Re: [U-Boot-Users] [DNX#2006081142000045] [PATCH 03/07 v2]: tsi108 header file
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006081142000045] was created:
<snip>
Tundra tsi108 header file. Provided the macro define for tsi108 chip.
Signed-off-by: Alexandre Bounine alexandreb@tundra.com Signed-off-by: Roy Zang tie-fei.zang@freescale.com
include/tsi108.h | 221 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 221 insertions(+), 0 deletions(-)
diff --git a/include/tsi108.h b/include/tsi108.h new file mode 100644 index 0000000..072daa0 --- /dev/null +++ b/include/tsi108.h @@ -0,0 +1,221 @@ +/**********************************************************************
- (C) Copyright 2003; Tundra Semiconductor Corp.
- (C) Copyright 2006; Freescale Semiconductor Corp.
- MA 02111-1307 USA
- FILENAME: tsi108.h
- Originator: Alex Bounine
- DESCRIPTION:
- Common definitions for the Tundra Tsi108 bridge chip
+#ifndef _TSI108_H_ +#define _TSI108_H_
+#define TSI108_HLP_REG_OFFSET (0x0000) +#define TSI108_PCI_REG_OFFSET (0x1000) +#define TSI108_CLK_REG_OFFSET (0x2000) +#define TSI108_PB_REG_OFFSET (0x3000) +#define TSI108_SD_REG_OFFSET (0x4000) +#define TSI108_MPIC_REG_OFFSET (0x7400)
+#define PB_ID (0x000) +#define PB_RSR (0x004) +#define PB_BUS_MS_SELECT (0x008) +#define PB_ISR (0x00C) +#define PB_ARB_CTRL (0x018) +#define PB_PVT_CTRL2 (0x034) +#define PB_SCR (0x400) +#define PB_ERRCS (0x404) +#define PB_AERR (0x408) +#define PB_REG_BAR (0x410) +#define PB_OCN_BAR1 (0x414) +#define PB_OCN_BAR2 (0x418) +#define PB_SDRAM_BAR1 (0x41C) +#define PB_SDRAM_BAR2 (0x420) +#define PB_MCR (0xC00) +#define PB_MCMD (0xC04)
+#define HLP_B0_ADDR (0x000) +#define HLP_B1_ADDR (0x010) +#define HLP_B2_ADDR (0x020) +#define HLP_B3_ADDR (0x030)
+#define HLP_B0_MASK (0x004) +#define HLP_B1_MASK (0x014) +#define HLP_B2_MASK (0x024) +#define HLP_B3_MASK (0x034)
+#define HLP_B0_CTRL0 (0x008) +#define HLP_B1_CTRL0 (0x018) +#define HLP_B2_CTRL0 (0x028) +#define HLP_B3_CTRL0 (0x038)
+#define HLP_B0_CTRL1 (0x00C) +#define HLP_B1_CTRL1 (0x01C) +#define HLP_B2_CTRL1 (0x02C) +#define HLP_B3_CTRL1 (0x03C)
+#define PCI_CSR (0x004) +#define PCI_P2O_BAR0 (0x010) +#define PCI_P2O_BAR0_UPPER (0x014) +#define PCI_P2O_BAR2 (0x018)
</snip>
Your U-Boot support team
DENX Support System
