Re: [PATCH v3 3/3] arm: mvebu: Initial ESPRESSOBin-Ultra board support
Héllo,
Message: 2 Date: Fri, 13 Aug 2021 12:03:57 +0200 From: Luka Kovacicluka.kovacic@sartura.hr To: Pali Roh?rpali@kernel.org Cc:u-boot@lists.denx.de, Robert Markorobert.marko@sartura.hr, Luka Perkovluka.perkov@sartura.hr, Marek Behun marek.behun@nic.cz,sr@denx.de,sjg@chromium.org, patrick.delaunay@foss.st.com,xypron.glpk@gmx.de Subject: Re: [PATCH v3 3/3] arm: mvebu: Initial ESPRESSOBin-Ultra board support Message-ID: CADZsf3buKpgUJq_2yP1zakQbf0Hoq_4oPLdi69_d+qoR+Hbn0w@mail.gmail.com Content-Type: text/plain; charset="UTF-8"
Hello Pali,
On Fri, Aug 13, 2021 at 11:27 AM Pali Roh?rpali@kernel.org wrote:
On Friday 13 August 2021 01:39:38 Luka Kovacic wrote:
Add initial support for the ESPRESSOBin-Ultra board from Globalscale Technologies, Inc.
The board is based on the 64-bit dual-core Marvell Armada 3720 SoC. Peripherals:
- 5 Gigabit Ethernet ports (WAN has PoE, up to 30W, Topaz 6341 switch)
- RTC clock (PCF8563)
- USB 3.0 port
- USB 2.0 port
- 4x LED
- UART over Micro-USB
- M.2 slot (2280)
- Mini PCI-E slot
Additionally, automatic import of the Marvell hw_info parameters is enabled via the recently added mac command for A37XX platforms. The parameters stored in Marvell hw_info are usually the board serial number and MAC addresses.
Signed-off-by: Luka Kovacicluka.kovacic@sartura.hr Cc: Luka Perkovluka.perkov@sartura.hr Cc: Robert Markorobert.marko@sartura.hr
arch/arm/dts/Makefile | 1 + .../arm/dts/armada-3720-espressobin-ultra.dts | 114 ++++++++++ arch/arm/dts/armada-3720-espressobin.dts | 199 +---------------- arch/arm/dts/armada-3720-espressobin.dtsi | 210 ++++++++++++++++++ board/Marvell/mvebu_armada-37xx/MAINTAINERS | 8 + board/Marvell/mvebu_armada-37xx/board.c | 92 +++++++- .../mvebu_espressobin-ultra-88f3720_defconfig | 93 ++++++++ 7 files changed, 514 insertions(+), 203 deletions(-) create mode 100644 arch/arm/dts/armada-3720-espressobin-ultra.dts create mode 100644 arch/arm/dts/armada-3720-espressobin.dtsi create mode 100644 configs/mvebu_espressobin-ultra-88f3720_defconfig
Thanks, all, for this job.
I am available for testing (if needed) on EspressoBin V7, with eMMC, and EspressoBin Ultra.
I have issue on EspressoBin Ultra, with the v2 patch for EspressoBin-Ultra, on OpenWrt 21.02-RC, fw_printenv do not works... (CRC Error) I have the same issue with the Marvell (GlobalScale) u-Boot, factory and upgraded version.
Environments variables are correctly managed from the u-Boot itself.
Regards, Gérald Kerma
PS : I am only registered to the digest, so I hope my mail will not be disturbing...
Hello Gerald,
On Sat, Aug 14, 2021 at 9:59 AM Gérald Kerma gandalf@gk2.net wrote:
Héllo,
Hello Pali,
- USB 3.0 port
- USB 2.0 port
- 4x LED
- M.2 slot (2280)
- Mini PCI-E slot
Thanks for offering your help. Can you test the following patchset (v4), when it's out, as some implementation issues still have to be resolved here?
Did you specify the U-Boot environment location correctly in the fw_printenv config?
Kind regards, Luka
Héllo Luka,
Le 16/08/2021 à 10:50, Luka Kovacic a écrit :
Hello Gerald,
Héllo,
Hello Pali,
- USB 3.0 port
- USB 2.0 port
- 4x LED
- M.2 slot (2280)
- Mini PCI-E slot
Sure...
I think so : but It do not works...
root@ULTRA-5G:~# cat /etc/fw_env.config #/dev/mtd0 0x3f0000 0x10000 0x10000 1 /dev/mtd2 0x0 0x10000 0x10000 1 root@ULTRA-5G:~# fw_printenv Warning: Bad CRC, using default environment bootcmd=bootp; setenv bootargs root=/dev/nfs nfsroot=${serverip}:${rootpath} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off; bootm bootdelay=5 baudrate=115200
Kind regards, Luka
Best regards, Gérald
Gérald Kerma
Luka Kovacic
