[U-Boot] [PATCH] tests: test_dfu.py: Add example udev rule for host_usb_dev_node
If one does not already have a rule to create a custom device node when a given device enumerates it can be useful to have udev create a bus path based node to the entry in /dev/bus/usb that was just enumerated. Given that DFU itself does not require a /dev entry it is a good idea to provide a rule that will generate one.
Signed-off-by: Tom Rini trini@konsulko.com --- test/py/tests/test_dfu.py | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/test/py/tests/test_dfu.py b/test/py/tests/test_dfu.py index 585e6b29d7f8..fba67d585b9f 100644 --- a/test/py/tests/test_dfu.py +++ b/test/py/tests/test_dfu.py @@ -80,6 +80,13 @@ ACTION=="add", SUBSYSTEM=="block", SUBSYSTEMS=="usb", KERNELS=="3-13", MODE:="66 (You may wish to change the group ID instead of setting the permissions wide open. All that matters is that the user ID running the test can access the device.) + +c) An optional udev rule to give you a persistent value to use in +host_usb_dev_node. For example: + +IMPORT{builtin}="path_id" +ENV{ID_PATH}=="?*", ENV{.ID_PORT}=="", SYMLINK+="bus/usb/by-path/$env{ID_PATH}" +ENV{ID_PATH}=="?*", ENV{.ID_PORT}=="?*", SYMLINK+="bus/usb/by-path/$env{ID_PATH}-port$env{.ID_PORT}" """
# The set of file sizes to test. These values trigger various edge-cases such
