[PATCH] gpio/mpc83xx_spisel_boot.c: gpio driver for SPISEL_BOOT signal
Some SoCs in the mpc83xx family, e.g. mpc8309, have a dedicated spi chip select, SPISEL_BOOT, that is used by the boot code to boot from flash.
This chip select will typically be used to select a SPI boot flash. The SPISEL_BOOT signal is controlled by a single bit in the SPI_CS register.
Implement a gpio driver for the spi chip select register. This allows a spi driver capable of using gpios as chip select, to bind a chip select to SPISEL_BOOT.
It may be a little odd to do this as a GPIO driver, since the signal is neither GP or I, but it is quite convenient to present it to the spi driver that way. The alternative it to teach mpc8xxx_spi to handle the SPISEL_BOOT signal itself (that is how it's done in the linux kernel, see commit 69b921acae8a)
Signed-off-by: Klaus H. Sorensen khso@prevas.dk Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- .../gpio/fsl,mpc83xx-spisel-boot.txt | 22 +++ drivers/gpio/Kconfig | 8 + drivers/gpio/Makefile | 1 + drivers/gpio/mpc83xx_spisel_boot.c | 148 ++++++++++++++++++ 4 files changed, 179 insertions(+) create mode 100644 doc/device-tree-bindings/gpio/fsl,mpc83xx-spisel-boot.txt create mode 100644 drivers/gpio/mpc83xx_spisel_boot.c
diff --git a/doc/device-tree-bindings/gpio/fsl,mpc83xx-spisel-boot.txt b/doc/device-tree-bindings/gpio/fsl,mpc83xx-spisel-boot.txt new file mode 100644 index 0000000000..52d8bb0a5c --- /dev/null +++ b/doc/device-tree-bindings/gpio/fsl,mpc83xx-spisel-boot.txt @@ -0,0 +1,22 @@ +MPC83xx SPISEL_BOOT gpio controller + +Provide access to MPC83xx SPISEL_BOOT signal as a gpio to allow it to be +easily bound as a SPI controller chip select. + +The SPISEL_BOOT signal is always an output. + +Required properties: + +- compatible: must be "fsl,mpc83xx-spisel-boot" or "fsl,mpc8309-spisel-boot". +- reg: must point to the SPI_CS register in the SoC register map. +- ngpios: number of gpios provided by driver, normally 1. + +Example: + + spisel_boot: spisel_boot@14c { + compatible = "fsl,mpc8309-spisel-boot"; + reg = <0x14c 0x04>; + #gpio-cells = <2>; + device_type = "gpio"; + ngpios = <1>; + }; diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index c1ad5d64a3..73fdb8cb3b 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -383,6 +383,14 @@ config MPC8XXX_GPIO value setting, the open-drain feature, which can configure individual GPIOs to work as open-drain outputs, is supported.
+config MPC83XX_SPISEL_BOOT + bool "Freescale MPC83XX SPISEL_BOOT driver" + depends on DM_GPIO && ARCH_MPC830X + help + GPIO driver to set/clear dedicated SPISEL_BOOT output on MPC83XX. + + This pin is typically used as spi chip select to a spi nor flash. + config MT7621_GPIO bool "MediaTek MT7621 GPIO driver" depends on DM_GPIO && SOC_MT7628 diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index ccc49e2eb0..bbeec30431 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -38,6 +38,7 @@ obj-$(CONFIG_DM644X_GPIO) += da8xx_gpio.o obj-$(CONFIG_ALTERA_PIO) += altera_pio.o obj-$(CONFIG_MPC83XX_GPIO) += mpc83xx_gpio.o obj-$(CONFIG_MPC8XXX_GPIO) += mpc8xxx_gpio.o +obj-$(CONFIG_MPC83XX_SPISEL_BOOT) += mpc83xx_spisel_boot.o obj-$(CONFIG_SH_GPIO_PFC) += sh_pfc.o obj-$(CONFIG_OMAP_GPIO) += omap_gpio.o obj-$(CONFIG_DB8500_GPIO) += db8500_gpio.o diff --git a/drivers/gpio/mpc83xx_spisel_boot.c b/drivers/gpio/mpc83xx_spisel_boot.c new file mode 100644 index 0000000000..c7b08404d9 --- /dev/null +++ b/drivers/gpio/mpc83xx_spisel_boot.c @@ -0,0 +1,148 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 DEIF A/S + * + * GPIO driver to set/clear SPISEL_BOOT pin on mpc83xx. + */ + +#include <common.h> +#include <dm.h> +#include <mapmem.h> +#include <asm/gpio.h> + +struct mpc83xx_spisel_boot { + u32 __iomem *spi_cs; + ulong addr; + uint gpio_count; + ulong type; +}; + +static u32 gpio_mask(uint gpio) +{ + return (1U << (31 - (gpio))); +} + +static int mpc83xx_spisel_boot_direction_input(struct udevice *dev, uint gpio) +{ + return -EINVAL; +} + +static int mpc83xx_spisel_boot_set_value(struct udevice *dev, uint gpio, int value) +{ + struct mpc83xx_spisel_boot *data = dev_get_priv(dev); + + debug("%s: gpio=%d, value=%u, gpio_mask=0x%08x\n", __func__, + gpio, value, gpio_mask(gpio)); + + if (value) + setbits_be32(data->spi_cs, gpio_mask(gpio)); + else + clrbits_be32(data->spi_cs, gpio_mask(gpio)); + + return 0; +} + +static int mpc83xx_spisel_boot_direction_output(struct udevice *dev, uint gpio, int value) +{ + return 0; +} + +static int mpc83xx_spisel_boot_get_value(struct udevice *dev, uint gpio) +{ + struct mpc83xx_spisel_boot *data = dev_get_priv(dev); + + return !!(in_be32(data->spi_cs) & gpio_mask(gpio)); +} + +static int mpc83xx_spisel_boot_get_function(struct udevice *dev, uint gpio) +{ + return GPIOF_OUTPUT; +} + +#if CONFIG_IS_ENABLED(OF_CONTROL) +static int mpc83xx_spisel_boot_ofdata_to_platdata(struct udevice *dev) +{ + struct mpc8xxx_gpio_plat *plat = dev_get_platdata(dev); + fdt_addr_t addr; + u32 reg[2]; + + dev_read_u32_array(dev, "reg", reg, 2); + addr = dev_translate_address(dev, reg); + + plat->addr = addr; + plat->size = reg[1]; + plat->ngpios = dev_read_u32_default(dev, "ngpios", 1); + + return 0; +} +#endif + +static int mpc83xx_spisel_boot_platdata_to_priv(struct udevice *dev) +{ + struct mpc83xx_spisel_boot *priv = dev_get_priv(dev); + struct mpc8xxx_gpio_plat *plat = dev_get_platdata(dev); + unsigned long size = plat->size; + ulong driver_data = dev_get_driver_data(dev); + + if (size == 0) + size = 0x04; + + priv->addr = plat->addr; + priv->spi_cs = map_sysmem(plat->addr, size); + + if (!priv->spi_cs) + return -ENOMEM; + + priv->gpio_count = plat->ngpios; + + priv->type = driver_data; + + return 0; +} + +static int mpc83xx_spisel_boot_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct mpc83xx_spisel_boot *data = dev_get_priv(dev); + char name[32], *str; + + mpc83xx_spisel_boot_platdata_to_priv(dev); + + snprintf(name, sizeof(name), "MPC@%lx_", data->addr); + str = strdup(name); + + if (!str) + return -ENOMEM; + + uc_priv->bank_name = str; + uc_priv->gpio_count = data->gpio_count; + + return 0; +} + +static const struct dm_gpio_ops mpc83xx_spisel_boot_ops = { + .direction_input = mpc83xx_spisel_boot_direction_input, + .direction_output = mpc83xx_spisel_boot_direction_output, + .get_value = mpc83xx_spisel_boot_get_value, + .set_value = mpc83xx_spisel_boot_set_value, + .get_function = mpc83xx_spisel_boot_get_function, +}; + +static const struct udevice_id mpc83xx_spisel_boot_ids[] = { + { .compatible = "fsl,mpc8309-spisel-boot" }, + { .compatible = "fsl,mpc83xx-spisel-boot" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(spisel_boot_mpc83xx) = { + .name = "spisel_boot_mpc83xx", + .id = UCLASS_GPIO, + .ops = &mpc83xx_spisel_boot_ops, +#if CONFIG_IS_ENABLED(OF_CONTROL) + .ofdata_to_platdata = mpc83xx_spisel_boot_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct mpc8xxx_gpio_plat), + .of_match = mpc83xx_spisel_boot_ids, +#endif + .probe = mpc83xx_spisel_boot_probe, + .priv_auto_alloc_size = sizeof(struct mpc83xx_spisel_boot), +};
Rasmus Villemoes
