[PATCH v2] mtd: spi-nor: Enable mt35xu512aba_fixups for all mt35xx flashes
Add SPI_NOR_OCTAL_DTR_READ flags to micron flashes mt35xu01g and mt35xu02g. Also move them under CONFIG_SPI_FLASH_MT35XU config, so that in driver mt35xu512aba_fixups will be applied.
Signed-off-by: Venkatesh Yadav Abbarapu venkatesh.abbarapu@amd.com --- Changes in v2: - Add the OCTAL_DTR_READ flags for mt35xu01g and mt35xu02g. - Removed the return after nor->fixups. --- drivers/mtd/spi/spi-nor-core.c | 5 ++++- drivers/mtd/spi/spi-nor-ids.c | 6 ++++-- 2 files changed, 8 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index ec841fb13bd..700593f7739 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -4404,7 +4404,10 @@ void spi_nor_set_fixups(struct spi_nor *nor) #endif
#ifdef CONFIG_SPI_FLASH_MT35XU - if (!strcmp(nor->info->name, "mt35xu512aba")) + if (!strcmp(nor->info->name, "mt35xu512aba") || + !strcmp(nor->info->name, "mt35xl512aba") || + !strcmp(nor->info->name, "mt35xu01g") || + !strcmp(nor->info->name, "mt35xu02g")) nor->fixups = &mt35xu512aba_fixups; #endif
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 91ae49c9484..9a69e210eb4 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -359,9 +359,11 @@ const struct flash_info spi_nor_ids[] = { { INFO("mt35xl512aba", 0x2c5a1a, 0, 128 * 1024, 512, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ) }, { INFO("mt35xu512aba", 0x2c5b1a, 0, 128 * 1024, 512, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ) }, { INFO("mt35xu01gaba", 0x2c5b1b, 0, 128 * 1024, 1024, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, + { INFO6("mt35xu01g", 0x2c5b1b, 0x104100, 128 * 1024, 1024, + USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ) }, + { INFO("mt35xu02g", 0x2c5b1c, 0, 128 * 1024, 2048, + USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES | SPI_NOR_OCTAL_DTR_READ) }, #endif /* CONFIG_SPI_FLASH_MT35XU */ - { INFO6("mt35xu01g", 0x2c5b1b, 0x104100, 128 * 1024, 1024, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, - { INFO("mt35xu02g", 0x2c5b1c, 0, 128 * 1024, 2048, USE_FSR | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, #endif #ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ /* Spansion/Cypress -- single (large) sector size only, at least
Why? What problem are you trying to solve? Should we have a fixes tag? Why didn't you split these 2 changes in 2 dedicated patches?
Please read the following before submitting v3: https://docs.u-boot.org/en/latest/develop/sending_patches.html https://www.kernel.org/doc/html/latest/process/submitting-patches.html#descr...
-----Original Message----- From: Tudor Ambarus tudor.ambarus@linaro.org Sent: Thursday, December 5, 2024 1:20 PM To: Abbarapu, Venkatesh venkatesh.abbarapu@amd.com; u-boot@lists.denx.de; j-humphreys@ti.com Cc: Simek, Michal michal.simek@amd.com; jagan@amarulasolutions.com; vigneshr@ti.com; u-kumar1@ti.com; trini@konsulko.com; seanga2@gmail.com; caleb.connolly@linaro.org; sjg@chromium.org; william.zhang@broadcom.com; stefan_b@posteo.net; quentin.schulz@cherry.de; Takahiro.Kuwano@infineon.com; p-mantena@ti.com; git (AMD-Xilinx) git@amd.com Subject: Re: [PATCH v2] mtd: spi-nor: Enable mt35xu512aba_fixups for all mt35xx flashes
These two flashes mt35xu01g and mt35xu02g support DTR, so updated the flag SPI_NOR_OCTAL_DTR_READ which in turn uses this spi_nor_micron_octal_dtr_enable. Adding the support, not fixing anything. Let me know if anything missing from my side.
Sure. Will split to two separate patches.
Thanks Venkatesh
Please read the following before submitting v3: https://docs.u-boot.org/en/latest/develop/sending_patches.html https://www.kernel.org/doc/html/latest/process/submitting-patches.html#descr... your-changes
Abbarapu, Venkatesh
Tudor Ambarus
