72 | MAIN R5/C7x | + +------------------------------------------------------------------------+-----------------------+ + | +--------+ | | | | + | | Reset | | | | | + | +--------+ | | | | + | : | | | | + | +--------+ | +-----------+ | | | + | | *ROM* |----------|-->| Reset rls | | | | + | +--------+ | +-----------+ | | | + | | | | : | | | + | | ROM | | : | | | + | |services| | : | | | + | | | | +-------------+ | | | + | | | | | *R5 ROM* | | | | + | | | | +-------------+ | | | + | | |<---------|---|Load and auth| | | | + | | | | | tiboot3.bin | | | | + | | Start | | +-------------+ | | | + | | TIFS |<---------|---| Start | | | | + | | | | | TIFS | | | | + | +--------+ | +-------------+ | | | + | : | | | | | | + | +---------+ | | Load | | | | + | | *TIFS* | | | system | | | | + | +---------+ | | Config data | | | | + | | |<--------|---| | | | | + | | | | +-------------+ | | | + | | | | : | | | + | | | | : | | | + | | | | : | | | + | | | | +-------------+ | | | + | | | | | *R5 SPL* | | | | + | | | | +-------------+ | | | + | | | | | DDR | | | | + | | | | | config | | | | + | | | | +-------------+ | | | + | | | | | Load | | | | + | | | | | tispl.bin | | | | + | | | | +-------------+ | | | + | | | | | Load R5 | | | | + | | | | | firmware | | | | + | | | | +-------------+ | | | + | | |<--------|---| Start A72 | | | | + | | | | | and jump to | | | | + | | | | | DM fw image | | | | + | | | | +-------------+ | | | + | | | | | +-----------+ | | + | | |---------|-----------------------|---->| Reset rls | | | + | | | | | +-----------+ | | + | | TIFS | | | : | | + | |Services | | | +-----------+ | | + | | |<--------|-----------------------|---->|*ATF/OPTEE*| | | + | | | | | +-----------+ | | + | | | | | : | | + | | | | | +-----------+ | | + | | |<--------|-----------------------|---->| *A72 SPL* | | | + | | | | | +-----------+ | | + | | | | | | Load | | | + | | | | | | u-boot.img| | | + | | | | | +-----------+ | | + | | | | | : | | + | | | | | +-----------+ | | + | | |<--------|-----------------------|---->| *U-Boot* | | | + | | | | | +-----------+ | | + | | | | | | prompt | | | + | | | | | +-----------+ | | + | | | | | | Load R5 | | | + | | | | | | Firmware | | | + | | | | | +-----------+ | | + | | |<--------|-----------------------|-----| Start R5 | | +-----------+ | + | | |---------|-----------------------|-----+-----------+-----|----->| R5 starts | | + | | | | | | Load C7 | | +-----------+ | + | | | | | | Firmware | | | + | | | | | +-----------+ | | + | | |<--------|-----------------------|-----| Start C7 | | +-----------+ | + | | |---------|-----------------------|-----+-----------+-----|----->| C7 starts | | + | | | | | | +-----------+ | + | | | | | | | + | +---------+ | | | | + | | | | | + +------------------------------------------------------------------------+-----------------------+ + +- Here DMSC acts as master and provides all the critical services. R5/A72 + requests DMSC to get these services done as shown in the above diagram. + +Sources: +-------- +1. SYSFW: + Tree: git://git.ti.com/k3-image-gen/k3-image-gen.git + Branch: master + +2. ATF: + Tree: https://github.com/ARM-software/arm-trusted-firmware.git + Branch: master + +3. OPTEE: + Tree: https://github.com/OP-TEE/optee_os.git + Branch: master + +4. DM Firmware: + Tree: git://git.ti.com/processor-firmware/ti-linux-firmware.git + Branch: ti-linux-firmware + +5. U-Boot: + Tree: https://source.denx.de/u-boot/u-boot + Branch: master + +Build procedure: +---------------- +1. SYSFW: + +.. code-block:: bash + + make ARCH=arm CROSS_COMPILE=arm-none-linux-gnueabihf- SOC=j7200 SBL=u-boot-spl.bin SYSFW_PATH=<path to sysfw>/ti-fs-firmware-j7200-gp.bin + u-boot-spl.bin is generated at step 4. + +2. ATF: + +.. code-block:: bash + + make CROSS_COMPILE=aarch64-linux-gnu- ARCH=aarch64 PLAT=k3 TARGET_BOARD=generic SPD=opteed + +3. OPTEE: + +.. code-block:: bash + + make PLATFORM=k3-j7200 CFG_ARM64_core=y + +4. U-Boot: + +* 4.1 R5: + +.. code-block:: bash + + make CROSS_COMPILE=arm-linux-gnueabihf- j7200_evm_r5_defconfig O=build/r5 + make CROSS_COMPILE=arm-linux-gnueabihf- O=build/r5 + +* 4.2 A72: + +.. code-block:: bash + + make CROSS_COMPILE=aarch64-linux-gnu- j7200_evm_a72_defconfig O=build/a72 + make CROSS_COMPILE=aarch64-linux-gnu- ATF=<ATF dir>/build/k3/generic/release/bl31.bin TEE=<OPTEE OS dir>/out/arm-plat-k3/core/tee-pager_v2.bin DM=<DM firmware>/ti-dm/j7200/ipc_echo_testb_mcu1_0_release_strip.xer5f O=build/a72 + +Target Images +-------------- +Copy the below images to an SD card and boot: + - tiboot3.bin from step 1 + - tispl.bin, u-boot.img from 4.2 + +Image formats: +-------------- + +- tiboot3.bin: + +.. code-block:: console + + +-----------------------+ + | X.509 | + | Certificate | + | +-------------------+ | + | | | | + | | R5 | | + | | u-boot-spl.bin | | + | | | | + | +-------------------+ | + | | | | + | | FIT header | | + | | +---------------+ | | + | | | | | | + | | | DTB 1...N | | | + | | +---------------+ | | + | +-------------------+ | + | | | | + | | FIT HEADER | | + | | +---------------+ | | + | | | | | | + | | | sysfw.bin | | | + | | +---------------+ | | + | | | | | | + | | | board config | | | + | | +---------------+ | | + | | | | | | + | | | PM config | | | + | | +---------------+ | | + | | | | | | + | | | RM config | | | + | | +---------------+ | | + | | | | | | + | | | Secure config | | | + | | +---------------+ | | + | +-------------------+ | + +-----------------------+ + +- tispl.bin + +.. code-block:: console + + +-----------------------+ + | | + | FIT HEADER | + | +-------------------+ | + | | | | + | | A72 ATF | | + | +-------------------+ | + | | | | + | | A72 OPTEE | | + | +-------------------+ | + | | | | + | | R5 DM FW | | + | +-------------------+ | + | | | | + | | A72 SPL | | + | +-------------------+ | + | | | | + | | SPL DTB 1...N | | + | +-------------------+ | + +-----------------------+ + + +Switch Setting for Boot Mode +---------------------------- + +Boot Mode pins provide means to select the boot mode and options before the +device is powered up. After every POR, they are the main source to populate +the Boot Parameter Tables. + +The following table shows some common boot modes used on J7200 platform. More +details can be found in the Technical Reference Manual: +https://www.ti.com/lit/pdf/spruiu1 under the `Boot Mode Pins` section. + + +*Boot Modes* + +============ ============= ============= +Switch Label SW9: 12345678 SW8: 12345678 +============ ============= ============= +SD 00000000 10000010 +EMMC 01000000 10000000 +OSPI 01000000 00000110 +UART 01110000 00000000 +USB DFU 00100000 10000000 +============ ============= ============= + +For SW8 and SW9, the switch state in the "ON" position = 1. + +eMMC: +----- +ROM supports booting from eMMC raw read or UDA FS mode. + +Below is memory layout in case of booting from +boot 0/1 partition in raw mode. + +Current allocated size for tiboot3 size is 1MB, tispl is 2MB. + +Size of u-boot.img is taken 4MB for refernece, +But this is subject to change depending upon atf, optee size + +.. code-block:: console + + boot0/1 partition (8 MB) user partition + 0x0+----------------------------------+ 0x0+------------------------+ + | tiboot3.bin (1 MB) | | | + 0x800+----------------------------------+ | | + | tispl.bin (2 MB) | | | + 0x1800+----------------------------------+ | | + | u-boot.img (4MB) | | | + 0x3800+----------------------------------+ | | + | | | | + 0x3900+ environment | | | + | | | | + 0x3A00+----------------------------------+ +-------------------------+ + +In case of UDA FS mode booting, following is layout. + +All boot images tiboot3.bin, tispl and u-boot should be written to +fat formatted UDA FS as file. + +.. code-block:: console + + boot0/1 partition (8 MB) user partition + 0x0+---------------------------------+ 0x0+-------------------------+ + | | | tiboot3.bin* | + 0x800+----------------------------------+ | | + | | | tispl.bin | + 0x1800+----------------------------------+ | | + | | | u-boot.img | + 0x3800+----------------------------------+ | | + | | | | + 0x3900+ | | environment | + | | | | + 0x3A00+----------------------------------+ +-------------------------+ + + + +In case of booting from eMMC, write above images into raw or UDA FS. +and set mmc partconf accordingly. diff --git a/doc/board/ti/k3.rst b/doc/board/ti/k3.rst index b49a60caf1..2b2f4bb8bb 100644 --- a/doc/board/ti/k3.rst +++ b/doc/board/ti/k3.rst @@ -31,6 +31,7 @@ K3 Based SoCs :maxdepth: 1
j721e_evm + j7200_evm am62x_sk
Boot Flow Overview
HTML docs build without problems. Formatting looks correct.
Thank you for the documentation.
Tested-by: Heinrich Schuchardt xypron.glpk@gmx.de
Signed-off-by: Udit Kumar u-kumar1@ti.com Tested-by: Heinrich Schuchardt xypron.glpk@gmx.de
This patch corrects the MMC raw mode sector offset.
Current allocated size for tiboot3 is 1MB and 2MB for tispl.
Without this correct offset eMMC boot will fail.
Fixes: f8c1e893c82 (configs: j7200_evm_a72: Add Initial suppot) Fixes: 02dff65efe7 (configs: j7200_evm_r5: Add initial support) Fixes: 360c7f46f39 (configs: Add configs for J7200 High Security EVM)
Way to test with eMMC boot from boot0/1 partition Boot with SD card, copy images to eMMC boot0 or boot1 partition
=> mmc dev 0 (1 or 2) => fatload mmc 1 ${loadaddr} tiboot3.bin => mmc write ${loadaddr} 0x0 0x800 => fatload mmc 1 ${loadaddr} tispl.bin => mmc write ${loadaddr} 0x800 0x1000 => fatload mmc 1 ${loadaddr} u-boot.img => mmc write ${loadaddr} 0x1800 0x2000 => mmc partconf 0 1 (1 or 2) 1 => mmc bootbus 0 2 0 0
Cc: Bhavya Kapoor b-kapoor@ti.com Cc: Diwakar Dhyani d-dhyani@ti.com Cc: KEERTHY j-keerthy@ti.com Signed-off-by: Udit Kumar u-kumar1@ti.com
--- configs/j7200_evm_a72_defconfig | 2 +- configs/j7200_evm_r5_defconfig | 2 +- configs/j7200_hs_evm_a72_defconfig | 2 +- configs/j7200_hs_evm_r5_defconfig | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index fa5ea2aecd..8a810f8f48 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -46,7 +46,7 @@ CONFIG_SPL_STACK_R=y CONFIG_SYS_SPL_MALLOC=y CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1800 CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index 00ec48b83b..908cfaf402 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -43,7 +43,7 @@ CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y diff --git a/configs/j7200_hs_evm_a72_defconfig b/configs/j7200_hs_evm_a72_defconfig index d9560727ed..c234a58a7a 100644 --- a/configs/j7200_hs_evm_a72_defconfig +++ b/configs/j7200_hs_evm_a72_defconfig @@ -47,7 +47,7 @@ CONFIG_SPL_STACK_R=y CONFIG_SYS_SPL_MALLOC=y CONFIG_SYS_SPL_MALLOC_SIZE=0x800000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1800 CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_LOAD_PAYLOAD_NAME="u-boot.img" diff --git a/configs/j7200_hs_evm_r5_defconfig b/configs/j7200_hs_evm_r5_defconfig index 94a6523f06..74015db1af 100644 --- a/configs/j7200_hs_evm_r5_defconfig +++ b/configs/j7200_hs_evm_r5_defconfig @@ -43,7 +43,7 @@ CONFIG_CUSTOM_SYS_SPL_MALLOC_ADDR=0x84000000 CONFIG_SYS_SPL_MALLOC_SIZE=0x1000000 CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y -CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 +CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x800 CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_FS_EXT4=y
When selecting UDA partition for booting. MMC read mode was selected as RAW.
Due to growing/changing size of u-boot and tispl images. It will be better change to FS in case of UDA FS instead of adjusting offsets with new change.
Signed-off-by: Udit Kumar u-kumar1@ti.com --- arch/arm/mach-k3/j721e_init.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index 9bba5f7954..44ebb37c48 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -288,7 +288,7 @@ u32 spl_mmc_boot_mode(struct mmc *mmc, const u32 boot_device) { switch (boot_device) { case BOOT_DEVICE_MMC1: - return MMCSD_MODE_EMMCBOOT; + return (spl_mmc_emmc_boot_partition(mmc) ? MMCSD_MODE_EMMCBOOT : MMCSD_MODE_FS); case BOOT_DEVICE_MMC2: return MMCSD_MODE_FS; default:
Udit Kumar
