[U-Boot] [PATCH v4] ARM64: zynqmp: Add support for standard distro boot commands
Nand and QSPI are not defined now but this will be extended. Based on selected bootmode boot_targets are rewritten. Patch also contains detection if variables are saved. If yes don't rewrite boot_targets variable.
Also move variable setup to the end of file because SCSI needs to be defined before others macros are using it.
Changes in v4: - Give one more byte for space in malloc buffer
Changes in v3: - Fix buffer overflow reported by Alexander - Remove also unused variables from board files
Changes in v2: - Append default boot_targets to the list
Patch depends on "env: Setup GD_FLG_ENV_DEFAULT flag when default environment are used"
--- board/xilinx/zynqmp/zynqmp.c | 34 +++++++++++--- include/configs/xilinx_zynqmp.h | 59 ++++++++++++++++++------ include/configs/xilinx_zynqmp_ep.h | 7 --- include/configs/xilinx_zynqmp_zc1751_xm015_dc1.h | 7 --- include/configs/xilinx_zynqmp_zc1751_xm016_dc2.h | 7 --- include/configs/xilinx_zynqmp_zc1751_xm018_dc4.h | 7 --- include/configs/xilinx_zynqmp_zc1751_xm019_dc5.h | 7 --- include/configs/xilinx_zynqmp_zcu102.h | 7 --- 8 files changed, 71 insertions(+), 64 deletions(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index 4623cd49e9c7..f15dc5d71522 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -9,6 +9,7 @@ #include <sata.h> #include <ahci.h> #include <scsi.h> +#include <malloc.h> #include <asm/arch/clk.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> @@ -214,6 +215,13 @@ int board_late_init(void) { u32 reg = 0; u8 bootmode; + const char *mode; + char *new_targets; + + if (!(gd->flags & GD_FLG_ENV_DEFAULT)) { + debug("Saved variables - Skipping\n"); + return 0; + }
reg = readl(&crlapb_base->boot_mode); bootmode = reg & BOOT_MODES_MASK; @@ -222,37 +230,49 @@ int board_late_init(void) switch (bootmode) { case JTAG_MODE: puts("JTAG_MODE\n"); - setenv("modeboot", "jtagboot"); + mode = "pxe dhcp"; break; case QSPI_MODE_24BIT: case QSPI_MODE_32BIT: - setenv("modeboot", "qspiboot"); + mode = "qspi0"; puts("QSPI_MODE\n"); break; case EMMC_MODE: puts("EMMC_MODE\n"); - setenv("modeboot", "sdboot"); + mode = "mmc0"; break; case SD_MODE: puts("SD_MODE\n"); - setenv("modeboot", "sdboot"); + mode = "mmc0"; break; case SD_MODE1: puts("SD_MODE1\n"); #if defined(CONFIG_ZYNQ_SDHCI0) && defined(CONFIG_ZYNQ_SDHCI1) - setenv("sdbootdev", "1"); + mode = "mmc1"; +#else + mode = "mmc0"; #endif - setenv("modeboot", "sdboot"); break; case NAND_MODE: puts("NAND_MODE\n"); - setenv("modeboot", "nandboot"); + mode = "nand0"; break; default: + mode = ""; printf("Invalid Boot Mode:0x%x\n", bootmode); break; }
+ /* + * One terminating char + one byte for space between mode + * and default boot_targets + */ + new_targets = calloc(1, strlen(mode) + + strlen(getenv("boot_targets")) + 2); + + sprintf(new_targets, "%s %s", mode, getenv("boot_targets")); + setenv("boot_targets", new_targets); + return 0; }
diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index ac3de0ac811e..fc2e1f72d0ce 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -146,21 +146,6 @@ # define DFU_ALT_INFO #endif
-/* Initial environment variables */ -#ifndef CONFIG_EXTRA_ENV_SETTINGS -#define CONFIG_EXTRA_ENV_SETTINGS \ - "kernel_addr=0x80000\0" \ - "fdt_addr=0x7000000\0" \ - "fdt_high=0x10000000\0" \ - CONFIG_KERNEL_FDT_OFST_SIZE \ - "sdbootdev=0\0"\ - "sdboot=mmc dev $sdbootdev && mmcinfo && load mmc $sdbootdev:$partid $fdt_addr system.dtb && " \ - "load mmc $sdbootdev:$partid $kernel_addr Image && " \ - "booti $kernel_addr - $fdt_addr\0" \ - DFU_ALT_INFO -#endif - -#define CONFIG_BOOTCOMMAND "run $modeboot" #define CONFIG_BOOTDELAY 3
#define CONFIG_BOARD_LATE_INIT @@ -230,6 +215,50 @@ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_CLOCKS
+#define ENV_MEM_LAYOUT_SETTINGS \ + "fdt_high=10000000\0" \ + "initrd_high=10000000\0" \ + "fdt_addr_r=0x40000000\0" \ + "pxefile_addr_r=0x10000000\0" \ + "kernel_addr_r=0x18000000\0" \ + "scriptaddr=0x02000000\0" \ + "ramdisk_addr_r=0x02100000\0" \ + +#if defined(CONFIG_ZYNQ_SDHCI) +# define BOOT_TARGET_DEVICES_MMC(func) func(MMC, mmc, 0) func(MMC, mmc, 1) +#else +# define BOOT_TARGET_DEVICES_MMC(func) +#endif + +#if defined(CONFIG_SATA_CEVA) +# define BOOT_TARGET_DEVICES_SCSI(func) func(SCSI, scsi, 0) +#else +# define BOOT_TARGET_DEVICES_SCSI(func) +#endif + +#if defined(CONFIG_ZYNQMP_USB) +# define BOOT_TARGET_DEVICES_USB(func) func(USB, usb, 0) func(USB, usb, 1) +#else +# define BOOT_TARGET_DEVICES_USB(func) +#endif + +#define BOOT_TARGET_DEVICES(func) \ + BOOT_TARGET_DEVICES_MMC(func) \ + BOOT_TARGET_DEVICES_USB(func) \ + BOOT_TARGET_DEVICES_SCSI(func) \ + func(PXE, pxe, na) \ + func(DHCP, dhcp, na) + +#include <config_distro_bootcmd.h> + +/* Initial environment variables */ +#ifndef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + ENV_MEM_LAYOUT_SETTINGS \ + BOOTENV \ + DFU_ALT_INFO +#endif + #define CONFIG_SPL_TEXT_BASE 0xfffc0000 #define CONFIG_SPL_MAX_SIZE 0x20000
diff --git a/include/configs/xilinx_zynqmp_ep.h b/include/configs/xilinx_zynqmp_ep.h index 95063557137b..c5bd5da43c5e 100644 --- a/include/configs/xilinx_zynqmp_ep.h +++ b/include/configs/xilinx_zynqmp_ep.h @@ -22,13 +22,6 @@
#define COUNTER_FREQUENCY 4000000
-#define CONFIG_KERNEL_FDT_OFST_SIZE \ - "kernel_offset=0x400000\0" \ - "fdt_offset=0x2400000\0" \ - "kernel_size=0x2000000\0" \ - "fdt_size=0x80000\0" \ - "board=ep108\0" - #include <configs/xilinx_zynqmp.h>
#endif /* __CONFIG_ZYNQMP_EP_H */ diff --git a/include/configs/xilinx_zynqmp_zc1751_xm015_dc1.h b/include/configs/xilinx_zynqmp_zc1751_xm015_dc1.h index 3c0ba883dbba..c9f443207d90 100644 --- a/include/configs/xilinx_zynqmp_zc1751_xm015_dc1.h +++ b/include/configs/xilinx_zynqmp_zc1751_xm015_dc1.h @@ -17,13 +17,6 @@
#define CONFIG_IDENT_STRING " Xilinx ZynqMP ZC1751 xm015 dc1"
-#define CONFIG_KERNEL_FDT_OFST_SIZE \ - "kernel_offset=0x400000\0" \ - "fdt_offset=0x2400000\0" \ - "kernel_size=0x2000000\0" \ - "fdt_size=0x80000\0" \ - "board=zc1751-dc1\0" - #include <configs/xilinx_zynqmp.h>
#endif /* __CONFIG_ZYNQMP_ZC1751_XM015_DC1_H */ diff --git a/include/configs/xilinx_zynqmp_zc1751_xm016_dc2.h b/include/configs/xilinx_zynqmp_zc1751_xm016_dc2.h index 83ea624c51c4..526d0bbe5852 100644 --- a/include/configs/xilinx_zynqmp_zc1751_xm016_dc2.h +++ b/include/configs/xilinx_zynqmp_zc1751_xm016_dc2.h @@ -14,13 +14,6 @@
#define CONFIG_IDENT_STRING " Xilinx ZynqMP ZC1751 xm016 dc2"
-#define CONFIG_KERNEL_FDT_OFST_SIZE \ - "kernel_offset=0x400000\0" \ - "fdt_offset=0x2400000\0" \ - "kernel_size=0x2000000\0" \ - "fdt_size=0x80000\0" \ - "board=zc1751-dc2\0" - #include <configs/xilinx_zynqmp.h>
#endif /* __CONFIG_ZYNQMP_ZC1751_XM016_DC2_H */ diff --git a/include/configs/xilinx_zynqmp_zc1751_xm018_dc4.h b/include/configs/xilinx_zynqmp_zc1751_xm018_dc4.h index fd2ec6a77516..65277a64c3c4 100644 --- a/include/configs/xilinx_zynqmp_zc1751_xm018_dc4.h +++ b/include/configs/xilinx_zynqmp_zc1751_xm018_dc4.h @@ -12,13 +12,6 @@
#define CONFIG_IDENT_STRING " Xilinx ZynqMP ZC1751 xm018 dc4"
-#define CONFIG_KERNEL_FDT_OFST_SIZE \ - "kernel_offset=0x400000\0" \ - "fdt_offset=0x2400000\0" \ - "kernel_size=0x2000000\0" \ - "fdt_size=0x80000\0" \ - "board=zc1751-dc4\0" - #include <configs/xilinx_zynqmp.h>
#endif /* __CONFIG_ZYNQMP_ZC1751_XM018_DC4_H */ diff --git a/include/configs/xilinx_zynqmp_zc1751_xm019_dc5.h b/include/configs/xilinx_zynqmp_zc1751_xm019_dc5.h index 4f8f5c10536d..76350d957950 100644 --- a/include/configs/xilinx_zynqmp_zc1751_xm019_dc5.h +++ b/include/configs/xilinx_zynqmp_zc1751_xm019_dc5.h @@ -15,13 +15,6 @@
#define CONFIG_IDENT_STRING " Xilinx ZynqMP ZC1751 xm019 dc5"
-#define CONFIG_KERNEL_FDT_OFST_SIZE \ - "kernel_offset=0x400000\0" \ - "fdt_offset=0x2400000\0" \ - "kernel_size=0x2000000\0" \ - "fdt_size=0x80000\0" \ - "board=zc1751-dc5\0" - #include <configs/xilinx_zynqmp.h>
#endif /* __CONFIG_ZYNQMP_ZC1751_XM019_DC5_H */ diff --git a/include/configs/xilinx_zynqmp_zcu102.h b/include/configs/xilinx_zynqmp_zcu102.h index 09c4a51a2ec0..7ceab3230b88 100644 --- a/include/configs/xilinx_zynqmp_zcu102.h +++ b/include/configs/xilinx_zynqmp_zcu102.h @@ -53,13 +53,6 @@ #define CONFIG_ZYNQ_GEM_EEPROM_ADDR 0x54 #define CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET 0x20
-#define CONFIG_KERNEL_FDT_OFST_SIZE \ - "kernel_offset=0x180000\0" \ - "fdt_offset=0x100000\0" \ - "kernel_size=0x1e00000\0" \ - "fdt_size=0x80000\0" \ - "board=zcu102\0" - #include <configs/xilinx_zynqmp.h>
#endif /* __CONFIG_ZYNQMP_ZCU102_H */
Reviewed-by: Alexander Graf agraf@suse.de
Alex
Alexander Graf
Michal Simek
