[U-Boot] [PATCH 0/2] ARM: dt: sunxi: Add Itead Ibox support
This patch delivers the uboot changes required for the Itead Ibox A20. As there are a few Itead variants out there based on their A10/A20 core module; I have created a common dtsi for all of them.
I've also converted the A10 Itead Iteaduino dts to use this common file. BR, CK
Marcus Cooper (2): sun7i: Add support for the Itead Ibox sun4i: Convert Iteadunio plus dts
arch/arm/dts/Makefile | 1 + arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts | 86 +-------------- arch/arm/dts/sun7i-a20-itead-ibox.dts | 125 ++++++++++++++++++++++ arch/arm/dts/sunxi-itead-core-common.dtsi | 136 ++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 + configs/Itead_Ibox_A20_defconfig | 16 +++ 6 files changed, 285 insertions(+), 84 deletions(-) create mode 100644 arch/arm/dts/sun7i-a20-itead-ibox.dts create mode 100644 arch/arm/dts/sunxi-itead-core-common.dtsi create mode 100644 configs/Itead_Ibox_A20_defconfig
Add dts and defconfig for the multi board device based on the Allwinner A20 SoC. It contains the A20 Itead Core module and a base board for the external interfaces.
The core module comes with 4GB NAND and 1GB DDR RAM. As this is a generic design which has also been used on a A10 board then a common core dtsi file is included.
The base board to which the core board is connected provides 3 USB 2.0 Host ports, 1 USB 2.0 OTG, 1 uSD slot, 10/100 Ethernet port, HDMI, IR receiver, SPDIF and a 32-pin GPIO header. This header expands the features of core board by exposing the VGA pins, audio In/Out pins, SATA, SPI, I2C, UARTS, USB-OTG and power..
Signed-off-by: Marcus Cooper codekipper@gmail.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/sun7i-a20-itead-ibox.dts | 125 +++++++++++++++++++++++++++ arch/arm/dts/sunxi-itead-core-common.dtsi | 136 ++++++++++++++++++++++++++++++ board/sunxi/MAINTAINERS | 5 ++ configs/Itead_Ibox_A20_defconfig | 16 ++++ 5 files changed, 283 insertions(+) create mode 100644 arch/arm/dts/sun7i-a20-itead-ibox.dts create mode 100644 arch/arm/dts/sunxi-itead-core-common.dtsi create mode 100644 configs/Itead_Ibox_A20_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b574284..466f961 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -162,6 +162,7 @@ dtb-$(CONFIG_MACH_SUN7I) += \ sun7i-a20-cubietruck.dtb \ sun7i-a20-hummingbird.dtb \ sun7i-a20-i12-tvbox.dtb \ + sun7i-a20-itead-ibox.dtb \ sun7i-a20-lamobo-r1.dtb \ sun7i-a20-m3.dtb \ sun7i-a20-m5.dtb \ diff --git a/arch/arm/dts/sun7i-a20-itead-ibox.dts b/arch/arm/dts/sun7i-a20-itead-ibox.dts new file mode 100644 index 0000000..661c21d --- /dev/null +++ b/arch/arm/dts/sun7i-a20-itead-ibox.dts @@ -0,0 +1,125 @@ +/* + * Copyright 2015 - Marcus Cooper codekipper@gmail.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +/dts-v1/; +#include "sun7i-a20.dtsi" +#include "sunxi-itead-core-common.dtsi" + +/ { + model = "Itead Ibox A20"; + compatible = "itead,itead-ibox-a20", "allwinner,sun7i-a20"; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&led_pins_itead_core>; + + green { + label = "itead_core:green:usr"; + gpios = <&pio 7 20 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + + blue { + label = "itead_core:blue:usr"; + gpios = <&pio 7 21 GPIO_ACTIVE_HIGH>; + default-state = "on"; + }; + }; +}; + +&ahci { + target-supply = <®_ahci_5v>; + status = "okay"; +}; + +&codec { + status = "okay"; +}; + +&gmac { + pinctrl-names = "default"; + pinctrl-0 = <&gmac_pins_mii_a>; + phy = <&phy1>; + phy-mode = "mii"; + status = "okay"; + + phy1: ethernet-phy@1 { + reg = <1>; + }; +}; + +&i2c0 { + axp209: pmic@34 { + interrupt-parent = <&nmi_intc>; + interrupts = <0 IRQ_TYPE_LEVEL_LOW>; + }; +}; + +&ir0 { + pinctrl-names = "default"; + pinctrl-0 = <&ir0_rx_pins_a>; + status = "okay"; +}; + +&mmc0 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin_reference_design>; + vmmc-supply = <®_vcc3v3>; + bus-width = <4>; + cd-gpios = <&pio 7 1 GPIO_ACTIVE_HIGH>; /* PH1 */ + cd-inverted; + status = "okay"; +}; + +&pio { + led_pins_itead_core: led_pins@0 { + allwinner,pins = "PH20","PH21"; + allwinner,function = "gpio_out"; + allwinner,drive = <SUN4I_PINCTRL_20_MA>; + allwinner,pull = <SUN4I_PINCTRL_NO_PULL>; + }; +}; + +®_ahci_5v { + status = "okay"; +}; diff --git a/arch/arm/dts/sunxi-itead-core-common.dtsi b/arch/arm/dts/sunxi-itead-core-common.dtsi new file mode 100644 index 0000000..2565d51 --- /dev/null +++ b/arch/arm/dts/sunxi-itead-core-common.dtsi @@ -0,0 +1,136 @@ +/* + * Copyright 2015 - Marcus Cooper codekipper@gmail.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include "sunxi-common-regulators.dtsi" + +/ { + aliases { + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&cpu0 { + cpu-supply = <®_dcdc2>; +}; + +&ehci0 { + status = "okay"; +}; + +&ehci1 { + status = "okay"; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins_a>; + status = "okay"; + + axp209: pmic@34 { + reg = <0x34>; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins_a>; + status = "okay"; +}; + +&ohci0 { + status = "okay"; +}; + +&ohci1 { + status = "okay"; +}; + +#include "axp209.dtsi" + +®_dcdc2 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-cpu"; +}; + +®_dcdc3 { + regulator-always-on; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1400000>; + regulator-name = "vdd-int-dll"; +}; + +®_ldo1 { + regulator-name = "vdd-rtc"; +}; + +®_ldo2 { + regulator-always-on; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-name = "avcc"; +}; + +®_usb1_vbus { + status = "okay"; +}; + +®_usb2_vbus { + status = "okay"; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins_a>; + status = "okay"; +}; + +&usbphy { + usb1_vbus-supply = <®_usb1_vbus>; + usb2_vbus-supply = <®_usb2_vbus>; + status = "okay"; +}; diff --git a/board/sunxi/MAINTAINERS b/board/sunxi/MAINTAINERS index 739b6fd..4365ba7 100644 --- a/board/sunxi/MAINTAINERS +++ b/board/sunxi/MAINTAINERS @@ -112,6 +112,11 @@ M: Chen-Yu Tsai wens@csie.org S: Maintained F: configs/Hummingbird_A31_defconfig
+ITEAD IBOX BOARD +M: Marcus Cooper codekipper@gmail.com +S: Maintained +F: configs/Itead_Ibox_A20_defconfig + INET 3F BOARD M: Paul Kocialkowski contact@paulk.fr S: Maintained diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig new file mode 100644 index 0000000..fab5f34 --- /dev/null +++ b/configs/Itead_Ibox_A20_defconfig @@ -0,0 +1,16 @@ +CONFIG_ARM=y +CONFIG_ARCH_SUNXI=y +CONFIG_MACH_SUN7I=y +CONFIG_DRAM_CLK=480 +CONFIG_MMC0_CD_PIN="PH1" +CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" +# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +#CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_GPIO=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_USB_EHCI_HCD=y
The delivery of the Itead Ibox A20 contained a common include dtsi file for the core module which this Itead Iteadunio Plus uses. This patch modifies the dts to use this include dtsi.
Signed-off-by: Marcus Cooper codekipper@gmail.com --- arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts | 86 +------------------------ 1 file changed, 2 insertions(+), 84 deletions(-)
diff --git a/arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts b/arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts index 985e155..4e798f0 100644 --- a/arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts +++ b/arch/arm/dts/sun4i-a10-itead-iteaduino-plus.dts @@ -1,5 +1,6 @@ /* * Copyright 2015 Josef Gajdusek atx@atx.name + * Copyright 2015 - Marcus Cooper codekipper@gmail.com * * This file is dual-licensed: you can use it either under the terms * of the GPL or the X11 license, at your option. Note that this dual @@ -42,22 +43,11 @@
/dts-v1/; #include "sun4i-a10.dtsi" -#include "sunxi-common-regulators.dtsi" - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/sun4i-a10.h> +#include "sunxi-itead-core-common.dtsi"
/ { model = "Iteaduino Plus A10"; compatible = "itead,iteaduino-plus-a10", "allwinner,sun4i-a10"; - - aliases { - serial0 = &uart0; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; };
&ahci { @@ -65,18 +55,6 @@ status = "okay"; };
-&cpu0 { - cpu-supply = <®_dcdc2>; -}; - -&ehci0 { - status = "okay"; -}; - -&ehci1 { - status = "okay"; -}; - &emac { pinctrl-names = "default"; pinctrl-0 = <&emac_pins_a>; @@ -89,12 +67,7 @@ };
&i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_pins_a>; - status = "okay"; - axp209: pmic@34 { - reg = <0x34>; interrupts = <0>; }; }; @@ -135,68 +108,13 @@ status = "okay"; };
-&ohci0 { - status = "okay"; -}; - -&ohci1 { - status = "okay"; -}; - ®_ahci_5v { status = "okay"; };
-#include "axp209.dtsi" - -®_dcdc2 { - regulator-always-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1450000>; - regulator-name = "vdd-cpu"; -}; - -®_dcdc3 { - regulator-always-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1400000>; - regulator-name = "vdd-int-dll"; -}; - -®_ldo1 { - regulator-name = "vdd-rtc"; -}; - -®_ldo2 { - regulator-always-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-name = "avcc"; -}; - -®_usb1_vbus { - status = "okay"; -}; - -®_usb2_vbus { - status = "okay"; -}; - &spi0 { pinctrl-names = "default"; pinctrl-0 = <&spi0_pins_a>, <&spi0_cs0_pins_a>; status = "okay"; }; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_pins_a>; - status = "okay"; -}; - -&usbphy { - usb1_vbus-supply = <®_usb1_vbus>; - usb2_vbus-supply = <®_usb2_vbus>; - status = "okay"; -};
NAK - just noticed a rouge patch that I didn't squash into this. Will fix straight away. CK
-- 2.7.3
Code Kipper
