[U-Boot] [PATCH 0/3] rockchip: rk3368: spl: move SPL_LDSCRIPT from header-files to Kconfig
After applying the SPL/TPL infrastructure changes for the RK3368, a number of unexpected failures occurred during the buildman validation run. For a some of platforms, SPL_LDSCRIPT was now defined multiple times: once from Kconfig and once from a header file.
This is a hot fix (i.e. it's needed before I can send out our pull-request) that adjusts the everything else to work again with SPL_LDSCRIPT moved to Kconfig.
Note that I marked this as 'rockchip: spl: rk3368', as it is a change from integration/merging the changes already queued for our tree.
Philipp Tomsich (3): spl: add hierarchical defaults for SPL_LDSCRIPT spl: moveconfig: remove SPL_LDSCRIPT definitions for header-files rockchip: rk3368: spl: move SPL_LDSCRIPT to Kconfig
arch/arm/Kconfig | 12 ++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 3 +++ arch/arm/mach-at91/Kconfig | 4 ++++ arch/arm/mach-davinci/Kconfig | 4 ++++ arch/arm/mach-exynos/Kconfig | 3 +++ arch/arm/mach-omap2/Kconfig | 3 +++ arch/arm/mach-orion5x/Kconfig | 3 +++ arch/arm/mach-rockchip/rk3368/Kconfig | 3 +++ arch/arm/mach-sunxi/Kconfig | 3 +++ arch/arm/mach-zynq/Kconfig | 3 +++ arch/microblaze/Kconfig | 3 +++ board/armadeus/apf27/Kconfig | 3 +++ board/freescale/mx31pdk/Kconfig | 3 +++ board/spear/x600/Kconfig | 3 +++ include/configs/am335x_evm.h | 2 -- include/configs/am335x_igep003x.h | 1 - include/configs/am335x_shc.h | 2 -- include/configs/am335x_sl50.h | 2 -- include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 2 -- include/configs/apf27.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/baltos.h | 2 -- include/configs/bav335x.h | 2 -- include/configs/bur_am335x_common.h | 1 - include/configs/chiliboard.h | 2 -- include/configs/cm_t335.h | 1 - include/configs/cm_t35.h | 1 - include/configs/cm_t43.h | 2 -- include/configs/da850evm.h | 1 - include/configs/edminiv2.h | 1 - include/configs/exynos5-common.h | 1 - include/configs/imx6_spl.h | 1 - include/configs/ipam390.h | 1 - include/configs/kc1.h | 2 -- include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 2 -- include/configs/ls1021atwr.h | 1 - include/configs/ls1043a_common.h | 2 -- include/configs/ls1046a_common.h | 2 -- include/configs/ls2080a_common.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/mcx.h | 1 - include/configs/microblaze-generic.h | 2 -- include/configs/mx31pdk.h | 1 - include/configs/mxs.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/origen.h | 1 - include/configs/pcm051.h | 2 -- include/configs/pengwyn.h | 2 -- include/configs/pepper.h | 1 - include/configs/picosam9g45.h | 1 - include/configs/sama5d2_xplained.h | 1 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/siemens-am33x-common.h | 2 -- include/configs/smartweb.h | 1 - include/configs/smdkv310.h | 1 - include/configs/sniper.h | 2 -- include/configs/sunxi-common.h | 4 ---- include/configs/tam3517-common.h | 1 - include/configs/tao3530.h | 1 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 2 -- include/configs/ti_omap3_common.h | 1 - include/configs/ti_omap4_common.h | 1 - include/configs/ti_omap5_common.h | 1 - include/configs/tricorder.h | 1 - include/configs/woodburn_sd.h | 1 - include/configs/x600.h | 1 - include/configs/zynq-common.h | 2 -- 77 files changed, 53 insertions(+), 85 deletions(-)
With SPL_LDSCRIPT moved to Kconfig (and this being a 'string' config node), all the lingering definitions in header files will cause errors due to the redefinition of the configuration item.
As we don't want to pollute the defconfig files (and values should usually be identical for entire architectures), the defaults are moved into Kconfig. Kconfig will always pick the first default that matches, so please keep these values at the end of each file (to allow any board-specific Kconfig, which will be included earlier) to override with an unconditional default setting.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
arch/arm/Kconfig | 12 ++++++++++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 3 +++ arch/arm/mach-at91/Kconfig | 4 ++++ arch/arm/mach-davinci/Kconfig | 4 ++++ arch/arm/mach-exynos/Kconfig | 3 +++ arch/arm/mach-omap2/Kconfig | 3 +++ arch/arm/mach-orion5x/Kconfig | 3 +++ arch/arm/mach-sunxi/Kconfig | 3 +++ arch/arm/mach-zynq/Kconfig | 3 +++ arch/microblaze/Kconfig | 3 +++ board/armadeus/apf27/Kconfig | 3 +++ board/freescale/mx31pdk/Kconfig | 3 +++ board/spear/x600/Kconfig | 3 +++ 13 files changed, 50 insertions(+)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7f6ab4a..2b72810 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -609,6 +609,11 @@ config ARCH_MX6 select SYS_FSL_SEC_LE select SYS_THUMB_BUILD if SPL
+if ARCH_MX6 +config SPL_LDSCRIPT + default "arch/arm/mach-omap2/u-boot-spl.lds" +endif + config ARCH_MX5 bool "Freescale MX5" select CPU_V7 @@ -1222,3 +1227,10 @@ source "board/zipitz2/Kconfig" source "arch/arm/Kconfig.debug"
endmenu + +config SPL_LDSCRIPT + default "arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds" if CPU_ARM926EJS + default "arch/arm/cpu/arm1136/u-boot-spl.lds" if CPU_ARM1136 + default "arch/arm/cpu/armv8/u-boot-spl.lds" if ARM64 + + diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index 5825f9b..5ba347c 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -392,3 +392,6 @@ config SYS_MC_RSV_MEM_ALIGN help Reserved memory needs to be aligned for MC to use. Default value is 512MB. + +config SPL_LDSCRIPT + default "arch/arm/cpu/armv8/u-boot-spl.lds" if ARCH_LS1043A || ARCH_LS1046A || ARCH_LS2080A diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 033c1ef..c81264b 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -198,4 +198,8 @@ source "board/siemens/corvus/Kconfig" source "board/siemens/taurus/Kconfig" source "board/siemens/smartweb/Kconfig"
+config SPL_LDSCRIPT + default "arch/arm/mach-at91/arm926ejs/u-boot-spl.lds" if CPU_ARM926EJS + default "arch/arm/mach-at91/armv7/u-boot-spl.lds" if CPU_V7 + endif diff --git a/arch/arm/mach-davinci/Kconfig b/arch/arm/mach-davinci/Kconfig index 4757f24..35e4e9b 100644 --- a/arch/arm/mach-davinci/Kconfig +++ b/arch/arm/mach-davinci/Kconfig @@ -53,4 +53,8 @@ source "board/davinci/ea20/Kconfig" source "board/omicron/calimain/Kconfig" source "board/lego/ev3/Kconfig"
+config SPL_LDSCRIPT + default "board/$(BOARDDIR)/u-boot-spl-ipam390.lds" if TARGET_IPAM390 + default "board/$(BOARDDIR)/u-boot-spl-da850evm.lds" + endif diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index d1aa68d..8b1389f 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -161,4 +161,7 @@ source "board/samsung/smdk5250/Kconfig" source "board/samsung/smdk5420/Kconfig" source "board/samsung/espresso7420/Kconfig"
+config SPL_LDSCRIPT + default "board/samsung/common/exynos-uboot-spl.lds" if ARCH_EXYNOS5 || ARCH_EXYNOS4 + endif diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 013586e..588ef8f 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -165,4 +165,7 @@ source "board/ti/am335x/Kconfig" source "board/compulab/cm_t335/Kconfig" source "board/compulab/cm_t43/Kconfig"
+config SPL_LDSCRIPT + default "arch/arm/mach-omap2/u-boot-spl.lds" + endif diff --git a/arch/arm/mach-orion5x/Kconfig b/arch/arm/mach-orion5x/Kconfig index 7644b8d..2984a3e 100644 --- a/arch/arm/mach-orion5x/Kconfig +++ b/arch/arm/mach-orion5x/Kconfig @@ -15,4 +15,7 @@ config SYS_SOC
source "board/LaCie/edminiv2/Kconfig"
+config SPL_LDSCRIPT + default "$(CPUDIR)/orion5x/u-boot-spl.lds" if ORION5X + endif diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index 94412ba..386befb 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -1,5 +1,8 @@ if ARCH_SUNXI
+config SPL_LDSCRIPT + default "arch/arm/cpu/armv7/sunxi/u-boot-spl.lds" if !ARM64 + config IDENT_STRING default " Allwinner Technology"
diff --git a/arch/arm/mach-zynq/Kconfig b/arch/arm/mach-zynq/Kconfig index c428ce5..b9cd45b 100644 --- a/arch/arm/mach-zynq/Kconfig +++ b/arch/arm/mach-zynq/Kconfig @@ -1,5 +1,8 @@ if ARCH_ZYNQ
+config SPL_LDSCRIPT + default "arch/arm/mach-zynq/u-boot-spl.lds" + config SPL_FAT_SUPPORT default y
diff --git a/arch/microblaze/Kconfig b/arch/microblaze/Kconfig index 20fa25b..f791c00 100644 --- a/arch/microblaze/Kconfig +++ b/arch/microblaze/Kconfig @@ -21,4 +21,7 @@ endchoice
source "board/xilinx/microblaze-generic/Kconfig"
+config SPL_LDSCRIPT + default "arch/microblaze/cpu/u-boot-spl.lds" + endmenu diff --git a/board/armadeus/apf27/Kconfig b/board/armadeus/apf27/Kconfig index 65544a8..a342d2e 100644 --- a/board/armadeus/apf27/Kconfig +++ b/board/armadeus/apf27/Kconfig @@ -1,5 +1,8 @@ if TARGET_APF27
+config SPL_LDSCRIPT + default "arch/$(ARCH)/cpu/u-boot-spl.lds" + config SYS_BOARD default "apf27"
diff --git a/board/freescale/mx31pdk/Kconfig b/board/freescale/mx31pdk/Kconfig index 055545c..b9fc2d5 100644 --- a/board/freescale/mx31pdk/Kconfig +++ b/board/freescale/mx31pdk/Kconfig @@ -1,5 +1,8 @@ if TARGET_MX31PDK
+config SPL_LDSCRIPT + default "arch/$(ARCH)/cpu/u-boot-spl.lds" + config SYS_BOARD default "mx31pdk"
diff --git a/board/spear/x600/Kconfig b/board/spear/x600/Kconfig index 6a1c5c7..59f2b1e 100644 --- a/board/spear/x600/Kconfig +++ b/board/spear/x600/Kconfig @@ -1,5 +1,8 @@ if TARGET_X600
+config SPL_LDSCRIPT + default "arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds" + config SYS_BOARD default "x600"
Hi Philipp,
On 4 August 2017 at 14:52, Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
I would expect this to generate warnings given that the header files define these also. But perhaps it doesn't since the values are the same.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Simon Glass sjg@chromium.org
Applied to u-boot-rockchip, thanks!
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes.
Signed-off-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
include/configs/am335x_evm.h | 2 -- include/configs/am335x_igep003x.h | 1 - include/configs/am335x_shc.h | 2 -- include/configs/am335x_sl50.h | 2 -- include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/am43xx_evm.h | 2 -- include/configs/apf27.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/baltos.h | 2 -- include/configs/bav335x.h | 2 -- include/configs/bur_am335x_common.h | 1 - include/configs/chiliboard.h | 2 -- include/configs/cm_t335.h | 1 - include/configs/cm_t35.h | 1 - include/configs/cm_t43.h | 2 -- include/configs/da850evm.h | 1 - include/configs/edminiv2.h | 1 - include/configs/exynos5-common.h | 1 - include/configs/imx6_spl.h | 1 - include/configs/ipam390.h | 1 - include/configs/kc1.h | 2 -- include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 2 -- include/configs/ls1021atwr.h | 1 - include/configs/ls1043a_common.h | 2 -- include/configs/ls1046a_common.h | 2 -- include/configs/ls2080a_common.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/mcx.h | 1 - include/configs/microblaze-generic.h | 2 -- include/configs/mx31pdk.h | 1 - include/configs/mxs.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omapl138_lcdk.h | 1 - include/configs/origen.h | 1 - include/configs/pcm051.h | 2 -- include/configs/pengwyn.h | 2 -- include/configs/pepper.h | 1 - include/configs/picosam9g45.h | 1 - include/configs/sama5d2_xplained.h | 1 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 1 - include/configs/sama5d4_xplained.h | 1 - include/configs/sama5d4ek.h | 1 - include/configs/siemens-am33x-common.h | 2 -- include/configs/smartweb.h | 1 - include/configs/smdkv310.h | 1 - include/configs/sniper.h | 2 -- include/configs/sunxi-common.h | 4 ---- include/configs/tam3517-common.h | 1 - include/configs/tao3530.h | 1 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 2 -- include/configs/ti_omap3_common.h | 1 - include/configs/ti_omap4_common.h | 1 - include/configs/ti_omap5_common.h | 1 - include/configs/tricorder.h | 1 - include/configs/woodburn_sd.h | 1 - include/configs/x600.h | 1 - include/configs/zynq-common.h | 2 -- 63 files changed, 85 deletions(-)
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 2a2e2ba..9df856c 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -191,8 +191,6 @@ #define CONFIG_SYS_BOOTCOUNT_BE
/* USB gadget RNDIS */ - -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" #endif
#ifdef CONFIG_NAND diff --git a/include/configs/am335x_igep003x.h b/include/configs/am335x_igep003x.h index 4721b42..ae72543 100644 --- a/include/configs/am335x_igep003x.h +++ b/include/configs/am335x_igep003x.h @@ -125,7 +125,6 @@ #define MTDPARTS_DEFAULT "mtdparts=omap2-nand.0:512k(SPL),-(UBI)"
/* SPL */ -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
/* UBI configuration */ #define CONFIG_SPL_UBI 1 diff --git a/include/configs/am335x_shc.h b/include/configs/am335x_shc.h index f3b7767..d84d268 100644 --- a/include/configs/am335x_shc.h +++ b/include/configs/am335x_shc.h @@ -247,8 +247,6 @@
/* SPL */
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - #ifndef CONFIG_SPL_USBETH_SUPPORT #define CONFIG_FASTBOOT_FLASH_MMC_DEV 1 #endif diff --git a/include/configs/am335x_sl50.h b/include/configs/am335x_sl50.h index 75f9bef..7ea135e 100644 --- a/include/configs/am335x_sl50.h +++ b/include/configs/am335x_sl50.h @@ -78,8 +78,6 @@ #define CONFIG_BOOTCOUNT_AM33XX #define CONFIG_SYS_BOOTCOUNT_BE
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - #ifndef CONFIG_SPL_USBETH_SUPPORT #define CONFIG_FASTBOOT_FLASH_MMC_DEV 1 #endif diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 36adea7..2cdf4c8 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -258,7 +258,6 @@ #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
/* NAND boot config */ #define CONFIG_SYS_NAND_BUSWIDTH_16BIT diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 2f2e13c..ecbf835 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -306,6 +306,5 @@ #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
#endif /* __CONFIG_H */ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 4469167..181b28d 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -71,8 +71,6 @@ /* NS16550 Configuration */ #define CONFIG_SYS_NS16550_COM1 0x44e09000 /* Base EVM has UART0 */
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - /* SPL USB Support */
#if defined(CONFIG_SPL_USB_HOST_SUPPORT) || !defined(CONFIG_SPL_BUILD) diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 29cbbab..5c5d223 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -27,7 +27,6 @@ * SPL */ #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" -#define CONFIG_SPL_LDSCRIPT "arch/$(ARCH)/cpu/u-boot-spl.lds" #define CONFIG_SPL_MAX_SIZE 2048 #define CONFIG_SPL_TEXT_BASE 0xA0000000
diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index 019006a..ee6ab41 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -136,7 +136,6 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x70080000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00080000
-#define CONFIG_SPL_LDSCRIPT arch/arm/mach-at91/arm926ejs/u-boot-spl.lds #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index db04662..089b865 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -189,7 +189,6 @@ #define CONFIG_SYS_MCKR_CSS 0x1302
#ifdef CONFIG_SYS_USE_MMC -#define CONFIG_SPL_LDSCRIPT arch/arm/mach-at91/arm926ejs/u-boot-spl.lds #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 608be14..0cb8985 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -180,7 +180,6 @@ #define CONFIG_SYS_MCKR_CSS 0x1302
diff --git a/include/configs/baltos.h b/include/configs/baltos.h index aba7208..cfb2855 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -243,8 +243,6 @@ /* General network SPL, both CPSW and USB gadget RNDIS */ #define CONFIG_SPL_NET_VCI_STRING "AM335x U-Boot SPL"*/
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - #ifdef CONFIG_NAND #define CONFIG_NAND_OMAP_GPMC #define CONFIG_NAND_OMAP_GPMC_PREFETCH diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index fafab8e..7b6ca13 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -344,8 +344,6 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_SYS_BOOTCOUNT_BE
#ifdef CONFIG_NAND diff --git a/include/configs/bur_am335x_common.h b/include/configs/bur_am335x_common.h index 8d0e0ea..f54bb91 100644 --- a/include/configs/bur_am335x_common.h +++ b/include/configs/bur_am335x_common.h @@ -104,6 +104,5 @@ #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN
/* General parts of the framework, required. */ -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
#endif /* ! __BUR_AM335X_COMMON_H__ */ diff --git a/include/configs/chiliboard.h b/include/configs/chiliboard.h index 82be3a1..f42130e 100644 --- a/include/configs/chiliboard.h +++ b/include/configs/chiliboard.h @@ -129,8 +129,6 @@ #define CONFIG_BOOTCOUNT_AM33XX #define CONFIG_SYS_BOOTCOUNT_BE
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - /* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE #define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index ed7bb1d..cf8fea1 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -99,7 +99,6 @@ #define CONFIG_SYS_I2C_EEPROM_BUS 0
/* Network. */ #define CONFIG_PHY_GIGE diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index bdbbfdd..4670820 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -262,7 +262,6 @@ #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC #define CONFIG_SPL_OMAP3_ID_NAND -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
/* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 7a61107..1a819aa 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -100,8 +100,6 @@ #define CONFIG_ENV_OFFSET (768 * 1024) #define CONFIG_ENV_SPI_MAX_HZ 48000000
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x80200000\0" \ "fdtaddr=0x81200000\0" \ diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 695f3f6..6e2525a 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -296,7 +296,6 @@ CONFIG_SYS_MALLOC_LEN) #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN #define CONFIG_SPL_SPI_LOAD -#define CONFIG_SPL_LDSCRIPT "board/$(BOARDDIR)/u-boot-spl-da850evm.lds" #define CONFIG_SPL_STACK 0x8001ff00 #define CONFIG_SPL_TEXT_BASE 0x80000000 #define CONFIG_SPL_MAX_FOOTPRINT 32768 diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 31364c2..235b746 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -24,7 +24,6 @@ #define CONFIG_SPL_BSS_MAX_SIZE 0x0001ffff #define CONFIG_SYS_SPL_MALLOC_START 0x00040000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x0001ffff -#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/orion5x/u-boot-spl.lds" #define CONFIG_SYS_UBOOT_BASE 0xfff90000 #define CONFIG_SYS_UBOOT_START 0x00800000 #define CONFIG_SYS_TEXT_BASE 0x00800000 diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 3b73bbc..82eb444 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -49,7 +49,6 @@ #define CONFIG_SUPPORT_EMMC_BOOT
/* specific .lds file */ -#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds"
/* Boot Argument Buffer Size */ /* memtest works on */ diff --git a/include/configs/imx6_spl.h b/include/configs/imx6_spl.h index 9537112..cdb3a37 100644 --- a/include/configs/imx6_spl.h +++ b/include/configs/imx6_spl.h @@ -24,7 +24,6 @@ * and some padding thus 'our' max size is really 0x00908000 - 0x00918000 * or 64KB */ -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" #define CONFIG_SPL_TEXT_BASE 0x00908000 #define CONFIG_SPL_MAX_SIZE 0x10000 #define CONFIG_SPL_STACK 0x0091FFB8 diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index a21261f..fa455e7 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -266,7 +266,6 @@ #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE - \ CONFIG_SYS_MALLOC_LEN) #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN -#define CONFIG_SPL_LDSCRIPT "board/$(BOARDDIR)/u-boot-spl-ipam390.lds" #define CONFIG_SPL_STACK 0x8001ff00 #define CONFIG_SPL_TEXT_BASE 0x80000000 #define CONFIG_SPL_MAX_SIZE 0x20000 diff --git a/include/configs/kc1.h b/include/configs/kc1.h index f040d0b..eb1b63e 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -89,8 +89,6 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x80208000 #define CONFIG_SYS_SPL_MALLOC_SIZE (1024 * 1024)
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - /* * Console */ diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 58f893f..87bc3c6 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -76,7 +76,6 @@ #define CONFIG_SYS_FSL_PBL_RCW \ board/freescale/ls1021aiot/ls102xa_rcw_sd.cfg #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_LDSCRIPT "arch/$(ARCH)/cpu/u-boot-spl.lds" #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT #define CONFIG_SPL_ENV_SUPPORT diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index bd05b45..fef9ca8 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -52,7 +52,6 @@ unsigned long get_board_ddr_clk(void); board/freescale/ls1021aqds/ls102xa_rcw_sd_ifc.cfg #endif #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_LDSCRIPT "arch/$(ARCH)/cpu/u-boot-spl.lds"
#define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x1a000 @@ -75,7 +74,6 @@ unsigned long get_board_ddr_clk(void); #ifdef CONFIG_NAND_BOOT #define CONFIG_SYS_FSL_PBL_RCW board/freescale/ls1021aqds/ls102xa_rcw_nand.cfg #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_LDSCRIPT "arch/$(ARCH)/cpu/u-boot-spl.lds"
#define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x1a000 diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 0aa6fdd..9078599 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -95,7 +95,6 @@ board/freescale/ls1021atwr/ls102xa_rcw_sd_ifc.cfg #endif #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_LDSCRIPT "arch/$(ARCH)/cpu/u-boot-spl.lds"
#ifdef CONFIG_SECURE_BOOT /* diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 32f7162..bc40ec0 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -66,7 +66,6 @@ /* SD boot SPL */ #ifdef CONFIG_SD_BOOT #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_TARGET "u-boot-with-spl.bin"
#define CONFIG_SPL_TEXT_BASE 0x10000000 @@ -98,7 +97,6 @@ #ifdef CONFIG_NAND_BOOT #define CONFIG_SPL_PBL_PAD #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_TEXT_BASE 0x10000000 #define CONFIG_SPL_MAX_SIZE 0x1a000 diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index 1b91676..1ad6600 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -64,7 +64,6 @@ /* SD boot SPL */ #ifdef CONFIG_SD_BOOT #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT @@ -104,7 +103,6 @@ #ifdef CONFIG_NAND_BOOT #define CONFIG_SPL_PBL_PAD #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" #define CONFIG_SPL_LIBCOMMON_SUPPORT #define CONFIG_SPL_LIBGENERIC_SUPPORT diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 6ae5586..582bc1a 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -233,7 +233,6 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SPL_BSS_START_ADDR 0x80100000 #define CONFIG_SPL_BSS_MAX_SIZE 0x00100000 #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv8/u-boot-spl.lds" #define CONFIG_SPL_MAX_SIZE 0x16000 #define CONFIG_SPL_STACK (CONFIG_SYS_FSL_OCRAM_BASE + 0x9ff0) #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index 7c28a94..0d6977c 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -214,7 +214,6 @@ #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x10000
#define CONFIG_SYS_USE_MMC -#define CONFIG_SPL_LDSCRIPT arch/arm/mach-at91/armv7/u-boot-spl.lds #define CONFIG_SPL_MMC_SUPPORT #define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x200 #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 9138452..f42c08f 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -286,7 +286,6 @@ #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
#define CONFIG_SPL_TEXT_BASE 0x40200000 /*CONFIG_SYS_SRAM_START*/ #define CONFIG_SPL_MAX_SIZE (54 * 1024) /* 8 KB for stack */ diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index aa007e2..5036b1c 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -258,8 +258,6 @@ #define CONFIG_CMD_SPL #define CONFIG_SPL_FRAMEWORK
-#define CONFIG_SPL_LDSCRIPT "arch/microblaze/cpu/u-boot-spl.lds" - #ifdef CONFIG_SYS_FLASH_BASE # define CONFIG_SYS_UBOOT_BASE CONFIG_SYS_FLASH_BASE #endif diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 3b776b1..2bb24a1 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -26,7 +26,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_MX31_3DS
#define CONFIG_SPL_TEXT_BASE 0x87dc0000 diff --git a/include/configs/mxs.h b/include/configs/mxs.h index 041dcde..804b9e1 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -46,7 +46,6 @@ /* SPL */ #define CONFIG_SPL_NO_CPU_SUPPORT_CODE #define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/mxs" -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds"
/* Memory sizes */ #define CONFIG_SYS_MALLOC_LEN 0x00400000 /* 4 MB for malloc */ diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 70cd0ea..35662fe 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -307,7 +307,6 @@ #define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */
/* * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index 08e7deb..cbdaf09 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -311,7 +311,6 @@ #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_TEXT_BASE - \ CONFIG_SYS_MALLOC_LEN) #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN -#define CONFIG_SPL_LDSCRIPT "board/$(BOARDDIR)/u-boot-spl-da850evm.lds" #define CONFIG_SPL_STACK 0x8001ff00 #define CONFIG_SPL_TEXT_BASE 0x80000000 #define CONFIG_SPL_MAX_FOOTPRINT 32768 diff --git a/include/configs/origen.h b/include/configs/origen.h index c363653..69f6930 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -95,7 +95,6 @@ #define BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ #define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE)
-#define CONFIG_SPL_LDSCRIPT "board/samsung/common/exynos-uboot-spl.lds" #define CONFIG_SPL_MAX_FOOTPRINT (14 * 1024)
#define CONFIG_SYS_INIT_SP_ADDR 0x02040000 diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index ce80e7e..585f370 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -117,8 +117,6 @@
/* CPU */
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - #ifdef CONFIG_SPI_BOOT #define CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index dbe0ddd..acad8b1 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -198,6 +198,4 @@
/* CPSW support */
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - #endif /* ! __CONFIG_PENGWYN_H */ diff --git a/include/configs/pepper.h b/include/configs/pepper.h index ff3cd74..afeb297 100644 --- a/include/configs/pepper.h +++ b/include/configs/pepper.h @@ -85,6 +85,5 @@ #define CONFIG_PHY_RESET_DELAY 1000
#endif /* __CONFIG_PEPPER_H */ diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 4e64eac..c8ab542 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -141,7 +141,6 @@ #define CONFIG_SYS_SPL_MALLOC_START 0x20080000 #define CONFIG_SYS_SPL_MALLOC_SIZE 0x00080000
diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index 13d454f..72beb25 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -77,7 +77,6 @@ #define CONFIG_SYS_MONITOR_LEN (512 << 10)
#ifdef CONFIG_SYS_USE_MMC -#define CONFIG_SPL_LDSCRIPT arch/arm/mach-at91/armv7/u-boot-spl.lds #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index cc12521..05600c8 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -87,7 +87,6 @@ #define CONFIG_SYS_MONITOR_LEN (512 << 10)
diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 83b527c..cd8d742 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -120,7 +120,6 @@ #define CONFIG_SYS_MONITOR_LEN (512 << 10)
diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index f0c8026..c8462b0 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -76,7 +76,6 @@ #define CONFIG_SYS_MONITOR_LEN (512 << 10)
diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index ab858ce..fc16ed0 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -74,7 +74,6 @@ #define CONFIG_SYS_MONITOR_LEN (512 << 10)
diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 5a5bf7a..a6c6605 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -121,8 +121,6 @@ #define CONFIG_SPL_SPI_LOAD #define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - #define CONFIG_SPL_NAND_AM33XX_BCH #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index cc83b98..d7648ec 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -223,7 +223,6 @@ #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SPL_BSS_START_ADDR + \ CONFIG_SPL_BSS_MAX_SIZE) #define CONFIG_SYS_SPL_MALLOC_SIZE CONFIG_SYS_MALLOC_LEN -#define CONFIG_SPL_LDSCRIPT arch/arm/mach-at91/arm926ejs/u-boot-spl.lds
#define CONFIG_SYS_NAND_ENABLE_PIN_SPL (2*32 + 14) #define CONFIG_SYS_USE_NANDFLASH 1 diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 9986a3b..79bd3a2 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -79,7 +79,6 @@ #define BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ #define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE)
#define CONFIG_SYS_INIT_SP_ADDR 0x02040000 diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 669ce85..f5e74c3 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -86,8 +86,6 @@ #define CONFIG_SYS_SPL_MALLOC_SIZE (1024 * 1024) #define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img"
diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 681c91c..77f2a4e 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -202,10 +202,6 @@
-#ifndef CONFIG_ARM64 -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/armv7/sunxi/u-boot-spl.lds" -#endif - #define CONFIG_SPL_PAD_TO 32768 /* decimal for 'dd' */
diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index b695d8d..2e1a5b7 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -172,7 +172,6 @@ #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
#define CONFIG_SPL_TEXT_BASE 0x40200000 /*CONFIG_SYS_SRAM_START*/ #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 3dd7a9b..351b9dc 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -243,7 +243,6 @@ #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC #define CONFIG_SPL_OMAP3_ID_NAND -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
/* NAND boot config */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index b5f8177..f0866f7 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -149,7 +149,6 @@
#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 #define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000 -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
/* * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index bba10ec..3da774f 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -118,8 +118,6 @@ #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE)
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" - #define CONFIG_SYS_TEXT_BASE 0x80800000
#define CONFIG_DRIVER_TI_EMAC diff --git a/include/configs/ti_omap3_common.h b/include/configs/ti_omap3_common.h index 393d867..938136c 100644 --- a/include/configs/ti_omap3_common.h +++ b/include/configs/ti_omap3_common.h @@ -60,7 +60,6 @@
/* SPL */ #define CONFIG_SPL_TEXT_BASE 0x40200800 -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (64 << 20))
diff --git a/include/configs/ti_omap4_common.h b/include/configs/ti_omap4_common.h index 1a6551e..1d9e59d 100644 --- a/include/configs/ti_omap4_common.h +++ b/include/configs/ti_omap4_common.h @@ -139,7 +139,6 @@ * So moving TEXT_BASE down to non-HS limit. */ #define CONFIG_SPL_TEXT_BASE 0x40300000 -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (128 << 20))
diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 4c3a276..73c1d8f 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -100,7 +100,6 @@ #define CONFIG_SPL_TEXT_BASE 0x40300000 #endif
diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 6e80e5b..dac847e 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -260,7 +260,6 @@ #define CONFIG_SPL_NAND_BASE #define CONFIG_SPL_NAND_DRIVERS #define CONFIG_SPL_NAND_ECC -#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds" #define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1
diff --git a/include/configs/woodburn_sd.h b/include/configs/woodburn_sd.h index bab7fdf..fb73856 100644 --- a/include/configs/woodburn_sd.h +++ b/include/configs/woodburn_sd.h @@ -21,7 +21,6 @@ * SPL */ #define CONFIG_SPL_FRAMEWORK -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm1136/u-boot-spl.lds"
#define CONFIG_SPL_TEXT_BASE 0x10002300 #define CONFIG_SPL_MAX_SIZE (64 * 1024) /* 8 KB for stack */ diff --git a/include/configs/x600.h b/include/configs/x600.h index a8435d8..63d0fac 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -245,7 +245,6 @@ #define CONFIG_SPL_TEXT_BASE 0xd2800b00 #define CONFIG_SPL_MAX_SIZE (CONFIG_SRAM_SIZE - 0xb00) #define CONFIG_SPL_START_S_PATH "arch/arm/cpu/arm926ejs/spear" -#define CONFIG_SPL_LDSCRIPT "arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds"
diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 4975d76..2858edb 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -274,8 +274,6 @@ #define CONFIG_CMD_SPL #define CONFIG_SPL_FRAMEWORK
-#define CONFIG_SPL_LDSCRIPT "arch/arm/mach-zynq/u-boot-spl.lds" - /* MMC support */ #ifdef CONFIG_MMC_SDHCI_ZYNQ #define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1
With the new way of doing things (i.e. the hierarchical selection of SPL_LDSCRIPT via Kconfig) in place, this moves the SPL_LDSCRIPT setting for the RK3368 from defconfig back into Kconfig.
With this done, there should be no lingering cases of SPL_LDSCRIPT outside of Kconfig files.
arch/arm/mach-rockchip/rk3368/Kconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/mach-rockchip/rk3368/Kconfig b/arch/arm/mach-rockchip/rk3368/Kconfig index f8189f1..7c9b722 100644 --- a/arch/arm/mach-rockchip/rk3368/Kconfig +++ b/arch/arm/mach-rockchip/rk3368/Kconfig @@ -50,4 +50,7 @@ source "board/rockchip/sheep_rk3368/Kconfig" source "board/geekbuying/geekbox/Kconfig" source "board/rockchip/evb_px5/Kconfig"
+config SPL_LDSCRIPT + default "arch/arm/cpu/armv8/u-boot-spl.lds" + endif
Philipp Tomsich
