[PATCH] phy: rockchip: inno-usb2: fix phy reg=0 case
The support for #address-cells=2 has a loophole: if the reg is actually 0, but the #address-cells is actually 1, like in such case below:
syscon { #address-cells = <1>;
phy { reg = <0 0x10>; }; };
then the second u32 of the 'reg' is the size, not the address.
The code should check for the parent's #address-cells value, and not assume that if the first u32 is 0, then the #address-cells is 2, and the reg property is something like reg = <0 0xff00 0x10>;
Fixed this by looking for the #address-cells value and retrieving the reg address only if this is ==2. To avoid breaking anything I also kept the check `if reg==0` as some DT's may have a wrong #address-cells as parent and even if this commit is correct, it might break the existing wrong device-trees.
Fixes: d538efb9adcf ("phy: rockchip: inno-usb2: Add support #address_cells = 2") Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index 22e2797eea28..e5e02b6765b1 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -186,7 +186,7 @@ static int rockchip_usb2phy_probe(struct udevice *dev) }
/* support address_cells=2 */ - if (reg == 0) { + if (dev_read_addr_cells(dev) == 2 && reg == 0) { if (ofnode_read_u32_index(dev_ofnode(dev), "reg", 1, ®)) { dev_err(dev, "%s must have reg[1]\n", ofnode_get_name(dev_ofnode(dev)));
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- if (reg == 0) {
- if (dev_read_addr_cells(dev) == 2 && reg == 0) { if (ofnode_read_u32_index(dev_ofnode(dev), "reg", 1, ®)) { dev_err(dev, "%s must have reg[1]\n", ofnode_get_name(dev_ofnode(dev)));
Eugen Hristev
Kever Yang
