[U-Boot] i.MX28 AUTO_RESTART, watchdog, battery and poweroff
Greetings,
I'm not sure I understand the function mxs_power_clear_auto_restart() in spl_power_init.c
The name of the function seems to indicate that its purpose is to *clear* the AUTO_RESTART bit, but it is actually setting it:
setbits_le32(&rtc_regs->hw_rtc_persistent0, RTC_PERSISTENT0_AUTO_RESTART);
I believe though, that setting this bit is OK because it guarantees that the target can be reset from a reset button or a watchdog reset even when powered from the battery.
Am I missing something? Otherwise I think this function should be renamed to mxs_power_set_auto_restart().
Best regards, -- Hector Palacios
Dear Hector Palacios,
Greetings,
We're on the same board there. According to FSL, this is needed on some versions of MX28 (translation from the techsupp language: we have no idea where this code came from nor what it does, so we will tell you it's important and you shouldn't touch it).
I believe the powercode will need a revision and I'll likely get to it once I'm done with my current hacking.
I'd ack the rename. Fabio?
Best regards, Marek Vasut
Sounds good. Please submit a patch, Hector.
Thanks,
Fabio Estevam
Fabio Estevam
Hector Palacios
