[PATCH] arm: dts: stm32mp15: alignment with v5.11-rc2
Device tree alignment with Linux kernel v5.11-rc2 - fix DCMI DMA features on stm32mp15 family - Add alternate pinmux for FMC EBI bus - Harmonize EHCI/OHCI DT nodes name on stm32mp15 - update sdmmc IP version for STM32MP15 - Add LP timer irqs on stm32mp151 - Add LP timer wakeup-source on stm32mp151 - enable HASH by default on stm32mp15 - enable CRC1 by default on stm32mp15 - enable CRYP by default on stm32mp15 - set bus-type in DCMI endpoint for stm32mp157c-ev1 board - reorder spi4 within stm32mp15-pinctrl - add STUSB1600 Type-C using I2C4 on stm32mp15xx-dkx - fix mdma1 clients channel priority level on stm32mp151 - fix dmamux reg property on stm32mp151 - adjust USB OTG gadget fifo sizes in stm32mp151 - update stm32mp151 for remote proc synchronization support - support child mfd cells for the stm32mp1 TAMP syscon
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/dts/stm32mp15-pinctrl.dtsi | 87 +++++++++++++++++++++- arch/arm/dts/stm32mp151.dtsi | 48 +++++++++--- arch/arm/dts/stm32mp153.dtsi | 6 ++ arch/arm/dts/stm32mp157c-dk2.dts | 4 + arch/arm/dts/stm32mp157c-ed1.dts | 27 +++++++ arch/arm/dts/stm32mp157c-ev1.dts | 1 + arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi | 55 -------------- arch/arm/dts/stm32mp15xx-dkx.dtsi | 47 ++++++++++-- 8 files changed, 200 insertions(+), 75 deletions(-)
diff --git a/arch/arm/dts/stm32mp15-pinctrl.dtsi b/arch/arm/dts/stm32mp15-pinctrl.dtsi index 154832983c..dd4bd1e554 100644 --- a/arch/arm/dts/stm32mp15-pinctrl.dtsi +++ b/arch/arm/dts/stm32mp15-pinctrl.dtsi @@ -349,6 +349,61 @@ }; };
+ fmc_pins_b: fmc-1 { + pins { + pinmux = <STM32_PINMUX('D', 4, AF12)>, /* FMC_NOE */ + <STM32_PINMUX('D', 5, AF12)>, /* FMC_NWE */ + <STM32_PINMUX('B', 7, AF12)>, /* FMC_NL */ + <STM32_PINMUX('D', 14, AF12)>, /* FMC_D0 */ + <STM32_PINMUX('D', 15, AF12)>, /* FMC_D1 */ + <STM32_PINMUX('D', 0, AF12)>, /* FMC_D2 */ + <STM32_PINMUX('D', 1, AF12)>, /* FMC_D3 */ + <STM32_PINMUX('E', 7, AF12)>, /* FMC_D4 */ + <STM32_PINMUX('E', 8, AF12)>, /* FMC_D5 */ + <STM32_PINMUX('E', 9, AF12)>, /* FMC_D6 */ + <STM32_PINMUX('E', 10, AF12)>, /* FMC_D7 */ + <STM32_PINMUX('E', 11, AF12)>, /* FMC_D8 */ + <STM32_PINMUX('E', 12, AF12)>, /* FMC_D9 */ + <STM32_PINMUX('E', 13, AF12)>, /* FMC_D10 */ + <STM32_PINMUX('E', 14, AF12)>, /* FMC_D11 */ + <STM32_PINMUX('E', 15, AF12)>, /* FMC_D12 */ + <STM32_PINMUX('D', 8, AF12)>, /* FMC_D13 */ + <STM32_PINMUX('D', 9, AF12)>, /* FMC_D14 */ + <STM32_PINMUX('D', 10, AF12)>, /* FMC_D15 */ + <STM32_PINMUX('G', 9, AF12)>, /* FMC_NE2_FMC_NCE */ + <STM32_PINMUX('G', 12, AF12)>; /* FMC_NE4 */ + bias-disable; + drive-push-pull; + slew-rate = <3>; + }; + }; + + fmc_sleep_pins_b: fmc-sleep-1 { + pins { + pinmux = <STM32_PINMUX('D', 4, ANALOG)>, /* FMC_NOE */ + <STM32_PINMUX('D', 5, ANALOG)>, /* FMC_NWE */ + <STM32_PINMUX('B', 7, ANALOG)>, /* FMC_NL */ + <STM32_PINMUX('D', 14, ANALOG)>, /* FMC_D0 */ + <STM32_PINMUX('D', 15, ANALOG)>, /* FMC_D1 */ + <STM32_PINMUX('D', 0, ANALOG)>, /* FMC_D2 */ + <STM32_PINMUX('D', 1, ANALOG)>, /* FMC_D3 */ + <STM32_PINMUX('E', 7, ANALOG)>, /* FMC_D4 */ + <STM32_PINMUX('E', 8, ANALOG)>, /* FMC_D5 */ + <STM32_PINMUX('E', 9, ANALOG)>, /* FMC_D6 */ + <STM32_PINMUX('E', 10, ANALOG)>, /* FMC_D7 */ + <STM32_PINMUX('E', 11, ANALOG)>, /* FMC_D8 */ + <STM32_PINMUX('E', 12, ANALOG)>, /* FMC_D9 */ + <STM32_PINMUX('E', 13, ANALOG)>, /* FMC_D10 */ + <STM32_PINMUX('E', 14, ANALOG)>, /* FMC_D11 */ + <STM32_PINMUX('E', 15, ANALOG)>, /* FMC_D12 */ + <STM32_PINMUX('D', 8, ANALOG)>, /* FMC_D13 */ + <STM32_PINMUX('D', 9, ANALOG)>, /* FMC_D14 */ + <STM32_PINMUX('D', 10, ANALOG)>, /* FMC_D15 */ + <STM32_PINMUX('G', 9, ANALOG)>, /* FMC_NE2_FMC_NCE */ + <STM32_PINMUX('G', 12, ANALOG)>; /* FMC_NE4 */ + }; + }; + i2c1_pins_a: i2c1-0 { pins { pinmux = <STM32_PINMUX('D', 12, AF5)>, /* I2C1_SCL */ @@ -1437,6 +1492,24 @@ }; };
+ sdmmc2_d47_pins_d: sdmmc2-d47-3 { + pins { + pinmux = <STM32_PINMUX('A', 8, AF9)>, /* SDMMC2_D4 */ + <STM32_PINMUX('A', 9, AF10)>, /* SDMMC2_D5 */ + <STM32_PINMUX('E', 5, AF9)>, /* SDMMC2_D6 */ + <STM32_PINMUX('C', 7, AF10)>; /* SDMMC2_D7 */ + }; + }; + + sdmmc2_d47_sleep_pins_d: sdmmc2-d47-sleep-3 { + pins { + pinmux = <STM32_PINMUX('A', 8, ANALOG)>, /* SDMMC2_D4 */ + <STM32_PINMUX('A', 9, ANALOG)>, /* SDMMC2_D5 */ + <STM32_PINMUX('E', 5, ANALOG)>, /* SDMMC2_D6 */ + <STM32_PINMUX('C', 7, ANALOG)>; /* SDMMC2_D7 */ + }; + }; + sdmmc3_b4_pins_a: sdmmc3-b4-0 { pins1 { pinmux = <STM32_PINMUX('F', 0, AF9)>, /* SDMMC3_D0 */ @@ -1588,9 +1661,9 @@ };
stusb1600_pins_a: stusb1600-0 { - pins { - pinmux = <STM32_PINMUX('I', 11, ANALOG)>; - bias-pull-up; + pins { + pinmux = <STM32_PINMUX('I', 11, ANALOG)>; + bias-pull-up; }; };
@@ -1721,6 +1794,14 @@ }; };
+ uart8_rtscts_pins_a: uart8rtscts-0 { + pins { + pinmux = <STM32_PINMUX('G', 7, AF8)>, /* UART8_RTS */ + <STM32_PINMUX('G', 10, AF8)>; /* UART8_CTS */ + bias-disable; + }; + }; + usart2_pins_a: usart2-0 { pins1 { pinmux = <STM32_PINMUX('F', 5, AF7)>, /* USART2_TX */ diff --git a/arch/arm/dts/stm32mp151.dtsi b/arch/arm/dts/stm32mp151.dtsi index 206d3d3c78..eedea6f4b8 100644 --- a/arch/arm/dts/stm32mp151.dtsi +++ b/arch/arm/dts/stm32mp151.dtsi @@ -41,6 +41,13 @@ }; };
+ arm-pmu { + compatible = "arm,cortex-a7-pmu"; + interrupts = <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>; + interrupt-parent = <&intc>; + }; + psci { compatible = "arm,psci-1.0"; method = "smc"; @@ -373,8 +380,10 @@ #size-cells = <0>; compatible = "st,stm32-lptimer"; reg = <0x40009000 0x400>; + interrupts-extended = <&exti 47 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc LPTIM1_K>; clock-names = "mux"; + wakeup-source; status = "disabled";
pwm { @@ -1010,7 +1019,7 @@
dmamux1: dma-router@48002000 { compatible = "st,stm32h7-dmamux"; - reg = <0x48002000 0x1c>; + reg = <0x48002000 0x40>; #dma-cells = <3>; dma-requests = <128>; dma-masters = <&dma1 &dma2>; @@ -1058,7 +1067,7 @@
sdmmc3: sdmmc@48004000 { compatible = "arm,pl18x", "arm,primecell"; - arm,primecell-periphid = <0x10153180>; + arm,primecell-periphid = <0x00253180>; reg = <0x48004000 0x400>; interrupts = <GIC_SPI 137 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "cmd_irq"; @@ -1079,9 +1088,9 @@ resets = <&rcc USBO_R>; reset-names = "dwc2"; interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - g-rx-fifo-size = <256>; + g-rx-fifo-size = <512>; g-np-tx-fifo-size = <32>; - g-tx-fifo-size = <128 128 64 64 64 64 32 32>; + g-tx-fifo-size = <256 16 16 16 16 16 16 16>; dr_mode = "otg"; usb33d-supply = <&usb33>; status = "disabled"; @@ -1117,7 +1126,7 @@ resets = <&rcc CAMITF_R>; clocks = <&rcc DCMI>; clock-names = "mclk"; - dmas = <&dmamux1 75 0x400 0x0d>; + dmas = <&dmamux1 75 0x400 0x01>; dma-names = "tx"; status = "disabled"; }; @@ -1175,8 +1184,10 @@ #size-cells = <0>; compatible = "st,stm32-lptimer"; reg = <0x50021000 0x400>; + interrupts-extended = <&exti 48 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc LPTIM2_K>; clock-names = "mux"; + wakeup-source; status = "disabled";
pwm { @@ -1202,8 +1213,10 @@ #size-cells = <0>; compatible = "st,stm32-lptimer"; reg = <0x50022000 0x400>; + interrupts-extended = <&exti 50 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc LPTIM3_K>; clock-names = "mux"; + wakeup-source; status = "disabled";
pwm { @@ -1222,8 +1235,10 @@ lptimer4: timer@50023000 { compatible = "st,stm32-lptimer"; reg = <0x50023000 0x400>; + interrupts-extended = <&exti 52 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc LPTIM4_K>; clock-names = "mux"; + wakeup-source; status = "disabled";
pwm { @@ -1236,8 +1251,10 @@ lptimer5: timer@50024000 { compatible = "st,stm32-lptimer"; reg = <0x50024000 0x400>; + interrupts-extended = <&exti 53 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc LPTIM5_K>; clock-names = "mux"; + wakeup-source; status = "disabled";
pwm { @@ -1303,7 +1320,7 @@ interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; clocks = <&rcc HASH1>; resets = <&rcc HASH1_R>; - dmas = <&mdma1 31 0x10 0x1000A02 0x0 0x0>; + dmas = <&mdma1 31 0x2 0x1000A02 0x0 0x0>; dma-names = "in"; dma-maxburst = <2>; status = "disabled"; @@ -1367,8 +1384,8 @@ reg = <0x58003000 0x1000>, <0x70000000 0x10000000>; reg-names = "qspi", "qspi_mm"; interrupts = <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>; - dmas = <&mdma1 22 0x10 0x100002 0x0 0x0>, - <&mdma1 22 0x10 0x100008 0x0 0x0>; + dmas = <&mdma1 22 0x2 0x100002 0x0 0x0>, + <&mdma1 22 0x2 0x100008 0x0 0x0>; dma-names = "tx", "rx"; clocks = <&rcc QSPI_K>; resets = <&rcc QSPI_R>; @@ -1379,7 +1396,7 @@
sdmmc1: sdmmc@58005000 { compatible = "arm,pl18x", "arm,primecell"; - arm,primecell-periphid = <0x10153180>; + arm,primecell-periphid = <0x00253180>; reg = <0x58005000 0x1000>; interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "cmd_irq"; @@ -1394,7 +1411,7 @@
sdmmc2: sdmmc@58007000 { compatible = "arm,pl18x", "arm,primecell"; - arm,primecell-periphid = <0x10153180>; + arm,primecell-periphid = <0x00253180>; reg = <0x58007000 0x1000>; interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "cmd_irq"; @@ -1445,7 +1462,7 @@ status = "disabled"; };
- usbh_ohci: usbh-ohci@5800c000 { + usbh_ohci: usb@5800c000 { compatible = "generic-ohci"; reg = <0x5800c000 0x1000>; clocks = <&rcc USBH>; @@ -1454,7 +1471,7 @@ status = "disabled"; };
- usbh_ehci: usbh-ehci@5800d000 { + usbh_ehci: usb@5800d000 { compatible = "generic-ehci"; reg = <0x5800d000 0x1000>; clocks = <&rcc USBH>; @@ -1587,6 +1604,11 @@ status = "disabled"; };
+ tamp: tamp@5c00a000 { + compatible = "st,stm32-tamp", "syscon", "simple-mfd"; + reg = <0x5c00a000 0x400>; + }; + /* * Break node order to solve dependency probe issue between * pinctrl and exti. @@ -1765,6 +1787,8 @@ st,syscfg-holdboot = <&rcc 0x10C 0x1>; st,syscfg-tz = <&rcc 0x000 0x1>; st,syscfg-pdds = <&pwr_mcu 0x0 0x1>; + st,syscfg-rsc-tbl = <&tamp 0x144 0xFFFFFFFF>; + st,syscfg-m4-state = <&tamp 0x148 0xFFFFFFFF>; status = "disabled"; }; }; diff --git a/arch/arm/dts/stm32mp153.dtsi b/arch/arm/dts/stm32mp153.dtsi index 6d9ab08667..1c1889b194 100644 --- a/arch/arm/dts/stm32mp153.dtsi +++ b/arch/arm/dts/stm32mp153.dtsi @@ -16,6 +16,12 @@ }; };
+ arm-pmu { + interrupts = <GIC_SPI 200 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 201 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>; + }; + soc { m_can1: can@4400e000 { compatible = "bosch,m_can"; diff --git a/arch/arm/dts/stm32mp157c-dk2.dts b/arch/arm/dts/stm32mp157c-dk2.dts index 045636555d..2bc92ef3ae 100644 --- a/arch/arm/dts/stm32mp157c-dk2.dts +++ b/arch/arm/dts/stm32mp157c-dk2.dts @@ -29,6 +29,10 @@ }; };
+&cryp1 { + status = "okay"; +}; + &dsi { status = "okay"; phy-dsi-supply = <®18>; diff --git a/arch/arm/dts/stm32mp157c-ed1.dts b/arch/arm/dts/stm32mp157c-ed1.dts index dd911c9932..6e89f88a17 100644 --- a/arch/arm/dts/stm32mp157c-ed1.dts +++ b/arch/arm/dts/stm32mp157c-ed1.dts @@ -89,6 +89,14 @@ states = <1800000 0x1>, <2900000 0x0>; }; + + vin: vin { + compatible = "regulator-fixed"; + regulator-name = "vin"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; };
&adc { @@ -115,6 +123,14 @@ cpu-supply = <&vddcore>; };
+&crc1 { + status = "okay"; +}; + +&cryp1 { + status = "okay"; +}; + &dac { pinctrl-names = "default"; pinctrl-0 = <&dac_ch1_pins_a &dac_ch2_pins_a>; @@ -136,6 +152,10 @@ contiguous-area = <&gpu_reserved>; };
+&hash1 { + status = "okay"; +}; + &i2c4 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&i2c4_pins_a>; @@ -158,11 +178,18 @@
regulators { compatible = "st,stpmic1-regulators"; + buck1-supply = <&vin>; + buck2-supply = <&vin>; + buck3-supply = <&vin>; + buck4-supply = <&vin>; ldo1-supply = <&v3v3>; ldo2-supply = <&v3v3>; ldo3-supply = <&vdd_ddr>; + ldo4-supply = <&vin>; ldo5-supply = <&v3v3>; ldo6-supply = <&v3v3>; + vref_ddr-supply = <&vin>; + boost-supply = <&vin>; pwr_sw1-supply = <&bst_out>; pwr_sw2-supply = <&bst_out>;
diff --git a/arch/arm/dts/stm32mp157c-ev1.dts b/arch/arm/dts/stm32mp157c-ev1.dts index a55e80ce26..5c5b1ddf7b 100644 --- a/arch/arm/dts/stm32mp157c-ev1.dts +++ b/arch/arm/dts/stm32mp157c-ev1.dts @@ -90,6 +90,7 @@ port { dcmi_0: endpoint { remote-endpoint = <&ov5640_0>; + bus-type = <5>; bus-width = <8>; hsync-active = <0>; vsync-active = <0>; diff --git a/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi b/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi index 6868769c6e..11bc247065 100644 --- a/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi +++ b/arch/arm/dts/stm32mp15xx-dhcom-u-boot.dtsi @@ -76,61 +76,6 @@ pinctrl-1 = <&fmc_sleep_pins_b &mco2_sleep_pins_a>; pinctrl-names = "default", "sleep";
- fmc_pins_b: fmc-0 { - pins1 { - pinmux = <STM32_PINMUX('D', 4, AF12)>, /* FMC_NOE */ - <STM32_PINMUX('D', 5, AF12)>, /* FMC_NWE */ - <STM32_PINMUX('B', 7, AF12)>, /* FMC_NL */ - <STM32_PINMUX('D', 14, AF12)>, /* FMC_D0 */ - <STM32_PINMUX('D', 15, AF12)>, /* FMC_D1 */ - <STM32_PINMUX('D', 0, AF12)>, /* FMC_D2 */ - <STM32_PINMUX('D', 1, AF12)>, /* FMC_D3 */ - <STM32_PINMUX('E', 7, AF12)>, /* FMC_D4 */ - <STM32_PINMUX('E', 8, AF12)>, /* FMC_D5 */ - <STM32_PINMUX('E', 9, AF12)>, /* FMC_D6 */ - <STM32_PINMUX('E', 10, AF12)>, /* FMC_D7 */ - <STM32_PINMUX('E', 11, AF12)>, /* FMC_D8 */ - <STM32_PINMUX('E', 12, AF12)>, /* FMC_D9 */ - <STM32_PINMUX('E', 13, AF12)>, /* FMC_D10 */ - <STM32_PINMUX('E', 14, AF12)>, /* FMC_D11 */ - <STM32_PINMUX('E', 15, AF12)>, /* FMC_D12 */ - <STM32_PINMUX('D', 8, AF12)>, /* FMC_D13 */ - <STM32_PINMUX('D', 9, AF12)>, /* FMC_D14 */ - <STM32_PINMUX('D', 10, AF12)>, /* FMC_D15 */ - <STM32_PINMUX('G', 9, AF12)>, /* FMC_NE2_FMC_NCE */ - <STM32_PINMUX('G', 12, AF12)>; /* FMC_NE4 */ - bias-disable; - drive-push-pull; - slew-rate = <3>; - }; - }; - - fmc_sleep_pins_b: fmc-sleep-0 { - pins { - pinmux = <STM32_PINMUX('D', 4, ANALOG)>, /* FMC_NOE */ - <STM32_PINMUX('D', 5, ANALOG)>, /* FMC_NWE */ - <STM32_PINMUX('B', 7, ANALOG)>, /* FMC_NL */ - <STM32_PINMUX('D', 14, ANALOG)>, /* FMC_D0 */ - <STM32_PINMUX('D', 15, ANALOG)>, /* FMC_D1 */ - <STM32_PINMUX('D', 0, ANALOG)>, /* FMC_D2 */ - <STM32_PINMUX('D', 1, ANALOG)>, /* FMC_D3 */ - <STM32_PINMUX('E', 7, ANALOG)>, /* FMC_D4 */ - <STM32_PINMUX('E', 8, ANALOG)>, /* FMC_D5 */ - <STM32_PINMUX('E', 9, ANALOG)>, /* FMC_D6 */ - <STM32_PINMUX('E', 10, ANALOG)>, /* FMC_D7 */ - <STM32_PINMUX('E', 11, ANALOG)>, /* FMC_D8 */ - <STM32_PINMUX('E', 12, ANALOG)>, /* FMC_D9 */ - <STM32_PINMUX('E', 13, ANALOG)>, /* FMC_D10 */ - <STM32_PINMUX('E', 14, ANALOG)>, /* FMC_D11 */ - <STM32_PINMUX('E', 15, ANALOG)>, /* FMC_D12 */ - <STM32_PINMUX('D', 8, ANALOG)>, /* FMC_D13 */ - <STM32_PINMUX('D', 9, ANALOG)>, /* FMC_D14 */ - <STM32_PINMUX('D', 10, ANALOG)>, /* FMC_D15 */ - <STM32_PINMUX('G', 9, ANALOG)>, /* FMC_NE2_FMC_NCE */ - <STM32_PINMUX('G', 12, ANALOG)>; /* FMC_NE4 */ - }; - }; - mco2_pins_a: mco2-0 { pins { pinmux = <STM32_PINMUX('G', 2, AF1)>; /* MCO2 */ diff --git a/arch/arm/dts/stm32mp15xx-dkx.dtsi b/arch/arm/dts/stm32mp15xx-dkx.dtsi index aa4aa83e05..68987f64c5 100644 --- a/arch/arm/dts/stm32mp15xx-dkx.dtsi +++ b/arch/arm/dts/stm32mp15xx-dkx.dtsi @@ -80,6 +80,14 @@ dais = <&sai2a_port &sai2b_port &i2s2_port>; status = "okay"; }; + + vin: vin { + compatible = "regulator-fixed"; + regulator-name = "vin"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; };
&adc { @@ -116,6 +124,10 @@ status = "okay"; };
+&crc1 { + status = "okay"; +}; + &dts { status = "okay"; }; @@ -151,6 +163,10 @@ contiguous-area = <&gpu_reserved>; };
+&hash1 { + status = "okay"; +}; + &i2c1 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&i2c1_pins_a>; @@ -238,21 +254,27 @@ /delete-property/dmas; /delete-property/dma-names;
- typec: stusb1600@28 { + stusb1600@28 { compatible = "st,stusb1600"; reg = <0x28>; interrupts = <11 IRQ_TYPE_EDGE_FALLING>; interrupt-parent = <&gpioi>; pinctrl-names = "default"; pinctrl-0 = <&stusb1600_pins_a>; - status = "okay"; + vdd-supply = <&vin>;
- typec_con: connector { + connector { compatible = "usb-c-connector"; label = "USB-C"; - power-role = "sink"; - power-opmode = "default"; + power-role = "dual"; + typec-power-opmode = "default"; + + port { + con_usbotg_hs_ep: endpoint { + remote-endpoint = <&usbotg_hs_ep>; + }; + }; }; };
@@ -266,9 +288,18 @@
regulators { compatible = "st,stpmic1-regulators"; + buck1-supply = <&vin>; + buck2-supply = <&vin>; + buck3-supply = <&vin>; + buck4-supply = <&vin>; ldo1-supply = <&v3v3>; + ldo2-supply = <&vin>; ldo3-supply = <&vdd_ddr>; + ldo4-supply = <&vin>; + ldo5-supply = <&vin>; ldo6-supply = <&v3v3>; + vref_ddr-supply = <&vin>; + boost-supply = <&vin>; pwr_sw1-supply = <&bst_out>; pwr_sw2-supply = <&bst_out>;
@@ -657,6 +688,12 @@ phy-names = "usb2-phy"; usb-role-switch; status = "okay"; + + port { + usbotg_hs_ep: endpoint { + remote-endpoint = <&con_usbotg_hs_ep>; + }; + }; };
&usbphyc {
Are you completely sure the dhcom based boards generate the same DT after the sync ?
I would rather prefer sync with Linux 5.10 (LTS), or is that not an option due to some extra DT patches ?
Either way, if you have an upstream queue for this DT sync somewhere, please give me a link, I plan to sync the dhcom boards after 2021.01 is out, so I would build on top of that.
Hi Marek,
I am sure the DT is not the same, sorry.
At least for the SOC part (new nodes, updates value).
I compare the dhcom device tree (dts file form dtb) and I don't found modifications except the phandle changes and the expected modifications.
But it is not a exhaustive check.
For ST boards, the U-Boot device trees are aligned with Linux 5.9 since the commit 62f95af92a3fc21a72f5f3198f0d065cbd773f03 ("ARM: dts: stm32mp1: DT alignment with Linux kernel v5.9-rc4")
I skip the Linux 5.10 (LTS) as it comes after v2020.10 merge windows and the 5.11 device tree are already updated (pull request from Alexandre Torgue = https://kernel.googlesource.com/pub/scm/linux/kernel/git/atorgue/stm32)
But if you prefer I can split it in 2 steps
1/ Device tree alignment with Linux kernel v5.10 (LTS)
2/ Device tree alignment with Linux kernel v5.11-rc2
Today the patch is present in next branch of stm custodians (https://gitlab.denx.de/u-boot/custodians/u-boot-stm/-/tree/next)
And I am preparing a pull request for the master branch.
Patrick
On 1/13/21 10:48 AM, Patrick DELAUNAY wrote:
Hi Marek,
There is dtdiff, you can run it on the generated SPL and U-Boot DTBs before and after your changes. That should be a thorough check.
Keep it as-is, I just wanted to know why you didn't pick the LTS option, now it's clear, thanks.
Applied to u-boot-stm/master, thanks!
Regards
Patrick
Patrick DELAUNAY
Patrick Delaunay
