[U-Boot] [PATCH 1/9] Define UART4 and UART5 base addresses
Signed-off-by: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx5/imx-regs.h | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 4fa6658..07296b5 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -93,6 +93,7 @@ #define GPIO5_BASE_ADDR (AIPS1_BASE_ADDR + 0x000DC000) #define GPIO6_BASE_ADDR (AIPS1_BASE_ADDR + 0x000E0000) #define GPIO7_BASE_ADDR (AIPS1_BASE_ADDR + 0x000E4000) +#define UART4_BASE_ADDR (AIPS1_BASE_ADDR + 0x000F0000) #endif /* * AIPS 2 @@ -133,6 +134,10 @@ #define VPU_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F4000) #define SAHARA_BASE_ADDR (AIPS2_BASE_ADDR + 0x000F8000)
+#if defined(CONFIG_MX53) +#define UART5_BASE_ADDR (AIPS2_BASE_ADDR + 0x00090000) +#endif + /* * WEIM CSnGCR1 */
Signed-off-by: Stefano Babic sbabic@denx.de CC: Fabio Estevam fabio.estevam@freescale.com --- drivers/net/fec_mxc.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 1fdd071..201e5d2 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -419,8 +419,13 @@ static int fec_open(struct eth_device *edev) while (readw(&fec->eth->miigsk_enr) & MIIGSK_ENR_READY) udelay(2);
+#if !defined(CONFIG_MII) /* configure gasket for RMII, 50 MHz, no loopback, and no echo */ writew(MIIGSK_CFGR_IF_MODE_RMII, &fec->eth->miigsk_cfgr); +#else + /* configure gasket for MII, no loopback, and no echo */ + writew(MIIGSK_CFGR_IF_MODE_MII, &fec->eth->miigsk_cfgr); +#endif
/* re-enable the gasket */ writew(MIIGSK_ENR_EN, &fec->eth->miigsk_enr);
- /* configure gasket for MII, no loopback, and no echo */
- writew(MIIGSK_CFGR_IF_MODE_MII, &fec->eth->miigsk_cfgr);
I have this patch on my list of pending patches.
What's the status of this?
Best regards
Dirk
Hi Dirk,
This patch must be reworked. See also the discussion about Timo's patch on http://patchwork.ozlabs.org/patch/153695/
There is some confusion about how to set the interface type. At the beginning, CONFIG_MII or CONFIG_RMII was used, but after the introduction of the MX28, CONFIG_FEC_XCV_TYPE is used. This should be unified, and I tend to use CONFIG_FEC_XCV_TYPE for all i.MX
Best regards, Stefano Babic
Signed-off-by: Stefano Babic sbabic@denx.de CC: Fabio Estevam fabio.estevam@freescale.com --- drivers/net/fec_mxc.c | 4 +++- 1 files changed, 3 insertions(+), 1 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 201e5d2..a45ac3f 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -175,9 +175,10 @@ int fec_phy_write(struct mii_dev *bus, int phyAddr, int dev_addr, int regAddr, #ifndef CONFIG_PHYLIB static int miiphy_restart_aneg(struct eth_device *dev) { + int ret = 0; +#if !defined(CONFIG_FEC_MXC_NO_ANEG) struct fec_priv *fec = (struct fec_priv *)dev->priv; struct ethernet_regs *eth = fec->bus->priv; - int ret = 0;
/* * Wake up from sleep if necessary @@ -201,6 +202,7 @@ static int miiphy_restart_aneg(struct eth_device *dev) if (fec->mii_postcall) ret = fec->mii_postcall(fec->phy_id);
+#endif return ret; }
Add base address and MXC_SATA_CLK to return the clock used for the SATA controller.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Fabio Estevam fabio.estevam@freescale.com CC: Dirk Behme dirk.behme@de.bosch.com --- arch/arm/cpu/armv7/mx5/clock.c | 2 ++ arch/arm/include/asm/arch-mx5/clock.h | 1 + arch/arm/include/asm/arch-mx5/imx-regs.h | 1 + 3 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx5/clock.c b/arch/arm/cpu/armv7/mx5/clock.c index e92f106..8f8d01c 100644 --- a/arch/arm/cpu/armv7/mx5/clock.c +++ b/arch/arm/cpu/armv7/mx5/clock.c @@ -380,6 +380,8 @@ unsigned int mxc_get_clock(enum mxc_clock clk) case MXC_FEC_CLK: return decode_pll(mxc_plls[PLL1_CLOCK], CONFIG_SYS_MX5_HCLK); + case MXC_SATA_CLK: + return get_ahb_clk(); default: break; } diff --git a/arch/arm/include/asm/arch-mx5/clock.h b/arch/arm/include/asm/arch-mx5/clock.h index ea972a3..f9f82f3 100644 --- a/arch/arm/include/asm/arch-mx5/clock.h +++ b/arch/arm/include/asm/arch-mx5/clock.h @@ -32,6 +32,7 @@ enum mxc_clock { MXC_UART_CLK, MXC_CSPI_CLK, MXC_FEC_CLK, + MXC_SATA_CLK, };
unsigned int imx_decode_pll(unsigned int pll, unsigned int f_ref); diff --git a/arch/arm/include/asm/arch-mx5/imx-regs.h b/arch/arm/include/asm/arch-mx5/imx-regs.h index 07296b5..a4245a3 100644 --- a/arch/arm/include/asm/arch-mx5/imx-regs.h +++ b/arch/arm/include/asm/arch-mx5/imx-regs.h @@ -43,6 +43,7 @@ #define NFC_BASE_ADDR_AXI 0xF7FF0000 #define IRAM_BASE_ADDR 0xF8000000 #define CS1_BASE_ADDR 0xF4000000 +#define SATA_BASE_ADDR 0x10000000 #else #error "CPU_TYPE not defined" #endif
sata functions are called even if previous functions failed because return value is not checked.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Dirk Behme dirk.behme@de.bosch.com CC: Fabio Estevam fabio.estevam@freescale.com --- common/cmd_sata.c | 9 ++++++--- 1 files changed, 6 insertions(+), 3 deletions(-)
diff --git a/common/cmd_sata.c b/common/cmd_sata.c index f62c0cb..dfa5300 100644 --- a/common/cmd_sata.c +++ b/common/cmd_sata.c @@ -48,9 +48,12 @@ int __sata_initialize(void) sata_dev_desc[i].block_write = sata_write;
rc = init_sata(i); - rc = scan_sata(i); - if ((sata_dev_desc[i].lba > 0) && (sata_dev_desc[i].blksz > 0)) - init_part(&sata_dev_desc[i]); + if (!rc) { + rc = scan_sata(i); + if (!rc && (sata_dev_desc[i].lba > 0) && + (sata_dev_desc[i].blksz > 0)) + init_part(&sata_dev_desc[i]); + } } sata_curr_device = 0; return rc;
The MX53 SATA interface can use an internal clock (USB PHY1) instead of an external clock. This is an undocumented feature, but used on most Freescale's evaluation boards, such as MX53-loco.
As stated by Freescale's support:
Fuses (but not pins) may be used to configure SATA clocks. Particularly the i.MX53 Fuse_Map contains the next information about configuring SATA clocks : SATA_ALT_REF_CLK[1:0] (offset 0x180C)
'00' - 100MHz (External) '01' - 50MHz (External) '10' - 120MHz, internal (USB PHY) '11' - Reserved
Signed-off-by: Stefano Babic sbabic@denx.de CC: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/armv7/mx5/clock.c | 24 ++++++++++++++++++++++++ arch/arm/include/asm/arch-mx5/clock.h | 1 + 2 files changed, 25 insertions(+), 0 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx5/clock.c b/arch/arm/cpu/armv7/mx5/clock.c index 8f8d01c..d769a4d 100644 --- a/arch/arm/cpu/armv7/mx5/clock.c +++ b/arch/arm/cpu/armv7/mx5/clock.c @@ -399,6 +399,30 @@ u32 imx_get_fecclk(void) return mxc_get_clock(MXC_IPG_CLK); }
+#ifdef CONFIG_MX53 +/* + * The clock for the external interface can be set to use internal clock + * if fuse bank 4, row 3, bit 2 is set. + * This is an undocumented feature and it was confirmed by Freescale's support: + * Fuses (but not pins) may be used to configure SATA clocks. + * Particularly the i.MX53 Fuse_Map contains the next information + * about configuring SATA clocks : SATA_ALT_REF_CLK[1:0] (offset 0x180C) + * '00' - 100MHz (External) + * '01' - 50MHz (External) + * '10' - 120MHz, internal (USB PHY) + * '11' - Reserved +*/ +void mxc_set_sata_internal_clock(void) +{ + u32 *tmp_base = + (u32 *)(IIM_BASE_ADDR + 0x180c); + + set_usb_phy1_clk(); + + writel((readl(tmp_base) & (~0x7)) | 0x4, tmp_base); +} +#endif + /* * Dump some core clockes. */ diff --git a/arch/arm/include/asm/arch-mx5/clock.h b/arch/arm/include/asm/arch-mx5/clock.h index f9f82f3..e822809 100644 --- a/arch/arm/include/asm/arch-mx5/clock.h +++ b/arch/arm/include/asm/arch-mx5/clock.h @@ -45,5 +45,6 @@ void set_usb_phy2_clk(void); void enable_usb_phy2_clk(unsigned char enable); void set_usboh3_clk(void); void enable_usboh3_clk(unsigned char enable); +void mxc_set_sata_internal_clock(void);
#endif /* __ASM_ARCH_CLOCK_H */
This driver is part of Freescale's LTIB for MX5 / MX6.
Signed-off-by: Stefano Babic sbabic@denx.de Signed-off-by: Terry Lv r65388@freescale.com CC: Fabio Estevam fabio.estevam@freescale.com CC: Dirk Behme dirk.behme@de.bosch.com --- drivers/block/Makefile | 1 + drivers/block/dwc_ahsata.c | 969 ++++++++++++++++++++++++++++++++++++++++++++ drivers/block/dwc_ahsata.h | 335 +++++++++++++++ include/ahci.h | 5 +- 4 files changed, 1308 insertions(+), 2 deletions(-) create mode 100644 drivers/block/dwc_ahsata.c create mode 100644 drivers/block/dwc_ahsata.h
diff --git a/drivers/block/Makefile b/drivers/block/Makefile index 98560ef..b9c2047 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -27,6 +27,7 @@ LIB := $(obj)libblock.o
COBJS-$(CONFIG_SCSI_AHCI) += ahci.o COBJS-$(CONFIG_ATA_PIIX) += ata_piix.o +COBJS-$(CONFIG_DWC_AHSATA) += dwc_ahsata.o COBJS-$(CONFIG_FSL_SATA) += fsl_sata.o COBJS-$(CONFIG_IDE_FTIDE020) += ftide020.o COBJS-$(CONFIG_LIBATA) += libata.o diff --git a/drivers/block/dwc_ahsata.c b/drivers/block/dwc_ahsata.c new file mode 100644 index 0000000..2703d3d --- /dev/null +++ b/drivers/block/dwc_ahsata.c @@ -0,0 +1,969 @@ +/* + * Copyright (C) 2010-2011 Freescale Semiconductor, Inc. + * Terry Lv r65388@freescale.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + * + */ + +#include <libata.h> +#include <ahci.h> +#include <fis.h> + +#include <common.h> +#include <malloc.h> +#include <linux/ctype.h> +#include <asm/errno.h> +#include <asm/io.h> +#include <linux/bitops.h> +#include <asm/arch/clock.h> +#include "dwc_ahsata.h" + +struct sata_port_regs { + u32 clb; + u32 clbu; + u32 fb; + u32 fbu; + u32 is; + u32 ie; + u32 cmd; + u32 res1[1]; + u32 tfd; + u32 sig; + u32 ssts; + u32 sctl; + u32 serr; + u32 sact; + u32 ci; + u32 sntf; + u32 res2[1]; + u32 dmacr; + u32 res3[1]; + u32 phycr; + u32 physr; +}; + +struct sata_host_regs { + u32 cap; + u32 ghc; + u32 is; + u32 pi; + u32 vs; + u32 ccc_ctl; + u32 ccc_ports; + u32 res1[2]; + u32 cap2; + u32 res2[30]; + u32 bistafr; + u32 bistcr; + u32 bistfctr; + u32 bistsr; + u32 bistdecr; + u32 res3[2]; + u32 oobr; + u32 res4[8]; + u32 timer1ms; + u32 res5[1]; + u32 gparam1r; + u32 gparam2r; + u32 pparamr; + u32 testr; + u32 versionr; + u32 idr; +}; + +#define MAX_DATA_BYTES_PER_SG (4 * 1024 * 1024) +#define MAX_BYTES_PER_TRANS (AHCI_MAX_SG * MAX_DATA_BYTES_PER_SG) + +#define writel_with_flush(a, b) do { writel(a, b); readl(b); } while (0) + +static int is_ready; + +static inline u32 ahci_port_base(u32 base, u32 port) +{ + return base + 0x100 + (port * 0x80); +} + +static int waiting_for_cmd_completed(u8 *offset, + int timeout_msec, + u32 sign) +{ + int i; + u32 status; + + for (i = 0; + ((status = readl(offset)) & sign) && i < timeout_msec; + ++i) + mdelay(1); + + return (i < timeout_msec) ? 0 : -1; +} + +static int ahci_setup_oobr(struct ahci_probe_ent *probe_ent, + int clk) +{ + struct sata_host_regs *host_mmio = + (struct sata_host_regs *)probe_ent->mmio_base; + + writel(SATA_HOST_OOBR_WE, &(host_mmio->oobr)); + writel(0x02060b14, &(host_mmio->oobr)); + + return 0; +} + +static int ahci_host_init(struct ahci_probe_ent *probe_ent) +{ + u32 tmp, cap_save, num_ports; + int i, j, timeout = 1000; + struct sata_port_regs *port_mmio = NULL; + struct sata_host_regs *host_mmio = + (struct sata_host_regs *)probe_ent->mmio_base; + int clk = mxc_get_clock(MXC_SATA_CLK); + + cap_save = readl(&(host_mmio->cap)); + cap_save |= SATA_HOST_CAP_SSS; + + /* global controller reset */ + tmp = readl(&(host_mmio->ghc)); + if ((tmp & SATA_HOST_GHC_HR) == 0) + writel_with_flush(tmp | SATA_HOST_GHC_HR, &(host_mmio->ghc)); + + while ((readl(&(host_mmio->ghc)) & SATA_HOST_GHC_HR) + && --timeout) + ; + + if (timeout <= 0) { + debug("controller reset failed (0x%x)\n", tmp); + return -1; + } + + /* Set timer 1ms */ + writel(clk / 1000, &(host_mmio->timer1ms)); + + ahci_setup_oobr(probe_ent, 0); + + writel_with_flush(SATA_HOST_GHC_AE, &(host_mmio->ghc)); + writel(cap_save, &(host_mmio->cap)); + num_ports = (cap_save & SATA_HOST_CAP_NP_MASK) + 1; + writel_with_flush((1 << num_ports) - 1, + &(host_mmio->pi)); + + /* + * Determine which Ports are implemented by the DWC_ahsata, + * by reading the PI register. This bit map value aids the + * software to determine how many Ports are available and + * which Port registers need to be initialized. + */ + probe_ent->cap = readl(&(host_mmio->cap)); + probe_ent->port_map = readl(&(host_mmio->pi)); + + /* Determine how many command slots the HBA supports */ + probe_ent->n_ports = + (probe_ent->cap & SATA_HOST_CAP_NP_MASK) + 1; + + debug("cap 0x%x port_map 0x%x n_ports %d\n", + probe_ent->cap, probe_ent->port_map, probe_ent->n_ports); + + for (i = 0; i < probe_ent->n_ports; i++) { + probe_ent->port[i].port_mmio = + ahci_port_base((u32)host_mmio, i); + port_mmio = + (struct sata_port_regs *)probe_ent->port[i].port_mmio; + + /* Ensure that the DWC_ahsata is in idle state */ + tmp = readl(&(port_mmio->cmd)); + + /* + * When P#CMD.ST, P#CMD.CR, P#CMD.FRE and P#CMD.FR + * are all cleared, the Port is in an idle state. + */ + if (tmp & (SATA_PORT_CMD_CR | SATA_PORT_CMD_FR | + SATA_PORT_CMD_FRE | SATA_PORT_CMD_ST)) { + + /* + * System software places a Port into the idle state by + * clearing P#CMD.ST and waiting for P#CMD.CR to return + * 0 when read. + */ + tmp &= ~SATA_PORT_CMD_ST; + writel_with_flush(tmp, &(port_mmio->cmd)); + + /* + * spec says 500 msecs for each bit, so + * this is slightly incorrect. + */ + mdelay(500); + + timeout = 1000; + while ((readl(&(port_mmio->cmd)) & SATA_PORT_CMD_CR) + && --timeout) + ; + + if (timeout <= 0) { + debug("port reset failed (0x%x)\n", tmp); + return -1; + } + } + + /* Spin-up device */ + tmp = readl(&(port_mmio->cmd)); + writel((tmp | SATA_PORT_CMD_SUD), &(port_mmio->cmd)); + + /* Wait for spin-up to finish */ + timeout = 1000; + while (!(readl(&(port_mmio->cmd)) | SATA_PORT_CMD_SUD) + && --timeout) + ; + if (timeout <= 0) { + debug("Spin-Up can't finish!\n"); + return -1; + } + + for (j = 0; j < 100; ++j) { + mdelay(10); + tmp = readl(&(port_mmio->ssts)); + if (((tmp & SATA_PORT_SSTS_DET_MASK) == 0x3) || + ((tmp & SATA_PORT_SSTS_DET_MASK) == 0x1)) + break; + } + + /* Wait for COMINIT bit 26 (DIAG_X) in SERR */ + timeout = 1000; + while (!(readl(&(port_mmio->serr)) | SATA_PORT_SERR_DIAG_X) + && --timeout) + ; + if (timeout <= 0) { + debug("Can't find DIAG_X set!\n"); + return -1; + } + + /* + * For each implemented Port, clear the P#SERR + * register, by writing ones to each implemented\ + * bit location. + */ + tmp = readl(&(port_mmio->serr)); + debug("P#SERR 0x%x\n", + tmp); + writel(tmp, &(port_mmio->serr)); + + /* Ack any pending irq events for this port */ + tmp = readl(&(host_mmio->is)); + debug("IS 0x%x\n", tmp); + if (tmp) + writel(tmp, &(host_mmio->is)); + + writel(1 << i, &(host_mmio->is)); + + /* set irq mask (enables interrupts) */ + writel(DEF_PORT_IRQ, &(port_mmio->ie)); + + /* register linkup ports */ + tmp = readl(&(port_mmio->ssts)); + debug("Port %d status: 0x%x\n", i, tmp); + if ((tmp & SATA_PORT_SSTS_DET_MASK) == 0x03) + probe_ent->link_port_map |= (0x01 << i); + } + + tmp = readl(&(host_mmio->ghc)); + debug("GHC 0x%x\n", tmp); + writel(tmp | SATA_HOST_GHC_IE, &(host_mmio->ghc)); + tmp = readl(&(host_mmio->ghc)); + debug("GHC 0x%x\n", tmp); + + return 0; +} + +static void ahci_print_info(struct ahci_probe_ent *probe_ent) +{ + struct sata_host_regs *host_mmio = + (struct sata_host_regs *)probe_ent->mmio_base; + u32 vers, cap, impl, speed; + const char *speed_s; + const char *scc_s; + + vers = readl(&(host_mmio->vs)); + cap = probe_ent->cap; + impl = probe_ent->port_map; + + speed = (cap & SATA_HOST_CAP_ISS_MASK) + >> SATA_HOST_CAP_ISS_OFFSET; + if (speed == 1) + speed_s = "1.5"; + else if (speed == 2) + speed_s = "3"; + else + speed_s = "?"; + + scc_s = "SATA"; + + printf("AHCI %02x%02x.%02x%02x " + "%u slots %u ports %s Gbps 0x%x impl %s mode\n", + (vers >> 24) & 0xff, + (vers >> 16) & 0xff, + (vers >> 8) & 0xff, + vers & 0xff, + ((cap >> 8) & 0x1f) + 1, + (cap & 0x1f) + 1, + speed_s, + impl, + scc_s); + + printf("flags: " + "%s%s%s%s%s%s" + "%s%s%s%s%s%s%s\n", + cap & (1 << 31) ? "64bit " : "", + cap & (1 << 30) ? "ncq " : "", + cap & (1 << 28) ? "ilck " : "", + cap & (1 << 27) ? "stag " : "", + cap & (1 << 26) ? "pm " : "", + cap & (1 << 25) ? "led " : "", + cap & (1 << 24) ? "clo " : "", + cap & (1 << 19) ? "nz " : "", + cap & (1 << 18) ? "only " : "", + cap & (1 << 17) ? "pmp " : "", + cap & (1 << 15) ? "pio " : "", + cap & (1 << 14) ? "slum " : "", + cap & (1 << 13) ? "part " : ""); +} + +static int ahci_init_one(int pdev) +{ + int rc; + struct ahci_probe_ent *probe_ent = NULL; + + probe_ent = malloc(sizeof(struct ahci_probe_ent)); + memset(probe_ent, 0, sizeof(struct ahci_probe_ent)); + probe_ent->dev = pdev; + + probe_ent->host_flags = ATA_FLAG_SATA + | ATA_FLAG_NO_LEGACY + | ATA_FLAG_MMIO + | ATA_FLAG_PIO_DMA + | ATA_FLAG_NO_ATAPI; + + probe_ent->mmio_base = CONFIG_DWC_AHSATA_BASE_ADDR; + + /* initialize adapter */ + rc = ahci_host_init(probe_ent); + if (rc) + goto err_out; + + ahci_print_info(probe_ent); + + /* Save the private struct to block device struct */ + sata_dev_desc[pdev].priv = (void *)probe_ent; + + return 0; + +err_out: + return rc; +} + +static int ahci_fill_sg(struct ahci_probe_ent *probe_ent, + u8 port, unsigned char *buf, int buf_len) +{ + struct ahci_ioports *pp = &(probe_ent->port[port]); + struct ahci_sg *ahci_sg = pp->cmd_tbl_sg; + u32 sg_count, max_bytes; + int i; + + max_bytes = MAX_DATA_BYTES_PER_SG; + sg_count = ((buf_len - 1) / max_bytes) + 1; + if (sg_count > AHCI_MAX_SG) { + printf("Error:Too much sg!\n"); + return -1; + } + + for (i = 0; i < sg_count; i++) { + ahci_sg->addr = + cpu_to_le32((u32)buf + i * max_bytes); + ahci_sg->addr_hi = 0; + ahci_sg->flags_size = cpu_to_le32(0x3fffff & + (buf_len < max_bytes + ? (buf_len - 1) + : (max_bytes - 1))); + ahci_sg++; + buf_len -= max_bytes; + } + + return sg_count; +} + +static void ahci_fill_cmd_slot(struct ahci_ioports *pp, u32 cmd_slot, u32 opts) +{ + struct ahci_cmd_hdr *cmd_hdr = (struct ahci_cmd_hdr *)(pp->cmd_slot + + AHCI_CMD_SLOT_SZ * cmd_slot); + + memset(cmd_hdr, 0, AHCI_CMD_SLOT_SZ); + cmd_hdr->opts = cpu_to_le32(opts); + cmd_hdr->status = 0; + cmd_hdr->tbl_addr = cpu_to_le32(pp->cmd_tbl & 0xffffffff); + cmd_hdr->tbl_addr_hi = 0; +} + +#define AHCI_GET_CMD_SLOT(c) ((c) ? ffs(c) : 0) + +static int ahci_exec_ata_cmd(struct ahci_probe_ent *probe_ent, + u8 port, struct sata_fis_h2d *cfis, + u8 *buf, u32 buf_len, s32 is_write) +{ + struct ahci_ioports *pp = &(probe_ent->port[port]); + struct sata_port_regs *port_mmio = + (struct sata_port_regs *)pp->port_mmio; + u32 opts; + int sg_count = 0, cmd_slot = 0; + + cmd_slot = AHCI_GET_CMD_SLOT(readl(&(port_mmio->ci))); + if (32 == cmd_slot) { + printf("Can't find empty command slot!\n"); + return 0; + } + + /* Check xfer length */ + if (buf_len > MAX_BYTES_PER_TRANS) { + printf("Max transfer length is %dB\n\r", + MAX_BYTES_PER_TRANS); + return 0; + } + + memcpy((u8 *)(pp->cmd_tbl), cfis, sizeof(struct sata_fis_h2d)); + if (buf && buf_len) + sg_count = ahci_fill_sg(probe_ent, port, buf, buf_len); + opts = (sizeof(struct sata_fis_h2d) >> 2) | (sg_count << 16); + if (is_write) + opts |= 0x40; + ahci_fill_cmd_slot(pp, cmd_slot, opts); + + writel_with_flush(1 << cmd_slot, &(port_mmio->ci)); + + if (waiting_for_cmd_completed((u8 *)&(port_mmio->ci), + 10000, 0x1 << cmd_slot)) { + printf("timeout exit!\n"); + return -1; + } + debug("ahci_exec_ata_cmd: %d byte transferred.\n", + pp->cmd_slot->status); + + return buf_len; +} + +static void ahci_set_feature(u8 dev, u8 port) +{ + struct ahci_probe_ent *probe_ent = + (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d, *cfis = &h2d; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 1 << 7; + cfis->command = ATA_CMD_SET_FEATURES; + cfis->features = SETFEATURES_XFER; + cfis->sector_count = ffs(probe_ent->udma_mask + 1) + 0x3e; + + ahci_exec_ata_cmd(probe_ent, port, cfis, NULL, 0, READ_CMD); +} + +static int ahci_port_start(struct ahci_probe_ent *probe_ent, + u8 port) +{ + struct ahci_ioports *pp = &(probe_ent->port[port]); + struct sata_port_regs *port_mmio = + (struct sata_port_regs *)pp->port_mmio; + u32 port_status; + u32 mem; + int timeout = 10000000; + + debug("Enter start port: %d\n", port); + port_status = readl(&(port_mmio->ssts)); + debug("Port %d status: %x\n", port, port_status); + if ((port_status & 0xf) != 0x03) { + printf("No Link on this port!\n"); + return -1; + } + + mem = (u32)malloc(AHCI_PORT_PRIV_DMA_SZ + 1024); + if (!mem) { + free(pp); + printf("No mem for table!\n"); + return -ENOMEM; + } + + mem = (mem + 0x400) & (~0x3ff); /* Aligned to 1024-bytes */ + memset((u8 *)mem, 0, AHCI_PORT_PRIV_DMA_SZ); + + /* + * First item in chunk of DMA memory: 32-slot command table, + * 32 bytes each in size + */ + pp->cmd_slot = (struct ahci_cmd_hdr *)mem; + debug("cmd_slot = 0x%x\n", (unsigned int) pp->cmd_slot); + mem += (AHCI_CMD_SLOT_SZ * DWC_AHSATA_MAX_CMD_SLOTS); + + /* + * Second item: Received-FIS area, 256-Byte aligned + */ + pp->rx_fis = mem; + mem += AHCI_RX_FIS_SZ; + + /* + * Third item: data area for storing a single command + * and its scatter-gather table + */ + pp->cmd_tbl = mem; + debug("cmd_tbl_dma = 0x%x\n", pp->cmd_tbl); + + mem += AHCI_CMD_TBL_HDR; + + writel_with_flush(0x00004444, &(port_mmio->dmacr)); + pp->cmd_tbl_sg = (struct ahci_sg *)mem; + writel_with_flush((u32)pp->cmd_slot, &(port_mmio->clb)); + writel_with_flush(pp->rx_fis, &(port_mmio->fb)); + + /* Enable FRE */ + writel_with_flush((SATA_PORT_CMD_FRE | readl(&(port_mmio->cmd))), + &(port_mmio->cmd)); + + /* Wait device ready */ + while ((readl(&(port_mmio->tfd)) & (SATA_PORT_TFD_STS_ERR | + SATA_PORT_TFD_STS_DRQ | SATA_PORT_TFD_STS_BSY)) + && --timeout) + ; + if (timeout <= 0) { + debug("Device not ready for BSY, DRQ and" + "ERR in TFD!\n"); + return -1; + } + + writel_with_flush(PORT_CMD_ICC_ACTIVE | PORT_CMD_FIS_RX | + PORT_CMD_POWER_ON | PORT_CMD_SPIN_UP | + PORT_CMD_START, &(port_mmio->cmd)); + + debug("Exit start port %d\n", port); + + return 0; +} + +int init_sata(int dev) +{ + int i; + u32 linkmap; + struct ahci_probe_ent *probe_ent = NULL; + + if (dev < 0 || dev > (CONFIG_SYS_SATA_MAX_DEVICE - 1)) { + printf("The sata index %d is out of ranges\n\r", dev); + return -1; + } + + ahci_init_one(dev); + + probe_ent = (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + linkmap = probe_ent->link_port_map; + + if (0 == linkmap) { + printf("No port device detected!\n"); + return 1; + } + + for (i = 0; i < probe_ent->n_ports; i++) { + if ((linkmap >> i) && ((linkmap >> i) & 0x01)) { + if (ahci_port_start(probe_ent, (u8)i)) { + printf("Can not start port %d\n", i); + return 1; + } + probe_ent->hard_port_no = i; + break; + } + } + + return 0; +} + +static void dwc_ahsata_print_info(int dev) +{ + block_dev_desc_t *pdev = &(sata_dev_desc[dev]); + + printf("SATA Device Info:\n\r"); +#ifdef CONFIG_SYS_64BIT_LBA + printf("S/N: %s\n\rProduct model number: %s\n\r" + "Firmware version: %s\n\rCapacity: %lld sectors\n\r", + pdev->product, pdev->vendor, pdev->revision, pdev->lba); +#else + printf("S/N: %s\n\rProduct model number: %s\n\r" + "Firmware version: %s\n\rCapacity: %ld sectors\n\r", + pdev->product, pdev->vendor, pdev->revision, pdev->lba); +#endif +} + +static void dwc_ahsata_identify(int dev, u16 *id) +{ + struct ahci_probe_ent *probe_ent = + (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d, *cfis = &h2d; + u8 port = probe_ent->hard_port_no; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_ID_ATA; + + ahci_exec_ata_cmd(probe_ent, port, cfis, + (u8 *)id, ATA_ID_WORDS * 2, READ_CMD); + ata_swap_buf_le16(id, ATA_ID_WORDS); +} + +static void dwc_ahsata_xfer_mode(int dev, u16 *id) +{ + struct ahci_probe_ent *probe_ent = + (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + + probe_ent->pio_mask = id[ATA_ID_PIO_MODES]; + probe_ent->udma_mask = id[ATA_ID_UDMA_MODES]; + debug("pio %04x, udma %04x\n\r", + probe_ent->pio_mask, probe_ent->udma_mask); +} + +static u32 dwc_ahsata_rw_cmd(int dev, u32 start, u32 blkcnt, + u8 *buffer, int is_write) +{ + struct ahci_probe_ent *probe_ent = + (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d, *cfis = &h2d; + u8 port = probe_ent->hard_port_no; + u32 block; + + block = start; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = (is_write) ? ATA_CMD_WRITE : ATA_CMD_READ; + cfis->device = ATA_LBA; + + cfis->device |= (block >> 24) & 0xf; + cfis->lba_high = (block >> 16) & 0xff; + cfis->lba_mid = (block >> 8) & 0xff; + cfis->lba_low = block & 0xff; + cfis->sector_count = (u8)(blkcnt & 0xff); + + if (ahci_exec_ata_cmd(probe_ent, port, cfis, + buffer, ATA_SECT_SIZE * blkcnt, is_write) > 0) + return blkcnt; + else + return 0; +} + +void dwc_ahsata_flush_cache(int dev) +{ + struct ahci_probe_ent *probe_ent = + (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d, *cfis = &h2d; + u8 port = probe_ent->hard_port_no; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_FLUSH; + + ahci_exec_ata_cmd(probe_ent, port, cfis, NULL, 0, 0); +} + +static u32 dwc_ahsata_rw_cmd_ext(int dev, u32 start, lbaint_t blkcnt, + u8 *buffer, int is_write) +{ + struct ahci_probe_ent *probe_ent = + (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d, *cfis = &h2d; + u8 port = probe_ent->hard_port_no; + u64 block; + + block = (u64)start; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + + cfis->command = (is_write) ? ATA_CMD_WRITE_EXT + : ATA_CMD_READ_EXT; + + cfis->lba_high_exp = (block >> 40) & 0xff; + cfis->lba_mid_exp = (block >> 32) & 0xff; + cfis->lba_low_exp = (block >> 24) & 0xff; + cfis->lba_high = (block >> 16) & 0xff; + cfis->lba_mid = (block >> 8) & 0xff; + cfis->lba_low = block & 0xff; + cfis->device = ATA_LBA; + cfis->sector_count_exp = (blkcnt >> 8) & 0xff; + cfis->sector_count = blkcnt & 0xff; + + if (ahci_exec_ata_cmd(probe_ent, port, cfis, buffer, + ATA_SECT_SIZE * blkcnt, is_write) > 0) + return blkcnt; + else + return 0; +} + +u32 dwc_ahsata_rw_ncq_cmd(int dev, u32 start, lbaint_t blkcnt, + u8 *buffer, int is_write) +{ + struct ahci_probe_ent *probe_ent = + (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d, *cfis = &h2d; + u8 port = probe_ent->hard_port_no; + u64 block; + + if (sata_dev_desc[dev].lba48 != 1) { + printf("execute FPDMA command on non-LBA48 hard disk\n\r"); + return -1; + } + + block = (u64)start; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + + cfis->command = (is_write) ? ATA_CMD_FPDMA_WRITE + : ATA_CMD_FPDMA_READ; + + cfis->lba_high_exp = (block >> 40) & 0xff; + cfis->lba_mid_exp = (block >> 32) & 0xff; + cfis->lba_low_exp = (block >> 24) & 0xff; + cfis->lba_high = (block >> 16) & 0xff; + cfis->lba_mid = (block >> 8) & 0xff; + cfis->lba_low = block & 0xff; + + cfis->device = ATA_LBA; + cfis->features_exp = (blkcnt >> 8) & 0xff; + cfis->features = blkcnt & 0xff; + + /* Use the latest queue */ + ahci_exec_ata_cmd(probe_ent, port, cfis, + buffer, ATA_SECT_SIZE * blkcnt, is_write); + + return blkcnt; +} + +void dwc_ahsata_flush_cache_ext(int dev) +{ + struct ahci_probe_ent *probe_ent = + (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + struct sata_fis_h2d h2d, *cfis = &h2d; + u8 port = probe_ent->hard_port_no; + + memset(cfis, 0, sizeof(struct sata_fis_h2d)); + + cfis->fis_type = SATA_FIS_TYPE_REGISTER_H2D; + cfis->pm_port_c = 0x80; /* is command */ + cfis->command = ATA_CMD_FLUSH_EXT; + + ahci_exec_ata_cmd(probe_ent, port, cfis, NULL, 0, 0); +} + +static void dwc_ahsata_init_wcache(int dev, u16 *id) +{ + struct ahci_probe_ent *probe_ent = + (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + + if (ata_id_has_wcache(id) && ata_id_wcache_enabled(id)) + probe_ent->flags |= SATA_FLAG_WCACHE; + if (ata_id_has_flush(id)) + probe_ent->flags |= SATA_FLAG_FLUSH; + if (ata_id_has_flush_ext(id)) + probe_ent->flags |= SATA_FLAG_FLUSH_EXT; +} + +u32 ata_low_level_rw_lba48(int dev, u32 blknr, lbaint_t blkcnt, + void *buffer, int is_write) +{ + u32 start, blks; + u8 *addr; + int max_blks; + + start = blknr; + blks = blkcnt; + addr = (u8 *)buffer; + + max_blks = ATA_MAX_SECTORS_LBA48; + + do { + if (blks > max_blks) { + if (max_blks != dwc_ahsata_rw_cmd_ext(dev, start, + max_blks, addr, is_write)) + return 0; + start += max_blks; + blks -= max_blks; + addr += ATA_SECT_SIZE * max_blks; + } else { + if (blks != dwc_ahsata_rw_cmd_ext(dev, start, + blks, addr, is_write)) + return 0; + start += blks; + blks = 0; + addr += ATA_SECT_SIZE * blks; + } + } while (blks != 0); + + return blkcnt; +} + +u32 ata_low_level_rw_lba28(int dev, u32 blknr, lbaint_t blkcnt, + void *buffer, int is_write) +{ + u32 start, blks; + u8 *addr; + int max_blks; + + start = blknr; + blks = blkcnt; + addr = (u8 *)buffer; + + max_blks = ATA_MAX_SECTORS; + do { + if (blks > max_blks) { + if (max_blks != dwc_ahsata_rw_cmd(dev, start, + max_blks, addr, is_write)) + return 0; + start += max_blks; + blks -= max_blks; + addr += ATA_SECT_SIZE * max_blks; + } else { + if (blks != dwc_ahsata_rw_cmd(dev, start, + blks, addr, is_write)) + return 0; + start += blks; + blks = 0; + addr += ATA_SECT_SIZE * blks; + } + } while (blks != 0); + + return blkcnt; +} + +/* + * SATA interface between low level driver and command layer + */ +ulong sata_read(int dev, unsigned long blknr, lbaint_t blkcnt, void *buffer) +{ + u32 rc; + + if (sata_dev_desc[dev].lba48) + rc = ata_low_level_rw_lba48(dev, blknr, blkcnt, + buffer, READ_CMD); + else + rc = ata_low_level_rw_lba28(dev, blknr, blkcnt, + buffer, READ_CMD); + return rc; +} + +ulong sata_write(int dev, unsigned long blknr, lbaint_t blkcnt, void *buffer) +{ + u32 rc; + struct ahci_probe_ent *probe_ent = + (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + u32 flags = probe_ent->flags; + + if (sata_dev_desc[dev].lba48) { + rc = ata_low_level_rw_lba48(dev, blknr, blkcnt, + buffer, WRITE_CMD); + if ((flags & SATA_FLAG_WCACHE) && + (flags & SATA_FLAG_FLUSH_EXT)) + dwc_ahsata_flush_cache_ext(dev); + } else { + rc = ata_low_level_rw_lba28(dev, blknr, blkcnt, + buffer, WRITE_CMD); + if ((flags & SATA_FLAG_WCACHE) && + (flags & SATA_FLAG_FLUSH)) + dwc_ahsata_flush_cache(dev); + } + return rc; +} + +int scan_sata(int dev) +{ + u8 serial[ATA_ID_SERNO_LEN + 1] = { 0 }; + u8 firmware[ATA_ID_FW_REV_LEN + 1] = { 0 }; + u8 product[ATA_ID_PROD_LEN + 1] = { 0 }; + u16 *id; + u64 n_sectors; + struct ahci_probe_ent *probe_ent = + (struct ahci_probe_ent *)sata_dev_desc[dev].priv; + u8 port = probe_ent->hard_port_no; + block_dev_desc_t *pdev = &(sata_dev_desc[dev]); + + id = (u16 *)malloc(ATA_ID_WORDS * 2); + if (!id) { + printf("id malloc failed\n\r"); + return -1; + } + + /* Identify device to get information */ + dwc_ahsata_identify(dev, id); + + /* Serial number */ + ata_id_c_string(id, serial, ATA_ID_SERNO, sizeof(serial)); + memcpy(pdev->product, serial, sizeof(serial)); + + /* Firmware version */ + ata_id_c_string(id, firmware, ATA_ID_FW_REV, sizeof(firmware)); + memcpy(pdev->revision, firmware, sizeof(firmware)); + + /* Product model */ + ata_id_c_string(id, product, ATA_ID_PROD, sizeof(product)); + memcpy(pdev->vendor, product, sizeof(product)); + + /* Totoal sectors */ + n_sectors = ata_id_n_sectors(id); + pdev->lba = (u32)n_sectors; + + pdev->type = DEV_TYPE_HARDDISK; + pdev->blksz = ATA_SECT_SIZE; + pdev->lun = 0 ; + + /* Check if support LBA48 */ + if (ata_id_has_lba48(id)) { + pdev->lba48 = 1; + debug("Device support LBA48\n\r"); + } + + /* Get the NCQ queue depth from device */ + probe_ent->flags &= (~SATA_FLAG_Q_DEP_MASK); + probe_ent->flags |= ata_id_queue_depth(id); + + /* Get the xfer mode from device */ + dwc_ahsata_xfer_mode(dev, id); + + /* Get the write cache status from device */ + dwc_ahsata_init_wcache(dev, id); + + /* Set the xfer mode to highest speed */ + ahci_set_feature(dev, port); + + free((void *)id); + + dwc_ahsata_print_info(dev); + + is_ready = 1; + + return 0; +} diff --git a/drivers/block/dwc_ahsata.h b/drivers/block/dwc_ahsata.h new file mode 100644 index 0000000..84860ea --- /dev/null +++ b/drivers/block/dwc_ahsata.h @@ -0,0 +1,335 @@ +/* + * Copyright (C) 2010 Freescale Semiconductor, Inc. + * Terry Lv r65388@freescale.com + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __FSL_SATA_H__ +#define __FSL_SATA_H__ + +#define DWC_AHSATA_MAX_CMD_SLOTS 32 + +/* Max host controller numbers */ +#define SATA_HC_MAX_NUM 4 +/* Max command queue depth per host controller */ +#define DWC_AHSATA_HC_MAX_CMD 32 +/* Max port number per host controller */ +#define SATA_HC_MAX_PORT 16 + +/* Generic Host Register */ + +/* HBA Capabilities Register */ +#define SATA_HOST_CAP_S64A 0x80000000 +#define SATA_HOST_CAP_SNCQ 0x40000000 +#define SATA_HOST_CAP_SSNTF 0x20000000 +#define SATA_HOST_CAP_SMPS 0x10000000 +#define SATA_HOST_CAP_SSS 0x08000000 +#define SATA_HOST_CAP_SALP 0x04000000 +#define SATA_HOST_CAP_SAL 0x02000000 +#define SATA_HOST_CAP_SCLO 0x01000000 +#define SATA_HOST_CAP_ISS_MASK 0x00f00000 +#define SATA_HOST_CAP_ISS_OFFSET 20 +#define SATA_HOST_CAP_SNZO 0x00080000 +#define SATA_HOST_CAP_SAM 0x00040000 +#define SATA_HOST_CAP_SPM 0x00020000 +#define SATA_HOST_CAP_PMD 0x00008000 +#define SATA_HOST_CAP_SSC 0x00004000 +#define SATA_HOST_CAP_PSC 0x00002000 +#define SATA_HOST_CAP_NCS 0x00001f00 +#define SATA_HOST_CAP_CCCS 0x00000080 +#define SATA_HOST_CAP_EMS 0x00000040 +#define SATA_HOST_CAP_SXS 0x00000020 +#define SATA_HOST_CAP_NP_MASK 0x0000001f + +/* Global HBA Control Register */ +#define SATA_HOST_GHC_AE 0x80000000 +#define SATA_HOST_GHC_IE 0x00000002 +#define SATA_HOST_GHC_HR 0x00000001 + +/* Interrupt Status Register */ + +/* Ports Implemented Register */ + +/* AHCI Version Register */ +#define SATA_HOST_VS_MJR_MASK 0xffff0000 +#define SATA_HOST_VS_MJR_OFFSET 16 +#define SATA_HOST_VS_MJR_MNR 0x0000ffff + +/* Command Completion Coalescing Control */ +#define SATA_HOST_CCC_CTL_TV_MASK 0xffff0000 +#define SATA_HOST_CCC_CTL_TV_OFFSET 16 +#define SATA_HOST_CCC_CTL_CC_MASK 0x0000ff00 +#define SATA_HOST_CCC_CTL_CC_OFFSET 8 +#define SATA_HOST_CCC_CTL_INT_MASK 0x000000f8 +#define SATA_HOST_CCC_CTL_INT_OFFSET 3 +#define SATA_HOST_CCC_CTL_EN 0x00000001 + +/* Command Completion Coalescing Ports */ + +/* HBA Capabilities Extended Register */ +#define SATA_HOST_CAP2_APST 0x00000004 + +/* BIST Activate FIS Register */ +#define SATA_HOST_BISTAFR_NCP_MASK 0x0000ff00 +#define SATA_HOST_BISTAFR_NCP_OFFSET 8 +#define SATA_HOST_BISTAFR_PD_MASK 0x000000ff +#define SATA_HOST_BISTAFR_PD_OFFSET 0 + +/* BIST Control Register */ +#define SATA_HOST_BISTCR_FERLB 0x00100000 +#define SATA_HOST_BISTCR_TXO 0x00040000 +#define SATA_HOST_BISTCR_CNTCLR 0x00020000 +#define SATA_HOST_BISTCR_NEALB 0x00010000 +#define SATA_HOST_BISTCR_LLC_MASK 0x00000700 +#define SATA_HOST_BISTCR_LLC_OFFSET 8 +#define SATA_HOST_BISTCR_ERREN 0x00000040 +#define SATA_HOST_BISTCR_FLIP 0x00000020 +#define SATA_HOST_BISTCR_PV 0x00000010 +#define SATA_HOST_BISTCR_PATTERN_MASK 0x0000000f +#define SATA_HOST_BISTCR_PATTERN_OFFSET 0 + +/* BIST FIS Count Register */ + +/* BIST Status Register */ +#define SATA_HOST_BISTSR_FRAMERR_MASK 0x0000ffff +#define SATA_HOST_BISTSR_FRAMERR_OFFSET 0 +#define SATA_HOST_BISTSR_BRSTERR_MASK 0x00ff0000 +#define SATA_HOST_BISTSR_BRSTERR_OFFSET 16 + +/* BIST DWORD Error Count Register */ + +/* OOB Register*/ +#define SATA_HOST_OOBR_WE 0x80000000 +#define SATA_HOST_OOBR_cwMin_MASK 0x7f000000 +#define SATA_HOST_OOBR_cwMAX_MASK 0x00ff0000 +#define SATA_HOST_OOBR_ciMin_MASK 0x0000ff00 +#define SATA_HOST_OOBR_ciMax_MASK 0x000000ff + +/* Timer 1-ms Register */ + +/* Global Parameter 1 Register */ +#define SATA_HOST_GPARAM1R_ALIGN_M 0x80000000 +#define SATA_HOST_GPARAM1R_RX_BUFFER 0x40000000 +#define SATA_HOST_GPARAM1R_PHY_DATA_MASK 0x30000000 +#define SATA_HOST_GPARAM1R_PHY_RST 0x08000000 +#define SATA_HOST_GPARAM1R_PHY_CTRL_MASK 0x07e00000 +#define SATA_HOST_GPARAM1R_PHY_STAT_MASK 0x001f8000 +#define SATA_HOST_GPARAM1R_LATCH_M 0x00004000 +#define SATA_HOST_GPARAM1R_BIST_M 0x00002000 +#define SATA_HOST_GPARAM1R_PHY_TYPE 0x00001000 +#define SATA_HOST_GPARAM1R_RETURN_ERR 0x00000400 +#define SATA_HOST_GPARAM1R_AHB_ENDIAN_MASK 0x00000300 +#define SATA_HOST_GPARAM1R_S_HADDR 0X00000080 +#define SATA_HOST_GPARAM1R_M_HADDR 0X00000040 + +/* Global Parameter 2 Register */ +#define SATA_HOST_GPARAM2R_DEV_CP 0x00004000 +#define SATA_HOST_GPARAM2R_DEV_MP 0x00002000 +#define SATA_HOST_GPARAM2R_DEV_ENCODE_M 0x00001000 +#define SATA_HOST_GPARAM2R_RXOOB_CLK_M 0x00000800 +#define SATA_HOST_GPARAM2R_RXOOB_M 0x00000400 +#define SATA_HOST_GPARAM2R_TX_OOB_M 0x00000200 +#define SATA_HOST_GPARAM2R_RXOOB_CLK_MASK 0x000001ff + +/* Port Parameter Register */ +#define SATA_HOST_PPARAMR_TX_MEM_M 0x00000200 +#define SATA_HOST_PPARAMR_TX_MEM_S 0x00000100 +#define SATA_HOST_PPARAMR_RX_MEM_M 0x00000080 +#define SATA_HOST_PPARAMR_RX_MEM_S 0x00000040 +#define SATA_HOST_PPARAMR_TXFIFO_DEPTH_MASK 0x00000038 +#define SATA_HOST_PPARAMR_RXFIFO_DEPTH_MASK 0x00000007 + +/* Test Register */ +#define SATA_HOST_TESTR_PSEL_MASK 0x00070000 +#define SATA_HOST_TESTR_TEST_IF 0x00000001 + +/* Port Register Descriptions */ +/* Port# Command List Base Address Register */ +#define SATA_PORT_CLB_CLB_MASK 0xfffffc00 + +/* Port# Command List Base Address Upper 32-Bits Register */ + +/* Port# FIS Base Address Register */ +#define SATA_PORT_FB_FB_MASK 0xfffffff0 + +/* Port# FIS Base Address Upper 32-Bits Register */ + +/* Port# Interrupt Status Register */ +#define SATA_PORT_IS_CPDS 0x80000000 +#define SATA_PORT_IS_TFES 0x40000000 +#define SATA_PORT_IS_HBFS 0x20000000 +#define SATA_PORT_IS_HBDS 0x10000000 +#define SATA_PORT_IS_IFS 0x08000000 +#define SATA_PORT_IS_INFS 0x04000000 +#define SATA_PORT_IS_OFS 0x01000000 +#define SATA_PORT_IS_IPMS 0x00800000 +#define SATA_PORT_IS_PRCS 0x00400000 +#define SATA_PORT_IS_DMPS 0x00000080 +#define SATA_PORT_IS_PCS 0x00000040 +#define SATA_PORT_IS_DPS 0x00000020 +#define SATA_PORT_IS_UFS 0x00000010 +#define SATA_PORT_IS_SDBS 0x00000008 +#define SATA_PORT_IS_DSS 0x00000004 +#define SATA_PORT_IS_PSS 0x00000002 +#define SATA_PORT_IS_DHRS 0x00000001 + +/* Port# Interrupt Enable Register */ +#define SATA_PORT_IE_CPDE 0x80000000 +#define SATA_PORT_IE_TFEE 0x40000000 +#define SATA_PORT_IE_HBFE 0x20000000 +#define SATA_PORT_IE_HBDE 0x10000000 +#define SATA_PORT_IE_IFE 0x08000000 +#define SATA_PORT_IE_INFE 0x04000000 +#define SATA_PORT_IE_OFE 0x01000000 +#define SATA_PORT_IE_IPME 0x00800000 +#define SATA_PORT_IE_PRCE 0x00400000 +#define SATA_PORT_IE_DMPE 0x00000080 +#define SATA_PORT_IE_PCE 0x00000040 +#define SATA_PORT_IE_DPE 0x00000020 +#define SATA_PORT_IE_UFE 0x00000010 +#define SATA_PORT_IE_SDBE 0x00000008 +#define SATA_PORT_IE_DSE 0x00000004 +#define SATA_PORT_IE_PSE 0x00000002 +#define SATA_PORT_IE_DHRE 0x00000001 + +/* Port# Command Register */ +#define SATA_PORT_CMD_ICC_MASK 0xf0000000 +#define SATA_PORT_CMD_ASP 0x08000000 +#define SATA_PORT_CMD_ALPE 0x04000000 +#define SATA_PORT_CMD_DLAE 0x02000000 +#define SATA_PORT_CMD_ATAPI 0x01000000 +#define SATA_PORT_CMD_APSTE 0x00800000 +#define SATA_PORT_CMD_ESP 0x00200000 +#define SATA_PORT_CMD_CPD 0x00100000 +#define SATA_PORT_CMD_MPSP 0x00080000 +#define SATA_PORT_CMD_HPCP 0x00040000 +#define SATA_PORT_CMD_PMA 0x00020000 +#define SATA_PORT_CMD_CPS 0x00010000 +#define SATA_PORT_CMD_CR 0x00008000 +#define SATA_PORT_CMD_FR 0x00004000 +#define SATA_PORT_CMD_MPSS 0x00002000 +#define SATA_PORT_CMD_CCS_MASK 0x00001f00 +#define SATA_PORT_CMD_FRE 0x00000010 +#define SATA_PORT_CMD_CLO 0x00000008 +#define SATA_PORT_CMD_POD 0x00000004 +#define SATA_PORT_CMD_SUD 0x00000002 +#define SATA_PORT_CMD_ST 0x00000001 + +/* Port# Task File Data Register */ +#define SATA_PORT_TFD_ERR_MASK 0x0000ff00 +#define SATA_PORT_TFD_STS_MASK 0x000000ff +#define SATA_PORT_TFD_STS_ERR 0x00000001 +#define SATA_PORT_TFD_STS_DRQ 0x00000008 +#define SATA_PORT_TFD_STS_BSY 0x00000080 + +/* Port# Signature Register */ + +/* Port# Serial ATA Status {SStatus} Register */ +#define SATA_PORT_SSTS_IPM_MASK 0x00000f00 +#define SATA_PORT_SSTS_SPD_MASK 0x000000f0 +#define SATA_PORT_SSTS_DET_MASK 0x0000000f + +/* Port# Serial ATA Control {SControl} Register */ +#define SATA_PORT_SCTL_IPM_MASK 0x00000f00 +#define SATA_PORT_SCTL_SPD_MASK 0x000000f0 +#define SATA_PORT_SCTL_DET_MASK 0x0000000f + +/* Port# Serial ATA Error {SError} Register */ +#define SATA_PORT_SERR_DIAG_X 0x04000000 +#define SATA_PORT_SERR_DIAG_F 0x02000000 +#define SATA_PORT_SERR_DIAG_T 0x01000000 +#define SATA_PORT_SERR_DIAG_S 0x00800000 +#define SATA_PORT_SERR_DIAG_H 0x00400000 +#define SATA_PORT_SERR_DIAG_C 0x00200000 +#define SATA_PORT_SERR_DIAG_D 0x00100000 +#define SATA_PORT_SERR_DIAG_B 0x00080000 +#define SATA_PORT_SERR_DIAG_W 0x00040000 +#define SATA_PORT_SERR_DIAG_I 0x00020000 +#define SATA_PORT_SERR_DIAG_N 0x00010000 +#define SATA_PORT_SERR_ERR_E 0x00000800 +#define SATA_PORT_SERR_ERR_P 0x00000400 +#define SATA_PORT_SERR_ERR_C 0x00000200 +#define SATA_PORT_SERR_ERR_T 0x00000100 +#define SATA_PORT_SERR_ERR_M 0x00000002 +#define SATA_PORT_SERR_ERR_I 0x00000001 + +/* Port# Serial ATA Active {SActive} Register */ + +/* Port# Command Issue Register */ + +/* Port# Serial ATA Notification Register */ + +/* Port# DMA Control Register */ +#define SATA_PORT_DMACR_RXABL_MASK 0x0000f000 +#define SATA_PORT_DMACR_TXABL_MASK 0x00000f00 +#define SATA_PORT_DMACR_RXTS_MASK 0x000000f0 +#define SATA_PORT_DMACR_TXTS_MASK 0x0000000f + +/* Port# PHY Control Register */ + +/* Port# PHY Status Register */ + +#define SATA_HC_CMD_HDR_ENTRY_SIZE sizeof(struct cmd_hdr_entry) + +/* DW0 +*/ +#define CMD_HDR_DI_CFL_MASK 0x0000001f +#define CMD_HDR_DI_CFL_OFFSET 0 +#define CMD_HDR_DI_A 0x00000020 +#define CMD_HDR_DI_W 0x00000040 +#define CMD_HDR_DI_P 0x00000080 +#define CMD_HDR_DI_R 0x00000100 +#define CMD_HDR_DI_B 0x00000200 +#define CMD_HDR_DI_C 0x00000400 +#define CMD_HDR_DI_PMP_MASK 0x0000f000 +#define CMD_HDR_DI_PMP_OFFSET 12 +#define CMD_HDR_DI_PRDTL 0xffff0000 +#define CMD_HDR_DI_PRDTL_OFFSET 16 + +/* prde_fis_len +*/ +#define CMD_HDR_PRD_ENTRY_SHIFT 16 +#define CMD_HDR_PRD_ENTRY_MASK 0x003f0000 +#define CMD_HDR_FIS_LEN_SHIFT 2 + +/* attribute +*/ +#define CMD_HDR_ATTR_RES 0x00000800 /* Reserved bit, should be 1 */ +#define CMD_HDR_ATTR_VBIST 0x00000400 /* Vendor BIST */ +/* Snoop enable for all descriptor */ +#define CMD_HDR_ATTR_SNOOP 0x00000200 +#define CMD_HDR_ATTR_FPDMA 0x00000100 /* FPDMA queued command */ +#define CMD_HDR_ATTR_RESET 0x00000080 /* Reset - a SRST or device reset */ +/* BIST - require the host to enter BIST mode */ +#define CMD_HDR_ATTR_BIST 0x00000040 +#define CMD_HDR_ATTR_ATAPI 0x00000020 /* ATAPI command */ +#define CMD_HDR_ATTR_TAG 0x0000001f /* TAG mask */ + +#define FLAGS_DMA 0x00000000 +#define FLAGS_FPDMA 0x00000001 + +#define SATA_FLAG_Q_DEP_MASK 0x0000000f +#define SATA_FLAG_WCACHE 0x00000100 +#define SATA_FLAG_FLUSH 0x00000200 +#define SATA_FLAG_FLUSH_EXT 0x00000400 + +#define READ_CMD 0 +#define WRITE_CMD 1 + +extern block_dev_desc_t sata_dev_desc[CONFIG_SYS_SATA_MAX_DEVICE]; + +#endif /* __FSL_SATA_H__ */ diff --git a/include/ahci.h b/include/ahci.h index 465ea7f..c4fb9e7 100644 --- a/include/ahci.h +++ b/include/ahci.h @@ -30,12 +30,13 @@ #define AHCI_PCI_BAR 0x24 #define AHCI_MAX_SG 56 /* hardware max is 64K */ #define AHCI_CMD_SLOT_SZ 32 +#define AHCI_MAX_CMD_SLOT 32 #define AHCI_RX_FIS_SZ 256 #define AHCI_CMD_TBL_HDR 0x80 #define AHCI_CMD_TBL_CDB 0x40 #define AHCI_CMD_TBL_SZ AHCI_CMD_TBL_HDR + (AHCI_MAX_SG * 16) -#define AHCI_PORT_PRIV_DMA_SZ AHCI_CMD_SLOT_SZ + AHCI_CMD_TBL_SZ \ - + AHCI_RX_FIS_SZ +#define AHCI_PORT_PRIV_DMA_SZ (AHCI_CMD_SLOT_SZ * AHCI_MAX_CMD_SLOT + \ + AHCI_CMD_TBL_SZ + AHCI_RX_FIS_SZ) #define AHCI_CMD_ATAPI (1 << 5) #define AHCI_CMD_WRITE (1 << 6) #define AHCI_CMD_PREFETCH (1 << 7)
The ESG ima3-mx53 board is based on the Freescale i.MX53 SOC. It boots from NOR (128 MB) and supports Ethernet (FEC), SATA.
Signed-off-by: Stefano Babic sbabic@denx.de --- board/esg/ima3-mx53/Makefile | 41 +++++ board/esg/ima3-mx53/ima3-mx53.c | 302 ++++++++++++++++++++++++++++++++++++++ board/esg/ima3-mx53/imximage.cfg | 108 ++++++++++++++ boards.cfg | 1 + include/configs/ima3-mx53.h | 269 +++++++++++++++++++++++++++++++++ 5 files changed, 721 insertions(+), 0 deletions(-) create mode 100644 board/esg/ima3-mx53/Makefile create mode 100644 board/esg/ima3-mx53/ima3-mx53.c create mode 100644 board/esg/ima3-mx53/imximage.cfg create mode 100644 include/configs/ima3-mx53.h
diff --git a/board/esg/ima3-mx53/Makefile b/board/esg/ima3-mx53/Makefile new file mode 100644 index 0000000..f3b13bc --- /dev/null +++ b/board/esg/ima3-mx53/Makefile @@ -0,0 +1,41 @@ +# +# Copyright (C) 2012, Stefano Babic sbabic@denx.de +# +# Based on ti/evm/Makefile +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS := ima3-mx53.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/esg/ima3-mx53/ima3-mx53.c b/board/esg/ima3-mx53/ima3-mx53.c new file mode 100644 index 0000000..9ecf31d --- /dev/null +++ b/board/esg/ima3-mx53/ima3-mx53.c @@ -0,0 +1,302 @@ +/* + * (C) Copyright 2012, Stefano Babic sbabic@denx.de + * + * (C) Copyright 2010 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ +#include <common.h> +#include <asm/io.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx5x_pins.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/clock.h> +#include <asm/arch/iomux.h> +#include <asm/errno.h> +#include <netdev.h> +#include <mmc.h> +#include <fsl_esdhc.h> +#include <asm/gpio.h> + +/* NOR flash configuration */ +#define IMA3_MX53_CS0GCR1 (CSEN | DSZ(2)) +#define IMA3_MX53_CS0GCR2 0 +#define IMA3_MX53_CS0RCR1 (RCSN(2) | OEN(1) | RWSC(15)) +#define IMA3_MX53_CS0RCR2 0 +#define IMA3_MX53_CS0WCR1 (WBED1 | WCSN(2) | WEN(1) | WWSC(15)) +#define IMA3_MX53_CS0WCR2 0 + +DECLARE_GLOBAL_DATA_PTR; + +static void weim_nor_settings(void) +{ + struct weim *weim_regs = (struct weim *)WEIM_BASE_ADDR; + + writel(IMA3_MX53_CS0GCR1, &weim_regs->cs0gcr1); + writel(IMA3_MX53_CS0GCR2, &weim_regs->cs0gcr2); + writel(IMA3_MX53_CS0RCR1, &weim_regs->cs0rcr1); + writel(IMA3_MX53_CS0RCR2, &weim_regs->cs0rcr2); + writel(IMA3_MX53_CS0WCR1, &weim_regs->cs0wcr1); + writel(IMA3_MX53_CS0WCR2, &weim_regs->cs0wcr2); + writel(0x0, &weim_regs->wcr); + + set_chipselect_size(CS0_128); +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((void *) CONFIG_SYS_SDRAM_BASE, + PHYS_SDRAM_1_SIZE); + return 0; +} + +static void setup_iomux_uart(void) +{ + /* UART4 RXD */ + mxc_request_iomux(MX53_PIN_CSI0_D13, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX53_PIN_CSI0_D13, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | + PAD_CTL_100K_PU | PAD_CTL_ODE_OPENDRAIN_ENABLE); + mxc_iomux_set_input(MX53_UART4_IPP_UART_RXD_MUX_SELECT_INPUT, 0x3); + + /* UART4 TXD */ + mxc_request_iomux(MX53_PIN_CSI0_D12, IOMUX_CONFIG_ALT2); + mxc_iomux_set_pad(MX53_PIN_CSI0_D12, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | + PAD_CTL_100K_PU | PAD_CTL_ODE_OPENDRAIN_ENABLE); +} + +static void setup_iomux_fec(void) +{ + /*FEC_MDIO*/ + mxc_request_iomux(MX53_PIN_FEC_MDIO, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_MDIO, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | PAD_CTL_22K_PU | + PAD_CTL_ODE_OPENDRAIN_ENABLE); + mxc_iomux_set_input(MX53_FEC_FEC_MDI_SELECT_INPUT, 0x1); + + /*FEC_MDC*/ + mxc_request_iomux(MX53_PIN_FEC_MDC, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_MDC, PAD_CTL_DRV_HIGH); + + /* FEC RXD3 */ + mxc_request_iomux(MX53_PIN_KEY_COL0, IOMUX_CONFIG_ALT6); + mxc_iomux_set_pad(MX53_PIN_KEY_COL0, PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE); + + /* FEC RXD2 */ + mxc_request_iomux(MX53_PIN_KEY_COL2, IOMUX_CONFIG_ALT6); + mxc_iomux_set_pad(MX53_PIN_KEY_COL2, PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE); + + /* FEC RXD1 */ + mxc_request_iomux(MX53_PIN_FEC_RXD1, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_RXD1, PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE); + + /* FEC RXD0 */ + mxc_request_iomux(MX53_PIN_FEC_RXD0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_RXD0, PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE); + + /* FEC TXD3 */ + mxc_request_iomux(MX53_PIN_GPIO_19, IOMUX_CONFIG_ALT6); + mxc_iomux_set_pad(MX53_PIN_GPIO_19, PAD_CTL_DRV_HIGH); + + /* FEC TXD2 */ + mxc_request_iomux(MX53_PIN_KEY_ROW2, IOMUX_CONFIG_ALT6); + mxc_iomux_set_pad(MX53_PIN_KEY_ROW2, PAD_CTL_DRV_HIGH); + + /* FEC TXD1 */ + mxc_request_iomux(MX53_PIN_FEC_TXD1, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_TXD1, PAD_CTL_DRV_HIGH); + + /* FEC TXD0 */ + mxc_request_iomux(MX53_PIN_FEC_TXD0, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_TXD0, PAD_CTL_DRV_HIGH); + + /* FEC TX_EN */ + mxc_request_iomux(MX53_PIN_FEC_TX_EN, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_TX_EN, PAD_CTL_DRV_HIGH); + + /* FEC TX_CLK */ + mxc_request_iomux(MX53_PIN_FEC_REF_CLK, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_REF_CLK, PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE); + + /* FEC RX_ER */ + mxc_request_iomux(MX53_PIN_FEC_RX_ER, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_RX_ER, PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE); + + /* FEC RX_DV */ + mxc_request_iomux(MX53_PIN_FEC_CRS_DV, IOMUX_CONFIG_ALT0); + mxc_iomux_set_pad(MX53_PIN_FEC_CRS_DV, PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE); + + /* FEC CRS */ + mxc_request_iomux(MX53_PIN_KEY_COL3, IOMUX_CONFIG_ALT6); + mxc_iomux_set_pad(MX53_PIN_KEY_COL3, PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE); + + /* FEC COL */ + mxc_request_iomux(MX53_PIN_KEY_ROW1, IOMUX_CONFIG_ALT6); + mxc_iomux_set_pad(MX53_PIN_KEY_ROW1, PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE); + mxc_iomux_set_input(MX53_FEC_FEC_COL_SELECT_INPUT, 0x0); + + /* FEC RX_CLK */ + mxc_request_iomux(MX53_PIN_KEY_COL1, IOMUX_CONFIG_ALT6); + mxc_iomux_set_pad(MX53_PIN_KEY_COL1, PAD_CTL_HYS_ENABLE | + PAD_CTL_PKE_ENABLE); + mxc_iomux_set_input(MX53_FEC_FEC_RX_CLK_SELECT_INPUT, 0x0); +} + +#ifdef CONFIG_FSL_ESDHC +struct fsl_esdhc_cfg esdhc_cfg = { MMC_SDHC1_BASE_ADDR, 1 }; + +int board_mmc_getcd(struct mmc *mmc) +{ + int ret; + + ret = !gpio_get_value(IOMUX_TO_GPIO(MX53_PIN_GPIO_1)); + + return ret; +} + +int board_mmc_init(bd_t *bis) +{ + mxc_request_iomux(MX53_PIN_SD1_CMD, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_CLK, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA0, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA1, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA2, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_SD1_DATA3, IOMUX_CONFIG_ALT0); + mxc_request_iomux(MX53_PIN_GPIO_1, IOMUX_CONFIG_ALT1); + mxc_iomux_set_pad(MX53_PIN_GPIO_1, + PAD_CTL_DRV_HIGH | PAD_CTL_HYS_ENABLE | + PAD_CTL_PUE_KEEPER | PAD_CTL_100K_PU | + PAD_CTL_ODE_OPENDRAIN_NONE | PAD_CTL_PKE_ENABLE); + gpio_direction_input(IOMUX_TO_GPIO(MX53_PIN_GPIO_1)); + + mxc_iomux_set_pad(MX53_PIN_SD1_CMD, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | PAD_CTL_100K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_CLK, + PAD_CTL_PUE_PULL | PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | + PAD_CTL_47K_PU | PAD_CTL_DRV_HIGH); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA0, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA1, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA2, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_pad(MX53_PIN_SD1_DATA3, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + + return fsl_esdhc_initialize(bis, &esdhc_cfg); +} +#endif + +static void setup_iomux_spi(void) +{ + /* SCLK */ + mxc_request_iomux(MX53_PIN_CSI0_D8, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX53_PIN_CSI0_D8, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_input(MX53_ECSPI2_IPP_CSPI_CLK_IN_SELECT_INPUT, 0x1); + /* MOSI */ + mxc_request_iomux(MX53_PIN_CSI0_D9, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX53_PIN_CSI0_D9, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_input(MX53_ECSPI2_IPP_IND_MOSI_SELECT_INPUT, 0x1); + /* MISO */ + mxc_request_iomux(MX53_PIN_CSI0_D10, IOMUX_CONFIG_ALT3); + mxc_iomux_set_pad(MX53_PIN_CSI0_D10, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + mxc_iomux_set_input(MX53_ECSPI2_IPP_IND_MISO_SELECT_INPUT, 0x1); + /* SSEL 0 */ + mxc_request_iomux(MX53_PIN_CSI0_D11, IOMUX_CONFIG_GPIO); + mxc_iomux_set_pad(MX53_PIN_CSI0_D11, + PAD_CTL_HYS_ENABLE | PAD_CTL_DRV_HIGH | PAD_CTL_PUE_PULL | + PAD_CTL_PKE_ENABLE | PAD_CTL_HYS_ENABLE | PAD_CTL_47K_PU); + gpio_direction_output(IOMUX_TO_GPIO(MX53_PIN_CSI0_D11), 1); +} + +int board_early_init_f(void) +{ + /* configure I/O pads */ + setup_iomux_uart(); + setup_iomux_fec(); + + weim_nor_settings(); + + /* configure spi */ + setup_iomux_spi(); + + return 0; +} + +int board_init(void) +{ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + mxc_set_sata_internal_clock(); + + return 0; +} + +#if defined(CONFIG_RESET_PHY_R) +#include <miiphy.h> + +void reset_phy(void) +{ + unsigned short reg; + + /* reset the phy */ + miiphy_reset("FEC", CONFIG_PHY_ADDR); + + /* set hard link to 100Mbit, full-duplex */ + miiphy_read("FEC", CONFIG_PHY_ADDR, MII_BMCR, ®); + reg &= ~BMCR_ANENABLE; + reg |= (BMCR_SPEED100 | BMCR_FULLDPLX); + miiphy_write("FEC", CONFIG_PHY_ADDR, MII_BMCR, reg); + + miiphy_read("FEC", CONFIG_PHY_ADDR, 0x16, ®); + reg |= (1 << 5); + miiphy_write("FEC", CONFIG_PHY_ADDR, 0x16, reg); +} +#endif + +int checkboard(void) +{ + puts("Board: IMA3_MX53\n"); + + return 0; +} diff --git a/board/esg/ima3-mx53/imximage.cfg b/board/esg/ima3-mx53/imximage.cfg new file mode 100644 index 0000000..fa6b42d --- /dev/null +++ b/board/esg/ima3-mx53/imximage.cfg @@ -0,0 +1,108 @@ +# +# (C) Copyright 2012 +# Stefano Babic DENX Software Engineering sbabic@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not write to the Free Software +# Foundation Inc. 51 Franklin Street Fifth Floor Boston, +# MA 02110-1301 USA +# +# Refer docs/README.imxmage for more details about how-to configure +# and create imximage boot image +# +# The syntax is taken as close as possible with the kwbimage + +# image version + +IMAGE_VERSION 2 + +# Boot Device : one of +# spi, sd (the board has no nand neither onenand) + +BOOT_FROM nor + +# Device Configuration Data (DCD) +# +# Each entry must have the format: +# Addr-type Address Value +# +# where: +# Addr-type register length (1,2 or 4 bytes) +# Address absolute address of the register +# value value to be stored in the register + +# IOMUX for RAM only +DATA 4 0x53fa8554 0x300020 +DATA 4 0x53fa8560 0x300020 +DATA 4 0x53fa8594 0x300020 +DATA 4 0x53fa8584 0x300020 +DATA 4 0x53fa8558 0x300040 +DATA 4 0x53fa8568 0x300040 +DATA 4 0x53fa8590 0x300040 +DATA 4 0x53fa857c 0x300040 +DATA 4 0x53fa8564 0x300040 +DATA 4 0x53fa8580 0x300040 +DATA 4 0x53fa8570 0x300220 +DATA 4 0x53fa8578 0x300220 +DATA 4 0x53fa872c 0x300000 +DATA 4 0x53fa8728 0x300000 +DATA 4 0x53fa871c 0x300000 +DATA 4 0x53fa8718 0x300000 +DATA 4 0x53fa8574 0x300020 +DATA 4 0x53fa8588 0x300020 +DATA 4 0x53fa855c 0x0 +DATA 4 0x53fa858c 0x0 +DATA 4 0x53fa856c 0x300040 +DATA 4 0x53fa86f0 0x300000 +DATA 4 0x53fa8720 0x300000 +DATA 4 0x53fa86fc 0x0 +DATA 4 0x53fa86f4 0x0 +DATA 4 0x53fa8714 0x0 +DATA 4 0x53fa8724 0x4000000 +# +# DDR RAM +DATA 4 0x63fd9088 0x40404040 +DATA 4 0x63fd9090 0x40404040 +DATA 4 0x63fd907C 0x01420143 +DATA 4 0x63fd9080 0x01450146 +DATA 4 0x63fd9018 0x00111740 +DATA 4 0x63fd9000 0x84190000 +# esdcfgX +DATA 4 0x63fd900C 0x9f5152e3 +DATA 4 0x63fd9010 0xb68e8a63 +DATA 4 0x63fd9014 0x01ff00db +# Read/Write command delay +DATA 4 0x63fd902c 0x000026d2 +# Out of reset delays +DATA 4 0x63fd9030 0x00ff0e21 +# ESDCTL ODT timing control +DATA 4 0x63fd9008 0x12273030 +# ESDCTL power down control +DATA 4 0x63fd9004 0x0002002d +# Set registers in DDR memory chips +DATA 4 0x63fd901c 0x00008032 +DATA 4 0x63fd901c 0x00008033 +DATA 4 0x63fd901c 0x00028031 +DATA 4 0x63fd901c 0x052080b0 +DATA 4 0x63fd901c 0x04008040 +# ESDCTL refresh control +DATA 4 0x63fd9020 0x00005800 +# PHY ZQ HW control +DATA 4 0x63fd9040 0x05380003 +# PHY ODT control +DATA 4 0x63fd9058 0x00022222 +# start DDR3 +DATA 4 0x63fd901c 0x00000000 diff --git a/boards.cfg b/boards.cfg index bf71a66..b9fc69a 100644 --- a/boards.cfg +++ b/boards.cfg @@ -197,6 +197,7 @@ mx53ard arm armv7 mx53ard freesca mx53evk arm armv7 mx53evk freescale mx5 mx53evk:IMX_CONFIG=board/freescale/mx53evk/imximage.cfg mx53loco arm armv7 mx53loco freescale mx5 mx53loco:IMX_CONFIG=board/freescale/mx53loco/imximage.cfg mx53smd arm armv7 mx53smd freescale mx5 mx53smd:IMX_CONFIG=board/freescale/mx53smd/imximage.cfg +ima3-mx53 arm armv7 ima3-mx53 esg mx5 ima3-mx53:IMX_CONFIG=board/esg/ima3-mx53/imximage.cfg vision2 arm armv7 vision2 ttcontrol mx5 vision2:IMX_CONFIG=board/ttcontrol/vision2/imximage_hynix.cfg mx6qarm2 arm armv7 mx6qarm2 freescale mx6 mx6qarm2:IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg mx6qsabrelite arm armv7 mx6qsabrelite freescale mx6 mx6qsabrelite:IMX_CONFIG=board/freescale/mx6qsabrelite/imximage.cfg diff --git a/include/configs/ima3-mx53.h b/include/configs/ima3-mx53.h new file mode 100644 index 0000000..ea48d64 --- /dev/null +++ b/include/configs/ima3-mx53.h @@ -0,0 +1,269 @@ +/* + * (C) Copyright 2012, Stefano Babic sbabic@denx.de + * + * Copyright (C) 2010 Freescale Semiconductor, Inc. + * + * Configuration settings for the MX53-EVK Freescale board. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc. + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* SOC type must be included before imx-regs.h */ +#define CONFIG_MX53 +#include <asm/arch/imx-regs.h> +#include <asm/arch/mx5x_pins.h> + +#define CONFIG_SYS_MX5_HCLK 24000000 +#define CONFIG_SYS_MX5_CLK32 32768 + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_INITRD_TAG + +#define CONFIG_OF_LIBFDT + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2 * 1024 * 1024) + +#define CONFIG_BOARD_EARLY_INIT_F + +/* Enable GPIOs */ +#define CONFIG_MXC_GPIO + +/* UART */ +#define CONFIG_MXC_UART +#define CONFIG_MXC_UART_BASE UART4_BASE_ADDR + +/* MMC */ +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR 0 +#define CONFIG_SYS_FSL_ESDHC_NUM 1 + +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_DOS_PARTITION + +/* Ethernet on FEC */ +#define CONFIG_NET_MULTI +#define CONFIG_MII +#define CONFIG_DISCOVER_PHY + +#define CONFIG_FEC_MXC +#define IMX_FEC_BASE FEC_BASE_ADDR +#define CONFIG_FEC_MXC_PHYADDR 0x01 +#define CONFIG_PHY_ADDR CONFIG_FEC_MXC_PHYADDR +#define CONFIG_RESET_PHY_R +#define CONFIG_FEC_MXC_NO_ANEG +#define CONFIG_PRIME "FEC0" + +/* SPI */ +#define CONFIG_HARD_SPI +#define CONFIG_MXC_SPI +#define CONFIG_DEFAULT_SPI_BUS 1 +#define CONFIG_DEFAULT_SPI_MODE SPI_MODE_0 + +/* SPI FLASH - not used for environment */ +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_STMICRO +#define CONFIG_SPI_FLASH_CS (IOMUX_TO_GPIO(MX53_PIN_CSI0_D11) \ + << 8) | 0 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 +#define CONFIG_SF_DEFAULT_SPEED 25000000 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_CONS_INDEX 1 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {9600, 19200, 38400, 57600, 115200} + +/* Command definition */ +#include <config_cmd_default.h> +#define CONFIG_CMD_PING +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MII +#define CONFIG_CMD_MMC +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_MTDPARTS +#define CONFIG_CMD_SPI +#define CONFIG_CMD_SF +#define CONFIG_CMD_GPIO + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_LOADADDR 0x70800000 /* loadaddr env var */ +#define CONFIG_SYS_TEXT_BASE 0xf0001400 /* uboot in nor flash */ + +#define CONFIG_ARP_TIMEOUT 200UL + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "IMA3 MX53 U-Boot > " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ + +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START 0x70000000 +#define CONFIG_SYS_MEMTEST_END 0x10000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_CMDLINE_EDITING + +/* Stack sizes */ +#define CONFIG_STACKSIZE (128 * 1024) /* regular stack */ + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM_1 CSD0_BASE_ADDR +#define PHYS_SDRAM_1_SIZE (1024 * 1024 * 1024) + +#define CONFIG_SYS_SDRAM_BASE (PHYS_SDRAM_1) +#define CONFIG_SYS_INIT_RAM_ADDR (IRAM_BASE_ADDR) +#define CONFIG_SYS_INIT_RAM_SIZE (IRAM_SIZE) + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define MTDIDS_DEFAULT "nor0=f0000000.flash" + +/* FLASH and environment organization */ + +#define CONFIG_SYS_FLASH_BASE 0xF0000000 +#define CONFIG_SYS_FLASH_CFI /* Flash is CFI conformant */ +#define CONFIG_FLASH_CFI_DRIVER /* Use the common driver */ +#define CONFIG_FLASH_CFI_MTD /* with MTD support */ +#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 1024 + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) + +#define CONFIG_ENV_SIZE (8 * 1024) +#define CONFIG_ENV_IS_IN_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + \ + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_SECT_SIZE 0x20000 +#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ + CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE + +/* + * Default environment and default scripts + * to update uboot and load kernel + */ + +#define HOSTNAME ima3-mx53 +#define xstr(s) str(s) +#define str(s) #s + +#define CONFIG_HOSTNAME ima3-mx53 +#define CONFIG_EXTRA_ENV_SETTINGS \ + "netdev=eth0\0" \ + "nfsargs=setenv bootargs root=/dev/nfs rw " \ + "nfsroot=${serverip}:${rootpath}\0" \ + "ramargs=setenv bootargs root=/dev/ram0 rw\0" \ + "addip_sta=setenv bootargs ${bootargs} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ + ":${hostname}:${netdev}:off panic=1\0" \ + "addip_dyn=setenv bootargs ${bootargs} ip=dhcp\0" \ + "addip=if test -n ${ipdyn};then run addip_dyn;" \ + "else run addip_sta;fi\0" \ + "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0" \ + "addtty=setenv bootargs ${bootargs}" \ + " console=${console},${baudrate}\0" \ + "addmisc=setenv bootargs ${bootargs} ${misc}\0" \ + "console=ttymxc3\0" \ + "loadaddr=70800000\0" \ + "kernel_addr_r=70800000\0" \ + "ramdisk_addr_r=71000000\0" \ + "hostname=" xstr(CONFIG_HOSTNAME) "\0" \ + "bootfile=" xstr(CONFIG_HOSTNAME) "/uImage\0" \ + "ramdisk_file=" xstr(CONFIG_HOSTNAME) "/uRamdisk\0" \ + "mmcargs=setenv bootargs root=${mmcroot} " \ + "rootfstype=${mmcrootfstype}\0" \ + "mmcroot=/dev/mmcblk0p3 rw\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs addip addtty addmtd addmisc mmcload;" \ + "bootm\0" \ + "mmcload=fatload mmc ${mmcdev}:${mmcpart} " \ + "${loadaddr} ${uimage}\0" \ + "mmcrootfstype=ext3 rootwait\0" \ + "flash_self=run ramargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr} ${ramdisk_addr}\0" \ + "flash_nfs=run nfsargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr}\0" \ + "net_nfs=tftp ${kernel_addr_r} ${bootfile}; " \ + "run nfsargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr_r}\0" \ + "net_self_load=tftp ${ramdisk_addr_r} ${ramdisk_file};" \ + "tftp ${kernel_addr_r} ${bootfile}\0" \ + "net_self=if run net_self_load;then " \ + "run ramargs addip addtty addmtd addmisc;" \ + "bootm ${kernel_addr_r} ${ramdisk_addr_r};" \ + "else echo Images not loades;fi\0" \ + "satargs=setenv bootargs root=/dev/sda1\0" \ + "satafile=boot/uImage\0" \ + "ssdboot=echo Booting from ssd ...; " \ + "run satargs addip addtty addmtd addmisc;" \ + "sata init;ext2load sata 0:1 ${kernel_addr_r} " \ + "${satafile};bootm\0" \ + "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.imx\0" \ + "uimage=uImage\0" \ + "load=tftp ${loadaddr} ${u-boot}\0" \ + "uboot_addr=0xf0001000\0" \ + "update=protect off 0xf0000000 +60000;" \ + "erase ${uboot_addr} +60000;" \ + "cp.b ${loadaddr} ${uboot_addr} ${filesize}\0" \ + "upd=if run load;then echo Updating u-boot;if run update;" \ + "then echo U-Boot updated;" \ + "else echo Error updating u-boot !;" \ + "echo Board without bootloader !!;" \ + "fi;" \ + "else echo U-Boot not downloaded..exiting;fi\0" \ + "bootcmd=run net_nfs\0" + + +#define CONFIG_CMD_SATA +#ifdef CONFIG_CMD_SATA + #define CONFIG_DWC_AHSATA + #define CONFIG_SYS_SATA_MAX_DEVICE 1 + #define CONFIG_DWC_AHSATA_PORT_ID 0 + #define CONFIG_DWC_AHSATA_BASE_ADDR SATA_BASE_ADDR + #define CONFIG_LBA48 + #define CONFIG_LIBATA +#endif + +#endif /* __CONFIG_H */
On 22.02.2012 11:24, Stefano Babic wrote: ...
Ah. I wonder why I was under the impression that I was the only guy fighting with the imximage NOR header pain, then ;)
Maybe the above comment should be updated for nor? ;)
+BOOT_FROM nor
I assume that you have tested this and it works with the imximage?
Best regards
Dirk
When something goes wrong, it does for everybody...
Yes, I'll do
+BOOT_FROM nor
I have not any problem with the current imximage, so I am quite confused. Agree that you are fixing a bug, but I have not understood why I have not seen any issue on my board, a MX53 using V2 image header.
My board boots flawlessly from the NOR interface. I will try to investigate why and, of course, I will be able to test your patch on my board.
Can you confirm that your board does not boot ? Or are there other symptoms ?
Best regards, Stefano Babic
+BOOT_FROM nor
Hmm, yes, this is quite confusing :(
Yes, removing the imximage fix stops the board from booting. Unfortunately it's hard to debug how the boot ROM deals with the header information. So either it works, or not, but there is little chance to debug :(
For testing, taking the SabreLite (mx6qsabrelite), switching it to NOR [1] and then compiling it without and with my imximage fix, results in the following difference in the header (disassembly of u-boot.imx):
- 20: 177ff800 + 20: 177fec00
At offset 0x20 in the header, this is the target address in the destination memory. Having a header with the size of 0x400 (like here) the destination address should be TEXT_BASE - 0x400 (header size) - 0x1000 (NOR offset), i.e. 0x17800000 - 0x1400. So my understanding is that 0x177fec00 is correct for NOR, while 0x177ff800 is valid for all FLASH_OFFSET_STANDARD devices.
Best regards
Dirk
[1]
board/freescale/mx6qsabrelite/imximage.cfg BOOT_FROM nor
Signed-off-by: Stefano Babic sbabic@denx.de CC: Jason Liu jason.hui@linaro.org --- board/freescale/mx53loco/mx53loco.c | 3 +++ include/configs/mx53loco.h | 11 +++++++++++ 2 files changed, 14 insertions(+), 0 deletions(-)
diff --git a/board/freescale/mx53loco/mx53loco.c b/board/freescale/mx53loco/mx53loco.c index d736141..7ea9f6e 100644 --- a/board/freescale/mx53loco/mx53loco.c +++ b/board/freescale/mx53loco/mx53loco.c @@ -27,6 +27,7 @@ #include <asm/arch/mx5x_pins.h> #include <asm/arch/sys_proto.h> #include <asm/arch/crm_regs.h> +#include <asm/arch/clock.h> #include <asm/arch/iomux.h> #include <asm/arch/clock.h> #include <asm/errno.h> @@ -302,6 +303,8 @@ int board_init(void) { gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
+ mxc_set_sata_internal_clock(); + return 0; }
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 34a4edd..af59307 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -56,6 +56,7 @@ #define CONFIG_CMD_MMC #define CONFIG_GENERIC_MMC #define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION
/* Eth Configs */ @@ -193,4 +194,14 @@
+#define CONFIG_CMD_SATA +#ifdef CONFIG_CMD_SATA + #define CONFIG_DWC_AHSATA + #define CONFIG_SYS_SATA_MAX_DEVICE 1 + #define CONFIG_DWC_AHSATA_PORT_ID 0 + #define CONFIG_DWC_AHSATA_BASE_ADDR SATA_BASE_ADDR + #define CONFIG_LBA48 + #define CONFIG_LIBATA +#endif + #endif /* __CONFIG_H */
- mxc_set_sata_internal_clock();
return 0; }
- #define CONFIG_DWC_AHSATA
- #define CONFIG_SYS_SATA_MAX_DEVICE 1
- #define CONFIG_DWC_AHSATA_PORT_ID 0
- #define CONFIG_DWC_AHSATA_BASE_ADDR SATA_BASE_ADDR
- #define CONFIG_LBA48
- #define CONFIG_LIBATA
1.7.5.4
Acked-by: Jason Liu jason.hui@linaro.org
Dirk Behme
Jason Hui
Stefano Babic
