[U-Boot] [PATCH] ARM: cache_v7: use __weak
This is not only more readable but also prevents a warning about a missing prototype. The prototypes which are actually missing are added.
cc: Albert Aribaud albert.u.boot@aribaud.net Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl --- arch/arm/cpu/armv7/cache_v7.c | 45 +++++++------------------------------------ arch/arm/include/asm/cache.h | 3 +++ arch/arm/lib/cache-cp15.c | 9 ++------- arch/arm/lib/cache.c | 13 +++---------- 4 files changed, 15 insertions(+), 55 deletions(-)
diff --git a/arch/arm/cpu/armv7/cache_v7.c b/arch/arm/cpu/armv7/cache_v7.c index bc5fc42..a2c4032 100644 --- a/arch/arm/cpu/armv7/cache_v7.c +++ b/arch/arm/cpu/armv7/cache_v7.c @@ -354,41 +354,10 @@ void invalidate_icache_all(void) } #endif
-/* - * Stub implementations for outer cache operations - */ -void __v7_outer_cache_enable(void) -{ -} -void v7_outer_cache_enable(void) - __attribute__((weak, alias("__v7_outer_cache_enable"))); - -void __v7_outer_cache_disable(void) -{ -} -void v7_outer_cache_disable(void) - __attribute__((weak, alias("__v7_outer_cache_disable"))); - -void __v7_outer_cache_flush_all(void) -{ -} -void v7_outer_cache_flush_all(void) - __attribute__((weak, alias("__v7_outer_cache_flush_all"))); - -void __v7_outer_cache_inval_all(void) -{ -} -void v7_outer_cache_inval_all(void) - __attribute__((weak, alias("__v7_outer_cache_inval_all"))); - -void __v7_outer_cache_flush_range(u32 start, u32 end) -{ -} -void v7_outer_cache_flush_range(u32 start, u32 end) - __attribute__((weak, alias("__v7_outer_cache_flush_range"))); - -void __v7_outer_cache_inval_range(u32 start, u32 end) -{ -} -void v7_outer_cache_inval_range(u32 start, u32 end) - __attribute__((weak, alias("__v7_outer_cache_inval_range"))); +/* Stub implementations for outer cache operations */ +__weak void v7_outer_cache_enable(void) {} +__weak void v7_outer_cache_disable(void) {} +__weak void v7_outer_cache_flush_all(void) {} +__weak void v7_outer_cache_inval_all(void) {} +__weak void v7_outer_cache_flush_range(u32 start, u32 end) {} +__weak void v7_outer_cache_inval_range(u32 start, u32 end) {} diff --git a/arch/arm/include/asm/cache.h b/arch/arm/include/asm/cache.h index ddebbc8..a836e9f 100644 --- a/arch/arm/include/asm/cache.h +++ b/arch/arm/include/asm/cache.h @@ -29,6 +29,9 @@ void l2_cache_enable(void); void l2_cache_disable(void); void set_section_dcache(int section, enum dcache_option option);
+void arm_init_before_mmu(void); +void arm_init_domains(void); +void cpu_cache_initialization(void); void dram_bank_mmu_setup(int bank);
#endif diff --git a/arch/arm/lib/cache-cp15.c b/arch/arm/lib/cache-cp15.c index 8642010..5fdfdbf 100644 --- a/arch/arm/lib/cache-cp15.c +++ b/arch/arm/lib/cache-cp15.c @@ -14,11 +14,9 @@
DECLARE_GLOBAL_DATA_PTR;
-void __arm_init_before_mmu(void) +__weak void arm_init_before_mmu(void) { } -void arm_init_before_mmu(void) - __attribute__((weak, alias("__arm_init_before_mmu")));
__weak void arm_init_domains(void) { @@ -44,14 +42,11 @@ void set_section_dcache(int section, enum dcache_option option) page_table[section] = value; }
-void __mmu_page_table_flush(unsigned long start, unsigned long stop) +__weak void mmu_page_table_flush(unsigned long start, unsigned long stop) { debug("%s: Warning: not implemented\n", __func__); }
-void mmu_page_table_flush(unsigned long start, unsigned long stop) - __attribute__((weak, alias("__mmu_page_table_flush"))); - void mmu_set_region_dcache_behaviour(u32 start, int size, enum dcache_option option) { diff --git a/arch/arm/lib/cache.c b/arch/arm/lib/cache.c index 4f6b9f0..4e597a4 100644 --- a/arch/arm/lib/cache.c +++ b/arch/arm/lib/cache.c @@ -9,7 +9,7 @@
#include <common.h>
-void __flush_cache(unsigned long start, unsigned long size) +__weak void flush_cache(unsigned long start, unsigned long size) { #if defined(CONFIG_ARM1136)
@@ -31,28 +31,21 @@ void __flush_cache(unsigned long start, unsigned long size) #endif /* CONFIG_ARM926EJS */ return; } -void flush_cache(unsigned long start, unsigned long size) - __attribute__((weak, alias("__flush_cache")));
/* * Default implementation: * do a range flush for the entire range */ -void __flush_dcache_all(void) +__weak void flush_dcache_all(void) { flush_cache(0, ~0); } -void flush_dcache_all(void) - __attribute__((weak, alias("__flush_dcache_all"))); -
/* * Default implementation of enable_caches() * Real implementation should be in platform code */ -void __enable_caches(void) +__weak void enable_caches(void) { puts("WARNING: Caches not enabled\n"); } -void enable_caches(void) - __attribute__((weak, alias("__enable_caches")));
Been on my TODO list for a long time, thanks!
Reviewed-by: Tom Rini trini@ti.com
Extra space. Albert assuming you're OK can you just fix it up when you take it?
Hi Tom,
Ok -- pulling this one in as a bugfix (though I don't see the warning with the toolchain I am using).
Amicalement,
Hi Jeroen,
On Mon, 23 Jun 2014 22:07:04 +0200, Jeroen Hofstee jeroen@myspectrum.nl wrote:
- Stub implementations for outer cache operations
#include <common.h>
- Default implementation:
- do a range flush for the entire range
- Default implementation of enable_caches()
- Real implementation should be in platform code
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Jeroen Hofstee
