[U-Boot] [PATCH] spl: dfu: compilation fixes for spl-dfu
This patch fixes the compilation error common/cli_hush.c:3349: undefined reference to 'realloc_simple'
The dfu uses run_command(), it is part of cli_hush.c but defining CONFIG_HUSH_PARSER for spl-dfu causes this compilation error.
Signed-off-by: Ravi Babu ravibabu@ti.com --- common/cli.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/cli.c b/common/cli.c index a433ef2..5e0869b 100644 --- a/common/cli.c +++ b/common/cli.c @@ -28,7 +28,7 @@ DECLARE_GLOBAL_DATA_PTR; */ int run_command(const char *cmd, int flag) { -#ifndef CONFIG_HUSH_PARSER +#if defined(CONFIG_SPL_DFU_SUPPORT) || !defined(CONFIG_HUSH_PARSER) /* * cli_run_command can return 0 or 1 for success, so clean up * its result.
Hi Ravi,
I must admit that this seems odd to me....since we should avoided adding (SPL DFU) dependency to common parser code.
Maybe some kconfig tweaks would help?
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Hi Lukasz
Yes, I agree, or use CONFIG_SPL_BUILD.
You Mean, unselect CONFIG_HUSH_PARSER when SPL_DFU_SUPPORT enabled?
Regards Ravi
B, Ravi
Lukasz Majewski
Ravi Babu
