[U-Boot] [PATCH v3 00/13] dm: pci: Support native driver model calls
At present driver model supports PCI, but most of the code in U-Boot still uses the old API.
This series changes the 'pci' command so that the new API is used. The old API is placed behind a 'compatibility' option. The overall goal is to deprecate the old API and remove all use of it. The auto-config and device finding will be the subject of future patches.
Changes in v3: - Use 'Show' instead of 'Shows' in the the pci_header_show() function comment - Fix mix-up between PCI_SIZE_xx and byte size - Fix 'switch (cmd)' merge error
Changes in v2: - Squash in the patch to fix pci_field_width() for 32-bit values - Rename '_byte' to class in pci_header_show() - Fix 'autoconfiguration' typo - Fix merge error in pciauto_setup_device() which removed needed code - Add a new patch to update the function comments - Add back the leading 0 in the printf() statements - Refactor the patch based on dropping the earlier refactor patch - Make pciinfo() static - Drop patch: pci: Move 'pci scan' code in with other commands - Move dm_pciauto_config_device() out of CONFIG_DM_PCI_COMPAT
Simon Glass (13): pci: Use a common return in command processing pci: Use a separate variable for the bus number pci: Refactor the pciinfo() function dm: pci: Add a comment about how to find struct pci_controller dm: pci: Rename pci_auto.c to pci_auto_old.c dm: pci: Move common auto-config functions to a common file dm: pci: Reorder functions in cmd_pci.c pci: Tidy up function comments in cmd_pci.c pci: Use common functions to read/write config pci: Use a separate 'dev' variable for the PCI device pci: Move PCI header output code into its own function dm: pci: Convert 'pci' command to driver model dm: pci: Disable PCI compatibility functions by default
arch/arm/mach-tegra/Kconfig | 1 + arch/x86/Kconfig | 3 + common/cmd_pci.c | 631 ++++++++++++++++++----------- configs/sandbox_defconfig | 1 + drivers/pci/Kconfig | 9 + drivers/pci/Makefile | 5 +- drivers/pci/pci_auto_common.c | 128 ++++++ drivers/pci/{pci_auto.c => pci_auto_old.c} | 116 ------ include/common.h | 1 - include/pci.h | 32 +- 10 files changed, 576 insertions(+), 351 deletions(-) create mode 100644 drivers/pci/pci_auto_common.c rename drivers/pci/{pci_auto.c => pci_auto_old.c} (81%)
Adjust the commands to return from the same place.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
common/cmd_pci.c | 19 +++++++++++++------ 1 file changed, 13 insertions(+), 6 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index 2eafd5c..f3148a3 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -410,6 +410,7 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) ulong addr = 0, value = 0, size = 0; pci_dev_t bdf = 0; char cmd = 's'; + int ret = 0;
if (argc > 1) cmd = argv[1][0]; @@ -453,7 +454,7 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) switch (argv[1][0]) { case 'h': /* header */ pci_header_show(bdf); - return 0; + break; case 'd': /* display */ return pci_cfg_display(bdf, addr, size, value); #ifdef CONFIG_CMD_PCI_ENUM @@ -463,23 +464,29 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) # else pci_init(); # endif - return 0; + break; #endif case 'n': /* next */ if (argc < 4) goto usage; - return pci_cfg_modify(bdf, addr, size, value, 0); + ret = pci_cfg_modify(bdf, addr, size, value, 0); + break; case 'm': /* modify */ if (argc < 4) goto usage; - return pci_cfg_modify(bdf, addr, size, value, 1); + ret = pci_cfg_modify(bdf, addr, size, value, 1); + break; case 'w': /* write */ if (argc < 5) goto usage; - return pci_cfg_write(bdf, addr, size, value); + ret = pci_cfg_write(bdf, addr, size, value); + break; + default: + ret = CMD_RET_USAGE; + break; }
- return 1; + return ret; usage: return CMD_RET_USAGE; }
Applied to u-boot-dm.
At present in do_pci(), bdf can either mean a bus number or a PCI bus number. Use separate variables instead to reduce confusion.
common/cmd_pci.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index f3148a3..bed880c 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -408,6 +408,7 @@ pci_cfg_modify (pci_dev_t bdf, ulong addr, ulong size, ulong value, int incrflag static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { ulong addr = 0, value = 0, size = 0; + int busnum = 0; pci_dev_t bdf = 0; char cmd = 's'; int ret = 0; @@ -438,16 +439,15 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #endif default: /* scan bus */ value = 1; /* short listing */ - bdf = 0; /* bus number */ if (argc > 1) { if (argv[argc-1][0] == 'l') { value = 0; argc--; } if (argc > 1) - bdf = simple_strtoul(argv[1], NULL, 16); + busnum = simple_strtoul(argv[1], NULL, 16); } - pciinfo(bdf, value); + pciinfo(busnum, value); return 0; }
This function uses macros to output data. It seems better to use a table of registers rather than macro-based code generation. It also reduces the code/data size by 2KB on ARM.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v3: None Changes in v2: - Squash in the patch to fix pci_field_width() for 32-bit values - Rename '_byte' to class in pci_header_show()
common/cmd_pci.c | 237 ++++++++++++++++++++++++++++++++++--------------------- 1 file changed, 148 insertions(+), 89 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index bed880c..190e3b6 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -131,6 +131,145 @@ void pci_header_show_brief(pci_dev_t dev) pci_class_str(class), subclass); }
+struct pci_reg_info { + const char *name; + enum pci_size_t size; + u8 offset; +}; + +static int pci_field_width(enum pci_size_t size) +{ + switch (size) { + case PCI_SIZE_8: + return 2; + case PCI_SIZE_16: + return 4; + case PCI_SIZE_32: + default: + return 8; + } +} + +static unsigned long pci_read_config(pci_dev_t dev, int offset, + enum pci_size_t size) +{ + u32 val32; + u16 val16; + u8 val8; + + switch (size) { + case PCI_SIZE_8: + pci_read_config_byte(dev, offset, &val8); + return val8; + case PCI_SIZE_16: + pci_read_config_word(dev, offset, &val16); + return val16; + case PCI_SIZE_32: + default: + pci_read_config_dword(dev, offset, &val32); + return val32; + } +} + +static void pci_show_regs(pci_dev_t dev, struct pci_reg_info *regs) +{ + for (; regs->name; regs++) { + printf(" %s =%*s%#.*lx\n", regs->name, + (int)(28 - strlen(regs->name)), "", + pci_field_width(regs->size), + pci_read_config(dev, regs->offset, regs->size)); + } +} + +static struct pci_reg_info regs_start[] = { + { "vendor ID", PCI_SIZE_16, PCI_VENDOR_ID }, + { "device ID", PCI_SIZE_16, PCI_DEVICE_ID }, + { "command register ID", PCI_SIZE_16, PCI_COMMAND }, + { "status register", PCI_SIZE_16, PCI_STATUS }, + { "revision ID", PCI_SIZE_8, PCI_REVISION_ID }, + {}, +}; + +static struct pci_reg_info regs_rest[] = { + { "sub class code", PCI_SIZE_8, PCI_CLASS_SUB_CODE }, + { "programming interface", PCI_SIZE_8, PCI_CLASS_PROG }, + { "cache line", PCI_SIZE_8, PCI_CACHE_LINE_SIZE }, + { "latency time", PCI_SIZE_8, PCI_LATENCY_TIMER }, + { "header type", PCI_SIZE_8, PCI_HEADER_TYPE }, + { "BIST", PCI_SIZE_8, PCI_BIST }, + { "base address 0", PCI_SIZE_32, PCI_BASE_ADDRESS_0 }, + {}, +}; + +static struct pci_reg_info regs_normal[] = { + { "base address 1", PCI_SIZE_32, PCI_BASE_ADDRESS_1 }, + { "base address 2", PCI_SIZE_32, PCI_BASE_ADDRESS_2 }, + { "base address 3", PCI_SIZE_32, PCI_BASE_ADDRESS_3 }, + { "base address 4", PCI_SIZE_32, PCI_BASE_ADDRESS_4 }, + { "base address 5", PCI_SIZE_32, PCI_BASE_ADDRESS_5 }, + { "cardBus CIS pointer", PCI_SIZE_32, PCI_CARDBUS_CIS }, + { "sub system vendor ID", PCI_SIZE_16, PCI_SUBSYSTEM_VENDOR_ID }, + { "sub system ID", PCI_SIZE_16, PCI_SUBSYSTEM_ID }, + { "expansion ROM base address", PCI_SIZE_32, PCI_ROM_ADDRESS }, + { "interrupt line", PCI_SIZE_8, PCI_INTERRUPT_LINE }, + { "interrupt pin", PCI_SIZE_8, PCI_INTERRUPT_PIN }, + { "min Grant", PCI_SIZE_8, PCI_MIN_GNT }, + { "max Latency", PCI_SIZE_8, PCI_MAX_LAT }, + {}, +}; + +static struct pci_reg_info regs_bridge[] = { + { "base address 1", PCI_SIZE_32, PCI_BASE_ADDRESS_1 }, + { "primary bus number", PCI_SIZE_8, PCI_PRIMARY_BUS }, + { "secondary bus number", PCI_SIZE_8, PCI_SECONDARY_BUS }, + { "subordinate bus number", PCI_SIZE_8, PCI_SUBORDINATE_BUS }, + { "secondary latency timer", PCI_SIZE_8, PCI_SEC_LATENCY_TIMER }, + { "IO base", PCI_SIZE_8, PCI_IO_BASE }, + { "IO limit", PCI_SIZE_8, PCI_IO_LIMIT }, + { "secondary status", PCI_SIZE_16, PCI_SEC_STATUS }, + { "memory base", PCI_SIZE_16, PCI_MEMORY_BASE }, + { "memory limit", PCI_SIZE_16, PCI_MEMORY_LIMIT }, + { "prefetch memory base", PCI_SIZE_16, PCI_PREF_MEMORY_BASE }, + { "prefetch memory limit", PCI_SIZE_16, PCI_PREF_MEMORY_LIMIT }, + { "prefetch memory base upper", PCI_SIZE_32, PCI_PREF_BASE_UPPER32 }, + { "prefetch memory limit upper", PCI_SIZE_32, PCI_PREF_LIMIT_UPPER32 }, + { "IO base upper 16 bits", PCI_SIZE_16, PCI_IO_BASE_UPPER16 }, + { "IO limit upper 16 bits", PCI_SIZE_16, PCI_IO_LIMIT_UPPER16 }, + { "expansion ROM base address", PCI_SIZE_32, PCI_ROM_ADDRESS1 }, + { "interrupt line", PCI_SIZE_8, PCI_INTERRUPT_LINE }, + { "interrupt pin", PCI_SIZE_8, PCI_INTERRUPT_PIN }, + { "bridge control", PCI_SIZE_16, PCI_BRIDGE_CONTROL }, + {}, +}; + +static struct pci_reg_info regs_cardbus[] = { + { "capabilities", PCI_SIZE_8, PCI_CB_CAPABILITY_LIST }, + { "secondary status", PCI_SIZE_16, PCI_CB_SEC_STATUS }, + { "primary bus number", PCI_SIZE_8, PCI_CB_PRIMARY_BUS }, + { "CardBus number", PCI_SIZE_8, PCI_CB_CARD_BUS }, + { "subordinate bus number", PCI_SIZE_8, PCI_CB_SUBORDINATE_BUS }, + { "CardBus latency timer", PCI_SIZE_8, PCI_CB_LATENCY_TIMER }, + { "CardBus memory base 0", PCI_SIZE_32, PCI_CB_MEMORY_BASE_0 }, + { "CardBus memory limit 0", PCI_SIZE_32, PCI_CB_MEMORY_LIMIT_0 }, + { "CardBus memory base 1", PCI_SIZE_32, PCI_CB_MEMORY_BASE_1 }, + { "CardBus memory limit 1", PCI_SIZE_32, PCI_CB_MEMORY_LIMIT_1 }, + { "CardBus IO base 0", PCI_SIZE_16, PCI_CB_IO_BASE_0 }, + { "CardBus IO base high 0", PCI_SIZE_16, PCI_CB_IO_BASE_0_HI }, + { "CardBus IO limit 0", PCI_SIZE_16, PCI_CB_IO_LIMIT_0 }, + { "CardBus IO limit high 0", PCI_SIZE_16, PCI_CB_IO_LIMIT_0_HI }, + { "CardBus IO base 1", PCI_SIZE_16, PCI_CB_IO_BASE_1 }, + { "CardBus IO base high 1", PCI_SIZE_16, PCI_CB_IO_BASE_1_HI }, + { "CardBus IO limit 1", PCI_SIZE_16, PCI_CB_IO_LIMIT_1 }, + { "CardBus IO limit high 1", PCI_SIZE_16, PCI_CB_IO_LIMIT_1_HI }, + { "interrupt line", PCI_SIZE_8, PCI_INTERRUPT_LINE }, + { "interrupt pin", PCI_SIZE_8, PCI_INTERRUPT_PIN }, + { "bridge control", PCI_SIZE_16, PCI_CB_BRIDGE_CONTROL }, + { "subvendor ID", PCI_SIZE_16, PCI_CB_SUBSYSTEM_VENDOR_ID }, + { "subdevice ID", PCI_SIZE_16, PCI_CB_SUBSYSTEM_ID }, + { "PC Card 16bit base address", PCI_SIZE_32, PCI_CB_LEGACY_MODE_BASE }, + {}, +}; + /* * Subroutine: PCI_Header_Show * @@ -143,111 +282,31 @@ void pci_header_show_brief(pci_dev_t dev) */ void pci_header_show(pci_dev_t dev) { - u8 _byte, header_type; - u16 _word; - u32 _dword; - -#define PRINT(msg, type, reg) \ - pci_read_config_##type(dev, reg, &_##type); \ - printf(msg, _##type) - -#define PRINT2(msg, type, reg, func) \ - pci_read_config_##type(dev, reg, &_##type); \ - printf(msg, _##type, func(_##type)) + u8 class, header_type;
pci_read_config_byte(dev, PCI_HEADER_TYPE, &header_type); + pci_show_regs(dev, regs_start);
- PRINT (" vendor ID = 0x%.4x\n", word, PCI_VENDOR_ID); - PRINT (" device ID = 0x%.4x\n", word, PCI_DEVICE_ID); - PRINT (" command register = 0x%.4x\n", word, PCI_COMMAND); - PRINT (" status register = 0x%.4x\n", word, PCI_STATUS); - PRINT (" revision ID = 0x%.2x\n", byte, PCI_REVISION_ID); - PRINT2(" class code = 0x%.2x (%s)\n", byte, PCI_CLASS_CODE, - pci_class_str); - PRINT (" sub class code = 0x%.2x\n", byte, PCI_CLASS_SUB_CODE); - PRINT (" programming interface = 0x%.2x\n", byte, PCI_CLASS_PROG); - PRINT (" cache line = 0x%.2x\n", byte, PCI_CACHE_LINE_SIZE); - PRINT (" latency time = 0x%.2x\n", byte, PCI_LATENCY_TIMER); - PRINT (" header type = 0x%.2x\n", byte, PCI_HEADER_TYPE); - PRINT (" BIST = 0x%.2x\n", byte, PCI_BIST); - PRINT (" base address 0 = 0x%.8x\n", dword, PCI_BASE_ADDRESS_0); + pci_read_config_byte(dev, PCI_CLASS_CODE, &class); + printf(" class code = 0x%.2x (%s)\n", class, + pci_class_str(class)); + pci_show_regs(dev, regs_rest);
switch (header_type & 0x03) { case PCI_HEADER_TYPE_NORMAL: /* "normal" PCI device */ - PRINT (" base address 1 = 0x%.8x\n", dword, PCI_BASE_ADDRESS_1); - PRINT (" base address 2 = 0x%.8x\n", dword, PCI_BASE_ADDRESS_2); - PRINT (" base address 3 = 0x%.8x\n", dword, PCI_BASE_ADDRESS_3); - PRINT (" base address 4 = 0x%.8x\n", dword, PCI_BASE_ADDRESS_4); - PRINT (" base address 5 = 0x%.8x\n", dword, PCI_BASE_ADDRESS_5); - PRINT (" cardBus CIS pointer = 0x%.8x\n", dword, PCI_CARDBUS_CIS); - PRINT (" sub system vendor ID = 0x%.4x\n", word, PCI_SUBSYSTEM_VENDOR_ID); - PRINT (" sub system ID = 0x%.4x\n", word, PCI_SUBSYSTEM_ID); - PRINT (" expansion ROM base address = 0x%.8x\n", dword, PCI_ROM_ADDRESS); - PRINT (" interrupt line = 0x%.2x\n", byte, PCI_INTERRUPT_LINE); - PRINT (" interrupt pin = 0x%.2x\n", byte, PCI_INTERRUPT_PIN); - PRINT (" min Grant = 0x%.2x\n", byte, PCI_MIN_GNT); - PRINT (" max Latency = 0x%.2x\n", byte, PCI_MAX_LAT); + pci_show_regs(dev, regs_normal); break; - case PCI_HEADER_TYPE_BRIDGE: /* PCI-to-PCI bridge */ - - PRINT (" base address 1 = 0x%.8x\n", dword, PCI_BASE_ADDRESS_1); - PRINT (" primary bus number = 0x%.2x\n", byte, PCI_PRIMARY_BUS); - PRINT (" secondary bus number = 0x%.2x\n", byte, PCI_SECONDARY_BUS); - PRINT (" subordinate bus number = 0x%.2x\n", byte, PCI_SUBORDINATE_BUS); - PRINT (" secondary latency timer = 0x%.2x\n", byte, PCI_SEC_LATENCY_TIMER); - PRINT (" IO base = 0x%.2x\n", byte, PCI_IO_BASE); - PRINT (" IO limit = 0x%.2x\n", byte, PCI_IO_LIMIT); - PRINT (" secondary status = 0x%.4x\n", word, PCI_SEC_STATUS); - PRINT (" memory base = 0x%.4x\n", word, PCI_MEMORY_BASE); - PRINT (" memory limit = 0x%.4x\n", word, PCI_MEMORY_LIMIT); - PRINT (" prefetch memory base = 0x%.4x\n", word, PCI_PREF_MEMORY_BASE); - PRINT (" prefetch memory limit = 0x%.4x\n", word, PCI_PREF_MEMORY_LIMIT); - PRINT (" prefetch memory base upper = 0x%.8x\n", dword, PCI_PREF_BASE_UPPER32); - PRINT (" prefetch memory limit upper = 0x%.8x\n", dword, PCI_PREF_LIMIT_UPPER32); - PRINT (" IO base upper 16 bits = 0x%.4x\n", word, PCI_IO_BASE_UPPER16); - PRINT (" IO limit upper 16 bits = 0x%.4x\n", word, PCI_IO_LIMIT_UPPER16); - PRINT (" expansion ROM base address = 0x%.8x\n", dword, PCI_ROM_ADDRESS1); - PRINT (" interrupt line = 0x%.2x\n", byte, PCI_INTERRUPT_LINE); - PRINT (" interrupt pin = 0x%.2x\n", byte, PCI_INTERRUPT_PIN); - PRINT (" bridge control = 0x%.4x\n", word, PCI_BRIDGE_CONTROL); + pci_show_regs(dev, regs_bridge); break; - case PCI_HEADER_TYPE_CARDBUS: /* PCI-to-CardBus bridge */ - - PRINT (" capabilities = 0x%.2x\n", byte, PCI_CB_CAPABILITY_LIST); - PRINT (" secondary status = 0x%.4x\n", word, PCI_CB_SEC_STATUS); - PRINT (" primary bus number = 0x%.2x\n", byte, PCI_CB_PRIMARY_BUS); - PRINT (" CardBus number = 0x%.2x\n", byte, PCI_CB_CARD_BUS); - PRINT (" subordinate bus number = 0x%.2x\n", byte, PCI_CB_SUBORDINATE_BUS); - PRINT (" CardBus latency timer = 0x%.2x\n", byte, PCI_CB_LATENCY_TIMER); - PRINT (" CardBus memory base 0 = 0x%.8x\n", dword, PCI_CB_MEMORY_BASE_0); - PRINT (" CardBus memory limit 0 = 0x%.8x\n", dword, PCI_CB_MEMORY_LIMIT_0); - PRINT (" CardBus memory base 1 = 0x%.8x\n", dword, PCI_CB_MEMORY_BASE_1); - PRINT (" CardBus memory limit 1 = 0x%.8x\n", dword, PCI_CB_MEMORY_LIMIT_1); - PRINT (" CardBus IO base 0 = 0x%.4x\n", word, PCI_CB_IO_BASE_0); - PRINT (" CardBus IO base high 0 = 0x%.4x\n", word, PCI_CB_IO_BASE_0_HI); - PRINT (" CardBus IO limit 0 = 0x%.4x\n", word, PCI_CB_IO_LIMIT_0); - PRINT (" CardBus IO limit high 0 = 0x%.4x\n", word, PCI_CB_IO_LIMIT_0_HI); - PRINT (" CardBus IO base 1 = 0x%.4x\n", word, PCI_CB_IO_BASE_1); - PRINT (" CardBus IO base high 1 = 0x%.4x\n", word, PCI_CB_IO_BASE_1_HI); - PRINT (" CardBus IO limit 1 = 0x%.4x\n", word, PCI_CB_IO_LIMIT_1); - PRINT (" CardBus IO limit high 1 = 0x%.4x\n", word, PCI_CB_IO_LIMIT_1_HI); - PRINT (" interrupt line = 0x%.2x\n", byte, PCI_INTERRUPT_LINE); - PRINT (" interrupt pin = 0x%.2x\n", byte, PCI_INTERRUPT_PIN); - PRINT (" bridge control = 0x%.4x\n", word, PCI_CB_BRIDGE_CONTROL); - PRINT (" subvendor ID = 0x%.4x\n", word, PCI_CB_SUBSYSTEM_VENDOR_ID); - PRINT (" subdevice ID = 0x%.4x\n", word, PCI_CB_SUBSYSTEM_ID); - PRINT (" PC Card 16bit base address = 0x%.8x\n", dword, PCI_CB_LEGACY_MODE_BASE); + pci_show_regs(dev, regs_cardbus); break;
default: printf("unknown header\n"); break; } - -#undef PRINT -#undef PRINT2 }
/* Convert the "bus.device.function" identifier into a number.
With driver mode, struct pci_controller is stored as uclass-private data. Add a comment to that effect.
include/pci.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/pci.h b/include/pci.h index 9c19482..c4f6577 100644 --- a/include/pci.h +++ b/include/pci.h @@ -537,6 +537,8 @@ extern void pci_cfgfunc_config_device(struct pci_controller* hose, pci_dev_t dev
/* * Structure of a PCI controller (host bridge) + * + * With driver model this is dev_get_uclass_priv(bus) */ struct pci_controller { #ifdef CONFIG_DM_PCI
This file should not be used with driver model as it has lots of legacy/ compatibility functions. Rename it to make this clear.
drivers/pci/Makefile | 2 +- drivers/pci/{pci_auto.c => pci_auto_old.c} | 0 2 files changed, 1 insertion(+), 1 deletion(-) rename drivers/pci/{pci_auto.c => pci_auto_old.c} (100%)
diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index bcf8127..dee844f 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -13,7 +13,7 @@ obj-$(CONFIG_X86) += pci_x86.o else obj-$(CONFIG_PCI) += pci.o endif -obj-$(CONFIG_PCI) += pci_common.o pci_auto.o pci_rom.o +obj-$(CONFIG_PCI) += pci_common.o pci_auto_old.o pci_rom.o
obj-$(CONFIG_FSL_PCI_INIT) += fsl_pci_init.o obj-$(CONFIG_PCI_INDIRECT_BRIDGE) += pci_indirect.o diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto_old.c similarity index 100% rename from drivers/pci/pci_auto.c rename to drivers/pci/pci_auto_old.c
Some functions will be used by driver model and legacy PCI code. To avoid duplication, put these in a separate, shared file.
Changes in v3: None Changes in v2: - Fix 'autoconfiguration' typo - Fix merge error in pciauto_setup_device() which removed needed code
drivers/pci/Makefile | 2 +- drivers/pci/pci_auto_common.c | 128 ++++++++++++++++++++++++++++++++++++++++++ drivers/pci/pci_auto_old.c | 116 -------------------------------------- 3 files changed, 129 insertions(+), 117 deletions(-) create mode 100644 drivers/pci/pci_auto_common.c
diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index dee844f..1f8f86f 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -13,7 +13,7 @@ obj-$(CONFIG_X86) += pci_x86.o else obj-$(CONFIG_PCI) += pci.o endif -obj-$(CONFIG_PCI) += pci_common.o pci_auto_old.o pci_rom.o +obj-$(CONFIG_PCI) += pci_auto_common.o pci_auto_old.o pci_common.o pci_rom.o
obj-$(CONFIG_FSL_PCI_INIT) += fsl_pci_init.o obj-$(CONFIG_PCI_INDIRECT_BRIDGE) += pci_indirect.o diff --git a/drivers/pci/pci_auto_common.c b/drivers/pci/pci_auto_common.c new file mode 100644 index 0000000..85c419e --- /dev/null +++ b/drivers/pci/pci_auto_common.c @@ -0,0 +1,128 @@ +/* + * PCI auto-configuration library + * + * Author: Matt Porter mporter@mvista.com + * + * Copyright 2000 MontaVista Software Inc. + * + * Modifications for driver model: + * Copyright 2015 Google, Inc + * Written by Simon Glass sjg@chromium.org + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <pci.h> + +void pciauto_region_init(struct pci_region *res) +{ + /* + * Avoid allocating PCI resources from address 0 -- this is illegal + * according to PCI 2.1 and moreover, this is known to cause Linux IDE + * drivers to fail. Use a reasonable starting value of 0x1000 instead. + */ + res->bus_lower = res->bus_start ? res->bus_start : 0x1000; +} + +void pciauto_region_align(struct pci_region *res, pci_size_t size) +{ + res->bus_lower = ((res->bus_lower - 1) | (size - 1)) + 1; +} + +int pciauto_region_allocate(struct pci_region *res, pci_size_t size, + pci_addr_t *bar) +{ + pci_addr_t addr; + + if (!res) { + debug("No resource"); + goto error; + } + + addr = ((res->bus_lower - 1) | (size - 1)) + 1; + + if (addr - res->bus_start + size > res->size) { + debug("No room in resource"); + goto error; + } + + res->bus_lower = addr + size; + + debug("address=0x%llx bus_lower=0x%llx", (unsigned long long)addr, + (unsigned long long)res->bus_lower); + + *bar = addr; + return 0; + + error: + *bar = (pci_addr_t)-1; + return -1; +} + +void pciauto_config_init(struct pci_controller *hose) +{ + int i; + + hose->pci_io = NULL; + hose->pci_mem = NULL; + hose->pci_prefetch = NULL; + + for (i = 0; i < hose->region_count; i++) { + switch (hose->regions[i].flags) { + case PCI_REGION_IO: + if (!hose->pci_io || + hose->pci_io->size < hose->regions[i].size) + hose->pci_io = hose->regions + i; + break; + case PCI_REGION_MEM: + if (!hose->pci_mem || + hose->pci_mem->size < hose->regions[i].size) + hose->pci_mem = hose->regions + i; + break; + case (PCI_REGION_MEM | PCI_REGION_PREFETCH): + if (!hose->pci_prefetch || + hose->pci_prefetch->size < hose->regions[i].size) + hose->pci_prefetch = hose->regions + i; + break; + } + } + + + if (hose->pci_mem) { + pciauto_region_init(hose->pci_mem); + + debug("PCI Autoconfig: Bus Memory region: [0x%llx-0x%llx],\n" + "\t\tPhysical Memory [%llx-%llxx]\n", + (u64)hose->pci_mem->bus_start, + (u64)(hose->pci_mem->bus_start + hose->pci_mem->size - 1), + (u64)hose->pci_mem->phys_start, + (u64)(hose->pci_mem->phys_start + hose->pci_mem->size - 1)); + } + + if (hose->pci_prefetch) { + pciauto_region_init(hose->pci_prefetch); + + debug("PCI Autoconfig: Bus Prefetchable Mem: [0x%llx-0x%llx],\n" + "\t\tPhysical Memory [%llx-%llx]\n", + (u64)hose->pci_prefetch->bus_start, + (u64)(hose->pci_prefetch->bus_start + + hose->pci_prefetch->size - 1), + (u64)hose->pci_prefetch->phys_start, + (u64)(hose->pci_prefetch->phys_start + + hose->pci_prefetch->size - 1)); + } + + if (hose->pci_io) { + pciauto_region_init(hose->pci_io); + + debug("PCI Autoconfig: Bus I/O region: [0x%llx-0x%llx],\n" + "\t\tPhysical Memory: [%llx-%llx]\n", + (u64)hose->pci_io->bus_start, + (u64)(hose->pci_io->bus_start + hose->pci_io->size - 1), + (u64)hose->pci_io->phys_start, + (u64)(hose->pci_io->phys_start + hose->pci_io->size - 1)); + } +} diff --git a/drivers/pci/pci_auto_old.c b/drivers/pci/pci_auto_old.c index 0412bf3..932eab8 100644 --- a/drivers/pci/pci_auto_old.c +++ b/drivers/pci/pci_auto_old.c @@ -23,55 +23,6 @@ * */
-void pciauto_region_init(struct pci_region *res) -{ - /* - * Avoid allocating PCI resources from address 0 -- this is illegal - * according to PCI 2.1 and moreover, this is known to cause Linux IDE - * drivers to fail. Use a reasonable starting value of 0x1000 instead. - */ - res->bus_lower = res->bus_start ? res->bus_start : 0x1000; -} - -void pciauto_region_align(struct pci_region *res, pci_size_t size) -{ - res->bus_lower = ((res->bus_lower - 1) | (size - 1)) + 1; -} - -int pciauto_region_allocate(struct pci_region *res, pci_size_t size, - pci_addr_t *bar) -{ - pci_addr_t addr; - - if (!res) { - debug("No resource"); - goto error; - } - - addr = ((res->bus_lower - 1) | (size - 1)) + 1; - - if (addr - res->bus_start + size > res->size) { - debug("No room in resource"); - goto error; - } - - res->bus_lower = addr + size; - - debug("address=0x%llx bus_lower=0x%llx", (unsigned long long)addr, - (unsigned long long)res->bus_lower); - - *bar = addr; - return 0; - - error: - *bar = (pci_addr_t)-1; - return -1; -} - -/* - * - */ - void pciauto_setup_device(struct pci_controller *hose, pci_dev_t dev, int bars_num, struct pci_region *mem, @@ -385,73 +336,6 @@ void pciauto_postscan_setup_bridge(struct pci_controller *hose, } }
-/* - * - */ - -void pciauto_config_init(struct pci_controller *hose) -{ - int i; - - hose->pci_io = hose->pci_mem = hose->pci_prefetch = NULL; - - for (i = 0; i < hose->region_count; i++) { - switch(hose->regions[i].flags) { - case PCI_REGION_IO: - if (!hose->pci_io || - hose->pci_io->size < hose->regions[i].size) - hose->pci_io = hose->regions + i; - break; - case PCI_REGION_MEM: - if (!hose->pci_mem || - hose->pci_mem->size < hose->regions[i].size) - hose->pci_mem = hose->regions + i; - break; - case (PCI_REGION_MEM | PCI_REGION_PREFETCH): - if (!hose->pci_prefetch || - hose->pci_prefetch->size < hose->regions[i].size) - hose->pci_prefetch = hose->regions + i; - break; - } - } - - - if (hose->pci_mem) { - pciauto_region_init(hose->pci_mem); - - debug("PCI Autoconfig: Bus Memory region: [0x%llx-0x%llx],\n" - "\t\tPhysical Memory [%llx-%llxx]\n", - (u64)hose->pci_mem->bus_start, - (u64)(hose->pci_mem->bus_start + hose->pci_mem->size - 1), - (u64)hose->pci_mem->phys_start, - (u64)(hose->pci_mem->phys_start + hose->pci_mem->size - 1)); - } - - if (hose->pci_prefetch) { - pciauto_region_init(hose->pci_prefetch); - - debug("PCI Autoconfig: Bus Prefetchable Mem: [0x%llx-0x%llx],\n" - "\t\tPhysical Memory [%llx-%llx]\n", - (u64)hose->pci_prefetch->bus_start, - (u64)(hose->pci_prefetch->bus_start + - hose->pci_prefetch->size - 1), - (u64)hose->pci_prefetch->phys_start, - (u64)(hose->pci_prefetch->phys_start + - hose->pci_prefetch->size - 1)); - } - - if (hose->pci_io) { - pciauto_region_init(hose->pci_io); - - debug("PCI Autoconfig: Bus I/O region: [0x%llx-0x%llx],\n" - "\t\tPhysical Memory: [%llx-%llx]\n", - (u64)hose->pci_io->bus_start, - (u64)(hose->pci_io->bus_start + hose->pci_io->size - 1), - (u64)hose->pci_io->phys_start, - (u64)(hose->pci_io->phys_start + hose->pci_io->size - 1)); - - } -}
/* * HJF: Changed this to return int. I think this is required
Before converting this to driver model, reorder the code to avoid forward function declarations.
common/cmd_pci.c | 216 +++++++++++++++++++++++++++---------------------------- 1 file changed, 106 insertions(+), 110 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index 190e3b6..f8faa31 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -22,115 +22,6 @@ #include <asm/io.h> #include <pci.h>
-/* - * Follows routines for the output of infos about devices on PCI bus. - */ - -void pci_header_show(pci_dev_t dev); -void pci_header_show_brief(pci_dev_t dev); - -/* - * Subroutine: pciinfo - * - * Description: Show information about devices on PCI bus. - * Depending on the define CONFIG_SYS_SHORT_PCI_LISTING - * the output will be more or less exhaustive. - * - * Inputs: bus_no the number of the bus to be scanned. - * - * Return: None - * - */ -void pciinfo(int BusNum, int ShortPCIListing) -{ - struct pci_controller *hose = pci_bus_to_hose(BusNum); - int Device; - int Function; - unsigned char HeaderType; - unsigned short VendorID; - pci_dev_t dev; - int ret; - - if (!hose) - return; - - printf("Scanning PCI devices on bus %d\n", BusNum); - - if (ShortPCIListing) { - printf("BusDevFun VendorId DeviceId Device Class Sub-Class\n"); - printf("_____________________________________________________________\n"); - } - - for (Device = 0; Device < PCI_MAX_PCI_DEVICES; Device++) { - HeaderType = 0; - VendorID = 0; - for (Function = 0; Function < PCI_MAX_PCI_FUNCTIONS; Function++) { - /* - * If this is not a multi-function device, we skip the rest. - */ - if (Function && !(HeaderType & 0x80)) - break; - - dev = PCI_BDF(BusNum, Device, Function); - - if (pci_skip_dev(hose, dev)) - continue; - - ret = pci_read_config_word(dev, PCI_VENDOR_ID, - &VendorID); - if (ret) - goto error; - if ((VendorID == 0xFFFF) || (VendorID == 0x0000)) - continue; - - if (!Function) pci_read_config_byte(dev, PCI_HEADER_TYPE, &HeaderType); - - if (ShortPCIListing) - { - printf("%02x.%02x.%02x ", BusNum, Device, Function); - pci_header_show_brief(dev); - } - else - { - printf("\nFound PCI device %02x.%02x.%02x:\n", - BusNum, Device, Function); - pci_header_show(dev); - } - } - } - - return; -error: - printf("Cannot read bus configuration: %d\n", ret); -} - - -/* - * Subroutine: pci_header_show_brief - * - * Description: Reads and prints the header of the - * specified PCI device in short form. - * - * Inputs: dev Bus+Device+Function number - * - * Return: None - * - */ -void pci_header_show_brief(pci_dev_t dev) -{ - u16 vendor, device; - u8 class, subclass; - - pci_read_config_word(dev, PCI_VENDOR_ID, &vendor); - pci_read_config_word(dev, PCI_DEVICE_ID, &device); - pci_read_config_byte(dev, PCI_CLASS_CODE, &class); - pci_read_config_byte(dev, PCI_CLASS_SUB_CODE, &subclass); - - printf("0x%.4x 0x%.4x %-23s 0x%.2x\n", - vendor, device, - pci_class_str(class), subclass); -} - struct pci_reg_info { const char *name; enum pci_size_t size; @@ -284,10 +175,10 @@ void pci_header_show(pci_dev_t dev) { u8 class, header_type;
+ pci_read_config_byte(dev, PCI_CLASS_CODE, &class); pci_read_config_byte(dev, PCI_HEADER_TYPE, &header_type); pci_show_regs(dev, regs_start);
- pci_read_config_byte(dev, PCI_CLASS_CODE, &class); printf(" class code = 0x%.2x (%s)\n", class, pci_class_str(class)); pci_show_regs(dev, regs_rest); @@ -309,6 +200,111 @@ void pci_header_show(pci_dev_t dev) } }
+/* + * Subroutine: pci_header_show_brief + * + * Description: Reads and prints the header of the + * specified PCI device in short form. + * + * Inputs: dev Bus+Device+Function number + * + * Return: None + * + */ +void pci_header_show_brief(pci_dev_t dev) +{ + u16 vendor, device; + u8 class, subclass; + + pci_read_config_word(dev, PCI_VENDOR_ID, &vendor); + pci_read_config_word(dev, PCI_DEVICE_ID, &device); + pci_read_config_byte(dev, PCI_CLASS_CODE, &class); + pci_read_config_byte(dev, PCI_CLASS_SUB_CODE, &subclass); + + printf("0x%.4x 0x%.4x %-23s 0x%.2x\n", + vendor, device, + pci_class_str(class), subclass); +} + +/* + * Subroutine: pciinfo + * + * Description: Show information about devices on PCI bus. + * Depending on the defineCONFIG_SYS_SHORT_PCI_LISTING + * the output will be more or less exhaustive. + * + * Inputs: bus_no the number of the bus to be scanned. + * + * Return: None + * + */ +void pciinfo(int bus_num, int short_pci_listing) +{ + struct pci_controller *hose = pci_bus_to_hose(bus_num); + int Device; + int Function; + unsigned char HeaderType; + unsigned short VendorID; + pci_dev_t dev; + int ret; + + if (!hose) + return; + + printf("Scanning PCI devices on bus %d\n", bus_num); + + if (short_pci_listing) { + printf("BusDevFun VendorId DeviceId Device Class Sub-Class\n"); + printf("_____________________________________________________________\n"); + } + + for (Device = 0; Device < PCI_MAX_PCI_DEVICES; Device++) { + HeaderType = 0; + VendorID = 0; + for (Function = 0; Function < PCI_MAX_PCI_FUNCTIONS; + Function++) { + /* + * If this is not a multi-function device, we skip + * the rest. + */ + if (Function && !(HeaderType & 0x80)) + break; + + dev = PCI_BDF(bus_num, Device, Function); + + if (pci_skip_dev(hose, dev)) + continue; + + ret = pci_read_config_word(dev, PCI_VENDOR_ID, + &VendorID); + if (ret) + goto error; + if ((VendorID == 0xFFFF) || (VendorID == 0x0000)) + continue; + + if (!Function) { + pci_read_config_byte(dev, PCI_HEADER_TYPE, + &HeaderType); + } + + if (short_pci_listing) { + printf("%02x.%02x.%02x ", bus_num, Device, + Function); + pci_header_show_brief(dev); + } else { + printf("\nFound PCI device %02x.%02x.%02x:\n", + bus_num, Device, Function); + pci_header_show(dev); + } + } + } + + return; +error: + printf("Cannot read bus configuration: %d\n", ret); +} + + /* Convert the "bus.device.function" identifier into a number. */ static pci_dev_t get_pci_dev(char* name)
The function comments use an old style and some are incorrect. Update them.
Changes in v2: - Add a new patch to update the function comments
common/cmd_pci.c | 84 ++++++++++++++++++++++++++------------------------------ 1 file changed, 39 insertions(+), 45 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index f8faa31..7fdd3d8 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -161,15 +161,10 @@ static struct pci_reg_info regs_cardbus[] = { {}, };
-/* - * Subroutine: PCI_Header_Show - * - * Description: Reads the header of the specified PCI device. - * - * Inputs: BusDevFunc Bus+Device+Function number - * - * Return: None +/** + * @pci_header_show() - Show the header of the specified PCI device. * + * @dev: Bus+Device+Function number */ void pci_header_show(pci_dev_t dev) { @@ -200,16 +195,12 @@ void pci_header_show(pci_dev_t dev) } }
-/* - * Subroutine: pci_header_show_brief - * - * Description: Reads and prints the header of the - * specified PCI device in short form. +/** + * pci_header_show_brief() - Show the short-form PCI device header * - * Inputs: dev Bus+Device+Function number - * - * Return: None + * Reads and prints the header of the specified PCI device in short form. * + * @dev: Bus+Device+Function number */ void pci_header_show_brief(pci_dev_t dev) { @@ -226,25 +217,23 @@ void pci_header_show_brief(pci_dev_t dev) pci_class_str(class), subclass); }
-/* - * Subroutine: pciinfo - * - * Description: Show information about devices on PCI bus. - * Depending on the defineCONFIG_SYS_SHORT_PCI_LISTING - * the output will be more or less exhaustive. +/** + * pciinfo() - Show a list of devices on the PCI bus * - * Inputs: bus_no the number of the bus to be scanned. - * - * Return: None + * Show information about devices on PCI bus. Depending on @short_pci_listing + * the output will be more or less exhaustive. * + * @bus_num: The number of the bus to be scanned + * @short_pci_listing: true to use short form, showing only a brief header + * for each device */ void pciinfo(int bus_num, int short_pci_listing) { struct pci_controller *hose = pci_bus_to_hose(bus_num); - int Device; - int Function; - unsigned char HeaderType; - unsigned short VendorID; + int device; + int function; + unsigned char header_type; + unsigned short vendor_id; pci_dev_t dev; int ret;
@@ -258,42 +247,42 @@ void pciinfo(int bus_num, int short_pci_listing) printf("_____________________________________________________________\n"); }
- for (Device = 0; Device < PCI_MAX_PCI_DEVICES; Device++) { - HeaderType = 0; - VendorID = 0; - for (Function = 0; Function < PCI_MAX_PCI_FUNCTIONS; - Function++) { + for (device = 0; device < PCI_MAX_PCI_DEVICES; device++) { + header_type = 0; + vendor_id = 0; + for (function = 0; function < PCI_MAX_PCI_FUNCTIONS; + function++) { /* * If this is not a multi-function device, we skip * the rest. */ - if (Function && !(HeaderType & 0x80)) + if (function && !(header_type & 0x80)) break;
- dev = PCI_BDF(bus_num, Device, Function); + dev = PCI_BDF(bus_num, device, function);
if (pci_skip_dev(hose, dev)) continue;
ret = pci_read_config_word(dev, PCI_VENDOR_ID, - &VendorID); + &vendor_id); if (ret) goto error; - if ((VendorID == 0xFFFF) || (VendorID == 0x0000)) + if ((vendor_id == 0xFFFF) || (vendor_id == 0x0000)) continue;
- if (!Function) { + if (!function) { pci_read_config_byte(dev, PCI_HEADER_TYPE, - &HeaderType); + &header_type); }
if (short_pci_listing) { - printf("%02x.%02x.%02x ", bus_num, Device, - Function); + printf("%02x.%02x.%02x ", bus_num, device, + function); pci_header_show_brief(dev); } else { printf("\nFound PCI device %02x.%02x.%02x:\n", - bus_num, Device, Function); + bus_num, device, function); pci_header_show(dev); } } @@ -305,9 +294,13 @@ error: }
-/* Convert the "bus.device.function" identifier into a number. +/** + * get_pci_dev() - Convert the "bus.device.function" identifier into a number + * + * @name: Device string in the form "bus.device.function" where each is in hex + * @return encoded pci_dev_t or -1 if the string was invalid */ -static pci_dev_t get_pci_dev(char* name) +static pci_dev_t get_pci_dev(char *name) { char cnum[12]; int len, i, iold, n; @@ -328,6 +321,7 @@ static pci_dev_t get_pci_dev(char* name) if (n == 0) n = 1; bdfs[n] = simple_strtoul(cnum, NULL, 16); + return PCI_BDF(bdfs[0], bdfs[1], bdfs[2]); }
Hi Simon,
Changes in v3:
Changes in v2:
- Subroutine: PCI_Header_Show
- Description: Reads the header of the specified PCI device.
- Inputs: BusDevFunc Bus+Device+Function number
- Return: None
- @pci_header_show() - Show the header of the specified PCI device.
nits: please remove @ before pci_header_show(). Sorry I missed this in previous review. Please fix it when applying.
- @dev: Bus+Device+Function number
[snip]
Regards, Bin
On 26 November 2015 at 23:37, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
Changes in v3:
Changes in v2:
- Return: None
Fixed, and
Currently we use switch() and access PCI configuration via several functions, one for each data size. Adjust the code to use generic functions, where the data size is a parameter.
Changes in v3: - Fix mix-up between PCI_SIZE_xx and byte size
Changes in v2: - Add back the leading 0 in the printf() statements
common/cmd_pci.c | 74 ++++++++++++++++++++++++-------------------------------- 1 file changed, 31 insertions(+), 43 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index 7fdd3d8..4874033 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -28,19 +28,24 @@ struct pci_reg_info { u8 offset; };
-static int pci_field_width(enum pci_size_t size) +static int pci_byte_size(enum pci_size_t size) { switch (size) { case PCI_SIZE_8: - return 2; + return 1; case PCI_SIZE_16: - return 4; + return 2; case PCI_SIZE_32: default: - return 8; + return 4; } }
+static int pci_field_width(enum pci_size_t size) +{ + return pci_byte_size(size) * 2; +} + static unsigned long pci_read_config(pci_dev_t dev, int offset, enum pci_size_t size) { @@ -325,38 +330,31 @@ static pci_dev_t get_pci_dev(char *name) return PCI_BDF(bdfs[0], bdfs[1], bdfs[2]); }
-static int pci_cfg_display(pci_dev_t bdf, ulong addr, ulong size, ulong length) +static int pci_cfg_display(pci_dev_t bdf, ulong addr, enum pci_size_t size, + ulong length) { #define DISP_LINE_LEN 16 ulong i, nbytes, linebytes; + int byte_size; int rc = 0;
+ byte_size = pci_byte_size(size); if (length == 0) - length = 0x40 / size; /* Standard PCI configuration space */ + length = 0x40 / byte_size; /* Standard PCI config space */
/* Print the lines. * once, and all accesses are with the specified bus width. */ - nbytes = length * size; + nbytes = length * byte_size; do { - uint val4; - ushort val2; - u_char val1; - printf("%08lx:", addr); - linebytes = (nbytes>DISP_LINE_LEN)?DISP_LINE_LEN:nbytes; - for (i=0; i<linebytes; i+= size) { - if (size == 4) { - pci_read_config_dword(bdf, addr, &val4); - printf(" %08x", val4); - } else if (size == 2) { - pci_read_config_word(bdf, addr, &val2); - printf(" %04x", val2); - } else { - pci_read_config_byte(bdf, addr, &val1); - printf(" %02x", val1); - } - addr += size; + linebytes = (nbytes > DISP_LINE_LEN) ? DISP_LINE_LEN : nbytes; + for (i = 0; i < linebytes; i += byte_size) { + unsigned long val; + + val = pci_read_config(bdf, addr, size); + printf(" %0*lx", pci_field_width(size), val); + addr += byte_size; } printf("\n"); nbytes -= linebytes; @@ -385,32 +383,20 @@ static int pci_cfg_write (pci_dev_t bdf, ulong addr, ulong size, ulong value) return 0; }
-static int -pci_cfg_modify (pci_dev_t bdf, ulong addr, ulong size, ulong value, int incrflag) +static int pci_cfg_modify(pci_dev_t bdf, ulong addr, enum pci_size_t size, + ulong value, int incrflag) { ulong i; int nbytes; - uint val4; - ushort val2; - u_char val1; + ulong val;
/* Print the address, followed by value. Then accept input for * the next value. A non-converted value exits. */ do { printf("%08lx:", addr); - if (size == 4) { - pci_read_config_dword(bdf, addr, &val4); - printf(" %08x", val4); - } - else if (size == 2) { - pci_read_config_word(bdf, addr, &val2); - printf(" %04x", val2); - } - else { - pci_read_config_byte(bdf, addr, &val1); - printf(" %02x", val1); - } + val = pci_read_config(bdf, addr, size); + printf(" %0*lx", pci_field_width(size), val);
nbytes = cli_readline(" ? "); if (nbytes == 0 || (nbytes == 1 && console_buffer[0] == '-')) { @@ -456,7 +442,8 @@ pci_cfg_modify (pci_dev_t bdf, ulong addr, ulong size, ulong value, int incrflag */ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { - ulong addr = 0, value = 0, size = 0; + ulong addr = 0, value = 0, cmd_size = 0; + enum pci_size_t size = PCI_SIZE_32; int busnum = 0; pci_dev_t bdf = 0; char cmd = 's'; @@ -471,7 +458,8 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) case 'm': /* modify */ case 'w': /* write */ /* Check for a size specification. */ - size = cmd_get_data_size(argv[1], 4); + cmd_size = cmd_get_data_size(argv[1], 4); + size = (cmd_size == 4) ? PCI_SIZE_32 : cmd_size - 1; if (argc > 3) addr = simple_strtoul(argv[3], NULL, 16); if (argc > 4)
Changes in v3:
Changes in v2:
return 2;
return 4;
return 8;
return 4; }
ulong length)
length = 0x40 / byte_size; /* Standard PCI config space */ /* Print the lines. * once, and all accesses are with the specified bus width. */
uint val4;
ushort val2;
u_char val1;
if (size == 4) {
} else {
addr += size;
unsigned long val;
uint val4;
ushort val2;
u_char val1;
ulong val; /* Print the address, followed by value. Then accept input for * the next value. A non-converted value exits. */ do { printf("%08lx:", addr);
if (size == 4) {
else {
printf(" %0*lx", pci_field_width(size), val); nbytes = cli_readline(" ? "); if (nbytes == 0 || (nbytes == 1 && console_buffer[0] == '-')) {
Changes in v3:
Changes in v2:
[snip]
In the 'pci' command, add a separate variable to hold the PCI device. When this code is converted to driver model, this variable will be used to hold a struct udevice instead.
Changes in v3: - Fix 'switch (cmd)' merge error
Changes in v2: - Refactor the patch based on dropping the earlier refactor patch
common/cmd_pci.c | 13 ++++++++----- 1 file changed, 8 insertions(+), 5 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index 4874033..857e3e5 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -444,6 +444,7 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { ulong addr = 0, value = 0, cmd_size = 0; enum pci_size_t size = PCI_SIZE_32; + pci_dev_t dev; int busnum = 0; pci_dev_t bdf = 0; char cmd = 's'; @@ -488,12 +489,14 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) return 0; }
+ dev = bdf; + switch (argv[1][0]) { case 'h': /* header */ - pci_header_show(bdf); + pci_header_show(dev); break; case 'd': /* display */ - return pci_cfg_display(bdf, addr, size, value); + return pci_cfg_display(dev, addr, size, value); #ifdef CONFIG_CMD_PCI_ENUM case 'e': # ifdef CONFIG_DM_PCI @@ -506,17 +509,17 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) case 'n': /* next */ if (argc < 4) goto usage; - ret = pci_cfg_modify(bdf, addr, size, value, 0); + ret = pci_cfg_modify(dev, addr, size, value, 0); break; case 'm': /* modify */ if (argc < 4) goto usage; - ret = pci_cfg_modify(bdf, addr, size, value, 1); + ret = pci_cfg_modify(dev, addr, size, value, 1); break; case 'w': /* write */ if (argc < 5) goto usage; - ret = pci_cfg_write(bdf, addr, size, value); + ret = pci_cfg_write(dev, addr, size, value); break; default: ret = CMD_RET_USAGE;
Changes in v3:
Changes in v2:
dev = bdf;
Changes in v3:
Changes in v2:
[snip]
Thanks for the review.
We want to share this code with the driver model version, so put it in a separate function.
common/cmd_pci.c | 17 +++++++++++------ 1 file changed, 11 insertions(+), 6 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index 857e3e5..fcda7f6 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -200,6 +200,16 @@ void pci_header_show(pci_dev_t dev) } }
+void pciinfo_header(int busnum, bool short_listing) +{ + printf("Scanning PCI devices on bus %d\n", busnum); + + if (short_listing) { + printf("BusDevFun VendorId DeviceId Device Class Sub-Class\n"); + printf("_____________________________________________________________\n"); + } +} + /** * pci_header_show_brief() - Show the short-form PCI device header * @@ -245,12 +255,7 @@ void pciinfo(int bus_num, int short_pci_listing) if (!hose) return;
- printf("Scanning PCI devices on bus %d\n", bus_num); - - if (short_pci_listing) { - printf("BusDevFun VendorId DeviceId Device Class Sub-Class\n"); - printf("_____________________________________________________________\n"); - } + pciinfo_header(bus_num, short_pci_listing);
for (device = 0; device < PCI_MAX_PCI_DEVICES; device++) { header_type = 0;
Adjust this command to use the correct PCI functions, instead of the compatibility layer.
Changes in v3: None Changes in v2: - Make pciinfo() static
common/cmd_pci.c | 133 ++++++++++++++++++++++++++++++++++++++++++++++++++++--- include/common.h | 1 - 2 files changed, 128 insertions(+), 6 deletions(-)
diff --git a/common/cmd_pci.c b/common/cmd_pci.c index fcda7f6..1bd6001 100644 --- a/common/cmd_pci.c +++ b/common/cmd_pci.c @@ -18,6 +18,7 @@ #include <cli.h> #include <command.h> #include <console.h> +#include <dm.h> #include <asm/processor.h> #include <asm/io.h> #include <pci.h> @@ -46,6 +47,19 @@ static int pci_field_width(enum pci_size_t size) return pci_byte_size(size) * 2; }
+#ifdef CONFIG_DM_PCI +static void pci_show_regs(struct udevice *dev, struct pci_reg_info *regs) +{ + for (; regs->name; regs++) { + unsigned long val; + + dm_pci_read_config(dev, regs->offset, &val, regs->size); + printf(" %s =%*s%#.*lx\n", regs->name, + (int)(28 - strlen(regs->name)), "", + pci_field_width(regs->size), val); + } +} +#else static unsigned long pci_read_config(pci_dev_t dev, int offset, enum pci_size_t size) { @@ -76,6 +90,7 @@ static void pci_show_regs(pci_dev_t dev, struct pci_reg_info *regs) pci_read_config(dev, regs->offset, regs->size)); } } +#endif
static struct pci_reg_info regs_start[] = { { "vendor ID", PCI_SIZE_16, PCI_VENDOR_ID }, @@ -171,15 +186,25 @@ static struct pci_reg_info regs_cardbus[] = { * * @dev: Bus+Device+Function number */ +#ifdef CONFIG_DM_PCI +void pci_header_show(struct udevice *dev) +#else void pci_header_show(pci_dev_t dev) +#endif { +#ifdef CONFIG_DM_PCI + unsigned long class, header_type; + + dm_pci_read_config(dev, PCI_CLASS_CODE, &class, PCI_SIZE_8); + dm_pci_read_config(dev, PCI_HEADER_TYPE, &header_type, PCI_SIZE_8); +#else u8 class, header_type;
pci_read_config_byte(dev, PCI_CLASS_CODE, &class); pci_read_config_byte(dev, PCI_HEADER_TYPE, &header_type); +#endif pci_show_regs(dev, regs_start); - - printf(" class code = 0x%.2x (%s)\n", class, + printf(" class code = 0x%.2x (%s)\n", (int)class, pci_class_str(class)); pci_show_regs(dev, regs_rest);
@@ -210,6 +235,55 @@ void pciinfo_header(int busnum, bool short_listing) } }
+#ifdef CONFIG_DM_PCI +/** + * pci_header_show_brief() - Show the short-form PCI device header + * + * Reads and prints the header of the specified PCI device in short form. + * + * @dev: PCI device to show + */ +static void pci_header_show_brief(struct udevice *dev) +{ + ulong vendor, device; + ulong class, subclass; + + dm_pci_read_config(dev, PCI_VENDOR_ID, &vendor, PCI_SIZE_16); + dm_pci_read_config(dev, PCI_DEVICE_ID, &device, PCI_SIZE_16); + dm_pci_read_config(dev, PCI_CLASS_CODE, &class, PCI_SIZE_8); + dm_pci_read_config(dev, PCI_CLASS_SUB_CODE, &subclass, PCI_SIZE_8); + + printf("0x%.4lx 0x%.4lx %-23s 0x%.2lx\n", + vendor, device, + pci_class_str(class), subclass); +} + +static void pciinfo(struct udevice *bus, bool short_listing) +{ + struct udevice *dev; + + pciinfo_header(bus->seq, short_listing); + + for (device_find_first_child(bus, &dev); + dev; + device_find_next_child(&dev)) { + struct pci_child_platdata *pplat; + + pplat = dev_get_parent_platdata(dev); + if (short_listing) { + printf("%02x.%02x.%02x ", bus->seq, + PCI_DEV(pplat->devfn), PCI_FUNC(pplat->devfn)); + pci_header_show_brief(dev); + } else { + printf("\nFound PCI device %02x.%02x.%02x:\n", bus->seq, + PCI_DEV(pplat->devfn), PCI_FUNC(pplat->devfn)); + pci_header_show(dev); + } + } +} + +#else + /** * pci_header_show_brief() - Show the short-form PCI device header * @@ -302,7 +376,7 @@ void pciinfo(int bus_num, int short_pci_listing) error: printf("Cannot read bus configuration: %d\n", ret); } - +#endif
/** * get_pci_dev() - Convert the "bus.device.function" identifier into a number @@ -335,8 +409,13 @@ static pci_dev_t get_pci_dev(char *name) return PCI_BDF(bdfs[0], bdfs[1], bdfs[2]); }
+#ifdef CONFIG_DM_PCI +static int pci_cfg_display(struct udevice *dev, ulong addr, + enum pci_size_t size, ulong length) +#else static int pci_cfg_display(pci_dev_t bdf, ulong addr, enum pci_size_t size, ulong length) +#endif { #define DISP_LINE_LEN 16 ulong i, nbytes, linebytes; @@ -357,7 +436,11 @@ static int pci_cfg_display(pci_dev_t bdf, ulong addr, enum pci_size_t size, for (i = 0; i < linebytes; i += byte_size) { unsigned long val;
+#ifdef CONFIG_DM_PCI + dm_pci_read_config(dev, addr, &val, size); +#else val = pci_read_config(bdf, addr, size); +#endif printf(" %0*lx", pci_field_width(size), val); addr += byte_size; } @@ -372,6 +455,7 @@ static int pci_cfg_display(pci_dev_t bdf, ulong addr, enum pci_size_t size, return (rc); }
+#ifndef CONFIG_DM_PCI static int pci_cfg_write (pci_dev_t bdf, ulong addr, ulong size, ulong value) { if (size == 4) { @@ -387,9 +471,15 @@ static int pci_cfg_write (pci_dev_t bdf, ulong addr, ulong size, ulong value) } return 0; } +#endif
-static int pci_cfg_modify(pci_dev_t bdf, ulong addr, enum pci_size_t size, +#ifdef CONFIG_DM_PCI +static int pci_cfg_modify(struct udevice *dev, ulong addr, ulong size, ulong value, int incrflag) +#else +static int pci_cfg_modify(pci_dev_t bdf, ulong addr, ulong size, ulong value, + int incrflag) +#endif { ulong i; int nbytes; @@ -400,7 +490,11 @@ static int pci_cfg_modify(pci_dev_t bdf, ulong addr, enum pci_size_t size, */ do { printf("%08lx:", addr); +#ifdef CONFIG_DM_PCI + dm_pci_read_config(dev, addr, &val, size); +#else val = pci_read_config(bdf, addr, size); +#endif printf(" %0*lx", pci_field_width(size), val);
nbytes = cli_readline(" ? "); @@ -427,7 +521,11 @@ static int pci_cfg_modify(pci_dev_t bdf, ulong addr, enum pci_size_t size, /* good enough to not time out */ bootretry_reset_cmd_timeout(); - pci_cfg_write (bdf, addr, size, i); +#ifdef CONFIG_DM_PCI + dm_pci_write_config(dev, addr, i, size); +#else + pci_cfg_write(bdf, addr, size, i); +#endif if (incrflag) addr += size; } @@ -449,7 +547,11 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { ulong addr = 0, value = 0, cmd_size = 0; enum pci_size_t size = PCI_SIZE_32; +#ifdef CONFIG_DM_PCI + struct udevice *dev, *bus; +#else pci_dev_t dev; +#endif int busnum = 0; pci_dev_t bdf = 0; char cmd = 's'; @@ -490,11 +592,28 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) if (argc > 1) busnum = simple_strtoul(argv[1], NULL, 16); } +#ifdef CONFIG_DM_PCI + ret = uclass_get_device_by_seq(UCLASS_PCI, busnum, &bus); + if (ret) { + printf("No such bus\n"); + return CMD_RET_FAILURE; + } + pciinfo(bus, value); +#else pciinfo(busnum, value); +#endif return 0; }
+#ifdef CONFIG_DM_PCI + ret = pci_bus_find_bdf(bdf, &dev); + if (ret) { + printf("No such device\n"); + return CMD_RET_FAILURE; + } +#else dev = bdf; +#endif
switch (argv[1][0]) { case 'h': /* header */ @@ -524,7 +643,11 @@ static int do_pci(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) case 'w': /* write */ if (argc < 5) goto usage; +#ifdef CONFIG_DM_PCI + ret = dm_pci_write_config(dev, addr, value, size); +#else ret = pci_cfg_write(dev, addr, size, value); +#endif break; default: ret = CMD_RET_USAGE; diff --git a/include/common.h b/include/common.h index a3831b7..75c78d5 100644 --- a/include/common.h +++ b/include/common.h @@ -432,7 +432,6 @@ int get_env_id (void);
void pci_init (void); void pci_init_board(void); -void pciinfo (int, int);
#if defined(CONFIG_PCI) && defined(CONFIG_4xx) int pci_pre_init (struct pci_controller *);
We eventually need to drop the compatibility functions for driver model. As a first step, create a configuration option to enable them and hide them when the option is disabled.
Changes in v3: None Changes in v2: - Drop patch: pci: Move 'pci scan' code in with other commands - Move dm_pciauto_config_device() out of CONFIG_DM_PCI_COMPAT
arch/arm/mach-tegra/Kconfig | 1 + arch/x86/Kconfig | 3 +++ configs/sandbox_defconfig | 1 + drivers/pci/Kconfig | 9 +++++++++ drivers/pci/Makefile | 3 ++- include/pci.h | 30 ++++++++++++++++++++++++++---- 6 files changed, 42 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index 8db0708..fbfb204 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -7,6 +7,7 @@ config TEGRA_COMMON select DM_I2C select DM_KEYBOARD select DM_PCI + select DM_PCI_COMPAT select DM_SERIAL select DM_SPI select DM_SPI_FLASH diff --git a/arch/x86/Kconfig b/arch/x86/Kconfig index 16ba4f4..7e7cb61 100644 --- a/arch/x86/Kconfig +++ b/arch/x86/Kconfig @@ -93,6 +93,9 @@ config SYS_X86_START16 depends on X86_RESET_VECTOR default 0xfffff800
+config DM_PCI_COMPAT + default y # Until we finish moving over to the new API + config BOARD_ROMSIZE_KB_512 bool config BOARD_ROMSIZE_KB_1024 diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 0178674..27753cc 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -41,6 +41,7 @@ CONFIG_SPI_FLASH_SANDBOX=y CONFIG_SPI_FLASH=y CONFIG_DM_ETH=y CONFIG_DM_PCI=y +CONFIG_DM_PCI_COMPAT=y CONFIG_PCI_SANDBOX=y CONFIG_PINCTRL=y CONFIG_PINCONF=y diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index c219c19..26aa2b0 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -9,6 +9,15 @@ config DM_PCI available PCI devices, allows scanning of PCI buses and provides device configuration support.
+config DM_PCI_COMPAT + bool "Enable compatible functions for PCI" + depends on DM_PCI + help + Enable compatibility functions for PCI so that old code can be used + with CONFIG_DM_PCI enabled. This should be used as an interim + measure when porting a board to use driver model for PCI. Once the + board is fully supported, this option should be disabled. + config PCI_SANDBOX bool "Sandbox PCI support" depends on SANDBOX && DM_PCI diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 1f8f86f..6b761b4 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -6,7 +6,8 @@ #
ifneq ($(CONFIG_DM_PCI),) -obj-$(CONFIG_PCI) += pci-uclass.o pci_compat.o +obj-$(CONFIG_PCI) += pci-uclass.o +obj-$(CONFIG_DM_PCI_COMPAT) += pci_compat.o obj-$(CONFIG_PCI_SANDBOX) += pci_sandbox.o obj-$(CONFIG_SANDBOX) += pci-emul-uclass.o obj-$(CONFIG_X86) += pci_x86.o diff --git a/include/pci.h b/include/pci.h index c4f6577..2adca85 100644 --- a/include/pci.h +++ b/include/pci.h @@ -656,6 +656,7 @@ extern pci_addr_t pci_hose_phys_to_bus(struct pci_controller* hose, pci_bus_to_virt((dev), (addr), PCI_REGION_IO, (len), (map_flags))
/* For driver model these are defined in macros in pci_compat.c */ +#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) extern int pci_hose_read_config_byte(struct pci_controller *hose, pci_dev_t dev, int where, u8 *val); extern int pci_hose_read_config_word(struct pci_controller *hose, @@ -668,6 +669,7 @@ extern int pci_hose_write_config_word(struct pci_controller *hose, pci_dev_t dev, int where, u16 val); extern int pci_hose_write_config_dword(struct pci_controller *hose, pci_dev_t dev, int where, u32 val); +#endif
#ifndef CONFIG_DM_PCI extern int pci_read_config_byte(pci_dev_t dev, int where, u8 *val); @@ -678,6 +680,13 @@ extern int pci_write_config_word(pci_dev_t dev, int where, u16 val); extern int pci_write_config_dword(pci_dev_t dev, int where, u32 val); #endif
+void pciauto_region_init(struct pci_region *res); +void pciauto_region_align(struct pci_region *res, pci_size_t size); +void pciauto_config_init(struct pci_controller *hose); +int pciauto_region_allocate(struct pci_region *res, pci_size_t size, + pci_addr_t *bar); + +#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) extern int pci_hose_read_config_byte_via_dword(struct pci_controller *hose, pci_dev_t dev, int where, u8 *val); extern int pci_hose_read_config_word_via_dword(struct pci_controller *hose, @@ -696,9 +705,6 @@ extern int pci_skip_dev(struct pci_controller *hose, pci_dev_t dev); extern int pci_hose_scan(struct pci_controller *hose); extern int pci_hose_scan_bus(struct pci_controller *hose, int bus);
-extern void pciauto_region_init(struct pci_region* res); -extern void pciauto_region_align(struct pci_region *res, pci_size_t size); -extern int pciauto_region_allocate(struct pci_region* res, pci_size_t size, pci_addr_t *bar); extern void pciauto_setup_device(struct pci_controller *hose, pci_dev_t dev, int bars_num, struct pci_region *mem, @@ -708,7 +714,6 @@ extern void pciauto_prescan_setup_bridge(struct pci_controller *hose, pci_dev_t dev, int sub_bus); extern void pciauto_postscan_setup_bridge(struct pci_controller *hose, pci_dev_t dev, int sub_bus); -extern void pciauto_config_init(struct pci_controller *hose); extern int pciauto_config_device(struct pci_controller *hose, pci_dev_t dev);
extern pci_dev_t pci_find_device (unsigned int vendor, unsigned int device, int index); @@ -739,6 +744,7 @@ extern void board_pci_fixup_dev(struct pci_controller *hose, pci_dev_t dev, unsigned short device, unsigned short class); #endif +#endif /* !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) */
const char * pci_class_str(u8 class); int pci_last_busno(void); @@ -747,6 +753,7 @@ int pci_last_busno(void); extern void pci_mpc85xx_init (struct pci_controller *hose); #endif
+#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) /** * pci_write_bar32() - Write the address of a BAR including control bits * @@ -783,6 +790,7 @@ u32 pci_read_bar32(struct pci_controller *hose, pci_dev_t dev, int barnum); */ pci_dev_t pci_hose_find_devices(struct pci_controller *hose, int busnum, struct pci_device_id *ids, int *indexp); +#endif /* !CONFIG_DM_PCI || CONFIG_DM_PCI_COMPAT */
/* Access sizes for PCI reads and writes */ enum pci_size_t { @@ -1041,6 +1049,7 @@ int dm_pci_write_config32(struct udevice *dev, int offset, u32 value); */ int pci_write_config32(pci_dev_t pcidev, int offset, u32 value);
+#ifdef CONFIG_DM_PCI_COMPAT /* Compatibility with old naming */ static inline int pci_write_config_dword(pci_dev_t pcidev, int offset, u32 value) @@ -1093,6 +1102,19 @@ static inline int pci_read_config_byte(pci_dev_t pcidev, int offset, return pci_read_config8(pcidev, offset, valuep); }
+#endif /* CONFIG_DM_PCI_COMPAT */ + +/** + * dm_pciauto_config_device() - configure a device ready for use + * + * Space is allocated for each PCI base address register (BAR) so that the + * devices are mapped into memory and I/O space ready for use. + * + * @dev: Device to configure + * @return 0 if OK, -ve on error + */ +int dm_pciauto_config_device(struct udevice *dev); + /** * pci_conv_32_to_size() - convert a 32-bit read value to the given size *
Bin Meng
