[PATCH u-boot-marvell v4 0/9] More verifications for kwbimage in SPL
Hello Stefan,
this is v4 of series that adds more checks for kwbimage validity and consistency to SPL, mainly checking image data checksum.
Patches now passed Github CI testing: https://github.com/u-boot/u-boot/pull/106
Changes since v3: - fix compile erros detected by CI (patch 2) - print addresses in hex format instead of dec format (patch 1,3,6) - rebase on master branch as v3 does not apply (patch 8)
Changes since v2: - changed the error message in patch 6 according to Pali's suggestion - added R-B tags
Changes since v1: - updated error messages as requested by Stefan - fixed checkpatch warnings for uintN_t types (converted to preferred uN) - added more checkpatch fixes
Marek Behún (4): arm: mvebu: spl: Print srcaddr in error message arm: mvebu: spl: Use preferred types u8/u16/u32 instead of uintN_t arm: mvebu: spl: Use IS_ENABLED() instead of #ifdef where possible arm: mvebu: spl: Fix 100 column exceeds
Pali Rohár (5): arm: mvebu: Check that kwbimage offset and blocksize are valid SPL: Add struct spl_boot_device parameter into spl_parse_board_header() arm: mvebu: Check that kwbimage blockid matches boot mode SPL: Add support for checking board / BootROM specific image types arm: mvebu: Check for kwbimage data checksum
arch/arm/mach-mvebu/spl.c | 133 +++++++++++++++++++--------- arch/arm/mach-sunxi/spl_spi_sunxi.c | 2 +- common/spl/spl.c | 13 ++- common/spl/spl_ext.c | 9 +- common/spl/spl_fat.c | 11 ++- common/spl/spl_legacy.c | 3 +- common/spl/spl_mmc.c | 43 +++++---- common/spl/spl_nand.c | 13 +-- common/spl/spl_net.c | 2 +- common/spl/spl_nor.c | 4 +- common/spl/spl_onenand.c | 2 +- common/spl/spl_ram.c | 2 +- common/spl/spl_sata.c | 9 +- common/spl/spl_sdp.c | 2 +- common/spl/spl_spi.c | 9 +- common/spl/spl_ubi.c | 4 +- common/spl/spl_usb.c | 4 +- common/spl/spl_xip.c | 4 +- common/spl/spl_ymodem.c | 4 +- drivers/usb/gadget/f_sdp.c | 13 +-- include/sdp.h | 3 +- include/spl.h | 7 ++ 22 files changed, 196 insertions(+), 100 deletions(-)
There are certain restrictions for kwbimage offset and blocksize. Validate them.
Signed-off-by: Pali Rohár pali@kernel.org Signed-off-by: Marek Behún marek.behun@nic.cz Reviewed-by: Stefan Roese sr@denx.de --- arch/arm/mach-mvebu/spl.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index aada83f1902a..47b64c14631b 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -162,6 +162,18 @@ int spl_parse_board_header(struct spl_image_info *spl_image, spl_image->offset *= 512; #endif
+ if (spl_image->offset % 4 != 0) { + printf("ERROR: Wrong srcaddr (0x%08x) in kwbimage\n", + spl_image->offset); + return -EINVAL; + } + + if (mhdr->blocksize <= 4 || mhdr->blocksize % 4 != 0) { + printf("ERROR: Wrong blocksize (0x%08x) in kwbimage\n", + mhdr->blocksize); + return -EINVAL; + } + spl_image->size = mhdr->blocksize; spl_image->entry_point = mhdr->execaddr; spl_image->load_addr = mhdr->destaddr;
Add parameter spl_boot_device to spl_parse_board_header(), which allows the implementations to see from which device we are booting and do boot-device-specific checks of the image header.
Signed-off-by: Pali Rohár pali@kernel.org Signed-off-by: Marek Behún marek.behun@nic.cz Reviewed-by: Stefan Roese sr@denx.de --- arch/arm/mach-mvebu/spl.c | 1 + arch/arm/mach-sunxi/spl_spi_sunxi.c | 2 +- common/spl/spl.c | 4 ++- common/spl/spl_ext.c | 9 ++++-- common/spl/spl_fat.c | 11 +++++--- common/spl/spl_legacy.c | 3 +- common/spl/spl_mmc.c | 43 ++++++++++++++++++----------- common/spl/spl_nand.c | 13 +++++---- common/spl/spl_net.c | 2 +- common/spl/spl_nor.c | 4 +-- common/spl/spl_onenand.c | 2 +- common/spl/spl_ram.c | 2 +- common/spl/spl_sata.c | 9 +++--- common/spl/spl_sdp.c | 2 +- common/spl/spl_spi.c | 9 +++--- common/spl/spl_ubi.c | 4 +-- common/spl/spl_usb.c | 4 +-- common/spl/spl_xip.c | 4 +-- common/spl/spl_ymodem.c | 4 +-- drivers/usb/gadget/f_sdp.c | 13 +++++---- include/sdp.h | 3 +- include/spl.h | 7 +++++ 22 files changed, 95 insertions(+), 60 deletions(-)
diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index 47b64c14631b..fe22951e16c0 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -100,6 +100,7 @@ u32 spl_mmc_boot_mode(const u32 boot_device) #endif
int spl_parse_board_header(struct spl_image_info *spl_image, + const struct spl_boot_device *bootdev, const void *image_header, size_t size) { const struct kwbimage_main_hdr_v1 *mhdr = image_header; diff --git a/arch/arm/mach-sunxi/spl_spi_sunxi.c b/arch/arm/mach-sunxi/spl_spi_sunxi.c index 3499c4cc5f88..910e80501617 100644 --- a/arch/arm/mach-sunxi/spl_spi_sunxi.c +++ b/arch/arm/mach-sunxi/spl_spi_sunxi.c @@ -348,7 +348,7 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, ret = spl_load_simple_fit(spl_image, &load, load_offset, header); } else { - ret = spl_parse_image_header(spl_image, header); + ret = spl_parse_image_header(spl_image, bootdev, header); if (ret) return ret;
diff --git a/common/spl/spl.c b/common/spl/spl.c index 4c101ec5d34e..bf2139a05888 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -312,6 +312,7 @@ static int spl_load_fit_image(struct spl_image_info *spl_image, #endif
__weak int spl_parse_board_header(struct spl_image_info *spl_image, + const struct spl_boot_device *bootdev, const void *image_header, size_t size) { return -EINVAL; @@ -326,6 +327,7 @@ __weak int spl_parse_legacy_header(struct spl_image_info *spl_image, }
int spl_parse_image_header(struct spl_image_info *spl_image, + const struct spl_boot_device *bootdev, const struct image_header *header) { #if CONFIG_IS_ENABLED(LOAD_FIT_FULL) @@ -369,7 +371,7 @@ int spl_parse_image_header(struct spl_image_info *spl_image, } #endif
- if (!spl_parse_board_header(spl_image, (const void *)header, sizeof(*header))) + if (!spl_parse_board_header(spl_image, bootdev, (const void *)header, sizeof(*header))) return 0;
#ifdef CONFIG_SPL_RAW_IMAGE_SUPPORT diff --git a/common/spl/spl_ext.c b/common/spl/spl_ext.c index 6a28fe9bdb50..ebd914c49267 100644 --- a/common/spl/spl_ext.c +++ b/common/spl/spl_ext.c @@ -10,6 +10,7 @@ #include <image.h>
int spl_load_image_ext(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition, const char *filename) { @@ -46,7 +47,7 @@ int spl_load_image_ext(struct spl_image_info *spl_image, goto end; }
- err = spl_parse_image_header(spl_image, header); + err = spl_parse_image_header(spl_image, bootdev, header); if (err < 0) { puts("spl: ext: failed to parse image header\n"); goto end; @@ -66,6 +67,7 @@ end:
#if CONFIG_IS_ENABLED(OS_BOOT) int spl_load_image_ext_os(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition) { int err; @@ -103,7 +105,7 @@ int spl_load_image_ext_os(struct spl_image_info *spl_image, } file = env_get("falcon_image_file"); if (file) { - err = spl_load_image_ext(spl_image, block_dev, + err = spl_load_image_ext(spl_image, bootdev, block_dev, partition, file); if (err != 0) { puts("spl: falling back to default\n"); @@ -134,11 +136,12 @@ defaults: return -1; }
- return spl_load_image_ext(spl_image, block_dev, partition, + return spl_load_image_ext(spl_image, bootdev, block_dev, partition, CONFIG_SPL_FS_LOAD_KERNEL_NAME); } #else int spl_load_image_ext_os(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition) { return -ENOSYS; diff --git a/common/spl/spl_fat.c b/common/spl/spl_fat.c index 576c2e876adc..5b270541fcc7 100644 --- a/common/spl/spl_fat.c +++ b/common/spl/spl_fat.c @@ -55,6 +55,7 @@ static ulong spl_fit_read(struct spl_load_info *load, ulong file_offset, }
int spl_load_image_fat(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition, const char *filename) { @@ -76,7 +77,7 @@ int spl_load_image_fat(struct spl_image_info *spl_image, err = file_fat_read(filename, (void *)CONFIG_SYS_LOAD_ADDR, 0); if (err <= 0) goto end; - err = spl_parse_image_header(spl_image, + err = spl_parse_image_header(spl_image, bootdev, (struct image_header *)CONFIG_SYS_LOAD_ADDR); if (err == -EAGAIN) return err; @@ -94,7 +95,7 @@ int spl_load_image_fat(struct spl_image_info *spl_image,
return spl_load_simple_fit(spl_image, &load, 0, header); } else { - err = spl_parse_image_header(spl_image, header); + err = spl_parse_image_header(spl_image, bootdev, header); if (err) goto end;
@@ -114,6 +115,7 @@ end:
#if CONFIG_IS_ENABLED(OS_BOOT) int spl_load_image_fat_os(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition) { int err; @@ -134,7 +136,7 @@ int spl_load_image_fat_os(struct spl_image_info *spl_image, } file = env_get("falcon_image_file"); if (file) { - err = spl_load_image_fat(spl_image, block_dev, + err = spl_load_image_fat(spl_image, bootdev, block_dev, partition, file); if (err != 0) { puts("spl: falling back to default\n"); @@ -160,11 +162,12 @@ defaults: return -1; }
- return spl_load_image_fat(spl_image, block_dev, partition, + return spl_load_image_fat(spl_image, bootdev, block_dev, partition, CONFIG_SPL_FS_LOAD_KERNEL_NAME); } #else int spl_load_image_fat_os(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition) { return -ENOSYS; diff --git a/common/spl/spl_legacy.c b/common/spl/spl_legacy.c index 82d032680616..2ec715442389 100644 --- a/common/spl/spl_legacy.c +++ b/common/spl/spl_legacy.c @@ -76,6 +76,7 @@ static inline int spl_image_get_comp(const struct image_header *hdr) }
int spl_load_legacy_img(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct spl_load_info *load, ulong header) { __maybe_unused SizeT lzma_len; @@ -87,7 +88,7 @@ int spl_load_legacy_img(struct spl_image_info *spl_image, /* Read header into local struct */ load->read(load, header, sizeof(hdr), &hdr);
- ret = spl_parse_image_header(spl_image, &hdr); + ret = spl_parse_image_header(spl_image, bootdev, &hdr); if (ret) return ret;
diff --git a/common/spl/spl_mmc.c b/common/spl/spl_mmc.c index e1a7d25bd05a..d550da2d97ec 100644 --- a/common/spl/spl_mmc.c +++ b/common/spl/spl_mmc.c @@ -17,7 +17,9 @@ #include <mmc.h> #include <image.h>
-static int mmc_load_legacy(struct spl_image_info *spl_image, struct mmc *mmc, +static int mmc_load_legacy(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, + struct mmc *mmc, ulong sector, struct image_header *header) { u32 image_offset_sectors; @@ -26,7 +28,7 @@ static int mmc_load_legacy(struct spl_image_info *spl_image, struct mmc *mmc, u32 image_offset; int ret;
@@ -77,6 +79,7 @@ static __maybe_unused unsigned long spl_mmc_raw_uboot_offset(int part)
static __maybe_unused int mmc_load_image_raw_sector(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct mmc *mmc, unsigned long sector) { unsigned long count; @@ -116,7 +119,7 @@ int mmc_load_image_raw_sector(struct spl_image_info *spl_image,
ret = spl_load_imx_container(spl_image, &load, sector); } else { - ret = mmc_load_legacy(spl_image, mmc, sector, header); + ret = mmc_load_legacy(spl_image, bootdev, mmc, sector, header); }
end: @@ -181,6 +184,7 @@ static int spl_mmc_find_device(struct mmc **mmcp, u32 boot_device)
#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION static int mmc_load_image_raw_partition(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct mmc *mmc, int partition, unsigned long sector) { @@ -211,15 +215,16 @@ static int mmc_load_image_raw_partition(struct spl_image_info *spl_image, }
#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR - return mmc_load_image_raw_sector(spl_image, mmc, info.start + sector); + return mmc_load_image_raw_sector(spl_image, bootdev, mmc, info.start + sector); #else - return mmc_load_image_raw_sector(spl_image, mmc, info.start); + return mmc_load_image_raw_sector(spl_image, bootdev, mmc, info.start); #endif } #endif
#if CONFIG_IS_ENABLED(OS_BOOT) static int mmc_load_image_raw_os(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct mmc *mmc) { int ret; @@ -239,7 +244,7 @@ static int mmc_load_image_raw_os(struct spl_image_info *spl_image, } #endif /* CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR */
- ret = mmc_load_image_raw_sector(spl_image, mmc, + ret = mmc_load_image_raw_sector(spl_image, bootdev, mmc, CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR); if (ret) return ret; @@ -257,6 +262,7 @@ int spl_start_uboot(void) return 1; } static int mmc_load_image_raw_os(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct mmc *mmc) { return -ENOSYS; @@ -264,20 +270,22 @@ static int mmc_load_image_raw_os(struct spl_image_info *spl_image, #endif
#ifdef CONFIG_SYS_MMCSD_FS_BOOT_PARTITION -static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc, +static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, + struct mmc *mmc, const char *filename) { int err = -ENOSYS;
#ifdef CONFIG_SPL_FS_FAT if (!spl_start_uboot()) { - err = spl_load_image_fat_os(spl_image, mmc_get_blk_desc(mmc), + err = spl_load_image_fat_os(spl_image, bootdev, mmc_get_blk_desc(mmc), CONFIG_SYS_MMCSD_FS_BOOT_PARTITION); if (!err) return err; } #ifdef CONFIG_SPL_FS_LOAD_PAYLOAD_NAME - err = spl_load_image_fat(spl_image, mmc_get_blk_desc(mmc), + err = spl_load_image_fat(spl_image, bootdev, mmc_get_blk_desc(mmc), CONFIG_SYS_MMCSD_FS_BOOT_PARTITION, filename); if (!err) @@ -286,13 +294,13 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc, #endif #ifdef CONFIG_SPL_FS_EXT4 if (!spl_start_uboot()) { - err = spl_load_image_ext_os(spl_image, mmc_get_blk_desc(mmc), + err = spl_load_image_ext_os(spl_image, bootdev, mmc_get_blk_desc(mmc), CONFIG_SYS_MMCSD_FS_BOOT_PARTITION); if (!err) return err; } #ifdef CONFIG_SPL_FS_LOAD_PAYLOAD_NAME - err = spl_load_image_ext(spl_image, mmc_get_blk_desc(mmc), + err = spl_load_image_ext(spl_image, bootdev, mmc_get_blk_desc(mmc), CONFIG_SYS_MMCSD_FS_BOOT_PARTITION, filename); if (!err) @@ -307,7 +315,9 @@ static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc, return err; } #else -static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, struct mmc *mmc, +static int spl_mmc_do_fs_boot(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, + struct mmc *mmc, const char *filename) { return -ENOSYS; @@ -410,7 +420,7 @@ int spl_mmc_load(struct spl_image_info *spl_image, debug("spl: mmc boot mode: raw\n");
if (!spl_start_uboot()) { - err = mmc_load_image_raw_os(spl_image, mmc); + err = mmc_load_image_raw_os(spl_image, bootdev, mmc); if (!err) return err; } @@ -418,13 +428,14 @@ int spl_mmc_load(struct spl_image_info *spl_image, raw_sect = spl_mmc_get_uboot_raw_sector(mmc, raw_sect);
#ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION - err = mmc_load_image_raw_partition(spl_image, mmc, raw_part, + err = mmc_load_image_raw_partition(spl_image, bootdev, + mmc, raw_part, raw_sect); if (!err) return err; #endif #ifdef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR - err = mmc_load_image_raw_sector(spl_image, mmc, + err = mmc_load_image_raw_sector(spl_image, bootdev, mmc, raw_sect + spl_mmc_raw_uboot_offset(part)); if (!err) return err; @@ -433,7 +444,7 @@ int spl_mmc_load(struct spl_image_info *spl_image, case MMCSD_MODE_FS: debug("spl: mmc boot mode: fs\n");
- err = spl_mmc_do_fs_boot(spl_image, mmc, filename); + err = spl_mmc_do_fs_boot(spl_image, bootdev, mmc, filename); if (!err) return err;
diff --git a/common/spl/spl_nand.c b/common/spl/spl_nand.c index 8ae7d04fa634..fc61b447a52e 100644 --- a/common/spl/spl_nand.c +++ b/common/spl/spl_nand.c @@ -65,6 +65,7 @@ struct mtd_info * __weak nand_get_mtd(void) }
static int spl_nand_load_element(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, int offset, struct image_header *header) { struct mtd_info *mtd = nand_get_mtd(); @@ -96,7 +97,7 @@ static int spl_nand_load_element(struct spl_image_info *spl_image, load.read = spl_nand_fit_read; return spl_load_imx_container(spl_image, &load, offset / bl_len); } else { - err = spl_parse_image_header(spl_image, header); + err = spl_parse_image_header(spl_image, bootdev, header); if (err) return err; return nand_spl_load_image(offset, spl_image->size, @@ -145,7 +146,7 @@ static int spl_nand_load_image(struct spl_image_info *spl_image, /* load linux */ nand_spl_load_image(CONFIG_SYS_NAND_SPL_KERNEL_OFFS, sizeof(*header), (void *)header); - err = spl_parse_image_header(spl_image, header); + err = spl_parse_image_header(spl_image, bootdev, header); if (err) return err; if (header->ih_os == IH_OS_LINUX) { @@ -165,18 +166,18 @@ static int spl_nand_load_image(struct spl_image_info *spl_image, } #endif #ifdef CONFIG_NAND_ENV_DST - spl_nand_load_element(spl_image, CONFIG_ENV_OFFSET, header); + spl_nand_load_element(spl_image, bootdev, CONFIG_ENV_OFFSET, header); #ifdef CONFIG_ENV_OFFSET_REDUND - spl_nand_load_element(spl_image, CONFIG_ENV_OFFSET_REDUND, header); + spl_nand_load_element(spl_image, bootdev, CONFIG_ENV_OFFSET_REDUND, header); #endif #endif /* Load u-boot */ - err = spl_nand_load_element(spl_image, spl_nand_get_uboot_raw_page(), + err = spl_nand_load_element(spl_image, bootdev, spl_nand_get_uboot_raw_page(), header); #ifdef CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND #if CONFIG_SYS_NAND_U_BOOT_OFFS != CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND if (err) - err = spl_nand_load_element(spl_image, + err = spl_nand_load_element(spl_image, bootdev, CONFIG_SYS_NAND_U_BOOT_OFFS_REDUND, header); #endif diff --git a/common/spl/spl_net.c b/common/spl/spl_net.c index d23b395ab960..a853e6aead40 100644 --- a/common/spl/spl_net.c +++ b/common/spl/spl_net.c @@ -58,7 +58,7 @@ static int spl_net_load_image(struct spl_image_info *spl_image, } else { debug("Legacy image\n");
- rv = spl_parse_image_header(spl_image, header); + rv = spl_parse_image_header(spl_image, bootdev, header); if (rv) return rv;
diff --git a/common/spl/spl_nor.c b/common/spl/spl_nor.c index 68c12413fa68..0f4fff849362 100644 --- a/common/spl/spl_nor.c +++ b/common/spl/spl_nor.c @@ -66,7 +66,7 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, /* happy - was a Linux */ int ret;
@@ -113,7 +113,7 @@ static int spl_nor_load_image(struct spl_image_info *spl_image, if (IS_ENABLED(CONFIG_SPL_LEGACY_IMAGE_SUPPORT)) { load.bl_len = 1; load.read = spl_nor_load_read; - return spl_load_legacy_img(spl_image, &load, + return spl_load_legacy_img(spl_image, bootdev, &load, spl_nor_get_uboot_base()); }
diff --git a/common/spl/spl_onenand.c b/common/spl/spl_onenand.c index 93cbf47e8228..f80769a02770 100644 --- a/common/spl/spl_onenand.c +++ b/common/spl/spl_onenand.c @@ -27,7 +27,7 @@ static int spl_onenand_load_image(struct spl_image_info *spl_image, /* Load u-boot */ onenand_spl_load_image(CONFIG_SYS_ONENAND_U_BOOT_OFFS, CONFIG_SYS_ONENAND_PAGE_SIZE, (void *)header); - ret = spl_parse_image_header(spl_image, header); + ret = spl_parse_image_header(spl_image, bootdev, header); if (ret) return ret; onenand_spl_load_image(CONFIG_SYS_ONENAND_U_BOOT_OFFS, diff --git a/common/spl/spl_ram.c b/common/spl/spl_ram.c index df9f3a4d00f0..3f7f7accc111 100644 --- a/common/spl/spl_ram.c +++ b/common/spl/spl_ram.c @@ -70,7 +70,7 @@ static int spl_ram_load_image(struct spl_image_info *spl_image, } header = (struct image_header *)map_sysmem(u_boot_pos, 0);
- spl_parse_image_header(spl_image, header); + spl_parse_image_header(spl_image, bootdev, header); }
return 0; diff --git a/common/spl/spl_sata.c b/common/spl/spl_sata.c index e9f6c5f050b4..1f3a144cdfbf 100644 --- a/common/spl/spl_sata.c +++ b/common/spl/spl_sata.c @@ -31,6 +31,7 @@ #endif
static int spl_sata_load_image_raw(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct blk_desc *stor_dev, unsigned long sector) { struct image_header *header; @@ -45,7 +46,7 @@ static int spl_sata_load_image_raw(struct spl_image_info *spl_image, if (count == 0) return -EIO;
@@ -90,18 +91,18 @@ static int spl_sata_load_image(struct spl_image_info *spl_image,
#if CONFIG_IS_ENABLED(OS_BOOT) if (spl_start_uboot() || - spl_load_image_fat_os(spl_image, stor_dev, + spl_load_image_fat_os(spl_image, bootdev, stor_dev, CONFIG_SYS_SATA_FAT_BOOT_PARTITION)) #endif { err = -ENOSYS;
if (IS_ENABLED(CONFIG_SPL_FS_FAT)) { - err = spl_load_image_fat(spl_image, stor_dev, + err = spl_load_image_fat(spl_image, bootdev, stor_dev, CONFIG_SYS_SATA_FAT_BOOT_PARTITION, CONFIG_SPL_FS_LOAD_PAYLOAD_NAME); } else if (IS_ENABLED(CONFIG_SPL_SATA_RAW_U_BOOT_USE_SECTOR)) { - err = spl_sata_load_image_raw(spl_image, stor_dev, + err = spl_sata_load_image_raw(spl_image, bootdev, stor_dev, CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR); } } diff --git a/common/spl/spl_sdp.c b/common/spl/spl_sdp.c index ae9c09883a40..36c31aff099a 100644 --- a/common/spl/spl_sdp.c +++ b/common/spl/spl_sdp.c @@ -39,7 +39,7 @@ static int spl_sdp_load_image(struct spl_image_info *spl_image, * or it loads a FIT image and returns it to be handled by the SPL * code. */ - ret = spl_sdp_handle(controller_index, spl_image); + ret = spl_sdp_handle(controller_index, spl_image, bootdev); debug("SDP ended\n");
usb_gadget_release(controller_index); diff --git a/common/spl/spl_spi.c b/common/spl/spl_spi.c index 4e20a23dea09..cf3f7ef4c0d5 100644 --- a/common/spl/spl_spi.c +++ b/common/spl/spl_spi.c @@ -24,6 +24,7 @@ * the kernel and then device tree. */ static int spi_load_image_os(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct spi_flash *flash, struct image_header *header) { @@ -36,7 +37,7 @@ static int spi_load_image_os(struct spl_image_info *spl_image, if (image_get_magic(header) != IH_MAGIC) return -1;
@@ -108,7 +109,7 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, }
#if CONFIG_IS_ENABLED(OS_BOOT) - if (spl_start_uboot() || spi_load_image_os(spl_image, flash, header)) + if (spl_start_uboot() || spi_load_image_os(spl_image, bootdev, flash, header)) #endif { /* Load u-boot, mkimage header is 64 bytes. */ @@ -127,7 +128,7 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, (void *)CONFIG_SYS_LOAD_ADDR); if (err) return err; - err = spl_parse_image_header(spl_image, + err = spl_parse_image_header(spl_image, bootdev, (struct image_header *)CONFIG_SYS_LOAD_ADDR); } else if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && image_get_magic(header) == FDT_MAGIC) { @@ -154,7 +155,7 @@ static int spl_spi_load_image(struct spl_image_info *spl_image, err = spl_load_imx_container(spl_image, &load, payload_offs); } else { - err = spl_parse_image_header(spl_image, header); + err = spl_parse_image_header(spl_image, bootdev, header); if (err) return err; err = spi_flash_read(flash, payload_offs + spl_image->offset, diff --git a/common/spl/spl_ubi.c b/common/spl/spl_ubi.c index 2f2d74a02de1..bdf5cc4c3833 100644 --- a/common/spl/spl_ubi.c +++ b/common/spl/spl_ubi.c @@ -55,7 +55,7 @@ int spl_ubi_load_image(struct spl_image_info *spl_image, ret = ubispl_load_volumes(&info, volumes, 2); if (!ret) { header = (struct image_header *)volumes[0].load_addr; - spl_parse_image_header(spl_image, header); + spl_parse_image_header(spl_image, bootdev, header); puts("Linux loaded.\n"); goto out; } @@ -75,7 +75,7 @@ int spl_ubi_load_image(struct spl_image_info *spl_image,
ret = ubispl_load_volumes(&info, volumes, 1); if (!ret) - spl_parse_image_header(spl_image, header); + spl_parse_image_header(spl_image, bootdev, header); out: #ifdef CONFIG_SPL_NAND_SUPPORT if (bootdev->boot_device == BOOT_DEVICE_NAND) diff --git a/common/spl/spl_usb.c b/common/spl/spl_usb.c index 67d503026ca8..ccf01c8276b4 100644 --- a/common/spl/spl_usb.c +++ b/common/spl/spl_usb.c @@ -49,10 +49,10 @@ int spl_usb_load(struct spl_image_info *spl_image,
#if CONFIG_IS_ENABLED(OS_BOOT) if (spl_start_uboot() || - spl_load_image_fat_os(spl_image, stor_dev, partition)) + spl_load_image_fat_os(spl_image, bootdev, stor_dev, partition)) #endif { - err = spl_load_image_fat(spl_image, stor_dev, partition, filename); + err = spl_load_image_fat(spl_image, bootdev, stor_dev, partition, filename); }
if (err) { diff --git a/common/spl/spl_xip.c b/common/spl/spl_xip.c index ba4af38a3eca..33863fe7d454 100644 --- a/common/spl/spl_xip.c +++ b/common/spl/spl_xip.c @@ -24,7 +24,7 @@ static int spl_xip(struct spl_image_info *spl_image, return 0; } #endif - return(spl_parse_image_header(spl_image, (const struct image_header *) - CONFIG_SYS_UBOOT_BASE)); + return(spl_parse_image_header(spl_image, bootdev, + (const struct image_header *)CONFIG_SYS_UBOOT_BASE)); } SPL_LOAD_IMAGE_METHOD("XIP", 0, BOOT_DEVICE_XIP, spl_xip); diff --git a/common/spl/spl_ymodem.c b/common/spl/spl_ymodem.c index e979f780ad09..047df74856b6 100644 --- a/common/spl/spl_ymodem.c +++ b/common/spl/spl_ymodem.c @@ -112,7 +112,7 @@ int spl_ymodem_load_image(struct spl_image_info *spl_image, addr += res; }
- ret = spl_parse_image_header(spl_image, ih); + ret = spl_parse_image_header(spl_image, bootdev, ih); if (ret) return ret; } else if (IS_ENABLED(CONFIG_SPL_LOAD_FIT) && @@ -135,7 +135,7 @@ int spl_ymodem_load_image(struct spl_image_info *spl_image, size += res; } else { ih = (struct image_header *)buf; - ret = spl_parse_image_header(spl_image, ih); + ret = spl_parse_image_header(spl_image, bootdev, ih); if (ret) goto end_stream; #ifdef CONFIG_SPL_GZIP diff --git a/drivers/usb/gadget/f_sdp.c b/drivers/usb/gadget/f_sdp.c index e48aa2f90df1..0fa7230b992a 100644 --- a/drivers/usb/gadget/f_sdp.c +++ b/drivers/usb/gadget/f_sdp.c @@ -773,7 +773,8 @@ static ulong search_container_header(ulong p, int size) } #endif
-static int sdp_handle_in_ep(struct spl_image_info *spl_image) +static int sdp_handle_in_ep(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev) { u8 *data = sdp_func->in_req->buf; u32 status; @@ -862,7 +863,8 @@ static int sdp_handle_in_ep(struct spl_image_info *spl_image)
/* In SPL, allow jumps to U-Boot images */ struct spl_image_info spl_image = {}; - spl_parse_image_header(&spl_image, header); + struct spl_boot_device bootdev = {}; + spl_parse_image_header(&spl_image, &bootdev, header); jump_to_image_no_args(&spl_image); #else /* In U-Boot, allow jumps to scripts */ @@ -910,7 +912,8 @@ static void sdp_handle_out_ep(void) #ifndef CONFIG_SPL_BUILD int sdp_handle(int controller_index) #else -int spl_sdp_handle(int controller_index, struct spl_image_info *spl_image) +int spl_sdp_handle(int controller_index, struct spl_image_info *spl_image, + struct spl_boot_device *bootdev) #endif { int flag = 0; @@ -928,9 +931,9 @@ int spl_sdp_handle(int controller_index, struct spl_image_info *spl_image) usb_gadget_handle_interrupts(controller_index);
#ifdef CONFIG_SPL_BUILD - flag = sdp_handle_in_ep(spl_image); + flag = sdp_handle_in_ep(spl_image, bootdev); #else - flag = sdp_handle_in_ep(NULL); + flag = sdp_handle_in_ep(NULL, NULL); #endif if (sdp_func->ep_int_enable) sdp_handle_out_ep(); diff --git a/include/sdp.h b/include/sdp.h index 6ac64fb1f316..6d89baa04ec5 100644 --- a/include/sdp.h +++ b/include/sdp.h @@ -14,7 +14,8 @@ int sdp_init(int controller_index); #ifdef CONFIG_SPL_BUILD #include <spl.h>
-int spl_sdp_handle(int controller_index, struct spl_image_info *spl_image); +int spl_sdp_handle(int controller_index, struct spl_image_info *spl_image, + struct spl_boot_device *bootdev); #else int sdp_handle(int controller_index); #endif diff --git a/include/spl.h b/include/spl.h index 0af0ee300345..469e7fe1cc3d 100644 --- a/include/spl.h +++ b/include/spl.h @@ -29,6 +29,7 @@ struct image_header;
struct blk_desc; struct image_header; +struct spl_boot_device;
/* * u_boot_first_phase() - check if this is the first U-Boot phase @@ -340,6 +341,7 @@ int spl_load_simple_fit(struct spl_image_info *spl_image, * Returns 0 on success. */ int spl_load_legacy_img(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct spl_load_info *load, ulong header);
/** @@ -438,6 +440,7 @@ void spl_set_header_raw_uboot(struct spl_image_info *spl_image); * @return 0 if a header was correctly parsed, -ve on error */ int spl_parse_image_header(struct spl_image_info *spl_image, + const struct spl_boot_device *bootdev, const struct image_header *header);
void spl_board_prepare_for_linux(void); @@ -574,18 +577,22 @@ static inline const char *spl_loader_name(const struct spl_image_loader *loader)
/* SPL FAT image functions */ int spl_load_image_fat(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition, const char *filename); int spl_load_image_fat_os(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition);
void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image);
/* SPL EXT image functions */ int spl_load_image_ext(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition, const char *filename); int spl_load_image_ext_os(struct spl_image_info *spl_image, + struct spl_boot_device *bootdev, struct blk_desc *block_dev, int partition);
Each boot mode has its own kwbimage specified by blockid. So check that kwbimage is valid by blockid.
Signed-off-by: Pali Rohár pali@kernel.org Signed-off-by: Marek Behún marek.behun@nic.cz Reviewed-by: Stefan Roese sr@denx.de --- arch/arm/mach-mvebu/spl.c | 35 ++++++++++++++++++++++++++--------- 1 file changed, 26 insertions(+), 9 deletions(-)
diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index fe22951e16c0..62e4fe12d65c 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -117,22 +117,39 @@ int spl_parse_board_header(struct spl_image_info *spl_image, * (including SPL content) which is not included in U-Boot image_header. */ if (mhdr->version != 1 || - ((mhdr->headersz_msb << 16) | mhdr->headersz_lsb) < sizeof(*mhdr) || - ( + ((mhdr->headersz_msb << 16) | mhdr->headersz_lsb) < sizeof(*mhdr)) { + printf("ERROR: Invalid kwbimage v1\n"); + return -EINVAL; + } + #ifdef CONFIG_SPL_SPI_FLASH_SUPPORT - mhdr->blockid != IBR_HDR_SPI_ID && + if (bootdev->boot_device == BOOT_DEVICE_SPI && + mhdr->blockid != IBR_HDR_SPI_ID) { + printf("ERROR: Wrong blockid (0x%x) in SPI kwbimage\n", + mhdr->blockid); + return -EINVAL; + } #endif + #ifdef CONFIG_SPL_SATA - mhdr->blockid != IBR_HDR_SATA_ID && + if (bootdev->boot_device == BOOT_DEVICE_SATA && + mhdr->blockid != IBR_HDR_SATA_ID) { + printf("ERROR: Wrong blockid (0x%x) in SATA kwbimage\n", + mhdr->blockid); + return -EINVAL; + } #endif + #ifdef CONFIG_SPL_MMC - mhdr->blockid != IBR_HDR_SDIO_ID && -#endif - 1 - )) { - printf("ERROR: Not valid SPI/NAND/SATA/SDIO kwbimage v1\n"); + if ((bootdev->boot_device == BOOT_DEVICE_MMC1 || + bootdev->boot_device == BOOT_DEVICE_MMC2 || + bootdev->boot_device == BOOT_DEVICE_MMC2_2) && + mhdr->blockid != IBR_HDR_SDIO_ID) { + printf("ERROR: Wrong blockid (0x%x) in SDIO kwbimage\n", + mhdr->blockid); return -EINVAL; } +#endif
spl_image->offset = mhdr->srcaddr;
Commit 9baab60b8054 ("SPL: Add support for parsing board / BootROM specific image types") added support for loading board specific image types.
This commit adds support for a new weak function spl_parse_board_header() which is called after loading boot image. Board may implement this function for checking if loaded board specific image is valid.
Signed-off-by: Pali Rohár pali@kernel.org Signed-off-by: Marek Behún marek.behun@nic.cz Reviewed-by: Stefan Roese sr@denx.de --- common/spl/spl.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/common/spl/spl.c b/common/spl/spl.c index bf2139a05888..cc3b3b3438e2 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -589,6 +589,12 @@ static struct spl_image_loader *spl_ll_find_loader(uint boot_device) return NULL; }
+__weak int spl_check_board_image(struct spl_image_info *spl_image, + const struct spl_boot_device *bootdev) +{ + return 0; +} + static int spl_load_image(struct spl_image_info *spl_image, struct spl_image_loader *loader) { @@ -610,6 +616,9 @@ static int spl_load_image(struct spl_image_info *spl_image, } } #endif + if (!ret) + ret = spl_check_board_image(spl_image, &bootdev); + return ret; }
Last 4 bytes of kwbimage boot image is checksum. Verify it via the new spl_check_board_image() function which is called by U-Boot SPL after loading kwbimage.
Signed-off-by: Pali Rohár pali@kernel.org Signed-off-by: Marek Behún marek.behun@nic.cz Reviewed-by: Stefan Roese sr@denx.de --- arch/arm/mach-mvebu/spl.c | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index 62e4fe12d65c..72cc2f92f698 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -99,6 +99,33 @@ u32 spl_mmc_boot_mode(const u32 boot_device) } #endif
+static u32 checksum32(void *start, u32 len) +{ + u32 csum = 0; + u32 *p = start; + + while (len > 0) { + csum += *p++; + len -= sizeof(u32); + }; + + return csum; +} + +int spl_check_board_image(struct spl_image_info *spl_image, + const struct spl_boot_device *bootdev) +{ + u32 csum = *(u32 *)(spl_image->load_addr + spl_image->size - 4); + + if (checksum32((void *)spl_image->load_addr, + spl_image->size - 4) != csum) { + printf("ERROR: Invalid data checksum in kwbimage\n"); + return -EINVAL; + } + + return 0; +} + int spl_parse_board_header(struct spl_image_info *spl_image, const struct spl_boot_device *bootdev, const void *image_header, size_t size)
Print the wrong srcaddr (spl_image->offset) in error message also for SATA case.
Signed-off-by: Marek Behún marek.behun@nic.cz Reviewed-by: Stefan Roese sr@denx.de --- arch/arm/mach-mvebu/spl.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index 72cc2f92f698..eacac776530c 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -189,7 +189,8 @@ int spl_parse_board_header(struct spl_image_info *spl_image, */ if (mhdr->blockid == IBR_HDR_SATA_ID) { if (spl_image->offset < 1) { - printf("ERROR: Wrong SATA srcaddr in kwbimage\n"); + printf("ERROR: Wrong srcaddr (0x%08x) in SATA kwbimage\n", + spl_image->offset); return -EINVAL; } spl_image->offset -= 1;
Checkpatch warns about using uint32/16/8_t instead of u32/16/8.
Use the preferred types.
Signed-off-by: Marek Behún marek.behun@nic.cz Reviewed-by: Stefan Roese sr@denx.de --- arch/arm/mach-mvebu/spl.c | 34 +++++++++++++++++----------------- 1 file changed, 17 insertions(+), 17 deletions(-)
diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index eacac776530c..103049b49b89 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -73,23 +73,23 @@
/* Structure of the main header, version 1 (Armada 370/XP/375/38x/39x) */ struct kwbimage_main_hdr_v1 { - uint8_t blockid; /* 0x0 */ - uint8_t flags; /* 0x1 */ - uint16_t nandpagesize; /* 0x2-0x3 */ - uint32_t blocksize; /* 0x4-0x7 */ - uint8_t version; /* 0x8 */ - uint8_t headersz_msb; /* 0x9 */ - uint16_t headersz_lsb; /* 0xA-0xB */ - uint32_t srcaddr; /* 0xC-0xF */ - uint32_t destaddr; /* 0x10-0x13 */ - uint32_t execaddr; /* 0x14-0x17 */ - uint8_t options; /* 0x18 */ - uint8_t nandblocksize; /* 0x19 */ - uint8_t nandbadblklocation; /* 0x1A */ - uint8_t reserved4; /* 0x1B */ - uint16_t reserved5; /* 0x1C-0x1D */ - uint8_t ext; /* 0x1E */ - uint8_t checksum; /* 0x1F */ + u8 blockid; /* 0x0 */ + u8 flags; /* 0x1 */ + u16 nandpagesize; /* 0x2-0x3 */ + u32 blocksize; /* 0x4-0x7 */ + u8 version; /* 0x8 */ + u8 headersz_msb; /* 0x9 */ + u16 headersz_lsb; /* 0xA-0xB */ + u32 srcaddr; /* 0xC-0xF */ + u32 destaddr; /* 0x10-0x13 */ + u32 execaddr; /* 0x14-0x17 */ + u8 options; /* 0x18 */ + u8 nandblocksize; /* 0x19 */ + u8 nandbadblklocation; /* 0x1A */ + u8 reserved4; /* 0x1B */ + u16 reserved5; /* 0x1C-0x1D */ + u8 ext; /* 0x1E */ + u8 checksum; /* 0x1F */ } __packed;
Use the preferred if (IS_ENABLED(X)) instead of #ifdef X where possible.
There are still places where this is not possible or is more complicated to convert in this file. Leave those be for now.
Signed-off-by: Marek Behún marek.behun@nic.cz Reviewed-by: Stefan Roese sr@denx.de --- arch/arm/mach-mvebu/spl.c | 23 ++++++++--------------- 1 file changed, 8 insertions(+), 15 deletions(-)
diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index 103049b49b89..5006f9e80bb0 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -149,26 +149,24 @@ int spl_parse_board_header(struct spl_image_info *spl_image, return -EINVAL; }
-#ifdef CONFIG_SPL_SPI_FLASH_SUPPORT - if (bootdev->boot_device == BOOT_DEVICE_SPI && + if (IS_ENABLED(CONFIG_SPL_SPI_FLASH_SUPPORT) && + bootdev->boot_device == BOOT_DEVICE_SPI && mhdr->blockid != IBR_HDR_SPI_ID) { printf("ERROR: Wrong blockid (0x%x) in SPI kwbimage\n", mhdr->blockid); return -EINVAL; } -#endif
-#ifdef CONFIG_SPL_SATA - if (bootdev->boot_device == BOOT_DEVICE_SATA && + if (IS_ENABLED(CONFIG_SPL_SATA) && + bootdev->boot_device == BOOT_DEVICE_SATA && mhdr->blockid != IBR_HDR_SATA_ID) { printf("ERROR: Wrong blockid (0x%x) in SATA kwbimage\n", mhdr->blockid); return -EINVAL; } -#endif
-#ifdef CONFIG_SPL_MMC - if ((bootdev->boot_device == BOOT_DEVICE_MMC1 || + if (IS_ENABLED(CONFIG_SPL_MMC) && + (bootdev->boot_device == BOOT_DEVICE_MMC1 || bootdev->boot_device == BOOT_DEVICE_MMC2 || bootdev->boot_device == BOOT_DEVICE_MMC2_2) && mhdr->blockid != IBR_HDR_SDIO_ID) { @@ -176,18 +174,16 @@ int spl_parse_board_header(struct spl_image_info *spl_image, mhdr->blockid); return -EINVAL; } -#endif
-#ifdef CONFIG_SPL_SATA /* * For SATA srcaddr is specified in number of sectors. * The main header is must be stored at sector number 1. * This expects that sector size is 512 bytes and recalculates * data offset to bytes relative to the main header. */ - if (mhdr->blockid == IBR_HDR_SATA_ID) { + if (IS_ENABLED(CONFIG_SPL_SATA) && mhdr->blockid == IBR_HDR_SATA_ID) { if (spl_image->offset < 1) { printf("ERROR: Wrong srcaddr (0x%08x) in SATA kwbimage\n", spl_image->offset); @@ -196,17 +192,14 @@ int spl_parse_board_header(struct spl_image_info *spl_image, spl_image->offset -= 1; spl_image->offset *= 512; } -#endif
-#ifdef CONFIG_SPL_MMC /* * For SDIO (eMMC) srcaddr is specified in number of sectors. * This expects that sector size is 512 bytes and recalculates * data offset to bytes. */ - if (mhdr->blockid == IBR_HDR_SDIO_ID) + if (IS_ENABLED(CONFIG_SPL_MMC) && mhdr->blockid == IBR_HDR_SDIO_ID) spl_image->offset *= 512; -#endif
if (spl_image->offset % 4 != 0) { printf("ERROR: Wrong srcaddr (0x%08x) in kwbimage\n",
Fix 100 column exceeds in arch/arm/mach-mvebu/spl.c.
Signed-off-by: Marek Behún marek.behun@nic.cz Reviewed-by: Stefan Roese sr@denx.de --- arch/arm/mach-mvebu/spl.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-mvebu/spl.c b/arch/arm/mach-mvebu/spl.c index 5006f9e80bb0..273ecb8bd6cf 100644 --- a/arch/arm/mach-mvebu/spl.c +++ b/arch/arm/mach-mvebu/spl.c @@ -46,7 +46,8 @@ #if defined(CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR) && CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR != 0 #error CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR must be set to 0 #endif -#if defined(CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET) && CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET != 0 +#if defined(CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET) && \ + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET != 0 #error CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_DATA_PART_OFFSET must be set to 0 #endif #endif @@ -57,7 +58,8 @@ * set to 1. Otherwise U-Boot SPL would not be able to load U-Boot proper. */ #ifdef CONFIG_SPL_SATA -#if !defined(CONFIG_SPL_SATA_RAW_U_BOOT_USE_SECTOR) || !defined(CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR) || CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR != 1 +#if !defined(CONFIG_SPL_SATA_RAW_U_BOOT_USE_SECTOR) || \ + !defined(CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR) || CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR != 1 #error CONFIG_SPL_SATA_RAW_U_BOOT_SECTOR must be set to 1 #endif #endif
On 1/14/22 14:31, Pali Rohár wrote:
Hello Stefan,
Changes since v3:
Changes since v2:
- added R-B tags
Changes since v1:
Applied to u-boot-marvell/master
Thanks, Stefan
Viele Grüße, Stefan Roese
Pali Rohár
Stefan Roese
