[U-Boot] [PATCH v1 00/23] apalis imx6 fixes, device tree enablement and driver model conversion
This series addresses some shortcomings, enables/introduces device tree support and converts all except video to using the driver model. This is fully tested both running our latest downstream BSP as well as the mainline Linux kernel.
Gerard Salvatella (1): board: apalis_imx6: check for and report ecc errors in fuses
Marcel Ziswiler (16): apalis_imx6: get rid of obsolete nospl configurations apalis_imx6: use distro defaults apalis_imx6: move console in env and dfu mmc from header file to defconfig apalis_imx6: enable fit image, gpt, imx thermal, efi loader support apalis_imx6: remove obsolete USB_GADGET_MASS_STORAGE configuration apalis_imx6: migrate to using device tree apalis_imx6: clean-up and migrate gpios to using driver model apalis_imx6: enable pin control driver apalis_imx6: migrate i2c to using driver model apalis_imx6: migrate pmic and regulator to using driver model apalis_imx6: migrate mmc and sata to using driver model apalis_imx6: migrate usb to using driver model apalis_imx6: drop CONFIG_OF_SYSTEM_SETUP apalis_imx6: add distroboot support apalis_imx6: pf0100: reorder and cleanup message printing apalis_imx6: switch to zimage
Max Krummenacher (4): apalis_imx6: use both sd/mmc interfaces for setsdupdate apalis_imx6: unify sd/mmc drive strength with linux kernel settings apalis_imx6: disable ri and dcd irq in uarts apalis_imx6: revert fuse value set in mfgr_fuse
Sanchayan Maity (1): configs: apalis_imx6: Use ext4 file system by default
Stefan Agner (1): apalis_imx6: use SDP if USB serial downloader has been used
arch/arm/dts/imx6-apalis.dts | 722 ++++++++++++++++++ .../toradex/apalis_imx6/1066mhz_4x128mx16.cfg | 47 -- .../toradex/apalis_imx6/1066mhz_4x256mx16.cfg | 47 -- board/toradex/apalis_imx6/MAINTAINERS | 4 +- board/toradex/apalis_imx6/apalis_imx6.c | 277 +++---- board/toradex/apalis_imx6/apalis_imx6q.cfg | 33 - board/toradex/apalis_imx6/clocks.cfg | 41 - board/toradex/apalis_imx6/ddr-setup.cfg | 96 --- board/toradex/apalis_imx6/do_fuse.c | 2 +- board/toradex/apalis_imx6/pf0100.c | 205 +++-- board/toradex/apalis_imx6/pf0100.h | 57 +- board/toradex/colibri_imx6/do_fuse.c | 2 +- configs/apalis_imx6_defconfig | 35 +- configs/apalis_imx6_nospl_com_defconfig | 65 -- configs/apalis_imx6_nospl_it_defconfig | 65 -- include/configs/apalis_imx6.h | 73 +- 16 files changed, 1069 insertions(+), 702 deletions(-) create mode 100644 arch/arm/dts/imx6-apalis.dts delete mode 100644 board/toradex/apalis_imx6/1066mhz_4x128mx16.cfg delete mode 100644 board/toradex/apalis_imx6/1066mhz_4x256mx16.cfg delete mode 100644 board/toradex/apalis_imx6/apalis_imx6q.cfg delete mode 100644 board/toradex/apalis_imx6/clocks.cfg delete mode 100644 board/toradex/apalis_imx6/ddr-setup.cfg delete mode 100644 configs/apalis_imx6_nospl_com_defconfig delete mode 100644 configs/apalis_imx6_nospl_it_defconfig
Now with SPL long since being in place even for recovery using SDP finally get rid of those nospl configurations.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
.../toradex/apalis_imx6/1066mhz_4x128mx16.cfg | 47 --------- .../toradex/apalis_imx6/1066mhz_4x256mx16.cfg | 47 --------- board/toradex/apalis_imx6/MAINTAINERS | 2 - board/toradex/apalis_imx6/apalis_imx6q.cfg | 33 ------- board/toradex/apalis_imx6/clocks.cfg | 41 -------- board/toradex/apalis_imx6/ddr-setup.cfg | 96 ------------------- configs/apalis_imx6_nospl_com_defconfig | 65 ------------- configs/apalis_imx6_nospl_it_defconfig | 65 ------------- 8 files changed, 396 deletions(-) delete mode 100644 board/toradex/apalis_imx6/1066mhz_4x128mx16.cfg delete mode 100644 board/toradex/apalis_imx6/1066mhz_4x256mx16.cfg delete mode 100644 board/toradex/apalis_imx6/apalis_imx6q.cfg delete mode 100644 board/toradex/apalis_imx6/clocks.cfg delete mode 100644 board/toradex/apalis_imx6/ddr-setup.cfg delete mode 100644 configs/apalis_imx6_nospl_com_defconfig delete mode 100644 configs/apalis_imx6_nospl_it_defconfig
diff --git a/board/toradex/apalis_imx6/1066mhz_4x128mx16.cfg b/board/toradex/apalis_imx6/1066mhz_4x128mx16.cfg deleted file mode 100644 index 29d1c3126c..0000000000 --- a/board/toradex/apalis_imx6/1066mhz_4x128mx16.cfg +++ /dev/null @@ -1,47 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2014-2016 Toradex AG - */ - -DATA 4, MX6_MMDC_P0_MDPDC, 0x00020036 -DATA 4, MX6_MMDC_P0_MDCFG0, 0x555A7954 -DATA 4, MX6_MMDC_P0_MDCFG1, 0xDB328F64 -DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB -DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 -DATA 4, MX6_MMDC_P0_MDOR, 0x005A1023 -DATA 4, MX6_MMDC_P0_MDOTC, 0x09555050 -DATA 4, MX6_MMDC_P0_MDPDC, 0x00025576 -DATA 4, MX6_MMDC_P0_MDASP, 0x00000027 -DATA 4, MX6_MMDC_P0_MDCTL, 0x831A0000 -DATA 4, MX6_MMDC_P0_MDSCR, 0x04088032 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00428031 -DATA 4, MX6_MMDC_P0_MDSCR, 0x19308030 -DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 -DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 -DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 -DATA 4, MX6_MMDC_P0_MDREF, 0x00005800 -DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00000000 -DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00000000 - -DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x432A0338 -DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x03260324 -DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x43340344 -DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x031E027C - -DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x33272D2E -DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x2F312B37 - -DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x3A35433C -DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x4336453F - -DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x0009000E -DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x0018000B -DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x00060015 -DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x0006000E - -DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 -DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 -DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/toradex/apalis_imx6/1066mhz_4x256mx16.cfg b/board/toradex/apalis_imx6/1066mhz_4x256mx16.cfg deleted file mode 100644 index 02e90dd5e6..0000000000 --- a/board/toradex/apalis_imx6/1066mhz_4x256mx16.cfg +++ /dev/null @@ -1,47 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2014-2016 Toradex AG - */ - -DATA 4, MX6_MMDC_P0_MDPDC, 0x00020036 -DATA 4, MX6_MMDC_P0_MDCFG0, 0x898E78f5 -DATA 4, MX6_MMDC_P0_MDCFG1, 0xff328f64 -DATA 4, MX6_MMDC_P0_MDCFG2, 0x01FF00DB -DATA 4, MX6_MMDC_P0_MDRWD, 0x000026D2 -DATA 4, MX6_MMDC_P0_MDOR, 0x008E1023 -DATA 4, MX6_MMDC_P0_MDOTC, 0x09444040 -DATA 4, MX6_MMDC_P0_MDPDC, 0x00025576 -DATA 4, MX6_MMDC_P0_MDASP, 0x00000047 -DATA 4, MX6_MMDC_P0_MDCTL, 0x841A0000 -DATA 4, MX6_MMDC_P0_MDSCR, 0x02888032 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00048031 -DATA 4, MX6_MMDC_P0_MDSCR, 0x19408030 -DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 -DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xA1390003 -DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xA1390003 -DATA 4, MX6_MMDC_P0_MDREF, 0x00007800 -DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00022227 -DATA 4, MX6_MMDC_P1_MPODTCTRL, 0x00022227 - -DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x03300338 -DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x03240324 -DATA 4, MX6_MMDC_P1_MPDGCTRL0, 0x03440350 -DATA 4, MX6_MMDC_P1_MPDGCTRL1, 0x032C0308 - -DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x40363C3E -DATA 4, MX6_MMDC_P1_MPRDDLCTL, 0x3C3E3C46 - -DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x403E463E -DATA 4, MX6_MMDC_P1_MPWRDLCTL, 0x4A384C46 - -DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x0009000E -DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x0018000B -DATA 4, MX6_MMDC_P1_MPWLDECTRL0, 0x00060015 -DATA 4, MX6_MMDC_P1_MPWLDECTRL1, 0x0006000E - -DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 -DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 -DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 diff --git a/board/toradex/apalis_imx6/MAINTAINERS b/board/toradex/apalis_imx6/MAINTAINERS index 2c70ab4fbd..a5d2c84956 100644 --- a/board/toradex/apalis_imx6/MAINTAINERS +++ b/board/toradex/apalis_imx6/MAINTAINERS @@ -5,5 +5,3 @@ S: Maintained F: board/toradex/apalis_imx6/ F: include/configs/apalis_imx6.h F: configs/apalis_imx6_defconfig -F: configs/apalis_imx6_nospl_com_defconfig -F: configs/apalis_imx6_nospl_it_defconfig diff --git a/board/toradex/apalis_imx6/apalis_imx6q.cfg b/board/toradex/apalis_imx6/apalis_imx6q.cfg deleted file mode 100644 index 739b1b7061..0000000000 --- a/board/toradex/apalis_imx6/apalis_imx6q.cfg +++ /dev/null @@ -1,33 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2014-2016, Toradex AG - * - * Refer doc/README.imximage for more details about how-to configure - * and create imximage boot image - * - * The syntax is taken as close as possible with the kwbimage - */ - -/* image version */ -IMAGE_VERSION 2 - -/* - * Boot Device : one of - * spi, sd (the board has no nand neither onenand) - */ -BOOT_FROM sd - -#define __ASSEMBLY__ -#include <config.h> -#include "asm/arch/mx6-ddr.h" -#include "asm/arch/iomux.h" -#include "asm/arch/crm_regs.h" - -#include "ddr-setup.cfg" -#if CONFIG_DDR_MB == 2048 -#include "1066mhz_4x256mx16.cfg" -#else -#include "1066mhz_4x128mx16.cfg" -#endif -#include "clocks.cfg" diff --git a/board/toradex/apalis_imx6/clocks.cfg b/board/toradex/apalis_imx6/clocks.cfg deleted file mode 100644 index 1bcbc4fa38..0000000000 --- a/board/toradex/apalis_imx6/clocks.cfg +++ /dev/null @@ -1,41 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2014-2016, Toradex AG - * - * Device Configuration Data (DCD) - * - * Each entry must have the format: - * Addr-type Address Value - * - * where: - * Addr-type register length (1,2 or 4 bytes) - * Address absolute address of the register - * value value to be stored in the register - */ - -/* set the default clock gate to save power */ -DATA 4, CCM_CCGR0, 0x00C03F3F -DATA 4, CCM_CCGR1, 0x0030FC03 -DATA 4, CCM_CCGR2, 0x0FFFC000 -DATA 4, CCM_CCGR3, 0x3FF00000 -DATA 4, CCM_CCGR4, 0x00FFF300 -DATA 4, CCM_CCGR5, 0x0F0000C3 -DATA 4, CCM_CCGR6, 0x000003FF - -/* enable AXI cache for VDOA/VPU/IPU */ -DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF -/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ -DATA 4, MX6_IOMUXC_GPR6, 0x007F007F -DATA 4, MX6_IOMUXC_GPR7, 0x007F007F - -/* - * Setup CCM_CCOSR register as follows: - * - * cko1_en = 1 --> CKO1 enabled - * cko1_div = 111 --> divide by 8 - * cko1_sel = 1011 --> ahb_clk_root - * - * This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz - */ -DATA 4, CCM_CCOSR, 0x000000fb diff --git a/board/toradex/apalis_imx6/ddr-setup.cfg b/board/toradex/apalis_imx6/ddr-setup.cfg deleted file mode 100644 index e42e3ce438..0000000000 --- a/board/toradex/apalis_imx6/ddr-setup.cfg +++ /dev/null @@ -1,96 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2014-2016, Toradex AG - * - * Device Configuration Data (DCD) - * - * Each entry must have the format: - * Addr-type Address Value - * - * where: - * Addr-type register length (1,2 or 4 bytes) - * Address absolute address of the register - * value value to be stored in the register - */ - -/* - * DDR3 settings - * MX6Q ddr is limited to 1066 Mhz currently 1056 MHz(528 MHz clock), - * memory bus width: 64 bits x16/x32/x64 - * MX6DL ddr is limited to 800 MHz(400 MHz clock) - * memory bus width: 64 bits x16/x32/x64 - * MX6SOLO ddr is limited to 800 MHz(400 MHz clock) - * memory bus width: 32 bits x16/x32 - */ -DATA 4, MX6_IOM_DRAM_SDQS0, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS1, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS2, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS3, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS4, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS5, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS6, 0x00000030 -DATA 4, MX6_IOM_DRAM_SDQS7, 0x00000030 - -DATA 4, MX6_IOM_GRP_B0DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B1DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B2DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B3DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B4DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B5DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B6DS, 0x00000030 -DATA 4, MX6_IOM_GRP_B7DS, 0x00000030 -DATA 4, MX6_IOM_GRP_ADDDS, 0x00000030 -/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ -DATA 4, MX6_IOM_GRP_CTLDS, 0x00000030 - -DATA 4, MX6_IOM_DRAM_DQM0, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM1, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM2, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM3, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM4, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM5, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM6, 0x00020030 -DATA 4, MX6_IOM_DRAM_DQM7, 0x00020030 - -DATA 4, MX6_IOM_DRAM_CAS, 0x00020030 -DATA 4, MX6_IOM_DRAM_RAS, 0x00020030 -DATA 4, MX6_IOM_DRAM_SDCLK_0, 0x00020030 -DATA 4, MX6_IOM_DRAM_SDCLK_1, 0x00020030 - -DATA 4, MX6_IOM_DRAM_RESET, 0x00020030 -DATA 4, MX6_IOM_DRAM_SDCKE0, 0x00003000 -DATA 4, MX6_IOM_DRAM_SDCKE1, 0x00003000 - -DATA 4, MX6_IOM_DRAM_SDODT0, 0x00003030 -DATA 4, MX6_IOM_DRAM_SDODT1, 0x00003030 - -/* (differential input) */ -DATA 4, MX6_IOM_DDRMODE_CTL, 0x00020000 -/* (differential input) */ -DATA 4, MX6_IOM_GRP_DDRMODE, 0x00020000 -/* disable ddr pullups */ -DATA 4, MX6_IOM_GRP_DDRPKE, 0x00000000 -DATA 4, MX6_IOM_DRAM_SDBA2, 0x00000000 -/* 40 Ohm drive strength for cs0/1,sdba2,cke0/1,sdwe */ -DATA 4, MX6_IOM_GRP_DDR_TYPE, 0x000C0000 - -/* Read data DQ Byte0-3 delay */ -DATA 4, MX6_MMDC_P0_MPRDDQBY0DL, 0x33333333 -DATA 4, MX6_MMDC_P0_MPRDDQBY1DL, 0x33333333 -DATA 4, MX6_MMDC_P0_MPRDDQBY2DL, 0x33333333 -DATA 4, MX6_MMDC_P0_MPRDDQBY3DL, 0x33333333 -DATA 4, MX6_MMDC_P1_MPRDDQBY0DL, 0x33333333 -DATA 4, MX6_MMDC_P1_MPRDDQBY1DL, 0x33333333 -DATA 4, MX6_MMDC_P1_MPRDDQBY2DL, 0x33333333 -DATA 4, MX6_MMDC_P1_MPRDDQBY3DL, 0x33333333 - -/* - * MDMISC mirroring interleaved (row/bank/col) - */ -DATA 4, MX6_MMDC_P0_MDMISC, 0x00081740 - -/* - * MDSCR con_req - */ -DATA 4, MX6_MMDC_P0_MDSCR, 0x00008000 diff --git a/configs/apalis_imx6_nospl_com_defconfig b/configs/apalis_imx6_nospl_com_defconfig deleted file mode 100644 index b6ab5285c2..0000000000 --- a/configs/apalis_imx6_nospl_com_defconfig +++ /dev/null @@ -1,65 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_THUMB_BUILD=y -CONFIG_ARCH_MX6=y -CONFIG_SYS_TEXT_BASE=0x17800000 -CONFIG_TARGET_APALIS_IMX6=y -CONFIG_CMD_HDMIDETECT=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/apalis_imx6/apalis_imx6q.cfg,MX6Q,DDR_MB=1024" -CONFIG_BOOTDELAY=1 -# CONFIG_CONSOLE_MUX is not set -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_MISC_INIT_R=y -CONFIG_VERSION_VARIABLE=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_BOUNCE_BUFFER=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="Apalis iMX6 # " -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_ASKENV=y -CONFIG_CRC32_VERIFY=y -CONFIG_CMD_MEMTEST=y -CONFIG_SYS_ALT_MEMTEST=y -CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_BMP=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_DWC_AHSATA=y -CONFIG_DFU_MMC=y -CONFIG_FSL_ESDHC=y -CONFIG_PHYLIB=y -CONFIG_PHY_MICREL=y -CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_MII=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Toradex" -CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 -CONFIG_USB_GADGET_PRODUCT_NUM=0x4020 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_VIDEO=y -CONFIG_FAT_WRITE=y -CONFIG_OF_LIBFDT=y -# CONFIG_EFI_LOADER is not set diff --git a/configs/apalis_imx6_nospl_it_defconfig b/configs/apalis_imx6_nospl_it_defconfig deleted file mode 100644 index c972b11eb5..0000000000 --- a/configs/apalis_imx6_nospl_it_defconfig +++ /dev/null @@ -1,65 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_THUMB_BUILD=y -CONFIG_ARCH_MX6=y -CONFIG_SYS_TEXT_BASE=0x17800000 -CONFIG_TARGET_APALIS_IMX6=y -CONFIG_CMD_HDMIDETECT=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_NR_DRAM_BANKS=1 -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/apalis_imx6/apalis_imx6q.cfg,MX6Q,DDR_MB=2048" -CONFIG_BOOTDELAY=1 -# CONFIG_CONSOLE_MUX is not set -CONFIG_SUPPORT_RAW_INITRD=y -CONFIG_MISC_INIT_R=y -CONFIG_VERSION_VARIABLE=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_DISPLAY_BOARDINFO_LATE=y -CONFIG_BOUNCE_BUFFER=y -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="Apalis iMX6 # " -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_IMI is not set -# CONFIG_CMD_XIMG is not set -CONFIG_CMD_ASKENV=y -CONFIG_CRC32_VERIFY=y -CONFIG_CMD_MEMTEST=y -CONFIG_SYS_ALT_MEMTEST=y -CONFIG_CMD_DFU=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_BMP=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_DWC_AHSATA=y -CONFIG_DFU_MMC=y -CONFIG_FSL_ESDHC=y -CONFIG_PHYLIB=y -CONFIG_PHY_MICREL=y -CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_MII=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Toradex" -CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 -CONFIG_USB_GADGET_PRODUCT_NUM=0x4020 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_VIDEO=y -CONFIG_FAT_WRITE=y -CONFIG_OF_LIBFDT=y -# CONFIG_EFI_LOADER is not set
Use distro defaults and minimise default configuration again using savedefconfig.
configs/apalis_imx6_defconfig | 12 +----------- 1 file changed, 1 insertion(+), 11 deletions(-)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 86dabd3736..f7fb7a5f8a 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -9,12 +9,11 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_CMD_HDMIDETECT=y -CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6Q" CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set -CONFIG_SUPPORT_RAW_INITRD=y CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -26,9 +25,7 @@ CONFIG_SPL_I2C_SUPPORT=y CONFIG_SPL_USB_HOST_SUPPORT=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_SDP_SUPPORT=y -CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Apalis iMX6 # " -CONFIG_CMD_BOOTZ=y # CONFIG_CMD_ELF is not set # CONFIG_CMD_IMI is not set # CONFIG_CMD_XIMG is not set @@ -43,14 +40,8 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DWC_AHSATA=y @@ -61,7 +52,6 @@ CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_MII=y CONFIG_USB=y -CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex"
Move console in env and DFU MMC from header file to defconfig.
While at it also update copyright year and remove spurious comments and new lines.
configs/apalis_imx6_defconfig | 1 + include/configs/apalis_imx6.h | 4 +--- 2 files changed, 2 insertions(+), 3 deletions(-)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index f7fb7a5f8a..098d791a62 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -14,6 +14,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6Q" CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set +CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_MISC_INIT_R=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index ba4e96da50..a1ba16fc79 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -1,6 +1,6 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* - * Copyright 2013-2015 Toradex, Inc. + * Copyright 2013-2019 Toradex, Inc. * * Configuration settings for the Toradex Apalis iMX6 */ @@ -86,7 +86,6 @@
/* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 -#define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #define CONFIG_VIDEO_BMP_RLE8 #define CONFIG_SPLASH_SCREEN @@ -255,7 +254,6 @@ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
/* environment organization */ - #define CONFIG_ENV_SIZE (8 * 1024)
#if defined(CONFIG_ENV_IS_IN_MMC)
Enbale FIT image, GPT command, i.MX thermal and EFI loader support.
configs/apalis_imx6_defconfig | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 098d791a62..b262bb88b9 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -11,6 +11,7 @@ CONFIG_SPL=y CONFIG_CMD_HDMIDETECT=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,MX6Q" CONFIG_BOOTDELAY=1 # CONFIG_CONSOLE_MUX is not set @@ -36,6 +37,7 @@ CONFIG_CMD_MEMTEST=y CONFIG_SYS_ALT_MEMTEST=y CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y @@ -52,6 +54,7 @@ CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_MII=y +CONFIG_IMX_THERMAL=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y @@ -65,4 +68,3 @@ CONFIG_VIDEO=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_OVERLAY=y -# CONFIG_EFI_LOADER is not set
Remove obsolete USB_GADGET_MASS_STORAGE configuration.
include/configs/apalis_imx6.h | 2 -- 1 file changed, 2 deletions(-)
diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index a1ba16fc79..7222285ab3 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -82,8 +82,6 @@ /* Client */ #define CONFIG_USBD_HS
-#define CONFIG_USB_GADGET_MASS_STORAGE - /* Framebuffer and LCD */ #define CONFIG_VIDEO_IPUV3 #define CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
Migrate to using device tree required for further driver model integration.
arch/arm/dts/imx6-apalis.dts | 722 ++++++++++++++++++++++++++ board/toradex/apalis_imx6/MAINTAINERS | 2 + configs/apalis_imx6_defconfig | 3 +- 3 files changed, 726 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/imx6-apalis.dts
diff --git a/arch/arm/dts/imx6-apalis.dts b/arch/arm/dts/imx6-apalis.dts new file mode 100644 index 0000000000..02a936fa4b --- /dev/null +++ b/arch/arm/dts/imx6-apalis.dts @@ -0,0 +1,722 @@ +// SPDX-License-Identifier: GPL-2.0 OR MIT +/* + * Copyright 2019 Toradex AG + */ + +/dts-v1/; +#include <dt-bindings/gpio/gpio.h> +#include "imx6q.dtsi" + +/ { + model = "Toradex Apalis iMX6Q/D"; + compatible = "toradex,apalis_imx6q", "fsl,imx6q"; + + /* Will be filled by the bootloader */ + memory@10000000 { + device_type = "memory"; + reg = <0x10000000 0>; + }; + + aliases { + mmc0 = &usdhc3; + mmc1 = &usdhc1; + mmc2 = &usdhc2; + usb0 = &usbotg; /* required for ums */ + }; + + chosen { + stdout-path = &uart1; + }; + + reg_module_3v3: regulator-module-3v3 { + compatible = "regulator-fixed"; + regulator-name = "+V3.3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + reg_usb_otg_vbus: regulator-usb-otg-vbus { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_regulator_usbotg_pwr>; + regulator-name = "usb_otg_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio3 22 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + /* on module USB hub */ + reg_usb_host_vbus_hub: regulator-usb-host-vbus-hub { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_regulator_usbhub_pwr>; + regulator-name = "usb_host_vbus_hub"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio3 28 GPIO_ACTIVE_HIGH>; + startup-delay-us = <2000>; + enable-active-high; + }; + + reg_usb_host_vbus: regulator-usb-host-vbus { + compatible = "regulator-fixed"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_regulator_usbh_pwr>; + regulator-name = "usb_host_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio1 0 GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <®_usb_host_vbus_hub>; + }; +}; + +/* I2C1_SDA/SCL on MXM3 209/211 (e.g. RTC on carrier board) */ +&i2c1 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c1>; + status = "okay"; +}; + +/* + * I2C3_SDA/SCL (CAM) on MXM3 pin 201/203 (e.g. camera sensor on carrier + * board) + */ +&i2c3 { + status = "okay"; +}; + +//TBD +&i2c2 { + clock-frequency = <100000>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_i2c2>; + status = "okay"; + + pmic: pfuze100@8 { + compatible = "fsl,pfuze100"; + reg = <0x8>; + + regulators { + sw1a_reg: sw1ab { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw1c_reg: sw1c { + regulator-min-microvolt = <300000>; + regulator-max-microvolt = <1875000>; + regulator-boot-on; + regulator-always-on; + regulator-ramp-delay = <6250>; + }; + + sw3a_reg: sw3a { + regulator-min-microvolt = <400000>; + regulator-max-microvolt = <1975000>; + regulator-boot-on; + regulator-always-on; + }; + + swbst_reg: swbst { + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5150000>; + regulator-boot-on; + regulator-always-on; + }; + + snvs_reg: vsnvs { + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + regulator-always-on; + }; + + vref_reg: vrefddr { + regulator-boot-on; + regulator-always-on; + }; + + /* vgen1: unused */ + + vgen2_reg: vgen2 { + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1550000>; + regulator-boot-on; + regulator-always-on; + }; + + /* vgen3: unused */ + + vgen4_reg: vgen4 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-boot-on; + regulator-always-on; + }; + + vgen5_reg: vgen5 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + + vgen6_reg: vgen6 { + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + regulator-always-on; + }; + }; + }; +}; + +/* + * I2C3_SDA/SCL (CAM) on MXM3 pin 201/203 (e.g. camera sensor on carrier + * board) + */ +&i2c3 { + clock-frequency = <100000>; + pinctrl-names = "default", "gpio"; + pinctrl-0 = <&pinctrl_i2c3>; + pinctrl-1 = <&pinctrl_i2c3_recovery>; + scl-gpios = <&gpio3 17 GPIO_ACTIVE_HIGH>; + sda-gpios = <&gpio3 18 GPIO_ACTIVE_HIGH>; + status = "okay"; +}; + +&sata { + status = "okay"; +}; + +/* Apalis UART1 */ +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart1_dte &pinctrl_uart1_ctrl>; + fsl,dte-mode; + uart-has-rtscts; + status = "okay"; +}; + +/* Apalis UART2 */ +&uart2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart2_dte>; + fsl,dte-mode; + uart-has-rtscts; + status = "okay"; +}; + +/* Apalis UART3 */ +&uart4 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart4_dte>; + fsl,dte-mode; + status = "okay"; +}; + +/* Apalis UART4 */ +&uart5 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_uart5_dte>; + fsl,dte-mode; + status = "okay"; +}; + +&usbh1 { + dr_mode = "host"; + vbus-supply = <®_usb_host_vbus>; + status = "okay"; +}; + +&usbotg { + dr_mode = "host"; + vbus-supply = <®_usb_otg_vbus>; + status = "okay"; +}; + +/* MMC1 */ +&usdhc1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc1_4bit &pinctrl_usdhc1_8bit &pinctrl_mmc_cd>; + cd-gpios = <&gpio4 20 GPIO_ACTIVE_LOW>; + disable-wp; + no-1-8-v; + status = "okay"; +}; + +/* SD1 */ +&usdhc2 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc2 &pinctrl_sd_cd>; + cd-gpios = <&gpio6 14 GPIO_ACTIVE_LOW>; + disable-wp; + no-1-8-v; + status = "okay"; +}; + +/* eMMC */ +&usdhc3 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_usdhc3>; + vqmmc-supply = <®_module_3v3>; + bus-width = <8>; + no-1-8-v; + non-removable; + status = "okay"; +}; + +&iomuxc { + pinctrl_apalis_gpio1: gpio2io04grp { + fsl,pins = < + MX6QDL_PAD_NANDF_D4__GPIO2_IO04 0x130b0 + >; + }; + + pinctrl_apalis_gpio2: gpio2io05grp { + fsl,pins = < + MX6QDL_PAD_NANDF_D5__GPIO2_IO05 0x130b0 + >; + }; + + pinctrl_apalis_gpio3: gpio2io06grp { + fsl,pins = < + MX6QDL_PAD_NANDF_D6__GPIO2_IO06 0x130b0 + >; + }; + + pinctrl_apalis_gpio4: gpio2io07grp { + fsl,pins = < + MX6QDL_PAD_NANDF_D7__GPIO2_IO07 0x130b0 + >; + }; + + pinctrl_apalis_gpio5: gpio6io10grp { + fsl,pins = < + MX6QDL_PAD_NANDF_RB0__GPIO6_IO10 0x130b0 + >; + }; + + pinctrl_apalis_gpio6: gpio6io09grp { + fsl,pins = < + MX6QDL_PAD_NANDF_WP_B__GPIO6_IO09 0x130b0 + >; + }; + + pinctrl_apalis_gpio7: gpio1io02grp { + fsl,pins = < + MX6QDL_PAD_GPIO_2__GPIO1_IO02 0x130b0 + >; + }; + + pinctrl_apalis_gpio8: gpio1io06grp { + fsl,pins = < + MX6QDL_PAD_GPIO_6__GPIO1_IO06 0x130b0 + >; + }; + + pinctrl_audmux: audmuxgrp { + fsl,pins = < + MX6QDL_PAD_DISP0_DAT20__AUD4_TXC 0x130b0 + MX6QDL_PAD_DISP0_DAT21__AUD4_TXD 0x130b0 + MX6QDL_PAD_DISP0_DAT22__AUD4_TXFS 0x130b0 + MX6QDL_PAD_DISP0_DAT23__AUD4_RXD 0x130b0 + /* SGTL5000 sys_mclk */ + MX6QDL_PAD_GPIO_5__CCM_CLKO1 0x130b0 + >; + }; + + pinctrl_cam_mclk: cammclkgrp { + fsl,pins = < + /* CAM sys_mclk */ + MX6QDL_PAD_NANDF_CS2__CCM_CLKO2 0x00b0 + >; + }; + + pinctrl_ecspi1: ecspi1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT6__ECSPI1_MISO 0x100b1 + MX6QDL_PAD_CSI0_DAT5__ECSPI1_MOSI 0x100b1 + MX6QDL_PAD_CSI0_DAT4__ECSPI1_SCLK 0x100b1 + /* SPI1 cs */ + MX6QDL_PAD_CSI0_DAT7__GPIO5_IO25 0x000b1 + >; + }; + + pinctrl_ecspi2: ecspi2grp { + fsl,pins = < + MX6QDL_PAD_EIM_OE__ECSPI2_MISO 0x100b1 + MX6QDL_PAD_EIM_CS1__ECSPI2_MOSI 0x100b1 + MX6QDL_PAD_EIM_CS0__ECSPI2_SCLK 0x100b1 + /* SPI2 cs */ + MX6QDL_PAD_EIM_RW__GPIO2_IO26 0x000b1 + >; + }; + + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x100b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x100b0 + MX6QDL_PAD_RGMII_TXC__RGMII_TXC 0x10030 + MX6QDL_PAD_RGMII_TD0__RGMII_TD0 0x10030 + MX6QDL_PAD_RGMII_TD1__RGMII_TD1 0x10030 + MX6QDL_PAD_RGMII_TD2__RGMII_TD2 0x10030 + MX6QDL_PAD_RGMII_TD3__RGMII_TD3 0x10030 + MX6QDL_PAD_RGMII_TX_CTL__RGMII_TX_CTL 0x10030 + MX6QDL_PAD_ENET_REF_CLK__ENET_TX_CLK 0x100b0 + MX6QDL_PAD_RGMII_RXC__RGMII_RXC 0x1b030 + MX6QDL_PAD_RGMII_RD0__RGMII_RD0 0x1b030 + MX6QDL_PAD_RGMII_RD1__RGMII_RD1 0x1b030 + MX6QDL_PAD_RGMII_RD2__RGMII_RD2 0x1b030 + MX6QDL_PAD_RGMII_RD3__RGMII_RD3 0x1b030 + MX6QDL_PAD_RGMII_RX_CTL__RGMII_RX_CTL 0x1b030 + /* Ethernet PHY reset */ + MX6QDL_PAD_ENET_CRS_DV__GPIO1_IO25 0x000b0 + /* Ethernet PHY interrupt */ + MX6QDL_PAD_ENET_TXD0__GPIO1_IO30 0x000b1 + >; + }; + + pinctrl_flexcan1: flexcan1grp { + fsl,pins = < + MX6QDL_PAD_GPIO_7__FLEXCAN1_TX 0x1b0b0 + MX6QDL_PAD_GPIO_8__FLEXCAN1_RX 0x1b0b0 + >; + }; + + pinctrl_flexcan2: flexcan2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL4__FLEXCAN2_TX 0x1b0b0 + MX6QDL_PAD_KEY_ROW4__FLEXCAN2_RX 0x1b0b0 + >; + }; + + pinctrl_gpio_bl_on: gpioblon { + fsl,pins = < + MX6QDL_PAD_EIM_DA13__GPIO3_IO13 0x1b0b0 + >; + }; + + pinctrl_gpio_keys: gpio1io04grp { + fsl,pins = < + /* Power button */ + MX6QDL_PAD_GPIO_4__GPIO1_IO04 0x1b0b0 + >; + }; + + pinctrl_hdmi_cec: hdmicecgrp { + fsl,pins = < + MX6QDL_PAD_KEY_ROW2__HDMI_TX_CEC_LINE 0x1f8b0 + >; + }; + + pinctrl_hdmi_ddc: hdmiddcgrp { + fsl,pins = < + MX6QDL_PAD_EIM_EB2__HDMI_TX_DDC_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D16__HDMI_TX_DDC_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c1: i2c1grp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT8__I2C1_SDA 0x4001b8b1 + MX6QDL_PAD_CSI0_DAT9__I2C1_SCL 0x4001b8b1 + >; + }; + + pinctrl_i2c2: i2c2grp { + fsl,pins = < + MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1 + MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3: i2c3grp { + fsl,pins = < + MX6QDL_PAD_EIM_D17__I2C3_SCL 0x4001b8b1 + MX6QDL_PAD_EIM_D18__I2C3_SDA 0x4001b8b1 + >; + }; + + pinctrl_i2c3_recovery: i2c3recoverygrp { + fsl,pins = < + MX6QDL_PAD_EIM_D17__GPIO3_IO17 0x4001b8b1 + MX6QDL_PAD_EIM_D18__GPIO3_IO18 0x4001b8b1 + >; + }; + + pinctrl_ipu1_lcdif: ipu1lcdifgrp { + fsl,pins = < + MX6QDL_PAD_EIM_A16__IPU1_DI1_DISP_CLK 0x61 + /* DE */ + MX6QDL_PAD_EIM_DA10__IPU1_DI1_PIN15 0x61 + /* HSync */ + MX6QDL_PAD_EIM_DA11__IPU1_DI1_PIN02 0x61 + /* VSync */ + MX6QDL_PAD_EIM_DA12__IPU1_DI1_PIN03 0x61 + MX6QDL_PAD_EIM_DA9__IPU1_DISP1_DATA00 0x61 + MX6QDL_PAD_EIM_DA8__IPU1_DISP1_DATA01 0x61 + MX6QDL_PAD_EIM_DA7__IPU1_DISP1_DATA02 0x61 + MX6QDL_PAD_EIM_DA6__IPU1_DISP1_DATA03 0x61 + MX6QDL_PAD_EIM_DA5__IPU1_DISP1_DATA04 0x61 + MX6QDL_PAD_EIM_DA4__IPU1_DISP1_DATA05 0x61 + MX6QDL_PAD_EIM_DA3__IPU1_DISP1_DATA06 0x61 + MX6QDL_PAD_EIM_DA2__IPU1_DISP1_DATA07 0x61 + MX6QDL_PAD_EIM_DA1__IPU1_DISP1_DATA08 0x61 + MX6QDL_PAD_EIM_DA0__IPU1_DISP1_DATA09 0x61 + MX6QDL_PAD_EIM_EB1__IPU1_DISP1_DATA10 0x61 + MX6QDL_PAD_EIM_EB0__IPU1_DISP1_DATA11 0x61 + MX6QDL_PAD_EIM_A17__IPU1_DISP1_DATA12 0x61 + MX6QDL_PAD_EIM_A18__IPU1_DISP1_DATA13 0x61 + MX6QDL_PAD_EIM_A19__IPU1_DISP1_DATA14 0x61 + MX6QDL_PAD_EIM_A20__IPU1_DISP1_DATA15 0x61 + MX6QDL_PAD_EIM_A21__IPU1_DISP1_DATA16 0x61 + MX6QDL_PAD_EIM_A22__IPU1_DISP1_DATA17 0x61 + MX6QDL_PAD_EIM_A23__IPU1_DISP1_DATA18 0x61 + MX6QDL_PAD_EIM_A24__IPU1_DISP1_DATA19 0x61 + MX6QDL_PAD_EIM_D31__IPU1_DISP1_DATA20 0x61 + MX6QDL_PAD_EIM_D30__IPU1_DISP1_DATA21 0x61 + MX6QDL_PAD_EIM_D26__IPU1_DISP1_DATA22 0x61 + MX6QDL_PAD_EIM_D27__IPU1_DISP1_DATA23 0x61 + >; + }; + + pinctrl_ipu2_vdac: ipu2vdacgrp { + fsl,pins = < + MX6QDL_PAD_DI0_DISP_CLK__IPU2_DI0_DISP_CLK 0xd1 + MX6QDL_PAD_DI0_PIN15__IPU2_DI0_PIN15 0xd1 + MX6QDL_PAD_DI0_PIN2__IPU2_DI0_PIN02 0xd1 + MX6QDL_PAD_DI0_PIN3__IPU2_DI0_PIN03 0xd1 + MX6QDL_PAD_DISP0_DAT0__IPU2_DISP0_DATA00 0xf9 + MX6QDL_PAD_DISP0_DAT1__IPU2_DISP0_DATA01 0xf9 + MX6QDL_PAD_DISP0_DAT2__IPU2_DISP0_DATA02 0xf9 + MX6QDL_PAD_DISP0_DAT3__IPU2_DISP0_DATA03 0xf9 + MX6QDL_PAD_DISP0_DAT4__IPU2_DISP0_DATA04 0xf9 + MX6QDL_PAD_DISP0_DAT5__IPU2_DISP0_DATA05 0xf9 + MX6QDL_PAD_DISP0_DAT6__IPU2_DISP0_DATA06 0xf9 + MX6QDL_PAD_DISP0_DAT7__IPU2_DISP0_DATA07 0xf9 + MX6QDL_PAD_DISP0_DAT8__IPU2_DISP0_DATA08 0xf9 + MX6QDL_PAD_DISP0_DAT9__IPU2_DISP0_DATA09 0xf9 + MX6QDL_PAD_DISP0_DAT10__IPU2_DISP0_DATA10 0xf9 + MX6QDL_PAD_DISP0_DAT11__IPU2_DISP0_DATA11 0xf9 + MX6QDL_PAD_DISP0_DAT12__IPU2_DISP0_DATA12 0xf9 + MX6QDL_PAD_DISP0_DAT13__IPU2_DISP0_DATA13 0xf9 + MX6QDL_PAD_DISP0_DAT14__IPU2_DISP0_DATA14 0xf9 + MX6QDL_PAD_DISP0_DAT15__IPU2_DISP0_DATA15 0xf9 + >; + }; + + pinctrl_mmc_cd: gpiommccdgrp { + fsl,pins = < + /* MMC1 CD */ + MX6QDL_PAD_DI0_PIN4__GPIO4_IO20 0x000b0 + >; + }; + + pinctrl_pwm1: pwm1grp { + fsl,pins = < + MX6QDL_PAD_GPIO_9__PWM1_OUT 0x1b0b1 + >; + }; + + pinctrl_pwm2: pwm2grp { + fsl,pins = < + MX6QDL_PAD_GPIO_1__PWM2_OUT 0x1b0b1 + >; + }; + + pinctrl_pwm3: pwm3grp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT1__PWM3_OUT 0x1b0b1 + >; + }; + + pinctrl_pwm4: pwm4grp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT2__PWM4_OUT 0x1b0b1 + >; + }; + + pinctrl_regulator_usbh_pwr: gpioregusbhpwrgrp { + fsl,pins = < + /* USBH_EN */ + MX6QDL_PAD_GPIO_0__GPIO1_IO00 0x0f058 + >; + }; + + pinctrl_regulator_usbhub_pwr: gpioregusbhubpwrgrp { + fsl,pins = < + /* USBH_HUB_EN */ + MX6QDL_PAD_EIM_D28__GPIO3_IO28 0x0f058 + >; + }; + + pinctrl_regulator_usbotg_pwr: gpioregusbotgpwrgrp { + fsl,pins = < + /* USBO1 power en */ + MX6QDL_PAD_EIM_D22__GPIO3_IO22 0x0f058 + >; + }; + + pinctrl_reset_moci: gpioresetmocigrp { + fsl,pins = < + /* RESET_MOCI control */ + MX6QDL_PAD_ENET_TX_EN__GPIO1_IO28 0x0f058 + >; + }; + + pinctrl_sd_cd: gpiosdcdgrp { + fsl,pins = < + /* SD1 CD */ + MX6QDL_PAD_NANDF_CS1__GPIO6_IO14 0x000b0 + >; + }; + + pinctrl_spdif: spdifgrp { + fsl,pins = < + MX6QDL_PAD_GPIO_16__SPDIF_IN 0x1b0b0 + MX6QDL_PAD_GPIO_17__SPDIF_OUT 0x1b0b0 + >; + }; + + pinctrl_touch_int: gpiotouchintgrp { + fsl,pins = < + /* STMPE811 interrupt */ + MX6QDL_PAD_KEY_COL2__GPIO4_IO10 0x1b0b0 + >; + }; + + pinctrl_uart1_dce: uart1dcegrp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT11__UART1_RX_DATA 0x1b0b1 + >; + }; + + /* DTE mode */ + pinctrl_uart1_dte: uart1dtegrp { + fsl,pins = < + MX6QDL_PAD_CSI0_DAT10__UART1_RX_DATA 0x1b0b1 + MX6QDL_PAD_CSI0_DAT11__UART1_TX_DATA 0x1b0b1 + MX6QDL_PAD_EIM_D19__UART1_RTS_B 0x1b0b1 + MX6QDL_PAD_EIM_D20__UART1_CTS_B 0x1b0b1 + >; + }; + + /* Additional DTR, DSR, DCD */ + pinctrl_uart1_ctrl: uart1ctrlgrp { + fsl,pins = < + MX6QDL_PAD_EIM_D23__UART1_DCD_B 0x1b0b0 + MX6QDL_PAD_EIM_D24__UART1_DTR_B 0x1b0b0 + MX6QDL_PAD_EIM_D25__UART1_DSR_B 0x1b0b0 + >; + }; + + pinctrl_uart2_dce: uart2dcegrp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT4__UART2_RX_DATA 0x1b0b1 + MX6QDL_PAD_SD4_DAT7__UART2_TX_DATA 0x1b0b1 + >; + }; + + /* DTE mode */ + pinctrl_uart2_dte: uart2dtegrp { + fsl,pins = < + MX6QDL_PAD_SD4_DAT4__UART2_TX_DATA 0x1b0b1 + MX6QDL_PAD_SD4_DAT7__UART2_RX_DATA 0x1b0b1 + MX6QDL_PAD_SD4_DAT6__UART2_RTS_B 0x1b0b1 + MX6QDL_PAD_SD4_DAT5__UART2_CTS_B 0x1b0b1 + >; + }; + + pinctrl_uart4_dce: uart4dcegrp { + fsl,pins = < + MX6QDL_PAD_KEY_COL0__UART4_TX_DATA 0x1b0b1 + MX6QDL_PAD_KEY_ROW0__UART4_RX_DATA 0x1b0b1 + >; + }; + + /* DTE mode */ + pinctrl_uart4_dte: uart4dtegrp { + fsl,pins = < + MX6QDL_PAD_KEY_COL0__UART4_RX_DATA 0x1b0b1 + MX6QDL_PAD_KEY_ROW0__UART4_TX_DATA 0x1b0b1 + >; + }; + + pinctrl_uart5_dce: uart5dcegrp { + fsl,pins = < + MX6QDL_PAD_KEY_COL1__UART5_TX_DATA 0x1b0b1 + MX6QDL_PAD_KEY_ROW1__UART5_RX_DATA 0x1b0b1 + >; + }; + + /* DTE mode */ + pinctrl_uart5_dte: uart5dtegrp { + fsl,pins = < + MX6QDL_PAD_KEY_COL1__UART5_RX_DATA 0x1b0b1 + MX6QDL_PAD_KEY_ROW1__UART5_TX_DATA 0x1b0b1 + >; + }; + + pinctrl_usbotg: usbotggrp { + fsl,pins = < + MX6QDL_PAD_ENET_RX_ER__USB_OTG_ID 0x17059 + >; + }; + + pinctrl_usdhc1_4bit: usdhc1grp_4bit { + fsl,pins = < + MX6QDL_PAD_SD1_CMD__SD1_CMD 0x17071 + MX6QDL_PAD_SD1_CLK__SD1_CLK 0x10071 + MX6QDL_PAD_SD1_DAT0__SD1_DATA0 0x17071 + MX6QDL_PAD_SD1_DAT1__SD1_DATA1 0x17071 + MX6QDL_PAD_SD1_DAT2__SD1_DATA2 0x17071 + MX6QDL_PAD_SD1_DAT3__SD1_DATA3 0x17071 + >; + }; + + pinctrl_usdhc1_8bit: usdhc1grp_8bit { + fsl,pins = < + MX6QDL_PAD_NANDF_D0__SD1_DATA4 0x17071 + MX6QDL_PAD_NANDF_D1__SD1_DATA5 0x17071 + MX6QDL_PAD_NANDF_D2__SD1_DATA6 0x17071 + MX6QDL_PAD_NANDF_D3__SD1_DATA7 0x17071 + >; + }; + + pinctrl_usdhc2: usdhc2grp { + fsl,pins = < + MX6QDL_PAD_SD2_CMD__SD2_CMD 0x17071 + MX6QDL_PAD_SD2_CLK__SD2_CLK 0x10071 + MX6QDL_PAD_SD2_DAT0__SD2_DATA0 0x17071 + MX6QDL_PAD_SD2_DAT1__SD2_DATA1 0x17071 + MX6QDL_PAD_SD2_DAT2__SD2_DATA2 0x17071 + MX6QDL_PAD_SD2_DAT3__SD2_DATA3 0x17071 + >; + }; + + pinctrl_usdhc3: usdhc3grp { + fsl,pins = < + MX6QDL_PAD_SD3_CMD__SD3_CMD 0x17059 + MX6QDL_PAD_SD3_CLK__SD3_CLK 0x10059 + MX6QDL_PAD_SD3_DAT0__SD3_DATA0 0x17059 + MX6QDL_PAD_SD3_DAT1__SD3_DATA1 0x17059 + MX6QDL_PAD_SD3_DAT2__SD3_DATA2 0x17059 + MX6QDL_PAD_SD3_DAT3__SD3_DATA3 0x17059 + MX6QDL_PAD_SD3_DAT4__SD3_DATA4 0x17059 + MX6QDL_PAD_SD3_DAT5__SD3_DATA5 0x17059 + MX6QDL_PAD_SD3_DAT6__SD3_DATA6 0x17059 + MX6QDL_PAD_SD3_DAT7__SD3_DATA7 0x17059 + /* eMMC reset */ + MX6QDL_PAD_SD3_RST__SD3_RESET 0x17059 + >; + }; +}; diff --git a/board/toradex/apalis_imx6/MAINTAINERS b/board/toradex/apalis_imx6/MAINTAINERS index a5d2c84956..7efe816a78 100644 --- a/board/toradex/apalis_imx6/MAINTAINERS +++ b/board/toradex/apalis_imx6/MAINTAINERS @@ -1,7 +1,9 @@ Apalis iMX6 M: Max Krummenacher max.krummenacher@toradex.com W: http://developer.toradex.com/software/linux/linux-software +W: https://www.toradex.com/community S: Maintained F: board/toradex/apalis_imx6/ F: include/configs/apalis_imx6.h F: configs/apalis_imx6_defconfig +F: arch/arm/dts/imx6-apalis.dts diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index b262bb88b9..985d8554b8 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -45,6 +45,8 @@ CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="imx6-apalis" CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DWC_AHSATA=y @@ -66,5 +68,4 @@ CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_HOST_ETHER=y CONFIG_VIDEO=y CONFIG_FAT_WRITE=y -CONFIG_OF_LIBFDT=y CONFIG_OF_LIBFDT_OVERLAY=y
Migrate GPIOs to using driver model, properly request backlight and Ethernet PHY reset GPIOs and also enable SION bit in pin muxing for USB power enable GPIOs.
While at it also update copyright year and add some comments clarifying ifdef scope.
board/toradex/apalis_imx6/apalis_imx6.c | 22 ++++++++++++---------- configs/apalis_imx6_defconfig | 1 + 2 files changed, 13 insertions(+), 10 deletions(-)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 368db9c488..ac1e616a36 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -2,7 +2,7 @@ /* * Copyright (C) 2010-2013 Freescale Semiconductor, Inc. * Copyright (C) 2013, Boundary Devices info@boundarydevices.com - * Copyright (C) 2014-2016, Toradex AG + * Copyright (C) 2014-2019, Toradex AG * copied from nitrogen6x */
@@ -253,6 +253,7 @@ static void setup_iomux_enet(void) static int reset_enet_phy(struct mii_dev *bus) { /* Reset KSZ9031 PHY */ + gpio_request(GPIO_ENET_PHY_RESET, "ETH_RESET#"); gpio_direction_output(GPIO_ENET_PHY_RESET, 0); mdelay(10); gpio_set_value(GPIO_ENET_PHY_RESET, 1); @@ -281,7 +282,7 @@ static void setup_iomux_gpio(void)
iomux_v3_cfg_t const usb_pads[] = { /* USBH_EN */ - MX6_PAD_GPIO_0__GPIO1_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_GPIO_0__GPIO1_IO00 | MUX_PAD_CTRL(NO_PAD_CTRL) | MUX_MODE_SION, # define GPIO_USBH_EN IMX_GPIO_NR(1, 0) /* USB_VBUS_DET */ MX6_PAD_EIM_D28__GPIO3_IO28 | MUX_PAD_CTRL(NO_PAD_CTRL), @@ -289,7 +290,7 @@ iomux_v3_cfg_t const usb_pads[] = { /* USBO1_ID */ MX6_PAD_ENET_RX_ER__USB_OTG_ID | MUX_PAD_CTRL(WEAK_PULLUP), /* USBO1_EN */ - MX6_PAD_EIM_D22__GPIO3_IO22 | MUX_PAD_CTRL(NO_PAD_CTRL), + MX6_PAD_EIM_D22__GPIO3_IO22 | MUX_PAD_CTRL(NO_PAD_CTRL) | MUX_MODE_SION, # define GPIO_USBO_EN IMX_GPIO_NR(3, 22) };
@@ -424,7 +425,7 @@ int board_mmc_init(bd_t *bis) }
return status; -#else +#else /* CONFIG_SPL_BUILD */ struct src *psrc = (struct src *)SRC_BASE_ADDR; unsigned reg = readl(&psrc->sbmr1) >> 11; /* @@ -463,9 +464,9 @@ int board_mmc_init(bd_t *bis) }
return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); -#endif +#endif /* CONFIG_SPL_BUILD */ } -#endif +#endif /* CONFIG_FSL_ESDHC */
int board_phy_config(struct phy_device *phydev) { @@ -504,7 +505,7 @@ int board_eth_init(bd_t *bis) free(phydev); free(bus); } -#endif +#endif /* CONFIG_FEC_MXC */ return 0; }
@@ -741,6 +742,9 @@ static void setup_display(void) imx_iomux_v3_setup_multiple_pads(backlight_pads, ARRAY_SIZE(backlight_pads)); /* use 0 for EDT 7", use 1 for LG fullHD panel */ + gpio_request(RGB_BACKLIGHTPWM_GP, "PWM<A>"); + gpio_request(RGB_BACKLIGHTPWM_OE, "BKL1_PWM_EN"); + gpio_request(RGB_BACKLIGHT_GP, "BL_ON"); gpio_direction_output(RGB_BACKLIGHTPWM_GP, 0); gpio_direction_output(RGB_BACKLIGHTPWM_OE, 0); gpio_direction_output(RGB_BACKLIGHT_GP, 1); @@ -1134,7 +1138,6 @@ MX6_MMDC_P0_MDSCR, 0x00000000, MX6_MMDC_P0_MAPSR, 0x00011006, };
- static void ccgr_init(void) { struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; @@ -1222,8 +1225,7 @@ void board_init_f(ulong dummy) void reset_cpu(ulong addr) { } - -#endif +#endif /* CONFIG_SPL_BUILD */
static struct mxc_serial_platdata mxc_serial_plat = { .reg = (struct mxc_uart *)UART1_BASE, diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 985d8554b8..0f6119bef5 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -51,6 +51,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DWC_AHSATA=y CONFIG_DFU_MMC=y +CONFIG_DM_GPIO=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y
Enable pin control driver as required for further driver model migration.
configs/apalis_imx6_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 0f6119bef5..0763b1d986 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -57,6 +57,8 @@ CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_MII=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_IMX6=y CONFIG_IMX_THERMAL=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y
Migrate I2C to using driver model.
board/toradex/apalis_imx6/apalis_imx6.c | 88 +------------------------ board/toradex/apalis_imx6/pf0100.c | 58 ++++++++-------- configs/apalis_imx6_defconfig | 1 + include/configs/apalis_imx6.h | 8 +-- 4 files changed, 35 insertions(+), 120 deletions(-)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index ac1e616a36..2c9a7db931 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -21,14 +21,12 @@ #include <asm/gpio.h> #include <asm/io.h> #include <asm/mach-imx/iomux-v3.h> -#include <asm/mach-imx/mxc_i2c.h> #include <asm/mach-imx/sata.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> #include <dm/platform_data/serial_mxc.h> #include <dm/platdata.h> #include <fsl_esdhc.h> -#include <i2c.h> #include <input.h> #include <imx_thermal.h> #include <linux/errno.h> @@ -56,32 +54,16 @@ DECLARE_GLOBAL_DATA_PTR; #define ENET_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS)
-#define SPI_PAD_CTRL (PAD_CTL_HYS | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST) - -#define BUTTON_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - -#define I2C_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_ODE | PAD_CTL_SRE_FAST) - #define WEAK_PULLUP (PAD_CTL_PUS_100K_UP | \ PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ PAD_CTL_SRE_SLOW)
-#define NO_PULLUP ( \ - PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | PAD_CTL_HYS | \ - PAD_CTL_SRE_SLOW) - #define WEAK_PULLDOWN (PAD_CTL_PUS_100K_DOWN | \ PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ PAD_CTL_HYS | PAD_CTL_SRE_SLOW)
#define TRISTATE (PAD_CTL_HYS | PAD_CTL_SPEED_MED)
-#define OUTPUT_40OHM (PAD_CTL_SPEED_MED|PAD_CTL_DSE_40ohm) - #define OUTPUT_RGB (PAD_CTL_SPEED_MED|PAD_CTL_DSE_60ohm|PAD_CTL_SRE_FAST)
int dram_init(void) @@ -103,63 +85,6 @@ iomux_v3_cfg_t const uart1_pads_dte[] = { MX6_PAD_CSI0_DAT11__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
-#define PC MUX_PAD_CTRL(I2C_PAD_CTRL) -/* Apalis I2C1 */ -struct i2c_pads_info i2c_pad_info1 = { - .scl = { - .i2c_mode = MX6_PAD_CSI0_DAT9__I2C1_SCL | PC, - .gpio_mode = MX6_PAD_CSI0_DAT9__GPIO5_IO27 | PC, - .gp = IMX_GPIO_NR(5, 27) - }, - .sda = { - .i2c_mode = MX6_PAD_CSI0_DAT8__I2C1_SDA | PC, - .gpio_mode = MX6_PAD_CSI0_DAT8__GPIO5_IO26 | PC, - .gp = IMX_GPIO_NR(5, 26) - } -}; - -/* Apalis local, PMIC, SGTL5000, STMPE811 */ -struct i2c_pads_info i2c_pad_info_loc = { - .scl = { - .i2c_mode = MX6_PAD_KEY_COL3__I2C2_SCL | PC, - .gpio_mode = MX6_PAD_KEY_COL3__GPIO4_IO12 | PC, - .gp = IMX_GPIO_NR(4, 12) - }, - .sda = { - .i2c_mode = MX6_PAD_KEY_ROW3__I2C2_SDA | PC, - .gpio_mode = MX6_PAD_KEY_ROW3__GPIO4_IO13 | PC, - .gp = IMX_GPIO_NR(4, 13) - } -}; - -/* Apalis I2C3 / CAM */ -struct i2c_pads_info i2c_pad_info3 = { - .scl = { - .i2c_mode = MX6_PAD_EIM_D17__I2C3_SCL | PC, - .gpio_mode = MX6_PAD_EIM_D17__GPIO3_IO17 | PC, - .gp = IMX_GPIO_NR(3, 17) - }, - .sda = { - .i2c_mode = MX6_PAD_EIM_D18__I2C3_SDA | PC, - .gpio_mode = MX6_PAD_EIM_D18__GPIO3_IO18 | PC, - .gp = IMX_GPIO_NR(3, 18) - } -}; - -/* Apalis I2C2 / DDC */ -struct i2c_pads_info i2c_pad_info_ddc = { - .scl = { - .i2c_mode = MX6_PAD_EIM_EB2__HDMI_TX_DDC_SCL | PC, - .gpio_mode = MX6_PAD_EIM_EB2__GPIO2_IO30 | PC, - .gp = IMX_GPIO_NR(2, 30) - }, - .sda = { - .i2c_mode = MX6_PAD_EIM_D16__HDMI_TX_DDC_SDA | PC, - .gpio_mode = MX6_PAD_EIM_D16__GPIO3_IO16 | PC, - .gp = IMX_GPIO_NR(3, 16) - } -}; - /* Apalis MMC1 */ iomux_v3_cfg_t const usdhc1_pads[] = { MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -572,12 +497,6 @@ static void do_enable_hdmi(struct display_info_t const *dev) imx_enable_hdmi_phy(); }
-static int detect_i2c(struct display_info_t const *dev) -{ - return (0 == i2c_set_bus_num(dev->bus)) && - (0 == i2c_probe(dev->addr)); -} - static void enable_lvds(struct display_info_t const *dev) { struct iomuxc *iomux = (struct iomuxc *) @@ -671,7 +590,6 @@ struct display_info_t const displays[] = {{ .bus = -1, .addr = 0, .pixfmt = IPU_PIX_FMT_LVDS666, - .detect = detect_i2c, .enable = enable_lvds, .mode = { .name = "wsvga-lvds", @@ -777,10 +695,6 @@ int board_init(void) /* address of boot parameters */ gd->bd->bi_boot_params = PHYS_SDRAM + 0x100;
- setup_i2c(0, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info1); - setup_i2c(1, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info_loc); - setup_i2c(2, CONFIG_SYS_I2C_SPEED, 0x7f, &i2c_pad_info3); - #if defined(CONFIG_VIDEO_IPUV3) setup_display(); #endif @@ -1198,7 +1112,7 @@ void board_init_f(ulong dummy) ccgr_init(); gpr_init();
- /* iomux and setup of i2c */ + /* iomux */ board_early_init_f();
/* setup GP timer */ diff --git a/board/toradex/apalis_imx6/pf0100.c b/board/toradex/apalis_imx6/pf0100.c index 7334e92f2e..6ff21adf50 100644 --- a/board/toradex/apalis_imx6/pf0100.c +++ b/board/toradex/apalis_imx6/pf0100.c @@ -1,6 +1,6 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2014-2016, Toradex AG + * Copyright (C) 2014-2019, Toradex AG */
/* @@ -30,22 +30,25 @@ static __maybe_unused iomux_v3_cfg_t const pmic_prog_pads[] = {
unsigned pmic_init(void) { + int rc; + struct udevice *dev = NULL; unsigned programmed = 0; uchar bus = 1; uchar devid, revid, val;
puts("PMIC: "); - if (!((0 == i2c_set_bus_num(bus)) && - (0 == i2c_probe(PFUZE100_I2C_ADDR)))) { - puts("i2c bus failed\n"); + rc = i2c_get_chip_for_busnum(bus, PFUZE100_I2C_ADDR, 1, &dev); + if (rc) { + printf("failed to get device for PMIC at address 0x%x\n", + PFUZE100_I2C_ADDR); return 0; } /* get device ident */ - if (i2c_read(PFUZE100_I2C_ADDR, PFUZE100_DEVICEID, 1, &devid, 1) < 0) { + if (dm_i2c_read(dev, PFUZE100_DEVICEID, &devid, 1) < 0) { puts("i2c pmic devid read failed\n"); return 0; } - if (i2c_read(PFUZE100_I2C_ADDR, PFUZE100_REVID, 1, &revid, 1) < 0) { + if (dm_i2c_read(dev, PFUZE100_REVID, &revid, 1) < 0) { puts("i2c pmic revid read failed\n"); return 0; } @@ -60,7 +63,7 @@ unsigned pmic_init(void) for (j = 0; j < 0x80; ) { printf("\n%2x", j); for (i = 0; i < 16; i++) { - i2c_read(PFUZE100_I2C_ADDR, j+i, 1, &val, 1); + dm_i2c_read(dev, j + i, &val, 1); printf("\t%2x", val); } j += 0x10; @@ -68,8 +71,7 @@ unsigned pmic_init(void) printf("\nEXT Page 1");
val = PFUZE100_PAGE_REGISTER_PAGE1; - if (i2c_write(PFUZE100_I2C_ADDR, PFUZE100_PAGE_REGISTER, 1, - &val, 1)) { + if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { puts("i2c write failed\n"); return 0; } @@ -77,7 +79,7 @@ unsigned pmic_init(void) for (j = 0x80; j < 0x100; ) { printf("\n%2x", j); for (i = 0; i < 16; i++) { - i2c_read(PFUZE100_I2C_ADDR, j+i, 1, &val, 1); + dm_i2c_read(dev, j + i, &val, 1); printf("\t%2x", val); } j += 0x10; @@ -85,8 +87,7 @@ unsigned pmic_init(void) printf("\nEXT Page 2");
val = PFUZE100_PAGE_REGISTER_PAGE2; - if (i2c_write(PFUZE100_I2C_ADDR, PFUZE100_PAGE_REGISTER, 1, - &val, 1)) { + if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { puts("i2c write failed\n"); return 0; } @@ -94,35 +95,35 @@ unsigned pmic_init(void) for (j = 0x80; j < 0x100; ) { printf("\n%2x", j); for (i = 0; i < 16; i++) { - i2c_read(PFUZE100_I2C_ADDR, j+i, 1, &val, 1); + dm_i2c_read(dev, j + i, &val, 1); printf("\t%2x", val); } j += 0x10; } printf("\n"); } -#endif +#endif /* DEBUG */ /* get device programmed state */ val = PFUZE100_PAGE_REGISTER_PAGE1; - if (i2c_write(PFUZE100_I2C_ADDR, PFUZE100_PAGE_REGISTER, 1, &val, 1)) { + if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { puts("i2c write failed\n"); return 0; } - if (i2c_read(PFUZE100_I2C_ADDR, PFUZE100_FUSE_POR1, 1, &val, 1) < 0) { + if (dm_i2c_read(dev, PFUZE100_FUSE_POR1, &val, 1) < 0) { puts("i2c fuse_por read failed\n"); return 0; } if (val & PFUZE100_FUSE_POR_M) programmed++;
- if (i2c_read(PFUZE100_I2C_ADDR, PFUZE100_FUSE_POR2, 1, &val, 1) < 0) { + if (dm_i2c_read(dev, PFUZE100_FUSE_POR2, &val, 1) < 0) { puts("i2c fuse_por read failed\n"); return programmed; } if (val & PFUZE100_FUSE_POR_M) programmed++;
- if (i2c_read(PFUZE100_I2C_ADDR, PFUZE100_FUSE_POR3, 1, &val, 1) < 0) { + if (dm_i2c_read(dev, PFUZE100_FUSE_POR3, &val, 1) < 0) { puts("i2c fuse_por read failed\n"); return programmed; } @@ -145,18 +146,15 @@ unsigned pmic_init(void) if (programmed != 3) { /* set VGEN1 to 1.2V */ val = PFUZE100_VGEN1_VAL; - if (i2c_write(PFUZE100_I2C_ADDR, PFUZE100_VGEN1CTL, 1, - &val, 1)) { + if (dm_i2c_write(dev, PFUZE100_VGEN1CTL, &val, 1)) { puts("i2c write failed\n"); return programmed; }
/* set SWBST to 5.0V */ val = PFUZE100_SWBST_VAL; - if (i2c_write(PFUZE100_I2C_ADDR, PFUZE100_SWBSTCTL, 1, - &val, 1)) { + if (dm_i2c_write(dev, PFUZE100_SWBSTCTL, &val, 1)) puts("i2c write failed\n"); - } } return programmed; } @@ -164,6 +162,8 @@ unsigned pmic_init(void) #ifndef CONFIG_SPL_BUILD static int pf0100_prog(void) { + int rc; + struct udevice *dev = NULL; unsigned char bus = 1; unsigned char val; unsigned int i; @@ -177,9 +177,10 @@ static int pf0100_prog(void) ARRAY_SIZE(pmic_prog_pads)); gpio_direction_output(PMIC_PROG_VOLTAGE, 0);
- if (!((0 == i2c_set_bus_num(bus)) && - (0 == i2c_probe(PFUZE100_I2C_ADDR)))) { - puts("i2c bus failed\n"); + rc = i2c_get_chip_for_busnum(bus, PFUZE100_I2C_ADDR, 1, &dev); + if (rc) { + printf("failed to get device for PMIC at address 0x%x\n", + PFUZE100_I2C_ADDR); return CMD_RET_FAILURE; }
@@ -187,8 +188,7 @@ static int pf0100_prog(void) switch (pmic_otp_prog[i].cmd) { case pmic_i2c: val = (unsigned char) (pmic_otp_prog[i].value & 0xff); - if (i2c_write(PFUZE100_I2C_ADDR, pmic_otp_prog[i].reg, - 1, &val, 1)) { + if (dm_i2c_write(dev, pmic_otp_prog[i].reg, &val, 1)) { printf("i2c write failed, reg 0x%2x, value 0x%2x\n", pmic_otp_prog[i].reg, val); return CMD_RET_FAILURE; @@ -227,4 +227,4 @@ U_BOOT_CMD( "Program the OTP fuses on the PMIC PF0100", "" ); -#endif +#endif /* CONFIG_SPL_BUILD */ diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 0763b1d986..60c4d9720d 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -52,6 +52,7 @@ CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y CONFIG_DWC_AHSATA=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 7222285ab3..5ab009c8f3 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -34,12 +34,12 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
/* I2C Configs */ -#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC -#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ -#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ -#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ +#define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ +#define CONFIG_SYS_I2C_MXC_I2C2 /* enable I2C bus 2 */ +#define CONFIG_SYS_I2C_MXC_I2C3 /* enable I2C bus 3 */ #define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_MXC_I2C3_SPEED 400000
/* OCOTP Configs */ #ifdef CONFIG_CMD_FUSE
Migrate PMIC and regulator to using driver model.
configs/apalis_imx6_defconfig | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 60c4d9720d..7e973ded74 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -45,6 +45,8 @@ CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="imx6-apalis" CONFIG_ENV_IS_IN_MMC=y @@ -60,6 +62,11 @@ CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_MII=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y +CONFIG_DM_PMIC=y +CONFIG_DM_PMIC_PFUZE100=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_PFUZE100=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_IMX_THERMAL=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y
Migrate MMC and SATA to using driver model.
While at it also enable SCSI driver model.
board/toradex/apalis_imx6/apalis_imx6.c | 102 ++++++++++++++---------- configs/apalis_imx6_defconfig | 3 + include/configs/apalis_imx6.h | 3 - 3 files changed, 64 insertions(+), 44 deletions(-)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 2c9a7db931..95ee39d09e 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -9,6 +9,7 @@ #include <common.h> #include <dm.h> #include <environment.h> +#include <ahci.h> #include <asm/arch/clock.h> #include <asm/arch/crm_regs.h> #include <asm/arch/mxc_hdmi.h> @@ -24,17 +25,21 @@ #include <asm/mach-imx/sata.h> #include <asm/mach-imx/boot_mode.h> #include <asm/mach-imx/video.h> +#include <dm/device-internal.h> #include <dm/platform_data/serial_mxc.h> #include <dm/platdata.h> +#include <dwc_ahsata.h> #include <fsl_esdhc.h> #include <input.h> #include <imx_thermal.h> #include <linux/errno.h> #include <malloc.h> -#include <mmc.h> #include <micrel.h> #include <miiphy.h> +#include <mmc.h> #include <netdev.h> +#include <usb.h> +#include <usb/ehci-ci.h>
#include "../common/tdx-cfg-block.h" #ifdef CONFIG_TDX_CMD_IMX_MFGR @@ -66,6 +71,8 @@ DECLARE_GLOBAL_DATA_PTR;
+#define APALIS_IMX6_SATA_INIT_RETRIES 10 + int dram_init(void) { /* use the DDR controllers configured size */ @@ -85,6 +92,7 @@ iomux_v3_cfg_t const uart1_pads_dte[] = { MX6_PAD_CSI0_DAT11__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
+#if defined(CONFIG_FSL_ESDHC) && defined(CONFIG_SPL_BUILD) /* Apalis MMC1 */ iomux_v3_cfg_t const usdhc1_pads[] = { MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -127,6 +135,7 @@ iomux_v3_cfg_t const usdhc3_pads[] = { MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), MX6_PAD_SD3_RST__GPIO7_IO08 | MUX_PAD_CTRL(WEAK_PULLUP), }; +#endif /* CONFIG_FSL_ESDHC & CONFIG_SPL_BUILD */
int mx6_rgmii_rework(struct phy_device *phydev) { @@ -285,7 +294,7 @@ int board_ehci_power(int port, int on) } #endif
-#ifdef CONFIG_FSL_ESDHC +#if defined(CONFIG_FSL_ESDHC) && defined(CONFIG_SPL_BUILD) /* use the following sequence: eMMC, MMC, SD */ struct fsl_esdhc_cfg usdhc_cfg[CONFIG_SYS_FSL_USDHC_NUM] = { {USDHC3_BASE_ADDR}, @@ -314,43 +323,6 @@ int board_mmc_getcd(struct mmc *mmc)
int board_mmc_init(bd_t *bis) { -#ifndef CONFIG_SPL_BUILD - s32 status = 0; - u32 index = 0; - - usdhc_cfg[0].sdhc_clk = mxc_get_clock(MXC_ESDHC3_CLK); - usdhc_cfg[1].sdhc_clk = mxc_get_clock(MXC_ESDHC_CLK); - usdhc_cfg[2].sdhc_clk = mxc_get_clock(MXC_ESDHC2_CLK); - - usdhc_cfg[0].max_bus_width = 8; - usdhc_cfg[1].max_bus_width = 8; - usdhc_cfg[2].max_bus_width = 4; - - for (index = 0; index < CONFIG_SYS_FSL_USDHC_NUM; ++index) { - switch (index) { - case 0: - imx_iomux_v3_setup_multiple_pads( - usdhc3_pads, ARRAY_SIZE(usdhc3_pads)); - break; - case 1: - imx_iomux_v3_setup_multiple_pads( - usdhc1_pads, ARRAY_SIZE(usdhc1_pads)); - break; - case 2: - imx_iomux_v3_setup_multiple_pads( - usdhc2_pads, ARRAY_SIZE(usdhc2_pads)); - break; - default: - printf("Warning: you configured more USDHC controllers (%d) then supported by the board (%d)\n", - index + 1, CONFIG_SYS_FSL_USDHC_NUM); - return status; - } - - status |= fsl_esdhc_initialize(bis, &usdhc_cfg[index]); - } - - return status; -#else /* CONFIG_SPL_BUILD */ struct src *psrc = (struct src *)SRC_BASE_ADDR; unsigned reg = readl(&psrc->sbmr1) >> 11; /* @@ -389,9 +361,8 @@ int board_mmc_init(bd_t *bis) }
return fsl_esdhc_initialize(bis, &usdhc_cfg[0]); -#endif /* CONFIG_SPL_BUILD */ } -#endif /* CONFIG_FSL_ESDHC */ +#endif /* CONFIG_FSL_ESDHC & CONFIG_SPL_BUILD */
int board_phy_config(struct phy_device *phydev) { @@ -1150,3 +1121,52 @@ U_BOOT_DEVICE(mxc_serial) = { .name = "serial_mxc", .platdata = &mxc_serial_plat, }; + +#if CONFIG_IS_ENABLED(AHCI) +static int sata_imx_probe(struct udevice *dev) +{ + int i, err; + + for (i = 0; i < APALIS_IMX6_SATA_INIT_RETRIES; i++) { + err = setup_sata(); + if (err) { + printf("SATA setup failed: %d\n", err); + return err; + } + + udelay(100); + + err = dwc_ahsata_probe(dev); + if (!err) + break; + + /* There is no device on the SATA port */ + if (sata_dm_port_status(0, 0) == 0) + break; + + /* There's a device, but link not established. Retry */ + device_remove(dev, DM_REMOVE_NORMAL); + } + + return 0; +} + +struct ahci_ops sata_imx_ops = { + .port_status = dwc_ahsata_port_status, + .reset = dwc_ahsata_bus_reset, + .scan = dwc_ahsata_scan, +}; + +static const struct udevice_id sata_imx_ids[] = { + { .compatible = "fsl,imx6q-ahci" }, + { } +}; + +U_BOOT_DRIVER(sata_imx) = { + .name = "dwc_ahci", + .id = UCLASS_AHCI, + .of_match = sata_imx_ids, + .ops = &sata_imx_ops, + .probe = sata_imx_probe, +}; +#endif /* AHCI */ diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 7e973ded74..510161ad32 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y CONFIG_CMD_HDMIDETECT=y +CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y @@ -55,6 +56,7 @@ CONFIG_DWC_AHSATA=y CONFIG_DFU_MMC=y CONFIG_DM_GPIO=y CONFIG_DM_I2C=y +CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_PHYLIB=y CONFIG_PHY_MICREL=y @@ -67,6 +69,7 @@ CONFIG_DM_PMIC_PFUZE100=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_PFUZE100=y CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_SCSI=y CONFIG_IMX_THERMAL=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 5ab009c8f3..6b20d1e104 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -57,9 +57,6 @@ * SATA Configs */ #ifdef CONFIG_CMD_SATA -#define CONFIG_SYS_SATA_MAX_DEVICE 1 -#define CONFIG_DWC_AHSATA_PORT_ID 0 -#define CONFIG_DWC_AHSATA_BASE_ADDR SATA_ARB_BASE_ADDR #define CONFIG_LBA48 #endif
Hi Marcel,
Thank you for providing this solution to keep SATA working on i.MX6 under DM_SCSI. I also want to use this on a tbs2910 board, there was a long list of other boards needing this functionality [1].
Can you implement the UCLASS at a more general place, e.g. drivers/ata/dwc_ahsata.c directly, instead of your board file? So this functionality could easily be enabled for other boards.
Thank you, Soeren
[1] https://lists.denx.de/pipermail/u-boot/2018-November/349368.html
- s32 status = 0;
- u32 index = 0;
switch (index) {
case 0:
break;
case 1:
break;
case 2:
break;
default:
return status;
- return status;
- int i, err;
- for (i = 0; i < APALIS_IMX6_SATA_INIT_RETRIES; i++) {
err = setup_sata();
if (err) {
return err;
udelay(100);
if (!err)
break;
break;
- .port_status = dwc_ahsata_port_status,
- .reset = dwc_ahsata_bus_reset,
- .scan = dwc_ahsata_scan,
- { .compatible = "fsl,imx6q-ahci" },
- .name = "dwc_ahci",
- .id = UCLASS_AHCI,
- .of_match = sata_imx_ids,
- .ops = &sata_imx_ops,
- .probe = sata_imx_probe,
- SATA Configs
Migrate USB to using driver model.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
board/toradex/apalis_imx6/apalis_imx6.c | 22 ---------------------- configs/apalis_imx6_defconfig | 1 + 2 files changed, 1 insertion(+), 22 deletions(-)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 95ee39d09e..8a1f8bcc5f 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -270,28 +270,6 @@ int board_ehci_hcd_init(int port) imx_iomux_v3_setup_multiple_pads(usb_pads, ARRAY_SIZE(usb_pads)); return 0; } - -int board_ehci_power(int port, int on) -{ - switch (port) { - case 0: - /* control OTG power */ - gpio_direction_output(GPIO_USBO_EN, on); - mdelay(100); - break; - case 1: - /* Control MXM USBH */ - gpio_direction_output(GPIO_USBH_EN, on); - mdelay(2); - /* Control onboard USB Hub VBUS */ - gpio_direction_output(GPIO_USB_VBUS_DET, on); - mdelay(100); - break; - default: - break; - } - return 0; -} #endif
#if defined(CONFIG_FSL_ESDHC) && defined(CONFIG_SPL_BUILD) diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 510161ad32..1ab5edc966 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -72,6 +72,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_SCSI=y CONFIG_IMX_THERMAL=y CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex"
This doesn't do anything anymore, probably never did.
Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
board/toradex/apalis_imx6/apalis_imx6.c | 7 ------- include/configs/apalis_imx6.h | 2 -- 2 files changed, 9 deletions(-)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 8a1f8bcc5f..063c13dd50 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -697,13 +697,6 @@ int board_late_init(void) } #endif /* CONFIG_BOARD_LATE_INIT */
-#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_SYSTEM_SETUP) -int ft_system_setup(void *blob, bd_t *bd) -{ - return 0; -} -#endif - int checkboard(void) { char it[] = " IT"; diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 6b20d1e104..382048d2ef 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -259,8 +259,6 @@ #define CONFIG_SYS_MMC_ENV_PART 1 #endif
-#define CONFIG_OF_SYSTEM_SETUP - #define CONFIG_CMD_TIME
#endif /* __CONFIG_H */
Add support for distro boot. This is especially helpful for external devices. There is a global boot command which scans a predefined list of boot targets: run distro_bootcmd
As well as direct boot commands such as: run bootcmd_mmc1 run bootcmd_mmc2 run bootcmd_usb run bootcmd_dhcp ...
Refer to doc/README.distro for details.
While at it, remove the CONFIG_DRIVE_TYPES define which has not been used and was meant to be used for multi device boot support which is now provided by distroboot.
Signed-off-by: Stefan Agner stefan.agner@toradex.com Acked-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
include/configs/apalis_imx6.h | 30 ++++++++++++++++-------------- 1 file changed, 16 insertions(+), 14 deletions(-)
diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 382048d2ef..5f865e1f08 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -109,20 +109,19 @@
#define CONFIG_LOADADDR 0x12000000
-#ifdef CONFIG_CMD_SATA -#define CONFIG_DRIVE_SATA "sata " +#ifndef CONFIG_SPL_BUILD +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 1) \ + func(MMC, mmc, 2) \ + func(USB, usb, 0) \ + func(DHCP, dhcp, na) +#include <config_distro_bootcmd.h> +#undef BOOTENV_RUN_NET_USB_START +#define BOOTENV_RUN_NET_USB_START "" #else -#define CONFIG_DRIVE_SATA +#define BOOTENV #endif
-#ifdef CONFIG_CMD_MMC -#define CONFIG_DRIVE_MMC "mmc " -#else -#define CONFIG_DRIVE_MMC -#endif - -#define CONFIG_DRIVE_TYPES CONFIG_DRIVE_SATA CONFIG_DRIVE_MMC - #define DFU_ALT_EMMC_INFO \ "u-boot.imx raw 0x2 0x3ff mmcpart 0;" \ "boot part 0 1;" \ @@ -149,7 +148,9 @@ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ "kernel_addr_r=0x11000000\0" \ - "ramdisk_addr_r=0x12100000\0" + "pxefile_addr_r=0x17100000\0" \ + "ramdisk_addr_r=0x12100000\0" \ + "scriptaddr=0x17000000\0"
#define NFS_BOOTCMD \ "nfsargs=ip=:::::eth0:on root=/dev/nfs rw\0" \ @@ -191,9 +192,10 @@ #define FDT_FILE "imx6q-apalis_v1_0-eval.dtb" #endif #define CONFIG_EXTRA_ENV_SETTINGS \ + BOOTENV \ "bootcmd=run emmcboot ; echo ; echo emmcboot failed ; " \ - "run nfsboot ; echo ; echo nfsboot failed ; " \ - "usb start ;" \ + "run distro_bootcmd ; " \ + "usb start ; " \ "setenv stdout serial,vga ; setenv stdin serial,usbkbd\0" \ "boot_file=uImage\0" \ "console=ttymxc0\0" \
From: Max Krummenacher max.krummenacher@toradex.com
During porting to 2016.11 the check of a SD (mmc2) interface was dropped, this was unintended.
include/configs/apalis_imx6.h | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 5f865e1f08..7df32feb0d 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -210,8 +210,10 @@ "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ "00:14:2d:00:00:00; fi; tftpboot ${loadaddr} " \ "flash_eth.img && source ${loadaddr}\0" \ - "setsdupdate=setenv interface mmc; setenv drive 1; mmc rescan; load " \ - "${interface} ${drive}:1 ${loadaddr} flash_blk.img && " \ + "setsdupdate=setenv interface mmc; setenv drive 1; mmc rescan; " \ + "load ${interface} ${drive}:1 ${loadaddr} flash_blk.img " \ + "|| setenv drive 2; mmc rescan; load ${interface} ${drive}:1" \ + " ${loadaddr} flash_blk.img && " \ "source ${loadaddr}\0" \ "setup=setenv setupargs fec_mac=${ethaddr} " \ "consoleblank=0 no_console_suspend=1 console=tty1 " \
In the Linux device tree we use 40Ohm drive strength. So use the same value in U-Boot.
board/toradex/apalis_imx6/apalis_imx6.c | 24 ++++++++++++++---------- 1 file changed, 14 insertions(+), 10 deletions(-)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 063c13dd50..99bd9232dc 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -53,6 +53,10 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_SRE_FAST | PAD_CTL_HYS)
#define USDHC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ + PAD_CTL_SPEED_LOW | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +#define USDHC_EMMC_PAD_CTRL (PAD_CTL_PUS_47K_UP | \ PAD_CTL_SPEED_LOW | PAD_CTL_DSE_80ohm | \ PAD_CTL_SRE_FAST | PAD_CTL_HYS)
@@ -123,16 +127,16 @@ iomux_v3_cfg_t const usdhc2_pads[] = {
/* eMMC */ iomux_v3_cfg_t const usdhc3_pads[] = { - MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_PAD_CTRL), - MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_PAD_CTRL), + MX6_PAD_SD3_CLK__SD3_CLK | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_CMD__SD3_CMD | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT0__SD3_DATA0 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT4__SD3_DATA4 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT5__SD3_DATA5 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT6__SD3_DATA6 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), + MX6_PAD_SD3_DAT7__SD3_DATA7 | MUX_PAD_CTRL(USDHC_EMMC_PAD_CTRL), MX6_PAD_SD3_RST__GPIO7_IO08 | MUX_PAD_CTRL(WEAK_PULLUP), }; #endif /* CONFIG_FSL_ESDHC & CONFIG_SPL_BUILD */
Keep debug code at the end of the function. Use a one line informational message for the PMIC only.
board/toradex/apalis_imx6/pf0100.c | 110 +++++++++++++++-------------- 1 file changed, 56 insertions(+), 54 deletions(-)
diff --git a/board/toradex/apalis_imx6/pf0100.c b/board/toradex/apalis_imx6/pf0100.c index 6ff21adf50..030124c0ae 100644 --- a/board/toradex/apalis_imx6/pf0100.c +++ b/board/toradex/apalis_imx6/pf0100.c @@ -36,7 +36,7 @@ unsigned pmic_init(void) uchar bus = 1; uchar devid, revid, val;
- puts("PMIC: "); + puts("PMIC: "); rc = i2c_get_chip_for_busnum(bus, PFUZE100_I2C_ADDR, 1, &dev); if (rc) { printf("failed to get device for PMIC at address 0x%x\n", @@ -52,57 +52,8 @@ unsigned pmic_init(void) puts("i2c pmic revid read failed\n"); return 0; } - printf("device id: 0x%.2x, revision id: 0x%.2x\n", devid, revid); + printf("device id: 0x%.2x, revision id: 0x%.2x, ", devid, revid);
-#ifdef DEBUG - { - unsigned i, j; - - for (i = 0; i < 16; i++) - printf("\t%x", i); - for (j = 0; j < 0x80; ) { - printf("\n%2x", j); - for (i = 0; i < 16; i++) { - dm_i2c_read(dev, j + i, &val, 1); - printf("\t%2x", val); - } - j += 0x10; - } - printf("\nEXT Page 1"); - - val = PFUZE100_PAGE_REGISTER_PAGE1; - if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { - puts("i2c write failed\n"); - return 0; - } - - for (j = 0x80; j < 0x100; ) { - printf("\n%2x", j); - for (i = 0; i < 16; i++) { - dm_i2c_read(dev, j + i, &val, 1); - printf("\t%2x", val); - } - j += 0x10; - } - printf("\nEXT Page 2"); - - val = PFUZE100_PAGE_REGISTER_PAGE2; - if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { - puts("i2c write failed\n"); - return 0; - } - - for (j = 0x80; j < 0x100; ) { - printf("\n%2x", j); - for (i = 0; i < 16; i++) { - dm_i2c_read(dev, j + i, &val, 1); - printf("\t%2x", val); - } - j += 0x10; - } - printf("\n"); - } -#endif /* DEBUG */ /* get device programmed state */ val = PFUZE100_PAGE_REGISTER_PAGE1; if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { @@ -132,13 +83,13 @@ unsigned pmic_init(void)
switch (programmed) { case 0: - printf("PMIC: not programmed\n"); + puts("not programmed\n"); break; case 3: - printf("PMIC: programmed\n"); + puts("programmed\n"); break; default: - printf("PMIC: undefined programming state\n"); + puts("undefined programming state\n"); break; }
@@ -156,6 +107,57 @@ unsigned pmic_init(void) if (dm_i2c_write(dev, PFUZE100_SWBSTCTL, &val, 1)) puts("i2c write failed\n"); } + +#ifdef DEBUG + { + unsigned int i, j; + + for (i = 0; i < 16; i++) + printf("\t%x", i); + for (j = 0; j < 0x80; ) { + printf("\n%2x", j); + for (i = 0; i < 16; i++) { + dm_i2c_read(dev, j + i, &val, 1); + printf("\t%2x", val); + } + j += 0x10; + } + printf("\nEXT Page 1"); + + val = PFUZE100_PAGE_REGISTER_PAGE1; + if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { + puts("i2c write failed\n"); + return 0; + } + + for (j = 0x80; j < 0x100; ) { + printf("\n%2x", j); + for (i = 0; i < 16; i++) { + dm_i2c_read(dev, j + i, &val, 1); + printf("\t%2x", val); + } + j += 0x10; + } + printf("\nEXT Page 2"); + + val = PFUZE100_PAGE_REGISTER_PAGE2; + if (dm_i2c_write(dev, PFUZE100_PAGE_REGISTER, &val, 1)) { + puts("i2c write failed\n"); + return 0; + } + + for (j = 0x80; j < 0x100; ) { + printf("\n%2x", j); + for (i = 0; i < 16; i++) { + dm_i2c_read(dev, j + i, &val, 1); + printf("\t%2x", val); + } + j += 0x10; + } + printf("\n"); + } +#endif /* DEBUG */ + return programmed; }
If the UART is used in DTE mode the RI and DCD bits in UCR3 become irq enable bits. Both are set to enabled after reset and both likely are pending.
Disable the bits also on UARTs not used in the boot loader to prevent an interrupt storm when Linux enables the UART interrupts.
board/toradex/apalis_imx6/apalis_imx6.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 99bd9232dc..696994a6b6 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -236,8 +236,11 @@ iomux_v3_cfg_t const usb_pads[] = { * UARTs are used in DTE mode, switch the mode on all UARTs before * any pinmuxing connects a (DCE) output to a transceiver output. */ +#define UCR3 0x88 /* FIFO Control Register */ +#define UCR3_RI BIT(8) /* RIDELT DTE mode */ +#define UCR3_DCD BIT(9) /* DCDDELT DTE mode */ #define UFCR 0x90 /* FIFO Control Register */ -#define UFCR_DCEDTE (1<<6) /* DCE=0 */ +#define UFCR_DCEDTE BIT(6) /* DCE=0 */
static void setup_dtemode_uart(void) { @@ -245,6 +248,11 @@ static void setup_dtemode_uart(void) setbits_le32((u32 *)(UART2_BASE + UFCR), UFCR_DCEDTE); setbits_le32((u32 *)(UART4_BASE + UFCR), UFCR_DCEDTE); setbits_le32((u32 *)(UART5_BASE + UFCR), UFCR_DCEDTE); + + clrbits_le32((u32 *)(UART1_BASE + UCR3), UCR3_DCD | UCR3_RI); + clrbits_le32((u32 *)(UART2_BASE + UCR3), UCR3_DCD | UCR3_RI); + clrbits_le32((u32 *)(UART4_BASE + UCR3), UCR3_DCD | UCR3_RI); + clrbits_le32((u32 *)(UART5_BASE + UCR3), UCR3_DCD | UCR3_RI); } static void setup_dcemode_uart(void) {
We have two commands to change the bootmode fuses: mfgr_fuse which set fuse 0/5 and 0/6 and updt_fuse which burns bit 4 of 0/5.
Before BSP 2.6 we fused in mfgr_fuse 0x5062, which boots from the user partition of the eMMC. To workaround certain hangs we moved to fastboot mode and using the first bootpartition of the eMMC requiring a fuse value of 0x5072 which could be achieved by the then added updt_fuse command. At the same time the mfgr_fuse command was changed to also fuse 0x5072, revert that second change so that one can fuse both values, one with just mfgr_fuse and the later with mfgr_fuse;updt_fuse.
Note that the mfgr_fuse command is only needed at module production time, a customer might need to use updt_fuse when upgrading an older module to be compatible with a newer image. The command is integrated into the image update scripts.
Signed-off-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Stefan Agner stefan.agner@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
board/toradex/apalis_imx6/do_fuse.c | 2 +- board/toradex/colibri_imx6/do_fuse.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/toradex/apalis_imx6/do_fuse.c b/board/toradex/apalis_imx6/do_fuse.c index e6793e366a..22d191f52a 100644 --- a/board/toradex/apalis_imx6/do_fuse.c +++ b/board/toradex/apalis_imx6/do_fuse.c @@ -29,7 +29,7 @@ static int mfgr_fuse(void) return CMD_RET_FAILURE; } /* boot cfg */ - fuse_prog(0, 5, 0x00005072); + fuse_prog(0, 5, 0x00005062); /* BT_FUSE_SEL */ fuse_prog(0, 6, 0x00000010); return CMD_RET_SUCCESS; diff --git a/board/toradex/colibri_imx6/do_fuse.c b/board/toradex/colibri_imx6/do_fuse.c index e6793e366a..22d191f52a 100644 --- a/board/toradex/colibri_imx6/do_fuse.c +++ b/board/toradex/colibri_imx6/do_fuse.c @@ -29,7 +29,7 @@ static int mfgr_fuse(void) return CMD_RET_FAILURE; } /* boot cfg */ - fuse_prog(0, 5, 0x00005072); + fuse_prog(0, 5, 0x00005062); /* BT_FUSE_SEL */ fuse_prog(0, 6, 0x00000010); return CMD_RET_SUCCESS;
Use ext4 file system by default.
Signed-off-by: Sanchayan Maity maitysanchayan@gmail.com Acked-by: Max Krummenacher max.krummenacher@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
include/configs/apalis_imx6.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 7df32feb0d..a49b08ba45 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -131,7 +131,7 @@ "imx6q-colibri-cam-eval-v3.dtb fat 0 1"
#define EMMC_BOOTCMD \ - "emmcargs=ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext3 " \ + "emmcargs=ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext4 " \ "rootwait\0" \ "emmcboot=run setup; " \ "setenv bootargs ${defargs} ${emmcargs} ${setupargs} " \ @@ -163,7 +163,7 @@ "&& setenv dtbparam " - ${fdt_addr_r}" && true\0"
#define SD_BOOTCMD \ - "sdargs=ip=off root=/dev/mmcblk1p2 rw,noatime rootfstype=ext3 " \ + "sdargs=ip=off root=/dev/mmcblk1p2 rw,noatime rootfstype=ext4 " \ "rootwait\0" \ "sdboot=run setup; " \ "setenv bootargs ${defargs} ${sdargs} ${setupargs} " \ @@ -175,7 +175,7 @@ "${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true\0"
#define USB_BOOTCMD \ - "usbargs=ip=off root=/dev/sda2 rw,noatime rootfstype=ext3 " \ + "usbargs=ip=off root=/dev/sda2 rw,noatime rootfstype=ext4 " \ "rootwait\0" \ "usbboot=run setup; setenv bootargs ${defargs} ${setupargs} " \ "${usbargs} ${vidargs}; echo Booting from USB stick...; " \
In case USB serial downloader has been used to load U-Boot start the serial download protocol (SDP) emulation. This allows to download complete images such as Toradex Easy Installer over USB SDP as well. This code uses the boot ROM provided boot information to reliably detect USB serial downloader.
Signed-off-by: Stefan Agner stefan.agner@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
board/toradex/apalis_imx6/apalis_imx6.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index 696994a6b6..542b1ebafe 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -705,6 +705,14 @@ int board_late_init(void) #endif /* CONFIG_TDX_APALIS_IMX6_V1_0 */ #endif /* CONFIG_REVISION_TAG */
+#ifdef CONFIG_CMD_USB_SDP + if (is_boot_from_usb()) { + printf("Serial Downloader recovery mode, using sdp command\n"); + env_set("bootdelay", "0"); + env_set("bootcmd", "sdp 0"); + } +#endif /* CONFIG_CMD_USB_SDP */ + return 0; } #endif /* CONFIG_BOARD_LATE_INIT */
Switch to the generic compressed Kernel image type (zImage) instead of the U-Boot specific uImage format.
Signed-off-by: Bhuvanchandra DV bhuvanchandra.dv@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
include/configs/apalis_imx6.h | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index a49b08ba45..275d3a5a1f 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -126,7 +126,7 @@ "u-boot.imx raw 0x2 0x3ff mmcpart 0;" \ "boot part 0 1;" \ "rootfs part 0 2;" \ - "uImage fat 0 1;" \ + "zImage fat 0 1;" \ "imx6q-colibri-eval-v3.dtb fat 0 1;" \ "imx6q-colibri-cam-eval-v3.dtb fat 0 1"
@@ -138,7 +138,7 @@ "${vidargs}; echo Booting from internal eMMC chip...; " \ "run emmcdtbload; load mmc 0:1 ${kernel_addr_r} " \ "${boot_file} && run fdt_fixup && " \ - "bootm ${kernel_addr_r} ${dtbparam}\0" \ + "bootz ${kernel_addr_r} ${dtbparam}\0" \ "emmcdtbload=setenv dtbparam; load mmc 0:1 ${fdt_addr_r} " \ "${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true\0"
@@ -158,7 +158,7 @@ "setenv bootargs ${defargs} ${nfsargs} ${setupargs} " \ "${vidargs}; echo Booting via DHCP/TFTP/NFS...; " \ "run nfsdtbload; dhcp ${kernel_addr_r} " \ - "&& run fdt_fixup && bootm ${kernel_addr_r} ${dtbparam}\0" \ + "&& run fdt_fixup && bootz ${kernel_addr_r} ${dtbparam}\0" \ "nfsdtbload=setenv dtbparam; tftp ${fdt_addr_r} ${fdt_file} " \ "&& setenv dtbparam " - ${fdt_addr_r}" && true\0"
@@ -170,7 +170,7 @@ "${vidargs}; echo Booting from SD card; " \ "run sddtbload; load mmc 1:1 ${kernel_addr_r} " \ "${boot_file} && run fdt_fixup && " \ - "bootm ${kernel_addr_r} ${dtbparam}\0" \ + "bootz ${kernel_addr_r} ${dtbparam}\0" \ "sddtbload=setenv dtbparam; load mmc 1:1 ${fdt_addr_r} " \ "${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true\0"
@@ -181,7 +181,7 @@ "${usbargs} ${vidargs}; echo Booting from USB stick...; " \ "usb start && run usbdtbload; load usb 0:1 ${kernel_addr_r} " \ "${boot_file} && run fdt_fixup && " \ - "bootm ${kernel_addr_r} ${dtbparam}\0" \ + "bootz ${kernel_addr_r} ${dtbparam}\0" \ "usbdtbload=setenv dtbparam; load usb 0:1 ${fdt_addr_r} " \ "${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true\0"
@@ -197,7 +197,7 @@ "run distro_bootcmd ; " \ "usb start ; " \ "setenv stdout serial,vga ; setenv stdin serial,usbkbd\0" \ - "boot_file=uImage\0" \ + "boot_file=zImage\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off vmalloc=400M\0" \ "dfu_alt_info=" DFU_ALT_EMMC_INFO "\0" \
From: Gerard Salvatella gerard.salvatella@toradex.com
The PMIC on Apalis iMX6 may have ECC errors in fuses that will prevent correct settings. Up to one bit error per fuse bank may be reported and corrected by the ECC logic. Two bit errors can only be reported.
Signed-off-by: Gerard Salvatella gerard.salvatella@toradex.com Acked-by: Marcel Ziswiler marcel.ziswiler@toradex.com
board/toradex/apalis_imx6/pf0100.c | 51 ++++++++++++++++++++++++++ board/toradex/apalis_imx6/pf0100.h | 57 +++++++++++++++++++++++++++++- 2 files changed, 107 insertions(+), 1 deletion(-)
diff --git a/board/toradex/apalis_imx6/pf0100.c b/board/toradex/apalis_imx6/pf0100.c index 030124c0ae..8fc08d39b2 100644 --- a/board/toradex/apalis_imx6/pf0100.c +++ b/board/toradex/apalis_imx6/pf0100.c @@ -22,6 +22,8 @@ /* define for PMIC register dump */ /*#define DEBUG */
+#define WARNBAR "@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@\n" + /* use Apalis GPIO1 to switch on VPGM, ON: 1 */ static __maybe_unused iomux_v3_cfg_t const pmic_prog_pads[] = { MX6_PAD_NANDF_D4__GPIO2_IO04 | MUX_PAD_CTRL(NO_PAD_CTRL), @@ -43,6 +45,55 @@ unsigned pmic_init(void) PFUZE100_I2C_ADDR); return 0; } + + /* check for errors in PMIC fuses */ + if (dm_i2c_read(dev, PFUZE100_INTSTAT3, &val, 1) < 0) { + puts("i2c pmic INTSTAT3 register read failed\n"); + return 0; + } + if (val & PFUZE100_BIT_OTP_ECCI) { + puts("\n" WARNBAR); + puts("WARNING: ecc errors found in pmic fuse banks\n"); + puts(WARNBAR); + } + if (dm_i2c_read(dev, PFUZE100_OTP_ECC_SE1, &val, 1) < 0) { + puts("i2c pmic ECC_SE1 register read failed\n"); + return 0; + } + if (val & PFUZE100_BITS_ECC_SE1) { + puts(WARNBAR); + puts("WARNING: ecc has made bit corrections in banks 1 to 5\n"); + puts(WARNBAR); + } + if (dm_i2c_read(dev, PFUZE100_OTP_ECC_SE2, &val, 1) < 0) { + puts("i2c pmic ECC_SE2 register read failed\n"); + return 0; + } + if (val & PFUZE100_BITS_ECC_SE2) { + puts(WARNBAR); + puts("WARNING: ecc has made bit corrections in banks 6 to 10\n" + ); + puts(WARNBAR); + } + if (dm_i2c_read(dev, PFUZE100_OTP_ECC_DE1, &val, 1) < 0) { + puts("i2c pmic ECC_DE register read failed\n"); + return 0; + } + if (val & PFUZE100_BITS_ECC_DE1) { + puts(WARNBAR); + puts("ERROR: banks 1 to 5 have uncorrectable bits\n"); + puts(WARNBAR); + } + if (dm_i2c_read(dev, PFUZE100_OTP_ECC_DE2, &val, 1) < 0) { + puts("i2c pmic ECC_DE register read failed\n"); + return 0; + } + if (val & PFUZE100_BITS_ECC_DE2) { + puts(WARNBAR); + puts("ERROR: banks 6 to 10 have uncorrectable bits\n"); + puts(WARNBAR); + } + /* get device ident */ if (dm_i2c_read(dev, PFUZE100_DEVICEID, &devid, 1) < 0) { puts("i2c pmic devid read failed\n"); diff --git a/board/toradex/apalis_imx6/pf0100.h b/board/toradex/apalis_imx6/pf0100.h index c0efb79bbc..e4eb2bd542 100644 --- a/board/toradex/apalis_imx6/pf0100.h +++ b/board/toradex/apalis_imx6/pf0100.h @@ -10,11 +10,23 @@ #ifndef PF0100_H_ #define PF0100_H_
+/* bit definitions */ +#define PFUZE100_BIT_0 (0x01 << 0) +#define PFUZE100_BIT_1 (0x01 << 1) +#define PFUZE100_BIT_2 (0x01 << 2) +#define PFUZE100_BIT_3 (0x01 << 3) +#define PFUZE100_BIT_4 (0x01 << 4) +#define PFUZE100_BIT_5 (0x01 << 5) +#define PFUZE100_BIT_6 (0x01 << 6) +#define PFUZE100_BIT_7 (0x01 << 7) + /* 7-bit I2C bus slave address */ #define PFUZE100_I2C_ADDR (0x08) /* Register Addresses */ #define PFUZE100_DEVICEID (0x0) #define PFUZE100_REVID (0x3) +#define PFUZE100_INTSTAT3 (0xe) +#define PFUZE100_BIT_OTP_ECCI PFUZE100_BIT_7 #define PFUZE100_SW1AMODE (0x23) #define PFUZE100_SW1ACON 36 #define PFUZE100_SW1ACON_SPEED_VAL (0x1<<6) /*default */ @@ -39,12 +51,55 @@ #define PFUZE100_PAGE_REGISTER_PAGE2 (0x02 & PFUZE100_PAGE_REGISTER_PAGE_M)
/* extended page 1 */ +#define PFUZE100_OTP_ECC_SE1 0x8a +#define PFUZE100_BIT_ECC1_SE PFUZE100_BIT_0 +#define PFUZE100_BIT_ECC2_SE PFUZE100_BIT_1 +#define PFUZE100_BIT_ECC3_SE PFUZE100_BIT_2 +#define PFUZE100_BIT_ECC4_SE PFUZE100_BIT_3 +#define PFUZE100_BIT_ECC5_SE PFUZE100_BIT_4 +#define PFUZE100_BITS_ECC_SE1 ((PFUZE100_BIT_ECC1_SE) | \ + (PFUZE100_BIT_ECC2_SE) | \ + (PFUZE100_BIT_ECC3_SE) | \ + (PFUZE100_BIT_ECC4_SE) | \ + (PFUZE100_BIT_ECC5_SE)) +#define PFUZE100_OTP_ECC_SE2 0x8b +#define PFUZE100_BIT_ECC6_SE PFUZE100_BIT_0 +#define PFUZE100_BIT_ECC7_SE PFUZE100_BIT_1 +#define PFUZE100_BIT_ECC8_SE PFUZE100_BIT_2 +#define PFUZE100_BIT_ECC9_SE PFUZE100_BIT_3 +#define PFUZE100_BIT_ECC10_SE PFUZE100_BIT_4 +#define PFUZE100_BITS_ECC_SE2 ((PFUZE100_BIT_ECC6_SE) | \ + (PFUZE100_BIT_ECC7_SE) | \ + (PFUZE100_BIT_ECC8_SE) | \ + (PFUZE100_BIT_ECC9_SE) | \ + (PFUZE100_BIT_ECC10_SE)) +#define PFUZE100_OTP_ECC_DE1 0x8c +#define PFUZE100_BIT_ECC1_DE PFUZE100_BIT_0 +#define PFUZE100_BIT_ECC2_DE PFUZE100_BIT_1 +#define PFUZE100_BIT_ECC3_DE PFUZE100_BIT_2 +#define PFUZE100_BIT_ECC4_DE PFUZE100_BIT_3 +#define PFUZE100_BIT_ECC5_DE PFUZE100_BIT_4 +#define PFUZE100_BITS_ECC_DE1 ((PFUZE100_BIT_ECC1_DE) | \ + (PFUZE100_BIT_ECC2_DE) | \ + (PFUZE100_BIT_ECC3_DE) | \ + (PFUZE100_BIT_ECC4_DE) | \ + (PFUZE100_BIT_ECC5_DE)) +#define PFUZE100_OTP_ECC_DE2 0x8d +#define PFUZE100_BIT_ECC6_DE PFUZE100_BIT_0 +#define PFUZE100_BIT_ECC7_DE PFUZE100_BIT_1 +#define PFUZE100_BIT_ECC8_DE PFUZE100_BIT_2 +#define PFUZE100_BIT_ECC9_DE PFUZE100_BIT_3 +#define PFUZE100_BIT_ECC10_DE PFUZE100_BIT_4 +#define PFUZE100_BITS_ECC_DE2 ((PFUZE100_BIT_ECC6_DE) | \ + (PFUZE100_BIT_ECC7_DE) | \ + (PFUZE100_BIT_ECC8_DE) | \ + (PFUZE100_BIT_ECC9_DE) | \ + (PFUZE100_BIT_ECC10_DE)) #define PFUZE100_FUSE_POR1 0xe4 #define PFUZE100_FUSE_POR2 0xe5 #define PFUZE100_FUSE_POR3 0xe6 #define PFUZE100_FUSE_POR_M (0x1 << 1)
- /* output some informational messages, return the number FUSE_POR=1 */ /* i.e. 0: unprogrammed, 3: programmed, other: undefined prog. state */ unsigned pmic_init(void);
Marcel Ziswiler
Soeren Moch
