[U-Boot] [PATCH] ppc4xx: Fix DDR2 auto calibration on Kilauea 600MHz
Signed-off-by: Victor Gallardo vgallardo@amcc.com Signed-off-by: Adam Graham agraham@amcc.com --- board/amcc/kilauea/kilauea.c | 31 +++++++++++++++++++++++++++++++ cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c | 5 ----- include/asm-ppc/ppc4xx-sdram.h | 8 ++++++++ 3 files changed, 39 insertions(+), 5 deletions(-)
diff --git a/board/amcc/kilauea/kilauea.c b/board/amcc/kilauea/kilauea.c index 7b10255..8163d16 100644 --- a/board/amcc/kilauea/kilauea.c +++ b/board/amcc/kilauea/kilauea.c @@ -374,3 +374,34 @@ int post_hotkeys_pressed(void) return 0; /* No hotkeys supported */ } #endif /* CONFIG_POST */ + +#if defined(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) +/* + * This is for quicker auto calibration boot up once WRDTR and CLKTR + * values for the kilauea board were determined and are therefore known. + * + * Use these scan options for PLB bus greater than 200MHz else use + * the defaults. + */ +/* List of (SDRAM_WRDTR.[WDTR], SDRAM_CLKTR.[CLKP]) pairs to try */ +struct sdram_timing quick_scan_options[] = { + {0, 3}, {1, 1}, {1, 2}, {1, 3}, + {2, 1}, {2, 2}, {2, 3}, {3, 1}, + {3, 2}, {4, 1}, {-1, -1} +}; + +ulong ddr_scan_option(ulong default_val) +{ + u32 sdram_freq; + PPC4xx_SYS_INFO board_cfg; + + get_sys_info(&board_cfg); + sdram_freq = board_cfg.freqPLB; + + /* PLB bus greater than 200MHz */ + if (sdram_freq >= 0xbebc200) + return (ulong)(quick_scan_options); + else + return (ulong)default_val; +} +#endif /* CONFIG_PPC4xx_DDR_AUTOCALIBRATION */ diff --git a/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c b/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c index 83b9883..3ba8176 100644 --- a/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c +++ b/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c @@ -79,11 +79,6 @@ struct ddrautocal { u32 flags; };
-struct sdram_timing { - u32 wrdtr; - u32 clktr; -}; - struct sdram_timing_clks { u32 wrdtr; u32 clktr; diff --git a/include/asm-ppc/ppc4xx-sdram.h b/include/asm-ppc/ppc4xx-sdram.h index 8efa557..50148c5 100644 --- a/include/asm-ppc/ppc4xx-sdram.h +++ b/include/asm-ppc/ppc4xx-sdram.h @@ -1403,6 +1403,14 @@ #endif /* CONFIG_SDRAM_PPC4xx_DENALI_DDR2 */
#ifndef __ASSEMBLY__ + +#if defined(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) +struct sdram_timing { + u32 wrdtr; + u32 clktr; +}; +#endif /* CONFIG_PPC4xx_DDR_AUTOCALIBRATION */ + /* * Prototypes */
Please find some comments below.
- This is for quicker auto calibration boot up once WRDTR and CLKTR
- values for the kilauea board were determined and are therefore known.
- Use these scan options for PLB bus greater than 200MHz else use
- the defaults.
- {0, 3}, {1, 1}, {1, 2}, {1, 3},
- {2, 1}, {2, 2}, {2, 3}, {3, 1},
- {3, 2}, {4, 1}, {-1, -1}
It's not really clear to me, why this reduced list should fix this problem seen on the 600MHz boards (it does - I tested successfully on my board). From my understanding the scan is now skipping some of the WDTR/CLKTR configurations. This will of course result in a quicker scan, but autocalibration should still work with the default full list.
I'm probably missing something here so please enlighten me. :)
- u32 sdram_freq;
- PPC4xx_SYS_INFO board_cfg;
- get_sys_info(&board_cfg);
- sdram_freq = board_cfg.freqPLB;
- /* PLB bus greater than 200MHz */
- if (sdram_freq >= 0xbebc200)
Why do you write this in hex? Change it to decimal please.
- else
- u32 wrdtr;
- u32 clktr;
- u32 wrdtr;
- u32 clktr;
I suggest you remove this unnecessary conditional compilation option here. It doesn't hurt to have this struct declared in all configurations.
Please fix and resubmit. Thanks.
Best regards, Stefan
- the defaults.
Hi Stefan, yes you are correct, it should, but for some reason the full list causes problem. This is currently being investigated by HW team. Current work around is to reduce the WDTR/CLKTR to only those that produce a cycle delay of T2 or better.
-Victor Gallardo
Stefan Roese
Victor Gallardo
