[U-Boot] [PATCH v2 1/4] usb: USB download gadget and functions config options coherent naming
This introduces a coherent scheme for naming USB download gadget and functions config options. The download USB gadget config option is moved to CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each function's config option is moved to a CONFIG_USB_FUNCTION_ prefix.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- README | 2 +- board/samsung/common/Makefile | 2 +- board/siemens/common/factoryset.c | 4 ++-- doc/README.android-fastboot | 2 +- drivers/dfu/Makefile | 2 +- drivers/usb/gadget/Makefile | 8 ++++---- include/configs/am335x_evm.h | 4 ++-- include/configs/am43xx_evm.h | 4 ++-- include/configs/bav335x.h | 6 +++--- include/configs/colibri_vf.h | 6 +++--- include/configs/dra7xx_evm.h | 4 ++-- include/configs/exynos4-common.h | 8 ++++---- include/configs/gw_ventana.h | 4 ++-- include/configs/mx6sabre_common.h | 4 ++-- include/configs/nitrogen6x.h | 4 ++-- include/configs/odroid_xu3.h | 8 ++++---- include/configs/omap3_beagle.h | 2 +- include/configs/s5p_goni.h | 8 ++++---- include/configs/siemens-am33x-common.h | 4 ++-- include/configs/socfpga_common.h | 6 +++--- include/configs/tbs2910.h | 4 ++-- include/configs/tegra-common-usb-gadget.h | 6 +++--- include/configs/warp.h | 6 +++--- include/configs/zynq-common.h | 6 +++--- 24 files changed, 57 insertions(+), 57 deletions(-)
diff --git a/README b/README index 119bbc9..f404812 100644 --- a/README +++ b/README @@ -1675,7 +1675,7 @@ The following options need to be configured: key for the Replay Protection Memory Block partition in eMMC.
- USB Device Firmware Update (DFU) class support: - CONFIG_DFU_FUNCTION + CONFIG_USB_FUNCTION_DFU This enables the USB portion of the DFU USB class
CONFIG_CMD_DFU diff --git a/board/samsung/common/Makefile b/board/samsung/common/Makefile index 93347ef..5fb01ce 100644 --- a/board/samsung/common/Makefile +++ b/board/samsung/common/Makefile @@ -6,7 +6,7 @@ #
obj-$(CONFIG_SOFT_I2C_MULTI_BUS) += multi_i2c.o -obj-$(CONFIG_USBDOWNLOAD_GADGET) += gadget.o +obj-$(CONFIG_USB_GADGET_DOWNLOAD) += gadget.o obj-$(CONFIG_MISC_COMMON) += misc.o
ifndef CONFIG_SPL_BUILD diff --git a/board/siemens/common/factoryset.c b/board/siemens/common/factoryset.c index d81f548..6c869ed 100644 --- a/board/siemens/common/factoryset.c +++ b/board/siemens/common/factoryset.c @@ -144,7 +144,7 @@ int factoryset_read_eeprom(int i2c_addr) unsigned char eeprom_buf[0x3c00], hdr[4], buf[MAX_STRING_LENGTH]; unsigned char *cp, *cp1;
-#if defined(CONFIG_DFU_FUNCTION) +#if defined(CONFIG_USB_FUNCTION_DFU) factory_dat.usb_vendor_id = CONFIG_G_DNL_VENDOR_NUM; factory_dat.usb_product_id = CONFIG_G_DNL_PRODUCT_NUM; #endif @@ -202,7 +202,7 @@ int factoryset_read_eeprom(int i2c_addr) cp1 += 3; }
-#if defined(CONFIG_DFU_FUNCTION) +#if defined(CONFIG_USB_FUNCTION_DFU) /* read vid and pid for dfu mode */ if (0 <= get_factory_record_val(cp, size, (uchar *)"USBD1", (uchar *)"vid", buf, diff --git a/doc/README.android-fastboot b/doc/README.android-fastboot index 04411e9..c2a2418 100644 --- a/doc/README.android-fastboot +++ b/doc/README.android-fastboot @@ -33,7 +33,7 @@ Board specific The fastboot gadget relies on the USB download gadget, so the following options must be configured:
-CONFIG_USBDOWNLOAD_GADGET +CONFIG_USB_GADGET_DOWNLOAD CONFIG_G_DNL_VENDOR_NUM CONFIG_G_DNL_PRODUCT_NUM CONFIG_G_DNL_MANUFACTURER diff --git a/drivers/dfu/Makefile b/drivers/dfu/Makefile index 5cc535e..cebea30 100644 --- a/drivers/dfu/Makefile +++ b/drivers/dfu/Makefile @@ -5,7 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-$(CONFIG_DFU_FUNCTION) += dfu.o +obj-$(CONFIG_USB_FUNCTION_DFU) += dfu.o obj-$(CONFIG_DFU_MMC) += dfu_mmc.o obj-$(CONFIG_DFU_NAND) += dfu_nand.o obj-$(CONFIG_DFU_RAM) += dfu_ram.o diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 70bb550..46d7d94 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -15,10 +15,10 @@ obj-$(CONFIG_USB_GADGET_S3C_UDC_OTG) += s3c_udc_otg.o obj-$(CONFIG_USB_GADGET_S3C_UDC_OTG_PHY) += s3c_udc_otg_phy.o obj-$(CONFIG_USB_GADGET_FOTG210) += fotg210.o obj-$(CONFIG_CI_UDC) += ci_udc.o -obj-$(CONFIG_THOR_FUNCTION) += f_thor.o -obj-$(CONFIG_USBDOWNLOAD_GADGET) += g_dnl.o -obj-$(CONFIG_DFU_FUNCTION) += f_dfu.o -obj-$(CONFIG_USB_GADGET_MASS_STORAGE) += f_mass_storage.o +obj-$(CONFIG_USB_GADGET_DOWNLOAD) += g_dnl.o +obj-$(CONFIG_USB_FUNCTION_THOR) += f_thor.o +obj-$(CONFIG_USB_FUNCTION_DFU) += f_dfu.o +obj-$(CONFIG_USB_FUNCTION_MASS_STORAGE) += f_mass_storage.o obj-$(CONFIG_CMD_FASTBOOT) += f_fastboot.o endif ifdef CONFIG_USB_ETHER diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 8da3325..b94e4b5 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -287,7 +287,7 @@ #define CONFIG_MUSB_PIO_ONLY #define CONFIG_MUSB_DISABLE_BULK_COMBINE_SPLIT #define CONFIG_USB_GADGET -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DOWNLOAD #define CONFIG_USB_GADGET_DUALSPEED #define CONFIG_USB_GADGET_VBUS_DRAW 2 #define CONFIG_MUSB_HOST @@ -344,7 +344,7 @@
/* USB Device Firmware Update support */ #ifndef CONFIG_SPL_BUILD -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_CMD_DFU #define DFU_ALT_INFO_MMC \ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index d4f4c23..af39808 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -118,7 +118,7 @@ #define CONFIG_USB_DWC3_GADGET
#define CONFIG_USB_GADGET -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DOWNLOAD #define CONFIG_USB_GADGET_VBUS_DRAW 2 #define CONFIG_G_DNL_MANUFACTURER "Texas Instruments" #define CONFIG_G_DNL_VENDOR_NUM 0x0403 @@ -128,7 +128,7 @@
#ifndef CONFIG_SPL_BUILD /* USB Device Firmware Update support */ -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_RAM #define CONFIG_CMD_DFU
diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 490c53e..7ce568b 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -444,7 +444,7 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_MUSB_PIO_ONLY #define CONFIG_MUSB_DISABLE_BULK_COMBINE_SPLIT #define CONFIG_USB_GADGET -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DOWNLOAD #define CONFIG_USB_GADGET_DUALSPEED #define CONFIG_USB_GADGET_VBUS_DRAW 2 #define CONFIG_MUSB_HOST @@ -472,7 +472,7 @@ DEFAULT_LINUX_BOOT_ENV \
#ifdef CONFIG_MUSB_GADGET #define CONFIG_CMD_USB_MASS_STORAGE -#define CONFIG_USB_GADGET_MASS_STORAGE +#define CONFIG_USB_FUNCTION_MASS_STORAGE
/* USB TI's IDs */ #define CONFIG_G_DNL_VENDOR_NUM 0x0451 @@ -494,7 +494,7 @@ DEFAULT_LINUX_BOOT_ENV \
/* USB Device Firmware Update support */ #ifndef CONFIG_SPL_BUILD -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_CMD_DFU #define DFU_ALT_INFO_MMC \ diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 4dec42a..2b064f9 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -254,16 +254,16 @@ #define CONFIG_G_DNL_PRODUCT_NUM CONFIG_TRDX_PID_COLIBRI_VF50
/* USB DFU */ -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DOWNLOAD #define CONFIG_CMD_DFU -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_NAND #define CONFIG_DFU_MMC #define CONFIG_SYS_DFU_DATA_BUF_SIZE (1024 * 1024)
/* USB Storage */ #define CONFIG_USB_STORAGE -#define CONFIG_USB_GADGET_MASS_STORAGE +#define CONFIG_USB_FUNCTION_MASS_STORAGE #define CONFIG_CMD_USB_MASS_STORAGE
#endif /* __CONFIG_H */ diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 77edc21..1804cc0 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -186,7 +186,7 @@ #define CONFIG_USB_DWC3_GADGET
#define CONFIG_USB_GADGET -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DOWNLOAD #define CONFIG_USB_GADGET_VBUS_DRAW 2 #define CONFIG_G_DNL_MANUFACTURER "Texas Instruments" #define CONFIG_G_DNL_VENDOR_NUM 0x0451 @@ -194,7 +194,7 @@ #define CONFIG_USB_GADGET_DUALSPEED
diff --git a/include/configs/exynos4-common.h b/include/configs/exynos4-common.h index f6b0a6f..09d7c96 100644 --- a/include/configs/exynos4-common.h +++ b/include/configs/exynos4-common.h @@ -32,13 +32,13 @@ #define CONFIG_CMD_GPT
/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DOWNLOAD
/* TIZEN THOR downloader support */ #define CONFIG_CMD_THOR_DOWNLOAD -#define CONFIG_THOR_FUNCTION +#define CONFIG_USB_FUNCTION_THOR
-#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M #define DFU_DEFAULT_POLL_TIMEOUT 300 @@ -61,7 +61,7 @@ #define CONFIG_USB_GADGET_VBUS_DRAW 2
/* Common environment variables */ #define CONFIG_EXTRA_ENV_ITB \ diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 6b8c82d..e3c2aa9 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -208,8 +208,8 @@ /* USB Mass Storage Gadget */ #define CONFIG_USB_GADGET #define CONFIG_CMD_USB_MASS_STORAGE -#define CONFIG_USB_GADGET_MASS_STORAGE -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_FUNCTION_MASS_STORAGE +#define CONFIG_USB_GADGET_DOWNLOAD #define CONFIG_USB_GADGET_VBUS_DRAW 2
/* Netchip IDs */ diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index c8c9f81..ffddeac 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -218,8 +218,8 @@
#define CONFIG_G_DNL_VENDOR_NUM 0x0525 diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index beaa119..1c2eb47 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -338,8 +338,8 @@
/* Netchip IDs */ diff --git a/include/configs/odroid_xu3.h b/include/configs/odroid_xu3.h index cf17f3d..8d5c736 100644 --- a/include/configs/odroid_xu3.h +++ b/include/configs/odroid_xu3.h @@ -60,10 +60,10 @@ #define CONFIG_G_DNL_VENDOR_NUM 0x04E8 #define CONFIG_G_DNL_PRODUCT_NUM 0x6601 #define CONFIG_G_DNL_MANUFACTURER "Samsung" -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DOWNLOAD
/* DFU */ -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_CMD_DFU #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M @@ -72,13 +72,13 @@ /* THOR */ #define CONFIG_G_DNL_THOR_VENDOR_NUM CONFIG_G_DNL_VENDOR_NUM #define CONFIG_G_DNL_THOR_PRODUCT_NUM 0x685D -#define CONFIG_THOR_FUNCTION +#define CONFIG_USB_FUNCTION_THOR #define CONFIG_CMD_THOR_DOWNLOAD
/* UMS */ #define CONFIG_G_DNL_UMS_VENDOR_NUM 0x0525 #define CONFIG_G_DNL_UMS_PRODUCT_NUM 0xA4A5 -#define CONFIG_USB_GADGET_MASS_STORAGE +#define CONFIG_USB_FUNCTION_MASS_STORAGE #define CONFIG_CMD_USB_MASS_STORAGE
/* FIXME: MUST BE REMOVED AFTER TMU IS TURNED ON */ diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 709528b..46c0680 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -68,7 +68,7 @@ #define CONFIG_USB_ETHER_RNDIS #define CONFIG_USB_GADGET #define CONFIG_USB_GADGET_VBUS_DRAW 0 -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DOWNLOAD #define CONFIG_G_DNL_VENDOR_NUM 0x0451 #define CONFIG_G_DNL_PRODUCT_NUM 0xd022 #define CONFIG_G_DNL_MANUFACTURER "TI" diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 16770f0..bac4362 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -76,15 +76,15 @@ #define CONFIG_CMD_GPT
/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_GADGET_DOWNLOAD +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M #define DFU_DEFAULT_POLL_TIMEOUT 300
/* USB Samsung's IDs */ #define CONFIG_G_DNL_VENDOR_NUM 0x04E8 @@ -283,7 +283,7 @@ #define CONFIG_USB_GADGET_DUALSPEED #define CONFIG_USB_GADGET_VBUS_DRAW 2 #define CONFIG_CMD_USB_MASS_STORAGE -#define CONFIG_USB_GADGET_MASS_STORAGE +#define CONFIG_USB_FUNCTION_MASS_STORAGE
#define CONFIG_OF_LIBFDT
diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index f086e73..9b4be3f 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -250,7 +250,7 @@ #endif /* CONFIG_MUSB_GADGET */
/* USB DRACO ID as default */ #define CONFIG_USBD_HS @@ -259,7 +259,7 @@ #define CONFIG_G_DNL_MANUFACTURER "Siemens AG"
/* USB Device Firmware Update support */ -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_NAND #define CONFIG_CMD_DFU #define CONFIG_SYS_DFU_DATA_BUF_SIZE (1 << 20) diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 5ba2f6a..53dc51d 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -245,10 +245,10 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_USB_GADGET_VBUS_DRAW 2
/* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET -#define CONFIG_USB_GADGET_MASS_STORAGE +#define CONFIG_USB_GADGET_DOWNLOAD +#define CONFIG_USB_FUNCTION_MASS_STORAGE
-#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_SYS_DFU_DATA_BUF_SIZE (32 * 1024 * 1024) #define DFU_DEFAULT_POLL_TIMEOUT 300 diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index e1c9937..b702a06 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -127,10 +127,10 @@ #define CONFIG_CI_UDC #define CONFIG_USBD_HS #define CONFIG_USB_GADGET -#define CONFIG_USB_GADGET_MASS_STORAGE +#define CONFIG_USB_FUNCTION_MASS_STORAGE #define CONFIG_USB_GADGET_DUALSPEED #define CONFIG_USB_GADGET_VBUS_DRAW 0 -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DOWNLOAD #define CONFIG_G_DNL_VENDOR_NUM 0x0525 #define CONFIG_G_DNL_PRODUCT_NUM 0xa4a5 #define CONFIG_G_DNL_MANUFACTURER "TBS" diff --git a/include/configs/tegra-common-usb-gadget.h b/include/configs/tegra-common-usb-gadget.h index 287460c..d70a4e7 100644 --- a/include/configs/tegra-common-usb-gadget.h +++ b/include/configs/tegra-common-usb-gadget.h @@ -18,12 +18,12 @@ #define CONFIG_G_DNL_VENDOR_NUM 0x0955 #define CONFIG_G_DNL_PRODUCT_NUM 0x701A #define CONFIG_G_DNL_MANUFACTURER "NVIDIA" -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DOWNLOAD /* USB mass storage protocol */ -#define CONFIG_USB_GADGET_MASS_STORAGE +#define CONFIG_USB_FUNCTION_MASS_STORAGE #define CONFIG_CMD_USB_MASS_STORAGE /* DFU protocol */ -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_SYS_DFU_DATA_BUF_SIZE (1 * 1024 * 1024) #define CONFIG_CMD_DFU #ifdef CONFIG_MMC diff --git a/include/configs/warp.h b/include/configs/warp.h index e38b425..a152913 100644 --- a/include/configs/warp.h +++ b/include/configs/warp.h @@ -82,8 +82,8 @@
#define CONFIG_G_DNL_VENDOR_NUM 0x0525 @@ -91,7 +91,7 @@ #define CONFIG_G_DNL_MANUFACTURER "FSL"
#define CONFIG_CMD_DFU -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_SYS_DFU_DATA_BUF_SIZE SZ_32M #define DFU_DEFAULT_POLL_TIMEOUT 300 diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 1a52e7d..3c7eefd 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -111,10 +111,10 @@ # define CONFIG_CI_UDC /* ChipIdea CI13xxx UDC */ # define CONFIG_USB_GADGET # define CONFIG_USB_GADGET_DUALSPEED -# define CONFIG_USBDOWNLOAD_GADGET +# define CONFIG_USB_GADGET_DOWNLOAD # define CONFIG_SYS_DFU_DATA_BUF_SIZE 0x600000 # define DFU_DEFAULT_POLL_TIMEOUT 300 -# define CONFIG_DFU_FUNCTION +# define CONFIG_USB_FUNCTION_DFU # define CONFIG_DFU_RAM # define CONFIG_USB_GADGET_VBUS_DRAW 2 # define CONFIG_G_DNL_VENDOR_NUM 0x03FD @@ -124,7 +124,7 @@ # define CONFIG_USB_CABLE_CHECK # define CONFIG_CMD_DFU # define CONFIG_CMD_THOR_DOWNLOAD -# define CONFIG_THOR_FUNCTION +# define CONFIG_USB_FUNCTION_THOR # define DFU_ALT_INFO_RAM \ "dfu_ram_info=" \ "set dfu_alt_info " \
USB download gadget functions such as thor and dfu have a separate config option for the USB gadget part of the code, independent from the command part. This switches the fastboot USB gadget to the same scheme, for better consistency.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- README | 3 +++ arch/arm/cpu/armv7/omap-common/boot-common.c | 2 +- doc/README.android-fastboot | 4 ++-- drivers/usb/gadget/Makefile | 2 +- include/configs/am335x_evm.h | 1 + include/configs/bav335x.h | 1 + include/configs/dra7xx_evm.h | 1 + include/configs/nitrogen6x.h | 1 + include/configs/omap3_beagle.h | 1 + 9 files changed, 12 insertions(+), 4 deletions(-)
diff --git a/README b/README index f404812..2aa0cea 100644 --- a/README +++ b/README @@ -1720,6 +1720,9 @@ The following options need to be configured: sending again an USB request to the device.
- USB Device Android Fastboot support: + CONFIG_USB_FUNCTION_FASTBOOT + This enables the USB part of the fastboot gadget + CONFIG_CMD_FASTBOOT This enables the command "fastboot" which enables the Android fastboot mode for the platform's USB device. Fastboot is a USB diff --git a/arch/arm/cpu/armv7/omap-common/boot-common.c b/arch/arm/cpu/armv7/omap-common/boot-common.c index bbc6bed..7fc0a56 100644 --- a/arch/arm/cpu/armv7/omap-common/boot-common.c +++ b/arch/arm/cpu/armv7/omap-common/boot-common.c @@ -163,7 +163,7 @@ void arch_preboot_os(void) } #endif
-#if defined(CONFIG_CMD_FASTBOOT) && !defined(CONFIG_ENV_IS_NOWHERE) +#if defined(CONFIG_USB_FUNCTION_FASTBOOT) && !defined(CONFIG_ENV_IS_NOWHERE) int fb_set_reboot_flag(void) { printf("Setting reboot to fastboot flag ...\n"); diff --git a/doc/README.android-fastboot b/doc/README.android-fastboot index c2a2418..92f2897 100644 --- a/doc/README.android-fastboot +++ b/doc/README.android-fastboot @@ -42,8 +42,8 @@ NOTE: The CONFIG_G_DNL_VENDOR_NUM must be one of the numbers supported by the fastboot client. The list of vendor IDs supported can be found in the fastboot client source code (fastboot.c) mentioned above.
-The fastboot function is enabled by defining CONFIG_CMD_FASTBOOT and -CONFIG_ANDROID_BOOT_IMAGE. +The fastboot function is enabled by defining CONFIG_USB_FUNCTION_FASTBOOT, +CONFIG_CMD_FASTBOOT and CONFIG_ANDROID_BOOT_IMAGE.
The fastboot protocol requires a large memory buffer for downloads. This buffer should be as large as possible for a platform. The location of the diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 46d7d94..4e15323 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -19,7 +19,7 @@ obj-$(CONFIG_USB_GADGET_DOWNLOAD) += g_dnl.o obj-$(CONFIG_USB_FUNCTION_THOR) += f_thor.o obj-$(CONFIG_USB_FUNCTION_DFU) += f_dfu.o obj-$(CONFIG_USB_FUNCTION_MASS_STORAGE) += f_mass_storage.o -obj-$(CONFIG_CMD_FASTBOOT) += f_fastboot.o +obj-$(CONFIG_USB_FUNCTION_FASTBOOT) += f_fastboot.o endif ifdef CONFIG_USB_ETHER obj-y += ether.o diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index b94e4b5..8aa3fd7 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -298,6 +298,7 @@
#ifndef CONFIG_SPL_USBETH_SUPPORT /* Fastboot */ +#define CONFIG_USB_FUNCTION_FASTBOOT #define CONFIG_CMD_FASTBOOT #define CONFIG_ANDROID_BOOT_IMAGE #define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 7ce568b..99e3a00 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -455,6 +455,7 @@ DEFAULT_LINUX_BOOT_ENV \
#ifndef CONFIG_SPL_USBETH_SUPPORT /* Fastboot */ +#define CONFIG_USB_FUNCTION_FASTBOOT #define CONFIG_CMD_FASTBOOT #define CONFIG_ANDROID_BOOT_IMAGE #define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index 1804cc0..fc8de70 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -85,6 +85,7 @@ DFU_ALT_INFO_RAM
/* Fastboot */ +#define CONFIG_USB_FUNCTION_FASTBOOT #define CONFIG_CMD_FASTBOOT #define CONFIG_ANDROID_BOOT_IMAGE #define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 1c2eb47..191c0dd 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -347,6 +347,7 @@ #define CONFIG_G_DNL_PRODUCT_NUM 0xa4a5 #define CONFIG_G_DNL_MANUFACTURER "Boundary"
+#define CONFIG_USB_FUNCTION_FASTBOOT #define CONFIG_CMD_FASTBOOT #define CONFIG_ANDROID_BOOT_IMAGE #define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 46c0680..9089876 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -72,6 +72,7 @@ #define CONFIG_G_DNL_VENDOR_NUM 0x0451 #define CONFIG_G_DNL_PRODUCT_NUM 0xd022 #define CONFIG_G_DNL_MANUFACTURER "TI" +#define CONFIG_USB_FUNCTION_FASTBOOT #define CONFIG_CMD_FASTBOOT #define CONFIG_ANDROID_BOOT_IMAGE #define CONFIG_USB_FASTBOOT_BUF_ADDR CONFIG_SYS_LOAD_ADDR
Each USB download function command calls board_usb_init before registering the USB gadget and board_usb_cleanup after de-registering it. On devices currently using fasboot, musb-new is usually initialized earlier, but some other boards might need the board_usb_init call to properly initialize musb-new.
This requires adding an argument (the USB controller index) to the fastboot command, as it is currently done with other USB download gadget functions.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- common/cmd_fastboot.c | 31 +++++++++++++++++++++++++------ include/configs/ti_omap5_common.h | 2 +- 2 files changed, 26 insertions(+), 7 deletions(-)
diff --git a/common/cmd_fastboot.c b/common/cmd_fastboot.c index d52ccfb..86fbddf 100644 --- a/common/cmd_fastboot.c +++ b/common/cmd_fastboot.c @@ -10,11 +10,26 @@ #include <common.h> #include <command.h> #include <g_dnl.h> +#include <usb.h>
static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { + int controller_index; + char *usb_controller; int ret;
+ if (argc < 2) + return CMD_RET_USAGE; + + usb_controller = argv[1]; + controller_index = simple_strtoul(usb_controller, NULL, 0); + + ret = board_usb_init(controller_index, USB_INIT_DEVICE); + if (ret) { + error("USB init failed: %d", ret); + return CMD_RET_FAILURE; + } + g_dnl_clear_detach(); ret = g_dnl_register("usb_dnl_fastboot"); if (ret) @@ -23,9 +38,8 @@ static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) if (!g_dnl_board_usb_cable_connected()) { puts("\rUSB cable not detected.\n" \ "Command exit.\n"); - g_dnl_unregister(); - g_dnl_clear_detach(); - return CMD_RET_FAILURE; + ret = CMD_RET_FAILURE; + goto exit; }
while (1) { @@ -36,14 +50,19 @@ static int do_fastboot(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) usb_gadget_handle_interrupts(0); }
+ ret = CMD_RET_SUCCESS; + +exit: g_dnl_unregister(); g_dnl_clear_detach(); - return CMD_RET_SUCCESS; + board_usb_cleanup(controller_index, USB_INIT_DEVICE); + + return ret; }
U_BOOT_CMD( - fastboot, 1, 0, do_fastboot, + fastboot, 2, 1, do_fastboot, "use USB Fastboot protocol", - "\n" + "<USB_controller>\n" " - run as a fastboot usb device" ); diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 4faffef..4fd5669 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -137,7 +137,7 @@ "if test ${dofastboot} -eq 1; then " \ "echo Boot fastboot requested, resetting dofastboot ...;" \ "setenv dofastboot 0; saveenv;" \ - "echo Booting into fastboot ...; fastboot;" \ + "echo Booting into fastboot ...; fastboot 0;" \ "fi;" \ "run findfdt; " \ "run mmcboot;" \
Hi Paul,
if (argc < 2)
Not backwards compatible.... I would prefer to make it optional: if (argc < 2) controller_index = 0; else { usb_controller = argv[1]; controller_index = simple_strtoul(usb_controller, NULL, 0); }
- controller_index = simple_strtoul(usb_controller, NULL, 0);
- ret = board_usb_init(controller_index, USB_INIT_DEVICE);
- if (ret) {
- g_dnl_clear_detach(); ret = g_dnl_register("usb_dnl_fastboot"); if (ret)
g_dnl_unregister();
goto exit;
while (1) {
- ret = CMD_RET_SUCCESS;
return ret; }
U_BOOT_CMD(
- fastboot, 2, 1, do_fastboot, "use USB Fastboot protocol",
- "\n"
- "<USB_controller>\n"
make it optional: "[<USB_controller>]\n"
then this isn't needed either....
Thanks, Steve
Le mardi 16 juin 2015 à 13:58 -0700, Steve Rae a écrit :
Hi Paul,
if (argc < 2)
This is definitely a "bug fix". There is no reason to assume that the USB controller index is 0 and it was incorrect to assume that from the very beginning. Other download USB gadget commands had the controller index as a non-optional parameter already.
Since I fixed the configs that use it in U-Boot, I think it's fair enough. This may indeed break some hand-written scripts but those will be straightforward to fix.
I am strongly against keeping deprecated legacy fallbacks that make the code inconsistent and harder to maintain just for the sake of keeping backwards compatibility with users' hand-written scripts.
- if (ret) {
g_dnl_unregister();
goto exit;
while (1) {
return ret; }
U_BOOT_CMD(
- "\n"
Thanks, Steve
Hi Paul,
if (argc < 2)
I understand, but I'm more worried about _all_ the existing documentation that states the the command line is "fastboot" (which now would need to be changed to "fastboot 0")
- if (ret) {
g_dnl_unregister();
goto exit;
while (1) {
return ret; }
U_BOOT_CMD(
- "\n"
Thanks, Steve
Hi Paul,
if (argc < 2)
Well, if I missed someplace in U-Boot where it is stated that only "fastboot" is sufficient to run the command, I should change that too.
Otherwise, for third party guides, the rationale is the same as previously stated.
- if (ret) {
g_dnl_unregister();
goto exit;
while (1) {
return ret; }
U_BOOT_CMD(
- "\n"
Thanks, Steve
Weak versions of board_usb_init and board_usb_cleanup are defined in common USB host code, but it is also used for USB device gadgets, so we also need a weak definition of it when there is no USB host enabled. Both weak definitions do not conflict.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- drivers/usb/gadget/g_dnl.c | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/drivers/usb/gadget/g_dnl.c b/drivers/usb/gadget/g_dnl.c index ee52a29..ad89a0d 100644 --- a/drivers/usb/gadget/g_dnl.c +++ b/drivers/usb/gadget/g_dnl.c @@ -12,6 +12,7 @@
#include <mmc.h> #include <part.h> +#include <usb.h>
#include <g_dnl.h> #include <usb_mass_storage.h> @@ -148,6 +149,18 @@ static int g_dnl_config_register(struct usb_composite_dev *cdev) }
__weak +int board_usb_init(int index, enum usb_init_type init) +{ + return 0; +} + +__weak +int board_usb_cleanup(int index, enum usb_init_type init) +{ + return 0; +} + +__weak int g_dnl_bind_fixup(struct usb_device_descriptor *dev, const char *name) { return 0;
Lukasz, does that series look good to you (now that there is Odroid XU3 support too)? Could this be merged soon?
Thanks!
CONFIG_DFU_FUNCTION
CONFIG_CMD_DFU
Hi Paul,
I'm going to give it a test run. If no errors I will add it to u-boo-dfu tree.
Thanks for remainder.
Thanks!
CONFIG_DFU_FUNCTION
CONFIG_CMD_DFU
/* USB Device Firmware Update support */ #ifndef CONFIG_SPL_BUILD -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_MMC #define CONFIG_CMD_DFU #define DFU_ALT_INFO_MMC \ diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 4dec42a..2b064f9 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -254,16 +254,16 @@ #define CONFIG_G_DNL_PRODUCT_NUM CONFIG_TRDX_PID_COLIBRI_VF50 /* USB DFU */ -#define CONFIG_USBDOWNLOAD_GADGET +#define CONFIG_USB_GADGET_DOWNLOAD #define CONFIG_CMD_DFU -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_NAND #define CONFIG_DFU_MMC #define CONFIG_SYS_DFU_DATA_BUF_SIZE (1024 * 1024)
/* USB Device Firmware Update support */ -#define CONFIG_DFU_FUNCTION +#define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_NAND #define CONFIG_CMD_DFU #define CONFIG_SYS_DFU_DATA_BUF_SIZE (1 << 20) diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 5ba2f6a..53dc51d 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -245,10 +245,10 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_USB_GADGET_VBUS_DRAW 2 /* USB Composite download gadget - g_dnl */ -#define CONFIG_USBDOWNLOAD_GADGET -#define CONFIG_USB_GADGET_MASS_STORAGE +#define CONFIG_USB_GADGET_DOWNLOAD +#define CONFIG_USB_FUNCTION_MASS_STORAGE
Hi Paul,
All is OK. Thanks for your work. I've pushed your work to u-boot-dfu repository.
Thanks!
CONFIG_DFU_FUNCTION
CONFIG_CMD_DFU
Lukasz Majewski
Paul Kocialkowski
Steve Rae
