[U-Boot] [PATCH v2 00/34] x86: Add support for sound
At present no x86 boards support sound. This series adds several options:
- legacy beep - Intel HDA - I2S with codec
These are enabled on coreboot, link and samus, respectively.
A number of related patches are included to make the above work.
Changes in v2: - Add a PCI ID for the HD audio class - Add a link to the HD audio PDF fie - Add a note about undocumented IOMMU values - Add a note as to why the default log level must be set to LOGL_DEBUG - Add an example to the commit message for clarity - Add comments next to verbs in the DT mentioning the HDA spec - Add new patch to fix up Kconfig log level names - Add the log-level names into the Kconfig help - Adjust code to use #defines instead of open-coded values - Also remove this feature from the TODO - Change the driver name to i8254_drv - Correct the default log level to 6 (LOGL_INFO) - Drop useless 'set' comment - Fix capital letter in Ivybridge in Kconfig help - Fix comment about @return value in ioctl() method and function - Fix ordering of PCI IDs - Fix use of C++ comments in two places - Move comment about silencing on error so that it is clearer - Rename PPC_PORTB to SYSCTL_PORTB - Rename sound driver to bd82x6x-hda - Update in codec_init() to use defines for codec access - Use "sandbox-pch" for the compatible string, for consistency - Use PIT_TICK_RATE instead of creating a new define - Use a more generic "intel,hd-audio" as the compatible string - Use defines for all azalia verbs in binding file - User lower-case hex consistently in the DT
Simon Glass (34): log: Fix up Kconfig log level names log: Add a Kconfig option to set the default log level log: Add documentation for convenience functions log: Allow #define LOG_DEBUG to enable logging in a file dm: syscon: Don't require a regmap for PCI devices i2c: designware: Add error checking on init pci: Don't export pci_hose_config_device() pci: Fix comment in struct pci_child_platdata gpio: Show inactive GPIOs when explicitly requested gpio: Use case-insentive matching on the GPIO name pci: Add IDs for Intel high-definition audio sandbox: Add a note about the growing state_info struct x86: Adjust I/O macros to work on 64-bit machines x86: samus: Increase the pre-reloc memory x86: link: Increase malloc size and decrease code size x86: sandbox: pch: Add a CONFIG option for PCH sandbox: pch: Add a test for the PCH uclass pch: Add ioctl support x86: ivybridge: Add a way to get the HDA config setting sound: Mark sound_setup() as optional sound: Add uclass operations for beeping sound: Add support for Intel HDA sandbox: sound: Silence sound for testing sound: x86: link: Add sound support sound: x86: Add beeping support in i8254 sound: Add a driver for the i8254 beep x86: coreboot: Enable the beeper sound driver x86: broadwell: Add support for the ADSP x86: broadwell: Don't bother probing the PCH for pinctrl x86: broadwell: Add support for serial I/O devices x86: sound: Add support for broadwell I2S sound: Add a driver for RealTek RT5677 x86: sound: Add sound support for samus (broadwell) x86: Add sound support for samus
arch/Kconfig | 2 + arch/sandbox/dts/test.dts | 5 + arch/sandbox/include/asm/state.h | 9 + arch/sandbox/include/asm/test.h | 24 + arch/x86/cpu/broadwell/Makefile | 1 + arch/x86/cpu/broadwell/adsp.c | 156 ++ arch/x86/cpu/broadwell/pch.c | 110 ++ arch/x86/cpu/broadwell/pinctrl_broadwell.c | 3 +- arch/x86/cpu/ivybridge/Kconfig | 1 + arch/x86/cpu/ivybridge/bd82x6x.c | 27 +- arch/x86/cpu/ivybridge/northbridge.c | 32 + arch/x86/dts/chromebook_link.dts | 96 ++ arch/x86/dts/chromebook_samus.dts | 49 +- arch/x86/include/asm/arch-broadwell/adsp.h | 46 + arch/x86/include/asm/arch-broadwell/pch.h | 3 + arch/x86/include/asm/arch-broadwell/rcb.h | 2 + .../x86/include/asm/arch-broadwell/serialio.h | 82 + .../include/asm/arch-ivybridge/sandybridge.h | 3 + arch/x86/include/asm/i8254.h | 18 + arch/x86/include/asm/io.h | 16 +- arch/x86/lib/i8254.c | 35 +- cmd/gpio.c | 10 +- common/Kconfig | 86 +- common/log.c | 2 +- configs/chromebook_link_defconfig | 5 +- configs/chromebook_samus_defconfig | 11 +- configs/coreboot_defconfig | 3 + doc/README.log | 51 +- doc/device-tree-bindings/sound/intel-hda.txt | 25 + drivers/Kconfig | 2 + drivers/Makefile | 3 +- drivers/core/syscon-uclass.c | 4 + drivers/i2c/designware_i2c.c | 29 +- drivers/pch/Kconfig | 9 + drivers/pch/Makefile | 1 + drivers/pch/pch-uclass.c | 10 + drivers/pch/sandbox_pch.c | 86 + drivers/pci/pci.c | 7 +- drivers/sound/Kconfig | 40 + drivers/sound/Makefile | 5 + drivers/sound/broadwell_i2s.c | 306 ++++ drivers/sound/broadwell_i2s.h | 301 ++++ drivers/sound/broadwell_sound.c | 65 + drivers/sound/hda_codec.c | 556 +++++++ drivers/sound/i8254_beep.c | 38 + drivers/sound/ivybridge_sound.c | 137 ++ drivers/sound/rt5677.c | 334 ++++ drivers/sound/rt5677.h | 1428 +++++++++++++++++ drivers/sound/sandbox.c | 71 +- drivers/sound/sound-uclass.c | 36 +- include/dt-bindings/sound/azalia.h | 44 + include/hda_codec.h | 103 ++ include/log.h | 9 +- include/pch.h | 51 +- include/pci.h | 8 +- include/pci_ids.h | 5 + include/sound.h | 46 +- test/dm/Makefile | 1 + test/dm/pch.c | 55 + test/dm/sound.c | 21 + 60 files changed, 4623 insertions(+), 101 deletions(-) create mode 100644 arch/x86/cpu/broadwell/adsp.c create mode 100644 arch/x86/include/asm/arch-broadwell/adsp.h create mode 100644 arch/x86/include/asm/arch-broadwell/serialio.h create mode 100644 doc/device-tree-bindings/sound/intel-hda.txt create mode 100644 drivers/pch/Kconfig create mode 100644 drivers/pch/sandbox_pch.c create mode 100644 drivers/sound/broadwell_i2s.c create mode 100644 drivers/sound/broadwell_i2s.h create mode 100644 drivers/sound/broadwell_sound.c create mode 100644 drivers/sound/hda_codec.c create mode 100644 drivers/sound/i8254_beep.c create mode 100644 drivers/sound/ivybridge_sound.c create mode 100644 drivers/sound/rt5677.c create mode 100644 drivers/sound/rt5677.h create mode 100644 include/dt-bindings/sound/azalia.h create mode 100644 include/hda_codec.h create mode 100644 test/dm/pch.c
The log level numbers in the Kconfig are not actually correct. Fix them and also add a missing space in the header-file comment.
Changes in v2: - Add new patch to fix up Kconfig log level names
common/Kconfig | 66 ++++++++++++++++++++++++++++---------------------- include/log.h | 2 +- 2 files changed, 38 insertions(+), 30 deletions(-)
diff --git a/common/Kconfig b/common/Kconfig index 0a14bdedaa6..849d8ff90ad 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -286,14 +286,16 @@ config LOGLEVEL All Messages with a loglevel smaller than the console loglevel will be compiled in. The loglevels are defined as follows:
- 0 (KERN_EMERG) system is unusable - 1 (KERN_ALERT) action must be taken immediately - 2 (KERN_CRIT) critical conditions - 3 (KERN_ERR) error conditions - 4 (KERN_WARNING) warning conditions - 5 (KERN_NOTICE) normal but significant condition - 6 (KERN_INFO) informational - 7 (KERN_DEBUG) debug-level messages + 0 - emergency + 1 - alert + 2 - critical + 3 - error + 4 - warning + 5 - note + 6 - info + 7 - debug + 8 - debug content + 9 - debug hardware I/O
config SPL_LOGLEVEL int @@ -482,14 +484,16 @@ config LOG_MAX_LEVEL higher than this will be ignored. If possible log statements below this level will be discarded at build time. Levels:
- 0 - panic - 1 - critical - 2 - error - 3 - warning - 4 - note - 5 - info - 6 - detail + 0 - emergency + 1 - alert + 2 - critical + 3 - error + 4 - warning + 5 - note + 6 - info 7 - debug + 8 - debug content + 9 - debug hardware I/O
config SPL_LOG_MAX_LEVEL int "Maximum log level to record in SPL" @@ -500,14 +504,16 @@ config SPL_LOG_MAX_LEVEL higher than this will be ignored. If possible log statements below this level will be discarded at build time. Levels:
config TPL_LOG_MAX_LEVEL int "Maximum log level to record in TPL" @@ -518,14 +524,16 @@ config TPL_LOG_MAX_LEVEL higher than this will be ignored. If possible log statements below this level will be discarded at build time. Levels:
config LOG_CONSOLE bool "Allow log output to the console" diff --git a/include/log.h b/include/log.h index d7f64710061..33e99ab7030 100644 --- a/include/log.h +++ b/include/log.h @@ -14,7 +14,7 @@
/** Log levels supported, ranging from most to least important */ enum log_level_t { - LOGL_EMERG = 0, /*U-Boot is unstable */ + LOGL_EMERG = 0, /* U-Boot is unstable */ LOGL_ALERT, /* Action must be taken immediately */ LOGL_CRIT, /* Critical conditions */ LOGL_ERR, /* Error that prevents something from working */
Changes in v2:
At present the default log level is set to LOGL_INFO on start-up. Allow this to be controlled from Kconfig.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: - Add the log-level names into the Kconfig help - Correct the default log level to 6 (LOGL_INFO)
common/Kconfig | 20 ++++++++++++++++++++ common/log.c | 2 +- 2 files changed, 21 insertions(+), 1 deletion(-)
diff --git a/common/Kconfig b/common/Kconfig index 849d8ff90ad..e100c229496 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -535,6 +535,26 @@ config TPL_LOG_MAX_LEVEL 8 - debug content 9 - debug hardware I/O
+config LOG_DEFAULT_LEVEL + int "Default logging level to display" + default 6 + help + This is the default logging level set when U-Boot starts. It can + be adjusted later using the 'log level' command. Note that setting + this to a value abnove LOG_MAX_LEVEL will be ineffective, since the + higher levels are not compiled in to U-Boot. + + 0 - emergency + 1 - alert + 2 - critical + 3 - error + 4 - warning + 5 - note + 6 - info + 7 - debug + 8 - debug content + 9 - debug hardware I/O + config LOG_CONSOLE bool "Allow log output to the console" depends on LOG diff --git a/common/log.c b/common/log.c index ec14644516c..ffb3cd69332 100644 --- a/common/log.c +++ b/common/log.c @@ -316,7 +316,7 @@ int log_init(void) } gd->flags |= GD_FLG_LOG_READY; if (!gd->default_log_level) - gd->default_log_level = LOGL_INFO; + gd->default_log_level = CONFIG_LOG_DEFAULT_LEVEL; gd->log_fmt = LOGF_DEFAULT;
The log_debug(), etc. function are documented only in the header file at present. Add a section to README.log also.
Changes in v2: - Also remove this feature from the TODO
doc/README.log | 36 ++++++++++++++++++++++++++---------- 1 file changed, 26 insertions(+), 10 deletions(-)
diff --git a/doc/README.log b/doc/README.log index 2ee1b753bc7..75350ecd41d 100644 --- a/doc/README.log +++ b/doc/README.log @@ -69,6 +69,32 @@ If CONFIG_LOG is not set, then no logging will be available. The above have SPL versions also, e.g. CONFIG_SPL_MAX_LOG_LEVEL.
+Convenience functions +--------------------- + +A number of convenience functions are available to shorten the code needed +for logging: + + log_err(_fmt...) + log_warning(_fmt...) + log_notice(_fmt...) + log_info(_fmt...) + log_debug(_fmt...) + log_content(_fmt...) + log_io(_fmt...) + +With these the log level is implicit in the name. The category is set by +LOG_CATEGORY, which you can only define once per file, above all #includes: + + #define LOG_CATEGORY LOGC_ALLOC + +or + + #define LOG_CATEGORY UCLASS_SPI + +Remember that all uclasses IDs are log categories too. + + Log commands ------------
@@ -187,16 +213,6 @@ Convenience functions to support setting the category: log_core(level, format_string, ...) - category LOGC_CORE log_dt(level, format_string, ...) - category LOGC_DT
-Convenience functions to support a category defined for a single file, for -example: - - #define LOG_CATEGORY UCLASS_USB - -all of these can use LOG_CATEGORY as the category, and a log level -corresponding to the function name: - - logc(level, format_string, ...) - More logging destinations:
device - goes to a device (e.g. serial)
At present it is possible to '#define DEBUG' at the top of a file which causes all debug() statements in that file to become active. There is currently no equivalent with logging, but this is a useful function.
Add a LOG_DEBUG define along with documentation.
Changes in v2: - Add a note as to why the default log level must be set to LOGL_DEBUG
doc/README.log | 15 +++++++++++++++ include/log.h | 7 ++++++- 2 files changed, 21 insertions(+), 1 deletion(-)
diff --git a/doc/README.log b/doc/README.log index 75350ecd41d..19856d43da2 100644 --- a/doc/README.log +++ b/doc/README.log @@ -69,6 +69,21 @@ If CONFIG_LOG is not set, then no logging will be available. The above have SPL versions also, e.g. CONFIG_SPL_MAX_LOG_LEVEL.
+Temporary logging within a single file +-------------------------------------- + +Sometimes it is useful to turn on logging just in one file. You can use this: + + #define LOG_DEBUG + +to enable building in of all logging statements in a single file. Put it at +the top of the file, before any #includes. + +To actually get U-Boot to output this you need to also set the default logging +level - e.g. set CONFIG_LOG_DEFAULT_LEVEL to 7 (LOGL_DEBUG) or more. Otherwise +debug output is suppressed and will not be generated. + + Convenience functions ---------------------
diff --git a/include/log.h b/include/log.h index 33e99ab7030..7566ba7f2db 100644 --- a/include/log.h +++ b/include/log.h @@ -111,11 +111,16 @@ int _log(enum log_category_t cat, enum log_level_t level, const char *file, #endif
#if CONFIG_IS_ENABLED(LOG) +#ifdef LOG_DEBUG +#define _LOG_DEBUG 1 +#else +#define _LOG_DEBUG 0 +#endif
/* Emit a log record if the level is less that the maximum */ #define log(_cat, _level, _fmt, _args...) ({ \ int _l = _level; \ - if (CONFIG_IS_ENABLED(LOG) && _l <= _LOG_MAX_LEVEL) \ + if (CONFIG_IS_ENABLED(LOG) && (_l <= _LOG_MAX_LEVEL || _LOG_DEBUG)) \ _log((enum log_category_t)(_cat), _l, __FILE__, __LINE__, \ __func__, \ pr_fmt(_fmt), ##_args); \
Changes in v2:
At present it is not possible to use the syscon devices for PCI devices since a regmap is required. Since PCI uses a 3-cell address the conversion of the 'reg' property to an address always fails. In any case, the regmap is not useful with PCI since devices are accessed through the PCI bus which regmap does not support.
Add a special case for PCI syscon devices, so that they don't set up a regmap.
Changes in v2: None
drivers/core/syscon-uclass.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/core/syscon-uclass.c b/drivers/core/syscon-uclass.c index 3cf9dd9dbe4..afac6d6e37e 100644 --- a/drivers/core/syscon-uclass.c +++ b/drivers/core/syscon-uclass.c @@ -37,6 +37,10 @@ static int syscon_pre_probe(struct udevice *dev) { struct syscon_uc_info *priv = dev_get_uclass_priv(dev);
+ /* Special case for PCI devices, which don't have a regmap */ + if (device_get_uclass_id(dev->parent) == UCLASS_PCI) + return 0; + /* * With OF_PLATDATA we really have no way of knowing the format of * the device-specific platform data. So we assume that it starts with
At present this driver does not check whether it is able to actually communicate with the I2C controller. It prints a timeout message but still considers the probe to be successful.
To fix this, add some checking that the init succeeds.
Changes in v2: None
drivers/i2c/designware_i2c.c | 29 +++++++++++++++++++---------- 1 file changed, 19 insertions(+), 10 deletions(-)
diff --git a/drivers/i2c/designware_i2c.c b/drivers/i2c/designware_i2c.c index dbc3326b5a9..63e40823f12 100644 --- a/drivers/i2c/designware_i2c.c +++ b/drivers/i2c/designware_i2c.c @@ -38,14 +38,16 @@ struct dw_i2c { };
#ifdef CONFIG_SYS_I2C_DW_ENABLE_STATUS_UNSUPPORTED -static void dw_i2c_enable(struct i2c_regs *i2c_base, bool enable) +static int dw_i2c_enable(struct i2c_regs *i2c_base, bool enable) { u32 ena = enable ? IC_ENABLE_0B : 0;
writel(ena, &i2c_base->ic_enable); + + return 0; } #else -static void dw_i2c_enable(struct i2c_regs *i2c_base, bool enable) +static int dw_i2c_enable(struct i2c_regs *i2c_base, bool enable) { u32 ena = enable ? IC_ENABLE_0B : 0; int timeout = 100; @@ -53,7 +55,7 @@ static void dw_i2c_enable(struct i2c_regs *i2c_base, bool enable) do { writel(ena, &i2c_base->ic_enable); if ((readl(&i2c_base->ic_enable_status) & IC_ENABLE_0B) == ena) - return; + return 0;
/* * Wait 10 times the signaling period of the highest I2C @@ -62,8 +64,9 @@ static void dw_i2c_enable(struct i2c_regs *i2c_base, bool enable) */ udelay(25); } while (timeout--); - printf("timeout in %sabling I2C adapter\n", enable ? "en" : "dis"); + + return -ETIMEDOUT; } #endif
@@ -370,10 +373,14 @@ static int __dw_i2c_write(struct i2c_regs *i2c_base, u8 dev, uint addr, * * Initialization function. */ -static void __dw_i2c_init(struct i2c_regs *i2c_base, int speed, int slaveaddr) +static int __dw_i2c_init(struct i2c_regs *i2c_base, int speed, int slaveaddr) { + int ret; + /* Disable i2c */ - dw_i2c_enable(i2c_base, false); + ret = dw_i2c_enable(i2c_base, false); + if (ret) + return ret;
writel(IC_CON_SD | IC_CON_RE | IC_CON_SPD_FS | IC_CON_MM, &i2c_base->ic_con); @@ -386,7 +393,11 @@ static void __dw_i2c_init(struct i2c_regs *i2c_base, int speed, int slaveaddr) #endif
/* Enable i2c */ - dw_i2c_enable(i2c_base, true); + ret = dw_i2c_enable(i2c_base, true); + if (ret) + return ret; + + return 0; }
#ifndef CONFIG_DM_I2C @@ -558,9 +569,7 @@ static int designware_i2c_probe(struct udevice *bus) if (&priv->reset_ctl) reset_deassert(&priv->reset_ctl);
- __dw_i2c_init(priv->regs, 0, 0); - - return 0; + return __dw_i2c_init(priv->regs, 0, 0); }
static int designware_i2c_bind(struct udevice *dev)
Hello Simon,
Am 17.02.2019 um 04:24 schrieb Simon Glass:
Changes in v2: None
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
This function is not used outside this file so make it static.
Changes in v2: None
drivers/pci/pci.c | 7 ++----- include/pci.h | 6 ------ 2 files changed, 2 insertions(+), 11 deletions(-)
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index 221054593ef..e2195726c8a 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -184,11 +184,8 @@ pci_dev_t pci_find_devices(struct pci_device_id *ids, int index) return -1; }
-int pci_hose_config_device(struct pci_controller *hose, - pci_dev_t dev, - unsigned long io, - pci_addr_t mem, - unsigned long command) +static int pci_hose_config_device(struct pci_controller *hose, pci_dev_t dev, + ulong io, pci_addr_t mem, ulong command) { u32 bar_response; unsigned int old_command; diff --git a/include/pci.h b/include/pci.h index 041f8e37476..dd5f051989d 100644 --- a/include/pci.h +++ b/include/pci.h @@ -735,12 +735,6 @@ extern pci_dev_t pci_find_device (unsigned int vendor, unsigned int device, int extern pci_dev_t pci_find_devices (struct pci_device_id *ids, int index); pci_dev_t pci_find_class(unsigned int find_class, int index);
-extern int pci_hose_config_device(struct pci_controller *hose, - pci_dev_t dev, - unsigned long io, - pci_addr_t mem, - unsigned long command); - extern int pci_hose_find_capability(struct pci_controller *hose, pci_dev_t dev, int cap); extern int pci_hose_find_cap_start(struct pci_controller *hose, pci_dev_t dev,
This is platdata, not private data, so the comment is currently incorrect. Fix it to avoid confusion.
Changes in v2: None
include/pci.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/pci.h b/include/pci.h index dd5f051989d..936cfe975cb 100644 --- a/include/pci.h +++ b/include/pci.h @@ -822,7 +822,7 @@ struct udevice; * * Every device on a PCI bus has this per-child data. * - * It can be accessed using dev_get_parent_priv(dev) if dev->parent is a + * It can be accessed using dev_get_parent_platdata(dev) if dev->parent is a * PCI bus (i.e. UCLASS_PCI) * * @devfn: Encoded device and function index - see PCI_DEVFN()
At present the gpio command only shows GPIOs which are marked as in use. This makes sense with 'gpio status' since we already have the '-a' flag to indicate that all GPIOs should be shown. But when a particular GPIO is requested, it seems better to always display it. At present the request is simply ignored.
For example if GPIO a10 is not in use, then:
gpio a10
shows nothing, not even the function being used for that GPIO. With this change, it shows the pin status:
gpio a10
a10: input: 0 [ ]
Add an extra parameter for this to avoid changing the existing flag parameter.
Changes in v2: - Add an example to the commit message for clarity
cmd/gpio.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/cmd/gpio.c b/cmd/gpio.c index 4ac1f1e4180..539e07ee077 100644 --- a/cmd/gpio.c +++ b/cmd/gpio.c @@ -34,7 +34,7 @@ enum { };
static void gpio_get_description(struct udevice *dev, const char *bank_name, - int offset, int *flagsp) + int offset, int *flagsp, bool show_all) { char buf[80]; int ret; @@ -42,7 +42,7 @@ static void gpio_get_description(struct udevice *dev, const char *bank_name, ret = gpio_get_function(dev, offset, NULL); if (ret < 0) goto err; - if (!(*flagsp & FLAG_SHOW_ALL) && ret == GPIOF_UNUSED) + if (!show_all && !(*flagsp & FLAG_SHOW_ALL) && ret == GPIOF_UNUSED) return; if ((*flagsp & FLAG_SHOW_BANK) && bank_name) { if (*flagsp & FLAG_SHOW_NEWLINE) { @@ -98,11 +98,11 @@ static int do_gpio_status(bool all, const char *gpio_name) if (gpio_name && *p) { offset = simple_strtoul(p, NULL, 10); gpio_get_description(dev, bank_name, offset, - &flags); + &flags, true); } else { for (offset = 0; offset < num_bits; offset++) { gpio_get_description(dev, bank_name, - offset, &flags); + offset, &flags, false); } } }
Hi Simon,
gpio a10
I think this should be "gpio status a10".
gpio a10
ditto
a10: input: 0 [ ]
Changes in v2:
Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com
I can fix that when applying if you don't mind.
Regards, Bin
On Mon, 18 Feb 2019 at 02:46, Bin Meng bmeng.cn@gmail.com wrote:
Hi Simon,
gpio a10
gpio a10
ditto
a10: input: 0 [ ]
Changes in v2:
Yes please.
Regards, Bin
Allow the 'gpio' command to match GPIO bank names regardless of the case of each. While these are generally in upper case, it is useful to be able to provide lower case with the command.
Changes in v2: None
cmd/gpio.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/gpio.c b/cmd/gpio.c index 539e07ee077..53366f36e76 100644 --- a/cmd/gpio.c +++ b/cmd/gpio.c @@ -90,7 +90,7 @@ static int do_gpio_status(bool all, const char *gpio_name) banklen = bank_name ? strlen(bank_name) : 0;
if (!gpio_name || !bank_name || - !strncmp(gpio_name, bank_name, banklen)) { + !strncasecmp(gpio_name, bank_name, banklen)) { const char *p = NULL; int offset;
Add a few IDs for common HDA blocks and the ADSP used on samus.
Changes in v2: - Add a PCI ID for the HD audio class - Fix ordering of PCI IDs
include/pci_ids.h | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/include/pci_ids.h b/include/pci_ids.h index fdda679cc05..bd59578ccb9 100644 --- a/include/pci_ids.h +++ b/include/pci_ids.h @@ -41,6 +41,7 @@ #define PCI_CLASS_MULTIMEDIA_VIDEO 0x0400 #define PCI_CLASS_MULTIMEDIA_AUDIO 0x0401 #define PCI_CLASS_MULTIMEDIA_PHONE 0x0402 +#define PCI_CLASS_MULTIMEDIA_HD_AUDIO 0x0403 #define PCI_CLASS_MULTIMEDIA_OTHER 0x0480
#define PCI_BASE_CLASS_MEMORY 0x05 @@ -1363,6 +1364,7 @@ #define PCI_DEVICE_ID_CREATIVE_EMU10K1 0x0002 #define PCI_DEVICE_ID_CREATIVE_20K1 0x0005 #define PCI_DEVICE_ID_CREATIVE_20K2 0x000b +#define PCI_DEVICE_ID_CREATIVE_CA01322 0x0011 #define PCI_SUBDEVICE_ID_CREATIVE_SB0760 0x0024 #define PCI_SUBDEVICE_ID_CREATIVE_SB08801 0x0041 #define PCI_SUBDEVICE_ID_CREATIVE_SB08802 0x0042 @@ -2827,6 +2829,7 @@ #define PCI_DEVICE_ID_INTEL_ICH7_19 0x27dd #define PCI_DEVICE_ID_INTEL_ICH7_20 0x27de #define PCI_DEVICE_ID_INTEL_ICH7_21 0x27df +#define PCI_DEVICE_ID_INTEL_COUGARPOINT_HDMI 0x2806 #define PCI_DEVICE_ID_INTEL_ICH8_0 0x2810 #define PCI_DEVICE_ID_INTEL_ICH8_1 0x2811 #define PCI_DEVICE_ID_INTEL_ICH8_2 0x2812 @@ -3025,6 +3028,8 @@ #define PCI_DEVICE_ID_INTEL_LYNXPOINT_AHCI 0x9c03 #define PCI_DEVICE_ID_INTEL_LYNXPOINT_LPC 0x9c45 #define PCI_DEVICE_ID_INTEL_WILDCATPOINT_AHCI 0x9c83 +#define PCI_DEVICE_ID_INTEL_WILDCATPOINT_HDA 0x9ca0 +#define PCI_DEVICE_ID_INTEL_WILDCATPOINT_ADSP 0x9cb6 #define PCI_DEVICE_ID_INTEL_WILDCATPOINT_LPC 0x9cc3 #define PCI_DEVICE_ID_INTEL_S21152BB 0xb152
Changes in v2:
This struct is getting larger and in some cases is being used for things which would be better put into a driver. For example hwspinlock is not used outside of sandbox_hwspinlock.c.
Add a note to encourage people to put things elsewhere.
Changes in v2: None
arch/sandbox/include/asm/state.h | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/sandbox/include/asm/state.h b/arch/sandbox/include/asm/state.h index c724827f6cf..2d773d3fa6b 100644 --- a/arch/sandbox/include/asm/state.h +++ b/arch/sandbox/include/asm/state.h @@ -102,6 +102,15 @@ struct sandbox_state { ulong next_tag; /* Next address tag to allocate */ struct list_head mapmem_head; /* struct sandbox_mapmem_entry */ bool hwspinlock; /* Hardware Spinlock status */ + + /* + * This struct is getting large. + * + * Consider putting test data in driver-private structs, like + * sandbox_pch.c. + * + * If you add new members, please put them above this comment. + */ };
/* Minimum space we guarantee in the state FDT when calling read/write*/
At present these macros give warnings on 64-bit machines and do not correctly do 32-bit accesses. Update them to use linux types.
Changes in v2: None
arch/x86/include/asm/io.h | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/arch/x86/include/asm/io.h b/arch/x86/include/asm/io.h index 81def0afd30..cf6c33cbe3a 100644 --- a/arch/x86/include/asm/io.h +++ b/arch/x86/include/asm/io.h @@ -57,19 +57,19 @@ * memory location directly. */
-#define readb(addr) (*(volatile unsigned char *) (addr)) -#define readw(addr) (*(volatile unsigned short *) (addr)) -#define readl(addr) (*(volatile unsigned int *) (addr)) -#define readq(addr) (*(volatile unsigned long long *) (addr)) +#define readb(addr) (*(volatile u8 *)(uintptr_t)(addr)) +#define readw(addr) (*(volatile u16 *)(uintptr_t)(addr)) +#define readl(addr) (*(volatile u32 *)(uintptr_t)(addr)) +#define readq(addr) (*(volatile u64 *)(uintptr_t)(addr)) #define __raw_readb readb #define __raw_readw readw #define __raw_readl readl #define __raw_readq readq
-#define writeb(b,addr) (*(volatile unsigned char *) (addr) = (b)) -#define writew(b,addr) (*(volatile unsigned short *) (addr) = (b)) -#define writel(b,addr) (*(volatile unsigned int *) (addr) = (b)) -#define writeq(b,addr) (*(volatile unsigned long long *) (addr) = (b)) +#define writeb(b, addr) (*(volatile u8 *)(addr) = (b)) +#define writew(b, addr) (*(volatile u16 *)(addr) = (b)) +#define writel(b, addr) (*(volatile u32 *)(addr) = (b)) +#define writeq(b, addr) (*(volatile u64 *)(addr) = (b)) #define __raw_writeb writeb #define __raw_writew writew #define __raw_writel writel
This is too small now, likely due to the pre_reloc_only fixes. Increase it.
Changes in v2: None
configs/chromebook_samus_defconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index e5483c59205..745cb3db0a6 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -1,6 +1,6 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFE00000 -CONFIG_SYS_MALLOC_F_LEN=0x1a00 +CONFIG_SYS_MALLOC_F_LEN=0x1c00 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200
At present link does not boot since it has outgrown its pre-relocation malloc() size and its assigned code area. Increase the former and drop EFI loader support, which adds about 45KB!
Changes in v2: None
configs/chromebook_link_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index b90aae610b2..c402568c17e 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -1,6 +1,6 @@ CONFIG_X86=y CONFIG_SYS_TEXT_BASE=0xFFF00000 -CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SYS_MALLOC_F_LEN=0x2400 CONFIG_DEBUG_UART_BOARD_INIT=y CONFIG_DEBUG_UART_BASE=0x3f8 CONFIG_DEBUG_UART_CLOCK=1843200 @@ -63,3 +63,4 @@ CONFIG_VIDEO_IVYBRIDGE_IGD=y CONFIG_CONSOLE_SCROLL_LINES=5 CONFIG_CMD_DHRYSTONE=y CONFIG_TPM=y +# CONFIG_EFI_LOADER is not set
At present this uclass is selected only on x86. In order to add a test for it, it must also support sandbox. Create a new CONFIG_PCH option and enable it on x86 and sandbox.
Changes in v2: None
arch/Kconfig | 2 ++ drivers/Kconfig | 2 ++ drivers/Makefile | 3 ++- drivers/pch/Kconfig | 9 +++++++++ 4 files changed, 15 insertions(+), 1 deletion(-) create mode 100644 drivers/pch/Kconfig
diff --git a/arch/Kconfig b/arch/Kconfig index 35e2712fce9..d9afe269f20 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -117,6 +117,7 @@ config SANDBOX imply VIRTIO_BLK imply VIRTIO_NET imply DM_SOUND + imply PCH
config SH bool "SuperH architecture" @@ -160,6 +161,7 @@ config X86 imply USB_ETHER_ASIX imply USB_ETHER_SMSC95XX imply USB_HOST_ETHER + imply PCH
config XTENSA bool "Xtensa architecture" diff --git a/drivers/Kconfig b/drivers/Kconfig index e9fbadd13d5..f24351ac4f1 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -64,6 +64,8 @@ source "drivers/nvme/Kconfig"
source "drivers/pci/Kconfig"
+source "drivers/pch/Kconfig" + source "drivers/pcmcia/Kconfig"
source "drivers/phy/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index eca023ac04d..a7bba3ed564 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -86,7 +86,8 @@ obj-y += misc/ obj-$(CONFIG_MMC) += mmc/ obj-$(CONFIG_NVME) += nvme/ obj-y += pcmcia/ -obj-$(CONFIG_X86) += pch/ +obj-y += dfu/ +obj-$(CONFIG_PCH) += pch/ obj-y += phy/allwinner/ obj-y += phy/marvell/ obj-y += rtc/ diff --git a/drivers/pch/Kconfig b/drivers/pch/Kconfig new file mode 100644 index 00000000000..18f006de24c --- /dev/null +++ b/drivers/pch/Kconfig @@ -0,0 +1,9 @@ +config PCH + bool "Enable Platform-controller Hub (PCH) support" + depends on X86 || SANDBOX + help + Most x86 chips include a PCH which is responsible for handling + parts of the system not handled by that CPU. It supersedes the + northbridge / southbridge architecture that was previously used. The + PCH allows for higher performance since the memory functions are + handled in the CPU.
This uclass currently has no tests. Add a sandbox driver and some simple tests to provide basic coverage.
Changes in v2: - Use "sandbox-pch" for the compatible string, for consistency
arch/sandbox/dts/test.dts | 4 ++ arch/sandbox/include/asm/test.h | 8 ++++ drivers/pch/Makefile | 1 + drivers/pch/sandbox_pch.c | 69 +++++++++++++++++++++++++++++++++ test/dm/Makefile | 1 + test/dm/pch.c | 36 +++++++++++++++++ 6 files changed, 119 insertions(+) create mode 100644 drivers/pch/sandbox_pch.c create mode 100644 test/dm/pch.c
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 1d011ded7cc..f9a86f2596f 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -407,6 +407,10 @@ compatible = "sandbox,mmc"; };
+ pch { + compatible = "sandbox-pch"; + }; + pci0: pci-controller0 { compatible = "sandbox,pci"; device_type = "pci"; diff --git a/arch/sandbox/include/asm/test.h b/arch/sandbox/include/asm/test.h index 74f96188220..ce00ba51e47 100644 --- a/arch/sandbox/include/asm/test.h +++ b/arch/sandbox/include/asm/test.h @@ -161,4 +161,12 @@ int sandbox_get_setup_called(struct udevice *dev); */ int sandbox_get_sound_sum(struct udevice *dev);
+/** + * sandbox_get_pch_spi_protect() - Get the PCI SPI protection status + * + * @dev: Device to check + * @return 0 if not protected, 1 if protected + */ +int sandbox_get_pch_spi_protect(struct udevice *dev); + #endif diff --git a/drivers/pch/Makefile b/drivers/pch/Makefile index 696cdffedb6..8ea6b7852ac 100644 --- a/drivers/pch/Makefile +++ b/drivers/pch/Makefile @@ -3,3 +3,4 @@ obj-y += pch-uclass.o obj-y += pch7.o obj-y += pch9.o +obj-$(CONFIG_SANDBOX) += sandbox_pch.o diff --git a/drivers/pch/sandbox_pch.c b/drivers/pch/sandbox_pch.c new file mode 100644 index 00000000000..004de901ac7 --- /dev/null +++ b/drivers/pch/sandbox_pch.c @@ -0,0 +1,69 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google LLC + */ + +#include <common.h> +#include <dm.h> +#include <pch.h> + +struct sandbox_pch_priv { + bool protect; +}; + +int sandbox_get_pch_spi_protect(struct udevice *dev) +{ + struct sandbox_pch_priv *priv = dev_get_priv(dev); + + return priv->protect; +} + +static int sandbox_pch_get_spi_base(struct udevice *dev, ulong *sbasep) +{ + *sbasep = 0x10; + + return 0; +} + +static int sandbox_pch_set_spi_protect(struct udevice *dev, bool protect) +{ + struct sandbox_pch_priv *priv = dev_get_priv(dev); + + priv->protect = protect; + + return 0; +} + +static int sandbox_pch_get_gpio_base(struct udevice *dev, u32 *gbasep) +{ + *gbasep = 0x20; + + return 0; +} + +static int sandbox_pch_get_io_base(struct udevice *dev, u32 *iobasep) +{ + *iobasep = 0x30; + + return 0; +} + +static const struct pch_ops sandbox_pch_ops = { + .get_spi_base = sandbox_pch_get_spi_base, + .set_spi_protect = sandbox_pch_set_spi_protect, + .get_gpio_base = sandbox_pch_get_gpio_base, + .get_io_base = sandbox_pch_get_io_base, +}; + +static const struct udevice_id sandbox_pch_ids[] = { + { .compatible = "sandbox-pch" }, + { } +}; + +U_BOOT_DRIVER(sandbox_pch_drv) = { + .name = "sandbox-pch", + .id = UCLASS_PCH, + .of_match = sandbox_pch_ids, + .ops = &sandbox_pch_ops, + .priv_auto_alloc_size = sizeof(struct sandbox_pch_priv), +}; diff --git a/test/dm/Makefile b/test/dm/Makefile index 1b089960cbb..49857c50929 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -30,6 +30,7 @@ obj-y += ofnode.o obj-$(CONFIG_OSD) += osd.o obj-$(CONFIG_DM_VIDEO) += panel.o obj-$(CONFIG_DM_PCI) += pci.o +obj-$(CONFIG_PCH) += pch.o obj-$(CONFIG_PHY) += phy.o obj-$(CONFIG_POWER_DOMAIN) += power-domain.o obj-$(CONFIG_DM_PWM) += pwm.o diff --git a/test/dm/pch.c b/test/dm/pch.c new file mode 100644 index 00000000000..f184445342b --- /dev/null +++ b/test/dm/pch.c @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google LLC + */ + +#include <common.h> +#include <dm.h> +#include <pch.h> +#include <asm/test.h> +#include <dm/test.h> +#include <test/ut.h> + +/* Test that sandbox PCH works correctly */ +static int dm_test_pch_base(struct unit_test_state *uts) +{ + struct udevice *dev; + u32 gbase, iobase; + ulong sbase; + + ut_assertok(uclass_first_device_err(UCLASS_PCH, &dev)); + ut_assertok(pch_get_spi_base(dev, &sbase)); + ut_asserteq(0x10, sbase); + + ut_asserteq(0, sandbox_get_pch_spi_protect(dev)); + ut_assertok(pch_set_spi_protect(dev, true)); + ut_asserteq(1, sandbox_get_pch_spi_protect(dev)); + + ut_assertok(pch_get_gpio_base(dev, &gbase)); + ut_asserteq(0x20, gbase); + + ut_assertok(pch_get_io_base(dev, &iobase)); + ut_asserteq(0x30, iobase); + + return 0; +} +DM_TEST(dm_test_pch_base, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Hi Simon,
Changes in v2:
I think it should be "sandbox,pch" instead. If you agree, I can fix this when applying.
Regards, Bin
Hi Simon,
Changes in v2:
That's fine with me, it is more consistent with what we have.
Regards, Bin
At present the PCH has 4 operations and these are reasonably widely used in the drivers. But sometimes we want to add rarely used operations, and each of these currently adds to the size of the PCH operations table.
Add an ioctl() method which can be easily expanded without any more impact on the operations table.
Changes in v2: - Fix comment about @return value in ioctl() method and function
drivers/pch/pch-uclass.c | 10 ++++++++ drivers/pch/sandbox_pch.c | 17 ++++++++++++++ include/pch.h | 48 ++++++++++++++++++++++++++++++++++++++- test/dm/pch.c | 19 ++++++++++++++++ 4 files changed, 93 insertions(+), 1 deletion(-)
diff --git a/drivers/pch/pch-uclass.c b/drivers/pch/pch-uclass.c index 831b283d7b4..caf8b72803c 100644 --- a/drivers/pch/pch-uclass.c +++ b/drivers/pch/pch-uclass.c @@ -51,6 +51,16 @@ int pch_get_io_base(struct udevice *dev, u32 *iobasep) return ops->get_io_base(dev, iobasep); }
+int pch_ioctl(struct udevice *dev, ulong req, void *data, int size) +{ + struct pch_ops *ops = pch_get_ops(dev); + + if (!ops->ioctl) + return -ENOSYS; + + return ops->ioctl(dev, req, data, size); +} + UCLASS_DRIVER(pch) = { .id = UCLASS_PCH, .name = "pch", diff --git a/drivers/pch/sandbox_pch.c b/drivers/pch/sandbox_pch.c index 004de901ac7..01ff3bed351 100644 --- a/drivers/pch/sandbox_pch.c +++ b/drivers/pch/sandbox_pch.c @@ -48,11 +48,28 @@ static int sandbox_pch_get_io_base(struct udevice *dev, u32 *iobasep) return 0; }
+int sandbox_pch_ioctl(struct udevice *dev, enum pch_req_t req, void *data, + int size) +{ + switch (req) { + case PCH_REQ_TEST1: + return -ENOSYS; + case PCH_REQ_TEST2: + return *(char *)data; + case PCH_REQ_TEST3: + *(char *)data = 'x'; + return 1; + default: + return -ENOSYS; + } +} + static const struct pch_ops sandbox_pch_ops = { .get_spi_base = sandbox_pch_get_spi_base, .set_spi_protect = sandbox_pch_set_spi_protect, .get_gpio_base = sandbox_pch_get_gpio_base, .get_io_base = sandbox_pch_get_io_base, + .ioctl = sandbox_pch_ioctl, };
static const struct udevice_id sandbox_pch_ids[] = { diff --git a/include/pch.h b/include/pch.h index 73994b8343f..b8b62d74acb 100644 --- a/include/pch.h +++ b/include/pch.h @@ -11,7 +11,20 @@
#define BIOS_CTRL_BIOSWE BIT(0)
-/* Operations for the Platform Controller Hub */ +/* All the supported PCH ioctls */ +enum pch_req_t { + PCH_REQ_TEST1, /* Test requests for sandbox driver */ + PCH_REQ_TEST2, + PCH_REQ_TEST3, + + PCH_REQ_COUNT, /* Number of ioctrls supported */ +}; + +/** + * struct pch_ops - Operations for the Platform Controller Hub + * + * Consider using ioctl() to add rarely used or driver-specific operations. + */ struct pch_ops { /** * get_spi_base() - get the address of SPI base @@ -49,6 +62,23 @@ struct pch_ops { * @return 0 if OK, -ve on error (e.g. there is no IO base) */ int (*get_io_base)(struct udevice *dev, u32 *iobasep); + + /** + * ioctl() - perform misc read/write operations + * + * This is a catch-all operation intended to avoid adding lots of + * methods to this uclass, of which few are commonly used. Uncommon + * operations that pertain only to a few devices in this uclass should + * use this method instead of adding new methods. + * + * @dev: PCH device to check + * @req: PCH request ID + * @data: Input/output data + * @size: Size of input data (and maximum size of output data) + * @return size of output data on sucesss, -ve on error + */ + int (*ioctl)(struct udevice *dev, enum pch_req_t req, void *data, + int size); };
#define pch_get_ops(dev) ((struct pch_ops *)(dev)->driver->ops) @@ -90,4 +120,20 @@ int pch_get_gpio_base(struct udevice *dev, u32 *gbasep); */ int pch_get_io_base(struct udevice *dev, u32 *iobasep);
+/** + * pch_ioctl() - perform misc read/write operations + * + * This is a catch-all operation intended to avoid adding lots of + * methods to this uclass, of which few are commonly used. Uncommon + * operations that pertain only to a few devices in this uclass should + * use this method instead of adding new methods. + * + * @dev: PCH device to check + * @req: PCH request ID + * @data: Input/output data + * @size: Size of input data (and maximum size of output data) + * @return size of output data on sucesss, -ve on error + */ +int pch_ioctl(struct udevice *dev, ulong req, void *data, int size); + #endif diff --git a/test/dm/pch.c b/test/dm/pch.c index f184445342b..54e33d187b6 100644 --- a/test/dm/pch.c +++ b/test/dm/pch.c @@ -34,3 +34,22 @@ static int dm_test_pch_base(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_pch_base, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test sandbox PCH ioctl */ +static int dm_test_pch_ioctl(struct unit_test_state *uts) +{ + struct udevice *dev; + char data; + + ut_assertok(uclass_first_device_err(UCLASS_PCH, &dev)); + + ut_asserteq(-ENOSYS, pch_ioctl(dev, PCH_REQ_TEST1, NULL, 0)); + + ut_asserteq('a', pch_ioctl(dev, PCH_REQ_TEST2, "a", 1)); + + ut_asserteq(1, pch_ioctl(dev, PCH_REQ_TEST3, &data, 1)); + ut_asserteq('x', data); + + return 0; +} +DM_TEST(dm_test_pch_ioctl, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
Add a way check to whether HD audio is enabled. Use ioctl() to avoid adding too many unusual operations to PCH.
Changes in v2: - Adjust code to use #defines instead of open-coded values
arch/x86/cpu/ivybridge/bd82x6x.c | 27 +++++++++++++++++++++++++-- include/pch.h | 3 +++ 2 files changed, 28 insertions(+), 2 deletions(-)
diff --git a/arch/x86/cpu/ivybridge/bd82x6x.c b/arch/x86/cpu/ivybridge/bd82x6x.c index a78bb025440..ed9bce64168 100644 --- a/arch/x86/cpu/ivybridge/bd82x6x.c +++ b/arch/x86/cpu/ivybridge/bd82x6x.c @@ -20,8 +20,12 @@
DECLARE_GLOBAL_DATA_PTR;
-#define GPIO_BASE 0x48 -#define BIOS_CTRL 0xdc +#define GPIO_BASE 0x48 +#define BIOS_CTRL 0xdc + +#define RCBA_AUDIO_CONFIG 0x2030 +#define RCBA_AUDIO_CONFIG_HDA BIT(31) +#define RCBA_AUDIO_CONFIG_MASK 0xfe
#ifndef CONFIG_HAVE_FSP static int pch_revision_id = -1; @@ -212,10 +216,29 @@ static int bd82x6x_get_gpio_base(struct udevice *dev, u32 *gbasep) return 0; }
+static int bd82x6x_ioctl(struct udevice *dev, enum pch_req_t req, void *data, + int size) +{ + u32 rcba, val; + + switch (req) { + case PCH_REQ_HDA_CONFIG: + dm_pci_read_config32(dev, PCH_RCBA, &rcba); + val = readl(rcba + RCBA_AUDIO_CONFIG); + if (!(val & RCBA_AUDIO_CONFIG_HDA)) + return -ENOENT; + + return val & RCBA_AUDIO_CONFIG_MASK; + default: + return -ENOSYS; + } +} + static const struct pch_ops bd82x6x_pch_ops = { .get_spi_base = bd82x6x_pch_get_spi_base, .set_spi_protect = bd82x6x_set_spi_protect, .get_gpio_base = bd82x6x_get_gpio_base, + .ioctl = bd82x6x_ioctl, };
static const struct udevice_id bd82x6x_ids[] = { diff --git a/include/pch.h b/include/pch.h index b8b62d74acb..046a5fde3ab 100644 --- a/include/pch.h +++ b/include/pch.h @@ -13,6 +13,9 @@
/* All the supported PCH ioctls */ enum pch_req_t { + /* Returns HDA config info if Azalia V1CTL enabled, -ENOENT if not */ + PCH_REQ_HDA_CONFIG, + PCH_REQ_TEST1, /* Test requests for sandbox driver */ PCH_REQ_TEST2, PCH_REQ_TEST3,
This method in the sound API is optional since some drivers can do this when probing or as part of SoC init. Mark it as such.
Changes in v2: None
drivers/sound/sound-uclass.c | 2 +- include/sound.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/sound/sound-uclass.c b/drivers/sound/sound-uclass.c index 2b836268896..067660623b2 100644 --- a/drivers/sound/sound-uclass.c +++ b/drivers/sound/sound-uclass.c @@ -16,7 +16,7 @@ int sound_setup(struct udevice *dev) struct sound_ops *ops = sound_get_ops(dev);
if (!ops->setup) - return -ENOSYS; + return 0;
return ops->setup(dev); } diff --git a/include/sound.h b/include/sound.h index b7959cc2607..7d528c479ef 100644 --- a/include/sound.h +++ b/include/sound.h @@ -54,7 +54,7 @@ void sound_create_square_wave(uint sample_rate, unsigned short *data, int size, /* Operations for sound */ struct sound_ops { /** - * setup() - Set up to play a sound + * setup() - Set up to play a sound (optional) */ int (*setup)(struct udevice *dev);
Some audio codecs such as Intel HDA do not need to use digital data to play sounds, but instead have a way to emit beeps. Add this interface as an option. If the beep interface is not supported, then the sound uclass falls back to the I2S interface.
Changes in v2: None
arch/sandbox/include/asm/test.h | 16 ++++++++++++ drivers/sound/sandbox.c | 46 ++++++++++++++++++++++++++++++--- drivers/sound/sound-uclass.c | 34 +++++++++++++++++++++++- include/sound.h | 44 +++++++++++++++++++++++++++++++ test/dm/sound.c | 21 +++++++++++++++ 5 files changed, 157 insertions(+), 4 deletions(-)
diff --git a/arch/sandbox/include/asm/test.h b/arch/sandbox/include/asm/test.h index ce00ba51e47..fc52f47f821 100644 --- a/arch/sandbox/include/asm/test.h +++ b/arch/sandbox/include/asm/test.h @@ -161,6 +161,22 @@ int sandbox_get_setup_called(struct udevice *dev); */ int sandbox_get_sound_sum(struct udevice *dev);
+/** + * sandbox_set_allow_beep() - Set whether the 'beep' interface is supported + * + * @dev: Device to update + * @allow: true to allow the start_beep() method, false to disallow it + */ +void sandbox_set_allow_beep(struct udevice *dev, bool allow); + +/** + * sandbox_get_beep_frequency() - Get the frequency of the current beep + * + * @dev: Device to check + * @return frequency of beep, if there is an active beep, else 0 + */ +int sandbox_get_beep_frequency(struct udevice *dev); + /** * sandbox_get_pch_spi_protect() - Get the PCI SPI protection status * diff --git a/drivers/sound/sandbox.c b/drivers/sound/sandbox.c index b0b07f3239b..600523160f0 100644 --- a/drivers/sound/sandbox.c +++ b/drivers/sound/sandbox.c @@ -24,7 +24,9 @@ struct sandbox_i2s_priv {
struct sandbox_sound_priv { int setup_called; - int sum; /* Use to sum the provided audio data */ + int sum; /* Use to sum the provided audio data */ + bool allow_beep; /* true to allow the start_beep() interface */ + int frequency_hz; /* Beep frequency if active, else 0 */ };
void sandbox_get_codec_params(struct udevice *dev, int *interfacep, int *ratep, @@ -61,6 +63,20 @@ int sandbox_get_sound_sum(struct udevice *dev) return priv->sum; }
+void sandbox_set_allow_beep(struct udevice *dev, bool allow) +{ + struct sandbox_sound_priv *priv = dev_get_priv(dev); + + priv->allow_beep = allow; +} + +int sandbox_get_beep_frequency(struct udevice *dev) +{ + struct sandbox_sound_priv *priv = dev_get_priv(dev); + + return priv->frequency_hz; +} + static int sandbox_codec_set_params(struct udevice *dev, int interface, int rate, int mclk_freq, int bits_per_sample, uint channels) @@ -128,6 +144,28 @@ static int sandbox_sound_play(struct udevice *dev, void *data, uint data_size) return i2s_tx_data(uc_priv->i2s, data, data_size); }
+int sandbox_sound_start_beep(struct udevice *dev, int frequency_hz) +{ + struct sandbox_sound_priv *priv = dev_get_priv(dev); + + if (!priv->allow_beep) + return -ENOSYS; + priv->frequency_hz = frequency_hz; + + return 0; +} + +int sandbox_sound_stop_beep(struct udevice *dev) +{ + struct sandbox_sound_priv *priv = dev_get_priv(dev); + + if (!priv->allow_beep) + return -ENOSYS; + priv->frequency_hz = 0; + + return 0; +} + static int sandbox_sound_probe(struct udevice *dev) { return sound_find_codec_i2s(dev); @@ -169,8 +207,10 @@ U_BOOT_DRIVER(sandbox_i2s) = { };
static const struct sound_ops sandbox_sound_ops = { - .setup = sandbox_sound_setup, - .play = sandbox_sound_play, + .setup = sandbox_sound_setup, + .play = sandbox_sound_play, + .start_beep = sandbox_sound_start_beep, + .stop_beep = sandbox_sound_stop_beep, };
static const struct udevice_id sandbox_sound_ids[] = { diff --git a/drivers/sound/sound-uclass.c b/drivers/sound/sound-uclass.c index 067660623b2..d49f29bcd5b 100644 --- a/drivers/sound/sound-uclass.c +++ b/drivers/sound/sound-uclass.c @@ -31,10 +31,30 @@ int sound_play(struct udevice *dev, void *data, uint data_size) return ops->play(dev, data, data_size); }
+int sound_start_beep(struct udevice *dev, int frequency_hz) +{ + struct sound_ops *ops = sound_get_ops(dev); + + if (!ops->start_beep) + return -ENOSYS; + + return ops->start_beep(dev, frequency_hz); +} + +int sound_stop_beep(struct udevice *dev) +{ + struct sound_ops *ops = sound_get_ops(dev); + + if (!ops->stop_beep) + return -ENOSYS; + + return ops->stop_beep(dev); +} + int sound_beep(struct udevice *dev, int msecs, int frequency_hz) { struct sound_uc_priv *uc_priv = dev_get_uclass_priv(dev); - struct i2s_uc_priv *i2s_uc_priv = dev_get_uclass_priv(uc_priv->i2s); + struct i2s_uc_priv *i2s_uc_priv; unsigned short *data; uint data_size; int ret; @@ -43,7 +63,19 @@ int sound_beep(struct udevice *dev, int msecs, int frequency_hz) if (ret && ret != -EALREADY) return ret;
+ /* Try using the beep interface if available */ + ret = sound_start_beep(dev, frequency_hz); + if (ret != -ENOSYS) { + if (ret) + return ret; + mdelay(msecs); + ret = sound_stop_beep(dev); + + return ret; + } + /* Buffer length computation */ + i2s_uc_priv = dev_get_uclass_priv(uc_priv->i2s); data_size = i2s_uc_priv->samplingrate * i2s_uc_priv->channels; data_size *= (i2s_uc_priv->bitspersample / SOUND_BITS_IN_BYTE); data = malloc(data_size); diff --git a/include/sound.h b/include/sound.h index 7d528c479ef..47de9fa3ed3 100644 --- a/include/sound.h +++ b/include/sound.h @@ -67,6 +67,28 @@ struct sound_ops { * @return 0 if OK, -ve on error */ int (*play)(struct udevice *dev, void *data, uint data_size); + + /** + * start_beep() - Start beeping (optional) + * + * This tells the sound hardware to start a beep. It will continue until + * stopped by sound_stop_beep(). + * + * @dev: Sound device + * @frequency_hz: Beep frequency in hertz + * @return if OK, -ENOSYS if not supported, -ve on error + */ + int (*start_beep)(struct udevice *dev, int frequency_hz); + + /** + * stop_beep() - Stop beeping (optional) + * + * This tells the sound hardware to stop a previously started beep. + * + * @dev: Sound device + * @return if OK, -ve on error + */ + int (*stop_beep)(struct udevice *dev); };
#define sound_get_ops(dev) ((struct sound_ops *)(dev)->driver->ops) @@ -86,6 +108,28 @@ int sound_setup(struct udevice *dev); */ int sound_beep(struct udevice *dev, int msecs, int frequency_hz);
+/** + * sound_start_beep() - Start beeping + * + * This tells the sound hardware to start a beep. It will continue until stopped + * by sound_stop_beep(). + * + * @dev: Sound device + * @frequency_hz: Beep frequency in hertz + * @return if OK, -ve on error + */ +int sound_start_beep(struct udevice *dev, int frequency_hz); + +/** + * sound_stop_beep() - Stop beeping + * + * This tells the sound hardware to stop a previously started beep. + * + * @dev: Sound device + * @return if OK, -ve on error + */ +int sound_stop_beep(struct udevice *dev); + /** * sound_find_codec_i2s() - Called by sound drivers to locate codec and i2s * diff --git a/test/dm/sound.c b/test/dm/sound.c index 7d0b36e7a56..3767abbd1c7 100644 --- a/test/dm/sound.c +++ b/test/dm/sound.c @@ -32,3 +32,24 @@ static int dm_test_sound(struct unit_test_state *uts) return 0; } DM_TEST(dm_test_sound, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT); + +/* Test of the 'start beep' operations */ +static int dm_test_sound_beep(struct unit_test_state *uts) +{ + struct udevice *dev; + + /* check probe success */ + ut_assertok(uclass_first_device_err(UCLASS_SOUND, &dev)); + ut_asserteq(-ENOSYS, sound_start_beep(dev, 100)); + ut_asserteq(0, sandbox_get_beep_frequency(dev)); + + sandbox_set_allow_beep(dev, true); + ut_asserteq(0, sound_start_beep(dev, 100)); + ut_asserteq(100, sandbox_get_beep_frequency(dev)); + + ut_asserteq(0, sound_stop_beep(dev)); + ut_asserteq(0, sandbox_get_beep_frequency(dev)); + + return 0; +} +DM_TEST(dm_test_sound_beep, DM_TESTF_SCAN_PDATA | DM_TESTF_SCAN_FDT);
The Intel High-definition Audio is a newer-generation audio system which provides for transfer of a large number of audio stream, each containing up to 16 channels.
Add support for HDA as a library which can be used by other drivers. U-Boot currently uses only two channels (stereo).
Changes in v2: - Add a link to the HD audio PDF fie - Update in codec_init() to use defines for codec access - Use a more generic "intel,hd-audio" as the compatible string - Use defines for all azalia verbs in binding file
doc/device-tree-bindings/sound/intel-hda.txt | 25 + drivers/sound/Kconfig | 9 + drivers/sound/Makefile | 1 + drivers/sound/hda_codec.c | 556 +++++++++++++++++++ include/dt-bindings/sound/azalia.h | 44 ++ include/hda_codec.h | 103 ++++ 6 files changed, 738 insertions(+) create mode 100644 doc/device-tree-bindings/sound/intel-hda.txt create mode 100644 drivers/sound/hda_codec.c create mode 100644 include/dt-bindings/sound/azalia.h create mode 100644 include/hda_codec.h
diff --git a/doc/device-tree-bindings/sound/intel-hda.txt b/doc/device-tree-bindings/sound/intel-hda.txt new file mode 100644 index 00000000000..fb2ce550063 --- /dev/null +++ b/doc/device-tree-bindings/sound/intel-hda.txt @@ -0,0 +1,25 @@ +* Intel High-definition Audio + +Configuration is set using 'verbs' which are blocks of 16 bytes of data each +with a different purpose, a little like a simple instruction set. + +Top-level node +-------------- + +Required properties: +- compatible: "intel,hd-audio" +- beep-verbs: list of verbs to send for a beep + +Optional properties +- intel,beep-nid: Node ID to use for beep (will be detected if not provided) + +Required subnodes: +- codecs: Contains a list of codec nodes + + +* Codec nodes + +Required properties: +- vendor-id: 16-bit vendor ID for audio codec +- device-id: 16-bit device ID for audio codec +- verbs: List of verbs, each 4 cells in length diff --git a/drivers/sound/Kconfig b/drivers/sound/Kconfig index 40f4f7598aa..0dca6ffe88c 100644 --- a/drivers/sound/Kconfig +++ b/drivers/sound/Kconfig @@ -40,6 +40,15 @@ config I2S_SAMSUNG option provides an implementation for sound_init() and sound_play().
+config SOUND_INTEL_HDA + bool "Intel HDA audio codec" + depends on SOUND + help + Most Intel chips have an HDA (High-definition audio) codec which can + be used by U-Boot to play simple beeps. This is also sometimes called + Azalia which was the development code-name. It requires setup + information in the device tree (see intel-hda.txt). + config SOUND_MAX98088 bool "Support Maxim max98088 audio codec" depends on I2S diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 170e06ad538..2e21a0d0674 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -15,3 +15,4 @@ obj-$(CONFIG_SOUND_WM8994) += wm8994.o obj-$(CONFIG_SOUND_MAX98088) += max98088.o maxim_codec.o obj-$(CONFIG_SOUND_MAX98090) += max98090.o maxim_codec.o obj-$(CONFIG_SOUND_MAX98095) += max98095.o maxim_codec.o +obj-$(CONFIG_SOUND_INTEL_HDA) += hda_codec.o diff --git a/drivers/sound/hda_codec.c b/drivers/sound/hda_codec.c new file mode 100644 index 00000000000..572ef693cc0 --- /dev/null +++ b/drivers/sound/hda_codec.c @@ -0,0 +1,556 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Implementation of per-board codec beeping + * Copyright (c) 2011 The Chromium OS Authors. + * Copyright 2018 Google LLC + */ + +#define LOG_CATEGORY UCLASS_SOUND + +#include <common.h> +#include <dm.h> +#include <hda_codec.h> +#include <pci.h> +#include <sound.h> +#include <asm/io.h> +#include <dt-bindings/sound/azalia.h> + +/** + * struct hda_regs - HDA registers + * + * https://wiki.osdev.org/Intel_High_Definition_Audio + * https://www.intel.com/content/www/us/en/standards/high-definition-audio-spec... + */ +struct hda_regs { + u16 gcap; + u8 vmin; + u8 vmaj; + u16 outpay; + u16 inpay; + u32 gctl; + u16 wakeen; + u16 statests; + u8 reserved[0x50]; + u32 cmd; /* 0x60 */ + u32 resp; + u32 icii; +}; + +enum { + HDA_ICII_BUSY = BIT(0), + HDA_ICII_VALID = BIT(1), + + /* Common node IDs */ + HDA_ROOT_NODE = 0x00, + + /* HDA verbs fields */ + HDA_VERB_NID_S = 20, + HDA_VERB_VERB_S = 8, + HDA_VERB_PARAM_S = 0, + + HDA_VERB_GET_PARAMS = 0xf00, + HDA_VERB_SET_BEEP = 0x70a, + + /* GET_PARAMS parameter IDs */ + GET_PARAMS_NODE_COUNT = 0x04, + GET_PARAMS_AUDIO_GROUP_CAPS = 0x08, + GET_PARAMS_AUDIO_WIDGET_CAPS = 0x09, + + /* Sub-node fields */ + NUM_SUB_NODES_S = 0, + NUM_SUB_NODES_M = 0xff << NUM_SUB_NODES_S, + FIRST_SUB_NODE_S = 16, + FIRST_SUB_NODE_M = 0xff << FIRST_SUB_NODE_S, + + /* Get Audio Function Group Capabilities fields */ + AUDIO_GROUP_CAPS_BEEP_GEN = 0x10000, + + /* Get Audio Widget Capabilities fields */ + AUDIO_WIDGET_TYPE_BEEP = 0x7, + AUDIO_WIDGET_TYPE_S = 20, + AUDIO_WIDGET_TYPE_M = 0xf << AUDIO_WIDGET_TYPE_S, + + BEEP_FREQ_BASE = 12000, +}; + +static inline uint hda_verb(uint nid, uint verb, uint param) +{ + return nid << HDA_VERB_NID_S | verb << HDA_VERB_VERB_S | + param << HDA_VERB_PARAM_S; +} + +int hda_wait_for_ready(struct hda_regs *regs) +{ + int timeout = 1000; /* Use a 1msec timeout */ + + while (timeout--) { + u32 reg32 = readl(®s->icii); + + if (!(reg32 & HDA_ICII_BUSY)) + return 0; + udelay(1); + } + + return -ETIMEDOUT; +} + +static int wait_for_response(struct hda_regs *regs, uint *response) +{ + int timeout = 1000; + u32 reg32; + + /* Send the verb to the codec */ + setbits_le32(®s->icii, HDA_ICII_BUSY | HDA_ICII_VALID); + + /* Use a 1msec timeout */ + while (timeout--) { + reg32 = readl(®s->icii); + if ((reg32 & (HDA_ICII_VALID | HDA_ICII_BUSY)) == + HDA_ICII_VALID) { + if (response) + *response = readl(®s->resp); + return 0; + } + udelay(1); + } + + return -ETIMEDOUT; +} + +int hda_wait_for_valid(struct hda_regs *regs) +{ + return wait_for_response(regs, NULL); +} + +static int set_bits(void *port, u32 mask, u32 val) +{ + u32 reg32; + int count; + + /* Write (val & mask) to port */ + clrsetbits_le32(port, mask, val); + + /* Wait for readback of register to match what was just written to it */ + count = 50; + do { + /* Wait 1ms based on BKDG wait time */ + mdelay(1); + reg32 = readl(port) & mask; + } while (reg32 != val && --count); + + /* Timeout occurred */ + if (!count) + return -ETIMEDOUT; + + return 0; +} + +int hda_codec_detect(struct hda_regs *regs) +{ + uint reg8; + + /* Set Bit 0 to 1 to exit reset state (BAR + 0x8)[0] */ + if (set_bits(®s->gctl, 1, 1)) + goto no_codec; + + /* Write back the value once reset bit is set */ + writew(readw(®s->gcap), ®s->gcap); + + /* Read in Codec location */ + reg8 = readb(®s->statests) & 0xf; + if (!reg8) + goto no_codec; + + return reg8; + +no_codec: + /* Codec Not found - put HDA back in reset */ + set_bits(®s->gctl, 1, 0); + log_debug("No codec\n"); + + return 0; +} + +static int find_verb_data(struct udevice *dev, uint id, ofnode *nodep) +{ + ofnode parent = dev_read_subnode(dev, "codecs"); + ofnode node; + u32 vendor_id, device_id; + + ofnode_for_each_subnode(node, parent) { + if (ofnode_read_u32(node, "vendor-id", &vendor_id) || + ofnode_read_u32(node, "device-id", &device_id)) { + log_debug("Cannot get IDs for '%s'\n", + ofnode_get_name(node)); + return -EINVAL; + } + if (id != (vendor_id << 16 | device_id)) { + log_debug("Skip codec node '%s' for %08x\n", + ofnode_get_name(node), id); + continue; + } + + log_debug("Found codec node '%s' for %08x\n", + ofnode_get_name(node), id); + *nodep = node; + return 0; + } + + return -ENOENT; +} + +static int send_verbs(ofnode node, const char *prop_name, struct hda_regs *regs) +{ + int ret, verb_size, i; + const u32 *verb; + + verb = ofnode_get_property(node, prop_name, &verb_size); + if (verb_size < 0) { + log_debug("No verb data\n"); + return -EINVAL; + } + log_debug("verb_size: %d\n", verb_size); + + for (i = 0; i < verb_size / sizeof(*verb); i++) { + ret = hda_wait_for_ready(regs); + if (ret) { + log_debug(" codec ready timeout\n"); + return ret; + } + + writel(fdt32_to_cpu(verb[i]), ®s->cmd); + + ret = hda_wait_for_valid(regs); + if (ret) { + log_debug(" codec valid timeout\n"); + return ret; + } + } + + return 0; +} + +static int codec_init(struct udevice *dev, struct hda_regs *regs, uint addr) +{ + ofnode node; + uint id; + int ret; + + log_debug("Initializing codec #%d\n", addr); + ret = hda_wait_for_ready(regs); + if (ret) { + log_debug(" codec not ready\n"); + return ret; + } + + /* Read the codec's vendor ID */ + writel(addr << AZALIA_CODEC_SHIFT | + AZALIA_OPCODE_READ_PARAM << AZALIA_VERB_SHIFT | + AZALIA_PARAM_VENDOR_ID, ®s->cmd); + ret = hda_wait_for_valid(regs); + if (ret) { + log_debug(" codec not valid\n"); + return ret; + } + + id = readl(®s->resp); + log_debug("codec vid/did: %08x\n", id); + ret = find_verb_data(dev, id, &node); + if (ret) { + log_debug("No verb (err=%d)\n", ret); + return ret; + } + ret = send_verbs(node, "verbs", regs); + if (ret) { + log_debug("failed to send verbs (err=%d)\n", ret); + return ret; + } + log_debug("verb loaded\n"); + + return 0; +} + +int hda_codecs_init(struct udevice *dev, struct hda_regs *regs, u32 codec_mask) +{ + int ret; + int i; + + for (i = 3; i >= 0; i--) { + if (codec_mask & (1 << i)) { + ret = codec_init(dev, regs, i); + if (ret) + return ret; + } + } + + ret = send_verbs(dev_ofnode(dev), "beep-verbs", regs); + if (ret) { + log_debug("failed to send beep verbs (err=%d)\n", ret); + return ret; + } + log_debug("beep verbs loaded\n"); + + return 0; +} + +/** + * exec_verb() - Write a verb to the codec + * + * @regs: HDA registers + * @val: Command to write + * @response: Set to response from codec + * @return 0 if OK, -ve on error + */ +static int exec_verb(struct hda_regs *regs, uint val, uint *response) +{ + int ret; + + ret = hda_wait_for_ready(regs); + if (ret) + return ret; + + writel(val, ®s->cmd); + + return wait_for_response(regs, response); +} + +/** + * get_subnode_info() - Get subnode information + * + * @regs: HDA registers + * @nid: Parent node ID to check + * @num_sub_nodesp: Returns number of subnodes + * @start_sub_node_nidp: Returns start subnode number + * @return 0 if OK, -ve on error + */ +static int get_subnode_info(struct hda_regs *regs, uint nid, + uint *num_sub_nodesp, uint *start_sub_node_nidp) +{ + uint response; + int ret; + + ret = exec_verb(regs, hda_verb(nid, HDA_VERB_GET_PARAMS, + GET_PARAMS_NODE_COUNT), + &response); + if (ret < 0) { + printf("Audio: Error reading sub-node info %d\n", nid); + return ret; + } + + *num_sub_nodesp = (response & NUM_SUB_NODES_M) >> NUM_SUB_NODES_S; + *start_sub_node_nidp = (response & FIRST_SUB_NODE_M) >> + FIRST_SUB_NODE_S; + + return 0; +} + +/** + * find_beep_node_in_group() - Finds the beeping node + * + * Searches the audio group for a node that supports beeping + * + * @regs: HDA registers + * @group_nid: Group node ID to check + * @return 0 if OK, -ve on error + */ +static uint find_beep_node_in_group(struct hda_regs *regs, uint group_nid) +{ + uint node_count = 0; + uint current_nid = 0; + uint response; + uint end_nid; + int ret; + + ret = get_subnode_info(regs, group_nid, &node_count, ¤t_nid); + if (ret < 0) + return 0; + + end_nid = current_nid + node_count; + while (current_nid < end_nid) { + ret = exec_verb(regs, + hda_verb(current_nid, HDA_VERB_GET_PARAMS, + GET_PARAMS_AUDIO_WIDGET_CAPS), + &response); + if (ret < 0) { + printf("Audio: Error reading widget caps\n"); + return 0; + } + + if ((response & AUDIO_WIDGET_TYPE_M) >> AUDIO_WIDGET_TYPE_S == + AUDIO_WIDGET_TYPE_BEEP) + return current_nid; + + current_nid++; + } + + return 0; /* no beep node found */ +} + +/** + * audio_group_has_beep_node() - Check if group has a beep node + * + * Checks if the given audio group contains a beep generator + * @regs: HDA registers + * @nid: Node ID to check + * @return 0 if OK, -ve on error + */ +static int audio_group_has_beep_node(struct hda_regs *regs, uint nid) +{ + uint response; + int ret; + + ret = exec_verb(regs, hda_verb(nid, HDA_VERB_GET_PARAMS, + GET_PARAMS_AUDIO_GROUP_CAPS), + &response); + if (ret < 0) { + printf("Audio: Error reading audio group caps %d\n", nid); + return 0; + } + + return !!(response & AUDIO_GROUP_CAPS_BEEP_GEN); +} + +/** + * get_hda_beep_nid() - Finds the node ID of the beep node + * + * Finds the nid of the beep node if it exists. Starts at the root node, for + * each sub-node checks if the group contains a beep node. If the group + * contains a beep node, polls each node in the group until it is found. + * + * If the device has a intel,beep-nid property, the value of that is used + * instead. + * + * @dev: Sound device + * @return Node ID >0 if found, -ve error code otherwise + */ +static int get_hda_beep_nid(struct udevice *dev) +{ + struct hda_codec_priv *priv = dev_get_priv(dev); + uint current_nid = 0; + uint node_count = 0; + uint end_nid; + int ret; + + /* If the field exists, use the beep nid set in the fdt */ + ret = dev_read_u32(dev, "intel,beep-nid", ¤t_nid); + if (!ret) + return current_nid; + + ret = get_subnode_info(priv->regs, HDA_ROOT_NODE, &node_count, + ¤t_nid); + if (ret < 0) + return ret; + + end_nid = current_nid + node_count; + while (current_nid < end_nid) { + if (audio_group_has_beep_node(priv->regs, current_nid)) + return find_beep_node_in_group(priv->regs, + current_nid); + current_nid++; + } + /* no beep node found */ + + return -ENOENT; +} + +/** + * set_beep_divisor() - Sets the beep divisor to set the pitch + * + * @priv: Device's private data + * @divider: Divider value (0 to disable the beep) + * @return 0 if OK, -ve on error + */ +static int set_beep_divisor(struct hda_codec_priv *priv, uint divider) +{ + return exec_verb(priv->regs, + hda_verb(priv->beep_nid, HDA_VERB_SET_BEEP, divider), + NULL); +} + +int hda_codec_init(struct udevice *dev) +{ + struct hda_codec_priv *priv = dev_get_priv(dev); + ulong base_addr; + + base_addr = dm_pci_read_bar32(dev, 0); + log_debug("base = %08lx\n", base_addr); + if (!base_addr) + return -EINVAL; + + priv->regs = (struct hda_regs *)base_addr; + + return 0; +} + +int hda_codec_finish_init(struct udevice *dev) +{ + struct hda_codec_priv *priv = dev_get_priv(dev); + int ret; + + ret = get_hda_beep_nid(dev); + if (ret <= 0) { + log_warning("Could not find beep NID (err=%d)\n", ret); + return ret ? ret : -ENOENT; + } + priv->beep_nid = ret; + + return 0; +} + +int hda_codec_start_beep(struct udevice *dev, int frequency_hz) +{ + struct hda_codec_priv *priv = dev_get_priv(dev); + uint divider_val; + + if (!priv->beep_nid) { + log_err("Failed to find a beep-capable node\n"); + return -ENOENT; + } + + if (!frequency_hz) + divider_val = 0; /* off */ + else if (frequency_hz > BEEP_FREQ_BASE) + divider_val = 1; + else if (frequency_hz < BEEP_FREQ_BASE / 0xff) + divider_val = 0xff; + else + divider_val = 0xff & (BEEP_FREQ_BASE / frequency_hz); + + return set_beep_divisor(priv, divider_val); +} + +int hda_codec_stop_beep(struct udevice *dev) +{ + struct hda_codec_priv *priv = dev_get_priv(dev); + + return set_beep_divisor(priv, 0); +} + +static const struct sound_ops hda_codec_ops = { + .setup = hda_codec_finish_init, + .start_beep = hda_codec_start_beep, + .stop_beep = hda_codec_stop_beep, +}; + +U_BOOT_DRIVER(hda_codec) = { + .name = "hda_codec", + .id = UCLASS_SOUND, + .ops = &hda_codec_ops, + .priv_auto_alloc_size = sizeof(struct hda_codec_priv), + .probe = hda_codec_init, +}; + +static struct pci_device_id hda_supported[] = { + { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_COUGARPOINT_HDA}, + { PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_PANTHERPOINT_HDA}, + { PCI_DEVICE(PCI_VENDOR_ID_INTEL, + PCI_DEVICE_ID_INTEL_WILDCATPOINT_HDA) }, + + /* + * Note this driver is not necessarily generic, but it attempts to + * support any codec in the hd-audio class + */ + { PCI_DEVICE_CLASS(PCI_CLASS_MULTIMEDIA_HD_AUDIO, 0xffffff) }, +}; + +U_BOOT_PCI_DEVICE(hda_codec, hda_supported); diff --git a/include/dt-bindings/sound/azalia.h b/include/dt-bindings/sound/azalia.h new file mode 100644 index 00000000000..10ace3ef563 --- /dev/null +++ b/include/dt-bindings/sound/azalia.h @@ -0,0 +1,44 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Intel HDA audio codec config. This is a mechanicm to configure codecs when + * using Intel HDA audio. + * + * Copyright 2018 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#ifndef __AZALIA_H +#define __AZALIA_H + +#define AZALIA_CODEC_SHIFT 28 +#define AZALIA_NID_SHIFT 20 +#define AZALIA_VERB_SHIFT 8 + +/* Supported opcodes */ +#define AZALIA_OPCODE_CONFIG_DEFAULT 0x71c +#define AZALIA_OPCODE_IMPL_ID 0x720 +#define AZALIA_OPCODE_READ_PARAM 0xf00 + +#define AZALIA_PARAM_VENDOR_ID 0 + +/* Generate the register value to write a particular byte of a 32-bit value */ +#define AZALIA_SET_BYTE(codec, nid, opcode, val, byte) \ + ((codec) << AZALIA_CODEC_SHIFT | \ + (nid) << AZALIA_NID_SHIFT | \ + ((opcode) + (byte)) << AZALIA_VERB_SHIFT | \ + (((val) >> ((byte) * 8)) & 0xff)) + +/* Generate the register value to write all bytes of a 32-bit value */ +#define AZALIA_WORD(codec, nid, opcode, val) \ + (AZALIA_SET_BYTE(codec, nid, opcode, val, 0) | \ + AZALIA_SET_BYTE(codec, nid, opcode, val, 1) | \ + AZALIA_SET_BYTE(codec, nid, opcode, val, 2) | \ + AZALIA_SET_BYTE(codec, nid, opcode, val, 3)) + +#define AZALIA_PIN_CFG(codec, nid, val) \ + AZALIA_WORD(codec, nid, AZALIA_OPCODE_CONFIG_DEFAULT, val) + +#define AZALIA_SUBVENDOR(codec, val) \ + AZALIA_WORD(codec, 1, AZALIA_OPCODE_IMPL_ID, val) + +#endif /* __AZALIA_H */ diff --git a/include/hda_codec.h b/include/hda_codec.h new file mode 100644 index 00000000000..56de571f0f7 --- /dev/null +++ b/include/hda_codec.h @@ -0,0 +1,103 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Support for Intel High-Definition Audio codec + * + * Copyright 2018 Google LLC + * + * Taken from coreboot file of the same name + */ + +#ifndef __HDA_CODEC_H_ +#define __HDA_CODEC_H_ + +struct hda_regs; + +/** + * struct hda_codec_priv - Private data required by the HDA codec + * + * @regs: HDA registers + * @beep_nid: Node ID of beep node (>0) + */ +struct hda_codec_priv { + struct hda_regs *regs; + uint beep_nid; +}; + +/** + * hda_wait_for_ready() - Wait for the codec to indicate it is ready + * + * @regs: HDA registers + * @return 0 if OK -ETIMEDOUT if codec did not respond in time + */ +int hda_wait_for_ready(struct hda_regs *regs); + +/** + * hda_wait_for_valid() - Wait for the codec to accept the last command + * + * @regs: HDA registers + * @return 0 if OK -ETIMEDOUT if codec did not respond in time + */ +int hda_wait_for_valid(struct hda_regs *regs); + +/** + * hda_codec_detect() - Detect which codecs are present + * + * @regs: HDA registers + * @return bit mask of active codecs (0 if none) + * @return 0 if OK, -ve on error + */ +int hda_codec_detect(struct hda_regs *regs); + +/** + * hda_codecs_init() - Init all codecs + * + * @dev: Sound device + * @regs: HDA registers + * @codec_mask: Mask of codecs to init (bits 3:0) + * @return 0 if OK, -ve on error + */ +int hda_codecs_init(struct udevice *dev, struct hda_regs *regs, u32 codec_mask); + +/** + * hda_codec_start_beep() - Start beeping + * + * This tells the sound hardware to start a beep. It will continue until stopped + * by sound_stop_beep(). + * + * @dev: Sound device + * @frequency_hz: Beep frequency in hertz + * @return if OK, -ve on error + */ +int hda_codec_start_beep(struct udevice *dev, int frequency_hz); + +/** + * hda_codec_stop_beep() - Stop beeping + * + * This tells the sound hardware to stop a previously started beep. + * + * @dev: Sound device + * @return if OK, -ve on error + */ +int hda_codec_stop_beep(struct udevice *dev); + +/** + * hda_codec_init() - Set up the HDA codec base address + * + * This should be called at the start of the probe() method. + * + * @dev: Sound device + * @return 0 if OK, -ve on error + */ +int hda_codec_init(struct udevice *dev); + +/** + * hda_codec_finish_init() - Finish setting up the HDA codec base address + * + * This should be called at the end of the probe() method. + * + * @dev: Sound device + * @return 0 if OK, -ve on error + */ +int hda_codec_finish_init(struct udevice *dev); + +#endif /* __HDA_CODEC_H_ */
Signed-off-by: Simon Glass sjg@chromium.org
Changes in v2:
When testing the sound system we don't need the hear the beeps. The testing works by checking the data that would be emitted. Add a device-tree property to silence the sound, and enable it for testing.
Changes in v2: - Move comment about silencing on error so that it is clearer
arch/sandbox/dts/test.dts | 1 + drivers/sound/sandbox.c | 25 ++++++++++++++++++++++--- 2 files changed, 23 insertions(+), 3 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index f9a86f2596f..e541d6da37e 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -389,6 +389,7 @@ i2s: i2s { compatible = "sandbox,i2s"; #sound-dai-cells = <1>; + sandbox,silent; /* Don't emit sounds while testing */ };
misc-test { diff --git a/drivers/sound/sandbox.c b/drivers/sound/sandbox.c index 600523160f0..363c687bafd 100644 --- a/drivers/sound/sandbox.c +++ b/drivers/sound/sandbox.c @@ -3,6 +3,8 @@ * Copyright (c) 2013 Google, Inc */
+#define LOG_CATEGORY UCLASS_SOUND + #include <common.h> #include <audio_codec.h> #include <dm.h> @@ -20,6 +22,7 @@ struct sandbox_codec_priv {
struct sandbox_i2s_priv { int sum; /* Use to sum the provided audio data */ + bool silent; /* Sound is silent, don't use SDL */ };
struct sandbox_sound_priv { @@ -101,12 +104,21 @@ static int sandbox_i2s_tx_data(struct udevice *dev, void *data, for (i = 0; i < data_size; i++) priv->sum += ((uint8_t *)data)[i];
- return sandbox_sdl_sound_play(data, data_size); + if (!priv->silent) { + int ret; + + ret = sandbox_sdl_sound_play(data, data_size); + if (ret) + return ret; + } + + return 0; }
static int sandbox_i2s_probe(struct udevice *dev) { struct i2s_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct sandbox_i2s_priv *priv = dev_get_priv(dev);
/* Use hard-coded values here */ uc_priv->rfs = 256; @@ -117,8 +129,15 @@ static int sandbox_i2s_probe(struct udevice *dev) uc_priv->channels = 2; uc_priv->id = 1;
- /* Ignore any error here - we'll just have no sound */ - sandbox_sdl_sound_init(uc_priv->samplingrate, uc_priv->channels); + priv->silent = dev_read_bool(dev, "sandbox,silent"); + + if (priv->silent) { + log_warning("Sound is silenced\n"); + } else if (sandbox_sdl_sound_init(uc_priv->samplingrate, + uc_priv->channels)) { + /* Ignore any error here - we'll just have no sound */ + priv->silent = true; + }
return 0; }
Changes in v2:
Add sound support for link, using the HDA codec implementation.
Changes in v2: - Add a note about undocumented IOMMU values - Add comments next to verbs in the DT mentioning the HDA spec - Fix capital letter in Ivybridge in Kconfig help - Fix use of C++ comments in two places - Rename sound driver to bd82x6x-hda - Use a more generic "intel,hd-audio" as the compatible string - User lower-case hex consistently in the DT
arch/x86/cpu/ivybridge/Kconfig | 1 + arch/x86/cpu/ivybridge/northbridge.c | 32 ++++ arch/x86/dts/chromebook_link.dts | 96 ++++++++++++ .../include/asm/arch-ivybridge/sandybridge.h | 3 + configs/chromebook_link_defconfig | 2 + drivers/sound/Kconfig | 10 ++ drivers/sound/Makefile | 1 + drivers/sound/ivybridge_sound.c | 137 ++++++++++++++++++ 8 files changed, 282 insertions(+) create mode 100644 drivers/sound/ivybridge_sound.c
diff --git a/arch/x86/cpu/ivybridge/Kconfig b/arch/x86/cpu/ivybridge/Kconfig index 5f0e60837ca..2f423937864 100644 --- a/arch/x86/cpu/ivybridge/Kconfig +++ b/arch/x86/cpu/ivybridge/Kconfig @@ -21,6 +21,7 @@ config NORTHBRIDGE_INTEL_IVYBRIDGE imply USB_EHCI_HCD imply USB_XHCI_HCD imply VIDEO_VESA + imply SOUND_IVYBRIDGE
if NORTHBRIDGE_INTEL_IVYBRIDGE
diff --git a/arch/x86/cpu/ivybridge/northbridge.c b/arch/x86/cpu/ivybridge/northbridge.c index 39bab7bdf34..a809b823b3b 100644 --- a/arch/x86/cpu/ivybridge/northbridge.c +++ b/arch/x86/cpu/ivybridge/northbridge.c @@ -177,6 +177,35 @@ static void sandybridge_setup_northbridge_bars(struct udevice *dev) dm_pci_write_config8(dev, PAM6, 0x33); }
+/** + * sandybridge_init_iommu() - Set up IOMMU so that azalia can be used + * + * It is not obvious where these values come from. They may be undocumented. + */ +static void sandybridge_init_iommu(struct udevice *dev) +{ + u32 capid0_a; + + dm_pci_read_config32(dev, 0xe4, &capid0_a); + if (capid0_a & (1 << 23)) { + log_debug("capid0_a not needed\n"); + return; + } + + /* setup BARs */ + writel(IOMMU_BASE1 >> 32, MCHBAR_REG(0x5404)); + writel(IOMMU_BASE1 | 1, MCHBAR_REG(0x5400)); + writel(IOMMU_BASE2 >> 32, MCHBAR_REG(0x5414)); + writel(IOMMU_BASE2 | 1, MCHBAR_REG(0x5410)); + + /* lock policies */ + writel(0x80000000, IOMMU_BASE1 + 0xff0); + + /* Enable azalia sound */ + writel(0x20000000, IOMMU_BASE2 + 0xff0); + writel(0xa0000000, IOMMU_BASE2 + 0xff0); +} + static int bd82x6x_northbridge_early_init(struct udevice *dev) { const int chipset_type = SANDYBRIDGE_MOBILE; @@ -197,6 +226,9 @@ static int bd82x6x_northbridge_early_init(struct udevice *dev)
sandybridge_setup_northbridge_bars(dev);
+ /* Setup IOMMU BARs */ + sandybridge_init_iommu(dev); + /* Device Enable */ dm_pci_write_config32(dev, DEVEN, DEVEN_HOST | DEVEN_IGD);
diff --git a/arch/x86/dts/chromebook_link.dts b/arch/x86/dts/chromebook_link.dts index f9f09797302..c5653feac72 100644 --- a/arch/x86/dts/chromebook_link.dts +++ b/arch/x86/dts/chromebook_link.dts @@ -1,6 +1,8 @@ /dts-v1/;
#include <dt-bindings/gpio/x86-gpio.h> +#include <dt-bindings/sound/azalia.h> +#include <pci_ids.h>
/include/ "skeleton.dtsi" /include/ "keyboard.dtsi" @@ -372,6 +374,32 @@ compatible = "ehci-pci"; };
+ hda@1b,0 { + reg = <0x0000d800 0 0 0 0>; + compatible = "intel,bd82x6x-hda"; + + /* These correspond to the Intel HDA specification */ + beep-verbs = < + 0x00170500 /* power up codec */ + 0x00270500 /* power up DAC */ + 0x00b70500 /* power up speaker */ + 0x00b70740 /* enable speaker out */ + 0x00b78d00 /* enable EAPD pin */ + 0x00b70c02 /* set EAPD pin */ + 0x0143b013>; /* beep volume */ + + codecs { + creative_codec: creative-ca0132 { + vendor-id = <PCI_VENDOR_ID_CREATIVE>; + device-id = <PCI_DEVICE_ID_CREATIVE_CA01322>; + }; + intel_hdmi: hdmi { + vendor-id = <PCI_VENDOR_ID_INTEL>; + device-id = <PCI_DEVICE_ID_INTEL_COUGARPOINT_HDMI>; + }; + }; + }; + usb_0: usb@1d,0 { reg = <0x0000e800 0 0 0 0>; compatible = "ehci-pci"; @@ -492,3 +520,71 @@ };
}; + +&creative_codec { + verbs = < + /** + * Malcolm Setup. These correspond to the Intel HDA + * specification. + */ + 0x01570d09 0x01570c23 0x01570a01 0x01570df0 + 0x01570efe 0x01570775 0x015707d3 0x01570709 + 0x01570753 0x015707d4 0x015707ef 0x01570775 + 0x015707d3 0x01570709 0x01570702 0x01570737 + 0x01570778 0x01553cce 0x015575c9 0x01553dce + 0x0155b7c9 0x01570de8 0x01570efe 0x01570702 + 0x01570768 0x01570762 0x01553ace 0x015546c9 + 0x01553bce 0x0155e8c9 0x01570d49 0x01570c88 + 0x01570d20 0x01570e19 0x01570700 0x01571a05 + 0x01571b29 0x01571a04 0x01571b29 0x01570a01 + + /* Pin Widget Verb Table */ + + /* NID 0x01, HDA Codec Subsystem ID Verb Table: 0x144dc0c2 */ + AZALIA_SUBVENDOR(0x0, 0x144dc0c2) + + /* + * Pin Complex (NID 0x0B) Port-G Analog Unknown + * Speaker at Int N/A + */ + AZALIA_PIN_CFG(0x0, 0x0b, 0x901700f0) + + /* Pin Complex (NID 0x0C) N/C */ + AZALIA_PIN_CFG(0x0, 0x0c, 0x70f000f0) + + /* Pin Complex (NID 0x0D) N/C */ + AZALIA_PIN_CFG(0x0, 0x0d, 0x70f000f0) + + /* Pin Complex (NID 0x0E) N/C */ + AZALIA_PIN_CFG(0x0, 0x0e, 0x70f000f0) + + /* Pin Complex (NID 0x0F) N/C */ + AZALIA_PIN_CFG(0x0, 0x0f, 0x70f000f0) + + /* Pin Complex (NID 0x10) Port-D 1/8 Black HP Out at Ext Left */ + AZALIA_PIN_CFG(0x0, 0x10, 0x032110f0) + + /* Pin Complex (NID 0x11) Port-B Click Mic */ + AZALIA_PIN_CFG(0x0, 0x11, 0x90a700f0) + + /* Pin Complex (NID 0x12) Port-C Combo Jack Mic or D-Mic */ + AZALIA_PIN_CFG(0x0, 0x12, 0x03a110f0) + + /* Pin Complex (NID 0x13) What you hear */ + AZALIA_PIN_CFG(0x0, 0x13, 0x90d600f0)>; +}; + +&intel_hdmi { + verbs = < + /* NID 0x01, HDA Codec Subsystem ID Verb Table: 0x80860101 */ + AZALIA_SUBVENDOR(0x3, 0x80860101) + + /* Pin Complex (NID 0x05) Digital Out at Int HDMI */ + AZALIA_PIN_CFG(0x3, 0x05, 0x18560010) + + /* Pin Complex (NID 0x06) Digital Out at Int HDMI */ + AZALIA_PIN_CFG(0x3, 0x06, 0x18560020) + + /* Pin Complex (NID 0x07) Digital Out at Int HDMI */ + AZALIA_PIN_CFG(0x3, 0x07, 0x18560030)>; +}; diff --git a/arch/x86/include/asm/arch-ivybridge/sandybridge.h b/arch/x86/include/asm/arch-ivybridge/sandybridge.h index a96c951c85e..a3a507f2b36 100644 --- a/arch/x86/include/asm/arch-ivybridge/sandybridge.h +++ b/arch/x86/include/asm/arch-ivybridge/sandybridge.h @@ -43,6 +43,9 @@ /* 4 KB per PCIe device */ #define DEFAULT_PCIEXBAR CONFIG_PCIE_ECAM_BASE
+#define IOMMU_BASE1 0xfed90000ULL +#define IOMMU_BASE2 0xfed91000ULL + /* Device 0:0.0 PCI configuration space (Host Bridge) */ #define EPBAR 0x40 #define MCHBAR 0x48 diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index c402568c17e..6058dfaf0f2 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -33,6 +33,7 @@ CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_CMD_SOUND=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y @@ -53,6 +54,7 @@ CONFIG_SYS_I2C_INTEL=y CONFIG_CROS_EC=y CONFIG_CROS_EC_LPC=y CONFIG_SYS_NS16550=y +CONFIG_SOUND=y CONFIG_SPI=y CONFIG_TPM_TIS_LPC=y CONFIG_USB_STORAGE=y diff --git a/drivers/sound/Kconfig b/drivers/sound/Kconfig index 0dca6ffe88c..4b893f035b0 100644 --- a/drivers/sound/Kconfig +++ b/drivers/sound/Kconfig @@ -49,6 +49,16 @@ config SOUND_INTEL_HDA Azalia which was the development code-name. It requires setup information in the device tree (see intel-hda.txt).
+config SOUND_IVYBRIDGE + bool "Intel Ivybridge sound support" + depends on SOUND + select SOUND_INTEL_HDA + help + Enable sound output on supported Intel Ivybridge-based boards. This + driver uses Intel's High-definition Audio (HDA) architecture, + sometimes called Azalia. The audio codec is detected using a + semi-automatic mechanism. + config SOUND_MAX98088 bool "Support Maxim max98088 audio codec" depends on I2S diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 2e21a0d0674..771c1165167 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -16,3 +16,4 @@ obj-$(CONFIG_SOUND_MAX98088) += max98088.o maxim_codec.o obj-$(CONFIG_SOUND_MAX98090) += max98090.o maxim_codec.o obj-$(CONFIG_SOUND_MAX98095) += max98095.o maxim_codec.o obj-$(CONFIG_SOUND_INTEL_HDA) += hda_codec.o +obj-$(CONFIG_SOUND_IVYBRIDGE) += ivybridge_sound.o diff --git a/drivers/sound/ivybridge_sound.c b/drivers/sound/ivybridge_sound.c new file mode 100644 index 00000000000..101046f9c20 --- /dev/null +++ b/drivers/sound/ivybridge_sound.c @@ -0,0 +1,137 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Intel HDA audio (Azalia) for ivybridge + * + * Originally from coreboot file bd82x6x/azalia.c + * + * Copyright (C) 2008 Advanced Micro Devices, Inc. + * Copyright (C) 2008-2009 coresystems GmbH + * Copyright (C) 2011 The ChromiumOS Authors. + * Copyright 2018 Google LLC + */ + +#define LOG_CATEGORY UCLASS_SOUND + +#include <common.h> +#include <dm.h> +#include <hda_codec.h> +#include <pch.h> +#include <sound.h> + +static int bd82x6x_azalia_probe(struct udevice *dev) +{ + struct pci_child_platdata *plat; + struct hda_codec_priv *priv; + struct udevice *pch; + u32 codec_mask; + int conf; + int ret; + + /* Only init after relocation */ + if (!(gd->flags & GD_FLG_RELOC)) + return 0; + + ret = hda_codec_init(dev); + if (ret) { + log_debug("Cannot set up HDA codec (err=%d)\n", ret); + return ret; + } + priv = dev_get_priv(dev); + + ret = uclass_first_device_err(UCLASS_PCH, &pch); + log_debug("PCH %p %s\n", pch, pch->name); + if (ret) + return ret; + + conf = pch_ioctl(pch, PCH_REQ_HDA_CONFIG, NULL, 0); + log_debug("conf = %x\n", conf); + if (conf >= 0) { + dm_pci_clrset_config32(dev, 0x120, 7 << 24 | 0xfe, + 1 << 24 | /* 2 << 24 for server */ + conf); + + dm_pci_clrset_config16(dev, 0x78, 0, 1 << 1); + } else { + log_debug("V1CTL disabled\n"); + } + dm_pci_clrset_config32(dev, 0x114, 0xfe, 0); + + /* Set VCi enable bit */ + dm_pci_clrset_config32(dev, 0x120, 0, 1U << 31); + + /* Enable HDMI codec */ + dm_pci_clrset_config32(dev, 0xc4, 0, 1 << 1); + dm_pci_clrset_config8(dev, 0x43, 0, 1 << 6); + + /* Additional programming steps */ + dm_pci_clrset_config32(dev, 0xc4, 0, 1 << 13); + dm_pci_clrset_config32(dev, 0xc4, 0, 1 << 10); + dm_pci_clrset_config32(dev, 0xd0, 1U << 31, 0); + + /* Additional step on Panther Point */ + plat = dev_get_parent_platdata(dev); + if (plat->device == PCI_DEVICE_ID_INTEL_PANTHERPOINT_HDA) + dm_pci_clrset_config32(dev, 0xc4, 0, 1 << 17); + + dm_pci_write_config8(dev, 0x3c, 0xa); /* unused? */ + + /* Audio Control: Select Azalia mode */ + dm_pci_clrset_config8(dev, 0x40, 0, 1); + dm_pci_clrset_config8(dev, 0x4d, 1 << 7, 0); /* Docking not supported */ + codec_mask = hda_codec_detect(priv->regs); + log_debug("codec_mask = %02x\n", codec_mask); + + if (codec_mask) { + ret = hda_codecs_init(dev, priv->regs, codec_mask); + if (ret) { + log_err("Codec init failed (err=%d)\n", ret); + return ret; + } + } + + /* Enable dynamic clock gating */ + dm_pci_clrset_config8(dev, 0x43, 7, BIT(2) | BIT(0)); + + ret = hda_codec_finish_init(dev); + if (ret) { + log_debug("Cannot set up HDA codec (err=%d)\n", ret); + return ret; + } + + return 0; +} + +static int bd82x6x_azalia_setup(struct udevice *dev) +{ + return 0; +} + +int bd82x6x_azalia_start_beep(struct udevice *dev, int frequency_hz) +{ + return hda_codec_start_beep(dev, frequency_hz); +} + +int bd82x6x_azalia_stop_beep(struct udevice *dev) +{ + return hda_codec_stop_beep(dev); +} + +static const struct sound_ops bd82x6x_azalia_ops = { + .setup = bd82x6x_azalia_setup, + .start_beep = bd82x6x_azalia_start_beep, + .stop_beep = bd82x6x_azalia_stop_beep, +}; + +static const struct udevice_id bd82x6x_azalia_ids[] = { + { .compatible = "intel,hd-audio" }, + { } +}; + +U_BOOT_DRIVER(bd82x6x_azalia_drv) = { + .name = "bd82x6x-hda", + .id = UCLASS_SOUND, + .of_match = bd82x6x_azalia_ids, + .probe = bd82x6x_azalia_probe, + .ops = &bd82x6x_azalia_ops, + .priv_auto_alloc_size = sizeof(struct hda_codec_priv), +};
Changes in v2:
Adjust the code to allow beeping at different frequencies, using a calculated value for timer 2.
Changes in v2: - Rename PPC_PORTB to SYSCTL_PORTB - Use PIT_TICK_RATE instead of creating a new define
arch/x86/include/asm/i8254.h | 18 ++++++++++++++++++ arch/x86/lib/i8254.c | 35 +++++++++++++++++++++++++++++++---- 2 files changed, 49 insertions(+), 4 deletions(-)
diff --git a/arch/x86/include/asm/i8254.h b/arch/x86/include/asm/i8254.h index 65c97614d3e..d769daf85dc 100644 --- a/arch/x86/include/asm/i8254.h +++ b/arch/x86/include/asm/i8254.h @@ -35,4 +35,22 @@ /* The clock frequency of the i8253/i8254 PIT */ #define PIT_TICK_RATE 1193182
+/** + * i8254_enable_beep() - Start a beep using the PCAT timer + * + * This starts beeping using the legacy i8254 timer. The beep may be silenced + * after a delay with i8254_disable_beep(). + * + * @frequency_hz: Frequency of beep in Hz + * @return 0 if OK, -EINVAL if frequency_hz is 0 + */ +int i8254_enable_beep(uint frequency_hz); + +/** + * i8254_disable_beep() - Disable the bepper + * + * This stops any existing beep + */ +void i8254_disable_beep(void); + #endif /* _ASMI386_I8954_H_ */ diff --git a/arch/x86/lib/i8254.c b/arch/x86/lib/i8254.c index 1f1012488cb..d0227954b16 100644 --- a/arch/x86/lib/i8254.c +++ b/arch/x86/lib/i8254.c @@ -8,8 +8,20 @@ #include <asm/io.h> #include <asm/i8254.h>
-#define TIMER1_VALUE 18 /* 15.6us */ -#define TIMER2_VALUE 0x0a8e /* 440Hz */ +#define TIMER1_VALUE 18 /* 15.6us */ +#define BEEP_FREQUENCY_HZ 440 +#define SYSCTL_PORTB 0x61 +#define PORTB_BEEP_ENABLE 0x3 + +static void i8254_set_beep_freq(uint frequency_hz) +{ + uint countdown; + + countdown = PIT_TICK_RATE / frequency_hz; + + outb(countdown & 0xff, PIT_BASE + PIT_T2); + outb((countdown >> 8) & 0xff, PIT_BASE + PIT_T2); +}
int i8254_init(void) { @@ -29,8 +41,23 @@ int i8254_init(void) */ outb(PIT_CMD_CTR2 | PIT_CMD_BOTH | PIT_CMD_MODE3, PIT_BASE + PIT_COMMAND); - outb(TIMER2_VALUE & 0xff, PIT_BASE + PIT_T2); - outb(TIMER2_VALUE >> 8, PIT_BASE + PIT_T2); + i8254_set_beep_freq(BEEP_FREQUENCY_HZ); + + return 0; +} + +int i8254_enable_beep(uint frequency_hz) +{ + if (!frequency_hz) + return -EINVAL; + + i8254_set_beep_freq(frequency_hz); + setio_8(SYSCTL_PORTB, PORTB_BEEP_ENABLE);
return 0; } + +void i8254_disable_beep(void) +{ + clrio_8(SYSCTL_PORTB, PORTB_BEEP_ENABLE); +}
Changes in v2:
Add a sound driver which can output simple beeps using this legacy timer.
Changes in v2: - Change the driver name to i8254_drv
drivers/sound/Kconfig | 12 ++++++++++++ drivers/sound/Makefile | 1 + drivers/sound/i8254_beep.c | 38 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 51 insertions(+) create mode 100644 drivers/sound/i8254_beep.c
diff --git a/drivers/sound/Kconfig b/drivers/sound/Kconfig index 4b893f035b0..c1847df07fa 100644 --- a/drivers/sound/Kconfig +++ b/drivers/sound/Kconfig @@ -40,6 +40,18 @@ config I2S_SAMSUNG option provides an implementation for sound_init() and sound_play().
+config SOUND_I8254 + bool "Intel i8254 timer / beeper" + depends on SOUND + help + This enables support for a beeper that uses the i8254 timer chip. + This can emit beeps at a fixed frequency. It is possible to control + the length of the beeps, by turning a beep on, waiting for a period + of time, then turning it off. + + This is quite an old feature, called PIT (Programmable Interval + Timer), but is nonetheless still available on modern x86 machines. + config SOUND_INTEL_HDA bool "Intel HDA audio codec" depends on SOUND diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 771c1165167..2a6fd7420c2 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -16,4 +16,5 @@ obj-$(CONFIG_SOUND_MAX98088) += max98088.o maxim_codec.o obj-$(CONFIG_SOUND_MAX98090) += max98090.o maxim_codec.o obj-$(CONFIG_SOUND_MAX98095) += max98095.o maxim_codec.o obj-$(CONFIG_SOUND_INTEL_HDA) += hda_codec.o +obj-$(CONFIG_SOUND_I8254) += i8254_beep.o obj-$(CONFIG_SOUND_IVYBRIDGE) += ivybridge_sound.o diff --git a/drivers/sound/i8254_beep.c b/drivers/sound/i8254_beep.c new file mode 100644 index 00000000000..5572dc4d265 --- /dev/null +++ b/drivers/sound/i8254_beep.c @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2018 Google LLC + */ + +#include <common.h> +#include <dm.h> +#include <sound.h> +#include <asm/i8254.h> + +int i8254_start_beep(struct udevice *dev, int frequency_hz) +{ + return i8254_enable_beep(frequency_hz); +} + +int i8254_stop_beep(struct udevice *dev) +{ + i8254_disable_beep(); + + return 0; +} + +static const struct sound_ops i8254_ops = { + .start_beep = i8254_start_beep, + .stop_beep = i8254_stop_beep, +}; + +static const struct udevice_id i8254_ids[] = { + { .compatible = "i8254,beeper" }, + { } +}; + +U_BOOT_DRIVER(i8254_drv) = { + .name = "i8254_drv", + .id = UCLASS_SOUND, + .of_match = i8254_ids, + .ops = &i8254_ops, +};
Changes in v2:
Use the i8254 sound driver to support creating simple beeps.
Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: None
configs/coreboot_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/coreboot_defconfig b/configs/coreboot_defconfig index ad0b35f2046..2795fe97ca2 100644 --- a/configs/coreboot_defconfig +++ b/configs/coreboot_defconfig @@ -23,6 +23,7 @@ CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_CMD_SOUND=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y @@ -35,4 +36,6 @@ CONFIG_DEFAULT_DEVICE_TREE="coreboot" CONFIG_REGMAP=y CONFIG_SYSCON=y # CONFIG_PCI_PNP is not set +CONFIG_SOUND=y +CONFIG_SOUND_I8254=y CONFIG_CONSOLE_SCROLL_LINES=5
The Application Digital Signal Processor is used for sound processing with broadwell. Add a driver to support this.
Changes in v2: - Drop useless 'set' comment
arch/x86/cpu/broadwell/Makefile | 1 + arch/x86/cpu/broadwell/adsp.c | 156 +++++++++++++++++++++ arch/x86/include/asm/arch-broadwell/adsp.h | 46 ++++++ arch/x86/include/asm/arch-broadwell/pch.h | 3 + arch/x86/include/asm/arch-broadwell/rcb.h | 2 + 5 files changed, 208 insertions(+) create mode 100644 arch/x86/cpu/broadwell/adsp.c create mode 100644 arch/x86/include/asm/arch-broadwell/adsp.h
diff --git a/arch/x86/cpu/broadwell/Makefile b/arch/x86/cpu/broadwell/Makefile index a032861e57c..d3785aabdf2 100644 --- a/arch/x86/cpu/broadwell/Makefile +++ b/arch/x86/cpu/broadwell/Makefile @@ -2,6 +2,7 @@ # # Copyright (c) 2016 Google, Inc
+obj-y += adsp.o obj-y += cpu.o obj-y += iobp.o obj-y += lpc.o diff --git a/arch/x86/cpu/broadwell/adsp.c b/arch/x86/cpu/broadwell/adsp.c new file mode 100644 index 00000000000..2ac8cea7c33 --- /dev/null +++ b/arch/x86/cpu/broadwell/adsp.c @@ -0,0 +1,156 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Support for Intel Application Digital Signal Processor + * + * Copyright 2019 Google LLC + * + * Modified from coreboot file of the same name + */ + +#define LOG_CATEGORY UCLASS_SYSCON + +#include <common.h> +#include <dm.h> +#include <pci.h> +#include <asm/io.h> +#include <asm/cpu.h> +#include <asm/intel_regs.h> +#include <asm/arch/adsp.h> +#include <asm/arch/pch.h> +#include <asm/arch/rcb.h> + +enum pci_type_t { + LYNX_POINT, + WILDCAT_POINT, +}; + +struct broadwell_adsp_priv { + bool adsp_d3_pg_enable; + bool adsp_sram_pg_enable; + bool sio_acpi_mode; +}; + +static int broadwell_adsp_probe(struct udevice *dev) +{ + struct broadwell_adsp_priv *priv = dev_get_priv(dev); + enum pci_type_t type; + u32 bar0, bar1; + u32 tmp32; + + /* Find BAR0 and BAR1 */ + bar0 = dm_pci_read_bar32(dev, 0); + if (!bar0) + return -EINVAL; + bar1 = dm_pci_read_bar32(dev, 1); + if (!bar1) + return -EINVAL; + + /* + * Set LTR value in DSP shim LTR control register to 3ms + * SNOOP_REQ[13]=1b SNOOP_SCALE[12:10]=100b (1ms) SNOOP_VAL[9:0]=3h + */ + type = dev_get_driver_data(dev); + tmp32 = type == WILDCAT_POINT ? ADSP_SHIM_BASE_WPT : ADSP_SHIM_BASE_LPT; + writel(ADSP_SHIM_LTRC_VALUE, bar0 + tmp32); + + /* Program VDRTCTL2 D19:F0:A8[31:0] = 0x00000fff */ + dm_pci_write_config32(dev, ADSP_PCI_VDRTCTL2, ADSP_VDRTCTL2_VALUE); + + /* Program ADSP IOBP VDLDAT1 to 0x040100 */ + pch_iobp_write(ADSP_IOBP_VDLDAT1, ADSP_VDLDAT1_VALUE); + + /* Set D3 Power Gating Enable in D19:F0:A0 based on PCH type */ + dm_pci_read_config32(dev, ADSP_PCI_VDRTCTL0, &tmp32); + if (type == WILDCAT_POINT) { + if (priv->adsp_d3_pg_enable) { + tmp32 &= ~ADSP_VDRTCTL0_D3PGD_WPT; + if (priv->adsp_sram_pg_enable) + tmp32 &= ~ADSP_VDRTCTL0_D3SRAMPGD_WPT; + else + tmp32 |= ADSP_VDRTCTL0_D3SRAMPGD_WPT; + } else { + tmp32 |= ADSP_VDRTCTL0_D3PGD_WPT; + } + } else { + if (priv->adsp_d3_pg_enable) { + tmp32 &= ~ADSP_VDRTCTL0_D3PGD_LPT; + if (priv->adsp_sram_pg_enable) + tmp32 &= ~ADSP_VDRTCTL0_D3SRAMPGD_LPT; + else + tmp32 |= ADSP_VDRTCTL0_D3SRAMPGD_LPT; + } else { + tmp32 |= ADSP_VDRTCTL0_D3PGD_LPT; + } + } + dm_pci_write_config32(dev, ADSP_PCI_VDRTCTL0, tmp32); + + /* Set PSF Snoop to SA, RCBA+0x3350[10]=1b */ + setbits_le32(RCB_REG(0x3350), 1 << 10); + + /* Set DSP IOBP PMCTL 0x1e0=0x3f */ + pch_iobp_write(ADSP_IOBP_PMCTL, ADSP_PMCTL_VALUE); + + if (priv->sio_acpi_mode) { + /* Configure for ACPI mode */ + log_info("ADSP: Enable ACPI Mode IRQ3\n"); + + /* Set interrupt de-assert/assert opcode override to IRQ3 */ + pch_iobp_write(ADSP_IOBP_VDLDAT2, ADSP_IOBP_ACPI_IRQ3); + + /* Enable IRQ3 in RCBA */ + setbits_le32(RCB_REG(ACPIIRQEN), ADSP_ACPI_IRQEN); + + /* Set ACPI Interrupt Enable Bit */ + pch_iobp_update(ADSP_IOBP_PCICFGCTL, ~ADSP_PCICFGCTL_SPCBAD, + ADSP_PCICFGCTL_ACPIIE); + + /* Put ADSP in D3hot */ + clrbits_le32(bar1 + PCH_PCS, PCH_PCS_PS_D3HOT); + } else { + log_info("ADSP: Enable PCI Mode IRQ23\n"); + + /* Configure for PCI mode */ + dm_pci_write_config32(dev, PCI_INTERRUPT_LINE, ADSP_PCI_IRQ); + + /* Clear ACPI Interrupt Enable Bit */ + pch_iobp_update(ADSP_IOBP_PCICFGCTL, + ~(ADSP_PCICFGCTL_SPCBAD | + ADSP_PCICFGCTL_ACPIIE), 0); + } + + return 0; +} + +static int broadwell_adsp_ofdata_to_platdata(struct udevice *dev) +{ + struct broadwell_adsp_priv *priv = dev_get_priv(dev); + + priv->adsp_d3_pg_enable = dev_read_bool(dev, "intel,adsp-d3-pg-enable"); + priv->adsp_sram_pg_enable = dev_read_bool(dev, + "intel,adsp-sram-pg-enable"); + priv->sio_acpi_mode = dev_read_bool(dev, "intel,sio-acpi-mode"); + + return 0; +} + +static const struct udevice_id broadwell_adsp_ids[] = { + { .compatible = "intel,wildcatpoint-adsp", .data = WILDCAT_POINT }, + { } +}; + +U_BOOT_DRIVER(broadwell_adsp_drv) = { + .name = "adsp", + .id = UCLASS_SYSCON, + .ofdata_to_platdata = broadwell_adsp_ofdata_to_platdata, + .of_match = broadwell_adsp_ids, + .bind = dm_scan_fdt_dev, + .probe = broadwell_adsp_probe, +}; + +static struct pci_device_id broadwell_adsp_supported[] = { + { PCI_DEVICE(PCI_VENDOR_ID_INTEL, + PCI_DEVICE_ID_INTEL_WILDCATPOINT_ADSP) }, + { }, +}; + +U_BOOT_PCI_DEVICE(broadwell_adsp_drv, broadwell_adsp_supported); diff --git a/arch/x86/include/asm/arch-broadwell/adsp.h b/arch/x86/include/asm/arch-broadwell/adsp.h new file mode 100644 index 00000000000..eb825ce1c06 --- /dev/null +++ b/arch/x86/include/asm/arch-broadwell/adsp.h @@ -0,0 +1,46 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Support for Intel Application Digital Signal Processor + * + * Copyright 2019 Google LLC + * + * Modified from coreboot file of the same name + */ + +#ifndef __ASM_ARCH_BROADWELL_ADSP_H +#define __ASM_ARCH_BROADWELL_ADSP_H + +#define ADSP_PCI_IRQ 23 +#define ADSP_ACPI_IRQ 3 +#define ADSP_ACPI_IRQEN BIT(3) + +#define ADSP_SHIM_BASE_LPT 0xe7000 +#define ADSP_SHIM_BASE_WPT 0xfb000 +#define ADSP_SHIM_LTRC 0xe0 +#define ADSP_SHIM_LTRC_VALUE 0x3003 +#define ADSP_SHIM_IMC 0x28 +#define ADSP_SHIM_IPCD 0x40 + +#define ADSP_PCI_VDRTCTL0 0xa0 +#define ADSP_VDRTCTL0_D3PGD_LPT BIT(1) +#define ADSP_VDRTCTL0_D3PGD_WPT BIT(0) +#define ADSP_VDRTCTL0_D3SRAMPGD_LPT BIT(2) +#define ADSP_VDRTCTL0_D3SRAMPGD_WPT BIT(1) +#define ADSP_PCI_VDRTCTL1 0xa4 +#define ADSP_PCI_VDRTCTL2 0xa8 +#define ADSP_VDRTCTL2_VALUE 0x00000fff + +#define ADSP_IOBP_VDLDAT1 0xd7000624 +#define ADSP_VDLDAT1_VALUE 0x00040100 +#define ADSP_IOBP_VDLDAT2 0xd7000628 +#define ADSP_IOBP_ACPI_IRQ3 0xd9d8 +#define ADSP_IOBP_ACPI_IRQ3I 0xd8d9 +#define ADSP_IOBP_ACPI_IRQ4 0xdbda +#define ADSP_IOBP_PMCTL 0xd70001e0 +#define ADSP_PMCTL_VALUE 0x3f +#define ADSP_IOBP_PCICFGCTL 0xd7000500 +#define ADSP_PCICFGCTL_PCICD BIT(0) +#define ADSP_PCICFGCTL_ACPIIE BIT(1) +#define ADSP_PCICFGCTL_SPCBAD BIT(7) + +#endif /* __ASM_ARCH_BROADWELL_ADSP_H */ diff --git a/arch/x86/include/asm/arch-broadwell/pch.h b/arch/x86/include/asm/arch-broadwell/pch.h index 23ccd684842..23153a040fa 100644 --- a/arch/x86/include/asm/arch-broadwell/pch.h +++ b/arch/x86/include/asm/arch-broadwell/pch.h @@ -109,6 +109,9 @@ #define SATA_DTLE_EDGE_SHIFT 16
/* Power Management */ +#define PCH_PCS 0x84 +#define PCH_PCS_PS_D3HOT 3 + #define GEN_PMCON_1 0xa0 #define SMI_LOCK (1 << 4) #define GEN_PMCON_2 0xa2 diff --git a/arch/x86/include/asm/arch-broadwell/rcb.h b/arch/x86/include/asm/arch-broadwell/rcb.h index e7340c1e5a6..b7ce8746c85 100644 --- a/arch/x86/include/asm/arch-broadwell/rcb.h +++ b/arch/x86/include/asm/arch-broadwell/rcb.h @@ -6,6 +6,8 @@ #ifndef __asm_arch_rcba_h #define __asm_arch_rcba_h
+#define ACPIIRQEN 0x31e0 /* 32bit */ + #define PMSYNC_CONFIG 0x33c4 /* 32bit */ #define PMSYNC_CONFIG2 0x33cc /* 32bit */
Changes in v2:
At present the pinctrl probes the PCH but since it only uses it to obtain a PCI address, this is no necessary. Avoiding this fixes one of the two co-dependent loops in broadwell.
This driver really should be a proper pinctrl driver, but for now it remains a syscon device.
Changes in v2: None
arch/x86/cpu/broadwell/pinctrl_broadwell.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/x86/cpu/broadwell/pinctrl_broadwell.c b/arch/x86/cpu/broadwell/pinctrl_broadwell.c index 914ecfb3144..aa83abbf855 100644 --- a/arch/x86/cpu/broadwell/pinctrl_broadwell.c +++ b/arch/x86/cpu/broadwell/pinctrl_broadwell.c @@ -16,6 +16,7 @@ #include <asm/arch/gpio.h> #include <dt-bindings/gpio/x86-gpio.h> #include <dm/pinctrl.h> +#include <dm/uclass-internal.h>
@@ -214,7 +215,7 @@ static int broadwell_pinctrl_probe(struct udevice *dev) u32 gpiobase; int ret;
- ret = uclass_first_device(UCLASS_PCH, &pch); + ret = uclass_find_first_device(UCLASS_PCH, &pch); if (ret) return ret; if (!pch)
Add support for initing the I2C device and ADSP on broadwell. These are needed for sound to work.
Changes in v2: None
arch/x86/cpu/broadwell/pch.c | 110 ++++++++++++++++++ .../x86/include/asm/arch-broadwell/serialio.h | 82 +++++++++++++ 2 files changed, 192 insertions(+) create mode 100644 arch/x86/include/asm/arch-broadwell/serialio.h
diff --git a/arch/x86/cpu/broadwell/pch.c b/arch/x86/cpu/broadwell/pch.c index 82506ba35e3..73d3d3b5154 100644 --- a/arch/x86/cpu/broadwell/pch.c +++ b/arch/x86/cpu/broadwell/pch.c @@ -20,7 +20,9 @@ #include <asm/arch/pch.h> #include <asm/arch/pm.h> #include <asm/arch/rcb.h> +#include <asm/arch/serialio.h> #include <asm/arch/spi.h> +#include <dm/uclass-internal.h>
@@ -456,6 +458,111 @@ static void systemagent_init(void) cpu_set_power_limits(28); }
+/* Enable LTR Auto Mode for D21:F1-F6 */ +static void serialio_d21_ltr(u32 bar0) +{ + /* 1. Program BAR0 + 808h[2] = 0b */ + clrbits_le32(bar0 + SIO_REG_PPR_GEN, SIO_REG_PPR_GEN_LTR_MODE_MASK); + + /* 2. Program BAR0 + 804h[1:0] = 00b */ + clrbits_le32(bar0 + SIO_REG_PPR_RST, SIO_REG_PPR_RST_ASSERT); + + /* 3. Program BAR0 + 804h[1:0] = 11b */ + setbits_le32(bar0 + SIO_REG_PPR_RST, SIO_REG_PPR_RST_ASSERT); + + /* 4. Program BAR0 + 814h[31:0] = 00000000h */ + writel(0, bar0 + SIO_REG_AUTO_LTR); +} + +/* Select I2C voltage of 1.8V or 3.3V */ +static void serialio_i2c_voltage_sel(u32 bar0, uint voltage) +{ + clrsetbits_le32(bar0 + SIO_REG_PPR_GEN, SIO_REG_PPR_GEN_VOLTAGE_MASK, + SIO_REG_PPR_GEN_VOLTAGE(voltage)); +} + +/* Put Serial IO D21:F0-F6 device into desired mode */ +static void serialio_d21_mode(int sio_index, int int_pin, bool acpi_mode) +{ + u32 portctrl = SIO_IOBP_PORTCTRL_PM_CAP_PRSNT; + + /* Snoop select 1 */ + portctrl |= SIO_IOBP_PORTCTRL_SNOOP_SELECT(1); + + /* Set interrupt pin */ + portctrl |= SIO_IOBP_PORTCTRL_INT_PIN(int_pin); + + if (acpi_mode) { + /* Enable ACPI interrupt mode */ + portctrl |= SIO_IOBP_PORTCTRL_ACPI_IRQ_EN; + } + + pch_iobp_update(SIO_IOBP_PORTCTRLX(sio_index), 0, portctrl); +} + +/* Init sequence to be run once, done as part of D21:F0 (SDMA) init */ +static void serialio_init_once(bool acpi_mode) +{ + if (acpi_mode) { + /* Enable ACPI IRQ for IRQ13, IRQ7, IRQ6, IRQ5 in RCBA */ + setbits_le32(RCB_REG(ACPIIRQEN), + 1 << 13 | 1 << 7 | 1 << 6 | 1 << 5); + } + + /* Program IOBP CB000154h[12,9:8,4:0] = 1001100011111b */ + pch_iobp_update(SIO_IOBP_GPIODF, ~0x0000131f, 0x0000131f); + + /* Program IOBP CB000180h[5:0] = 111111b (undefined register) */ + pch_iobp_update(0xcb000180, ~0x0000003f, 0x0000003f); +} + +/** + * pch_serialio_init() - set up serial I/O devices + * + * @return 0 if OK, -ve on error + */ +static int pch_serialio_init(void) +{ + struct udevice *dev, *hda; + bool acpi_mode = true; + u32 bar0, bar1; + int ret; + + ret = uclass_find_first_device(UCLASS_I2C, &dev); + if (ret) + return ret; + bar0 = dm_pci_read_bar32(dev, 0); + if (!bar0) + return -EINVAL; + bar1 = dm_pci_read_bar32(dev, 1); + if (!bar1) + return -EINVAL; + + serialio_init_once(acpi_mode); + serialio_d21_mode(SIO_ID_SDMA, SIO_PIN_INTB, acpi_mode); + + serialio_d21_ltr(bar0); + serialio_i2c_voltage_sel(bar0, 1); /* Select 1.8V always */ + serialio_d21_mode(SIO_ID_I2C0, SIO_PIN_INTC, acpi_mode); + setbits_le32(bar1 + PCH_PCS, PCH_PCS_PS_D3HOT); + + clrbits_le32(bar1 + PCH_PCS, PCH_PCS_PS_D3HOT); + + setbits_le32(bar0 + SIO_REG_PPR_CLOCK, SIO_REG_PPR_CLOCK_EN); + + /* Manually find the High-definition audio, to turn it off */ + ret = dm_pci_bus_find_bdf(PCI_BDF(0, 0x1b, 0), &hda); + if (ret) + return -ENOENT; + dm_pci_clrset_config8(hda, 0x43, 0, 0x6f); + + /* Route I/O buffers to ADSP function */ + dm_pci_clrset_config8(hda, 0x42, 0, 1 << 7 | 1 << 6); + log_debug("HDA disabled, I/O buffers routed to ADSP\n"); + + return 0; +} + static int broadwell_pch_init(struct udevice *dev) { int ret; @@ -482,6 +589,9 @@ static int broadwell_pch_init(struct udevice *dev) return ret; pch_pm_init(dev); pch_cg_init(dev); + ret = pch_serialio_init(); + if (ret) + return ret; systemagent_init();
return 0; diff --git a/arch/x86/include/asm/arch-broadwell/serialio.h b/arch/x86/include/asm/arch-broadwell/serialio.h new file mode 100644 index 00000000000..5e98eaf53fd --- /dev/null +++ b/arch/x86/include/asm/arch-broadwell/serialio.h @@ -0,0 +1,82 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Serial IO defintiions (taken from coreboot file of same name) + * + * Copyright 2019 Google LLC + */ + +#ifndef __ARCH_BROADWELL_SERIALIO_H_ +#define __ARCH_BROADWELL_SERIALIO_H_ + +/* Serial IO IOBP Registers */ +#define SIO_IOBP_PORTCTRL0 0xcb000000 /* SDIO D23:F0 */ +#define SIO_IOBP_PORTCTRL0_ACPI_IRQ_EN BIT(5) +#define SIO_IOBP_PORTCTRL0_PCI_CONF_DIS BIT(4) +#define SIO_IOBP_PORTCTRL1 0xcb000014 /* SDIO D23:F0 */ +#define SIO_IOBP_PORTCTRL1_SNOOP_SELECT(x) (((x) & 3) << 13) +#define SIO_IOBP_GPIODF 0xcb000154 +#define SIO_IOBP_GPIODF_SDIO_IDLE_DET_EN BIT(4) +#define SIO_IOBP_GPIODF_DMA_IDLE_DET_EN BIT(3) +#define SIO_IOBP_GPIODF_UART_IDLE_DET_EN BIT(2) +#define SIO_IOBP_GPIODF_I2C_IDLE_DET_EN BIT(1) +#define SIO_IOBP_GPIODF_SPI_IDLE_DET_EN BIT(0) +#define SIO_IOBP_GPIODF_UART0_BYTE_ACCESS BIT(10) +#define SIO_IOBP_GPIODF_UART1_BYTE_ACCESS BIT(11) +#define SIO_IOBP_PORTCTRL2 0xcb000240 /* DMA D21:F0 */ +#define SIO_IOBP_PORTCTRL3 0xcb000248 /* I2C0 D21:F1 */ +#define SIO_IOBP_PORTCTRL4 0xcb000250 /* I2C1 D21:F2 */ +#define SIO_IOBP_PORTCTRL5 0xcb000258 /* SPI0 D21:F3 */ +#define SIO_IOBP_PORTCTRL6 0xcb000260 /* SPI1 D21:F4 */ +#define SIO_IOBP_PORTCTRL7 0xcb000268 /* UART0 D21:F5 */ +#define SIO_IOBP_PORTCTRL8 0xcb000270 /* UART1 D21:F6 */ +#define SIO_IOBP_PORTCTRLX(x) (0xcb000240 + ((x) * 8)) +/* PORTCTRL 2-8 have the same layout */ +#define SIO_IOBP_PORTCTRL_ACPI_IRQ_EN BIT(21) +#define SIO_IOBP_PORTCTRL_PCI_CONF_DIS BIT(20) +#define SIO_IOBP_PORTCTRL_SNOOP_SELECT(x) (((x) & 3) << 18) +#define SIO_IOBP_PORTCTRL_INT_PIN(x) (((x) & 0xf) << 2) +#define SIO_IOBP_PORTCTRL_PM_CAP_PRSNT BIT(1) +#define SIO_IOBP_FUNCDIS0 0xce00aa07 /* DMA D21:F0 */ +#define SIO_IOBP_FUNCDIS1 0xce00aa47 /* I2C0 D21:F1 */ +#define SIO_IOBP_FUNCDIS2 0xce00aa87 /* I2C1 D21:F2 */ +#define SIO_IOBP_FUNCDIS3 0xce00aac7 /* SPI0 D21:F3 */ +#define SIO_IOBP_FUNCDIS4 0xce00ab07 /* SPI1 D21:F4 */ +#define SIO_IOBP_FUNCDIS5 0xce00ab47 /* UART0 D21:F5 */ +#define SIO_IOBP_FUNCDIS6 0xce00ab87 /* UART1 D21:F6 */ +#define SIO_IOBP_FUNCDIS7 0xce00ae07 /* SDIO D23:F0 */ +#define SIO_IOBP_FUNCDIS_DIS BIT(8) + +/* Serial IO Devices */ +#define SIO_ID_SDMA 0 /* D21:F0 */ +#define SIO_ID_I2C0 1 /* D21:F1 */ +#define SIO_ID_I2C1 2 /* D21:F2 */ +#define SIO_ID_SPI0 3 /* D21:F3 */ +#define SIO_ID_SPI1 4 /* D21:F4 */ +#define SIO_ID_UART0 5 /* D21:F5 */ +#define SIO_ID_UART1 6 /* D21:F6 */ +#define SIO_ID_SDIO 7 /* D23:F0 */ + +#define SIO_REG_PPR_CLOCK 0x800 +#define SIO_REG_PPR_CLOCK_EN BIT(0) +#define SIO_REG_PPR_CLOCK_UPDATE BIT(31) +#define SIO_REG_PPR_CLOCK_M_DIV 0x25a +#define SIO_REG_PPR_CLOCK_N_DIV 0x7fff +#define SIO_REG_PPR_RST 0x804 +#define SIO_REG_PPR_RST_ASSERT 0x3 +#define SIO_REG_PPR_GEN 0x808 +#define SIO_REG_PPR_GEN_LTR_MODE_MASK BIT(2) +#define SIO_REG_PPR_GEN_VOLTAGE_MASK BIT(3) +#define SIO_REG_PPR_GEN_VOLTAGE(x) ((x & 1) << 3) +#define SIO_REG_AUTO_LTR 0x814 + +#define SIO_REG_SDIO_PPR_GEN 0x1008 +#define SIO_REG_SDIO_PPR_SW_LTR 0x1010 +#define SIO_REG_SDIO_PPR_CMD12 0x3c +#define SIO_REG_SDIO_PPR_CMD12_B30 BIT(30) + +#define SIO_PIN_INTA 1 /* IRQ5 in ACPI mode */ +#define SIO_PIN_INTB 2 /* IRQ6 in ACPI mode */ +#define SIO_PIN_INTC 3 /* IRQ7 in ACPI mode */ +#define SIO_PIN_INTD 4 /* IRQ13 in ACPI mode */ + +#endif /* __ARCH_BROADWELL_SERIALIO_H_ */
I2S is used to send digital audio data to an audio codec. Add support for this on broadwell.
Changes in v2: None
drivers/sound/Makefile | 1 + drivers/sound/broadwell_i2s.c | 306 ++++++++++++++++++++++++++++++++++ drivers/sound/broadwell_i2s.h | 301 +++++++++++++++++++++++++++++++++ 3 files changed, 608 insertions(+) create mode 100644 drivers/sound/broadwell_i2s.c create mode 100644 drivers/sound/broadwell_i2s.h
diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 2a6fd7420c2..07b590156c9 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -17,4 +17,5 @@ obj-$(CONFIG_SOUND_MAX98090) += max98090.o maxim_codec.o obj-$(CONFIG_SOUND_MAX98095) += max98095.o maxim_codec.o obj-$(CONFIG_SOUND_INTEL_HDA) += hda_codec.o obj-$(CONFIG_SOUND_I8254) += i8254_beep.o +obj-$(CONFIG_INTEL_BROADWELL) += broadwell_i2s.o obj-$(CONFIG_SOUND_IVYBRIDGE) += ivybridge_sound.o diff --git a/drivers/sound/broadwell_i2s.c b/drivers/sound/broadwell_i2s.c new file mode 100644 index 00000000000..998792b2399 --- /dev/null +++ b/drivers/sound/broadwell_i2s.c @@ -0,0 +1,306 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Intel Broadwell I2S driver + * + * Copyright 2019 Google LLC + * + * Modified from dc i2s/broadwell/broadwell.c + */ + +#define LOG_CATEGORY UCLASS_I2S + +#include <common.h> +#include <dm.h> +#include <i2s.h> +#include <asm/io.h> +#include "broadwell_i2s.h" + +enum { + BDW_SHIM_START_ADDRESS = 0xfb000, + BDW_SSP0_START_ADDRESS = 0xfc000, + BDW_SSP1_START_ADDRESS = 0xfd000, +}; + +struct broadwell_i2s_priv { + enum frame_sync_rel_timing_t rel_timing; + enum frame_sync_pol_t sfrm_polarity; + enum end_transfer_state_t end_transfer_state; + enum clock_mode_t sclk_mode; + uint sclk_dummy_stop; /* 0-31 */ + uint sclk_frame_width; /* 1-38 */ + struct i2s_shim_regs *shim; + struct broadwell_i2s_regs *regs; +}; + +static void init_shim_csr(struct broadwell_i2s_priv *priv) +{ + /* + * Select SSP clock + * Turn off low power clock + * Set PIO mode + * Stall DSP core + */ + clrsetbits_le32(&priv->shim->csr, + SHIM_CS_S0IOCS | SHIM_CS_LPCS | SHIM_CS_DCS_MASK, + SHIM_CS_S1IOCS | SHIM_CS_SBCS_SSP1_24MHZ | + SHIM_CS_SBCS_SSP0_24MHZ | SHIM_CS_SDPM_PIO_SSP1 | + SHIM_CS_SDPM_PIO_SSP0 | SHIM_CS_STALL | + SHIM_CS_DCS_DSP32_AF32); +} + +static void init_shim_clkctl(struct i2s_uc_priv *uc_priv, + struct broadwell_i2s_priv *priv) +{ + u32 clkctl = readl(&priv->shim->clkctl); + + /* Set 24Mhz mclk, prevent local clock gating, enable SSP0 clock */ + clkctl &= SHIM_CLKCTL_RESERVED; + clkctl |= SHIM_CLKCTL_MCLK_24MHZ | SHIM_CLKCTL_DCPLCG; + + /* Enable requested SSP interface */ + if (uc_priv->id) + clkctl |= SHIM_CLKCTL_SCOE_SSP1 | SHIM_CLKCTL_SFLCGB_SSP1_CGD; + else + clkctl |= SHIM_CLKCTL_SCOE_SSP0 | SHIM_CLKCTL_SFLCGB_SSP0_CGD; + + writel(clkctl, &priv->shim->clkctl); +} + +static void init_sscr0(struct i2s_uc_priv *uc_priv, + struct broadwell_i2s_priv *priv) +{ + u32 sscr0; + uint scale; + + /* Set data size based on BPS */ + if (uc_priv->bitspersample > 16) + sscr0 = (uc_priv->bitspersample - 16 - 1) << SSP_SSC0_DSS_SHIFT + | SSP_SSC0_EDSS; + else + sscr0 = (uc_priv->bitspersample - 1) << SSP_SSC0_DSS_SHIFT; + + /* Set network mode, Stereo PSP frame format */ + sscr0 |= SSP_SSC0_MODE_NETWORK | + SSP_SSC0_FRDC_STEREO | + SSP_SSC0_FRF_PSP | + SSP_SSC0_TIM | + SSP_SSC0_RIM | + SSP_SSC0_ECS_PCH | + SSP_SSC0_NCS_PCH | + SSP_SSC0_ACS_PCH; + + /* Scale 24MHz MCLK */ + scale = uc_priv->audio_pll_clk / uc_priv->samplingrate / uc_priv->bfs; + sscr0 |= scale << SSP_SSC0_SCR_SHIFT; + + writel(sscr0, &priv->regs->sscr0); +} + +static void init_sscr1(struct broadwell_i2s_priv *priv) +{ + u32 sscr1 = readl(&priv->regs->sscr1); + + sscr1 &= SSP_SSC1_RESERVED; + + /* Set as I2S master */ + sscr1 |= SSP_SSC1_SCLKDIR_MASTER | SSP_SSC1_SCLKDIR_MASTER; + + /* Enable TXD tristate behavior for PCH */ + sscr1 |= SSP_SSC1_TTELP | SSP_SSC1_TTE; + + /* Disable DMA Tx/Rx service request */ + sscr1 |= SSP_SSC1_TSRE | SSP_SSC1_RSRE; + + /* Clock on during transfer */ + sscr1 |= SSP_SSC1_SCFR; + + /* Set FIFO thresholds */ + sscr1 |= SSP_FIFO_SIZE << SSP_SSC1_RFT_SHIFT; + sscr1 |= SSP_FIFO_SIZE << SSP_SSC1_TFT_SHIFT; + + /* Disable interrupts */ + sscr1 &= ~(SSP_SSC1_EBCEI | SSP_SSC1_TINTE | SSP_SSC1_PINTE); + sscr1 &= ~(SSP_SSC1_LBM | SSP_SSC1_RWOT); + + writel(sscr1, &priv->regs->sscr1); +} + +static void init_sspsp(struct broadwell_i2s_priv *priv) +{ + u32 sspsp = readl(&priv->regs->sspsp); + + sspsp &= SSP_PSP_RESERVED; + sspsp |= priv->sclk_mode << SSP_PSP_SCMODE_SHIFT; + sspsp |= (priv->sclk_dummy_stop << SSP_PSP_DMYSTOP_SHIFT) & + SSP_PSP_DMYSTOP_MASK; + sspsp |= (priv->sclk_dummy_stop >> 2 << SSP_PSP_EDYMSTOP_SHIFT) & + SSP_PSP_EDMYSTOP_MASK; + sspsp |= priv->sclk_frame_width << SSP_PSP_SFRMWDTH_SHIFT; + + /* Frame Sync Relative Timing */ + if (priv->rel_timing == NEXT_FRMS_AFTER_END_OF_T4) + sspsp |= SSP_PSP_FSRT; + else + sspsp &= ~SSP_PSP_FSRT; + + /* Serial Frame Polarity */ + if (priv->sfrm_polarity == SSP_FRMS_ACTIVE_HIGH) + sspsp |= SSP_PSP_SFRMP; + else + sspsp &= ~SSP_PSP_SFRMP; + + /* End Data Transfer State */ + if (priv->end_transfer_state == SSP_END_TRANSFER_STATE_LOW) + sspsp &= ~SSP_PSP_ETDS; + else + sspsp |= SSP_PSP_ETDS; + + writel(sspsp, &priv->regs->sspsp); +} + +static void init_ssp_time_slot(struct broadwell_i2s_priv *priv) +{ + writel(3, &priv->regs->sstsa); + writel(3, &priv->regs->ssrsa); +} + +static int bdw_i2s_init(struct udevice *dev) +{ + struct i2s_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct broadwell_i2s_priv *priv = dev_get_priv(dev); + + init_shim_csr(priv); + init_shim_clkctl(uc_priv, priv); + init_sscr0(uc_priv, priv); + init_sscr1(priv); + init_sspsp(priv); + init_ssp_time_slot(priv); + + return 0; +} + +static void bdw_i2s_enable(struct broadwell_i2s_priv *priv) +{ + setbits_le32(&priv->regs->sscr0, SSP_SSC0_SSE); + setbits_le32(&priv->regs->sstsa, SSP_SSTSA_EN); +} + +static void bdw_i2s_disable(struct broadwell_i2s_priv *priv) +{ + clrbits_le32(&priv->regs->sstsa, SSP_SSTSA_EN); + clrbits_le32(&priv->regs->sstsa, SSP_SSTSA_EN); +} + +static int broadwell_i2s_tx_data(struct udevice *dev, void *data, + uint data_size) +{ + struct broadwell_i2s_priv *priv = dev_get_priv(dev); + u32 *ptr = data; + + log_debug("data=%p, data_size=%x\n", data, data_size); + if (data_size < SSP_FIFO_SIZE) { + log_err("Invalid I2S data size\n"); + return -ENODATA; + } + + /* Enable I2S interface */ + bdw_i2s_enable(priv); + + /* Transfer data */ + while (data_size > 0) { + ulong start = timer_get_us() + 100000; + + /* Write data if transmit FIFO has room */ + if (readl(&priv->regs->sssr) & SSP_SSS_TNF) { + writel(*ptr++, &priv->regs->ssdr); + data_size -= sizeof(*ptr); + } else { + if ((long)(timer_get_us() - start) > 0) { + /* Disable I2S interface */ + bdw_i2s_disable(priv); + log_debug("I2S Transfer Timeout\n"); + return -ETIMEDOUT; + } + } + } + + /* Disable I2S interface */ + bdw_i2s_disable(priv); + log_debug("done\n"); + + return 0; +} + +static int broadwell_i2s_probe(struct udevice *dev) +{ + struct i2s_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct broadwell_i2s_priv *priv = dev_get_priv(dev); + struct udevice *adsp = dev_get_parent(dev); + u32 bar0, offset; + int ret; + + bar0 = dm_pci_read_bar32(adsp, 0); + if (!bar0) { + log_debug("Cannot read adsp bar0\n"); + return -EINVAL; + } + offset = dev_read_addr_index(dev, 0); + if (offset == FDT_ADDR_T_NONE) { + log_debug("Cannot read address index 0\n"); + return -EINVAL; + } + uc_priv->base_address = bar0 + offset; + + /* + * Hard-code these values. If other settings are required we can add + * this to the device tree. + */ + uc_priv->rfs = 64; + uc_priv->bfs = 32; + uc_priv->audio_pll_clk = 24 * 1000 * 1000; + uc_priv->samplingrate = 48000; + uc_priv->bitspersample = 16; + uc_priv->channels = 2; + uc_priv->id = 0; + + priv->shim = (struct i2s_shim_regs *)uc_priv->base_address; + priv->sfrm_polarity = SSP_FRMS_ACTIVE_LOW; + priv->end_transfer_state = SSP_END_TRANSFER_STATE_LOW; + priv->sclk_mode = SCLK_MODE_DDF_DSR_ISL; + priv->rel_timing = NEXT_FRMS_WITH_LSB_PREVIOUS_FRM; + priv->sclk_dummy_stop = 0; + priv->sclk_frame_width = 31; + + offset = dev_read_addr_index(dev, 1 + uc_priv->id); + if (offset == FDT_ADDR_T_NONE) { + log_debug("Cannot read address index %d\n", 1 + uc_priv->id); + return -EINVAL; + } + log_debug("bar0=%x, uc_priv->base_address=%x, offset=%x\n", bar0, + uc_priv->base_address, offset); + priv->regs = (struct broadwell_i2s_regs *)(bar0 + offset); + + ret = bdw_i2s_init(dev); + if (ret) + return ret; + + return 0; +} + +static const struct i2s_ops broadwell_i2s_ops = { + .tx_data = broadwell_i2s_tx_data, +}; + +static const struct udevice_id broadwell_i2s_ids[] = { + { .compatible = "intel,broadwell-i2s" }, + { } +}; + +U_BOOT_DRIVER(broadwell_i2s) = { + .name = "broadwell_i2s", + .id = UCLASS_I2S, + .of_match = broadwell_i2s_ids, + .probe = broadwell_i2s_probe, + .ops = &broadwell_i2s_ops, + .priv_auto_alloc_size = sizeof(struct broadwell_i2s_priv), +}; diff --git a/drivers/sound/broadwell_i2s.h b/drivers/sound/broadwell_i2s.h new file mode 100644 index 00000000000..ba87abfc6ae --- /dev/null +++ b/drivers/sound/broadwell_i2s.h @@ -0,0 +1,301 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Intel Broadwell I2S driver + * + * Copyright 2019 Google LLC + * + * Modified from dc i2s/broadwell/broadwell.h + */ + +#ifndef __BROADWELL_I2S_H__ +#define __BROADWELL_I2S_H__ + +enum { + SSP_FIFO_SIZE = 7, +}; + +enum frame_sync_rel_timing_t { + NEXT_FRMS_AFTER_END_OF_T4 = 0, + NEXT_FRMS_WITH_LSB_PREVIOUS_FRM, +}; + +enum frame_sync_pol_t { + SSP_FRMS_ACTIVE_LOW = 0, + SSP_FRMS_ACTIVE_HIGH, +}; + +enum end_transfer_state_t { + SSP_END_TRANSFER_STATE_LOW = 0, + SSP_END_TRANSFER_STATE_PEVIOUS_BIT, +}; + +enum clock_mode_t { + /* Data driven (falling), data sampled (rising), idle state (low) */ + SCLK_MODE_DDF_DSR_ISL, + /* Data driven (rising), data sampled (falling), idle state (low) */ + SCLK_MODE_DDR_DSF_ISL, + /* Data driven (rising), data sampled (falling), idle state (high) */ + SCLK_MODE_DDR_DSF_ISH, + /* Data driven (falling), data sampled (rising), idle state (high) */ + SCLK_MODE_DDF_DSR_ISH, +}; + +struct i2s_shim_regs { + u32 csr; /* 0x00 */ + u32 reserved0[29]; /* 0x14 - 0x77 */ + u32 clkctl; /* 0x78 */ + u32 reserved1; /* 0x7c */ + u32 cs2; /* 0x80 */ +}; + +struct broadwell_i2s_regs { + u32 sscr0; /* 0x00 */ + u32 sscr1; /* 0x04 */ + u32 sssr; /* 0x08 */ + u32 ssitr; /* 0x0c */ + u32 ssdr; /* 0x10 */ + u32 reserved0[5]; /* 0x14 - 0x27 */ + u32 ssto; /* 0x28 */ + u32 sspsp; /* 0x2c */ + u32 sstsa; /* 0x30 */ + u32 ssrsa; /* 0x34 */ + u32 sstss; /* 0x38 */ + u32 sscr2; /* 0x40 */ + u32 sspsp2; /* 0x44 */ +}; + +/* SHIM Configuration & Status */ +enum { + /* Low Power Clock Select */ + SHIM_CS_LPCS = 1 << 31, + /* SSP Force Clock Running */ + SHIM_CS_SFCR_SSP1 = 1 << 28, + SHIM_CS_SFCR_SSP0 = 1 << 27, + /* SSP1 IO Clock Select */ + SHIM_CS_S1IOCS = 1 << 23, + /* SSP0 IO Clock Select */ + SHIM_CS_S0IOCS = 1 << 21, + /* Parity Check Enable */ + SHIM_CS_PCE = 1 << 15, + /* SSP DMA or PIO Mode */ + SHIM_CS_SDPM_PIO_SSP1 = 1 << 12, + SHIM_CS_SDPM_DMA_SSP1 = 0 << 12, + SHIM_CS_SDPM_PIO_SSP0 = 1 << 11, + SHIM_CS_SDPM_DMA_SSP0 = 0 << 11, + /* Run / Stall */ + SHIM_CS_STALL = 1 << 10, + /* DSP Clock Select */ + SHIM_CS_DCS_DSP320_AF80 = 0 << 4, + SHIM_CS_DCS_DSP160_AF80 = 1 << 4, + SHIM_CS_DCS_DSP80_AF80 = 2 << 4, + SHIM_CS_DCS_DSP320_AF160 = 4 << 4, + SHIM_CS_DCS_DSP160_AF160 = 5 << 4, + SHIM_CS_DCS_DSP32_AF32 = 6 << 4, + SHIM_CS_DCS_MASK = 7 << 4, + /* SSP Base Clock Select */ + SHIM_CS_SBCS_SSP0_24MHZ = 1 << 3, + SHIM_CS_SBCS_SSP0_32MHZ = 0 << 3, + SHIM_CS_SBCS_SSP1_24MHZ = 1 << 2, + SHIM_CS_SBCS_SSP1_32MHZ = 0 << 2, + /* DSP Core Reset */ + SHIM_CS_RST = 1 << 1, +}; + +/* SHIM Clock Control */ +enum { + /* Clock Frequency Change In Progress */ + SHIM_CLKCTL_CFCIP = 1 << 31, + /* SSP MCLK Output Select */ + SHIM_CLKCTL_MCLK_MASK = 0x3, + SHIM_CLKCTL_MCLK_SHIFT = 24, + SHIM_CLKCTL_MCLK_DISABLED = 0 << 24, + SHIM_CLKCTL_MCLK_6MHZ = 1 << 24, + SHIM_CLKCTL_MCLK_12MHZ = 2 << 24, + SHIM_CLKCTL_MCLK_24MHZ = 3 << 24, + /* DSP Core Prevent Local Clock Gating */ + SHIM_CLKCTL_DCPLCG = 1 << 18, + /* SSP Clock Output Enable */ + SHIM_CLKCTL_SCOE_SSP1 = 1 << 17, + SHIM_CLKCTL_SCOE_SSP0 = 1 << 16, + /* DMA Engine Force Local Clock Gating */ + SHIM_CLKCTL_DEFLCGB_DMA1_CGE = 0 << 6, + SHIM_CLKCTL_DEFLCGB_DMA1_CGD = 1 << 6, + SHIM_CLKCTL_DEFLCGB_DMA0_CGE = 0 << 5, + SHIM_CLKCTL_DEFLCGB_DMA0_CGD = 1 << 5, + /* SSP Force Local Clock Gating */ + SHIM_CLKCTL_SFLCGB_SSP1_CGE = 0 << 1, + SHIM_CLKCTL_SFLCGB_SSP1_CGD = 1 << 1, + SHIM_CLKCTL_SFLCGB_SSP0_CGE = 0 << 0, + SHIM_CLKCTL_SFLCGB_SSP0_CGD = 1 << 0, + + /* Reserved bits: 30:26, 23:19, 15:7, 4:2 */ + SHIM_CLKCTL_RESERVED = 0x1f << 26 | 0x1f << 19 | 0x1ff << 7 | 0x7 << 2, +}; + +/* SSP Status */ +enum { + /* Bit Count Error */ + SSP_SSS_BCE = 1 << 23, + /* Clock Sync Statu s*/ + SSP_SSS_CSS = 1 << 22, + /* Transmit FIFO Underrun */ + SSP_SSS_TUR = 1 << 21, + /* End Of Chain */ + SSP_SSS_EOC = 1 << 20, + /* Receiver Time-out Interrupt */ + SSP_SSS_TINT = 1 << 19, + /* Peripheral Trailing Byte Interrupt */ + SSP_SSS_PINT = 1 << 18, + /* Received FIFO Level */ + SSP_RFL_MASK = 0xf, + SSP_RFL_SHIFT = 12, + /* Transmit FIFO Level */ + SSP_TFL_MASK = 0xf, + SSP_TFL_SHIFT = 8, + /* Receive FIFO Overrun */ + SSP_SSS_ROR = 1 << 7, + /* Receive FIFO Service Request */ + SSP_SSS_RFS = 1 << 6, + /* Transmit FIFO Service Request */ + SSP_SSS_TFS = 1 << 5, + /* SSP Busy */ + SSP_SSS_BSY = 1 << 4, + /* Receive FIFO Not Empty */ + SSP_SSS_RNE = 1 << 3, + /* Transmit FIFO Not Full */ + SSP_SSS_TNF = 1 << 2, +}; + +/* SSP Control 0 */ +enum { + /* Mode */ + SSP_SSC0_MODE_NORMAL = 0 << 31, + SSP_SSC0_MODE_NETWORK = 1 << 31, + /* Audio Clock Select */ + SSP_SSC0_ACS_PCH = 0 << 30, + /* Frame Rate Divider Control (0-7) */ + SSP_SSC0_FRDC_MASK = 0x7, + SSP_SSC0_FRDC_SHIFT = 24, + SSP_SSC0_FRDC_STEREO = 1 << 24, + /* Transmit FIFO Underrun Interrupt Mask */ + SSP_SSC0_TIM = 1 << 23, + /* Receive FIFO Underrun Interrupt Mask */ + SSP_SSC0_RIM = 1 << 22, + /* Network Clock Select */ + SSP_SSC0_NCS_PCH = 0 << 21, + /* Extended Data Size Select */ + SSP_SSC0_EDSS = 1 << 20, + /* Serial Clock Rate (0-4095) */ + SSP_SSC0_SCR_SHIFT = 8, + SSP_SSC0_SCR_MASK = 0xfff << SSP_SSC0_SCR_SHIFT, + /* Synchronous Serial Port Enable */ + SSP_SSC0_SSE = 1 << 7, + /* External Clock Select */ + SSP_SSC0_ECS_PCH = 0 << 6, + /* Frame Format */ + SSP_SSC0_FRF_MOTOROLA_SPI = 0 << 4, + SSP_SSC0_FRF_TI_SSP = 1 << 4, + SSP_SSC0_FRF_NS_MICROWIRE = 2 << 4, + SSP_SSC0_FRF_PSP = 3 << 4, + /* Data Size Select */ + SSP_SSC0_DSS_SHIFT = 0, + SSP_SSC0_DSS_MASK = 0xf << SSP_SSC0_DSS_SHIFT, +}; + +/* SSP Control 1 */ +enum { + /* TXD Tristate Enable on Last Phase */ + SSP_SSC1_TTELP = 1 << 31, + /* TXD Tristate Enable */ + SSP_SSC1_TTE = 1 << 30, + /* Enable Bit Count Error Interrupt */ + SSP_SSC1_EBCEI = 1 << 29, + /* Slave Clock Running */ + SSP_SSC1_SCFR = 1 << 28, + /* Enable Clock Request A */ + SSP_SSC1_ECRA = 1 << 27, + /* Enable Clock Request B */ + SSP_SSC1_ECRB = 1 << 26, + /* SSPCLK Direction */ + SSP_SSC1_SCLKDIR_SLAVE = 1 << 25, + SSP_SSC1_SCLKDIR_MASTER = 0 << 25, + /* SSPFRM Direction */ + SSP_SSC1_SFRMDIR_SLAVE = 1 << 24, + SSP_SSC1_SFRMDIR_MASTER = 0 << 24, + /* Receive without Transmit */ + SSP_SSC1_RWOT = 1 << 23, + /* Trailing Byte */ + SSP_SSC1_TRAIL = 1 << 22, + /* DMA Tx Service Request Enable */ + SSP_SSC1_TSRE = 1 << 21, + /* DMA Rx Service Request Enable */ + SSP_SSC1_RSRE = 1 << 20, + /* Receiver Timeout Interrupt Enable */ + SSP_SSC1_TINTE = 1 << 19, + /* Periph. Trailing Byte Int. Enable */ + SSP_SSC1_PINTE = 1 << 18, + /* Invert Frame Signal */ + SSP_SSC1_IFS = 1 << 16, + /* Select FIFO for EFWR: test mode */ + SSP_SSC1_STRF = 1 << 15, + /* Enable FIFO Write/Read: test mode */ + SSP_SSC1_EFWR = 1 << 14, + /* Receive FIFO Trigger Threshold */ + SSP_SSC1_RFT_SHIFT = 10, + SSP_SSC1_RFT_MASK = 0xf << SSP_SSC1_RFT_SHIFT, + /* Transmit FIFO Trigger Threshold */ + SSP_SSC1_TFT_SHIFT = 6, + SSP_SSC1_TFT_MASK = 0xf << SSP_SSC1_TFT_SHIFT, + /* Microwire Transmit Data Size */ + SSP_SSC1_MWDS = 1 << 5, + /* Motorola SPI SSPSCLK Phase Setting*/ + SSP_SSC1_SPH = 1 << 4, + /* Motorola SPI SSPSCLK Polarity */ + SSP_SSC1_SPO = 1 << 3, + /* Loopback mode: test mode */ + SSP_SSC1_LBM = 1 << 2, + /* Transmit FIFO Interrupt Enable */ + SSP_SSC1_TIE = 1 << 1, + /* Receive FIFO Interrupt Enable */ + SSP_SSC1_RIE = 1 << 0, + + SSP_SSC1_RESERVED = 17 << 1, +}; + +/* SSP Programmable Serial Protocol */ +enum { + /* Extended Dummy Stop (0-31) */ + SSP_PSP_EDYMSTOP_SHIFT = 26, + SSP_PSP_EDMYSTOP_MASK = 0x7 << SSP_PSP_EDYMSTOP_SHIFT, + /* Frame Sync Relative Timing */ + SSP_PSP_FSRT = 1 << 25, + /* Dummy Stop low bits */ + SSP_PSP_DMYSTOP_SHIFT = 23, + SSP_PSP_DMYSTOP_MASK = 0x3 << SSP_PSP_DMYSTOP_SHIFT, + /* Serial Frame Width */ + SSP_PSP_SFRMWDTH_SHIFT = 16, + SSP_PSP_SFRMWDTH_MASK = 0x3f << SSP_PSP_SFRMWDTH_SHIFT, + /* Serial Frame Delay */ + SSP_PSP_SFRMDLY_MASK = 0x7f, + SSP_PSP_SFRMDLY_SHIFT = 9, + /* Start Delay */ + SSP_PSP_STRTDLY_MASK = 0x7, + SSP_PSP_STRTDLY_SHIFT = 4, + /* End of Transfer Data State */ + SSP_PSP_ETDS = 1 << 3, + /* Serial Frame Polarity */ + SSP_PSP_SFRMP = 1 << 2, + /* Serial Clock Mode */ + SSP_PSP_SCMODE_SHIFT = 0, + SSP_PSP_SCMODE_MASK = 0x3 << SSP_PSP_SCMODE_SHIFT, + + SSP_PSP_RESERVED = 1 << 22, +}; + +/* SSP TX Time Slot Active */ +enum { + SSP_SSTSA_EN = 1 << 8, + SSP_SSTSA_MASK = 0xff, +}; + +#endif /* __BROADWELL_I2S_H__ */
This audio codec is used on samus. Add a driver for it.
Changes in v2: None
drivers/sound/Kconfig | 9 + drivers/sound/Makefile | 1 + drivers/sound/rt5677.c | 334 ++++++++++ drivers/sound/rt5677.h | 1428 ++++++++++++++++++++++++++++++++++++++++ 4 files changed, 1772 insertions(+) create mode 100644 drivers/sound/rt5677.c create mode 100644 drivers/sound/rt5677.h
diff --git a/drivers/sound/Kconfig b/drivers/sound/Kconfig index c1847df07fa..6e9dcefcb90 100644 --- a/drivers/sound/Kconfig +++ b/drivers/sound/Kconfig @@ -95,6 +95,15 @@ config SOUND_MAX98095 audio data and I2C for codec control. At present it only works with the Samsung I2S driver.
+config SOUND_RT5677 + bool "Support Realtek RT5677 audio codec" + depends on SOUND + help + Enable the Realtek RT5677 audio codec. This is an I2S device used on + some Chromebooks from around 2015 ('auron'). It is configured using + an I2C interface and supports multiple sound inputs and outputs, + including digital microphones. + config SOUND_SANDBOX bool "Support sandbox emulated audio codec" depends on SANDBOX && SOUND diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 07b590156c9..fe3ccd6e5c6 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -17,5 +17,6 @@ obj-$(CONFIG_SOUND_MAX98090) += max98090.o maxim_codec.o obj-$(CONFIG_SOUND_MAX98095) += max98095.o maxim_codec.o obj-$(CONFIG_SOUND_INTEL_HDA) += hda_codec.o obj-$(CONFIG_SOUND_I8254) += i8254_beep.o +obj-$(CONFIG_SOUND_RT5677) += rt5677.o obj-$(CONFIG_INTEL_BROADWELL) += broadwell_i2s.o obj-$(CONFIG_SOUND_IVYBRIDGE) += ivybridge_sound.o diff --git a/drivers/sound/rt5677.c b/drivers/sound/rt5677.c new file mode 100644 index 00000000000..64776055d9f --- /dev/null +++ b/drivers/sound/rt5677.c @@ -0,0 +1,334 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2019 Google LLC + */ + +#define LOG_CATEGORY UCLASS_SOUND + +#include <common.h> +#include <audio_codec.h> +#include <dm.h> +#include <i2c.h> +#include "rt5677.h" + +struct rt5677_priv { + struct udevice *dev; +}; + +/* RT5677 has 256 8-bit register addresses, and 16-bit register data */ +struct rt5677_init_reg { + u8 reg; + u16 val; +}; + +static struct rt5677_init_reg init_list[] = { + {RT5677_LOUT1, 0x0800}, + {RT5677_SIDETONE_CTRL, 0x0000}, + {RT5677_STO1_ADC_DIG_VOL, 0x3F3F}, + {RT5677_DAC1_DIG_VOL, 0x9090}, + {RT5677_STO2_ADC_MIXER, 0xA441}, + {RT5677_STO1_ADC_MIXER, 0x5480}, + {RT5677_STO1_DAC_MIXER, 0x8A8A}, + {RT5677_PWR_DIG1, 0x9800}, /* Power up I2S1 */ + {RT5677_PWR_ANLG1, 0xE9D5}, + {RT5677_PWR_ANLG2, 0x2CC0}, + {RT5677_PWR_DSP2, 0x0C00}, + {RT5677_I2S2_SDP, 0x0000}, + {RT5677_CLK_TREE_CTRL1, 0x1111}, + {RT5677_PLL1_CTRL1, 0x0000}, + {RT5677_PLL1_CTRL2, 0x0000}, + {RT5677_DIG_MISC, 0x0029}, + {RT5677_GEN_CTRL1, 0x00FF}, + {RT5677_GPIO_CTRL2, 0x0020}, + {RT5677_PWR_DIG2, 0x9024}, /* Power on ADC Stereo Filters */ + {RT5677_PDM_OUT_CTRL, 0x0088}, /* Unmute PDM, set stereo1 DAC */ + {RT5677_PDM_DATA_CTRL1, 0x0001}, /* Sysclk to PDM filter divider 2 */ +}; + +/** + * rt5677_i2c_read() - Read a 16-bit register + * + * @priv: Private driver data + * @reg: Register number to read + * @returns data read or -ve on error + */ +static int rt5677_i2c_read(struct rt5677_priv *priv, uint reg) +{ + u8 buf[2]; + int ret; + + ret = dm_i2c_read(priv->dev, reg, buf, sizeof(u16)); + if (ret) + return ret; + return buf[0] << 8 | buf[1]; +} + +/** + * rt5677_i2c_write() - Write a 16-bit register + * + * @priv: Private driver data + * @reg: Register number to read + * @data: Data to write + * @returns 0 if OK, -ve on error + */ +static int rt5677_i2c_write(struct rt5677_priv *priv, uint reg, uint data) +{ + u8 buf[2]; + + buf[0] = (data >> 8) & 0xff; + buf[1] = data & 0xff; + + return dm_i2c_write(priv->dev, reg, buf, sizeof(u16)); +} + +/** + * rt5677_bic_or() - Set and clear bits of a codec register + * + * @priv: Private driver data + * @reg: Register number to update + * @bic: Mask of bits to clear + * @set: Mask of bits to set + * @returns 0 if OK, -ve on error + * + */ +static int rt5677_bic_or(struct rt5677_priv *priv, uint reg, uint bic, + uint set) +{ + uint old, new_value; + int ret; + + old = rt5677_i2c_read(priv, reg); + if (old < 0) + return old; + + new_value = (old & ~bic) | (set & bic); + + if (old != new_value) { + ret = rt5677_i2c_write(priv, reg, new_value); + if (ret) + return ret; + } + + return 0; +} + +/** + * rt5677_reg_init() - Initialise codec regs w/static/base values + * + * @priv: Private driver data + * @returns 0 if OK, -ve on error + */ +static int rt5677_reg_init(struct rt5677_priv *priv) +{ + int ret; + int i; + + for (i = 0; i < ARRAY_SIZE(init_list); i++) { + ret = rt5677_i2c_write(priv, init_list[i].reg, init_list[i].val); + if (ret) + return ret; + } + + return 0; +} + +#ifdef DEBUG +static void debug_dump_5677_regs(struct rt5677_priv *priv, int swap) +{ + uint i, reg_word; + + /* Show all 16-bit codec regs */ + for (i = 0; i < RT5677_REG_CNT; i++) { + if (i % 8 == 0) + log_debug("\nMX%02x: ", i); + + rt5677_i2c_read(priv, (u8)i, ®_word); + if (swap) + log_debug("%04x ", swap_bytes16(reg_word)); + else + log_debug("%04x ", reg_word); + } + log_debug("\n"); + + /* Show all 16-bit 'private' codec regs */ + for (i = 0; i < RT5677_PR_REG_CNT; i++) { + if (i % 8 == 0) + log_debug("\nPR%02x: ", i); + + rt5677_i2c_write(priv, RT5677_PRIV_INDEX, i); + rt5677_i2c_read(priv, RT5677_PRIV_DATA, ®_word); + if (swap) + log_debug("%04x ", swap_bytes16(reg_word)); + else + log_debug("%04x ", reg_word); + } + log_debug("\n"); +} +#endif /* DEBUG */ + +static int rt5677_hw_params(struct rt5677_priv *priv, uint bits_per_sample) +{ + int ret; + + switch (bits_per_sample) { + case 16: + ret = rt5677_bic_or(priv, RT5677_I2S1_SDP, RT5677_I2S_DL_MASK, + 0); + if (ret) { + log_debug("Error updating I2S1 Interface Ctrl reg\n"); + return 1; + } + break; + default: + log_err("Illegal bits per sample %d\n", bits_per_sample); + return -EINVAL; + } + + return 0; +} + +/** + * rt5677_set_fmt() - set rt5677 I2S format + * + * @priv: Private driver data + * @returns 0 if OK, -ve on error + */ +static int rt5677_set_fmt(struct rt5677_priv *priv) +{ + int ret = 0; + + /* + * Set format here: Assumes I2S, NB_NF, CBS_CFS + * + * CBS_CFS (Codec Bit Slave/Codec Frame Slave) + */ + ret = rt5677_bic_or(priv, RT5677_I2S1_SDP, RT5677_I2S_MS_MASK, + RT5677_I2S_MS_S); + + /* NB_NF (Normal Bit/Normal Frame) */ + ret |= rt5677_bic_or(priv, RT5677_I2S1_SDP, RT5677_I2S_BP_MASK, + RT5677_I2S_BP_NOR); + + /* I2S mode */ + ret |= rt5677_bic_or(priv, RT5677_I2S1_SDP, RT5677_I2S_DF_MASK, + RT5677_I2S_DF_I2S); + + /* A44: I2S2 (going to speaker amp) is master */ + ret |= rt5677_bic_or(priv, RT5677_I2S2_SDP, RT5677_I2S_MS_MASK, + RT5677_I2S_MS_M); + + if (ret) { + log_err("Error updating I2S1 Interface Ctrl reg\n"); + return ret; + } + + return 0; +} + +/** + * rt5677_reset() - reset the audio codec + * + * @priv: Private driver data + * @returns 0 if OK, -ve on error + */ +static int rt5677_reset(struct rt5677_priv *priv) +{ + int ret; + + /* Reset the codec registers to their defaults */ + ret = rt5677_i2c_write(priv, RT5677_RESET, RT5677_SW_RESET); + if (ret) { + log_err("Error resetting codec\n"); + return ret; + } + + return 0; +} + +/** + * Initialise rt5677 codec device + * + * @priv: Private driver data + * @returns 0 if OK, -ve on error + */ +int rt5677_device_init(struct rt5677_priv *priv) +{ + int ret; + + /* Read status reg */ + ret = rt5677_i2c_read(priv, RT5677_RESET); + if (ret < 0) + return ret; + log_debug("reg 00h, Software Reset & Status = 0x%04x\n", ret); + + /* Reset the codec/regs */ + ret = rt5677_reset(priv); + if (ret) + return ret; + + ret = rt5677_i2c_read(priv, RT5677_VENDOR_ID1); + if (ret < 0) { + log_err("Error reading vendor ID\n"); + return 1; + } + log_debug("Hardware ID: %0xX\n", ret); + + ret = rt5677_i2c_read(priv, RT5677_VENDOR_ID2); + if (ret < 0) { + log_err("Error reading vendor rev\n"); + return 1; + } + log_debug("Hardware revision: %04x\n", ret); + + return 0; +} + +static int rt5677_set_params(struct udevice *dev, int interface, int rate, + int mclk_freq, int bits_per_sample, + uint channels) +{ + struct rt5677_priv *priv = dev_get_priv(dev); + int ret; + + /* Initialise codec regs w/static/base values, same as Linux driver */ + ret = rt5677_reg_init(priv); + if (ret) + return ret; + + ret = rt5677_hw_params(priv, bits_per_sample); + if (ret) + return ret; + + ret = rt5677_set_fmt(priv); + if (ret) + return ret; + + return 0; +} + +static int rt5677_probe(struct udevice *dev) +{ + struct rt5677_priv *priv = dev_get_priv(dev); + + priv->dev = dev; + + return rt5677_device_init(priv); +} + +static const struct audio_codec_ops rt5677_ops = { + .set_params = rt5677_set_params, +}; + +static const struct udevice_id rt5677_ids[] = { + { .compatible = "realtek,rt5677" }, + { } +}; + +U_BOOT_DRIVER(rt5677_drv) = { + .name = "rt5677", + .id = UCLASS_AUDIO_CODEC, + .of_match = rt5677_ids, + .ops = &rt5677_ops, + .probe = rt5677_probe, + .priv_auto_alloc_size = sizeof(struct rt5677_priv), +}; diff --git a/drivers/sound/rt5677.h b/drivers/sound/rt5677.h new file mode 100644 index 00000000000..1ce3cec7220 --- /dev/null +++ b/drivers/sound/rt5677.h @@ -0,0 +1,1428 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * rt5677.h -- RealTek ALC5677 ALSA SoC Audio driver + * + * Copyright 2013 Realtek Semiconductor Corp. + * Author: Oder Chiou oder_chiou@realtek.com + * + * Based on the file by the same name in Chromium OS dc + */ + +#ifndef __DRIVERS_SOUND_RT5677_H__ +#define __DRIVERS_SOUND_RT5677_H__ + +/* + * RT5677 Registers Definition + */ + +/* Info */ +#define RT5677_RESET 0x00 +#define RT5677_VENDOR_ID 0xfd +#define RT5677_VENDOR_ID1 0xfe +#define RT5677_VENDOR_ID2 0xff + +#define RT5677_REG_CNT (RT5677_VENDOR_ID2 + 1) +#define RT5677_PR_REG_CNT 255 + +/* I/O - Output */ +#define RT5677_LOUT1 0x01 +/* I/O - Input */ +#define RT5677_IN1 0x03 +#define RT5677_MICBIAS 0x04 +/* I/O - SLIMBus */ +#define RT5677_SLIMBUS_PARAM 0x07 +#define RT5677_SLIMBUS_RX 0x08 +#define RT5677_SLIMBUS_CTRL 0x09 +/* I/O */ +#define RT5677_SIDETONE_CTRL 0x13 +/* I/O - ADC/DAC */ +#define RT5677_ANA_DAC1_2_3_SRC 0x15 +#define RT5677_IF_DSP_DAC3_4_MIXER 0x16 +#define RT5677_DAC4_DIG_VOL 0x17 +#define RT5677_DAC3_DIG_VOL 0x18 +#define RT5677_DAC1_DIG_VOL 0x19 +#define RT5677_DAC2_DIG_VOL 0x1a +#define RT5677_IF_DSP_DAC2_MIXER 0x1b +#define RT5677_STO1_ADC_DIG_VOL 0x1c +#define RT5677_MONO_ADC_DIG_VOL 0x1d +#define RT5677_STO1_2_ADC_BST 0x1e +#define RT5677_STO2_ADC_DIG_VOL 0x1f +/* Mixer - D-D */ +#define RT5677_ADC_BST_CTRL2 0x20 +#define RT5677_STO3_4_ADC_BST 0x21 +#define RT5677_STO3_ADC_DIG_VOL 0x22 +#define RT5677_STO4_ADC_DIG_VOL 0x23 +#define RT5677_STO4_ADC_MIXER 0x24 +#define RT5677_STO3_ADC_MIXER 0x25 +#define RT5677_STO2_ADC_MIXER 0x26 +#define RT5677_STO1_ADC_MIXER 0x27 +#define RT5677_MONO_ADC_MIXER 0x28 +#define RT5677_ADC_IF_DSP_DAC1_MIXER 0x29 +#define RT5677_STO1_DAC_MIXER 0x2a +#define RT5677_MONO_DAC_MIXER 0x2b +#define RT5677_DD1_MIXER 0x2c +#define RT5677_DD2_MIXER 0x2d +#define RT5677_IF3_DATA 0x2f +#define RT5677_IF4_DATA 0x30 +/* Mixer - PDM */ +#define RT5677_PDM_OUT_CTRL 0x31 +#define RT5677_PDM_DATA_CTRL1 0x32 +#define RT5677_PDM_DATA_CTRL2 0x33 +#define RT5677_PDM1_DATA_CTRL2 0x34 +#define RT5677_PDM1_DATA_CTRL3 0x35 +#define RT5677_PDM1_DATA_CTRL4 0x36 +#define RT5677_PDM2_DATA_CTRL2 0x37 +#define RT5677_PDM2_DATA_CTRL3 0x38 +#define RT5677_PDM2_DATA_CTRL4 0x39 +/* TDM */ +#define RT5677_TDM1_CTRL1 0x3b +#define RT5677_TDM1_CTRL2 0x3c +#define RT5677_TDM1_CTRL3 0x3d +#define RT5677_TDM1_CTRL4 0x3e +#define RT5677_TDM1_CTRL5 0x3f +#define RT5677_TDM2_CTRL1 0x40 +#define RT5677_TDM2_CTRL2 0x41 +#define RT5677_TDM2_CTRL3 0x42 +#define RT5677_TDM2_CTRL4 0x43 +#define RT5677_TDM2_CTRL5 0x44 +/* I2C_MASTER_CTRL */ +#define RT5677_I2C_MASTER_CTRL1 0x47 +#define RT5677_I2C_MASTER_CTRL2 0x48 +#define RT5677_I2C_MASTER_CTRL3 0x49 +#define RT5677_I2C_MASTER_CTRL4 0x4a +#define RT5677_I2C_MASTER_CTRL5 0x4b +#define RT5677_I2C_MASTER_CTRL6 0x4c +#define RT5677_I2C_MASTER_CTRL7 0x4d +#define RT5677_I2C_MASTER_CTRL8 0x4e +/* DMIC */ +#define RT5677_DMIC_CTRL1 0x50 +#define RT5677_DMIC_CTRL2 0x51 +/* Haptic Generator */ +#define RT5677_HAP_GENE_CTRL1 0x56 +#define RT5677_HAP_GENE_CTRL2 0x57 +#define RT5677_HAP_GENE_CTRL3 0x58 +#define RT5677_HAP_GENE_CTRL4 0x59 +#define RT5677_HAP_GENE_CTRL5 0x5a +#define RT5677_HAP_GENE_CTRL6 0x5b +#define RT5677_HAP_GENE_CTRL7 0x5c +#define RT5677_HAP_GENE_CTRL8 0x5d +#define RT5677_HAP_GENE_CTRL9 0x5e +#define RT5677_HAP_GENE_CTRL10 0x5f +/* Power */ +#define RT5677_PWR_DIG1 0x61 +#define RT5677_PWR_DIG2 0x62 +#define RT5677_PWR_ANLG1 0x63 +#define RT5677_PWR_ANLG2 0x64 +#define RT5677_PWR_DSP1 0x65 +#define RT5677_PWR_DSP_ST 0x66 +#define RT5677_PWR_DSP2 0x67 +#define RT5677_ADC_DAC_HPF_CTRL1 0x68 +/* Private Register Control */ +#define RT5677_PRIV_INDEX 0x6a +#define RT5677_PRIV_DATA 0x6c +/* Format - ADC/DAC */ +#define RT5677_I2S4_SDP 0x6f +#define RT5677_I2S1_SDP 0x70 +#define RT5677_I2S2_SDP 0x71 +#define RT5677_I2S3_SDP 0x72 +#define RT5677_CLK_TREE_CTRL1 0x73 +#define RT5677_CLK_TREE_CTRL2 0x74 +#define RT5677_CLK_TREE_CTRL3 0x75 +/* Function - Analog */ +#define RT5677_PLL1_CTRL1 0x7a +#define RT5677_PLL1_CTRL2 0x7b +#define RT5677_PLL2_CTRL1 0x7c +#define RT5677_PLL2_CTRL2 0x7d +#define RT5677_GLB_CLK1 0x80 +#define RT5677_GLB_CLK2 0x81 +#define RT5677_ASRC_1 0x83 +#define RT5677_ASRC_2 0x84 +#define RT5677_ASRC_3 0x85 +#define RT5677_ASRC_4 0x86 +#define RT5677_ASRC_5 0x87 +#define RT5677_ASRC_6 0x88 +#define RT5677_ASRC_7 0x89 +#define RT5677_ASRC_8 0x8a +#define RT5677_ASRC_9 0x8b +#define RT5677_ASRC_10 0x8c +#define RT5677_ASRC_11 0x8d +#define RT5677_ASRC_12 0x8e +#define RT5677_ASRC_13 0x8f +#define RT5677_ASRC_14 0x90 +#define RT5677_ASRC_15 0x91 +#define RT5677_ASRC_16 0x92 +#define RT5677_ASRC_17 0x93 +#define RT5677_ASRC_18 0x94 +#define RT5677_ASRC_19 0x95 +#define RT5677_ASRC_20 0x97 +#define RT5677_ASRC_21 0x98 +#define RT5677_ASRC_22 0x99 +#define RT5677_ASRC_23 0x9a +#define RT5677_VAD_CTRL1 0x9c +#define RT5677_VAD_CTRL2 0x9d +#define RT5677_VAD_CTRL3 0x9e +#define RT5677_VAD_CTRL4 0x9f +#define RT5677_VAD_CTRL5 0xa0 +/* Function - Digital */ +#define RT5677_DSP_INB_CTRL1 0xa3 +#define RT5677_DSP_INB_CTRL2 0xa4 +#define RT5677_DSP_IN_OUTB_CTRL 0xa5 +#define RT5677_DSP_OUTB0_1_DIG_VOL 0xa6 +#define RT5677_DSP_OUTB2_3_DIG_VOL 0xa7 +#define RT5677_DSP_OUTB4_5_DIG_VOL 0xa8 +#define RT5677_DSP_OUTB6_7_DIG_VOL 0xa9 +#define RT5677_ADC_EQ_CTRL1 0xae +#define RT5677_ADC_EQ_CTRL2 0xaf +#define RT5677_EQ_CTRL1 0xb0 +#define RT5677_EQ_CTRL2 0xb1 +#define RT5677_EQ_CTRL3 0xb2 +#define RT5677_SOFT_VOL_ZERO_CROSS1 0xb3 +#define RT5677_JD_CTRL1 0xb5 +#define RT5677_JD_CTRL2 0xb6 +#define RT5677_JD_CTRL3 0xb8 +#define RT5677_IRQ_CTRL1 0xbd +#define RT5677_IRQ_CTRL2 0xbe +#define RT5677_GPIO_ST 0xbf +#define RT5677_GPIO_CTRL1 0xc0 +#define RT5677_GPIO_CTRL2 0xc1 +#define RT5677_GPIO_CTRL3 0xc2 +#define RT5677_STO1_ADC_HI_FILTER1 0xc5 +#define RT5677_STO1_ADC_HI_FILTER2 0xc6 +#define RT5677_MONO_ADC_HI_FILTER1 0xc7 +#define RT5677_MONO_ADC_HI_FILTER2 0xc8 +#define RT5677_STO2_ADC_HI_FILTER1 0xc9 +#define RT5677_STO2_ADC_HI_FILTER2 0xca +#define RT5677_STO3_ADC_HI_FILTER1 0xcb +#define RT5677_STO3_ADC_HI_FILTER2 0xcc +#define RT5677_STO4_ADC_HI_FILTER1 0xcd +#define RT5677_STO4_ADC_HI_FILTER2 0xce +#define RT5677_MB_DRC_CTRL1 0xd0 +#define RT5677_DRC1_CTRL1 0xd2 +#define RT5677_DRC1_CTRL2 0xd3 +#define RT5677_DRC1_CTRL3 0xd4 +#define RT5677_DRC1_CTRL4 0xd5 +#define RT5677_DRC1_CTRL5 0xd6 +#define RT5677_DRC1_CTRL6 0xd7 +#define RT5677_DRC2_CTRL1 0xd8 +#define RT5677_DRC2_CTRL2 0xd9 +#define RT5677_DRC2_CTRL3 0xda +#define RT5677_DRC2_CTRL4 0xdb +#define RT5677_DRC2_CTRL5 0xdc +#define RT5677_DRC2_CTRL6 0xdd +#define RT5677_DRC1_HL_CTRL1 0xde +#define RT5677_DRC1_HL_CTRL2 0xdf +#define RT5677_DRC2_HL_CTRL1 0xe0 +#define RT5677_DRC2_HL_CTRL2 0xe1 +#define RT5677_DSP_INB1_SRC_CTRL1 0xe3 +#define RT5677_DSP_INB1_SRC_CTRL2 0xe4 +#define RT5677_DSP_INB1_SRC_CTRL3 0xe5 +#define RT5677_DSP_INB1_SRC_CTRL4 0xe6 +#define RT5677_DSP_INB2_SRC_CTRL1 0xe7 +#define RT5677_DSP_INB2_SRC_CTRL2 0xe8 +#define RT5677_DSP_INB2_SRC_CTRL3 0xe9 +#define RT5677_DSP_INB2_SRC_CTRL4 0xea +#define RT5677_DSP_INB3_SRC_CTRL1 0xeb +#define RT5677_DSP_INB3_SRC_CTRL2 0xec +#define RT5677_DSP_INB3_SRC_CTRL3 0xed +#define RT5677_DSP_INB3_SRC_CTRL4 0xee +#define RT5677_DSP_OUTB1_SRC_CTRL1 0xef +#define RT5677_DSP_OUTB1_SRC_CTRL2 0xf0 +#define RT5677_DSP_OUTB1_SRC_CTRL3 0xf1 +#define RT5677_DSP_OUTB1_SRC_CTRL4 0xf2 +#define RT5677_DSP_OUTB2_SRC_CTRL1 0xf3 +#define RT5677_DSP_OUTB2_SRC_CTRL2 0xf4 +#define RT5677_DSP_OUTB2_SRC_CTRL3 0xf5 +#define RT5677_DSP_OUTB2_SRC_CTRL4 0xf6 + +/* Virtual DSP Mixer Control */ +#define RT5677_DSP_OUTB_0123_MIXER_CTRL 0xf7 +#define RT5677_DSP_OUTB_45_MIXER_CTRL 0xf8 +#define RT5677_DSP_OUTB_67_MIXER_CTRL 0xf9 + +/* General Control */ +#define RT5677_DIG_MISC 0xfa +#define RT5677_GEN_CTRL1 0xfb +#define RT5677_GEN_CTRL2 0xfc + +/* DSP Mode I2C Control*/ +#define RT5677_DSP_I2C_OP_CODE 0x00 +#define RT5677_DSP_I2C_ADDR_LSB 0x01 +#define RT5677_DSP_I2C_ADDR_MSB 0x02 +#define RT5677_DSP_I2C_DATA_LSB 0x03 +#define RT5677_DSP_I2C_DATA_MSB 0x04 + +/* Index of Codec Private Register definition */ +#define RT5677_PR_DRC1_CTRL_1 0x01 +#define RT5677_PR_DRC1_CTRL_2 0x02 +#define RT5677_PR_DRC1_CTRL_3 0x03 +#define RT5677_PR_DRC1_CTRL_4 0x04 +#define RT5677_PR_DRC1_CTRL_5 0x05 +#define RT5677_PR_DRC1_CTRL_6 0x06 +#define RT5677_PR_DRC1_CTRL_7 0x07 +#define RT5677_PR_DRC2_CTRL_1 0x08 +#define RT5677_PR_DRC2_CTRL_2 0x09 +#define RT5677_PR_DRC2_CTRL_3 0x0a +#define RT5677_PR_DRC2_CTRL_4 0x0b +#define RT5677_PR_DRC2_CTRL_5 0x0c +#define RT5677_PR_DRC2_CTRL_6 0x0d +#define RT5677_PR_DRC2_CTRL_7 0x0e +#define RT5677_BIAS_CUR1 0x10 +#define RT5677_BIAS_CUR2 0x12 +#define RT5677_BIAS_CUR3 0x13 +#define RT5677_BIAS_CUR4 0x14 +#define RT5677_BIAS_CUR5 0x15 +#define RT5677_VREF_LOUT_CTRL 0x17 +#define RT5677_DIG_VOL_CTRL1 0x1a +#define RT5677_DIG_VOL_CTRL2 0x1b +#define RT5677_ANA_ADC_GAIN_CTRL 0x1e +#define RT5677_VAD_SRAM_TEST1 0x20 +#define RT5677_VAD_SRAM_TEST2 0x21 +#define RT5677_VAD_SRAM_TEST3 0x22 +#define RT5677_VAD_SRAM_TEST4 0x23 +#define RT5677_PAD_DRV_CTRL 0x26 +#define RT5677_DIG_IN_PIN_ST_CTRL1 0x29 +#define RT5677_DIG_IN_PIN_ST_CTRL2 0x2a +#define RT5677_DIG_IN_PIN_ST_CTRL3 0x2b +#define RT5677_PLL1_INT 0x38 +#define RT5677_PLL2_INT 0x39 +#define RT5677_TEST_CTRL1 0x3a +#define RT5677_TEST_CTRL2 0x3b +#define RT5677_TEST_CTRL3 0x3c +#define RT5677_CHOP_DAC_ADC 0x3d +#define RT5677_SOFT_DEPOP_DAC_CLK_CTRL 0x3e +#define RT5677_CROSS_OVER_FILTER1 0x90 +#define RT5677_CROSS_OVER_FILTER2 0x91 +#define RT5677_CROSS_OVER_FILTER3 0x92 +#define RT5677_CROSS_OVER_FILTER4 0x93 +#define RT5677_CROSS_OVER_FILTER5 0x94 +#define RT5677_CROSS_OVER_FILTER6 0x95 +#define RT5677_CROSS_OVER_FILTER7 0x96 +#define RT5677_CROSS_OVER_FILTER8 0x97 +#define RT5677_CROSS_OVER_FILTER9 0x98 +#define RT5677_CROSS_OVER_FILTER10 0x99 + +/* global definition */ +#define RT5677_L_MUTE (0x1 << 15) +#define RT5677_L_MUTE_SFT 15 +#define RT5677_VOL_L_MUTE (0x1 << 14) +#define RT5677_VOL_L_SFT 14 +#define RT5677_R_MUTE (0x1 << 7) +#define RT5677_R_MUTE_SFT 7 +#define RT5677_VOL_R_MUTE (0x1 << 6) +#define RT5677_VOL_R_SFT 6 +#define RT5677_L_VOL_MASK (0x3f << 8) +#define RT5677_L_VOL_SFT 8 +#define RT5677_R_VOL_MASK (0x3f) +#define RT5677_R_VOL_SFT 0 + +/* LOUT1 Control (0x01) */ +#define RT5677_LOUT1_L_MUTE (0x1 << 15) +#define RT5677_LOUT1_L_MUTE_SFT (15) +#define RT5677_LOUT1_L_DF (0x1 << 14) +#define RT5677_LOUT1_L_DF_SFT (14) +#define RT5677_LOUT2_L_MUTE (0x1 << 13) +#define RT5677_LOUT2_L_MUTE_SFT (13) +#define RT5677_LOUT2_L_DF (0x1 << 12) +#define RT5677_LOUT2_L_DF_SFT (12) +#define RT5677_LOUT3_L_MUTE (0x1 << 11) +#define RT5677_LOUT3_L_MUTE_SFT (11) +#define RT5677_LOUT3_L_DF (0x1 << 10) +#define RT5677_LOUT3_L_DF_SFT (10) +#define RT5677_LOUT1_ENH_DRV (0x1 << 9) +#define RT5677_LOUT1_ENH_DRV_SFT (9) +#define RT5677_LOUT2_ENH_DRV (0x1 << 8) +#define RT5677_LOUT2_ENH_DRV_SFT (8) +#define RT5677_LOUT3_ENH_DRV (0x1 << 7) +#define RT5677_LOUT3_ENH_DRV_SFT (7) + +/* IN1 Control (0x03) */ +#define RT5677_BST_MASK1 (0xf << 12) +#define RT5677_BST_SFT1 12 +#define RT5677_BST_MASK2 (0xf << 8) +#define RT5677_BST_SFT2 8 +#define RT5677_IN_DF1 (0x1 << 7) +#define RT5677_IN_DF1_SFT 7 +#define RT5677_IN_DF2 (0x1 << 6) +#define RT5677_IN_DF2_SFT 6 + +/* Micbias Control (0x04) */ +#define RT5677_MICBIAS1_OUTVOLT_MASK (0x1 << 15) +#define RT5677_MICBIAS1_OUTVOLT_SFT (15) +#define RT5677_MICBIAS1_OUTVOLT_2_7V (0x0 << 15) +#define RT5677_MICBIAS1_OUTVOLT_2_25V (0x1 << 15) +#define RT5677_MICBIAS1_CTRL_VDD_MASK (0x1 << 14) +#define RT5677_MICBIAS1_CTRL_VDD_SFT (14) +#define RT5677_MICBIAS1_CTRL_VDD_1_8V (0x0 << 14) +#define RT5677_MICBIAS1_CTRL_VDD_3_3V (0x1 << 14) +#define RT5677_MICBIAS1_OVCD_MASK (0x1 << 11) +#define RT5677_MICBIAS1_OVCD_SHIFT (11) +#define RT5677_MICBIAS1_OVCD_DIS (0x0 << 11) +#define RT5677_MICBIAS1_OVCD_EN (0x1 << 11) +#define RT5677_MICBIAS1_OVTH_MASK (0x3 << 9) +#define RT5677_MICBIAS1_OVTH_SFT 9 +#define RT5677_MICBIAS1_OVTH_640UA (0x0 << 9) +#define RT5677_MICBIAS1_OVTH_1280UA (0x1 << 9) +#define RT5677_MICBIAS1_OVTH_1920UA (0x2 << 9) + +/* SLIMbus Parameter (0x07) */ + +/* SLIMbus Rx (0x08) */ +#define RT5677_SLB_ADC4_MASK (0x3 << 6) +#define RT5677_SLB_ADC4_SFT 6 +#define RT5677_SLB_ADC3_MASK (0x3 << 4) +#define RT5677_SLB_ADC3_SFT 4 +#define RT5677_SLB_ADC2_MASK (0x3 << 2) +#define RT5677_SLB_ADC2_SFT 2 +#define RT5677_SLB_ADC1_MASK (0x3 << 0) +#define RT5677_SLB_ADC1_SFT 0 + +/* SLIMBus control (0x09) */ + +/* Sidetone Control (0x13) */ +#define RT5677_ST_HPF_SEL_MASK (0x7 << 13) +#define RT5677_ST_HPF_SEL_SFT 13 +#define RT5677_ST_HPF_PATH (0x1 << 12) +#define RT5677_ST_HPF_PATH_SFT 12 +#define RT5677_ST_SEL_MASK (0x7 << 9) +#define RT5677_ST_SEL_SFT 9 +#define RT5677_ST_EN (0x1 << 6) +#define RT5677_ST_EN_SFT 6 + +/* Analog DAC1/2/3 Source Control (0x15) */ +#define RT5677_ANA_DAC3_SRC_SEL_MASK (0x3 << 4) +#define RT5677_ANA_DAC3_SRC_SEL_SFT 4 +#define RT5677_ANA_DAC1_2_SRC_SEL_MASK (0x3 << 0) +#define RT5677_ANA_DAC1_2_SRC_SEL_SFT 0 + +/* IF/DSP to DAC3/4 Mixer Control (0x16) */ +#define RT5677_M_DAC4_L_VOL (0x1 << 15) +#define RT5677_M_DAC4_L_VOL_SFT 15 +#define RT5677_SEL_DAC4_L_SRC_MASK (0x7 << 12) +#define RT5677_SEL_DAC4_L_SRC_SFT 12 +#define RT5677_M_DAC4_R_VOL (0x1 << 11) +#define RT5677_M_DAC4_R_VOL_SFT 11 +#define RT5677_SEL_DAC4_R_SRC_MASK (0x7 << 8) +#define RT5677_SEL_DAC4_R_SRC_SFT 8 +#define RT5677_M_DAC3_L_VOL (0x1 << 7) +#define RT5677_M_DAC3_L_VOL_SFT 7 +#define RT5677_SEL_DAC3_L_SRC_MASK (0x7 << 4) +#define RT5677_SEL_DAC3_L_SRC_SFT 4 +#define RT5677_M_DAC3_R_VOL (0x1 << 3) +#define RT5677_M_DAC3_R_VOL_SFT 3 +#define RT5677_SEL_DAC3_R_SRC_MASK (0x7 << 0) +#define RT5677_SEL_DAC3_R_SRC_SFT 0 + +/* DAC4 Digital Volume (0x17) */ +#define RT5677_DAC4_L_VOL_MASK (0xff << 8) +#define RT5677_DAC4_L_VOL_SFT 8 +#define RT5677_DAC4_R_VOL_MASK (0xff) +#define RT5677_DAC4_R_VOL_SFT 0 + +/* DAC3 Digital Volume (0x18) */ +#define RT5677_DAC3_L_VOL_MASK (0xff << 8) +#define RT5677_DAC3_L_VOL_SFT 8 +#define RT5677_DAC3_R_VOL_MASK (0xff) +#define RT5677_DAC3_R_VOL_SFT 0 + +/* DAC3 Digital Volume (0x19) */ +#define RT5677_DAC1_L_VOL_MASK (0xff << 8) +#define RT5677_DAC1_L_VOL_SFT 8 +#define RT5677_DAC1_R_VOL_MASK (0xff) +#define RT5677_DAC1_R_VOL_SFT 0 + +/* DAC2 Digital Volume (0x1a) */ +#define RT5677_DAC2_L_VOL_MASK (0xff << 8) +#define RT5677_DAC2_L_VOL_SFT 8 +#define RT5677_DAC2_R_VOL_MASK (0xff) +#define RT5677_DAC2_R_VOL_SFT 0 + +/* IF/DSP to DAC2 Mixer Control (0x1b) */ +#define RT5677_M_DAC2_L_VOL (0x1 << 7) +#define RT5677_M_DAC2_L_VOL_SFT 7 +#define RT5677_SEL_DAC2_L_SRC_MASK (0x7 << 4) +#define RT5677_SEL_DAC2_L_SRC_SFT 4 +#define RT5677_M_DAC2_R_VOL (0x1 << 3) +#define RT5677_M_DAC2_R_VOL_SFT 3 +#define RT5677_SEL_DAC2_R_SRC_MASK (0x7 << 0) +#define RT5677_SEL_DAC2_R_SRC_SFT 0 + +/* Stereo1 ADC Digital Volume Control (0x1c) */ +#define RT5677_STO1_ADC_L_VOL_MASK (0x7f << 8) +#define RT5677_STO1_ADC_L_VOL_SFT 8 +#define RT5677_STO1_ADC_R_VOL_MASK (0x7f) +#define RT5677_STO1_ADC_R_VOL_SFT 0 + +/* Mono ADC Digital Volume Control (0x1d) */ +#define RT5677_MONO_ADC_L_VOL_MASK (0x7f << 8) +#define RT5677_MONO_ADC_L_VOL_SFT 8 +#define RT5677_MONO_ADC_R_VOL_MASK (0x7f) +#define RT5677_MONO_ADC_R_VOL_SFT 0 + +/* Stereo 1/2 ADC Boost Gain Control (0x1e) */ +#define RT5677_STO1_ADC_L_BST_MASK (0x3 << 14) +#define RT5677_STO1_ADC_L_BST_SFT 14 +#define RT5677_STO1_ADC_R_BST_MASK (0x3 << 12) +#define RT5677_STO1_ADC_R_BST_SFT 12 +#define RT5677_STO1_ADC_COMP_MASK (0x3 << 10) +#define RT5677_STO1_ADC_COMP_SFT 10 +#define RT5677_STO2_ADC_L_BST_MASK (0x3 << 8) +#define RT5677_STO2_ADC_L_BST_SFT 8 +#define RT5677_STO2_ADC_R_BST_MASK (0x3 << 6) +#define RT5677_STO2_ADC_R_BST_SFT 6 +#define RT5677_STO2_ADC_COMP_MASK (0x3 << 4) +#define RT5677_STO2_ADC_COMP_SFT 4 + +/* Stereo2 ADC Digital Volume Control (0x1f) */ +#define RT5677_STO2_ADC_L_VOL_MASK (0x7f << 8) +#define RT5677_STO2_ADC_L_VOL_SFT 8 +#define RT5677_STO2_ADC_R_VOL_MASK (0x7f) +#define RT5677_STO2_ADC_R_VOL_SFT 0 + +/* ADC Boost Gain Control 2 (0x20) */ +#define RT5677_MONO_ADC_L_BST_MASK (0x3 << 14) +#define RT5677_MONO_ADC_L_BST_SFT 14 +#define RT5677_MONO_ADC_R_BST_MASK (0x3 << 12) +#define RT5677_MONO_ADC_R_BST_SFT 12 +#define RT5677_MONO_ADC_COMP_MASK (0x3 << 10) +#define RT5677_MONO_ADC_COMP_SFT 10 + +/* Stereo 3/4 ADC Boost Gain Control (0x21) */ +#define RT5677_STO3_ADC_L_BST_MASK (0x3 << 14) +#define RT5677_STO3_ADC_L_BST_SFT 14 +#define RT5677_STO3_ADC_R_BST_MASK (0x3 << 12) +#define RT5677_STO3_ADC_R_BST_SFT 12 +#define RT5677_STO3_ADC_COMP_MASK (0x3 << 10) +#define RT5677_STO3_ADC_COMP_SFT 10 +#define RT5677_STO4_ADC_L_BST_MASK (0x3 << 8) +#define RT5677_STO4_ADC_L_BST_SFT 8 +#define RT5677_STO4_ADC_R_BST_MASK (0x3 << 6) +#define RT5677_STO4_ADC_R_BST_SFT 6 +#define RT5677_STO4_ADC_COMP_MASK (0x3 << 4) +#define RT5677_STO4_ADC_COMP_SFT 4 + +/* Stereo3 ADC Digital Volume Control (0x22) */ +#define RT5677_STO3_ADC_L_VOL_MASK (0x7f << 8) +#define RT5677_STO3_ADC_L_VOL_SFT 8 +#define RT5677_STO3_ADC_R_VOL_MASK (0x7f) +#define RT5677_STO3_ADC_R_VOL_SFT 0 + +/* Stereo4 ADC Digital Volume Control (0x23) */ +#define RT5677_STO4_ADC_L_VOL_MASK (0x7f << 8) +#define RT5677_STO4_ADC_L_VOL_SFT 8 +#define RT5677_STO4_ADC_R_VOL_MASK (0x7f) +#define RT5677_STO4_ADC_R_VOL_SFT 0 + +/* Stereo4 ADC Mixer control (0x24) */ +#define RT5677_M_STO4_ADC_L2 (0x1 << 15) +#define RT5677_M_STO4_ADC_L2_SFT 15 +#define RT5677_M_STO4_ADC_L1 (0x1 << 14) +#define RT5677_M_STO4_ADC_L1_SFT 14 +#define RT5677_SEL_STO4_ADC1_MASK (0x3 << 12) +#define RT5677_SEL_STO4_ADC1_SFT 12 +#define RT5677_SEL_STO4_ADC2_MASK (0x3 << 10) +#define RT5677_SEL_STO4_ADC2_SFT 10 +#define RT5677_SEL_STO4_DMIC_MASK (0x3 << 8) +#define RT5677_SEL_STO4_DMIC_SFT 8 +#define RT5677_M_STO4_ADC_R1 (0x1 << 7) +#define RT5677_M_STO4_ADC_R1_SFT 7 +#define RT5677_M_STO4_ADC_R2 (0x1 << 6) +#define RT5677_M_STO4_ADC_R2_SFT 6 + +/* Stereo3 ADC Mixer control (0x25) */ +#define RT5677_M_STO3_ADC_L2 (0x1 << 15) +#define RT5677_M_STO3_ADC_L2_SFT 15 +#define RT5677_M_STO3_ADC_L1 (0x1 << 14) +#define RT5677_M_STO3_ADC_L1_SFT 14 +#define RT5677_SEL_STO3_ADC1_MASK (0x3 << 12) +#define RT5677_SEL_STO3_ADC1_SFT 12 +#define RT5677_SEL_STO3_ADC2_MASK (0x3 << 10) +#define RT5677_SEL_STO3_ADC2_SFT 10 +#define RT5677_SEL_STO3_DMIC_MASK (0x3 << 8) +#define RT5677_SEL_STO3_DMIC_SFT 8 +#define RT5677_M_STO3_ADC_R1 (0x1 << 7) +#define RT5677_M_STO3_ADC_R1_SFT 7 +#define RT5677_M_STO3_ADC_R2 (0x1 << 6) +#define RT5677_M_STO3_ADC_R2_SFT 6 + +/* Stereo2 ADC Mixer Control (0x26) */ +#define RT5677_M_STO2_ADC_L2 (0x1 << 15) +#define RT5677_M_STO2_ADC_L2_SFT 15 +#define RT5677_M_STO2_ADC_L1 (0x1 << 14) +#define RT5677_M_STO2_ADC_L1_SFT 14 +#define RT5677_SEL_STO2_ADC1_MASK (0x3 << 12) +#define RT5677_SEL_STO2_ADC1_SFT 12 +#define RT5677_SEL_STO2_ADC2_MASK (0x3 << 10) +#define RT5677_SEL_STO2_ADC2_SFT 10 +#define RT5677_SEL_STO2_DMIC_MASK (0x3 << 8) +#define RT5677_SEL_STO2_DMIC_SFT 8 +#define RT5677_M_STO2_ADC_R1 (0x1 << 7) +#define RT5677_M_STO2_ADC_R1_SFT 7 +#define RT5677_M_STO2_ADC_R2 (0x1 << 6) +#define RT5677_M_STO2_ADC_R2_SFT 6 +#define RT5677_SEL_STO2_LR_MIX_MASK (0x1 << 0) +#define RT5677_SEL_STO2_LR_MIX_SFT 0 +#define RT5677_SEL_STO2_LR_MIX_L (0x0 << 0) +#define RT5677_SEL_STO2_LR_MIX_LR (0x1 << 0) + +/* Stereo1 ADC Mixer control (0x27) */ +#define RT5677_M_STO1_ADC_L2 (0x1 << 15) +#define RT5677_M_STO1_ADC_L2_SFT 15 +#define RT5677_M_STO1_ADC_L1 (0x1 << 14) +#define RT5677_M_STO1_ADC_L1_SFT 14 +#define RT5677_SEL_STO1_ADC1_MASK (0x3 << 12) +#define RT5677_SEL_STO1_ADC1_SFT 12 +#define RT5677_SEL_STO1_ADC2_MASK (0x3 << 10) +#define RT5677_SEL_STO1_ADC2_SFT 10 +#define RT5677_SEL_STO1_DMIC_MASK (0x3 << 8) +#define RT5677_SEL_STO1_DMIC_SFT 8 +#define RT5677_M_STO1_ADC_R1 (0x1 << 7) +#define RT5677_M_STO1_ADC_R1_SFT 7 +#define RT5677_M_STO1_ADC_R2 (0x1 << 6) +#define RT5677_M_STO1_ADC_R2_SFT 6 + +/* Mono ADC Mixer control (0x28) */ +#define RT5677_M_MONO_ADC_L2 (0x1 << 15) +#define RT5677_M_MONO_ADC_L2_SFT 15 +#define RT5677_M_MONO_ADC_L1 (0x1 << 14) +#define RT5677_M_MONO_ADC_L1_SFT 14 +#define RT5677_SEL_MONO_ADC_L1_MASK (0x3 << 12) +#define RT5677_SEL_MONO_ADC_L1_SFT 12 +#define RT5677_SEL_MONO_ADC_L2_MASK (0x3 << 10) +#define RT5677_SEL_MONO_ADC_L2_SFT 10 +#define RT5677_SEL_MONO_DMIC_L_MASK (0x3 << 8) +#define RT5677_SEL_MONO_DMIC_L_SFT 8 +#define RT5677_M_MONO_ADC_R1 (0x1 << 7) +#define RT5677_M_MONO_ADC_R1_SFT 7 +#define RT5677_M_MONO_ADC_R2 (0x1 << 6) +#define RT5677_M_MONO_ADC_R2_SFT 6 +#define RT5677_SEL_MONO_ADC_R1_MASK (0x3 << 4) +#define RT5677_SEL_MONO_ADC_R1_SFT 4 +#define RT5677_SEL_MONO_ADC_R2_MASK (0x3 << 2) +#define RT5677_SEL_MONO_ADC_R2_SFT 2 +#define RT5677_SEL_MONO_DMIC_R_MASK (0x3 << 0) +#define RT5677_SEL_MONO_DMIC_R_SFT 0 + +/* ADC/IF/DSP to DAC1 Mixer control (0x29) */ +#define RT5677_M_ADDA_MIXER1_L (0x1 << 15) +#define RT5677_M_ADDA_MIXER1_L_SFT 15 +#define RT5677_M_DAC1_L (0x1 << 14) +#define RT5677_M_DAC1_L_SFT 14 +#define RT5677_DAC1_L_SEL_MASK (0x7 << 8) +#define RT5677_DAC1_L_SEL_SFT 8 +#define RT5677_M_ADDA_MIXER1_R (0x1 << 7) +#define RT5677_M_ADDA_MIXER1_R_SFT 7 +#define RT5677_M_DAC1_R (0x1 << 6) +#define RT5677_M_DAC1_R_SFT 6 +#define RT5677_ADDA1_SEL_MASK (0x3 << 0) +#define RT5677_ADDA1_SEL_SFT 0 + +/* Stereo1 DAC Mixer L/R Control (0x2a) */ +#define RT5677_M_ST_DAC1_L (0x1 << 15) +#define RT5677_M_ST_DAC1_L_SFT 15 +#define RT5677_M_DAC1_L_STO_L (0x1 << 13) +#define RT5677_M_DAC1_L_STO_L_SFT 13 +#define RT5677_DAC1_L_STO_L_VOL_MASK (0x1 << 12) +#define RT5677_DAC1_L_STO_L_VOL_SFT 12 +#define RT5677_M_DAC2_L_STO_L (0x1 << 11) +#define RT5677_M_DAC2_L_STO_L_SFT 11 +#define RT5677_DAC2_L_STO_L_VOL_MASK (0x1 << 10) +#define RT5677_DAC2_L_STO_L_VOL_SFT 10 +#define RT5677_M_DAC1_R_STO_L (0x1 << 9) +#define RT5677_M_DAC1_R_STO_L_SFT 9 +#define RT5677_DAC1_R_STO_L_VOL_MASK (0x1 << 8) +#define RT5677_DAC1_R_STO_L_VOL_SFT 8 +#define RT5677_M_ST_DAC1_R (0x1 << 7) +#define RT5677_M_ST_DAC1_R_SFT 7 +#define RT5677_M_DAC1_R_STO_R (0x1 << 5) +#define RT5677_M_DAC1_R_STO_R_SFT 5 +#define RT5677_DAC1_R_STO_R_VOL_MASK (0x1 << 4) +#define RT5677_DAC1_R_STO_R_VOL_SFT 4 +#define RT5677_M_DAC2_R_STO_R (0x1 << 3) +#define RT5677_M_DAC2_R_STO_R_SFT 3 +#define RT5677_DAC2_R_STO_R_VOL_MASK (0x1 << 2) +#define RT5677_DAC2_R_STO_R_VOL_SFT 2 +#define RT5677_M_DAC1_L_STO_R (0x1 << 1) +#define RT5677_M_DAC1_L_STO_R_SFT 1 +#define RT5677_DAC1_L_STO_R_VOL_MASK (0x1 << 0) +#define RT5677_DAC1_L_STO_R_VOL_SFT 0 + +/* Mono DAC Mixer L/R Control (0x2b) */ +#define RT5677_M_ST_DAC2_L (0x1 << 15) +#define RT5677_M_ST_DAC2_L_SFT 15 +#define RT5677_M_DAC2_L_MONO_L (0x1 << 13) +#define RT5677_M_DAC2_L_MONO_L_SFT 13 +#define RT5677_DAC2_L_MONO_L_VOL_MASK (0x1 << 12) +#define RT5677_DAC2_L_MONO_L_VOL_SFT 12 +#define RT5677_M_DAC2_R_MONO_L (0x1 << 11) +#define RT5677_M_DAC2_R_MONO_L_SFT 11 +#define RT5677_DAC2_R_MONO_L_VOL_MASK (0x1 << 10) +#define RT5677_DAC2_R_MONO_L_VOL_SFT 10 +#define RT5677_M_DAC1_L_MONO_L (0x1 << 9) +#define RT5677_M_DAC1_L_MONO_L_SFT 9 +#define RT5677_DAC1_L_MONO_L_VOL_MASK (0x1 << 8) +#define RT5677_DAC1_L_MONO_L_VOL_SFT 8 +#define RT5677_M_ST_DAC2_R (0x1 << 7) +#define RT5677_M_ST_DAC2_R_SFT 7 +#define RT5677_M_DAC2_R_MONO_R (0x1 << 5) +#define RT5677_M_DAC2_R_MONO_R_SFT 5 +#define RT5677_DAC2_R_MONO_R_VOL_MASK (0x1 << 4) +#define RT5677_DAC2_R_MONO_R_VOL_SFT 4 +#define RT5677_M_DAC1_R_MONO_R (0x1 << 3) +#define RT5677_M_DAC1_R_MONO_R_SFT 3 +#define RT5677_DAC1_R_MONO_R_VOL_MASK (0x1 << 2) +#define RT5677_DAC1_R_MONO_R_VOL_SFT 2 +#define RT5677_M_DAC2_L_MONO_R (0x1 << 1) +#define RT5677_M_DAC2_L_MONO_R_SFT 1 +#define RT5677_DAC2_L_MONO_R_VOL_MASK (0x1 << 0) +#define RT5677_DAC2_L_MONO_R_VOL_SFT 0 + +/* DD Mixer 1 Control (0x2c) */ +#define RT5677_M_STO_L_DD1_L (0x1 << 15) +#define RT5677_M_STO_L_DD1_L_SFT 15 +#define RT5677_STO_L_DD1_L_VOL_MASK (0x1 << 14) +#define RT5677_STO_L_DD1_L_VOL_SFT 14 +#define RT5677_M_MONO_L_DD1_L (0x1 << 13) +#define RT5677_M_MONO_L_DD1_L_SFT 13 +#define RT5677_MONO_L_DD1_L_VOL_MASK (0x1 << 12) +#define RT5677_MONO_L_DD1_L_VOL_SFT 12 +#define RT5677_M_DAC3_L_DD1_L (0x1 << 11) +#define RT5677_M_DAC3_L_DD1_L_SFT 11 +#define RT5677_DAC3_L_DD1_L_VOL_MASK (0x1 << 10) +#define RT5677_DAC3_L_DD1_L_VOL_SFT 10 +#define RT5677_M_DAC3_R_DD1_L (0x1 << 9) +#define RT5677_M_DAC3_R_DD1_L_SFT 9 +#define RT5677_DAC3_R_DD1_L_VOL_MASK (0x1 << 8) +#define RT5677_DAC3_R_DD1_L_VOL_SFT 8 +#define RT5677_M_STO_R_DD1_R (0x1 << 7) +#define RT5677_M_STO_R_DD1_R_SFT 7 +#define RT5677_STO_R_DD1_R_VOL_MASK (0x1 << 6) +#define RT5677_STO_R_DD1_R_VOL_SFT 6 +#define RT5677_M_MONO_R_DD1_R (0x1 << 5) +#define RT5677_M_MONO_R_DD1_R_SFT 5 +#define RT5677_MONO_R_DD1_R_VOL_MASK (0x1 << 4) +#define RT5677_MONO_R_DD1_R_VOL_SFT 4 +#define RT5677_M_DAC3_R_DD1_R (0x1 << 3) +#define RT5677_M_DAC3_R_DD1_R_SFT 3 +#define RT5677_DAC3_R_DD1_R_VOL_MASK (0x1 << 2) +#define RT5677_DAC3_R_DD1_R_VOL_SFT 2 +#define RT5677_M_DAC3_L_DD1_R (0x1 << 1) +#define RT5677_M_DAC3_L_DD1_R_SFT 1 +#define RT5677_DAC3_L_DD1_R_VOL_MASK (0x1 << 0) +#define RT5677_DAC3_L_DD1_R_VOL_SFT 0 + +/* DD Mixer 2 Control (0x2d) */ +#define RT5677_M_STO_L_DD2_L (0x1 << 15) +#define RT5677_M_STO_L_DD2_L_SFT 15 +#define RT5677_STO_L_DD2_L_VOL_MASK (0x1 << 14) +#define RT5677_STO_L_DD2_L_VOL_SFT 14 +#define RT5677_M_MONO_L_DD2_L (0x1 << 13) +#define RT5677_M_MONO_L_DD2_L_SFT 13 +#define RT5677_MONO_L_DD2_L_VOL_MASK (0x1 << 12) +#define RT5677_MONO_L_DD2_L_VOL_SFT 12 +#define RT5677_M_DAC4_L_DD2_L (0x1 << 11) +#define RT5677_M_DAC4_L_DD2_L_SFT 11 +#define RT5677_DAC4_L_DD2_L_VOL_MASK (0x1 << 10) +#define RT5677_DAC4_L_DD2_L_VOL_SFT 10 +#define RT5677_M_DAC4_R_DD2_L (0x1 << 9) +#define RT5677_M_DAC4_R_DD2_L_SFT 9 +#define RT5677_DAC4_R_DD2_L_VOL_MASK (0x1 << 8) +#define RT5677_DAC4_R_DD2_L_VOL_SFT 8 +#define RT5677_M_STO_R_DD2_R (0x1 << 7) +#define RT5677_M_STO_R_DD2_R_SFT 7 +#define RT5677_STO_R_DD2_R_VOL_MASK (0x1 << 6) +#define RT5677_STO_R_DD2_R_VOL_SFT 6 +#define RT5677_M_MONO_R_DD2_R (0x1 << 5) +#define RT5677_M_MONO_R_DD2_R_SFT 5 +#define RT5677_MONO_R_DD2_R_VOL_MASK (0x1 << 4) +#define RT5677_MONO_R_DD2_R_VOL_SFT 4 +#define RT5677_M_DAC4_R_DD2_R (0x1 << 3) +#define RT5677_M_DAC4_R_DD2_R_SFT 3 +#define RT5677_DAC4_R_DD2_R_VOL_MASK (0x1 << 2) +#define RT5677_DAC4_R_DD2_R_VOL_SFT 2 +#define RT5677_M_DAC4_L_DD2_R (0x1 << 1) +#define RT5677_M_DAC4_L_DD2_R_SFT 1 +#define RT5677_DAC4_L_DD2_R_VOL_MASK (0x1 << 0) +#define RT5677_DAC4_L_DD2_R_VOL_SFT 0 + +/* IF3 data control (0x2f) */ +#define RT5677_IF3_DAC_SEL_MASK (0x3 << 6) +#define RT5677_IF3_DAC_SEL_SFT 6 +#define RT5677_IF3_ADC_SEL_MASK (0x3 << 4) +#define RT5677_IF3_ADC_SEL_SFT 4 +#define RT5677_IF3_ADC_IN_MASK (0xf << 0) +#define RT5677_IF3_ADC_IN_SFT 0 + +/* IF4 data control (0x30) */ +#define RT5677_IF4_ADC_IN_MASK (0xf << 4) +#define RT5677_IF4_ADC_IN_SFT 4 +#define RT5677_IF4_DAC_SEL_MASK (0x3 << 2) +#define RT5677_IF4_DAC_SEL_SFT 2 +#define RT5677_IF4_ADC_SEL_MASK (0x3 << 0) +#define RT5677_IF4_ADC_SEL_SFT 0 + +/* PDM Output Control (0x31) */ +#define RT5677_M_PDM1_L (0x1 << 15) +#define RT5677_M_PDM1_L_SFT 15 +#define RT5677_SEL_PDM1_L_MASK (0x3 << 12) +#define RT5677_SEL_PDM1_L_SFT 12 +#define RT5677_M_PDM1_R (0x1 << 11) +#define RT5677_M_PDM1_R_SFT 11 +#define RT5677_SEL_PDM1_R_MASK (0x3 << 8) +#define RT5677_SEL_PDM1_R_SFT 8 +#define RT5677_M_PDM2_L (0x1 << 7) +#define RT5677_M_PDM2_L_SFT 7 +#define RT5677_SEL_PDM2_L_MASK (0x3 << 4) +#define RT5677_SEL_PDM2_L_SFT 4 +#define RT5677_M_PDM2_R (0x1 << 3) +#define RT5677_M_PDM2_R_SFT 3 +#define RT5677_SEL_PDM2_R_MASK (0x3 << 0) +#define RT5677_SEL_PDM2_R_SFT 0 + +/* PDM I2C / Data Control 1 (0x32) */ +#define RT5677_PDM2_PW_DOWN (0x1 << 7) +#define RT5677_PDM1_PW_DOWN (0x1 << 6) +#define RT5677_PDM2_BUSY (0x1 << 5) +#define RT5677_PDM1_BUSY (0x1 << 4) +#define RT5677_PDM_PATTERN (0x1 << 3) +#define RT5677_PDM_GAIN (0x1 << 2) +#define RT5677_PDM_DIV_MASK (0x3 << 0) + +/* PDM I2C / Data Control 2 (0x33) */ +#define RT5677_PDM1_I2C_ID (0xf << 12) +#define RT5677_PDM1_EXE (0x1 << 11) +#define RT5677_PDM1_I2C_CMD (0x1 << 10) +#define RT5677_PDM1_I2C_EXE (0x1 << 9) +#define RT5677_PDM1_I2C_BUSY (0x1 << 8) +#define RT5677_PDM2_I2C_ID (0xf << 4) +#define RT5677_PDM2_EXE (0x1 << 3) +#define RT5677_PDM2_I2C_CMD (0x1 << 2) +#define RT5677_PDM2_I2C_EXE (0x1 << 1) +#define RT5677_PDM2_I2C_BUSY (0x1 << 0) + +/* MX3C TDM1 control 1 (0x3c) */ +#define RT5677_IF1_ADC4_MASK (0x3 << 10) +#define RT5677_IF1_ADC4_SFT 10 +#define RT5677_IF1_ADC3_MASK (0x3 << 8) +#define RT5677_IF1_ADC3_SFT 8 +#define RT5677_IF1_ADC2_MASK (0x3 << 6) +#define RT5677_IF1_ADC2_SFT 6 +#define RT5677_IF1_ADC1_MASK (0x3 << 4) +#define RT5677_IF1_ADC1_SFT 4 + +/* MX41 TDM2 control 1 (0x41) */ +#define RT5677_IF2_ADC4_MASK (0x3 << 10) +#define RT5677_IF2_ADC4_SFT 10 +#define RT5677_IF2_ADC3_MASK (0x3 << 8) +#define RT5677_IF2_ADC3_SFT 8 +#define RT5677_IF2_ADC2_MASK (0x3 << 6) +#define RT5677_IF2_ADC2_SFT 6 +#define RT5677_IF2_ADC1_MASK (0x3 << 4) +#define RT5677_IF2_ADC1_SFT 4 + +/* Digital Microphone Control 1 (0x50) */ +#define RT5677_DMIC_1_EN_MASK (0x1 << 15) +#define RT5677_DMIC_1_EN_SFT 15 +#define RT5677_DMIC_1_DIS (0x0 << 15) +#define RT5677_DMIC_1_EN (0x1 << 15) +#define RT5677_DMIC_2_EN_MASK (0x1 << 14) +#define RT5677_DMIC_2_EN_SFT 14 +#define RT5677_DMIC_2_DIS (0x0 << 14) +#define RT5677_DMIC_2_EN (0x1 << 14) +#define RT5677_DMIC_L_STO1_LH_MASK (0x1 << 13) +#define RT5677_DMIC_L_STO1_LH_SFT 13 +#define RT5677_DMIC_L_STO1_LH_FALLING (0x0 << 13) +#define RT5677_DMIC_L_STO1_LH_RISING (0x1 << 13) +#define RT5677_DMIC_R_STO1_LH_MASK (0x1 << 12) +#define RT5677_DMIC_R_STO1_LH_SFT 12 +#define RT5677_DMIC_R_STO1_LH_FALLING (0x0 << 12) +#define RT5677_DMIC_R_STO1_LH_RISING (0x1 << 12) +#define RT5677_DMIC_L_STO3_LH_MASK (0x1 << 11) +#define RT5677_DMIC_L_STO3_LH_SFT 11 +#define RT5677_DMIC_L_STO3_LH_FALLING (0x0 << 11) +#define RT5677_DMIC_L_STO3_LH_RISING (0x1 << 11) +#define RT5677_DMIC_R_STO3_LH_MASK (0x1 << 10) +#define RT5677_DMIC_R_STO3_LH_SFT 10 +#define RT5677_DMIC_R_STO3_LH_FALLING (0x0 << 10) +#define RT5677_DMIC_R_STO3_LH_RISING (0x1 << 10) +#define RT5677_DMIC_L_STO2_LH_MASK (0x1 << 9) +#define RT5677_DMIC_L_STO2_LH_SFT 9 +#define RT5677_DMIC_L_STO2_LH_FALLING (0x0 << 9) +#define RT5677_DMIC_L_STO2_LH_RISING (0x1 << 9) +#define RT5677_DMIC_R_STO2_LH_MASK (0x1 << 8) +#define RT5677_DMIC_R_STO2_LH_SFT 8 +#define RT5677_DMIC_R_STO2_LH_FALLING (0x0 << 8) +#define RT5677_DMIC_R_STO2_LH_RISING (0x1 << 8) +#define RT5677_DMIC_CLK_MASK (0x7 << 5) +#define RT5677_DMIC_CLK_SFT 5 +#define RT5677_DMIC_3_EN_MASK (0x1 << 4) +#define RT5677_DMIC_3_EN_SFT 4 +#define RT5677_DMIC_3_DIS (0x0 << 4) +#define RT5677_DMIC_3_EN (0x1 << 4) +#define RT5677_DMIC_R_MONO_LH_MASK (0x1 << 2) +#define RT5677_DMIC_R_MONO_LH_SFT 2 +#define RT5677_DMIC_R_MONO_LH_FALLING (0x0 << 2) +#define RT5677_DMIC_R_MONO_LH_RISING (0x1 << 2) +#define RT5677_DMIC_L_STO4_LH_MASK (0x1 << 1) +#define RT5677_DMIC_L_STO4_LH_SFT 1 +#define RT5677_DMIC_L_STO4_LH_FALLING (0x0 << 1) +#define RT5677_DMIC_L_STO4_LH_RISING (0x1 << 1) +#define RT5677_DMIC_R_STO4_LH_MASK (0x1 << 0) +#define RT5677_DMIC_R_STO4_LH_SFT 0 +#define RT5677_DMIC_R_STO4_LH_FALLING (0x0 << 0) +#define RT5677_DMIC_R_STO4_LH_RISING (0x1 << 0) + +/* Digital Microphone Control 2 (0x51) */ +#define RT5677_DMIC_4_EN_MASK (0x1 << 15) +#define RT5677_DMIC_4_EN_SFT 15 +#define RT5677_DMIC_4_DIS (0x0 << 15) +#define RT5677_DMIC_4_EN (0x1 << 15) +#define RT5677_DMIC_4L_LH_MASK (0x1 << 7) +#define RT5677_DMIC_4L_LH_SFT 7 +#define RT5677_DMIC_4L_LH_FALLING (0x0 << 7) +#define RT5677_DMIC_4L_LH_RISING (0x1 << 7) +#define RT5677_DMIC_4R_LH_MASK (0x1 << 6) +#define RT5677_DMIC_4R_LH_SFT 6 +#define RT5677_DMIC_4R_LH_FALLING (0x0 << 6) +#define RT5677_DMIC_4R_LH_RISING (0x1 << 6) +#define RT5677_DMIC_3L_LH_MASK (0x1 << 5) +#define RT5677_DMIC_3L_LH_SFT 5 +#define RT5677_DMIC_3L_LH_FALLING (0x0 << 5) +#define RT5677_DMIC_3L_LH_RISING (0x1 << 5) +#define RT5677_DMIC_3R_LH_MASK (0x1 << 4) +#define RT5677_DMIC_3R_LH_SFT 4 +#define RT5677_DMIC_3R_LH_FALLING (0x0 << 4) +#define RT5677_DMIC_3R_LH_RISING (0x1 << 4) +#define RT5677_DMIC_2L_LH_MASK (0x1 << 3) +#define RT5677_DMIC_2L_LH_SFT 3 +#define RT5677_DMIC_2L_LH_FALLING (0x0 << 3) +#define RT5677_DMIC_2L_LH_RISING (0x1 << 3) +#define RT5677_DMIC_2R_LH_MASK (0x1 << 2) +#define RT5677_DMIC_2R_LH_SFT 2 +#define RT5677_DMIC_2R_LH_FALLING (0x0 << 2) +#define RT5677_DMIC_2R_LH_RISING (0x1 << 2) +#define RT5677_DMIC_1L_LH_MASK (0x1 << 1) +#define RT5677_DMIC_1L_LH_SFT 1 +#define RT5677_DMIC_1L_LH_FALLING (0x0 << 1) +#define RT5677_DMIC_1L_LH_RISING (0x1 << 1) +#define RT5677_DMIC_1R_LH_MASK (0x1 << 0) +#define RT5677_DMIC_1R_LH_SFT 0 +#define RT5677_DMIC_1R_LH_FALLING (0x0 << 0) +#define RT5677_DMIC_1R_LH_RISING (0x1 << 0) + +/* Power Management for Digital 1 (0x61) */ +#define RT5677_PWR_I2S1 (0x1 << 15) +#define RT5677_PWR_I2S1_BIT 15 +#define RT5677_PWR_I2S2 (0x1 << 14) +#define RT5677_PWR_I2S2_BIT 14 +#define RT5677_PWR_I2S3 (0x1 << 13) +#define RT5677_PWR_I2S3_BIT 13 +#define RT5677_PWR_DAC1 (0x1 << 12) +#define RT5677_PWR_DAC1_BIT 12 +#define RT5677_PWR_DAC2 (0x1 << 11) +#define RT5677_PWR_DAC2_BIT 11 +#define RT5677_PWR_I2S4 (0x1 << 10) +#define RT5677_PWR_I2S4_BIT 10 +#define RT5677_PWR_SLB (0x1 << 9) +#define RT5677_PWR_SLB_BIT 9 +#define RT5677_PWR_DAC3 (0x1 << 7) +#define RT5677_PWR_DAC3_BIT 7 +#define RT5677_PWR_ADCFED2 (0x1 << 4) +#define RT5677_PWR_ADCFED2_BIT 4 +#define RT5677_PWR_ADCFED1 (0x1 << 3) +#define RT5677_PWR_ADCFED1_BIT 3 +#define RT5677_PWR_ADC_L (0x1 << 2) +#define RT5677_PWR_ADC_L_BIT 2 +#define RT5677_PWR_ADC_R (0x1 << 1) +#define RT5677_PWR_ADC_R_BIT 1 +#define RT5677_PWR_I2C_MASTER (0x1 << 0) +#define RT5677_PWR_I2C_MASTER_BIT 0 + +/* Power Management for Digital 2 (0x62) */ +#define RT5677_PWR_ADC_S1F (0x1 << 15) +#define RT5677_PWR_ADC_S1F_BIT 15 +#define RT5677_PWR_ADC_MF_L (0x1 << 14) +#define RT5677_PWR_ADC_MF_L_BIT 14 +#define RT5677_PWR_ADC_MF_R (0x1 << 13) +#define RT5677_PWR_ADC_MF_R_BIT 13 +#define RT5677_PWR_DAC_S1F (0x1 << 12) +#define RT5677_PWR_DAC_S1F_BIT 12 +#define RT5677_PWR_DAC_M2F_L (0x1 << 11) +#define RT5677_PWR_DAC_M2F_L_BIT 11 +#define RT5677_PWR_DAC_M2F_R (0x1 << 10) +#define RT5677_PWR_DAC_M2F_R_BIT 10 +#define RT5677_PWR_DAC_M3F_L (0x1 << 9) +#define RT5677_PWR_DAC_M3F_L_BIT 9 +#define RT5677_PWR_DAC_M3F_R (0x1 << 8) +#define RT5677_PWR_DAC_M3F_R_BIT 8 +#define RT5677_PWR_DAC_M4F_L (0x1 << 7) +#define RT5677_PWR_DAC_M4F_L_BIT 7 +#define RT5677_PWR_DAC_M4F_R (0x1 << 6) +#define RT5677_PWR_DAC_M4F_R_BIT 6 +#define RT5677_PWR_ADC_S2F (0x1 << 5) +#define RT5677_PWR_ADC_S2F_BIT 5 +#define RT5677_PWR_ADC_S3F (0x1 << 4) +#define RT5677_PWR_ADC_S3F_BIT 4 +#define RT5677_PWR_ADC_S4F (0x1 << 3) +#define RT5677_PWR_ADC_S4F_BIT 3 +#define RT5677_PWR_PDM1 (0x1 << 2) +#define RT5677_PWR_PDM1_BIT 2 +#define RT5677_PWR_PDM2 (0x1 << 1) +#define RT5677_PWR_PDM2_BIT 1 + +/* Power Management for Analog 1 (0x63) */ +#define RT5677_PWR_VREF1 (0x1 << 15) +#define RT5677_PWR_VREF1_BIT 15 +#define RT5677_PWR_FV1 (0x1 << 14) +#define RT5677_PWR_FV1_BIT 14 +#define RT5677_PWR_MB (0x1 << 13) +#define RT5677_PWR_MB_BIT 13 +#define RT5677_PWR_LO1 (0x1 << 12) +#define RT5677_PWR_LO1_BIT 12 +#define RT5677_PWR_BG (0x1 << 11) +#define RT5677_PWR_BG_BIT 11 +#define RT5677_PWR_LO2 (0x1 << 10) +#define RT5677_PWR_LO2_BIT 10 +#define RT5677_PWR_LO3 (0x1 << 9) +#define RT5677_PWR_LO3_BIT 9 +#define RT5677_PWR_VREF2 (0x1 << 8) +#define RT5677_PWR_VREF2_BIT 8 +#define RT5677_PWR_FV2 (0x1 << 7) +#define RT5677_PWR_FV2_BIT 7 +#define RT5677_LDO2_SEL_MASK (0x7 << 4) +#define RT5677_LDO2_SEL_SFT 4 +#define RT5677_LDO1_SEL_MASK (0x7 << 0) +#define RT5677_LDO1_SEL_SFT 0 + +/* Power Management for Analog 2 (0x64) */ +#define RT5677_PWR_BST1 (0x1 << 15) +#define RT5677_PWR_BST1_BIT 15 +#define RT5677_PWR_BST2 (0x1 << 14) +#define RT5677_PWR_BST2_BIT 14 +#define RT5677_PWR_CLK_MB1 (0x1 << 13) +#define RT5677_PWR_CLK_MB1_BIT 13 +#define RT5677_PWR_SLIM (0x1 << 12) +#define RT5677_PWR_SLIM_BIT 12 +#define RT5677_PWR_MB1 (0x1 << 11) +#define RT5677_PWR_MB1_BIT 11 +#define RT5677_PWR_PP_MB1 (0x1 << 10) +#define RT5677_PWR_PP_MB1_BIT 10 +#define RT5677_PWR_PLL1 (0x1 << 9) +#define RT5677_PWR_PLL1_BIT 9 +#define RT5677_PWR_PLL2 (0x1 << 8) +#define RT5677_PWR_PLL2_BIT 8 +#define RT5677_PWR_CORE (0x1 << 7) +#define RT5677_PWR_CORE_BIT 7 +#define RT5677_PWR_CLK_MB (0x1 << 6) +#define RT5677_PWR_CLK_MB_BIT 6 +#define RT5677_PWR_BST1_P (0x1 << 5) +#define RT5677_PWR_BST1_P_BIT 5 +#define RT5677_PWR_BST2_P (0x1 << 4) +#define RT5677_PWR_BST2_P_BIT 4 +#define RT5677_PWR_IPTV (0x1 << 3) +#define RT5677_PWR_IPTV_BIT 3 +#define RT5677_PWR_25M_CLK (0x1 << 1) +#define RT5677_PWR_25M_CLK_BIT 1 +#define RT5677_PWR_LDO1 (0x1 << 0) +#define RT5677_PWR_LDO1_BIT 0 + +/* Power Management for DSP (0x65) */ +#define RT5677_PWR_SR7 (0x1 << 10) +#define RT5677_PWR_SR7_BIT 10 +#define RT5677_PWR_SR6 (0x1 << 9) +#define RT5677_PWR_SR6_BIT 9 +#define RT5677_PWR_SR5 (0x1 << 8) +#define RT5677_PWR_SR5_BIT 8 +#define RT5677_PWR_SR4 (0x1 << 7) +#define RT5677_PWR_SR4_BIT 7 +#define RT5677_PWR_SR3 (0x1 << 6) +#define RT5677_PWR_SR3_BIT 6 +#define RT5677_PWR_SR2 (0x1 << 5) +#define RT5677_PWR_SR2_BIT 5 +#define RT5677_PWR_SR1 (0x1 << 4) +#define RT5677_PWR_SR1_BIT 4 +#define RT5677_PWR_SR0 (0x1 << 3) +#define RT5677_PWR_SR0_BIT 3 +#define RT5677_PWR_MLT (0x1 << 2) +#define RT5677_PWR_MLT_BIT 2 +#define RT5677_PWR_DSP (0x1 << 1) +#define RT5677_PWR_DSP_BIT 1 +#define RT5677_PWR_DSP_CPU (0x1 << 0) +#define RT5677_PWR_DSP_CPU_BIT 0 + +/* Power Status for DSP (0x66) */ +#define RT5677_PWR_SR7_RDY (0x1 << 9) +#define RT5677_PWR_SR7_RDY_BIT 9 +#define RT5677_PWR_SR6_RDY (0x1 << 8) +#define RT5677_PWR_SR6_RDY_BIT 8 +#define RT5677_PWR_SR5_RDY (0x1 << 7) +#define RT5677_PWR_SR5_RDY_BIT 7 +#define RT5677_PWR_SR4_RDY (0x1 << 6) +#define RT5677_PWR_SR4_RDY_BIT 6 +#define RT5677_PWR_SR3_RDY (0x1 << 5) +#define RT5677_PWR_SR3_RDY_BIT 5 +#define RT5677_PWR_SR2_RDY (0x1 << 4) +#define RT5677_PWR_SR2_RDY_BIT 4 +#define RT5677_PWR_SR1_RDY (0x1 << 3) +#define RT5677_PWR_SR1_RDY_BIT 3 +#define RT5677_PWR_SR0_RDY (0x1 << 2) +#define RT5677_PWR_SR0_RDY_BIT 2 +#define RT5677_PWR_MLT_RDY (0x1 << 1) +#define RT5677_PWR_MLT_RDY_BIT 1 +#define RT5677_PWR_DSP_RDY (0x1 << 0) +#define RT5677_PWR_DSP_RDY_BIT 0 + +/* Power Management for DSP (0x67) */ +#define RT5677_PWR_SLIM_ISO (0x1 << 11) +#define RT5677_PWR_SLIM_ISO_BIT 11 +#define RT5677_PWR_CORE_ISO (0x1 << 10) +#define RT5677_PWR_CORE_ISO_BIT 10 +#define RT5677_PWR_DSP_ISO (0x1 << 9) +#define RT5677_PWR_DSP_ISO_BIT 9 +#define RT5677_PWR_SR7_ISO (0x1 << 8) +#define RT5677_PWR_SR7_ISO_BIT 8 +#define RT5677_PWR_SR6_ISO (0x1 << 7) +#define RT5677_PWR_SR6_ISO_BIT 7 +#define RT5677_PWR_SR5_ISO (0x1 << 6) +#define RT5677_PWR_SR5_ISO_BIT 6 +#define RT5677_PWR_SR4_ISO (0x1 << 5) +#define RT5677_PWR_SR4_ISO_BIT 5 +#define RT5677_PWR_SR3_ISO (0x1 << 4) +#define RT5677_PWR_SR3_ISO_BIT 4 +#define RT5677_PWR_SR2_ISO (0x1 << 3) +#define RT5677_PWR_SR2_ISO_BIT 3 +#define RT5677_PWR_SR1_ISO (0x1 << 2) +#define RT5677_PWR_SR1_ISO_BIT 2 +#define RT5677_PWR_SR0_ISO (0x1 << 1) +#define RT5677_PWR_SR0_ISO_BIT 1 +#define RT5677_PWR_MLT_ISO (0x1 << 0) +#define RT5677_PWR_MLT_ISO_BIT 0 + +/* I2S1/2/3/4 Audio Serial Data Port Control (0x6f 0x70 0x71 0x72) */ +#define RT5677_I2S_MS_MASK (0x1 << 15) +#define RT5677_I2S_MS_SFT 15 +#define RT5677_I2S_MS_M (0x0 << 15) +#define RT5677_I2S_MS_S (0x1 << 15) +#define RT5677_I2S_O_CP_MASK (0x3 << 10) +#define RT5677_I2S_O_CP_SFT 10 +#define RT5677_I2S_O_CP_OFF (0x0 << 10) +#define RT5677_I2S_O_CP_U_LAW (0x1 << 10) +#define RT5677_I2S_O_CP_A_LAW (0x2 << 10) +#define RT5677_I2S_I_CP_MASK (0x3 << 8) +#define RT5677_I2S_I_CP_SFT 8 +#define RT5677_I2S_I_CP_OFF (0x0 << 8) +#define RT5677_I2S_I_CP_U_LAW (0x1 << 8) +#define RT5677_I2S_I_CP_A_LAW (0x2 << 8) +#define RT5677_I2S_BP_MASK (0x1 << 7) +#define RT5677_I2S_BP_SFT 7 +#define RT5677_I2S_BP_NOR (0x0 << 7) +#define RT5677_I2S_BP_INV (0x1 << 7) +#define RT5677_I2S_DL_MASK (0x3 << 2) +#define RT5677_I2S_DL_SFT 2 +#define RT5677_I2S_DL_16 (0x0 << 2) +#define RT5677_I2S_DL_20 (0x1 << 2) +#define RT5677_I2S_DL_24 (0x2 << 2) +#define RT5677_I2S_DL_8 (0x3 << 2) +#define RT5677_I2S_DF_MASK (0x3 << 0) +#define RT5677_I2S_DF_SFT 0 +#define RT5677_I2S_DF_I2S (0x0 << 0) +#define RT5677_I2S_DF_LEFT (0x1 << 0) +#define RT5677_I2S_DF_PCM_A (0x2 << 0) +#define RT5677_I2S_DF_PCM_B (0x3 << 0) + +/* Clock Tree Control 1 (0x73) */ +#define RT5677_I2S_PD1_MASK (0x7 << 12) +#define RT5677_I2S_PD1_SFT 12 +#define RT5677_I2S_PD1_1 (0x0 << 12) +#define RT5677_I2S_PD1_2 (0x1 << 12) +#define RT5677_I2S_PD1_3 (0x2 << 12) +#define RT5677_I2S_PD1_4 (0x3 << 12) +#define RT5677_I2S_PD1_6 (0x4 << 12) +#define RT5677_I2S_PD1_8 (0x5 << 12) +#define RT5677_I2S_PD1_12 (0x6 << 12) +#define RT5677_I2S_PD1_16 (0x7 << 12) +#define RT5677_I2S_BCLK_MS2_MASK (0x1 << 11) +#define RT5677_I2S_BCLK_MS2_SFT 11 +#define RT5677_I2S_BCLK_MS2_32 (0x0 << 11) +#define RT5677_I2S_BCLK_MS2_64 (0x1 << 11) +#define RT5677_I2S_PD2_MASK (0x7 << 8) +#define RT5677_I2S_PD2_SFT 8 +#define RT5677_I2S_PD2_1 (0x0 << 8) +#define RT5677_I2S_PD2_2 (0x1 << 8) +#define RT5677_I2S_PD2_3 (0x2 << 8) +#define RT5677_I2S_PD2_4 (0x3 << 8) +#define RT5677_I2S_PD2_6 (0x4 << 8) +#define RT5677_I2S_PD2_8 (0x5 << 8) +#define RT5677_I2S_PD2_12 (0x6 << 8) +#define RT5677_I2S_PD2_16 (0x7 << 8) +#define RT5677_I2S_BCLK_MS3_MASK (0x1 << 7) +#define RT5677_I2S_BCLK_MS3_SFT 7 +#define RT5677_I2S_BCLK_MS3_32 (0x0 << 7) +#define RT5677_I2S_BCLK_MS3_64 (0x1 << 7) +#define RT5677_I2S_PD3_MASK (0x7 << 4) +#define RT5677_I2S_PD3_SFT 4 +#define RT5677_I2S_PD3_1 (0x0 << 4) +#define RT5677_I2S_PD3_2 (0x1 << 4) +#define RT5677_I2S_PD3_3 (0x2 << 4) +#define RT5677_I2S_PD3_4 (0x3 << 4) +#define RT5677_I2S_PD3_6 (0x4 << 4) +#define RT5677_I2S_PD3_8 (0x5 << 4) +#define RT5677_I2S_PD3_12 (0x6 << 4) +#define RT5677_I2S_PD3_16 (0x7 << 4) +#define RT5677_I2S_BCLK_MS4_MASK (0x1 << 3) +#define RT5677_I2S_BCLK_MS4_SFT 3 +#define RT5677_I2S_BCLK_MS4_32 (0x0 << 3) +#define RT5677_I2S_BCLK_MS4_64 (0x1 << 3) +#define RT5677_I2S_PD4_MASK (0x7 << 0) +#define RT5677_I2S_PD4_SFT 0 +#define RT5677_I2S_PD4_1 (0x0 << 0) +#define RT5677_I2S_PD4_2 (0x1 << 0) +#define RT5677_I2S_PD4_3 (0x2 << 0) +#define RT5677_I2S_PD4_4 (0x3 << 0) +#define RT5677_I2S_PD4_6 (0x4 << 0) +#define RT5677_I2S_PD4_8 (0x5 << 0) +#define RT5677_I2S_PD4_12 (0x6 << 0) +#define RT5677_I2S_PD4_16 (0x7 << 0) + +/* Clock Tree Control 2 (0x74) */ +#define RT5677_I2S_PD5_MASK (0x7 << 12) +#define RT5677_I2S_PD5_SFT 12 +#define RT5677_I2S_PD5_1 (0x0 << 12) +#define RT5677_I2S_PD5_2 (0x1 << 12) +#define RT5677_I2S_PD5_3 (0x2 << 12) +#define RT5677_I2S_PD5_4 (0x3 << 12) +#define RT5677_I2S_PD5_6 (0x4 << 12) +#define RT5677_I2S_PD5_8 (0x5 << 12) +#define RT5677_I2S_PD5_12 (0x6 << 12) +#define RT5677_I2S_PD5_16 (0x7 << 12) +#define RT5677_I2S_PD6_MASK (0x7 << 8) +#define RT5677_I2S_PD6_SFT 8 +#define RT5677_I2S_PD6_1 (0x0 << 8) +#define RT5677_I2S_PD6_2 (0x1 << 8) +#define RT5677_I2S_PD6_3 (0x2 << 8) +#define RT5677_I2S_PD6_4 (0x3 << 8) +#define RT5677_I2S_PD6_6 (0x4 << 8) +#define RT5677_I2S_PD6_8 (0x5 << 8) +#define RT5677_I2S_PD6_12 (0x6 << 8) +#define RT5677_I2S_PD6_16 (0x7 << 8) +#define RT5677_I2S_PD7_MASK (0x7 << 4) +#define RT5677_I2S_PD7_SFT 4 +#define RT5677_I2S_PD7_1 (0x0 << 4) +#define RT5677_I2S_PD7_2 (0x1 << 4) +#define RT5677_I2S_PD7_3 (0x2 << 4) +#define RT5677_I2S_PD7_4 (0x3 << 4) +#define RT5677_I2S_PD7_6 (0x4 << 4) +#define RT5677_I2S_PD7_8 (0x5 << 4) +#define RT5677_I2S_PD7_12 (0x6 << 4) +#define RT5677_I2S_PD7_16 (0x7 << 4) +#define RT5677_I2S_PD8_MASK (0x7 << 0) +#define RT5677_I2S_PD8_SFT 0 +#define RT5677_I2S_PD8_1 (0x0 << 0) +#define RT5677_I2S_PD8_2 (0x1 << 0) +#define RT5677_I2S_PD8_3 (0x2 << 0) +#define RT5677_I2S_PD8_4 (0x3 << 0) +#define RT5677_I2S_PD8_6 (0x4 << 0) +#define RT5677_I2S_PD8_8 (0x5 << 0) +#define RT5677_I2S_PD8_12 (0x6 << 0) +#define RT5677_I2S_PD8_16 (0x7 << 0) + +/* Clock Tree Control 3 (0x75) */ +#define RT5677_DSP_ASRC_O_MASK (0x3 << 6) +#define RT5677_DSP_ASRC_O_SFT 6 +#define RT5677_DSP_ASRC_O_1_0 (0x0 << 6) +#define RT5677_DSP_ASRC_O_1_5 (0x1 << 6) +#define RT5677_DSP_ASRC_O_2_0 (0x2 << 6) +#define RT5677_DSP_ASRC_O_3_0 (0x3 << 6) +#define RT5677_DSP_ASRC_I_MASK (0x3 << 4) +#define RT5677_DSP_ASRC_I_SFT 4 +#define RT5677_DSP_ASRC_I_1_0 (0x0 << 4) +#define RT5677_DSP_ASRC_I_1_5 (0x1 << 4) +#define RT5677_DSP_ASRC_I_2_0 (0x2 << 4) +#define RT5677_DSP_ASRC_I_3_0 (0x3 << 4) +#define RT5677_DSP_BUS_PD_MASK (0x7 << 0) +#define RT5677_DSP_BUS_PD_SFT 0 +#define RT5677_DSP_BUS_PD_1 (0x0 << 0) +#define RT5677_DSP_BUS_PD_2 (0x1 << 0) +#define RT5677_DSP_BUS_PD_3 (0x2 << 0) +#define RT5677_DSP_BUS_PD_4 (0x3 << 0) +#define RT5677_DSP_BUS_PD_6 (0x4 << 0) +#define RT5677_DSP_BUS_PD_8 (0x5 << 0) +#define RT5677_DSP_BUS_PD_12 (0x6 << 0) +#define RT5677_DSP_BUS_PD_16 (0x7 << 0) + +#define RT5677_PLL_INP_MAX 40000000 +#define RT5677_PLL_INP_MIN 2048000 +/* PLL M/N/K Code Control 1 (0x7a 0x7c) */ +#define RT5677_PLL_N_MAX 0x1ff +#define RT5677_PLL_N_MASK (RT5677_PLL_N_MAX << 7) +#define RT5677_PLL_N_SFT 7 +#define RT5677_PLL_K_BP (0x1 << 5) +#define RT5677_PLL_K_BP_SFT 5 +#define RT5677_PLL_K_MAX 0x1f +#define RT5677_PLL_K_MASK (RT5677_PLL_K_MAX) +#define RT5677_PLL_K_SFT 0 + +/* PLL M/N/K Code Control 2 (0x7b 0x7d) */ +#define RT5677_PLL_M_MAX 0xf +#define RT5677_PLL_M_MASK (RT5677_PLL_M_MAX << 12) +#define RT5677_PLL_M_SFT 12 +#define RT5677_PLL_M_BP (0x1 << 11) +#define RT5677_PLL_M_BP_SFT 11 + +/* Global Clock Control 1 (0x80) */ +#define RT5677_SCLK_SRC_MASK (0x3 << 14) +#define RT5677_SCLK_SRC_SFT 14 +#define RT5677_SCLK_SRC_MCLK (0x0 << 14) +#define RT5677_SCLK_SRC_PLL1 (0x1 << 14) +#define RT5677_SCLK_SRC_RCCLK (0x2 << 14) /* 25MHz */ +#define RT5677_SCLK_SRC_SLIM (0x3 << 14) +#define RT5677_PLL1_SRC_MASK (0x7 << 11) +#define RT5677_PLL1_SRC_SFT 11 +#define RT5677_PLL1_SRC_MCLK (0x0 << 11) +#define RT5677_PLL1_SRC_BCLK1 (0x1 << 11) +#define RT5677_PLL1_SRC_BCLK2 (0x2 << 11) +#define RT5677_PLL1_SRC_BCLK3 (0x3 << 11) +#define RT5677_PLL1_SRC_BCLK4 (0x4 << 11) +#define RT5677_PLL1_SRC_RCCLK (0x5 << 11) +#define RT5677_PLL1_SRC_SLIM (0x6 << 11) +#define RT5677_MCLK_SRC_MASK (0x1 << 10) +#define RT5677_MCLK_SRC_SFT 10 +#define RT5677_MCLK1_SRC (0x0 << 10) +#define RT5677_MCLK2_SRC (0x1 << 10) +#define RT5677_PLL1_PD_MASK (0x1 << 8) +#define RT5677_PLL1_PD_SFT 8 +#define RT5677_PLL1_PD_1 (0x0 << 8) +#define RT5677_PLL1_PD_2 (0x1 << 8) +#define RT5671_DAC_OSR_MASK (0x3 << 6) +#define RT5671_DAC_OSR_SFT 6 +#define RT5671_DAC_OSR_128 (0x0 << 6) +#define RT5671_DAC_OSR_64 (0x1 << 6) +#define RT5671_DAC_OSR_32 (0x2 << 6) +#define RT5671_ADC_OSR_MASK (0x3 << 4) +#define RT5671_ADC_OSR_SFT 4 +#define RT5671_ADC_OSR_128 (0x0 << 4) +#define RT5671_ADC_OSR_64 (0x1 << 4) +#define RT5671_ADC_OSR_32 (0x2 << 4) + +/* Global Clock Control 2 (0x81) */ +#define RT5677_PLL2_PR_SRC_MASK (0x1 << 15) +#define RT5677_PLL2_PR_SRC_SFT 15 +#define RT5677_PLL2_PR_SRC_MCLK1 (0x0 << 15) +#define RT5677_PLL2_PR_SRC_MCLK2 (0x1 << 15) +#define RT5677_PLL2_SRC_MASK (0x7 << 12) +#define RT5677_PLL2_SRC_SFT 12 +#define RT5677_PLL2_SRC_MCLK (0x0 << 12) +#define RT5677_PLL2_SRC_BCLK1 (0x1 << 12) +#define RT5677_PLL2_SRC_BCLK2 (0x2 << 12) +#define RT5677_PLL2_SRC_BCLK3 (0x3 << 12) +#define RT5677_PLL2_SRC_BCLK4 (0x4 << 12) +#define RT5677_PLL2_SRC_RCCLK (0x5 << 12) +#define RT5677_PLL2_SRC_SLIM (0x6 << 12) +#define RT5671_DSP_ASRC_O_SRC (0x3 << 10) +#define RT5671_DSP_ASRC_O_SRC_SFT 10 +#define RT5671_DSP_ASRC_O_MCLK (0x0 << 10) +#define RT5671_DSP_ASRC_O_PLL1 (0x1 << 10) +#define RT5671_DSP_ASRC_O_SLIM (0x2 << 10) +#define RT5671_DSP_ASRC_O_RCCLK (0x3 << 10) +#define RT5671_DSP_ASRC_I_SRC (0x3 << 8) +#define RT5671_DSP_ASRC_I_SRC_SFT 8 +#define RT5671_DSP_ASRC_I_MCLK (0x0 << 8) +#define RT5671_DSP_ASRC_I_PLL1 (0x1 << 8) +#define RT5671_DSP_ASRC_I_SLIM (0x2 << 8) +#define RT5671_DSP_ASRC_I_RCCLK (0x3 << 8) +#define RT5677_DSP_CLK_SRC_MASK (0x1 << 7) +#define RT5677_DSP_CLK_SRC_SFT 7 +#define RT5677_DSP_CLK_SRC_PLL2 (0x0 << 7) +#define RT5677_DSP_CLK_SRC_BYPASS (0x1 << 7) + +/* VAD Function Control 4 (0x9f) */ +#define RT5677_VAD_SRC_MASK (0x7 << 8) +#define RT5677_VAD_SRC_SFT 8 + +/* DSP InBound Control (0xa3) */ +#define RT5677_IB01_SRC_MASK (0x7 << 12) +#define RT5677_IB01_SRC_SFT 12 +#define RT5677_IB23_SRC_MASK (0x7 << 8) +#define RT5677_IB23_SRC_SFT 8 +#define RT5677_IB45_SRC_MASK (0x7 << 4) +#define RT5677_IB45_SRC_SFT 4 +#define RT5677_IB6_SRC_MASK (0x7 << 0) +#define RT5677_IB6_SRC_SFT 0 + +/* DSP InBound Control (0xa4) */ +#define RT5677_IB7_SRC_MASK (0x7 << 12) +#define RT5677_IB7_SRC_SFT 12 +#define RT5677_IB8_SRC_MASK (0x7 << 8) +#define RT5677_IB8_SRC_SFT 8 +#define RT5677_IB9_SRC_MASK (0x7 << 4) +#define RT5677_IB9_SRC_SFT 4 + +/* DSP In/OutBound Control (0xa5) */ +#define RT5677_SEL_SRC_OB23 (0x1 << 4) +#define RT5677_SEL_SRC_OB23_SFT 4 +#define RT5677_SEL_SRC_OB01 (0x1 << 3) +#define RT5677_SEL_SRC_OB01_SFT 3 +#define RT5677_SEL_SRC_IB45 (0x1 << 2) +#define RT5677_SEL_SRC_IB45_SFT 2 +#define RT5677_SEL_SRC_IB23 (0x1 << 1) +#define RT5677_SEL_SRC_IB23_SFT 1 +#define RT5677_SEL_SRC_IB01 (0x1 << 0) +#define RT5677_SEL_SRC_IB01_SFT 0 + +/* Virtual DSP Mixer Control (0xf7 0xf8 0xf9) */ +#define RT5677_DSP_IB_01_H (0x1 << 15) +#define RT5677_DSP_IB_01_H_SFT 15 +#define RT5677_DSP_IB_23_H (0x1 << 14) +#define RT5677_DSP_IB_23_H_SFT 14 +#define RT5677_DSP_IB_45_H (0x1 << 13) +#define RT5677_DSP_IB_45_H_SFT 13 +#define RT5677_DSP_IB_6_H (0x1 << 12) +#define RT5677_DSP_IB_6_H_SFT 12 +#define RT5677_DSP_IB_7_H (0x1 << 11) +#define RT5677_DSP_IB_7_H_SFT 11 +#define RT5677_DSP_IB_8_H (0x1 << 10) +#define RT5677_DSP_IB_8_H_SFT 10 +#define RT5677_DSP_IB_9_H (0x1 << 9) +#define RT5677_DSP_IB_9_H_SFT 9 +#define RT5677_DSP_IB_01_L (0x1 << 7) +#define RT5677_DSP_IB_01_L_SFT 7 +#define RT5677_DSP_IB_23_L (0x1 << 6) +#define RT5677_DSP_IB_23_L_SFT 6 +#define RT5677_DSP_IB_45_L (0x1 << 5) +#define RT5677_DSP_IB_45_L_SFT 5 +#define RT5677_DSP_IB_6_L (0x1 << 4) +#define RT5677_DSP_IB_6_L_SFT 4 +#define RT5677_DSP_IB_7_L (0x1 << 3) +#define RT5677_DSP_IB_7_L_SFT 3 +#define RT5677_DSP_IB_8_L (0x1 << 2) +#define RT5677_DSP_IB_8_L_SFT 2 +#define RT5677_DSP_IB_9_L (0x1 << 1) +#define RT5677_DSP_IB_9_L_SFT 1 + +#define RT5677_SW_RESET 0x10EC + +/* System Clock Source */ +enum { + RT5677_SCLK_S_MCLK, + RT5677_SCLK_S_PLL1, + RT5677_SCLK_S_RCCLK, +}; + +/* PLL1 Source */ +enum { + RT5677_PLL1_S_MCLK, + RT5677_PLL1_S_BCLK1, + RT5677_PLL1_S_BCLK2, + RT5677_PLL1_S_BCLK3, + RT5677_PLL1_S_BCLK4, +}; + +enum { + RT5677_AIF1, + RT5677_AIF2, + RT5677_AIF3, + RT5677_AIF4, + RT5677_AIF5, + RT5677_AIFS, +}; + +#endif /* __DRIVERS_SOUND_RT5677_H__ */
Add a sound driver for samus which ties together the audio codec and I2S controller.
For now broadwell_sound is commented out in the makefile since we cannot compile it without sound support enabled. The next commit fixes this.
Changes in v2: None
drivers/sound/Makefile | 2 +- drivers/sound/broadwell_sound.c | 65 +++++++++++++++++++++++++++++++++ 2 files changed, 66 insertions(+), 1 deletion(-) create mode 100644 drivers/sound/broadwell_sound.c
diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index fe3ccd6e5c6..452a5a17616 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -18,5 +18,5 @@ obj-$(CONFIG_SOUND_MAX98095) += max98095.o maxim_codec.o obj-$(CONFIG_SOUND_INTEL_HDA) += hda_codec.o obj-$(CONFIG_SOUND_I8254) += i8254_beep.o obj-$(CONFIG_SOUND_RT5677) += rt5677.o -obj-$(CONFIG_INTEL_BROADWELL) += broadwell_i2s.o +obj-$(CONFIG_INTEL_BROADWELL) += broadwell_i2s.o #broadwell_sound.o obj-$(CONFIG_SOUND_IVYBRIDGE) += ivybridge_sound.o diff --git a/drivers/sound/broadwell_sound.c b/drivers/sound/broadwell_sound.c new file mode 100644 index 00000000000..6e083fe1f69 --- /dev/null +++ b/drivers/sound/broadwell_sound.c @@ -0,0 +1,65 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Sound for broadwell + * + * Copyright 2019 Google LLC + * Written by Simon Glass sjg@chromium.org + */ + +#define LOG_CATEGORY UCLASS_SOUND + +#include <common.h> +#include <audio_codec.h> +#include <dm.h> +#include <i2s.h> +#include <sound.h> + +static int broadwell_sound_probe(struct udevice *dev) +{ + return sound_find_codec_i2s(dev); +} + +static int broadwell_sound_setup(struct udevice *dev) +{ + struct sound_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct i2s_uc_priv *i2c_priv = dev_get_uclass_priv(uc_priv->i2s); + int ret; + + if (uc_priv->setup_done) + return -EALREADY; + ret = audio_codec_set_params(uc_priv->codec, i2c_priv->id, + i2c_priv->samplingrate, + i2c_priv->samplingrate * i2c_priv->rfs, + i2c_priv->bitspersample, + i2c_priv->channels); + if (ret) + return ret; + uc_priv->setup_done = true; + + return 0; +} + +static int broadwell_sound_play(struct udevice *dev, void *data, uint data_size) +{ + struct sound_uc_priv *uc_priv = dev_get_uclass_priv(dev); + + return i2s_tx_data(uc_priv->i2s, data, data_size); +} + +static const struct sound_ops broadwell_sound_ops = { + .setup = broadwell_sound_setup, + .play = broadwell_sound_play, +}; + +static const struct udevice_id broadwell_sound_ids[] = { + { .compatible = "google,samus-sound" }, + { } +}; + +U_BOOT_DRIVER(broadwell_sound_drv) = { + .name = "broadwell_sound", + .id = UCLASS_SOUND, + .of_match = broadwell_sound_ids, + .probe = broadwell_sound_probe, + .ops = &broadwell_sound_ops, +};
Changes in v2: None
Enable sound on samus using the broadwell I2S and an RT5677 audio codec.
Reviewed-by: Bin Meng bmeng.cn@gmail.com Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
arch/x86/dts/chromebook_samus.dts | 49 +++++++++++++++++++++++++++--- configs/chromebook_samus_defconfig | 9 ++++++ drivers/sound/Makefile | 2 +- 3 files changed, 55 insertions(+), 5 deletions(-)
diff --git a/arch/x86/dts/chromebook_samus.dts b/arch/x86/dts/chromebook_samus.dts index b58936b4ac9..ad687ce2cc3 100644 --- a/arch/x86/dts/chromebook_samus.dts +++ b/arch/x86/dts/chromebook_samus.dts @@ -494,10 +494,20 @@ intel,pre-graphics-delay = <200>; };
- me@16,0 { - reg = <0x0000b000 0 0 0 0>; - compatible = "intel,me"; - u-boot,dm-pre-reloc; + adsp@13,0 { + reg = <0x00009800 0 0 0 0>; + compatible = "intel,wildcatpoint-adsp"; + intel,adsp-d3-pg-enable = <0>; + intel,adsp-sram-pg-enable = <0>; + intel,sio-acpi-mode; + #address-cells = <1>; + #size-cells = <0>; + + i2s: shim { + compatible = "intel,broadwell-i2s"; + #sound-dai-cells = <1>; + reg = <0xfb000 0xfc000 0xfd000>; + }; };
usb_1: usb@14,0 { @@ -505,6 +515,25 @@ compatible = "xhci-pci"; };
+ i2c0: i2c@15,1 { + reg = <0x0000a900 0 0 0 0>; + compatible = "snps,designware-i2c"; + #address-cells = <1>; + #size-cells = <0>; + + rt5677: rt5677@2c { + compatible = "realtek,rt5677"; + #sound-dai-cells = <1>; + reg = <0x2c>; + }; + }; + + me@16,0 { + reg = <0x0000b000 0 0 0 0>; + compatible = "intel,me"; + u-boot,dm-pre-reloc; + }; + usb_0: usb@1d,0 { status = "disabled"; reg = <0x0000e800 0 0 0 0>; @@ -626,4 +655,16 @@ }; };
+ sound { + compatible = "google,samus-sound"; + codec-enable-gpio = <&gpio_b 11 GPIO_ACTIVE_HIGH>; + cpu { + sound-dai = <&i2s 0>; + }; + + codec { + sound-dai = <&rt5677 0>; + }; + }; + }; diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 745cb3db0a6..7e2453f2440 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -17,6 +17,7 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_USE_BOOTARGS=y CONFIG_BOOTARGS="root=/dev/sdb3 init=/sbin/init rootwait ro" CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_LOG_DEFAULT_LEVEL=7 CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_LAST_STAGE_INIT=y @@ -24,7 +25,9 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y CONFIG_CMD_PART=y +CONFIG_CMD_SATA=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y @@ -33,6 +36,7 @@ CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_PING=y CONFIG_CMD_TIME=y +CONFIG_CMD_SOUND=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y @@ -48,9 +52,14 @@ CONFIG_DEFAULT_DEVICE_TREE="chromebook_samus" CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CPU=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_DW=y CONFIG_CROS_EC=y CONFIG_CROS_EC_LPC=y CONFIG_SYS_NS16550=y +CONFIG_SOUND=y +CONFIG_SOUND_I8254=y +CONFIG_SOUND_RT5677=y CONFIG_SPI=y CONFIG_TPM_TIS_LPC=y CONFIG_USB_STORAGE=y diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index 452a5a17616..e155041ff5f 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -18,5 +18,5 @@ obj-$(CONFIG_SOUND_MAX98095) += max98095.o maxim_codec.o obj-$(CONFIG_SOUND_INTEL_HDA) += hda_codec.o obj-$(CONFIG_SOUND_I8254) += i8254_beep.o obj-$(CONFIG_SOUND_RT5677) += rt5677.o -obj-$(CONFIG_INTEL_BROADWELL) += broadwell_i2s.o #broadwell_sound.o +obj-$(CONFIG_INTEL_BROADWELL) += broadwell_i2s.o broadwell_sound.o obj-$(CONFIG_SOUND_IVYBRIDGE) += ivybridge_sound.o
On Sun, Feb 17, 2019 at 11:25 AM Simon Glass sjg@chromium.org wrote:
At present no x86 boards support sound. This series adds several options:
- legacy beep
- Intel HDA
- I2S with codec
These are enabled on coreboot, link and samus, respectively.
A number of related patches are included to make the above work.
Changes in v2:
- Add a PCI ID for the HD audio class
- Add a link to the HD audio PDF fie
- Add a note about undocumented IOMMU values
- Add a note as to why the default log level must be set to LOGL_DEBUG
- Add an example to the commit message for clarity
- Add comments next to verbs in the DT mentioning the HDA spec
- Add new patch to fix up Kconfig log level names
- Add the log-level names into the Kconfig help
- Adjust code to use #defines instead of open-coded values
- Also remove this feature from the TODO
- Change the driver name to i8254_drv
- Correct the default log level to 6 (LOGL_INFO)
- Drop useless 'set' comment
- Fix capital letter in Ivybridge in Kconfig help
- Fix comment about @return value in ioctl() method and function
- Fix ordering of PCI IDs
- Fix use of C++ comments in two places
- Move comment about silencing on error so that it is clearer
- Rename PPC_PORTB to SYSCTL_PORTB
- Rename sound driver to bd82x6x-hda
- Update in codec_init() to use defines for codec access
- Use "sandbox-pch" for the compatible string, for consistency
- Use PIT_TICK_RATE instead of creating a new define
- Use a more generic "intel,hd-audio" as the compatible string
- Use defines for all azalia verbs in binding file
- User lower-case hex consistently in the DT
Simon Glass (34): log: Fix up Kconfig log level names log: Add a Kconfig option to set the default log level log: Add documentation for convenience functions log: Allow #define LOG_DEBUG to enable logging in a file dm: syscon: Don't require a regmap for PCI devices i2c: designware: Add error checking on init pci: Don't export pci_hose_config_device() pci: Fix comment in struct pci_child_platdata gpio: Show inactive GPIOs when explicitly requested gpio: Use case-insentive matching on the GPIO name pci: Add IDs for Intel high-definition audio sandbox: Add a note about the growing state_info struct x86: Adjust I/O macros to work on 64-bit machines x86: samus: Increase the pre-reloc memory x86: link: Increase malloc size and decrease code size x86: sandbox: pch: Add a CONFIG option for PCH sandbox: pch: Add a test for the PCH uclass pch: Add ioctl support x86: ivybridge: Add a way to get the HDA config setting sound: Mark sound_setup() as optional sound: Add uclass operations for beeping sound: Add support for Intel HDA sandbox: sound: Silence sound for testing sound: x86: link: Add sound support sound: x86: Add beeping support in i8254 sound: Add a driver for the i8254 beep x86: coreboot: Enable the beeper sound driver x86: broadwell: Add support for the ADSP x86: broadwell: Don't bother probing the PCH for pinctrl x86: broadwell: Add support for serial I/O devices x86: sound: Add support for broadwell I2S sound: Add a driver for RealTek RT5677 x86: sound: Add sound support for samus (broadwell) x86: Add sound support for samus
Series applied to u-boot-x86, thanks!
Bin Meng
Heiko Schocher
