[U-Boot-Users] [PATCH 17/17] mpc83xx: Fix errors when CONFIG_OF_LIBFDT is enabled
Several node strings were not correct (trailing slashes and properties in the strings) Added setting of the timebase-frequency (if OF_TBCLK is defined). Improved error messages and use debug() instead of printf().
Signed-off-by: Gerald Van Baren vanbaren@cideas.com --- cpu/mpc83xx/cpu.c | 82 +++++++++++++++++++++++++++++++++------------------- 1 files changed, 52 insertions(+), 30 deletions(-)
(Sorry for the retransmission, I didn't get the proper subject on it the first time around.)
Hi Kim,
This is the second of two cross-over changes to the 83xx tree. It has the fixes for the TSEC errors you pointed out with the "old" set of patches.
Please review and ACK/NAK.
Thanks, gvb
diff --git a/cpu/mpc83xx/cpu.c b/cpu/mpc83xx/cpu.c index a52f98a..455b7a7 100644 --- a/cpu/mpc83xx/cpu.c +++ b/cpu/mpc83xx/cpu.c @@ -337,7 +337,7 @@ static int fdt_set_eth0(void *fdt, int nodeoffset, const char *name, bd_t *bd) if (fdt_get_property(fdt, nodeoffset, name, 0)) { return fdt_setprop(fdt, nodeoffset, name, bd->bi_enetaddr, 6); } - return -FDT_ERR_NOTFOUND; + return 0; } #ifdef CONFIG_HAS_ETH1 /* second onboard ethernet port */ @@ -349,7 +349,7 @@ static int fdt_set_eth1(void *fdt, int nodeoffset, const char *name, bd_t *bd) if (fdt_get_property(fdt, nodeoffset, name, 0)) { return fdt_setprop(fdt, nodeoffset, name, bd->bi_enet1addr, 6); } - return -FDT_ERR_NOTFOUND; + return 0; } #endif #ifdef CONFIG_HAS_ETH2 @@ -362,7 +362,7 @@ static int fdt_set_eth2(void *fdt, int nodeoffset, const char *name, bd_t *bd) if (fdt_get_property(fdt, nodeoffset, name, 0)) { return fdt_setprop(fdt, nodeoffset, name, bd->bi_enet2addr, 6); } - return -FDT_ERR_NOTFOUND; + return 0; } #endif #ifdef CONFIG_HAS_ETH3 @@ -375,7 +375,7 @@ static int fdt_set_eth3(void *fdt, int nodeoffset, const char *name, bd_t *bd) if (fdt_get_property(fdt, nodeoffset, name, 0)) { return fdt_setprop(fdt, nodeoffset, name, bd->bi_enet3addr, 6); } - return -FDT_ERR_NOTFOUND; + return 0; } #endif
@@ -389,94 +389,111 @@ static int fdt_set_busfreq(void *fdt, int nodeoffset, const char *name, bd_t *bd return fdt_setprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); }
+#ifdef OF_TBCLK +static int fdt_set_tbfreq(void *fdt, int nodeoffset, const char *name, bd_t *bd) +{ + u32 tmp; + /* + * Create or update the property. + */ + tmp = cpu_to_be32(OF_TBCLK); + return fdt_setprop(fdt, nodeoffset, name, &tmp, sizeof(tmp)); +} +#endif + + /* - * Fixups to the fdt. If "create" is TRUE, the node is created - * unconditionally. If "create" is FALSE, the node is updated - * only if it already exists. + * Fixups to the fdt. */ static const struct { char *node; char *prop; int (*set_fn)(void *fdt, int nodeoffset, const char *name, bd_t *bd); } fixup_props[] = { +#ifdef OF_TBCLK { "/cpus/" OF_CPU, - "bus-frequency", - fdt_set_busfreq + "timebase-frequency", + fdt_set_tbfreq }, - { "/cpus/" OF_SOC, +#endif + { "/cpus/" OF_CPU, "bus-frequency", fdt_set_busfreq }, - { "/" OF_SOC "/serial@4500/", + { "/cpus/" OF_CPU, "clock-frequency", fdt_set_busfreq }, - { "/" OF_SOC "/serial@4600/", + { "/" OF_SOC "/serial@4500", "clock-frequency", fdt_set_busfreq }, -#ifdef CONFIG_TSEC1 - { "/" OF_SOC "/ethernet@24000, + { "/" OF_SOC "/serial@4600", + "clock-frequency", + fdt_set_busfreq + }, +#ifdef CONFIG_MPC83XX_TSEC1 + { "/" OF_SOC "/ethernet@24000", "mac-address", fdt_set_eth0 }, - { "/" OF_SOC "/ethernet@24000, + { "/" OF_SOC "/ethernet@24000", "local-mac-address", fdt_set_eth0 }, #endif -#ifdef CONFIG_TSEC2 - { "/" OF_SOC "/ethernet@25000, +#ifdef CONFIG_MPC83XX_TSEC2 + { "/" OF_SOC "/ethernet@25000", "mac-address", fdt_set_eth1 }, - { "/" OF_SOC "/ethernet@25000, + { "/" OF_SOC "/ethernet@25000", "local-mac-address", fdt_set_eth1 }, #endif #ifdef CONFIG_UEC_ETH1 #if CFG_UEC1_UCC_NUM == 0 /* UCC1 */ - { "/" OF_QE "/ucc@2000/mac-address", + { "/" OF_QE "/ucc@2000", "mac-address", fdt_set_eth0 }, - { "/" OF_QE "/ucc@2000/mac-address", + { "/" OF_QE "/ucc@2000", "local-mac-address", fdt_set_eth0 }, #elif CFG_UEC1_UCC_NUM == 2 /* UCC3 */ - { "/" OF_QE "/ucc@2200/mac-address", + { "/" OF_QE "/ucc@2200", "mac-address", fdt_set_eth0 }, - { "/" OF_QE "/ucc@2200/mac-address", + { "/" OF_QE "/ucc@2200", "local-mac-address", fdt_set_eth0 }, #endif -#endif +#endif /* CONFIG_UEC_ETH1 */ #ifdef CONFIG_UEC_ETH2 #if CFG_UEC2_UCC_NUM == 1 /* UCC2 */ - { "/" OF_QE "/ucc@3000/mac-address", + { "/" OF_QE "/ucc@3000", "mac-address", fdt_set_eth1 }, - { "/" OF_QE "/ucc@3000/mac-address", + { "/" OF_QE "/ucc@3000", "local-mac-address", fdt_set_eth1 }, #elif CFG_UEC1_UCC_NUM == 3 /* UCC4 */ - { "/" OF_QE "/ucc@3200/mac-address", + { "/" OF_QE "/ucc@3200", "mac-address", fdt_set_eth1 }, - { "/" OF_QE "/ucc@3200/mac-address", + { "/" OF_QE "/ucc@3200", "local-mac-address", fdt_set_eth1 }, #endif -#endif +#endif /* CONFIG_UEC_ETH2 */ };
void @@ -489,12 +506,17 @@ ft_cpu_setup(void *blob, bd_t *bd) for (j = 0; j < (sizeof(fixup_props) / sizeof(fixup_props[0])); j++) { nodeoffset = fdt_find_node_by_path(fdt, fixup_props[j].node); if (nodeoffset >= 0) { - err = (*fixup_props[j].set_fn)(blob, nodeoffset, fixup_props[j].prop, bd); + err = fixup_props[j].set_fn( + blob, nodeoffset, fixup_props[j].prop, bd); if (err < 0) - printf("set_fn/libfdt: %s %s returned %s\n", + debug("Problem setting %s = %s: %s\n", fixup_props[j].node, fixup_props[j].prop, fdt_strerror(err)); + } else { + debug("Couldn't find %s: %s\n", + fixup_props[j].node, + fdt_strerror(nodeoffset)); } } }
Jerry Van Baren
