[U-Boot] ARM64: How to protect spin-table code from U-Boot?
Hi.
I assume the following code in arch/arm/cpu/armv8/start.S is for spin-table.
#ifdef CONFIG_ARMV8_MULTIENTRY branch_if_master x0, x1, master_cpu
/* * Slave CPUs */ slave_cpu: wfe ldr x1, =CPU_RELEASE_ADDR ldr x0, [x1] cbz x0, slave_cpu br x0 /* branch to the given address */ master_cpu: /* On the master CPU */ #endif /* CONFIG_ARMV8_MULTIENTRY */
As Documentation/arm64/booting.txt of Linux says, slave CPUs should spin outside of the kernel in a reserved area of memory.
U-Boot generally works on DRAM, so the code for spin-table should be reserved in Device Tree.
Otherwise, the code above and the variable "CPU_RELEASE_ADDR" has been destroyed by the kernel by the time slave CPUs are kicked.
Now, I locally work-around this problem by pre-fetching necessary code to the I-cache, but this solution is unstable.
My question is, is there a solution to protect spin-table code already? (or on-going work to solve the problem?)
One problem specific for U-Boot is that, U-Boot relocates itself to the tail of DRAM. So, it is difficult to reserve the code statically at the compile time of DT.
Thought?
On 07.05.16 09:12, Masahiro Yamada wrote:
Hi.
/* * Slave CPUs */
I assume your SoC has working EL3? If so, why don't you just provide the respective PSCI cpu wakeup calls via ATF instead of using spin tables?
Alex
Hi Alex,
2016-05-07 20:30 GMT+09:00 Alexander Graf agraf@suse.de:
Hi.
/* * Slave CPUs */
I am planning to switch to ARM Trusted Firmware in the future, but there are several things to study before staring to use it. (and I guess there are SoC-specific parts that should be implemented in ATF)
I needed to bring-up my first ARMv8 SoC quickly. I am familiar with U-Boot already, so I chose to use U-Boot alone in my early development phase.
A good thing about spin-table is that it is really simple.
Moreover, if we have something, it should be correct. (or should be deleted if it is not working.) I do not like the half-way house like "we implemented it, but not working".
If nobody has taken care about it yet, I am happy to work on it. Any comment is very appreciated, of course.
Am 09.05.2016 um 00:57 schrieb Masahiro Yamada yamada.masahiro@socionext.com:
Hi Alex,
On 07.05.16 09:12, Masahiro Yamada wrote: Hi.
/* * Slave CPUs */
Of course, I was really just asking :).
There are memory reservation functions in U-Boot that get translated to reserve fdt entries on boot. You can probably just call those from your board file.
Alex
-- Best Regards Masahiro Yamada
Alexander Graf
Masahiro Yamada
