[PATCH] arm: mvebu: Add default SPL_SIZE_LIMIT for 32-bit SoCs
32-bit Marvell Armada BootROMs limit maximal size of SPL image to 192 kB. So define 192 kB (= 0x30000) limit as default value for SPL_SIZE_LIMIT.
Signed-off-by: Pali Rohár pali@kernel.org --- common/spl/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 70d97815f0a1..29e2f92f9b03 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -40,6 +40,7 @@ config SPL_SIZE_LIMIT hex "Maximum size of SPL image" default 0x11000 if ARCH_MX6 && !MX6_OCRAM_256KB default 0x31000 if ARCH_MX6 && MX6_OCRAM_256KB + default 0x30000 if ARCH_MVEBU && ARMADA_32BIT default 0x0 help Specifies the maximum length of the U-Boot SPL image.
Reviewed-by: Marek Behún kabel@kernel.org
Applied to u-boot-marvell/next
Thanks, Stefan
Thanks, Stefan
- default 0x30000 if ARCH_MVEBU && ARMADA_32BIT default 0x0 help Specifies the maximum length of the U-Boot SPL image.
Viele Grüße, Stefan Roese
Marek Behún
Pali Rohár
Stefan Roese
