[U-Boot] [RESEND PATCH 1/3] pwm: sunxi: add support for PWM found on Allwinner A64 and H3
This commit adds basic support for PWM found on Allwinner A64 and H3
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- arch/arm/include/asm/arch-sunxi/gpio.h | 1 + arch/arm/include/asm/arch-sunxi/pwm.h | 12 +++ arch/arm/mach-sunxi/board.c | 11 +++ drivers/pwm/Kconfig | 7 ++ drivers/pwm/Makefile | 1 + drivers/pwm/sunxi_pwm.c | 174 +++++++++++++++++++++++++++++++++ 6 files changed, 206 insertions(+) create mode 100644 drivers/pwm/sunxi_pwm.c
diff --git a/arch/arm/include/asm/arch-sunxi/gpio.h b/arch/arm/include/asm/arch-sunxi/gpio.h index 24f85206c8..7265d18099 100644 --- a/arch/arm/include/asm/arch-sunxi/gpio.h +++ b/arch/arm/include/asm/arch-sunxi/gpio.h @@ -173,6 +173,7 @@ enum sunxi_gpio_number { #define SUN8I_GPD_SDC1 3 #define SUNXI_GPD_LCD0 2 #define SUNXI_GPD_LVDS0 3 +#define SUNXI_GPD_PWM 2
#define SUN5I_GPE_SDC2 3 #define SUN8I_GPE_TWI2 3 diff --git a/arch/arm/include/asm/arch-sunxi/pwm.h b/arch/arm/include/asm/arch-sunxi/pwm.h index 5884b5dbe7..673e0eb7b5 100644 --- a/arch/arm/include/asm/arch-sunxi/pwm.h +++ b/arch/arm/include/asm/arch-sunxi/pwm.h @@ -11,8 +11,15 @@ #define SUNXI_PWM_CH0_PERIOD (SUNXI_PWM_BASE + 4)
#define SUNXI_PWM_CTRL_PRESCALE0(x) ((x) & 0xf) +#define SUNXI_PWM_CTRL_PRESCALE0_MASK (0xf) #define SUNXI_PWM_CTRL_ENABLE0 (0x5 << 4) #define SUNXI_PWM_CTRL_POLARITY0(x) ((x) << 5) +#define SUNXI_PWM_CTRL_POLARITY0_MASK (1 << 5) +#define SUNXI_PWM_CTRL_CLK_GATE (1 << 6) + +#define SUNXI_PWM_CH0_PERIOD_MAX (0xffff) +#define SUNXI_PWM_CH0_PERIOD_PRD(x) ((x & 0xffff) << 16) +#define SUNXI_PWM_CH0_PERIOD_DUTY(x) ((x) & 0xffff)
#define SUNXI_PWM_PERIOD_80PCT 0x04af03c0
@@ -31,4 +38,9 @@ #define SUNXI_PWM_MUX SUN8I_GPH_PWM #endif
+struct sunxi_pwm { + u32 ctrl; + u32 ch0_period; +}; + #endif diff --git a/arch/arm/mach-sunxi/board.c b/arch/arm/mach-sunxi/board.c index 65b1ebd837..a85f973a46 100644 --- a/arch/arm/mach-sunxi/board.c +++ b/arch/arm/mach-sunxi/board.c @@ -141,6 +141,16 @@ static int gpio_init(void) return 0; }
+static int pwm_init(void) +{ +#ifdef CONFIG_PWM_SUNXI +#ifdef CONFIG_MACH_SUN50I + sunxi_gpio_set_cfgpin(SUNXI_GPD(22), SUNXI_GPD_PWM); +#endif +#endif + return 0; +} + #if defined(CONFIG_SPL_BOARD_LOAD_IMAGE) && defined(CONFIG_SPL_BUILD) static int spl_board_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev) @@ -204,6 +214,7 @@ void s_init(void) clock_init(); timer_init(); gpio_init(); + pwm_init(); #ifndef CONFIG_DM_I2C i2c_init_board(); #endif diff --git a/drivers/pwm/Kconfig b/drivers/pwm/Kconfig index e827558052..67e3f355e7 100644 --- a/drivers/pwm/Kconfig +++ b/drivers/pwm/Kconfig @@ -43,3 +43,10 @@ config PWM_TEGRA four channels with a programmable period and duty cycle. Only a 32KHz clock is supported by the driver but the duty cycle is configurable. + +config PWM_SUNXI + bool "Enable support for the Allwinner Sunxi PWM" + depends on DM_PWM + help + This PWM is found on A64 and other Allwinner SoCs. It supports a + programmable period and duty cycle. A 32-bit counter is used. diff --git a/drivers/pwm/Makefile b/drivers/pwm/Makefile index 29d59916cb..1a8f8a58bc 100644 --- a/drivers/pwm/Makefile +++ b/drivers/pwm/Makefile @@ -17,3 +17,4 @@ obj-$(CONFIG_PWM_IMX) += pwm-imx.o pwm-imx-util.o obj-$(CONFIG_PWM_ROCKCHIP) += rk_pwm.o obj-$(CONFIG_PWM_SANDBOX) += sandbox_pwm.o obj-$(CONFIG_PWM_TEGRA) += tegra_pwm.o +obj-$(CONFIG_PWM_SUNXI) += sunxi_pwm.o diff --git a/drivers/pwm/sunxi_pwm.c b/drivers/pwm/sunxi_pwm.c new file mode 100644 index 0000000000..3e6d69fa1c --- /dev/null +++ b/drivers/pwm/sunxi_pwm.c @@ -0,0 +1,174 @@ +/* + * Copyright (c) 2017 Vasily Khoruzhick anarsoul@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <div64.h> +#include <dm.h> +#include <pwm.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch/pwm.h> +#include <power/regulator.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct sunxi_pwm_priv { + struct sunxi_pwm *regs; + ulong freq; + bool invert; + uint32_t prescaler; +}; + +static const uint32_t prescaler_table[] = { + 120, /* 0000 */ + 180, /* 0001 */ + 240, /* 0010 */ + 360, /* 0011 */ + 480, /* 0100 */ + 0, /* 0101 */ + 0, /* 0110 */ + 0, /* 0111 */ + 12000, /* 1000 */ + 24000, /* 1001 */ + 36000, /* 1010 */ + 48000, /* 1011 */ + 72000, /* 1100 */ + 0, /* 1101 */ + 0, /* 1110 */ + 1, /* 1111 */ +}; + +static const uint64_t nsecs_per_sec = 1000000000L; + +static int sunxi_pwm_set_invert(struct udevice *dev, uint channel, bool polarity) +{ + struct sunxi_pwm_priv *priv = dev_get_priv(dev); + + debug("%s: polarity=%u\n", __func__, polarity); + priv->invert = polarity; + + return 0; +} + +static int sunxi_pwm_set_config(struct udevice *dev, uint channel, uint period_ns, + uint duty_ns) +{ + struct sunxi_pwm_priv *priv = dev_get_priv(dev); + struct sunxi_pwm *regs = priv->regs; + int prescaler; + u32 v, period, duty; + uint64_t div = 0, pval = 0, scaled_freq = 0; + + debug("%s: period_ns=%u, duty_ns=%u\n", __func__, period_ns, duty_ns); + + for (prescaler = 0; prescaler < SUNXI_PWM_CTRL_PRESCALE0_MASK; prescaler++) { + if (!prescaler_table[prescaler]) + continue; + div = priv->freq; + pval = prescaler_table[prescaler]; + scaled_freq = lldiv(div, pval); + div = scaled_freq * period_ns; + div = lldiv(div, nsecs_per_sec); + if (div - 1 <= SUNXI_PWM_CH0_PERIOD_MAX) + break; + } + + if (div - 1 > SUNXI_PWM_CH0_PERIOD_MAX) { + debug("%s: failed to find prescaler value\n", __func__); + return -EINVAL; + } + + period = div; + div = scaled_freq * duty_ns; + div = lldiv(div, nsecs_per_sec); + duty = div; + + if (priv->prescaler != prescaler) { + /* Mask clock to update prescaler */ + v = readl(®s->ctrl); + v &= ~SUNXI_PWM_CTRL_CLK_GATE; + writel(v, ®s->ctrl); + v &= ~SUNXI_PWM_CTRL_PRESCALE0_MASK; + v |= (priv->prescaler & SUNXI_PWM_CTRL_PRESCALE0_MASK); + writel(v, ®s->ctrl); + v |= SUNXI_PWM_CTRL_CLK_GATE; + writel(v, ®s->ctrl); + priv->prescaler = prescaler; + } + + writel(SUNXI_PWM_CH0_PERIOD_PRD(period) | + SUNXI_PWM_CH0_PERIOD_DUTY(duty), ®s->ch0_period); + + debug("%s: prescaler: %d, period: %d, duty: %d\n", __func__, priv->prescaler, + period, duty); + + return 0; +} + +static int sunxi_pwm_set_enable(struct udevice *dev, uint channel, bool enable) +{ + struct sunxi_pwm_priv *priv = dev_get_priv(dev); + struct sunxi_pwm *regs = priv->regs; + uint32_t v; + + debug("%s: Enable '%s'\n", __func__, dev->name); + + v = readl(®s->ctrl); + if (!enable) { + v &= ~SUNXI_PWM_CTRL_ENABLE0; + writel(v, ®s->ctrl); + return 0; + } + + v &= ~SUNXI_PWM_CTRL_POLARITY0_MASK; + v |= priv->invert ? SUNXI_PWM_CTRL_POLARITY0(0) : + SUNXI_PWM_CTRL_POLARITY0(1); + v |= SUNXI_PWM_CTRL_ENABLE0; + writel(v, ®s->ctrl); + + return 0; +} + +static int sunxi_pwm_ofdata_to_platdata(struct udevice *dev) +{ + struct sunxi_pwm_priv *priv = dev_get_priv(dev); + + priv->regs = (struct sunxi_pwm *)devfdt_get_addr(dev); + + return 0; +} + +static int sunxi_pwm_probe(struct udevice *dev) +{ + struct sunxi_pwm_priv *priv = dev_get_priv(dev); + + priv->freq = 24000000; + + return 0; +} + +static const struct pwm_ops sunxi_pwm_ops = { + .set_invert = sunxi_pwm_set_invert, + .set_config = sunxi_pwm_set_config, + .set_enable = sunxi_pwm_set_enable, +}; + +static const struct udevice_id sunxi_pwm_ids[] = { + { .compatible = "allwinner,sun8i-h3-pwm" }, + { .compatible = "allwinner,sun50i-a64-pwm" }, + { } +}; + +U_BOOT_DRIVER(sunxi_pwm) = { + .name = "sunxi_pwm", + .id = UCLASS_PWM, + .of_match = sunxi_pwm_ids, + .ops = &sunxi_pwm_ops, + .ofdata_to_platdata = sunxi_pwm_ofdata_to_platdata, + .probe = sunxi_pwm_probe, + .priv_auto_alloc_size = sizeof(struct sunxi_pwm_priv), +};
u-boot doesn't have dummy regulators, so pwm_backlight probe will fail if regulator is missing. Make it optional to get this driver working on platforms where there's no backlight regultor.
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- drivers/video/pwm_backlight.c | 28 ++++++++++++++++------------ 1 file changed, 16 insertions(+), 12 deletions(-)
diff --git a/drivers/video/pwm_backlight.c b/drivers/video/pwm_backlight.c index fbd7bf7838..05e56ffead 100644 --- a/drivers/video/pwm_backlight.c +++ b/drivers/video/pwm_backlight.c @@ -32,16 +32,21 @@ static int pwm_backlight_enable(struct udevice *dev) uint duty_cycle; int ret;
- plat = dev_get_uclass_platdata(priv->reg); - debug("%s: Enable '%s', regulator '%s'/'%s'\n", __func__, dev->name, - priv->reg->name, plat->name); - ret = regulator_set_enable(priv->reg, true); - if (ret) { - debug("%s: Cannot enable regulator for PWM '%s'\n", __func__, - dev->name); - return ret; + if (priv->reg) { + plat = dev_get_uclass_platdata(priv->reg); + debug("%s: Enable '%s', regulator '%s'/'%s'\n", __func__, dev->name, + priv->reg->name, plat->name); + ret = regulator_set_enable(priv->reg, true); + if (ret) { + debug("%s: Cannot enable regulator for PWM '%s'\n", __func__, + dev->name); + return ret; + } + mdelay(120); } - mdelay(120); + + debug("%s: default: %d, min: %d, max: %d\n", __func__, + priv->default_level, priv->min_level, priv->max_level);
duty_cycle = priv->period_ns * (priv->default_level - priv->min_level) / (priv->max_level - priv->min_level + 1); @@ -68,10 +73,9 @@ static int pwm_backlight_ofdata_to_platdata(struct udevice *dev) debug("%s: start\n", __func__); ret = uclass_get_device_by_phandle(UCLASS_REGULATOR, dev, "power-supply", &priv->reg); - if (ret) { + if (ret) debug("%s: Cannot get power supply: ret=%d\n", __func__, ret); - return ret; - } + ret = gpio_request_by_name(dev, "enable-gpios", 0, &priv->enable, GPIOD_IS_OUT); if (ret) {
Signed-off-by: Vasily Khoruzhick anarsoul@gmail.com --- arch/arm/dts/sun50i-a64.dtsi | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/dts/sun50i-a64.dtsi b/arch/arm/dts/sun50i-a64.dtsi index 65a344d9ce..14e94bf00e 100644 --- a/arch/arm/dts/sun50i-a64.dtsi +++ b/arch/arm/dts/sun50i-a64.dtsi @@ -319,6 +319,14 @@ }; };
+ pwm: pwm@01c21400 { + compatible = "allwinner,sun50i-a64-pwm"; + reg = <0x01c21400 0x8>; + clocks = <&osc24M>; + #pwm-cells = <3>; + status = "disabled"; + }; + uart0: serial@1c28000 { compatible = "snps,dw-apb-uart"; reg = <0x01c28000 0x400>;
Commit log please. At least mention the fact that this binding has not been accepted in Linux yet.
Maxime
pwm: pwm@01c21400 {
So the A64 PWM seems to be fully compatible with the H3 one, which has a documented binding (also used in the Linux driver). So can you please make this: compatible = "allwinner,sun50i-a64-pwm", "allwinner,sun8i-h3-pwm";
and then drop the sun50i-a64-pwm string in the driver?
And I wonder if we should have the pinctrl already in here, since there is only one choice for PWM0? At least that would document the clash.
clocks = <&osc24M>;
#pwm-cells = <3>;
- uart0: serial@1c28000 { compatible = "snps,dw-apb-uart"; reg = <0x01c28000 0x400>;
Mmh, can you explain (for instance in a 0/3 email) what this is used for? My understanding is that PWM0 (which is what you hard code here) is only exposed on PD22, which is also used for the MDC line to the Ethernet PHY. All boards I heard of have Ethernet, so PWM0 is not usable there. So is this for a special board?
+struct sunxi_pwm {
- u32 ctrl;
- u32 ch0_period;
- sunxi_gpio_set_cfgpin(SUNXI_GPD(22), SUNXI_GPD_PWM);
So this would probably kill Ethernet. At the very least this should be somehow protected against this clash. And I wonder if this should move into the PWM driver, for instance into the .enable function.
Cheers, Andre.
+#endif +#endif
- pwm_init();
+config PWM_SUNXI
- bool "Enable support for the Allwinner Sunxi PWM"
- depends on DM_PWM
- help
- Copyright (c) 2017 Vasily Khoruzhick anarsoul@gmail.com
- struct sunxi_pwm *regs;
- ulong freq;
- bool invert;
- uint32_t prescaler;
- 120, /* 0000 */
- 180, /* 0001 */
- 240, /* 0010 */
- 360, /* 0011 */
- 480, /* 0100 */
- 0, /* 0101 */
- 0, /* 0110 */
- 0, /* 0111 */
- 12000, /* 1000 */
- 24000, /* 1001 */
- 36000, /* 1010 */
- 48000, /* 1011 */
- 72000, /* 1100 */
- 0, /* 1101 */
- 0, /* 1110 */
- 1, /* 1111 */
- struct sunxi_pwm_priv *priv = dev_get_priv(dev);
- debug("%s: polarity=%u\n", __func__, polarity);
- priv->invert = polarity;
uint duty_ns)
- struct sunxi_pwm *regs = priv->regs;
- int prescaler;
- u32 v, period, duty;
- uint64_t div = 0, pval = 0, scaled_freq = 0;
- debug("%s: period_ns=%u, duty_ns=%u\n", __func__, period_ns, duty_ns);
- for (prescaler = 0; prescaler < SUNXI_PWM_CTRL_PRESCALE0_MASK; prescaler++) {
continue;
div = priv->freq;
break;
- if (div - 1 > SUNXI_PWM_CH0_PERIOD_MAX) {
return -EINVAL;
- period = div;
- div = scaled_freq * duty_ns;
- div = lldiv(div, nsecs_per_sec);
- duty = div;
- if (priv->prescaler != prescaler) {
- writel(SUNXI_PWM_CH0_PERIOD_PRD(period) |
- debug("%s: prescaler: %d, period: %d, duty: %d\n", __func__, priv->prescaler,
period, duty);
- uint32_t v;
- debug("%s: Enable '%s'\n", __func__, dev->name);
- v = readl(®s->ctrl);
- if (!enable) {
- v &= ~SUNXI_PWM_CTRL_POLARITY0_MASK;
- v |= priv->invert ? SUNXI_PWM_CTRL_POLARITY0(0) :
- v |= SUNXI_PWM_CTRL_ENABLE0;
- writel(v, ®s->ctrl);
- priv->regs = (struct sunxi_pwm *)devfdt_get_addr(dev);
- priv->freq = 24000000;
- .set_invert = sunxi_pwm_set_invert,
- .set_config = sunxi_pwm_set_config,
- .set_enable = sunxi_pwm_set_enable,
- { .compatible = "allwinner,sun8i-h3-pwm" },
- { .compatible = "allwinner,sun50i-a64-pwm" },
- .name = "sunxi_pwm",
- .id = UCLASS_PWM,
- .of_match = sunxi_pwm_ids,
- .ops = &sunxi_pwm_ops,
- .ofdata_to_platdata = sunxi_pwm_ofdata_to_platdata,
- .probe = sunxi_pwm_probe,
- .priv_auto_alloc_size = sizeof(struct sunxi_pwm_priv),
于 2017年9月19日 GMT+08:00 下午4:51:32, Andre Przywara andre.przywara@arm.com 写到:
Backlight for Pinebook.
+struct sunxi_pwm {
- u32 ctrl;
- u32 ch0_period;
Cheers, Andre.
+#endif +#endif
- pwm_init();
+config PWM_SUNXI
- depends on DM_PWM
- help
- ulong freq;
- bool invert;
- 120, /* 0000 */
- 180, /* 0001 */
- 240, /* 0010 */
- 360, /* 0011 */
- 480, /* 0100 */
- 0, /* 0101 */
- 0, /* 0110 */
- 0, /* 0111 */
- 12000, /* 1000 */
- 24000, /* 1001 */
- 36000, /* 1010 */
- 48000, /* 1011 */
- 72000, /* 1100 */
- 0, /* 1101 */
- 0, /* 1110 */
- 1, /* 1111 */
bool polarity)
uint period_ns,
uint duty_ns)
- int prescaler;
duty_ns);
prescaler++) {
continue;
div = priv->freq;
break;
return -EINVAL;
- period = div;
- duty = div;
priv->prescaler,
period, duty);
bool enable)
- uint32_t v;
- if (!enable) {
- .id = UCLASS_PWM,
Ah, right, forgot about that missing Ethernet there ... Thanks for the heads up.
Cheers, Andre.
+struct sunxi_pwm {
- u32 ctrl;
- u32 ch0_period;
Cheers, Andre.
+#endif +#endif
- pwm_init();
+config PWM_SUNXI
- depends on DM_PWM
- help
- ulong freq;
- bool invert;
- 120, /* 0000 */
- 180, /* 0001 */
- 240, /* 0010 */
- 360, /* 0011 */
- 480, /* 0100 */
- 0, /* 0101 */
- 0, /* 0110 */
- 0, /* 0111 */
- 12000, /* 1000 */
- 24000, /* 1001 */
- 36000, /* 1010 */
- 48000, /* 1011 */
- 72000, /* 1100 */
- 0, /* 1101 */
- 0, /* 1110 */
- 1, /* 1111 */
bool polarity)
uint period_ns,
uint duty_ns)
- int prescaler;
duty_ns);
prescaler++) {
continue;
div = priv->freq;
break;
return -EINVAL;
- period = div;
- duty = div;
priv->prescaler,
period, duty);
bool enable)
- uint32_t v;
- if (!enable) {
- .id = UCLASS_PWM,
Andre Przywara
Icenowy Zheng
Maxime Ripard
Vasily Khoruzhick
